cgma
00001 //- Class: Cholla 00002 //- Description: C Interface for the Cholla module 00003 //- Facet-based geometry definition and evaluation 00004 //- Owner: Steven J. Owen 00005 //- Checked by: 00006 //- Version: 00007 00008 #include "time.h" 00009 #include "Cholla.h" 00010 #include "ChollaEngine.hpp" 00011 #include "CubitPoint.hpp" 00012 #include "CubitPointData.hpp" 00013 #include "CubitFacetEdge.hpp" 00014 #include "CubitFacetEdgeData.hpp" 00015 #include "CubitFacet.hpp" 00016 #include "CubitFacetData.hpp" 00017 #include "CubitQuadFacet.hpp" 00018 #include "CubitQuadFacetData.hpp" 00019 #include "CastTo.hpp" 00020 #include "TDFacetBoundaryPoint.hpp" 00021 #include "FacetEvalTool.hpp" 00022 #include "FacetDataUtil.hpp" 00023 00024 #include <iostream> 00025 #include <fstream> 00026 using std::ifstream; 00027 00028 #define END_OF_BLOCKS "END_OF_BLOCKS" 00029 00030 // Internal Static function prototypes 00031 00032 static void time_stamp( FILE *fp ); 00033 static CubitStatus build_facets(int numTri, int numQuad, int numEdge, 00034 int numVert, int* triEdge, 00035 int *quadEdge, 00036 int* edgeVert, double* vert, 00037 CubitPoint **point_array, 00038 CubitFacetEdge **edge_array, 00039 CubitFacet **facet_array, 00040 CubitQuadFacet **qfacet_array, 00041 DLIList <FacetEntity *> &facet_list); 00042 static CubitStatus extractEdgeTangsFromFile( int num_file_edges, 00043 int *edge_nodes_file, 00044 double *edge_node_tangs_file, 00045 int numTri, 00046 int *edgeVert, 00047 double *edgeVertTang ); 00048 static CubitStatus extractTriNormalsFromFile( int num_file_tris, 00049 int *tri_nodes_file, 00050 double *tri_node_norms_file, 00051 int numTri, 00052 int *edgeVert, 00053 int *triEdge, 00054 double *triVertNorms ); 00055 static CubitStatus extractQuadNormalsFromFile( int num_file_quads, 00056 int *quad_nodes_file, 00057 double *quad_node_norms_file, 00058 int numQuad, 00059 int *edgeVert, 00060 int *quadEdge, 00061 double *quadVertNorms ); 00062 static void constructTriVerts( int triEdge[3], 00063 int *edgeVert, 00064 int this_tri[3] ); 00065 static void constructQuadVerts( int quadEdge[3], 00066 int *edgeVert, 00067 int this_quad[4] ); 00068 static void checkMemoryAllocations( int num_nodes_per_elem, 00069 int additional_num_elems, 00070 int *num_elems, 00071 int **nodes, 00072 double **node_normals ); 00073 00074 static int classify_local_convexity_at_edge(CubitFacetEdge *edge_ptr); 00075 00076 //=========================================================================== 00077 // Function: constructBezier 00078 // Purpose: Return control points for a quartic Bezier for each face, using 00079 // a given feature angle tolerance to distinguish C0 and C1 edges. 00080 // Separate arrays of tris and quad faces should be supplied 00081 // Date: 10/28/2002 00082 // Author: sjowen 00083 //=========================================================================== 00084 void constructBezier( double angle, int numTri, int numQuad, int numEdge, 00085 int numVert, int* triEdge, int* quadEdge, 00086 int* edgeVert, double* vert, 00087 double* edgeCtrlPts, double* triCtrlPts, 00088 double* quadCtrlPts ) 00089 { 00090 00091 // create arrays of facet entities from the arrays 00092 00093 CubitPoint **point_array = new CubitPoint * [numVert]; 00094 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 00095 CubitFacet **facet_array = NULL; 00096 if (numTri > 0) 00097 facet_array = new CubitFacet * [numTri]; 00098 CubitQuadFacet **qfacet_array = NULL; 00099 if (numQuad > 0) 00100 qfacet_array = new CubitQuadFacet * [numQuad]; 00101 DLIList<FacetEntity *> facet_list; 00102 CubitStatus stat = CUBIT_SUCCESS; 00103 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 00104 edgeVert, vert, point_array, edge_array, facet_array, 00105 qfacet_array, facet_list); 00106 if (CUBIT_SUCCESS != stat) { 00107 PRINT_ERROR("Failed to build facets.\n"); 00108 return; 00109 } 00110 00111 // create lists of points and edges 00112 00113 int ii; 00114 DLIList<CubitPoint *> point_list; 00115 for (ii=0; ii<numVert; ii++) 00116 point_list.append(point_array[ii]); 00117 00118 DLIList<CubitFacetEdge *> edge_list; 00119 for (ii=0; ii<numEdge; ii++) 00120 edge_list.append(edge_array[ii]); 00121 00122 // prepare the ChollaEngine 00123 00124 DLIList<FacetEntity *> fpoint_list, fedge_list; 00125 CAST_LIST_TO_PARENT( point_list, fpoint_list ); 00126 CAST_LIST_TO_PARENT( edge_list, fedge_list ); 00127 ChollaEngine *ceng = new ChollaEngine( facet_list, fedge_list, fpoint_list ); 00128 00129 CubitBoolean use_feature_angle; 00130 if (angle < 0.00001 || angle > 179.9999) 00131 use_feature_angle = CUBIT_FALSE; 00132 else 00133 use_feature_angle = CUBIT_TRUE; 00134 int interp_order = 4; // assume we are creating beziers 00135 CubitBoolean smooth_non_manifold = CUBIT_TRUE; 00136 CubitBoolean split_surfaces = CUBIT_FALSE; 00137 00138 // create the geometry 00139 00140 //CubitStatus rv = 00141 ceng->create_geometry(use_feature_angle,angle, 00142 interp_order,smooth_non_manifold, 00143 split_surfaces); 00144 00145 // get the control points on edges 00146 00147 int jj; 00148 int index; 00149 CubitVector *control_points; 00150 CubitFacetEdge *edge_ptr; 00151 for (ii=0; ii<numEdge; ii++) 00152 { 00153 edge_ptr = edge_array[ii]; 00154 control_points = edge_ptr->control_points(); 00155 assert(control_points != NULL); 00156 for (jj=0; jj<NUM_EDGE_CPTS; jj++) 00157 { 00158 index = 3 * (ii * NUM_EDGE_CPTS + jj); 00159 edgeCtrlPts[index] = control_points[jj].x(); 00160 edgeCtrlPts[index+1] = control_points[jj].y(); 00161 edgeCtrlPts[index+2] = control_points[jj].z(); 00162 } 00163 } 00164 00165 // get the control points on triangles 00166 00167 CubitFacet *facet_ptr; 00168 for (ii=0; ii<numTri; ii++) 00169 { 00170 facet_ptr = facet_array[ii]; 00171 control_points = facet_ptr->control_points(); 00172 assert(control_points != NULL); 00173 for (jj=0; jj<NUM_TRI_CPTS; jj++) 00174 { 00175 index = 3 * (ii * NUM_TRI_CPTS + jj); 00176 triCtrlPts[index] = control_points[jj].x(); 00177 triCtrlPts[index+1] = control_points[jj].y(); 00178 triCtrlPts[index+2] = control_points[jj].z(); 00179 } 00180 } 00181 00182 // get the control points on quads 00183 00184 //CubitVector qctrl_points[NUM_QUAD_CPTS]; 00185 CubitQuadFacet *qfacet_ptr; 00186 for (ii=0; ii<numQuad; ii++) 00187 { 00188 qfacet_ptr = qfacet_array[ii]; 00189 index = 3 * (ii * NUM_QUAD_CPTS); 00190 qfacet_ptr->get_control_points( &(quadCtrlPts[index]) ); 00191 } 00192 00193 // delete the ChollaEngine 00194 00195 ceng->delete_eval_tools(); 00196 ceng->delete_me(); 00197 delete ceng; 00198 00199 // delete temp arrays (facets are deleted with the eval tool) 00200 00201 for (ii=0; ii<numQuad; ii++) 00202 { 00203 qfacet_array[ii]->remove_tri_facets(); 00204 delete qfacet_array[ii]; 00205 } 00206 delete [] point_array; 00207 delete [] edge_array; 00208 if (facet_array) 00209 delete [] facet_array; 00210 if (qfacet_array) 00211 delete [] qfacet_array; 00212 00213 } 00214 00215 //=========================================================================== 00216 // Function: constructTriNormals 00217 // Purpose: Return normals and tangents for a set of triangles using 00218 // a given feature angle tolerance to distinguish C0 and C1 edges. 00219 // Date: 10/10/2003 00220 // Author: sjowen 00221 //=========================================================================== 00222 void constructTriNormals( double angle, int numTri, int numEdge, 00223 int numVert, int* triEdge, 00224 int* edgeVert, double* vert, 00225 double* triVertNorms, double* edgeVertTang, 00226 int* edgeTypeFlags) 00227 { 00228 00229 // create arrays of facet entities from the arrays 00230 00231 int* quadEdge = NULL; 00232 CubitPoint **point_array = new CubitPoint * [numVert]; 00233 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 00234 CubitFacet **facet_array = NULL; 00235 if (numTri > 0) 00236 facet_array = new CubitFacet * [numTri]; 00237 int numQuad = 0; 00238 CubitQuadFacet **qfacet_array = NULL; 00239 DLIList<FacetEntity *> facet_list; 00240 CubitStatus stat = CUBIT_SUCCESS; 00241 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 00242 edgeVert, vert, point_array, edge_array, facet_array, 00243 qfacet_array, facet_list); 00244 if (CUBIT_SUCCESS != stat) { 00245 PRINT_ERROR("Failed to build facets.