cgma
#include "CubitDefines.h"Go to the source code of this file.
Defines | |
| #define | NUM_EDGE_CPTS 3 |
| #define | NUM_TRI_CPTS 6 |
| #define | NUM_QUAD_CPTS 15 |
Functions | |
| void | constructBezier (double angle, int numTri, int numQuad, int numEdge, int numVert, int *triEdge, int *quadEdge, int *edgeVert, double *vert, double *edgeCtrlPts, double *triCtrlPts, double *quadCtrlPts) |
| void | constructTriNormals (double angle, int numTri, int numEdge, int numVert, int *triEdge, int *edgeVert, double *vert, double *triVertNorms, double *edgeVertTang, int *edgeTypeFlags) |
| void | constructQuadNormals (double angle, int numQuad, int numEdge, int numVert, int *quadEdge, int *edgeVert, double *vert, double *quadVertNorms, double *edgeVertTang, int *edgeTypeFlags) |
| CubitStatus | constructTriNormalsFromFile (const char *filename, int numTri, int numEdge, int *triEdge, int *edgeVert, double *triVertNorms, double *edgeVertTang) |
| CubitStatus | constructQuadNormalsFromFile (const char *filename, int numQuad, int numEdge, int *quadEdge, int *edgeVert, double *quadVertNorms, double *edgeVertTang) |
| CubitStatus | readMBGNormalFile (const char *filename, int *numTri, int *numQuad, int *numEdge, int **edgeVert, double **edgeVertTang, int **triVert, double **triVertNorms, int **quadVert, double **quadVertNorms) |
| void | evalBezierFace (int numFace, int numEdge, int numVert, int numVertPerFace, int *faceEdge, int *edgeVert, double *vert, double *faceCtrlPts, double *edgeCtrlPts, int numLocs, double *paramLocation, double *location, double *normal, double *deriv) |
| void | evalBezierFaceFromNorms (int numFace, int numEdge, int numVert, int numVertPerFace, int *faceEdge, int *edgeVert, double *vert, double *vertNorms, double *edgeVertTang, int numLocs, double *paramLocation, double *location, double *normal, double *deriv) |
| void | projToBezierFace (int numFace, int numEdge, int numVert, int numVertPerFace, int *faceEdge, int *edgeVert, double *vert, double *faceCtrlPts, double *edgeCtrlPts, int numLocs, double *xyz, int specify_tol, double converge_tol, double *xyzOnFace, double *normal, double *deriv) |
| void | projToBezierFaceFromNorms (int numFace, int numEdge, int numVert, int numVertPerFace, int *faceEdge, int *edgeVert, double *vert, double *vertNorms, double *edgeVertTang, int numLocs, double *xyz, int specify_tol, double converge_tol, double *xyzOnFace, double *normal, double *deriv) |
| void | evalBezierEdgeFromTans (int numEdge, int numVert, int *edgeVert, double *vert, double *edgeVertTang, int numLocs, double *paramLocation, double *location, double *tangent) |
| void | evalBezierEdge (int numEdge, int numVert, int *edgeVert, double *vert, double *edgeCtrlPts, int numLocs, double *paramLocation, double *location, double *tangent) |
| void | projToBezierEdgeFromTans (int numEdge, int numVert, int *edgeVert, double *vert, double *edgeVertTang, int numLocs, double *xyz, double *xyzOnEdge, double *tangent) |
| void | projToBezierEdge (int numEdge, int numVert, int *edgeVert, double *vert, double *edgeCtrlPts, int numLocs, double *xyz, double *xyzOnEdge, double *tangent, double *t_value) |
| void | dumpMesh (const char *fileName, int includeResults, double angle, int numTri, int numQuad, int numEdge, int numVert, int *triEdge, int *quadEdge, int *edgeVert, double *vert, double *edgeCtrlPts, double *triCtrlPts, double *quadCtrlPts) |
| void | dumpResults (const char *fileName, int numEdge, int numTri, int numQuad, double *edgeCtrlPts, double *triCtrlPts, double *quadCtrlPts) |
| void | importMesh (const char *fileName, int *resultsIncluded, double *angle, int *numTri, int *numQuad, int *numEdge, int *numVert, int **triEdge, int **quadEdge, int **edgeVert, double **vert, double **edgeCtrlPts, double **triCtrlPts, double **quadCtrlPts) |
| void | importResults (const char *fileName, int *numEdge, int *numTri, int *numQuad, double **edgeCtrlPts, double **triCtrlPts, double **quadCtrlPts) |
Definition in file Cholla.h.
| #define NUM_EDGE_CPTS 3 |
| #define NUM_QUAD_CPTS 15 |
| #define NUM_TRI_CPTS 6 |
| void constructBezier | ( | double | angle, |
| int | numTri, | ||
| int | numQuad, | ||
| int | numEdge, | ||
| int | numVert, | ||
| int * | triEdge, | ||
| int * | quadEdge, | ||
| int * | edgeVert, | ||
| double * | vert, | ||
| double * | edgeCtrlPts, | ||
| double * | triCtrlPts, | ||
| double * | quadCtrlPts | ||
Return control points for a quartic Bezier for each face, using a given feature angle tolerance to distinguish C0 and C1 edges. Separate arrays of tris and quad faces should be supplied
| angle | - (IN) feature angle tolerance (degrees) |
| numTri | - (IN) number of quad faces |
| numQuad | - (IN) number of triangle faces |
| numEdge | - (IN) number of edges |
| numVert | - (IN) number of vertices |
| triEdge | - (IN) array of face to edge numbering, length 3 * numTri |
| quadEdge | - (IN) array of face to edge numbering, length 4 * numQuad |
| edgeVert | - (IN) array of edge to vertex numbering, length 2*numEdge |
| vert | - (IN) array of vertex coordinates, length 3*numVert |
| edgeCtrlPts | - (OUT) array of control points computed at the edges length 3*(3*numEdge) |
| triCtrlPts | - (OUT) array of control points computed at the triangles length 3*(6*numTri) |
| quadCtrlPts | - (OUT) array of control points computed at the quads length 3*(15*numQuad) |
Definition at line 84 of file Cholla.cpp.
