cgma
a test of projecting a point onto a surface along a direction More...
#include <iostream>#include "Body.hpp"#include "CubitCompat.hpp"#include "DLIList.hpp"#include "GeometryModifyTool.hpp"#include "GeometryQueryTool.hpp"#include "InitCGMA.hpp"#include "RefEntity.hpp"#include "RefFace.hpp"#include "RefVolume.hpp"#include "Surface.hpp"Go to the source code of this file.
Defines | |
| #define | STRINGIFY(S) XSTRINGIFY(S) |
| #define | XSTRINGIFY(S) #S |
Functions | |
| bool | testDirectedProjection () |
| bool | testPieceOfTorusFromFile () |
| int | main (int argc, char **argv) |
Definition in file raySurfaceInt.cpp.
| #define STRINGIFY | ( | S | ) | XSTRINGIFY(S) |
Definition at line 25 of file raySurfaceInt.cpp.
| #define XSTRINGIFY | ( | S | ) | #S |
Definition at line 26 of file raySurfaceInt.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 31 of file raySurfaceInt.cpp.
CubitStatus status = InitCGMA::initialize_cgma();
if (CUBIT_SUCCESS != status)
return 1;
if (!testDirectedProjection())
return 2;
std::cout << std::endl;
if (!testPieceOfTorusFromFile())
return 3;
return 0;
| bool testDirectedProjection | ( | ) |
Definition at line 53 of file raySurfaceInt.cpp.
GeometryQueryTool* gqt = GeometryQueryTool::instance();
GeometryModifyTool* gmt = GeometryModifyTool::instance();
// create a sphere
Body* sphereBody = gmt->sphere(5.0);
std::cout << "Created sphere of radius 5 centered at (0, 0, 0)."
<< std::endl;
// extract the surface of the sphere
DLIList<RefEntity*> sphereChildren;
sphereBody->get_child_ref_entities(sphereChildren);
RefVolume* sphereVol = dynamic_cast<RefVolume*>(sphereChildren.get());
if (!sphereVol)
std::cout << "The child of the sphere body is not a RefVolume."
<< std::endl;
return false;
sphereVol->get_child_ref_entities(sphereChildren);
RefFace* sphereFace = dynamic_cast<RefFace*>(sphereChildren.get());
if (!sphereFace)
std::cout << "The child of the sphere volume is not a RefFace."
<< std::endl;
return false;
Surface* sphere = sphereFace->get_surface_ptr();
// test firing ray directly down at the north pole of the sphere
CubitVector raySource01(0, 0, 10);
CubitVector rayDir01(0, 0, -2); // NOTE: not a unit vector
CubitVector rayHit01;
CubitStatus rayResult01 =
sphere->closest_point_along_vector(raySource01, rayDir01, rayHit01);
if (rayResult01 != CUBIT_SUCCESS)
std::cout << "FAIL: Fire from (0, 0, 10) in direction (0, 0, -1) "
<< "did not produce CUBIT_SUCCESS." << std::endl;
return false;
std::cout << "Fire from (0, 0, 10) in direction (0, 0, -1) hits at ("
<< rayHit01.x() << ", " << rayHit01.y() << ", "
<< rayHit01.z() << ")." << std::endl;
if ((fabs(rayHit01.x() - 0) + fabs(rayHit01.y() - 0) +
fabs(rayHit01.z() - 5)) > 1e-12)
std::cout << "FAIL: The ray should hit at (0, 0, 5)." << std::endl;
return false;
// test firing ray from above the north pole at an angle that should
// hit the sphere where x = 2.5 and y = 0.