\n"); 00246 return; 00247 } 00248 00249 // create lists of points and edges 00250 00251 int ii; 00252 DLIList<CubitPoint *> point_list; 00253 for (ii=0; ii<numVert; ii++) 00254 point_list.append(point_array[ii]); 00255 00256 DLIList<CubitFacetEdge *> edge_list; 00257 for (ii=0; ii<numEdge; ii++){ 00258 edge_list.append(edge_array[ii]); 00259 } 00260 00261 00262 // prepare the ChollaEngine 00263 00264 DLIList<FacetEntity *> fpoint_list, fedge_list; 00265 CAST_LIST_TO_PARENT( point_list, fpoint_list ); 00266 CAST_LIST_TO_PARENT( edge_list, fedge_list ); 00267 ChollaEngine *ceng = new ChollaEngine( facet_list, fedge_list, fpoint_list ); 00268 00269 CubitBoolean use_feature_angle; 00270 if (angle < 0.00001 || angle > 179.9999) 00271 use_feature_angle = CUBIT_FALSE; 00272 else 00273 use_feature_angle = CUBIT_TRUE; 00274 int interp_order = 4; // assume we are creating beziers 00275 CubitBoolean smooth_non_manifold = CUBIT_TRUE; 00276 CubitBoolean split_surfaces = CUBIT_FALSE; 00277 00278 // create the geometry 00279 00280 //CubitStatus rv = 00281 ceng->create_geometry(use_feature_angle,angle, 00282 interp_order,smooth_non_manifold, 00283 split_surfaces); 00284 00285 // get the control points on edges and infer the tangents 00286 00287 int index = 0; 00288 CubitVector *control_points; 00289 CubitFacetEdge *edge_ptr; 00290 CubitVector v0, v1, t0, t1; 00291 for (ii=0; ii<numEdge; ii++) 00292 { 00293 edge_ptr = edge_array[ii]; 00294 v0 = edge_ptr->point(0)->coordinates(); 00295 v1 = edge_ptr->point(1)->coordinates(); 00296 control_points = edge_ptr->control_points(); 00297 assert(control_points != NULL); 00298 index = 6 * ii; 00299 t0 = control_points[0] - v0; 00300 t1 = v1 - control_points[2]; 00301 if(edge_ptr->is_flipped()){ 00302 t0 *= (-1.0); 00303 t1 *= (-1.0); 00304 } 00305 t0.normalize(); 00306 t1.normalize(); 00307 edgeVertTang[index ] = t0.x(); 00308 edgeVertTang[index+1] = t0.y(); 00309 edgeVertTang[index+2] = t0.z(); 00310 edgeVertTang[index+3] = t1.x(); 00311 edgeVertTang[index+4] = t1.y(); 00312 edgeVertTang[index+5] = t1.z(); 00313 edgeTypeFlags[ii]=classify_local_convexity_at_edge(edge_ptr); 00314 } 00315 00316 // get the normal on triangles 00317 00318 CubitVector n0, n1, n2; 00319 CubitFacet *facet_ptr; 00320 for (ii=0; ii<numTri; ii++) 00321 { 00322 facet_ptr = facet_array[ii]; 00323 index = 9 * ii; 00324 n0 = facet_ptr->point(0)->normal(facet_ptr); 00325 n1 = facet_ptr->point(1)->normal(facet_ptr); 00326 n2 = facet_ptr->point(2)->normal(facet_ptr); 00327 triVertNorms[index ] = n0.x(); 00328 triVertNorms[index + 1] = n0.y(); 00329 triVertNorms[index + 2] = n0.z(); 00330 triVertNorms[index + 3] = n1.x(); 00331 triVertNorms[index + 4] = n1.y(); 00332 triVertNorms[index + 5] = n1.z(); 00333 triVertNorms[index + 6] = n2.x(); 00334 triVertNorms[index + 7] = n2.y(); 00335 triVertNorms[index + 8] = n2.z(); 00336 } 00337 00338 // delete the ChollaEngine 00339 00340 ceng->delete_eval_tools(); 00341 ceng->delete_me(); 00342 delete ceng; 00343 00344 // delete temp arrays (facets are deleted with the eval tool) 00345 00346 for (ii=0; ii<numQuad; ii++) 00347 { 00348 qfacet_array[ii]->remove_tri_facets(); 00349 delete qfacet_array[ii]; 00350 } 00351 delete [] point_array; 00352 delete [] edge_array; 00353 if (facet_array) 00354 delete [] facet_array; 00355 if (qfacet_array) 00356 delete [] qfacet_array; 00357 } 00358 00359 //=========================================================================== 00360 // Function: constructQuadNormals 00361 // Purpose: Return normals and tangents for a set of quads using 00362 // a given feature angle tolerance to distinguish C0 and C1 edges. 00363 // Date: 10/10/2003 00364 // Author: sjowen 00365 //=========================================================================== 00366 void constructQuadNormals( double angle, int numQuad, int numEdge, 00367 int numVert, int* quadEdge, 00368 int* edgeVert, double* vert, 00369 double* quadVertNorms, double* edgeVertTang, 00370 int* edgeTypeFlags ) 00371 { 00372 00373 // create arrays of facet entities from the arrays 00374 00375 int *triEdge = NULL; 00376 CubitPoint **point_array = new CubitPoint * [numVert]; 00377 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 00378 CubitFacet **facet_array = NULL; 00379 CubitQuadFacet **qfacet_array = NULL; 00380 int numTri = 0; 00381 if (numQuad > 0) 00382 qfacet_array = new CubitQuadFacet * [numQuad]; 00383 DLIList<FacetEntity *> facet_list; 00384 CubitStatus stat = CUBIT_SUCCESS; 00385 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 00386 edgeVert, vert, point_array, edge_array, facet_array, 00387 qfacet_array, facet_list); 00388 if (CUBIT_SUCCESS != stat) { 00389 PRINT_ERROR("Failed to build facets.\n"); 00390 return; 00391 } 00392 // create lists of points and edges 00393 00394 int ii; 00395 00396 DLIList<CubitPoint *> point_list; 00397 for (ii=0; ii<numVert; ii++) 00398 point_list.append(point_array[ii]); 00399 00400 DLIList<CubitFacetEdge *> edge_list; 00401 for (ii=0; ii<numEdge; ii++) 00402 edge_list.append(edge_array[ii]); 00403 00404 // prepare the ChollaEngine 00405 00406 DLIList<FacetEntity *> fpoint_list, fedge_list; 00407 CAST_LIST_TO_PARENT( point_list, fpoint_list ); 00408 CAST_LIST_TO_PARENT( edge_list, fedge_list ); 00409 ChollaEngine *ceng = new ChollaEngine( facet_list, fedge_list, fpoint_list ); 00410 00411 CubitBoolean use_feature_angle; 00412 if (angle < 0.00001 || angle > 179.9999) 00413 use_feature_angle = CUBIT_FALSE; 00414 else 00415 use_feature_angle = CUBIT_TRUE; 00416 int interp_order = 4; // assume we are creating beziers 00417 CubitBoolean smooth_non_manifold = CUBIT_TRUE; 00418 CubitBoolean split_surfaces = CUBIT_FALSE; 00419 00420 // create the geometry 00421 00422 ceng->create_geometry(use_feature_angle,angle, 00423 interp_order,smooth_non_manifold, 00424 split_surfaces); 00425 00426 // get the control points on edges and infer the tangents 00427 00428 int mydebug = 0; 00429 FILE *fp = NULL; 00430 if (mydebug) 00431 { 00432 fp = fopen("edges.txt", "w"); 00433 } 00434 int index = 0; 00435 CubitVector *control_points; 00436 CubitFacetEdge *edge_ptr; 00437 CubitVector v0, v1, t0, t1; 00438 for (ii=0; ii<numEdge; ii++) 00439 { 00440 edge_ptr = edge_array[ii]; 00441 v0 = edge_ptr->point(0)->coordinates(); 00442 v1 = edge_ptr->point(1)->coordinates(); 00443 control_points = edge_ptr->control_points(); 00444 assert(control_points != NULL); 00445 if (mydebug) 00446 { 00447 int kk; 00448 for(kk=0; kk<3; kk++); 00449 fprintf(fp, "(%d) %.6f %.6f %.6f\n", edge_ptr->id(), v0.x(), v0.y(), v0.z()); 00450 fprintf(fp, " %.6f %.6f %.6f\n", control_points[0].x(), control_points[0].y(), control_points[0].z()); 00451 fprintf(fp, " %.6f %.6f %.6f\n", control_points[1].x(), control_points[1].y(), control_points[1].z()); 00452 fprintf(fp, " %.6f %.6f %.6f\n", control_points[2].x(), control_points[2].y(), control_points[2].z()); 00453 fprintf(fp, " %.6f %.6f %.6f\n", v1.x(), v1.y(), v1.z()); 00454 } 00455 index = 6 * ii; 00456 t0 = control_points[0] - v0; 00457 t1 = v1 - control_points[2]; 00458 if(edge_ptr->is_flipped()){ 00459 t0 *= (-1.0); 00460 t1 *= (-1.0); 00461 } 00462 t0.normalize(); 00463 t1.normalize(); 00464 edgeVertTang[index ] = t0.x(); 00465 edgeVertTang[index+1] = t0.y(); 00466 edgeVertTang[index+2] = t0.z(); 00467 edgeVertTang[index+3] = t1.x(); 00468 edgeVertTang[index+4] = t1.y(); 00469 edgeVertTang[index+5] = t1.z(); 00470 edgeTypeFlags[ii]=classify_local_convexity_at_edge(edge_ptr); 00471 } 00472 if (mydebug) 00473 { 00474 fclose(fp); 00475 } 00476 00477 // get the normal on quad 00478 00479 CubitVector n0, n1, n2, n3; 00480 CubitQuadFacet *qfacet_ptr; 00481 for (ii=0; ii<numQuad; ii++) 00482 { 00483 qfacet_ptr = qfacet_array[ii]; 00484 index = 12 * ii; 00485 n0 = qfacet_ptr->point(0)->normal(qfacet_ptr); 00486 n1 = qfacet_ptr->point(1)->normal(qfacet_ptr); 00487 n2 = qfacet_ptr->point(2)->normal(qfacet_ptr); 00488 n3 = qfacet_ptr->point(3)->normal(qfacet_ptr); 00489 quadVertNorms[index ] = n0.x(); 00490 quadVertNorms[index + 1 ] = n0.y(); 00491 quadVertNorms[index + 2 ] = n0.z(); 00492 quadVertNorms[index + 3 ] = n1.x(); 00493 quadVertNorms[index + 4 ] = n1.y(); 00494 quadVertNorms[index + 5 ] = n1.z(); 00495 quadVertNorms[index + 6 ] = n2.x(); 00496 quadVertNorms[index + 7 ] = n2.y(); 00497 quadVertNorms[index + 8 ] = n2.z(); 00498 quadVertNorms[index + 9 ] = n3.x(); 00499 quadVertNorms[index + 10] = n3.y(); 00500 quadVertNorms[index + 11] = n3.z(); 00501 } 00502 00503 // delete the ChollaEngine 00504 00505 ceng->delete_eval_tools(); 00506 ceng->delete_me(); 00507 delete ceng; 00508 00509 // delete temp arrays 00510 00511 for (ii=0; ii<numQuad; ii++) 00512 { 00513 qfacet_array[ii]->remove_tri_facets(); 00514 delete qfacet_array[ii]; 00515 } 00516 delete [] point_array; 00517 delete [] edge_array; 00518 if (facet_array) 00519 delete [] facet_array; 00520 if (qfacet_array) 00521 delete [] qfacet_array; 00522 } 00523 00524 //=========================================================================== 00525 // Function: build_facets 00526 // Purpose: static function that creates facet entities 00527 // from initial the arrays 00528 // Date: 10/28/2002 00529 // Author: sjowen 00530 //=========================================================================== 00531 static CubitStatus build_facets(int numTri, int numQuad, int numEdge, 00532 int numVert, int* triEdge, int *quadEdge, 00533 int* edgeVert, double* vert, 00534 CubitPoint **point_array, 00535 CubitFacetEdge **edge_array, 00536 CubitFacet **facet_array, 00537 CubitQuadFacet **qfacet_array, 00538 DLIList <FacetEntity *> &facet_list) 00539 { 00540 // create the points 00541 00542 double x, y, z; 00543 int ii; 00544 00545 for (ii=0; ii<numVert; ii++) 00546 { 00547 x = vert[ii*3]; 00548 y = vert[ii*3 + 1]; 00549 z = vert[ii*3 + 2]; 00550 point_array[ii] = (CubitPoint *) new CubitPointData( x, y, z ); 00551 point_array[ii]->set_id(ii); 00552 } 00553 00554 // create the edges 00555 00556 int ip, jp; 00557 for (ii=0; ii<numEdge; ii++) 00558 { 00559 ip = edgeVert[ii*2]; 00560 jp = edgeVert[ii*2 + 1]; 00561 assert(ip < numVert && jp < numVert && ip >= 0 && jp >= 0); 00562 edge_array[ii] = (CubitFacetEdge *) new CubitFacetEdgeData( point_array[ip], 00563 point_array[jp] ); 00564 edge_array[ii]->set_id(ii); 00565 } 00566 00567 // create the tri facets 00568 00569 int begin_face; 00570 int jj, iedge; 00571 CubitFacetEdge *edges[4]; 00572 CubitFacet *facet_ptr = NULL; 00573 00574 for (ii=0; ii<numTri; ii++) 00575 { 00576 begin_face = 3 * ii; 00577 for(jj=0; jj<3; jj++) 