// create arrays of facet entities from the arrays
CubitPoint **point_array = new CubitPoint * [numVert];
CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge];
CubitFacet **facet_array = NULL;
if (numTri > 0)
facet_array = new CubitFacet * [numTri];
CubitQuadFacet **qfacet_array = NULL;
if (numQuad > 0)
qfacet_array = new CubitQuadFacet * [numQuad];
DLIList<FacetEntity *> facet_list;
CubitStatus stat = CUBIT_SUCCESS;
stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge,
edgeVert, vert, point_array, edge_array, facet_array,
qfacet_array, facet_list);
if (CUBIT_SUCCESS != stat) {
PRINT_ERROR("Failed to build facets.\n");
return;
// create lists of points and edges
int ii;
DLIList<CubitPoint *> point_list;
for (ii=0; ii<numVert; ii++)
point_list.append(point_array[ii]);
DLIList<CubitFacetEdge *> edge_list;
for (ii=0; ii<numEdge; ii++)
edge_list.append(edge_array[ii]);
// prepare the ChollaEngine
DLIList<FacetEntity *> fpoint_list, fedge_list;
CAST_LIST_TO_PARENT( point_list, fpoint_list );
CAST_LIST_TO_PARENT( edge_list, fedge_list );
ChollaEngine *ceng = new ChollaEngine( facet_list, fedge_list, fpoint_list );
CubitBoolean use_feature_angle;
if (angle < 0.00001 || angle > 179.9999)
use_feature_angle = CUBIT_FALSE;
else
use_feature_angle = CUBIT_TRUE;
int interp_order = 4; // assume we are creating beziers
CubitBoolean smooth_non_manifold = CUBIT_TRUE;
CubitBoolean split_surfaces = CUBIT_FALSE;
// create the geometry
//CubitStatus rv =
ceng->create_geometry(use_feature_angle,angle,
interp_order,smooth_non_manifold,
split_surfaces);
// get the control points on edges
int jj;
int index;
CubitVector *control_points;
CubitFacetEdge *edge_ptr;
edge_ptr = edge_array[ii];
control_points = edge_ptr->control_points();
assert(control_points != NULL);
for (jj=0; jj<NUM_EDGE_CPTS; jj++)
index = 3 * (ii * NUM_EDGE_CPTS + jj);
edgeCtrlPts[index] = control_points[jj].x();
edgeCtrlPts[index+1] = control_points[jj].y();
edgeCtrlPts[index+2] = control_points[jj].z();
// get the control points on triangles
CubitFacet *facet_ptr;
for (ii=0; ii<numTri; ii++)
facet_ptr = facet_array[ii];
control_points = facet_ptr->control_points();
for (jj=0; jj<NUM_TRI_CPTS; jj++)
index = 3 * (ii * NUM_TRI_CPTS + jj);
triCtrlPts[index] = control_points[jj].x();
triCtrlPts[index+1] = control_points[jj].y();
triCtrlPts[index+2] = control_points[jj].z();
// get the control points on quads
//CubitVector qctrl_points[NUM_QUAD_CPTS];
CubitQuadFacet *qfacet_ptr;
for (ii=0; ii<numQuad; ii++)
qfacet_ptr = qfacet_array[ii];
index = 3 * (ii * NUM_QUAD_CPTS);
qfacet_ptr->get_control_points( &(quadCtrlPts[index]) );
// delete the ChollaEngine
ceng->delete_eval_tools();
ceng->delete_me();
delete ceng;
// delete temp arrays (facets are deleted with the eval tool)
qfacet_array[ii]->remove_tri_facets();
delete qfacet_array[ii];
delete [] point_array;
delete [] edge_array;
if (facet_array)
delete [] facet_array;
if (qfacet_array)
delete [] qfacet_array;
| void constructQuadNormals | ( | double | angle, |
| int | numQuad, | ||
| int | numEdge, | ||
| int | numVert, | ||
| double * | quadVertNorms, | ||
| double * | edgeVertTang, | ||
| int * | edgeTypeFlags | ||
Return normal and tangents for on a list of quad faces a given feature angle tolerance to distinguish C0 and C1 edges. Separate arrays of tris and quad faces should be supplied
| numQuad | - (IN) number of quad faces |
| quadVertNorms | - (OUT) array of normals at the quad vertices length 3*(4*numQuad) |
| edgeVertTang | - (OUT) array of tangents at the edge vertices length 3*(2*numEdge) |
| edgeTypeFlags | - (OUT) array of flags labeling the type of each edge, length numEdge 2 = non-manifold edge 1 = concave feature edge 0 = non-feature edge -1= convex feature edge |
Definition at line 366 of file Cholla.cpp.
int *triEdge = NULL;
int numTri = 0;
if (numQuad > 0)
return;
int ii;
else
split_surfaces);
// get the control points on edges and infer the tangents
int mydebug = 0;
FILE *fp = NULL;
if (mydebug)
fp = fopen("edges.txt", "w");
int index = 0;
CubitVector v0, v1, t0, t1;
v0 = edge_ptr->point(0)->coordinates();
v1 = edge_ptr->point(1)->coordinates();
if (mydebug)
int kk;
for(kk=0; kk<3; kk++);
fprintf(fp, "(%d) %.6f %.6f %.6f\n", edge_ptr->id(), v0.x(), v0.y(), v0.z());
fprintf(fp, " %.6f %.6f %.6f\n", control_points[0].x(), control_points[0].y(), control_points[0].z());
fprintf(fp, " %.6f %.6f %.6f\n", control_points[1].x(), control_points[1].y(), control_points[1].z());
fprintf(fp, " %.6f %.6f %.6f\n", control_points[2].x(), control_points[2].y(), control_points[2].z());
fprintf(fp, " %.6f %.6f %.6f\n", v1.x(), v1.y(), v1.z());
index = 6 * ii;
t0 = control_points[0] - v0;
t1 = v1 - control_points[2];
if(edge_ptr->is_flipped()){
t0 *= (-1.0);
t1 *= (-1.0);
t0.normalize();
t1.normalize();
edgeVertTang[index ] = t0.x();
edgeVertTang[index+1] = t0.y();
edgeVertTang[index+2] = t0.z();
edgeVertTang[index+3] = t1.x();
edgeVertTang[index+4] = t1.y();
edgeVertTang[index+5] = t1.z();
edgeTypeFlags[ii]=classify_local_convexity_at_edge(edge_ptr);
if (mydebug)
fclose(fp);
// get the normal on quad
CubitVector n0, n1, n2, n3;
index = 12 * ii;
n0 = qfacet_ptr->point(0)->normal(qfacet_ptr);
n1 = qfacet_ptr->point(1)->normal(qfacet_ptr);
n2 = qfacet_ptr->point(2)->normal(qfacet_ptr);
n3 = qfacet_ptr->point(3)->normal(qfacet_ptr);
quadVertNorms[index ] = n0.x();
quadVertNorms[index + 1 ] = n0.y();
quadVertNorms[index + 2 ] = n0.z();
quadVertNorms[index + 3 ] = n1.x();
quadVertNorms[index + 4 ] = n1.y();
quadVertNorms[index + 5 ] = n1.z();
quadVertNorms[index + 6 ] = n2.x();
quadVertNorms[index + 7 ] = n2.y();
quadVertNorms[index + 8 ] = n2.z();
quadVertNorms[index + 9 ] = n3.x();
quadVertNorms[index + 10] = n3.y();
quadVertNorms[index + 11] = n3.z();
ceng->delete_me();
delete ceng;
if (facet_array)
if (qfacet_array)
| CubitStatus constructQuadNormalsFromFile | ( | const char * | filename, |
| int | numQuad, | ||
| int | numEdge, | ||
| double * | edgeVertTang | ||
Return normal and tangents for on a list of quad faces a given a file containing the geometric normals and tangents. Separate arrays of tris and quad faces should be supplied
| filename | - (IN) full path and name of the text file containing the geometric surface normals and tangents. This file is output from Cubit when exporting an exodus file. |
Definition at line 2512 of file Cholla.cpp.