CubitVector raySource02(0, 0, 10);
CubitVector rayDir02(0.4034491106775367, 0, -0.9150020847481741);
CubitVector rayHit02;
CubitStatus rayResult02 =
sphere->closest_point_along_vector(raySource02, rayDir02, rayHit02);
if (rayResult02 != CUBIT_SUCCESS)
std::cout << "FAIL: Fire from (0, 0, 10)\n in direction "
<< "(0.4034491106775367, 0, -0.9150020847481741)\n "
return false;
std::cout << "Fire from (0, 0, 10)\n in direction "
<< "(0.4034491106775367, 0, -0.9150020847481741)\n hits at ("
<< rayHit02.x() << ", " << rayHit02.y() << ", "
<< rayHit02.z() << ")." << std::endl;
if ((fabs(rayHit02.x() - 2.5) + fabs(rayHit02.y() - 0) +
fabs(rayHit02.z() - 4.330127018922193)) > 1e-12)
std::cout << "FAIL: The ray should hit at approximately "
<< "(2.5, 0, 4.330127018922193)." << std::endl;
return false;
// test firing ray directly down from the center of the sphere
CubitVector raySource03(0, 0, 0);
CubitVector rayDir03(0, 0, -1);
CubitVector rayHit03;
CubitStatus rayResult03 =
sphere->closest_point_along_vector(raySource03, rayDir03, rayHit03);
if (rayResult03 != CUBIT_SUCCESS)
std::cout << "FAIL: Fire from (0, 0, 0) in direction (0, 0, -1) "
return false;
std::cout << "Fire from (0, 0, 0) in direction (0, 0, -1) hits at ("
<< rayHit03.x() << ", " << rayHit03.y() << ", "
<< rayHit03.z() << ")." << std::endl;
if ((fabs(rayHit03.x() - 0) + fabs(rayHit03.y() - 0) +
fabs(rayHit03.z() + 5)) > 1e-12)
std::cout << "FAIL: The ray should hit at (0, 0, -5)." << std::endl;
return false;
// delete the sphere body
gqt->delete_Body(sphereBody);
// create a torus
Body* torusBody = gmt->torus(3.0, 1.0);
std::cout << "Created torus of major radius 3 and minor radius 1 "
<< "centered at (0, 0, 0)\n with normal along the z-axis."
<< std::endl;
// extract the surface of the torus
DLIList<RefEntity*> torusChildren;
torusBody->get_child_ref_entities(torusChildren);
RefVolume* torusVol = dynamic_cast<RefVolume*>(torusChildren.get());
if (!torusVol)
std::cout << "The child of the torus body is not a RefVolume."
<< std::endl;
return false;
torusVol->get_child_ref_entities(torusChildren);
RefFace* torusFace = dynamic_cast<RefFace*>(torusChildren.get());
if (!torusFace)
std::cout << "The child of the torus volume is not a RefFace."
<< std::endl;
return false;
Surface* torus = torusFace->get_surface_ptr();
// test firing ray directly down from (0, 3.5, 1)
CubitVector raySource04(0, 3.5, 1);
CubitVector rayDir04(0, 0, -1);
CubitVector rayHit04;
CubitStatus rayResult04 =
torus->closest_point_along_vector(raySource04, rayDir04, rayHit04);
if (rayResult04 != CUBIT_SUCCESS)
std::cout << "FAIL: Fire from (0, 3.5, 1) in direction (0, 0, -1) "
return false;
std::cout << "Fire from (0, 3.5, 1) in direction (0, 0, -1)\n hits at ("
<< rayHit04.x() << ", " << rayHit04.y() << ", "
<< rayHit04.z() << ")." << std::endl;
if ((fabs(rayHit04.x() - 0) + fabs(rayHit04.y() - 3.5) +
fabs(rayHit04.z() - 0.8660254037844386)) > 1e-12)
std::cout << "FAIL: The ray should hit at (0, 3.5, 0.8660254037844386)."