00578 { 00579 iedge = triEdge[begin_face+jj]; 00580 edges[jj] = edge_array[iedge]; 00581 } 00582 facet_ptr = (CubitFacet *) 00583 new CubitFacetData(edges[0], edges[1], edges[2]); 00584 facet_list.append(facet_ptr); 00585 facet_array[ii] = facet_ptr; 00586 } 00587 00588 // create the quad facets 00589 00590 CubitQuadFacet *qfacet_ptr = NULL; 00591 for (ii=0; ii<numQuad; ii++) 00592 { 00593 begin_face = 4 * ii; 00594 for(jj=0; jj<4; jj++) 00595 { 00596 iedge = quadEdge[begin_face+jj]; 00597 edges[jj] = edge_array[iedge]; 00598 } 00599 qfacet_ptr = (CubitQuadFacet *) 00600 new CubitQuadFacetData(edges[0], edges[1], edges[2], edges[3]); 00601 facet_list.append(qfacet_ptr->get_tri_facet(0)); 00602 facet_list.append(qfacet_ptr->get_tri_facet(1)); 00603 qfacet_array[ii] = qfacet_ptr; 00604 } 00605 00606 int mydebug = 0; 00607 if (mydebug) 00608 { 00609 DLIList<CubitFacet*> myfacet_list; 00610 CAST_LIST(facet_list, myfacet_list, CubitFacet); 00611 FacetDataUtil::write_facets("C:\\CUBIT\\cholla_apps\\examples\\sierra\\test.facets",myfacet_list); 00612 } 00613 00614 return CUBIT_SUCCESS; 00615 00616 } 00617 00618 //=========================================================================== 00619 // Function: evalBezierFace 00620 // Purpose: Evaluate a set of quartic Bezier patches at a specified 00621 // parametric location given its control points. Evaluates 00622 // location, normal and/or derivative. Expects list of either 00623 // quads or tris (not both) 00624 // 00625 // Date: 10/28/2002 00626 // Author: sjowen 00627 //=========================================================================== 00628 void evalBezierFace( int numFace, int numEdge, int numVert, int numVertPerFace, 00629 int* faceEdge, int* edgeVert, 00630 double* vert, double* faceCtrlPts, 00631 double* edgeCtrlPts, 00632 int numLocs, double* paramLocation, 00633 double* location, double* normal, double* deriv ) 00634 { 00635 // create arrays of facet entities from the arrays 00636 00637 int numTri = 0; 00638 int numQuad = 0; 00639 CubitPoint **point_array = new CubitPoint * [numVert]; 00640 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 00641 CubitFacet **facet_array = NULL; 00642 int *tri_edge = (numVertPerFace == 3) ? faceEdge : NULL; 00643 int *quad_edge = (numVertPerFace == 4) ? faceEdge : NULL; 00644 if (numVertPerFace == 3) 00645 { 00646 facet_array = new CubitFacet * [numFace]; 00647 numTri = numFace; 00648 } 00649 CubitQuadFacet **qfacet_array = NULL; 00650 if (numVertPerFace == 4) 00651 { 00652 qfacet_array = new CubitQuadFacet * [numFace]; 00653 numQuad = numFace; 00654 } 00655 DLIList<FacetEntity *> facet_list; 00656 CubitStatus stat = CUBIT_SUCCESS; 00657 stat = build_facets(numTri, numQuad, numEdge, numVert, tri_edge, quad_edge, 00658 edgeVert, vert, point_array, edge_array, facet_array, 00659 qfacet_array, facet_list); 00660 if (CUBIT_SUCCESS != stat) { 00661 PRINT_ERROR("Failed to build facets.\n"); 00662 return; 00663 } 00664 00665 // set the control points on edges 00666 00667 int index, ii, jj; 00668 CubitFacetEdge *edge_ptr; 00669 for (ii=0; ii<numEdge; ii++) 00670 { 00671 edge_ptr = edge_array[ii]; 00672 index = 3 * (ii * NUM_EDGE_CPTS); 00673 edge_ptr->set_control_points( &(edgeCtrlPts[index]) ); 00674 } 00675 00676 // set the control points on triangles 00677 00678 CubitFacet *facet_ptr; 00679 for (ii=0; ii<numTri; ii++) 00680 { 00681 facet_ptr = facet_array[ii]; 00682 index = 3 * (ii * NUM_TRI_CPTS); 00683 facet_ptr->set_control_points( &(faceCtrlPts[index]) ); 00684 } 00685 00686 // set the control points on quads 00687 00688 CubitQuadFacet *qfacet_ptr; 00689 for (ii=0; ii<numQuad; ii++) 00690 { 00691 qfacet_ptr = qfacet_array[ii]; 00692 index = 3 * (ii * NUM_QUAD_CPTS); 00693 qfacet_ptr->set_control_points( &(faceCtrlPts[index]) ); 00694 } 00695 00696 // Do the evaluations 00697 00698 for (ii=0; ii<numTri; ii++) 00699 { 00700 for (jj=0; jj<numLocs; jj++) 00701 { 00702 facet_ptr = facet_array[ii]; 00703 CubitVector areacoord(paramLocation[jj*3], 00704 paramLocation[jj*3+1], 00705 paramLocation[jj*3+2]); 00706 CubitVector eval_point; 00707 CubitVector *eval_point_ptr = &eval_point; 00708 CubitVector eval_normal; 00709 CubitVector *eval_normal_ptr = NULL; 00710 if (normal != NULL) 00711 { 00712 eval_normal_ptr = &eval_normal; 00713 } 00714 facet_ptr->evaluate( areacoord, eval_point_ptr, eval_normal_ptr ); 00715 index = 3 * ii * jj; 00716 location[index] = eval_point.x(); 00717 location[index+1] = eval_point.y(); 00718 location[index+2] = eval_point.z(); 00719 if (normal != NULL) 00720 { 00721 normal[index] = eval_normal.x(); 00722 normal[index+1] = eval_normal.y(); 00723 normal[index+2] = eval_normal.z(); 00724 } 00725 } 00726 } 00727 00728 for (ii=0; ii<numQuad; ii++) 00729 { 00730 for (jj=0; jj<numLocs; jj++) 00731 { 00732 qfacet_ptr = qfacet_array[ii]; 00733 CubitVector eval_point; 00734 CubitVector *eval_point_ptr = &eval_point; 00735 CubitVector eval_normal; 00736 CubitVector *eval_normal_ptr = NULL; 00737 if (normal != NULL) 00738 eval_normal_ptr = &eval_normal; 00739 CubitVector eval_du, eval_dv; 00740 CubitVector *eval_du_ptr = NULL; 00741 CubitVector *eval_dv_ptr = NULL; 00742 if (deriv != NULL) 00743 { 00744 eval_du_ptr = &eval_du; 00745 eval_dv_ptr = &eval_dv; 00746 } 00747 00748 qfacet_ptr->evaluate( paramLocation[2*jj], paramLocation[2*jj+1], 00749 eval_point_ptr, eval_normal_ptr, 00750 eval_du_ptr, eval_dv_ptr); 00751 index = 3 * ii * jj; 00752 location[index] = eval_point.x(); 00753 location[index+1] = eval_point.y(); 00754 location[index+2] = eval_point.z(); 00755 if (normal != NULL) 00756 { 00757 normal[index] = eval_normal.x(); 00758 normal[index+1] = eval_normal.y(); 00759 normal[index+2] = eval_normal.z(); 00760 } 00761 if (deriv != NULL) 00762 { 00763 index = 6 * ii * jj; 00764 deriv[index] = eval_du.x(); 00765 deriv[index+1] = eval_du.y(); 00766 deriv[index+2] = eval_du.z(); 00767 deriv[index+3] = eval_dv.x(); 00768 deriv[index+4] = eval_dv.y(); 00769 deriv[index+5] = eval_dv.z(); 00770 } 00771 } 00772 } 00773 00774 // delete the temp arrays 00775 00776 for (ii=0; ii<numQuad; ii++) 00777 delete qfacet_array[ii]; 00778 for (ii=0; ii<numTri; ii++) 00779 delete facet_array[ii]; 00780 for (ii=0; ii<numEdge; ii++) 00781 delete edge_array[ii]; 00782 for (ii=0; ii<numVert; ii++) 00783 delete point_array[ii]; 00784 delete [] point_array; 00785 delete [] edge_array; 00786 if (facet_array) 00787 delete [] facet_array; 00788 if (qfacet_array) 00789 delete [] qfacet_array; 00790 } 00791 00792 //=========================================================================== 00793 // Function: evalBezierFaceFromNorms 00794 // Purpose: This is the same as the evalBezierFace except it differes by 00795 // the input arguments. This function takes a list of normals 00796 // and tangents at the face vertices and computes bezier control 00797 // points internally. Normals and tangents should have been 00798 // computed previously in constructTriNormals or constructQuadNormals. 00799 // This function is not as computationally efficient as evalBezierFace 00800 // since it requires Bezier control points to be computed 00801 // as part of the call - however, it is more memory efficient, 00802 // requiring fewer variables to be stored with the calling application. 00803 // The following argument list describes only those arguments that 00804 // differ from evalBezierFace above. 00805 // 00806 // Date: 10/15/2003 00807 // Author: sjowen 00808 //=========================================================================== 00809 void evalBezierFaceFromNorms( int numFace, int numEdge, int numVert, 00810 int numVertPerFace, int* faceEdge, int* edgeVert, 00811 double* vert, double* vertNorms, double* edgeVertTang, 00812 int numLocs, double* paramLocation, 00813 double* location, double* normal, double* deriv ) 00814 { 00815 // create arrays of facet entities from the arrays 00816 00817 int numTri = 0; 00818 int numQuad = 0; 00819 CubitPoint **point_array = new CubitPoint * [numVert]; 00820 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 00821 CubitFacet **facet_array = NULL; 00822 int *triEdge = (numVertPerFace == 3) ? faceEdge : NULL; 00823 int *quadEdge = (numVertPerFace == 4) ? faceEdge : NULL; 00824 if (numVertPerFace == 3) 00825 { 00826 facet_array = new CubitFacet * [numFace]; 00827 numTri = numFace; 00828 } 00829 CubitQuadFacet **qfacet_array = NULL; 00830 if (numVertPerFace == 4) 00831 { 00832 qfacet_array = new CubitQuadFacet * [numFace]; 00833 numQuad = numFace; 00834 } 00835 DLIList<FacetEntity *> facet_list; 00836 CubitStatus stat = CUBIT_SUCCESS; 00837 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 00838 edgeVert, vert, point_array, edge_array, facet_array, 00839 qfacet_array, facet_list); 00840 if (CUBIT_SUCCESS != stat) { 00841 PRINT_ERROR("Failed to build facets.