CubitStatus status = CUBIT_SUCCESS;
int num_file_quads = 0,
num_file_edges = 0,
*edge_nodes_file = NULL,
*quad_nodes_file = NULL;
double *edge_node_tangs_file = NULL,
*quad_node_norms_file = NULL;
status = readMBGNormalFile( filename,
NULL,
&num_file_quads,
&num_file_edges,
&edge_nodes_file,
&edge_node_tangs_file,
NULL,
NULL,
&quad_nodes_file,
&quad_node_norms_file );
if ( status == CUBIT_SUCCESS && numEdge > 0 )
status = extractEdgeTangsFromFile( num_file_edges,
edge_nodes_file,
numEdge,
edgeVert,
edgeVertTang );
if ( status == CUBIT_SUCCESS && numQuad > 0 )
status = extractQuadNormalsFromFile( num_file_quads,
quad_nodes_file,
quad_node_norms_file,
numQuad,
edgeVert,
quadEdge,
quadVertNorms );
delete [] edge_nodes_file;
delete [] quad_nodes_file;
delete [] edge_node_tangs_file;
delete [] quad_node_norms_file;
return status;
| void constructTriNormals | ( | double | angle, |
| int | numTri, | ||
| int | numEdge, | ||
| int | numVert, | ||
| double * | triVertNorms, | ||
Return normal and tangents for on a list of triangles a given feature angle tolerance to distinguish C0 and C1 edges. Separate arrays of tris and quad faces should be supplied
| numTri | - (IN) number of tri faces |
| triVertNorms | - (OUT) array of normals at the triangle vertices length 3*(3*numTri) |
Definition at line 222 of file Cholla.cpp.
int* quadEdge = NULL;
if (numTri > 0)
int numQuad = 0;
return;
int ii;
for (ii=0; ii<numEdge; ii++){
else
//CubitStatus rv =
split_surfaces);
int index = 0;
index = 6 * ii;
t0 *= (-1.0);
t1 *= (-1.0);
t0.normalize();
t1.normalize();
// get the normal on triangles
CubitVector n0, n1, n2;
index = 9 * ii;
n0 = facet_ptr->point(0)->normal(facet_ptr);
n1 = facet_ptr->point(1)->normal(facet_ptr);
n2 = facet_ptr->point(2)->normal(facet_ptr);
triVertNorms[index ] = n0.x();
triVertNorms[index + 1] = n0.y();
triVertNorms[index + 2] = n0.z();
triVertNorms[index + 3] = n1.x();
triVertNorms[index + 4] = n1.y();
triVertNorms[index + 5] = n1.z();
triVertNorms[index + 6] = n2.x();
triVertNorms[index + 7] = n2.y();
triVertNorms[index + 8] = n2.z();
ceng->delete_me();
delete ceng;
if (facet_array)
if (qfacet_array)
| CubitStatus constructTriNormalsFromFile | ( | const char * | filename, |
| int | numTri, | ||
| int | numEdge, | ||
Return normal and tangents for on a list of triangles a given a file containing the geometric normals and tangents. Separate arrays of tris and quad faces should be supplied
| triVert | - (IN) array of face to vertex numbering, length 3 * numTri |
Definition at line 2578 of file Cholla.cpp.
int num_file_tris = 0,
num_file_edges = 0,
*tri_nodes_file = NULL;
*tri_node_norms_file = NULL;
&num_file_tris,
NULL,
&num_file_edges,
&edge_nodes_file,
&tri_nodes_file,
&tri_node_norms_file,
NULL,
NULL );
edge_nodes_file,
numEdge,
edgeVert,
edgeVertTang );
if ( status == CUBIT_SUCCESS && numTri > 0 )
status = extractTriNormalsFromFile( num_file_tris,
tri_nodes_file,
numTri,
edgeVert,
triEdge,
triVertNorms );
delete [] tri_nodes_file;
delete [] tri_node_norms_file;
return status;
| void dumpMesh | ( | const char * | fileName, |
| int | includeResults, | ||
| double | angle, | ||
| int | numTri, | ||
| int | numQuad, | ||
| int | numEdge, | ||
| int | numVert, | ||
Functions for debugging
Definition at line 1412 of file Cholla.cpp.
FILE *fp = fopen(fileName, "w");
assert(fp != NULL); // couldn't open file for writing
// write the header info
fprintf(fp, "Cholla version 1.0\n");
time_stamp( fp );
fprintf(fp, "%d %d %d %d %d\n", numTri, numQuad, numEdge, numVert, includeResults);
fprintf(fp, "%f\n", angle);
// faceEdgeBegin
int ii;
// faceEdge
fprintf(fp, "triEdge\n");
for(ii=0; ii<numTri; ii++)
fprintf(fp, "%d %d %d\n", triEdge[ii*3], triEdge[ii*3+1], triEdge[ii*3+2]);
fprintf(fp, "quadEdge\n");
for(ii=0; ii<numQuad; ii++)
fprintf(fp, "%d %d %d %d\n", quadEdge[ii*4], quadEdge[ii*4+1],
quadEdge[ii*4+2], quadEdge[ii*4+3]);
// edgeVert
fprintf(fp, "edgeVert\n");
fprintf(fp, "%d %d\n", edgeVert[ii*2], edgeVert[ii*2+1]);
// vert
fprintf(fp, "vert\n");
fprintf(fp, "%f %f %f\n", vert[ii*3], vert[ii*3+1], vert[ii*3+2]);
if (includeResults != 0)
// edge control points
int jj;
fprintf(fp, "edgeCtrlPts\n");
for(ii=0; ii<numEdge; ii++)
fprintf(fp, "%f %f %f\n", edgeCtrlPts[ii*jj*3],
edgeCtrlPts[ii*jj*3+1],
edgeCtrlPts[ii*jj*3+2]);
// triangle control points
fprintf(fp, "triCtrlPts\n");
fprintf(fp, "%f %f %f\n", triCtrlPts[ii*jj*3],
triCtrlPts[ii*jj*3+1],
triCtrlPts[ii*jj*3+2]);
// quad control points
fprintf(fp, "quadCtrlPts\n");
for (jj=0; jj<NUM_QUAD_CPTS; jj++)
fprintf(fp, "%f %f %f\n", quadCtrlPts[ii*jj*3],
quadCtrlPts[ii*jj*3+1],
quadCtrlPts[ii*jj*3+2]);
fclose(fp);
| void dumpResults | ( | const char * | fileName, |
| int | numEdge, | ||
| int | numTri, | ||
| int | numQuad, | ||
Definition at line 1515 of file Cholla.cpp.
