cgma
#include "CubitDefines.h"Go to the source code of this file.
Functions | |
| CubitStatus | CubitCompat_import_solid_model (const char *file_name, const char *file_type, const char *logfile_name=NULL, CubitBoolean heal_step=CUBIT_TRUE, CubitBoolean import_bodies=CUBIT_TRUE, CubitBoolean import_surfaces=CUBIT_TRUE, CubitBoolean import_curves=CUBIT_TRUE, CubitBoolean import_vertices=CUBIT_TRUE, CubitBoolean free_surfaces=CUBIT_TRUE, DLIList< RefEntity * > *imported_entities=NULL) |
| CubitStatus | CubitCompat_export_solid_model (DLIList< RefEntity * > &ref_entity_list, const char *filename, const char *filetype, int &num_ents_exported, const CubitString &cubit_version, const char *logfile_name=NULL) |
| CubitStatus CubitCompat_export_solid_model | ( | DLIList< RefEntity * > & | ref_entity_list, |
| const char * | filename, | ||
| const char * | filetype, | ||
| int & | num_ents_exported, | ||
| const CubitString & | cubit_version, | ||
| const char * | logfile_name = NULL |
Definition at line 70 of file CubitCompat.cpp.
// const bool print_results = false;
// const bool merge_globally = false;
// const bool no_assembly_level_features = false;
ModelExportOptions CubitCompat_opts = {1, logfile_name ? logfile_name : "" };
return GeometryQueryTool::instance()->export_solid_model(
ref_entity_list,
filename,
CubitCompat_file_type(filetype),
num_ents_exported,
cubit_version,
CubitCompat_opts );
| CubitStatus CubitCompat_import_solid_model | ( | const char * | file_name, |
| const char * | file_type, | ||
| const char * | logfile_name = NULL, |
| CubitBoolean | heal_step = CUBIT_TRUE, |
| CubitBoolean | import_bodies = CUBIT_TRUE, |
| CubitBoolean | import_surfaces = CUBIT_TRUE, |
| CubitBoolean | import_curves = CUBIT_TRUE, |
| CubitBoolean | import_vertices = CUBIT_TRUE, |
| CubitBoolean | free_surfaces = CUBIT_TRUE, |
| DLIList< RefEntity * > * | imported_entities = NULL |
Definition at line 37 of file CubitCompat.cpp.
ModelImportOptions CubitCompat_opts = { heal_step,
print_results,
import_bodies,
import_surfaces,
import_curves,
import_vertices,
free_surfaces,
merge_globally,
no_assembly_level_features,
return GeometryQueryTool::instance()->import_solid_model(
file_name,
CubitCompat_file_type(file_type),
CubitCompat_opts,
imported_entities );