\n"); 00842 return; 00843 } 00844 00845 // set the normals on triangle vertices 00846 00847 int index, ii, jj; 00848 CubitPoint *pt; 00849 CubitFacet *facet_ptr; 00850 CubitVector pt_normal; 00851 for (ii=0; ii<numTri; ii++) 00852 { 00853 facet_ptr = facet_array[ii]; 00854 for(jj=0; jj<3; jj++) 00855 { 00856 index = ii * 9 + (3 * jj); 00857 pt_normal.x( vertNorms[ index ] ); 00858 pt_normal.y( vertNorms[ index + 1 ] ); 00859 pt_normal.z( vertNorms[ index + 2 ] ); 00860 pt = facet_ptr->point(jj); 00861 TDFacetBoundaryPoint::add_facet_boundary_point( pt, facet_ptr, pt_normal ); 00862 } 00863 } 00864 00865 // set the normals on quad vertices 00866 00867 CubitQuadFacet *qfacet_ptr; 00868 for (ii=0; ii<numQuad; ii++) 00869 { 00870 qfacet_ptr = qfacet_array[ii]; 00871 for(jj=0; jj<4; jj++) 00872 { 00873 index = ii * 12 + (3 * jj); 00874 pt_normal.x( vertNorms[ index ] ); 00875 pt_normal.y( vertNorms[ index + 1 ] ); 00876 pt_normal.z( vertNorms[ index + 2 ] ); 00877 pt = qfacet_ptr->point(jj); 00878 TDFacetBoundaryPoint::add_facet_boundary_point( pt, qfacet_ptr, pt_normal ); 00879 } 00880 } 00881 00882 // set the control points on edges 00883 00884 int mydebug = 0; 00885 FILE *fp = NULL; 00886 if (mydebug) 00887 fp = fopen("edges.txt", "w"); 00888 CubitFacetEdge *edge_ptr; 00889 CubitVector N0, N1, T0, T1, P0, P1; 00890 CubitVector Pi[3]; 00891 CubitPoint *pt0, *pt1; 00892 for (ii=0; ii<numEdge; ii++) 00893 { 00894 index = 6 * ii; 00895 edge_ptr = edge_array[ii]; 00896 pt0 = edge_ptr->point(0); 00897 pt1 = edge_ptr->point(1); 00898 P0 = pt0->coordinates(); 00899 P1 = pt1->coordinates(); 00900 N0 = pt0->normal( edge_ptr ); 00901 N1 = pt1->normal( edge_ptr ); 00902 T0.x( edgeVertTang[ index ] ); 00903 T0.y( edgeVertTang[ index + 1] ); 00904 T0.z( edgeVertTang[ index + 2] ); 00905 T1.x( edgeVertTang[ index + 3] ); 00906 T1.y( edgeVertTang[ index + 4] ); 00907 T1.z( edgeVertTang[ index + 5] ); 00908 FacetEvalTool::init_edge_control_points(P0, P1, N0, N1, T0, T1, Pi); 00909 if (mydebug) 00910 { 00911 int kk; 00912 for(kk=0; kk<3; kk++); 00913 fprintf(fp, "(%d) %.6f %.6f %.6f\n", edge_ptr->id(), P0.x(), P0.y(), P0.z()); 00914 fprintf(fp, " %.6f %.6f %.6f\n", Pi[0].x(), Pi[0].y(), Pi[0].z()); 00915 fprintf(fp, " %.6f %.6f %.6f\n", Pi[1].x(), Pi[1].y(), Pi[1].z()); 00916 fprintf(fp, " %.6f %.6f %.6f\n", Pi[2].x(), Pi[2].y(), Pi[2].z()); 00917 fprintf(fp, " %.6f %.6f %.6f\n", P1.x(), P1.y(), P1.z()); 00918 } 00919 edge_ptr->control_points( Pi, 4 ); 00920 } 00921 if (mydebug) 00922 fclose(fp); 00923 00924 // set the control points on triangles 00925 00926 for (ii=0; ii<numTri; ii++) 00927 { 00928 facet_ptr = facet_array[ii]; 00929 facet_ptr->init_patch(); 00930 } 00931 00932 // set the control points on quads 00933 00934 for (ii=0; ii<numQuad; ii++) 00935 { 00936 qfacet_ptr = qfacet_array[ii]; 00937 qfacet_ptr->init_patch(); 00938 } 00939 00940 // Do the evaluations 00941 00942 index = 0; 00943 int nindex = 0; 00944 for (ii=0; ii<numTri; ii++) 00945 { 00946 facet_ptr = facet_array[ii]; 00947 for (jj=0; jj<numLocs; jj++) 00948 { 00949 CubitVector areacoord(paramLocation[jj*3], 00950 paramLocation[jj*3+1], 00951 paramLocation[jj*3+2]); 00952 CubitVector eval_point; 00953 CubitVector *eval_point_ptr = &eval_point; 00954 CubitVector eval_normal; 00955 CubitVector *eval_normal_ptr = NULL; 00956 if (normal != NULL) 00957 { 00958 eval_normal_ptr = &eval_normal; 00959 } 00960 facet_ptr->evaluate( areacoord, eval_point_ptr, eval_normal_ptr ); 00961 location[index++] = eval_point.x(); 00962 location[index++] = eval_point.y(); 00963 location[index++] = eval_point.z(); 00964 if (normal != NULL) 00965 { 00966 normal[nindex++] = eval_normal.x(); 00967 normal[nindex++] = eval_normal.y(); 00968 normal[nindex++] = eval_normal.z(); 00969 } 00970 } 00971 } 00972 00973 int dindex = 0; 00974 nindex = index = 0; 00975 for (ii=0; ii<numQuad; ii++) 00976 { 00977 for (jj=0; jj<numLocs; jj++) 00978 { 00979 qfacet_ptr = qfacet_array[ii]; 00980 CubitVector eval_point; 00981 CubitVector *eval_point_ptr = &eval_point; 00982 CubitVector eval_normal; 00983 CubitVector *eval_normal_ptr = NULL; 00984 if (normal != NULL) 00985 eval_normal_ptr = &eval_normal; 00986 CubitVector eval_du, eval_dv; 00987 CubitVector *eval_du_ptr = NULL; 00988 CubitVector *eval_dv_ptr = NULL; 00989 if (deriv != NULL) 00990 { 00991 eval_du_ptr = &eval_du; 00992 eval_dv_ptr = &eval_dv; 00993 } 00994 00995 qfacet_ptr->evaluate( paramLocation[2*jj], paramLocation[2*jj+1], 00996 eval_point_ptr, eval_normal_ptr, 00997 eval_du_ptr, eval_dv_ptr); 00998 location[index++] = eval_point.x(); 00999 location[index++] = eval_point.y(); 01000 location[index++] = eval_point.z(); 01001 if (normal != NULL) 01002 { 01003 normal[nindex++] = eval_normal.x(); 01004 normal[nindex++] = eval_normal.y(); 01005 normal[nindex++] = eval_normal.z(); 01006 } 01007 if (deriv != NULL) 01008 { 01009 index = 6 * ii * jj; 01010 deriv[dindex++] = eval_du.x(); 01011 deriv[dindex++] = eval_du.y(); 01012 deriv[dindex++] = eval_du.z(); 01013 deriv[dindex++] = eval_dv.x(); 01014 deriv[dindex++] = eval_dv.y(); 01015 deriv[dindex++] = eval_dv.z(); 01016 } 01017 } 01018 } 01019 01020 // delete the temp arrays 01021 01022 for (ii=0; ii<numQuad; ii++) 01023 delete qfacet_array[ii]; 01024 for (ii=0; ii<numTri; ii++) 01025 delete facet_array[ii]; 01026 for (ii=0; ii<numEdge; ii++) 01027 delete edge_array[ii]; 01028 for (ii=0; ii<numVert; ii++) 01029 delete point_array[ii]; 01030 delete [] point_array; 01031 delete [] edge_array; 01032 if (facet_array) 01033 delete [] facet_array; 01034 if (qfacet_array) 01035 delete [] qfacet_array; 01036 } 01037 01038 //=========================================================================== 01039 // Function: projToBezierFace 01040 // Purpose: Project a set of x-y-z locations to Bezier patches. Finds the 01041 // closest point on one of the patches. Evaluates location, 01042 // normal and/or derivative. Expects list of either quads or 01043 // tris (not both) 01044 // 01045 // Date: 12/08/2003 01046 // Author: sjowen 01047 //=========================================================================== 01048 void projToBezierFace( int numFace, int numEdge, int numVert, int numVertPerFace, 01049 int* faceEdge, int* edgeVert, 01050 double* vert, double* faceCtrlPts, 01051 double* edgeCtrlPts, 01052 int numLocs, double* xyz, 01053 int specify_tol, double converge_tol, 01054 double* xyzOnFace, double* normal, double* deriv ) 01055 { 01056 // create arrays of facet entities from the arrays 01057 01058 int numTri = 0; 01059 int numQuad = 0; 01060 CubitPoint **point_array = new CubitPoint * [numVert]; 01061 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 01062 CubitFacet **facet_array = NULL; 01063 int *tri_edge = (numVertPerFace == 3) ? faceEdge : NULL; 01064 int *quad_edge = (numVertPerFace == 4) ? faceEdge : NULL; 01065 if (numVertPerFace == 3) 01066 { 01067 facet_array = new CubitFacet * [numFace]; 01068 numTri = numFace; 01069 } 01070 CubitQuadFacet **qfacet_array = NULL; 01071 if (numVertPerFace == 4) 01072 { 01073 qfacet_array = new CubitQuadFacet * [numFace]; 01074 numQuad = numFace; 01075 } 01076 DLIList<FacetEntity *> facetentity_list; 01077 CubitStatus stat = CUBIT_SUCCESS; 01078 stat = build_facets(numTri, numQuad, numEdge, numVert, quad_edge, tri_edge, 01079 edgeVert, vert, point_array, edge_array, facet_array, 01080 qfacet_array, facetentity_list); 01081 if (CUBIT_SUCCESS != stat) { 01082 PRINT_ERROR("Failed to build facets.\n"); 01083 return; 01084 } 01085 DLIList<CubitFacet *> facet_list; 01086 CAST_LIST(facetentity_list, facet_list, CubitFacet); 01087 01088 // set the control points on edges 01089 01090 double edgelen; 01091 double compare_tol = 0.0; 01092 int index, ii; 01093 CubitFacetEdge *edge_ptr; 01094 for (ii=0; ii<numEdge; ii++) 01095 { 01096 edge_ptr = edge_array[ii]; 01097 index = 3 * (ii * NUM_EDGE_CPTS); 01098 edge_ptr->set_control_points( &(edgeCtrlPts[index]) ); 01099 if ( !specify_tol ) 01100 { 01101 edgelen = edge_ptr->length(); 01102 compare_tol += edgelen; 01103 } 01104 } 01105 if ( specify_tol ) 01106 { 01107 compare_tol = converge_tol; 01108 } 01109 else 01110 { 01111 compare_tol /= numEdge; 01112 compare_tol *= 1.0e-3; 01113 } 01114 01115 // set the control points on triangles 01116 01117 CubitFacet *facet_ptr; 01118 for (ii=0; ii<numTri; ii++) 01119 { 01120 facet_ptr = facet_array[ii]; 01121 index = 3 * (ii * NUM_TRI_CPTS); 01122 facet_ptr->set_control_points( &(faceCtrlPts[index]) ); 01123 } 01124 01125 // set the control points on quads 01126 01127 CubitQuadFacet *qfacet_ptr; 01128 for (ii=0; ii<numQuad; ii++) 01129 { 01130 qfacet_ptr = qfacet_array[ii]; 01131 index = 3 * (ii * NUM_QUAD_CPTS); 01132 qfacet_ptr->set_control_points( &(faceCtrlPts[index]) ); 01133 } 01134 01135 // Do the projections 01136 01137 CubitFacet *last_facet = NULL; 01138 int interp_order = 4; 01139 CubitBoolean trim = CUBIT_TRUE; 01140 CubitBoolean outside; 01141 for (ii=0; ii<numLocs; ii++) 01142 { 01143 CubitVector cur_location(xyz[ii*3], 01144 xyz[ii*3+1], 01145 xyz[ii*3+2]); 01146 CubitVector eval_point; 01147 CubitVector *eval_point_ptr = &eval_point; 01148 CubitVector eval_normal; 01149 CubitVector *eval_normal_ptr = NULL; 01150 if (normal != NULL) 01151 { 01152 eval_normal_ptr = &eval_normal; 01153 } 01154 FacetEvalTool::project_to_facets(facet_list, last_facet, 01155 interp_order, compare_tol, 01156 cur_location, trim, 01157 &outside, eval_point_ptr, 01158 eval_normal_ptr); 01159 index = 3 * ii; 01160 xyzOnFace[index] = eval_point.x(); 01161 xyzOnFace[index+1] = eval_point.y(); 01162 xyzOnFace[index+2] = eval_point.z(); 01163 if (normal != NULL) 01164 { 01165 normal[index] = eval_normal.x(); 01166 normal[index+1] = eval_normal.y(); 01167 normal[index+2] = eval_normal.z(); 01168 } 01169 } 01170 01171 // no derivatives yet!! 01172 01173 01174 // delete the temp arrays 01175 01176 for (ii=0; ii<numQuad; ii++) 01177 delete qfacet_array[ii]; 01178 for (ii=0; ii<numTri; ii++) 01179 delete facet_array[ii]; 01180 for (ii=0; ii<numEdge; ii++) 01181 delete edge_array[ii]; 01182 for (ii=0; ii<numVert; ii++) 01183 delete point_array[ii]; 01184 delete [] point_array; 01185 delete [] edge_array; 01186 if (facet_array) 01187 delete [] facet_array; 01188 if (qfacet_array) 01189 delete [] qfacet_array; 01190 } 01191 01192 //=========================================================================== 01193 // Function: projToBezierFaceFromNorms 01194 // Purpose: This is the same as the projToBezierFace except it differes by 01195 // the input arguments. This function takes a list of normals and tangents 01196 // at the face vertices and computes bezier control points internally. 