FILE *fp = fopen( fileName, "w" );
assert(fp != NULL);
fprintf(fp, "Cholla version 1.0 Results\n");
time_stamp( fp );
fprintf(fp, "%d %d %d\n", numEdge, numTri, numQuad );
int ii,jj;
fclose(fp);
| void evalBezierEdge | ( | int | numEdge, |
| int | numVert, | ||
| int | numLocs, | ||
| double * | paramLocation, | ||
| double * | location, | ||
| double * | tangent | ||
Evaluate a quartic Bezier curve at a specified parametric location given its control points. Evaluates location, and/or tangent.
| numEdge | - (IN) number of edges on the faces |
| edgeVert | - (IN) array of edge to vertex indecies (into vert) length 2 * numEdge |
| vert | - (IN) array of vertex locations length 3 * numVert |
| edgeCtrlPts | - (IN) array of control pt locations for each edge in the bezier. The beziers are quartic, so there are 3 control pts per curve in addition to the 2 end pts for each curve for a total of 5 pts per edge. length = 3 * ( 3 * numEdge ) |
| numLocs | - (IN) number of locations to evaluate per edge |
| paramLocation | - (IN) parametric location to evaluate on each edge length = numLocs |
| location | - (OUT) evaluated point on edge at paramLocation length = numEdge * 3 * numLocs |
| tangent | - (IN/OUT) evaluated tangent at parmLocation. If NULL then will not be evaluated. Return vector is normalized length = numEdge * 3 * numLocs |
Definition at line 1945 of file Cholla.cpp.
int ii, index, numTri, numQuad;
int *triEdge, *quadEdge;
triEdge = quadEdge = NULL;
numTri = numQuad = 0;
return;
// Set the control points on the edges.
index = 3 * (ii * NUM_EDGE_CPTS);
edge_ptr->set_control_points( &(edgeCtrlPts[index]) );
// do the evaluations
int jj, tindex;
index = tindex = 0;
for ( ii = 0; ii < numEdge; ii++ ) {
for ( jj = 0; jj < numLocs; jj++ ) {
CubitVector eval_point;
CubitVector *eval_point_ptr = &eval_point;
CubitVector eval_tangent;
CubitVector *eval_tangent_ptr = NULL;
if ( tangent != NULL )
eval_tangent_ptr = &eval_tangent;
edge_ptr->evaluate_single(paramLocation[jj],eval_point_ptr);
location[index++] = eval_point.x();
location[index++] = eval_point.y();
location[index++] = eval_point.z();
if ( tangent != NULL ) {
edge_ptr->evaluate_single_tangent(paramLocation[jj],eval_tangent_ptr);
eval_tangent.normalize();
tangent[tindex++] = eval_tangent.x();
tangent[tindex++] = eval_tangent.y();
tangent[tindex++] = eval_tangent.z();
// delete the temp arrays
delete edge_array[ii];
delete point_array[ii];
| void evalBezierEdgeFromTans | ( | int | numEdge, |
| int | numVert, | ||
| int | numLocs, | ||
Evaluate a quartic Bezier curve at a specified parametric location given its tangents at the end-points. Evaluates location, and/or tangent.
| vert | - (IN) array of vertex locations |
| edgeVertTang | - (IN) array of tangents at the edge vertices length 3*(2*numEdge) |
Definition at line 2023 of file Cholla.cpp.
return;
// set the control points on edges
int mydebug = 0;
FILE *fp = NULL;
if (mydebug)
CubitVector T0, T1, P0, P1;
CubitVector Pi[3];
CubitPoint *pt0, *pt1;
index = 6 * ii;
pt0 = edge_ptr->point(0);
pt1 = edge_ptr->point(1);
P0 = pt0->coordinates();
P1 = pt1->coordinates();
T0.x( edgeVertTang[ index ] );
T0.y( edgeVertTang[ index + 1] );
T0.z( edgeVertTang[ index + 2] );
T1.x( edgeVertTang[ index + 3] );
T1.y( edgeVertTang[ index + 4] );
T1.z( edgeVertTang[ index + 5] );
FacetEvalTool::init_edge_control_points_single(P0, P1, T0, T1, Pi);
if (mydebug)
int kk;
fprintf(fp, "(%d) %.6f %.6f %.6f\n", edge_ptr->id(), P0.x(), P0.y(), P0.z());
fprintf(fp, " %.6f %.6f %.6f\n", Pi[0].x(), Pi[0].y(), Pi[0].z());
fprintf(fp, " %.6f %.6f %.6f\n", Pi[1].x(), Pi[1].y(), Pi[1].z());
fprintf(fp, " %.6f %.6f %.6f\n", Pi[2].x(), Pi[2].y(), Pi[2].z());
fprintf(fp, " %.6f %.6f %.6f\n", P1.x(), P1.y(), P1.z());
edge_ptr->control_points( Pi, 4 );
if (mydebug)
fclose(fp);
int jj, tindex;
index = tindex = 0;
| void evalBezierFace | ( | int | numFace, |
| int | numEdge, | ||
| int | numVert, | ||
| int | numVertPerFace, | ||
| int * | faceEdge, | ||
| double * | faceCtrlPts, | ||
| int | numLocs, | ||
| double * | normal, | ||
| double * | deriv | ||
Evaluate a set of quartic Bezier patches at a specified parametric location given its control points. Evaluates location, normal and/or derivative. Expects list of either quads or tris (not both)
| numFace | - (IN) number of faces to evaluate |
| numVertPerFace- | (IN) has value of of 3 or 4, for tris or quads |
| faceEdge | - (IN) array of face to edge indecies (into edgeVert) length numVertPerFace * numFace |
| faceCtrlPts | - (IN) array of control points for the faces (same order as faceEdge) if (numFacePerVert == 3) ncp = 6 if (numFacePerVert == 4) ncp = 15 length = 3 * (ncp * numFace) |
| edgeCtrlPts | - (IN) array of control points for the edges (same order as edgeVert array) length 3 * (3 * numEdge) |
| numLocs | - (IN) number of locations to evaluate per face |
| paramLocation | - (IN) parametric location to evaluate on each face if (numFacePerVert == 3) (u,v,w) length = 3 * numLocs if (numFacePerVert == 4) (u,v) length = 2 * numLocs |
| location | - (OUT) evaluated point on surface at paramLocation length = numFace * 3 * numLocs |
| normal | - (IN/OUT) evaluated normal at parmLocation. If NULL then will not be evaluated. Return vector is normalized length = numFace * 3 * numLocs |
| deriv | - (IN/OUT) evaluated derivative at parmLocation with respect to uv or uvw system. If NULL then will not be evaluated. if (numFacePerVert == 3) length = numFace * numLocs * 3*3 (du/dx,du/dy,du/dz, dv/dx,dv/dy,dv/dz, dw/dx,dw/dz,dw/dz) if (numFacePerVert == 4) length = numFace * numLocs * 3*2 (du/dx,du/dy,du/dz, dv/dx,dv/dy,dv/dz) |
Definition at line 628 of file Cholla.cpp.