<< std::endl;
return false;
// test firing ray directly down from (0, 4.5, 1)
CubitVector raySource05(0, 4.5, 1);
CubitVector rayDir05(0, 0, -1);
CubitVector rayHit05;
CubitStatus rayResult05 =
torus->closest_point_along_vector(raySource05, rayDir05, rayHit05);
if (rayResult05 != CUBIT_FAILURE)
std::cout << "FAIL: Fire from (0, 4.5, 1) in direction (0, 0, -1) "
<< "did not produce CUBIT_FAILURE." << std::endl;
return false;
std::cout << "Fire from (0, 4.5, 1) in direction (0, 0, -1) "
<< "did not intersect torus,\n as expected." << std::endl;
// test firing ray towards (-1, 1, 0) from (0, 0, 0)
CubitVector raySource06(0, 0, 0);
CubitVector rayDir06(-1, 1, 0);
CubitVector rayHit06;
CubitStatus rayResult06 =
torus->closest_point_along_vector(raySource06, rayDir06, rayHit06);
if (rayResult06 != CUBIT_SUCCESS)
std::cout << "FAIL: Fire from (0, 0, 0) in direction (-1, 1, 0) "
return false;
std::cout << "Fire from (0, 0, 0) in direction (-1, 1, 0)\n hits at ("
<< rayHit06.x() << ", " << rayHit06.y() << ", "
<< rayHit06.z() << ")." << std::endl;
if ((fabs(rayHit06.x() + 1.414213562373095) +
fabs(rayHit06.y() - 1.414213562373095) + fabs(rayHit06.z() - 0)) > 1e-12)
std::cout << "FAIL: The ray should hit\n "
<< "at (-1.414213562373095, 1.414213562373095, 0)."
<< std::endl;
return false;
// delete the torus body
gqt->delete_Body(torusBody);
return true;
| bool testPieceOfTorusFromFile | ( | ) |
Definition at line 252 of file raySurfaceInt.cpp.
std::string fileName(STRINGIFY(SRCDIR) "/pieceOfTorus01.");
fileName = fileName + FILE_EXT;
CubitStatus readGeoResult =
CubitCompat_import_solid_model(fileName.c_str(), GEO_TYPE);
if (readGeoResult != CUBIT_SUCCESS)
std::cout << "FAIL: Attempt to read geometry from " << fileName
<< " did not produce CUBIT_SUCCESS." << std::endl;
return false;
// extract the torus sheet body
DLIList<Body*> bodies;
gqt->bodies(bodies);
Body* pieceOfTorusBody = bodies.pop();
std::cout << "Extracted piece of torus body from file" << std::endl;
DLIList<RefEntity*> torusPieceChildren;
pieceOfTorusBody->get_child_ref_entities(torusPieceChildren);
RefVolume* torusPieceVol =
dynamic_cast<RefVolume*>(torusPieceChildren.get());
if (!torusPieceVol)
std::cout << "The child of the piece of torus body is not a RefVolume."
<< std::endl;
return false;
torusPieceVol->get_child_ref_entities(torusPieceChildren);
RefFace* torusPieceFace = dynamic_cast<RefFace*>(torusPieceChildren.get());
if (!torusPieceFace)
std::cout << "The child of the piece of torus volume is not a RefFace."
<< std::endl;
return false;
Surface* torusPiece = torusPieceFace->get_surface_ptr();
// test firing ray in the direction (0.707107, 0, -0.707107) from
// (3.17919, 0.1, 1.07919)
CubitVector raySource01(3.17919, 0.1, 1.07919);
CubitVector rayDir01(0.707107, 0, -0.707107);
torusPiece->closest_point_along_vector(raySource01, rayDir01, rayHit01);
std::cout << "FAIL: Fire from (3.17919, 0.1, 1.07919) "
<< "in direction (0.707107, 0, -0.707107) "
return false;
std::cout << "Fire from (3.17919, 0.1, 1.07919) "
<< "in direction (0.707107, 0, -0.707107)\n hits at ("
if ((fabs(rayHit01.x() - 3.30723) +
fabs(rayHit01.y() - 0.1) + fabs(rayHit01.z() - 0.951148)) > 1e-4)
<< "at (3.30723, 0.1, 0.951148)."
<< std::endl;
return false;
return true;