01197 // Normals and tangents should have been computed previously in 01198 // constructTriNormals or constructQuadNormals. This function is not as 01199 // computationally efficient as evalBezierFace since it requires Bezier 01200 // control points to be computed as part of the call - however, it is more 01201 // memory efficient, requiring fewer variables to be stored with the calling 01202 // application. The following argument list describes only those arguments 01203 // that differ from projToBezierFace above. 01204 // 01205 // Date: 12/08/2003 01206 // Author: sjowen 01207 //=========================================================================== 01208 void projToBezierFaceFromNorms( int numFace, int numEdge, int numVert, 01209 int numVertPerFace, int* faceEdge, int* edgeVert, 01210 double* vert, double* vertNorms, double* edgeVertTang, 01211 int numLocs, double* xyz, 01212 int specify_tol, double converge_tol, 01213 double* xyzOnFace, double* normal, double* deriv ) 01214 { 01215 // create arrays of facet entities from the arrays 01216 01217 int numTri = 0; 01218 int numQuad = 0; 01219 CubitPoint **point_array = new CubitPoint * [numVert]; 01220 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 01221 CubitFacet **facet_array = NULL; 01222 int *triEdge = (numVertPerFace == 3) ? faceEdge : NULL; 01223 int *quadEdge = (numVertPerFace == 4) ? faceEdge : NULL; 01224 if (numVertPerFace == 3) 01225 { 01226 facet_array = new CubitFacet * [numFace]; 01227 numTri = numFace; 01228 } 01229 CubitQuadFacet **qfacet_array = NULL; 01230 if (numVertPerFace == 4) 01231 { 01232 qfacet_array = new CubitQuadFacet * [numFace]; 01233 numQuad = numFace; 01234 } 01235 DLIList<FacetEntity *> facetentity_list; 01236 CubitStatus stat = CUBIT_SUCCESS; 01237 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 01238 edgeVert, vert, point_array, edge_array, facet_array, 01239 qfacet_array, facetentity_list); 01240 if (CUBIT_SUCCESS != stat) { 01241 PRINT_ERROR("Failed to build facets.\n"); 01242 return; 01243 } 01244 DLIList<CubitFacet *> facet_list; 01245 CAST_LIST(facetentity_list, facet_list, CubitFacet); 01246 01247 // set the normals on triangle vertices 01248 01249 int index, ii, jj; 01250 CubitPoint *pt; 01251 CubitFacet *facet_ptr; 01252 CubitVector pt_normal; 01253 for (ii=0; ii<numTri; ii++) 01254 { 01255 facet_ptr = facet_array[ii]; 01256 for(jj=0; jj<3; jj++) 01257 { 01258 index = ii * 9 + (3 * jj); 01259 pt_normal.x( vertNorms[ index ] ); 01260 pt_normal.y( vertNorms[ index + 1 ] ); 01261 pt_normal.z( vertNorms[ index + 2 ] ); 01262 pt = facet_ptr->point(jj); 01263 TDFacetBoundaryPoint::add_facet_boundary_point( pt, facet_ptr, pt_normal ); 01264 } 01265 } 01266 01267 // set the normals on quad vertices 01268 01269 CubitQuadFacet *qfacet_ptr; 01270 for (ii=0; ii<numQuad; ii++) 01271 { 01272 qfacet_ptr = qfacet_array[ii]; 01273 for(jj=0; jj<4; jj++) 01274 { 01275 index = ii * 12 + (3 * jj); 01276 pt_normal.x( vertNorms[ index ] ); 01277 pt_normal.y( vertNorms[ index + 1 ] ); 01278 pt_normal.z( vertNorms[ index + 2 ] ); 01279 pt = qfacet_ptr->point(jj); 01280 TDFacetBoundaryPoint::add_facet_boundary_point( pt, qfacet_ptr, pt_normal ); 01281 } 01282 } 01283 01284 // set the control points on edges 01285 01286 double edgelen; 01287 double compare_tol = 0.0; 01288 CubitFacetEdge *edge_ptr; 01289 CubitVector N0, N1, T0, T1, P0, P1; 01290 CubitVector Pi[3]; 01291 CubitPoint *pt0, *pt1; 01292 for (ii=0; ii<numEdge; ii++) 01293 { 01294 index = 6 * ii; 01295 edge_ptr = edge_array[ii]; 01296 pt0 = edge_ptr->point(0); 01297 pt1 = edge_ptr->point(1); 01298 P0 = pt0->coordinates(); 01299 P1 = pt1->coordinates(); 01300 N0 = pt0->normal( edge_ptr ); 01301 N1 = pt1->normal( edge_ptr ); 01302 T0.x( edgeVertTang[ index ] ); 01303 T0.y( edgeVertTang[ index + 1] ); 01304 T0.z( edgeVertTang[ index + 2] ); 01305 T1.x( edgeVertTang[ index + 3] ); 01306 T1.y( edgeVertTang[ index + 4] ); 01307 T1.z( edgeVertTang[ index + 5] ); 01308 FacetEvalTool::init_edge_control_points(P0, P1, N0, N1, T0, T1, Pi); 01309 edge_ptr->control_points( Pi, 4 ); 01310 if ( !specify_tol ) 01311 { 01312 edgelen = edge_ptr->length(); 01313 compare_tol += edgelen; 01314 } 01315 } 01316 if ( specify_tol ) 01317 { 01318 compare_tol = converge_tol; 01319 } 01320 else 01321 { 01322 compare_tol /= numEdge; 01323 compare_tol *= 1.0e-3; 01324 } 01325 01326 // set the control points on triangles 01327 01328 for (ii=0; ii<numTri; ii++) 01329 { 01330 facet_ptr = facet_array[ii]; 01331 facet_ptr->init_patch(); 01332 } 01333 01334 // set the control points on quads 01335 01336 for (ii=0; ii<numQuad; ii++) 01337 { 01338 qfacet_ptr = qfacet_array[ii]; 01339 qfacet_ptr->init_patch(); 01340 } 01341 01342 // Do the projections 01343 01344 CubitFacet *last_facet = NULL; 01345 int interp_order = 4; 01346 CubitBoolean trim = CUBIT_TRUE; 01347 CubitBoolean outside; 01348 01349 for (ii=0; ii<numLocs; ii++) 01350 { 01351 CubitVector cur_location(xyz[ii*3], 01352 xyz[ii*3+1], 01353 xyz[ii*3+2]); 01354 CubitVector eval_point; 01355 CubitVector *eval_point_ptr = &eval_point; 01356 CubitVector eval_normal; 01357 CubitVector *eval_normal_ptr = NULL; 01358 if (normal != NULL) 01359 { 01360 eval_normal_ptr = &eval_normal; 01361 } 01362 FacetEvalTool::project_to_facets(facet_list, last_facet, 01363 interp_order, compare_tol, 01364 cur_location, trim, 01365 &outside, eval_point_ptr, 01366 eval_normal_ptr); 01367 //double dist = cur_location.distance_between(eval_point); 01368 index = 3 * ii; 01369 xyzOnFace[index] = eval_point.x(); 01370 xyzOnFace[index+1] = eval_point.y(); 01371 xyzOnFace[index+2] = eval_point.z(); 01372 if (normal != NULL) 01373 { 01374 normal[index] = eval_normal.x(); 01375 normal[index+1] = eval_normal.y(); 01376 normal[index+2] = eval_normal.z(); 01377 } 01378 } 01379 01380 // no derivatives yet!! 01381 01382 // delete the temp arrays 01383 01384 for (ii=0; ii<numQuad; ii++) 01385 delete qfacet_array[ii]; 01386 for (ii=0; ii<numTri; ii++) 01387 delete facet_array[ii]; 01388 for (ii=0; ii<numEdge; ii++) 01389 delete edge_array[ii]; 01390 for (ii=0; ii<numVert; ii++) 01391 delete point_array[ii]; 01392 delete [] point_array; 01393 delete [] edge_array; 01394 if (facet_array) 01395 delete [] facet_array; 01396 if (qfacet_array) 01397 delete [] qfacet_array; 01398 } 01399 01400 //--------------------------------------------------------------------------- 01401 // Functions for debugging 01402 //--------------------------------------------------------------------------- 01403 01404 //=========================================================================== 01405 // Function: dumpMesh 01406 // Purpose: dump the face mesh to a file that can be read by CUBIT 01407 // Use the same definition of parameters as used with 01408 // resolveFaceVectors 01409 // Date: 10/28/2002 01410 // Author: sjowen 01411 //=========================================================================== 01412 void dumpMesh(const char *fileName, int includeResults, double angle, 01413 int numTri, int numQuad, int numEdge, 01414 int numVert, int* triEdge, int* quadEdge, 01415 int* edgeVert, double* vert, 01416 double* edgeCtrlPts, double* triCtrlPts, 01417 double* quadCtrlPts) 01418 { 01419 FILE *fp = fopen(fileName, "w"); 01420 assert(fp != NULL); // couldn't open file for writing 01421 01422 // write the header info 01423 01424 fprintf(fp, "Cholla version 1.0\n"); 01425 time_stamp( fp ); 01426 fprintf(fp, "%d %d %d %d %d\n", numTri, numQuad, numEdge, numVert, includeResults); 01427 fprintf(fp, "%f\n", angle); 01428 01429 // faceEdgeBegin 01430 01431 int ii; 01432 01433 // faceEdge 01434 01435 fprintf(fp, "triEdge\n"); 01436 for(ii=0; ii<numTri; ii++) 01437 { 01438 fprintf(fp, "%d %d %d\n", triEdge[ii*3], triEdge[ii*3+1], triEdge[ii*3+2]); 01439 } 01440 01441 fprintf(fp, "quadEdge\n"); 01442 for(ii=0; ii<numQuad; ii++) 01443 { 01444 fprintf(fp, "%d %d %d %d\n", quadEdge[ii*4], quadEdge[ii*4+1], 01445 quadEdge[ii*4+2], quadEdge[ii*4+3]); 01446 } 01447 01448 // edgeVert 01449 01450 fprintf(fp, "edgeVert\n"); 01451 for (ii=0; ii<numEdge; ii++) 01452 { 01453 fprintf(fp, "%d %d\n", edgeVert[ii*2], edgeVert[ii*2+1]); 01454 } 01455 01456 // vert 01457 01458 fprintf(fp, "vert\n"); 01459 for (ii=0; ii<numVert; ii++) 01460 { 01461 fprintf(fp, "%f %f %f\n", vert[ii*3], vert[ii*3+1], vert[ii*3+2]); 01462 } 01463 01464 if (includeResults != 0) 01465 { 01466 // edge control points 01467 01468 int jj; 01469 fprintf(fp, "edgeCtrlPts\n"); 01470 for(ii=0; ii<numEdge; ii++) 01471 { 01472 for (jj=0; jj<NUM_EDGE_CPTS; jj++) 01473 { 01474 fprintf(fp, "%f %f %f\n", edgeCtrlPts[ii*jj*3], 01475 edgeCtrlPts[ii*jj*3+1], 01476 edgeCtrlPts[ii*jj*3+2]); 01477 } 01478 } 01479 01480 // triangle control points 01481 