int numTri = 0;
int numQuad = 0;
int *tri_edge = (numVertPerFace == 3) ? faceEdge : NULL;
int *quad_edge = (numVertPerFace == 4) ? faceEdge : NULL;
if (numVertPerFace == 3)
facet_array = new CubitFacet * [numFace];
numTri = numFace;
if (numVertPerFace == 4)
qfacet_array = new CubitQuadFacet * [numFace];
numQuad = numFace;
stat = build_facets(numTri, numQuad, numEdge, numVert, tri_edge, quad_edge,
return;
int index, ii, jj;
// set the control points on triangles
index = 3 * (ii * NUM_TRI_CPTS);
facet_ptr->set_control_points( &(faceCtrlPts[index]) );
// set the control points on quads
qfacet_ptr->set_control_points( &(faceCtrlPts[index]) );
// Do the evaluations
for (jj=0; jj<numLocs; jj++)
CubitVector areacoord(paramLocation[jj*3],
paramLocation[jj*3+1],
paramLocation[jj*3+2]);
CubitVector eval_normal;
CubitVector *eval_normal_ptr = NULL;
if (normal != NULL)
eval_normal_ptr = &eval_normal;
facet_ptr->evaluate( areacoord, eval_point_ptr, eval_normal_ptr );
index = 3 * ii * jj;
location[index] = eval_point.x();
location[index+1] = eval_point.y();
location[index+2] = eval_point.z();
if (normal != NULL)
normal[index] = eval_normal.x();
normal[index+1] = eval_normal.y();
normal[index+2] = eval_normal.z();
if (normal != NULL)
CubitVector eval_du, eval_dv;
CubitVector *eval_du_ptr = NULL;
CubitVector *eval_dv_ptr = NULL;
if (deriv != NULL)
eval_du_ptr = &eval_du;
eval_dv_ptr = &eval_dv;
qfacet_ptr->evaluate( paramLocation[2*jj], paramLocation[2*jj+1],
eval_point_ptr, eval_normal_ptr,
eval_du_ptr, eval_dv_ptr);
if (normal != NULL)
if (deriv != NULL)
index = 6 * ii * jj;
deriv[index] = eval_du.x();
deriv[index+1] = eval_du.y();
deriv[index+2] = eval_du.z();
deriv[index+3] = eval_dv.x();
deriv[index+4] = eval_dv.y();
deriv[index+5] = eval_dv.z();
delete facet_array[ii];
if (facet_array)
if (qfacet_array)
| void evalBezierFaceFromNorms | ( | int | numFace, |
| int | numEdge, | ||
| int | numVert, | ||
| double * | vertNorms, | ||
| int | numLocs, | ||
This is the same as the evalBezierFace except it differes by the input arguments. This function takes a list of normals and tangents at the face vertices and computes bezier control points internally. Normals and tangents should have been computed previously in constructTriNormals or constructQuad Normals. This function is not as computationally efficient as evalBezierFace since it requires Bezier control points to be computed as part of the call - however, it is more memory efficient, requiring fewer variables to be stored with the calling application. The following argument list describes only those arguments that differ from evalBezierFace above.
| vertNorms | - (IN) array of normals at the face vertices length 3*(numVertPerFace*numFace) |
Definition at line 809 of file Cholla.cpp.
int numTri = 0;
int numQuad = 0;
int *triEdge = (numVertPerFace == 3) ? faceEdge : NULL;
int *quadEdge = (numVertPerFace == 4) ? faceEdge : NULL;
numTri = numFace;
numQuad = numFace;
return;
// set the normals on triangle vertices
int index, ii, jj;
CubitPoint *pt;
CubitVector pt_normal;
for(jj=0; jj<3; jj++)
index = ii * 9 + (3 * jj);
pt_normal.x( vertNorms[ index ] );
pt_normal.y( vertNorms[ index + 1 ] );
pt_normal.z( vertNorms[ index + 2 ] );
pt = facet_ptr->point(jj);
TDFacetBoundaryPoint::add_facet_boundary_point( pt, facet_ptr, pt_normal );
// set the normals on quad vertices
for(jj=0; jj<4; jj++)
index = ii * 12 + (3 * jj);
pt = qfacet_ptr->point(jj);
TDFacetBoundaryPoint::add_facet_boundary_point( pt, qfacet_ptr, pt_normal );
int mydebug = 0;
FILE *fp = NULL;
if (mydebug)
CubitVector N0, N1, T0, T1, P0, P1;
CubitVector Pi[3];
index = 6 * ii;
N0 = pt0->normal( edge_ptr );
N1 = pt1->normal( edge_ptr );
FacetEvalTool::init_edge_control_points(P0, P1, N0, N1, T0, T1, Pi);
if (mydebug)
int kk;
if (mydebug)
fclose(fp);
facet_ptr->init_patch();
qfacet_ptr->init_patch();
index = 0;
int nindex = 0;
if (normal != NULL)
if (normal != NULL)
normal[nindex++] = eval_normal.x();
normal[nindex++] = eval_normal.y();
normal[nindex++] = eval_normal.z();
int dindex = 0;
nindex = index = 0;
if (normal != NULL)
if (deriv != NULL)
if (normal != NULL)
if (deriv != NULL)
deriv[dindex++] = eval_du.x();
deriv[dindex++] = eval_du.y();
deriv[dindex++] = eval_du.z();
deriv[dindex++] = eval_dv.x();
deriv[dindex++] = eval_dv.y();
deriv[dindex++] = eval_dv.z();
if (facet_array)
if (qfacet_array)
| void importMesh | ( | const char * | fileName, |
| int * | resultsIncluded, | ||
| double * | angle, | ||
| int * | numTri, | ||
| int * | numQuad, | ||
| int * | numEdge, | ||
| int * | numVert, | ||
| int ** | triEdge, | ||
| int ** | quadEdge, | ||
| int ** | edgeVert, | ||
| double ** | vert, | ||
| double ** | edgeCtrlPts, | ||
| double ** | triCtrlPts, | ||
| double ** | quadCtrlPts | ||
Definition at line 1576 of file Cholla.cpp.
FILE *fp = fopen(fileName, "r");
assert(fp != NULL); // couldn't open file for reading
// read the header info
char version[128];
char* s = fgets(version, 128, fp);
if (NULL == s) {
PRINT_ERROR("Format error in file %s\n", fileName);
fclose(fp);
return;
assert(strcmp(version, "Cholla version 1.0\n") == 0); // don't recognize file
char filetime[128];
s = fgets(filetime, 128, fp);
if (NULL == s) {
fclose(fp);
return;
char line[256];
int num_tri;
int num_quad;
int num_edge;
int num_vert;
s = fgets(line,256,fp);
if (NULL == s) {
fclose(fp);
return;
sscanf(line, "%d %d %d %d %d\n", &num_tri, &num_quad, &num_edge, &num_vert, includeResults);
*numTri = num_tri;
*numQuad = num_quad;
*numEdge = num_edge;
*numVert = num_vert;
int nread = fscanf(fp, "%lf\n", angle);
if (1 != nread) {
fclose(fp);
return;
// triEdge
*triEdge = new int [num_tri*3];
int *tri_edge = *triEdge;
char array_name[128];
nread = fscanf(fp, "%s\n", array_name);
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "triEdge") == 0); // check start of array
int ii;
for(ii=0; ii<num_tri; ii++)
nread = fscanf(fp, "%d %d %d\n", &tri_edge[ii*3], &tri_edge[ii*3+1], &tri_edge[ii*3+2]);
if (3 != nread) {
fclose(fp);
return;
// quadEdge
*quadEdge = new int [num_quad*4];
int *quad_edge = *quadEdge;
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "quadEdge") == 0); // check start of array
for(ii=0; ii<num_quad; ii++)
nread = fscanf(fp, "%d %d %d %d\n", &quad_edge[ii*4], &quad_edge[ii*4+1],
&quad_edge[ii*4+2], &quad_edge[ii*4+3]);
if (4 != nread) {
fclose(fp);
return;
// edgeVert
*edgeVert = new int [2*num_edge];
int *edge_vert = *edgeVert;
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "edgeVert") == 0); // check start of array
for (ii=0; ii<num_edge; ii++)
nread = fscanf(fp, "%d %d\n", &edge_vert[ii*2], &edge_vert[ii*2+1]);
if (2 != nread) {
fclose(fp);
return;
// vert
*vert = new double [3*num_vert];
double *my_vert = *vert;
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "vert") == 0); // check start of array
for (ii=0; ii<num_vert; ii++)
nread = fscanf(fp, "%lf %lf %lf\n", &my_vert[ii*3], &my_vert[ii*3+1], &my_vert[ii*3+2]);
if (3 != nread) {
fclose(fp);
return;
*edgeCtrlPts = new double [3*num_edge*NUM_EDGE_CPTS];
if (numTri != 0)
*triCtrlPts = new double [3*num_tri*NUM_TRI_CPTS];
if (numQuad != 0)
*quadCtrlPts = new double [3*num_quad*NUM_QUAD_CPTS];
double *edge_ctrl_pts = *edgeCtrlPts;
double *tri_ctrl_pts = *triCtrlPts;
double *quad_ctrl_pts = *quadCtrlPts;
if (*includeResults != 0)
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "edgeCtrlPts") == 0); // check start of array
for(ii=0; ii<num_edge*NUM_EDGE_CPTS; ii++)
nread = fscanf(fp, "%lf %lf %lf\n", &edge_ctrl_pts[ii*3],
&edge_ctrl_pts[ii*3+1],
&edge_ctrl_pts[ii*3+2]);
if (3 != nread) {
fclose(fp);
return;
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "triCtrlPts") == 0); // check start of array
for(ii=0; ii<num_tri*NUM_TRI_CPTS; ii++)
nread = fscanf(fp, "%lf %lf %lf\n", &tri_ctrl_pts[ii*3],
&tri_ctrl_pts[ii*3+1],
&tri_ctrl_pts[ii*3+2]);
if (3 != nread) {
fclose(fp);
return;
if (1 != nread) {
fclose(fp);
return;
assert(strcmp(array_name, "quadCtrlPts") == 0); // check start of array
for(ii=0; ii<num_quad*NUM_QUAD_CPTS; ii++)
nread = fscanf(fp, "%lf %lf %lf\n", &quad_ctrl_pts[ii*3],
&quad_ctrl_pts[ii*3+1],
&quad_ctrl_pts[ii*3+2]);
if (3 != nread) {
fclose(fp);
return;
fclose(fp);
| void importResults | ( | const char * | fileName, |
Definition at line 1799 of file Cholla.cpp.
char version[128];
if (NULL == s) {
fclose(fp);
return;
assert(strcmp(version, "Cholla version 1.0 Results\n") == 0); // don't recognize file
char filetime[128];
if (NULL == s) {
PRINT_ERROR("Format error in mesh file %s\n", fileName);
fclose(fp);
return;
int nread = fscanf(fp, "%d %d %d\n", numEdge, numTri, numQuad);
if (3 != nread) {
fclose(fp);
return;
int num_edge = *numEdge;
int num_tri = *numTri;
int num_quad = *numQuad;
if (numTri != 0)
if (numQuad != 0)
int ii;
if (1 != nread) {
fclose(fp);
return;
if (3 != nread) {
fclose(fp);
return;
if (1 != nread) {
fclose(fp);
return;
if (3 != nread) {
fclose(fp);
return;
if (1 != nread) {
fclose(fp);
return;
for(ii=0; ii<num_tri*NUM_QUAD_CPTS; ii++)
if (3 != nread) {
fclose(fp);
return;
fclose(fp);
| void projToBezierEdge | ( | int | numEdge, |
| int | numVert, | ||
| int | numLocs, | ||
| double * | xyz, | ||
| double * | xyzOnEdge, | ||
| double * | tangent, | ||
| double * | t_value | ||
Project a 3d point to a quartic Bezier curve at a specified parametric location given its control points.
| vert | - (IN) array of vertex locations length = 3 * numVert |
| xyz | - (IN) xyz locations to evaluate on each edge length = 3 * numLocs |
| xyzOnEdge | - (OUT) locations on edges closest to input points xyz. length = numEdge * 3 * numLocs |
| t_value | - (OUT) value of the parameter at the projected point length = numEdge * numLocs |
Definition at line 2325 of file Cholla.cpp.
return;
//CubitVector T0, T1, P0, P1;
//CubitVector Pi[3];
// do the projections
int jj, kk, xyzindex, tindex;
index = tindex = 0;
double dsquared, dsquared_test, dderiv, dderiv2, t, t_min = 0.0;
CubitVector xyz_pt;//, second2142_d;
t = 0.0;
dsquared_test = CUBIT_DBL_MAX;
xyzindex = 3*jj;
xyz_pt.x(xyz[xyzindex]);
xyz_pt.y(xyz[xyzindex+1]);
xyz_pt.z(xyz[xyzindex+2]);
t = -1.0;
// Get square of distance from xyz to curve at intervals of 0.2
// in the parameter t. Save the closest distance found as a
// starting point for Newton-Raphson iterations. It was found
// that an interval of 0.5 was too coarse and that the N-R
// sometimes converged on a false value.