01482 fprintf(fp, "triCtrlPts\n"); 01483 for(ii=0; ii<numTri; ii++) 01484 { 01485 for (jj=0; jj<NUM_TRI_CPTS; jj++) 01486 { 01487 fprintf(fp, "%f %f %f\n", triCtrlPts[ii*jj*3], 01488 triCtrlPts[ii*jj*3+1], 01489 triCtrlPts[ii*jj*3+2]); 01490 } 01491 } 01492 01493 // quad control points 01494 01495 fprintf(fp, "quadCtrlPts\n"); 01496 for(ii=0; ii<numQuad; ii++) 01497 { 01498 for (jj=0; jj<NUM_QUAD_CPTS; jj++) 01499 { 01500 fprintf(fp, "%f %f %f\n", quadCtrlPts[ii*jj*3], 01501 quadCtrlPts[ii*jj*3+1], 01502 quadCtrlPts[ii*jj*3+2]); 01503 } 01504 } 01505 } 01506 fclose(fp); 01507 } 01508 01509 //=========================================================================== 01510 // Function: dumpResults 01511 // Purpose: dump only the results to a file 01512 // Date: 10/28/2002 01513 // Author: sjowen 01514 //=========================================================================== 01515 void dumpResults(const char *fileName, int numEdge, int numTri, int numQuad, 01516 double* edgeCtrlPts, double* triCtrlPts, 01517 double* quadCtrlPts ) 01518 { 01519 FILE *fp = fopen( fileName, "w" ); 01520 assert(fp != NULL); 01521 01522 // write the header info 01523 01524 fprintf(fp, "Cholla version 1.0 Results\n"); 01525 time_stamp( fp ); 01526 fprintf(fp, "%d %d %d\n", numEdge, numTri, numQuad ); 01527 01528 int ii,jj; 01529 fprintf(fp, "edgeCtrlPts\n"); 01530 for(ii=0; ii<numEdge; ii++) 01531 { 01532 for (jj=0; jj<NUM_EDGE_CPTS; jj++) 01533 { 01534 fprintf(fp, "%f %f %f\n", edgeCtrlPts[ii*jj*3], 01535 edgeCtrlPts[ii*jj*3+1], 01536 edgeCtrlPts[ii*jj*3+2]); 01537 } 01538 } 01539 01540 // triangle control points 01541 01542 fprintf(fp, "triCtrlPts\n"); 01543 for(ii=0; ii<numTri; ii++) 01544 { 01545 for (jj=0; jj<NUM_TRI_CPTS; jj++) 01546 { 01547 fprintf(fp, "%f %f %f\n", triCtrlPts[ii*jj*3], 01548 triCtrlPts[ii*jj*3+1], 01549 triCtrlPts[ii*jj*3+2]); 01550 } 01551 } 01552 01553 // quad control points 01554 01555 fprintf(fp, "quadCtrlPts\n"); 01556 for(ii=0; ii<numQuad; ii++) 01557 { 01558 for (jj=0; jj<NUM_QUAD_CPTS; jj++) 01559 { 01560 fprintf(fp, "%f %f %f\n", quadCtrlPts[ii*jj*3], 01561 quadCtrlPts[ii*jj*3+1], 01562 quadCtrlPts[ii*jj*3+2]); 01563 } 01564 } 01565 01566 fclose(fp); 01567 } 01568 01569 //=========================================================================== 01570 // Function: importMesh 01571 // Purpose: import the face mesh from the specified file 01572 // allocate the arrays and pass them back 01573 // Date: 11/28/2002 01574 // Author: sjowen 01575 //=========================================================================== 01576 void importMesh(const char *fileName, int *includeResults, 01577 double *angle, int *numTri, int *numQuad, int *numEdge, 01578 int *numVert, int** triEdge, int** quadEdge, 01579 int** edgeVert, double** vert, 01580 double** edgeCtrlPts, double** triCtrlPts, 01581 double** quadCtrlPts) 01582 { 01583 FILE *fp = fopen(fileName, "r"); 01584 assert(fp != NULL); // couldn't open file for reading 01585 01586 // read the header info 01587 01588 char version[128]; 01589 char* s = fgets(version, 128, fp); 01590 if (NULL == s) { 01591 PRINT_ERROR("Format error in file %s\n", fileName); 01592 fclose(fp); 01593 return; 01594 } 01595 assert(strcmp(version, "Cholla version 1.0\n") == 0); // don't recognize file 01596 char filetime[128]; 01597 s = fgets(filetime, 128, fp); 01598 if (NULL == s) { 01599 PRINT_ERROR("Format error in file %s\n", fileName); 01600 fclose(fp); 01601 return; 01602 } 01603 01604 char line[256]; 01605 int num_tri; 01606 int num_quad; 01607 int num_edge; 01608 int num_vert; 01609 s = fgets(line,256,fp); 01610 if (NULL == s) { 01611 PRINT_ERROR("Format error in file %s\n", fileName); 01612 fclose(fp); 01613 return; 01614 } 01615 sscanf(line, "%d %d %d %d %d\n", &num_tri, &num_quad, &num_edge, &num_vert, includeResults); 01616 *numTri = num_tri; 01617 *numQuad = num_quad; 01618 *numEdge = num_edge; 01619 *numVert = num_vert; 01620 int nread = fscanf(fp, "%lf\n", angle); 01621 if (1 != nread) { 01622 PRINT_ERROR("Format error in file %s\n", fileName); 01623 fclose(fp); 01624 return; 01625 } 01626 01627 // triEdge 01628 01629 *triEdge = new int [num_tri*3]; 01630 int *tri_edge = *triEdge; 01631 char array_name[128]; 01632 nread = fscanf(fp, "%s\n", array_name); 01633 if (1 != nread) { 01634 PRINT_ERROR("Format error in file %s\n", fileName); 01635 fclose(fp); 01636 return; 01637 } 01638 assert(strcmp(array_name, "triEdge") == 0); // check start of array 01639 int ii; 01640 for(ii=0; ii<num_tri; ii++) 01641 { 01642 nread = fscanf(fp, "%d %d %d\n", &tri_edge[ii*3], &tri_edge[ii*3+1], &tri_edge[ii*3+2]); 01643 if (3 != nread) { 01644 PRINT_ERROR("Format error in file %s\n", fileName); 01645 fclose(fp); 01646 return; 01647 } 01648 } 01649 01650 // quadEdge 01651 01652 *quadEdge = new int [num_quad*4]; 01653 int *quad_edge = *quadEdge; 01654 nread = fscanf(fp, "%s\n", array_name); 01655 if (1 != nread) { 01656 PRINT_ERROR("Format error in file %s\n", fileName); 01657 fclose(fp); 01658 return; 01659 } 01660 assert(strcmp(array_name, "quadEdge") == 0); // check start of array 01661 for(ii=0; ii<num_quad; ii++) 01662 { 01663 nread = fscanf(fp, "%d %d %d %d\n", &quad_edge[ii*4], &quad_edge[ii*4+1], 01664 &quad_edge[ii*4+2], &quad_edge[ii*4+3]); 01665 if (4 != nread) { 01666 PRINT_ERROR("Format error in file %s\n", fileName); 01667 fclose(fp); 01668 return; 01669 } 01670 } 01671 01672 // edgeVert 01673 01674 *edgeVert = new int [2*num_edge]; 01675 int *edge_vert = *edgeVert; 01676 nread = fscanf(fp, "%s\n", array_name); 01677 if (1 != nread) { 01678 PRINT_ERROR("Format error in file %s\n", fileName); 01679 fclose(fp); 01680 return; 01681 } 01682 assert(strcmp(array_name, "edgeVert") == 0); // check start of array 01683 for (ii=0; ii<num_edge; ii++) 01684 { 01685 nread = fscanf(fp, "%d %d\n", &edge_vert[ii*2], &edge_vert[ii*2+1]); 01686 if (2 != nread) { 01687 PRINT_ERROR("Format error in file %s\n", fileName); 01688 fclose(fp); 01689 return; 01690 } 01691 } 01692 01693 // vert 01694 01695 *vert = new double [3*num_vert]; 01696 double *my_vert = *vert; 01697 nread = fscanf(fp, "%s\n", array_name); 01698 if (1 != nread) { 01699 PRINT_ERROR("Format error in file %s\n", fileName); 01700 fclose(fp); 01701 return; 01702 } 01703 assert(strcmp(array_name, "vert") == 0); // check start of array 01704 for (ii=0; ii<num_vert; ii++) 01705 { 01706 nread = fscanf(fp, "%lf %lf %lf\n", &my_vert[ii*3], &my_vert[ii*3+1], &my_vert[ii*3+2]); 01707 if (3 != nread) { 01708 PRINT_ERROR("Format error in file %s\n", fileName); 01709 fclose(fp); 01710 return; 01711 } 01712 } 01713 01714 *edgeCtrlPts = new double [3*num_edge*NUM_EDGE_CPTS]; 01715 if (numTri != 0) 01716 *triCtrlPts = new double [3*num_tri*NUM_TRI_CPTS]; 01717 if (numQuad != 0) 01718 *quadCtrlPts = new double [3*num_quad*NUM_QUAD_CPTS]; 01719 01720 double *edge_ctrl_pts = *edgeCtrlPts; 01721 double *tri_ctrl_pts = *triCtrlPts; 01722 double *quad_ctrl_pts = *quadCtrlPts; 01723 if (*includeResults != 0) 01724 { 01725 // edge control points 01726 01727 nread = fscanf(fp, "%s\n", array_name); 01728 if (1 != nread) { 01729 PRINT_ERROR("Format error in file %s\n", fileName); 01730 fclose(fp); 01731 return; 01732 } 01733 assert(strcmp(array_name, "edgeCtrlPts") == 0); // check start of array 01734 for(ii=0; ii<num_edge*NUM_EDGE_CPTS; ii++) 01735 { 01736 nread = fscanf(fp, "%lf %lf %lf\n", &edge_ctrl_pts[ii*3], 01737 &edge_ctrl_pts[ii*3+1], 01738 &edge_ctrl_pts[ii*3+2]); 01739 if (3 != nread) { 01740 PRINT_ERROR("Format error in file %s\n", fileName); 01741 fclose(fp); 01742 return; 01743 } 01744 } 01745 01746 // triangle control points 01747 01748 nread = fscanf(fp, "%s\n", array_name); 01749 if (1 != nread) { 01750 PRINT_ERROR("Format error in file %s\n", fileName); 01751 fclose(fp); 01752 return; 01753 } 01754 assert(strcmp(array_name, "triCtrlPts") == 0); // check start of array 01755 for(ii=0; ii<num_tri*NUM_TRI_CPTS; ii++) 01756 { 01757 nread = fscanf(fp, "%lf %lf %lf\n", &tri_ctrl_pts[ii*3], 01758 &tri_ctrl_pts[ii*3+1], 01759 &tri_ctrl_pts[ii*3+2]); 01760 if (3 != nread) { 01761 PRINT_ERROR("Format error in file %s\n", fileName); 01762 fclose(fp); 01763 return; 01764 } 01765 } 01766 01767 // quad control points 01768 01769 nread = fscanf(fp, "%s\n", array_name); 01770 if (1 != nread) { 01771 PRINT_ERROR("Format error in file %s\n", fileName); 01772 fclose(fp); 01773 return; 01774 } 01775 assert(strcmp(array_name, "quadCtrlPts") == 0); // check start of array 01776 for(ii=0; ii<num_quad*NUM_QUAD_CPTS; ii++) 01777 { 01778 nread = fscanf(fp, "%lf %lf %lf\n", &quad_ctrl_pts[ii*3], 01779 &quad_ctrl_pts[ii*3+1], 01780 &quad_ctrl_pts[ii*3+2]); 01781 if (3 != nread) { 01782 PRINT_ERROR("Format error in file %s\n", fileName); 01783 fclose(fp); 01784 return; 01785 } 01786 } 01787 01788 } 01789 fclose(fp); 01790 } 01791 01792 //=========================================================================== 01793 // Function: importResults 01794 // Purpose: import only the results to from a file 01795 // Note: allocates the normal and tangent arrays 01796 // Date: 10/28/2002 01797 // Author: sjowen 01798 //=========================================================================== 01799 void importResults(const char *fileName, int *numEdge, int *numTri, 01800 int *numQuad, double** edgeCtrlPts, double** triCtrlPts, 01801 double** quadCtrlPts ) 01802 { 01803 FILE *fp = fopen(fileName, "r"); 01804 assert(fp != NULL); // couldn't open file for reading 01805 01806 // read the header info 01807 01808 char version[128]; 01809 char* s = fgets(version, 128, fp); 01810 if (NULL == s) { 01811 PRINT_ERROR("Format error in file %s\n", fileName); 01812 fclose(fp); 01813 return; 01814 } 01815 assert(strcmp(version, "Cholla version 1.0 Results\n") == 0); // don't recognize file 01816 char filetime[128]; 01817 s = fgets(filetime, 128, fp); 01818 if (NULL == s) { 01819 PRINT_ERROR("Format error in mesh file %s\n", fileName); 01820 fclose(fp); 01821 return; 01822 } 01823 int nread = fscanf(fp, "%d %d %d\n", numEdge, numTri, numQuad); 01824 if (3 != nread) { 01825 PRINT_ERROR("Format error in file %s\n", fileName); 01826 fclose(fp); 01827 return; 01828 } 01829 int num_edge = *numEdge; 01830 int num_tri = *numTri; 01831 int num_quad = *numQuad; 01832 01833 *edgeCtrlPts = new double [3*num_edge*NUM_EDGE_CPTS]; 01834 if (numTri != 0) 01835 *triCtrlPts = new double [3*num_tri*NUM_TRI_CPTS]; 01836 if (numQuad != 0) 01837 *quadCtrlPts = new double [3*num_quad*NUM_QUAD_CPTS]; 01838 01839 double *edge_ctrl_pts = *edgeCtrlPts; 01840 double *tri_ctrl_pts = *triCtrlPts; 01841 double *quad_ctrl_pts = *quadCtrlPts; 01842 01843 // edge control points 01844 01845 int ii; 01846 char array_name[128]; 01847 nread = fscanf(fp, "%s\n", array_name); 01848 if (1 != nread) { 01849 PRINT_ERROR("Format error in file %s\n", fileName); 01850 fclose(fp); 01851 return; 01852 } 01853 assert(strcmp(array_name, "edgeCtrlPts") == 0); // check start of array 01854 for(ii=0; ii<num_edge*NUM_EDGE_CPTS; ii++) 01855 { 01856 nread = fscanf(fp, "%lf %lf %lf\n", &edge_ctrl_pts[ii*3], 01857 &edge_ctrl_pts[ii*3+1], 01858 &edge_ctrl_pts[ii*3+2]); 01859 if (3 != nread) { 01860 PRINT_ERROR("Format error in file %s\n", fileName); 01861 fclose(fp); 01862 return; 01863 } 01864 } 01865 01866 // triangle control points 01867 01868 nread = fscanf(fp, "%s\n", array_name); 01869 if (1 != nread) { 01870 PRINT_ERROR("Format error in file %s\n", fileName); 01871 fclose(fp); 01872 return; 01873 } 01874 assert(strcmp(array_name, "triCtrlPts") == 0); // check start of array 01875 for(ii=0; ii<num_tri*NUM_TRI_CPTS; ii++) 01876 { 01877 nread = fscanf(fp, "%lf %lf %lf\n", &tri_ctrl_pts[ii*3], 01878 &tri_ctrl_pts[ii*3+1], 01879 &tri_ctrl_pts[ii*3+2]); 01880 if (3 != nread) { 01881 PRINT_ERROR("Format error in file %s\n", fileName); 01882 fclose(fp); 01883 return; 01884 } 01885 } 01886 01887 // quad control points 01888 01889 nread = fscanf(fp, "%s\n", array_name); 01890 if (1 != nread) { 01891 PRINT_ERROR("Format error in file %s\n", fileName); 01892 fclose(fp); 01893 return; 01894 } 01895 assert(strcmp(array_name, "quadCtrlPts") == 0); // check start of array 01896 for(ii=0; ii<num_tri*NUM_QUAD_CPTS; ii++) 01897 { 01898 nread = fscanf(fp, "%lf %lf %lf\n", &quad_ctrl_pts[ii*3], 01899 &quad_ctrl_pts[ii*3+1], 01900 &quad_ctrl_pts[ii*3+2]); 01901 if (3 != nread) { 01902 PRINT_ERROR("Format error in file %s\n", fileName); 01903 fclose(fp); 01904 return; 01905 } 01906 } 01907 01908 fclose(fp); 01909 01910 } 01911 01912 //=========================================================================== 01913 // Function: time_stamp 01914 // Purpose: write the current time to a file 01915 // Date: 11/28/2002 01916 // Author: sjowen 01917 //=========================================================================== 01918 static void time_stamp( FILE *fp ) 01919 { 01920 struct tm *newtime; 01921 bool am = true; 01922 time_t long_time; 01923 01924 time( &long_time ); /* Get time as long integer. */ 01925 newtime = localtime( &long_time ); /* Convert to local time. */ 01926 01927 if( newtime->tm_hour > 12 ) /* Set up extension. */ 01928 am = false; 01929 if( newtime->tm_hour > 12 ) /* Convert from 24-hour */ 01930 newtime->tm_hour -= 12; /* to 12-hour clock. */ 01931 if( newtime->tm_hour == 0 ) /*Set hour to 12 if midnight. */ 01932 newtime->tm_hour = 12; 01933 01934 fprintf( fp, "%.19s %s\n", asctime( newtime ), am ? "AM" : "PM" ); 01935 } 01936 01937 //=========================================================================== 01938 // Function: evalBezierEdge 01939 // Purpose: Evaluate a quartic Bezier curve at a specified parametric 01940 // location given its control points. Evaluates location, and/or tangent. 01941 01942 // Date: 01/20/2004 01943 // Author: jfowler 01944 //=========================================================================== 01945 void evalBezierEdge( int numEdge, int numVert, int* edgeVert, 01946 double* vert, double* edgeCtrlPts, 01947 int numLocs, double* paramLocation, 01948 double* location, double* tangent ) 01949 { 01950 CubitPoint **point_array = new CubitPoint * [numVert]; 01951 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 01952 CubitFacet **facet_array = NULL; 01953 CubitQuadFacet **qfacet_array = NULL; 01954 DLIList<FacetEntity *> facet_list; 01955 int ii, index, numTri, numQuad; 01956 int *triEdge, *quadEdge; 01957 triEdge = quadEdge = NULL; 01958 numTri = numQuad = 0; 01959 CubitStatus stat = CUBIT_SUCCESS; 01960 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 01961 edgeVert, vert, point_array, edge_array, facet_array, 01962 qfacet_array, facet_list); 01963 if (CUBIT_SUCCESS != stat) { 01964 PRINT_ERROR("Failed to build facets.\n"); 01965 return; 01966 } 01967 01968 CubitFacetEdge *edge_ptr; 01969 // Set the control points on the edges. 01970 for (ii=0; ii<numEdge; ii++) 01971 { 01972 edge_ptr = edge_array[ii]; 01973 index = 3 * (ii * NUM_EDGE_CPTS); 01974 edge_ptr->set_control_points( &(edgeCtrlPts[index]) ); 01975 } 01976 01977 // do the evaluations 01978 int jj, tindex; 01979 index = tindex = 0; 01980 01981 for ( ii = 0; ii < numEdge; ii++ ) { 01982 for ( jj = 0; jj < numLocs; jj++ ) { 01983 01984 CubitVector eval_point; 01985 CubitVector *eval_point_ptr = &eval_point; 01986 CubitVector eval_tangent; 01987 CubitVector *eval_tangent_ptr = NULL; 01988 if ( tangent != NULL ) 01989 eval_tangent_ptr = &eval_tangent; 01990 edge_ptr = edge_array[ii]; 01991 edge_ptr->evaluate_single(paramLocation[jj],eval_point_ptr); 01992 location[index++] = eval_point.x(); 01993 location[index++] = eval_point.y(); 01994 location[index++] = eval_point.z(); 01995 if ( tangent != NULL ) { 01996 edge_ptr->evaluate_single_tangent(paramLocation[jj],eval_tangent_ptr); 01997 eval_tangent.normalize(); 01998 tangent[tindex++] = eval_tangent.x(); 01999 tangent[tindex++] = eval_tangent.y(); 02000 tangent[tindex++] = eval_tangent.z(); 02001 } 02002 } 02003 } 02004 // delete the temp arrays 02005 02006 for (ii=0; ii<numEdge; ii++) 02007 delete edge_array[ii]; 02008 for (ii=0; ii<numVert; ii++) 02009 delete point_array[ii]; 02010 delete [] point_array; 02011 delete [] edge_array; 02012 02013 } 02014 02015 //=========================================================================== 02016 // Function: evalBezierEdgeFromTans 02017 // Purpose: Evaluate a quartic Bezier curve at a specified parametric 02018 // location given its tangents at the end-points. Evaluates location, 02019 // and/or tangent. 02020 // Date: 01/20/2004 02021 // Author: jfowler 02022 //=========================================================================== 02023 void evalBezierEdgeFromTans( int numEdge, int numVert, int* edgeVert, 02024 double* vert, double* edgeVertTang, 02025 int numLocs, double* paramLocation, 02026 double* location, double* tangent ) 02027 { 02028 CubitPoint **point_array = new CubitPoint * [numVert]; 02029 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 02030 CubitFacet **facet_array = NULL; 02031 CubitQuadFacet **qfacet_array = NULL; 02032 DLIList<FacetEntity *> facet_list; 02033 int ii, index, numTri, numQuad; 02034 int *triEdge, *quadEdge; 02035 triEdge = quadEdge = NULL; 02036 numTri = numQuad = 0; 02037 CubitStatus stat = CUBIT_SUCCESS; 02038 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 02039 edgeVert, vert, point_array, edge_array, facet_array, 02040 qfacet_array, facet_list); 02041 if (CUBIT_SUCCESS != stat) { 02042 PRINT_ERROR("Failed to build facets.\n"); 02043 return; 02044 } 02045 02046 // set the control points on edges 02047 02048 int mydebug = 0; 02049 FILE *fp = NULL; 02050 if (mydebug) 02051 fp = fopen("edges.txt", "w"); 02052 CubitFacetEdge *edge_ptr; 02053 CubitVector T0, T1, P0, P1; 02054 CubitVector Pi[3]; 02055 CubitPoint *pt0, *pt1; 02056 for (ii=0; ii<numEdge; ii++) 02057 { 02058 index = 6 * ii; 02059 edge_ptr = edge_array[ii]; 02060 pt0 = edge_ptr->point(0); 02061 pt1 = edge_ptr->point(1); 02062 P0 = pt0->coordinates(); 02063 P1 = pt1->coordinates(); 02064 T0.x( edgeVertTang[ index ] ); 02065 T0.y( edgeVertTang[ index + 1] ); 02066 T0.z( edgeVertTang[ index + 2] ); 02067 T1.x( edgeVertTang[ index + 3] ); 02068 T1.y( edgeVertTang[ index + 4] ); 02069 T1.z( edgeVertTang[ index + 5] ); 02070 FacetEvalTool::init_edge_control_points_single(P0, P1, T0, T1, Pi); 02071 if (mydebug) 02072 { 02073 int kk; 02074 for(kk=0; kk<3; kk++); 02075 fprintf(fp, "(%d) %.6f %.6f %.6f\n", edge_ptr->id(), P0.x(), P0.y(), P0.z()); 02076 fprintf(fp, " %.6f %.6f %.6f\n", Pi[0].x(), Pi[0].y(), Pi[0].z()); 02077 fprintf(fp, " %.6f %.6f %.6f\n", Pi[1].x(), Pi[1].y(), Pi[1].z()); 02078 fprintf(fp, " %.6f %.6f %.6f\n", Pi[2].x(), Pi[2].y(), Pi[2].z()); 02079 fprintf(fp, " %.6f %.6f %.6f\n", P1.x(), P1.y(), P1.z()); 02080 } 02081 edge_ptr->control_points( Pi, 4 ); 02082 } 02083 if (mydebug) 02084 fclose(fp); 02085 02086 // do the evaluations 02087 int jj, tindex; 02088 index = tindex = 0; 02089 02090 for ( ii = 0; ii < numEdge; ii++ ) { 02091 for ( jj = 0; jj < numLocs; jj++ ) { 02092 02093 CubitVector eval_point; 02094 CubitVector *eval_point_ptr = &eval_point; 02095 CubitVector eval_tangent; 02096 CubitVector *eval_tangent_ptr = NULL; 02097 if ( tangent != NULL ) 02098 eval_tangent_ptr = &eval_tangent; 02099 edge_ptr = edge_array[ii]; 02100 edge_ptr->evaluate_single(paramLocation[jj],eval_point_ptr); 02101 location[index++] = eval_point.x(); 02102 location[index++] = eval_point.y(); 02103 location[index++] = eval_point.z(); 02104 if ( tangent != NULL ) { 02105 edge_ptr->evaluate_single_tangent(paramLocation[jj],eval_tangent_ptr); 02106 eval_tangent.normalize(); 02107 tangent[tindex++] = eval_tangent.x(); 02108 tangent[tindex++] = eval_tangent.y(); 02109 tangent[tindex++] = eval_tangent.z(); 02110 } 02111 } 02112 } 02113 // delete the temp arrays 02114 02115 for (ii=0; ii<numEdge; ii++) 02116 delete edge_array[ii]; 02117 for (ii=0; ii<numVert; ii++) 02118 delete point_array[ii]; 02119 delete [] point_array; 02120 delete [] edge_array; 02121 } 02122 02123 //=========================================================================== 02124 // Function: projBezierEdgeFromTans 02125 // Purpose: Project a point to an edge given tangents at the endpoints. 