CubitVector *eval_tangent_ptr = &eval_tangent;
CubitVector second_d;
CubitVector *second_d_ptr = &second_d;
for ( kk = 0; kk < 11; kk++ ) {
edge_ptr->evaluate_single(t,eval_point_ptr);
dsquared = ( (xyz_pt.x()-eval_point.x())*(xyz_pt.x()-eval_point.x()) +
(xyz_pt.y()-eval_point.y())*(xyz_pt.y()-eval_point.y()) +
(xyz_pt.z()-eval_point.z())*(xyz_pt.z()-eval_point.z()) );
if ( fabs(dsquared) < fabs(dsquared_test) ) {
t_min = t;
dsquared_test = dsquared;
t += 0.2;
double dderiva, dderivb;
if ( t_min == -1.00 ) {
// Check whether the slope changed signs between -1.0 and -0.8.
// If so, the min must have occurred in this interval -- set
// t_min to -0.9.
t = -1.0;
edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr);
dderiva = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() +
(eval_point.y()-xyz_pt.y())*eval_tangent.y() +
(eval_point.z()-xyz_pt.z())*eval_tangent.z() );
t = -0.8;
dderivb = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() +
if ( dderiva*dderivb < 0.0 ) t_min = -0.9;
} else if ( t_min == 1.00 ) {
// Check the other end of the range, similarly.
t = 1.0;
t = 0.8;
if ( dderiva*dderivb < 0.0 ) t_min = 0.9;
t = t_min;
if ( (t > -1.0) && (t < 1.0) ) {
int mm;
mm = 0;
while ( mm < 10 ) { // to avoid possible infinite loop
mm++;
dderiv = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() +
edge_ptr->evaluate_2nd_derivative(t, second_d_ptr);
dderiv2 = (eval_point.x()-xyz_pt.x())*second_d.x() +
eval_tangent.x()*eval_tangent.x() +
(eval_point.y()-xyz_pt.y())*second_d.y() +
eval_tangent.y()*eval_tangent.y() +
(eval_point.z()-xyz_pt.z())*second_d.z() +
eval_tangent.z()*eval_tangent.z();
t = t - dderiv/dderiv2; // Newton-Raphson
if ( t < -1.0 ) {
t = -1.0;
break;
if ( t > 1.0 ) {
t = 1.0;
break;
if ( fabs(dderiv) < 1.e-11 ) break;
} else { // At an endpoint of the paramaterization.
xyzOnEdge[index++] = eval_point.x();
xyzOnEdge[index++] = eval_point.y();
xyzOnEdge[index++] = eval_point.z();
*t_value = t;
| void projToBezierEdgeFromTans | ( | int | numEdge, |
| int | numVert, | ||
| int | numLocs, | ||
Project to a quartic Bezier curve at a specified parametric location given its tangents at the end-points. Evaluates location, and/or tangent. Finds only one point; in rare cases, more than one closest point might exist.
| vert | - (IN) array of vertex locations length = 3 * NumVerts |
| xyz | - (IN) xyz locations to project to each edge length = 3 * numLocs |
Definition at line 2131 of file Cholla.cpp.
return;
CubitVector Pi[3];
index = 6 * ii;
index = tindex = 0;
CubitVector xyz_pt;//, second_d;
t = 0.0;
xyzindex = 3*jj;
t = -1.0;
t_min = t;
t += 0.2;
// t_min to -0.9.
t = -1.0;
t = -0.8;
t = 1.0;
t = 0.8;
t = t_min;
int mm;
mm = 0;
mm++;
if ( t < -1.0 ) {
t = -1.0;
break;
if ( t > 1.0 ) {
t = 1.0;
break;
| void projToBezierFace | ( | int | numFace, |
| int | numEdge, | ||
| int | numVert, | ||
| int | numLocs, | ||
| int | specify_tol, | ||
| double | converge_tol, | ||
| double * | xyzOnFace, | ||
Project a set of x-y-z locations to Bezier patches. Finds the closest point on one of the patches. Evaluates location, normal and/or derivative. Expects list of either quads or tris (not both)
| xyz | - (IN) xyz locations to evaluate on each face length = 3 * numLocs |
| specify_tol | - (IN) 1 = a converge_tol is specified, 0 = a converge_tol is not specified. A default tol will be computed and used. |
| converge_tol | - (IN) The convergance tolerance for this projection. Will be ignored if specify_tol == 0 |
| xyzOnFace | - (OUT) locations on patches closest to input points xyz. length = 3 * numLocs |
| normal | - (IN/OUT) evaluated normals at xyz. If NULL then will not be evaluated. Return vector is normalized length = 3 * numLocs |
| deriv | - (IN/OUT) evaluated derivatives at xyz with respect to uv or uvw system. If NULL then will not be evaluated. if (numFacePerVert == 3) length = numLocs * 3*3 (du/dx,du/dy,du/dz, dv/dx,dv/dy,dv/dz, dw/dx,dw/dz,dw/dz) if (numFacePerVert == 4) length = numLocs * 3*2 (du/dx,du/dy,du/dz, dv/dx,dv/dy,dv/dz) |
Definition at line 1048 of file Cholla.cpp.
int numTri = 0;
int numQuad = 0;
numTri = numFace;
numQuad = numFace;
DLIList<FacetEntity *> facetentity_list;
stat = build_facets(numTri, numQuad, numEdge, numVert, quad_edge, tri_edge,
qfacet_array, facetentity_list);
return;
DLIList<CubitFacet *> facet_list;
CAST_LIST(facetentity_list, facet_list, CubitFacet);
double edgelen;
double compare_tol = 0.0;
int index, ii;
if ( !specify_tol )
edgelen = edge_ptr->length();
compare_tol += edgelen;
if ( specify_tol )
compare_tol = converge_tol;
else
compare_tol /= numEdge;
compare_tol *= 1.0e-3;
// Do the projections
CubitFacet *last_facet = NULL;
CubitBoolean trim = CUBIT_TRUE;
CubitBoolean outside;
for (ii=0; ii<numLocs; ii++)
CubitVector cur_location(xyz[ii*3],
xyz[ii*3+1],
xyz[ii*3+2]);
if (normal != NULL)
FacetEvalTool::project_to_facets(facet_list, last_facet,
interp_order, compare_tol,
cur_location, trim,
&outside, eval_point_ptr,
eval_normal_ptr);
index = 3 * ii;
xyzOnFace[index] = eval_point.x();
xyzOnFace[index+1] = eval_point.y();
xyzOnFace[index+2] = eval_point.z();
if (normal != NULL)
// no derivatives yet!!
if (facet_array)
if (qfacet_array)
| void projToBezierFaceFromNorms | ( | int | numFace, |
| int | numEdge, | ||
| int | numVert, | ||
| int | numLocs, | ||
This is the same as the projToBezierFace except it differes by the input arguments. This function takes a list of normals and tangents at the face vertices and computes bezier control points internally. Normals and tangents should have been computed previously in constructTriNormals or constructQuadNormals. This function is not as computationally efficient as evalBezierFace since it requires Bezier control points to be computed as part of the call - however, it is more memory efficient, requiring fewer variables to be stored with the calling application. The following argument list describes only those arguments that differ from projToBezierFace above.
Definition at line 1208 of file Cholla.cpp.
int numTri = 0;
int numQuad = 0;
numTri = numFace;
numQuad = numFace;
return;
int index, ii, jj;
CubitPoint *pt;
double edgelen;
CubitVector Pi[3];
index = 6 * ii;
if ( !specify_tol )
if ( specify_tol )
else
xyz[ii*3+1],
xyz[ii*3+2]);
if (normal != NULL)
cur_location, trim,
eval_normal_ptr);
//double dist = cur_location.distance_between(eval_point);
index = 3 * ii;
if (normal != NULL)
if (facet_array)
if (qfacet_array)
| CubitStatus readMBGNormalFile | ( | const char * | filename, |
| double ** | edgeVertTang, | ||
| int ** | triVert, | ||
| double ** | triVertNorms, | ||
| int ** | quadVert, | ||
| double ** | quadVertNorms | ||
Return normal and tangents for on a list of quad faces a given a file containing the geometric normals and tangents. This returns all of the data in the file rather than just for the specified input elements and edges like constructQuadNormalsFromFile and constructTriNormalsFromFile
| numTri | - (OUT) number of quad faces |
| numQuad | - (OUT) number of quad faces |
| numEdge | - (OUT) number of edges |
| edgeVert | - (OUT) array of vertices on each edge. length 2*numEdge (Must be freed by caller) |
| edgeVertTang | - (OUT) array of tangents at the edge vertices length 3*(2*numEdge) (Must be freed by caller) |
| TriVert | - (OUT) array of vertices on each tri. length 3*numTri |
| TriVertNorms | - (OUT) array of normals at the tri vertices length 3*(4*numTri) (Must be freed by caller) |
| QuadVert | - (OUT) array of vertices on each quad. length 3*numQuad |
| QuadVertNorms | - (OUT) array of normals at the quad vertices length 3*(4*numQuad) (Must be freed by caller) |
Definition at line 3065 of file Cholla.cpp.
#define MAX_FILE_LINE 512
int num_t = 0;
int num_q = 0;
int curr_quad = 0;
int curr_tri = 0;
int num_e = 0;
int n[4];
if ( num_tris ) *num_tris = 0;
if ( num_quads ) *num_quads = 0;
if ( num_edges ) *num_edges = 0;
if ( edge_nodes ) *edge_nodes = NULL;
if ( edge_node_tangents ) *edge_node_tangents = NULL;
if ( tri_nodes ) *tri_nodes = NULL;
if ( quad_nodes ) *quad_nodes = NULL;
if ( tri_node_normals ) *tri_node_normals = NULL;
if ( quad_node_normals ) *quad_node_normals = NULL;
if ( strlen( filename ) == 0 )
PRINT_ERROR(" No filename specified\n");
return CUBIT_FAILURE;
ifstream geom_file( filename );
char fileline[MAX_FILE_LINE];
while ( geom_file.getline( fileline, MAX_FILE_LINE ) )
int block_id,
num_corners,
num_elems;
if ( !strcmp( fileline, END_OF_BLOCKS ) ) break;
if ( 3 != sscanf( fileline, "BLK %d %d %d",
&block_id, &num_corners, &num_elems ) )
PRINT_ERROR( "MBG Normal file has incorrect file format\n" );
geom_file.close();
if ( num_corners == 3 )
checkMemoryAllocations( num_corners, num_elems, &num_t, tri_nodes,
tri_node_normals );
else if ( num_corners == 4 )
checkMemoryAllocations( num_corners, num_elems, &num_q, quad_nodes,
quad_node_normals );
else
PRINT_ERROR( "MBG Normal file can only support quads and tris.\n" );
geom_file.close();
for ( int ielem = 0; ielem < num_elems; ielem++ )
int *this_nodes = NULL;
double *this_norms = NULL;
if ( !geom_file.getline( fileline, MAX_FILE_LINE ) )
geom_file.close();
if ( quad_nodes ) this_nodes = &((*quad_nodes )[4 * curr_quad]);
if ( quad_node_normals ) this_norms = &((*quad_node_normals)[4 * 3 * curr_quad]);
curr_quad++;
else if ( num_corners == 3 )
if ( tri_nodes ) this_nodes = &((*tri_nodes )[3 * curr_tri]);
if ( tri_node_normals ) this_norms = &((*tri_node_normals)[3 * 3 * curr_tri]);
curr_tri++;
if ( ( num_corners == 4 && 4 != sscanf( fileline, "%d %d %d %d",
&n[0], &n[1], &n[2], &n[3] ) ) ||
( num_corners == 3 && 3 != sscanf( fileline, "%d %d %d",
&n[0], &n[1], &n[2] ) ) )
geom_file.close();
if ( this_nodes )
memcpy( this_nodes, n, num_corners * sizeof( int ) );
// Read in the surface normals at the vertices of this element.
for ( int icorner = 0; icorner < num_corners; icorner++ )
geom_file.close();
if ( this_norms )
double norm[3];
if ( 3 != sscanf( fileline, "%lf %lf %lf", &norm[0], &norm[1], &norm[2] ) )
geom_file.close();
memcpy( &(this_norms[icorner * 3]), norm, 3 * sizeof( double ) );
geom_file.close();
if ( 1 != sscanf( fileline, "%d", &num_e ) )
geom_file.close();
if ( edge_nodes || edge_node_tangents )
if ( edge_nodes ) *edge_nodes = new int [ 2 * num_e ];
if ( edge_node_tangents ) *edge_node_tangents = new double [3 * 2 * num_e];
for ( int iedge = 0; iedge < num_e; iedge++ )
geom_file.close();
if ( 2 != sscanf( fileline, "%d %d", &n[0], &n[1] ) )
geom_file.close();
for ( int iend = 0; iend < 2; iend++ )
double d[3];
if ( edge_nodes )
(*edge_nodes)[iedge * 2 + iend ] = n[iend];
geom_file.close();
if ( 3 != sscanf( fileline, "%lf %lf %lf", &d[0], &d[1], &d[2] ) )
geom_file.close();
int index = ((iedge*2) + iend) * 3;
(*edge_node_tangents)[ index ] = d[0];
(*edge_node_tangents)[ index + 1 ] = d[1];
(*edge_node_tangents)[ index + 2 ] = d[2];
if ( num_quads ) *num_quads = num_q;
if ( num_tris ) *num_tris = num_t;
if ( num_edges ) *num_edges = num_e;
geom_file.close();
return CUBIT_SUCCESS;