02126 // The routine only finds one point. Rarely there might be 02127 // two or more closest points. 02128 // Date: 01/20/2004 02129 // Author: jfowler 02130 //=========================================================================== 02131 void projToBezierEdgeFromTans( int numEdge, int numVert, int* edgeVert, 02132 double* vert, double* edgeVertTang, 02133 int numLocs, double* xyz, 02134 double* xyzOnEdge, double* tangent ) 02135 { 02136 CubitPoint **point_array = new CubitPoint * [numVert]; 02137 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 02138 CubitFacet **facet_array = NULL; 02139 CubitQuadFacet **qfacet_array = NULL; 02140 DLIList<FacetEntity *> facet_list; 02141 int ii, index, numTri, numQuad; 02142 int *triEdge, *quadEdge; 02143 triEdge = quadEdge = NULL; 02144 numTri = numQuad = 0; 02145 CubitStatus stat = CUBIT_SUCCESS; 02146 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 02147 edgeVert, vert, point_array, edge_array, facet_array, 02148 qfacet_array, facet_list); 02149 if (CUBIT_SUCCESS != stat) { 02150 PRINT_ERROR("Failed to build facets.\n"); 02151 return; 02152 } 02153 02154 // set the control points on edges 02155 02156 CubitFacetEdge *edge_ptr; 02157 CubitVector T0, T1, P0, P1; 02158 CubitVector Pi[3]; 02159 CubitPoint *pt0, *pt1; 02160 for (ii=0; ii<numEdge; ii++) 02161 { 02162 index = 6 * ii; 02163 edge_ptr = edge_array[ii]; 02164 pt0 = edge_ptr->point(0); 02165 pt1 = edge_ptr->point(1); 02166 P0 = pt0->coordinates(); 02167 P1 = pt1->coordinates(); 02168 T0.x( edgeVertTang[ index ] ); 02169 T0.y( edgeVertTang[ index + 1] ); 02170 T0.z( edgeVertTang[ index + 2] ); 02171 T1.x( edgeVertTang[ index + 3] ); 02172 T1.y( edgeVertTang[ index + 4] ); 02173 T1.z( edgeVertTang[ index + 5] ); 02174 FacetEvalTool::init_edge_control_points_single(P0, P1, T0, T1, Pi); 02175 02176 edge_ptr->control_points( Pi, 4 ); 02177 } 02178 02179 // do the projections 02180 int jj, kk, xyzindex, tindex; 02181 index = tindex = 0; 02182 double dsquared, dsquared_test, dderiv, dderiv2, t, t_min = 0.0; 02183 CubitVector xyz_pt;//, second_d; 02184 t = 0.0; 02185 dsquared_test = CUBIT_DBL_MAX; 02186 for ( ii = 0; ii < numEdge; ii++ ) { 02187 edge_ptr = edge_array[ii]; 02188 for ( jj = 0; jj < numLocs; jj++ ) { 02189 xyzindex = 3*jj; 02190 xyz_pt.x(xyz[xyzindex]); 02191 xyz_pt.y(xyz[xyzindex+1]); 02192 xyz_pt.z(xyz[xyzindex+2]); 02193 t = -1.0; 02194 dsquared_test = CUBIT_DBL_MAX; 02195 // Get square of distance from xyz to curve at intervals of 0.2 02196 // in the parameter t. Save the closest distance found as a 02197 // starting point for Newton-Raphson iterations. It was found 02198 // that an interval of 0.5 was too coarse and that the N-R 02199 // sometimes converged on a false value. 02200 CubitVector eval_point; 02201 CubitVector *eval_point_ptr = &eval_point; 02202 CubitVector eval_tangent; 02203 CubitVector *eval_tangent_ptr = &eval_tangent; 02204 CubitVector second_d; 02205 CubitVector *second_d_ptr = &second_d; 02206 for ( kk = 0; kk < 11; kk++ ) { 02207 edge_ptr->evaluate_single(t,eval_point_ptr); 02208 dsquared = ( (xyz_pt.x()-eval_point.x())*(xyz_pt.x()-eval_point.x()) + 02209 (xyz_pt.y()-eval_point.y())*(xyz_pt.y()-eval_point.y()) + 02210 (xyz_pt.z()-eval_point.z())*(xyz_pt.z()-eval_point.z()) ); 02211 if ( fabs(dsquared) < fabs(dsquared_test) ) { 02212 t_min = t; 02213 dsquared_test = dsquared; 02214 } 02215 t += 0.2; 02216 } 02217 double dderiva, dderivb; 02218 if ( t_min == -1.00 ) { 02219 // Check whether the slope changed signs between -1.0 and -0.8. 02220 // If so, the min must have occurred in this interval -- set 02221 // t_min to -0.9. 02222 t = -1.0; 02223 edge_ptr->evaluate_single(t,eval_point_ptr); 02224 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02225 dderiva = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02226 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02227 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02228 t = -0.8; 02229 edge_ptr->evaluate_single(t,eval_point_ptr); 02230 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02231 dderivb = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02232 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02233 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02234 if ( dderiva*dderivb < 0.0 ) t_min = -0.9; 02235 02236 } else if ( t_min == 1.00 ) { 02237 // Check the other end of the range, similarly. 02238 t = 1.0; 02239 edge_ptr->evaluate_single(t,eval_point_ptr); 02240 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02241 dderiva = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02242 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02243 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02244 t = 0.8; 02245 edge_ptr->evaluate_single(t,eval_point_ptr); 02246 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02247 dderivb = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02248 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02249 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02250 if ( dderiva*dderivb < 0.0 ) t_min = 0.9; 02251 } 02252 t = t_min; 02253 if ( (t > -1.0) && (t < 1.0) ) { 02254 int mm; 02255 mm = 0; 02256 while ( mm < 10 ) { // to avoid possible infinite loop 02257 mm++; 02258 edge_ptr->evaluate_single(t,eval_point_ptr); 02259 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02260 dderiv = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02261 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02262 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02263 02264 edge_ptr->evaluate_2nd_derivative(t, second_d_ptr); 02265 02266 dderiv2 = (eval_point.x()-xyz_pt.x())*second_d.x() + 02267 eval_tangent.x()*eval_tangent.x() + 02268 (eval_point.y()-xyz_pt.y())*second_d.y() + 02269 eval_tangent.y()*eval_tangent.y() + 02270 (eval_point.z()-xyz_pt.z())*second_d.z() + 02271 eval_tangent.z()*eval_tangent.z(); 02272 02273 t = t - dderiv/dderiv2; // Newton-Raphson 02274 02275 if ( t < -1.0 ) { 02276 t = -1.0; 02277 edge_ptr->evaluate_single(t,eval_point_ptr); 02278 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02279 break; 02280 } 02281 if ( t > 1.0 ) { 02282 t = 1.0; 02283 edge_ptr->evaluate_single(t,eval_point_ptr); 02284 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02285 break; 02286 } 02287 if ( fabs(dderiv) < 1.e-11 ) break; 02288 } 02289 } else { // At an endpoint of the paramaterization. 02290 edge_ptr->evaluate_single(t,eval_point_ptr); 02291 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02292 } 02293 xyzOnEdge[index++] = eval_point.x(); 02294 xyzOnEdge[index++] = eval_point.y(); 02295 xyzOnEdge[index++] = eval_point.z(); 02296 if ( tangent != NULL ) { 02297 eval_tangent.normalize(); 02298 tangent[tindex++] = eval_tangent.x(); 02299 tangent[tindex++] = eval_tangent.y(); 02300 tangent[tindex++] = eval_tangent.z(); 02301 } 02302 } 02303 } 02304 02305 // delete the temp arrays 02306 02307 for (ii=0; ii<numEdge; ii++) 02308 delete edge_array[ii]; 02309 for (ii=0; ii<numVert; ii++) 02310 delete point_array[ii]; 02311 delete [] point_array; 02312 delete [] edge_array; 02313 02314 } 02315 02316 02317 //=========================================================================== 02318 // Function: projBezierEdge 02319 // Purpose: Project a point to an edge. 02320 // The routine only finds one point. Rarely there might be 02321 // two or more closest points. 02322 // Date: 01/20/2004 02323 // Author: jfowler 02324 //=========================================================================== 02325 void projToBezierEdge( int numEdge, int numVert, int* edgeVert, 02326 double* vert, double* edgeCtrlPts, 02327 int numLocs, double* xyz, 02328 double* xyzOnEdge, double* tangent, double* t_value ) 02329 { 02330 CubitPoint **point_array = new CubitPoint * [numVert]; 02331 CubitFacetEdge **edge_array = new CubitFacetEdge * [numEdge]; 02332 CubitFacet **facet_array = NULL; 02333 CubitQuadFacet **qfacet_array = NULL; 02334 DLIList<FacetEntity *> facet_list; 02335 int ii, index, numTri, numQuad; 02336 int *triEdge, *quadEdge; 02337 triEdge = quadEdge = NULL; 02338 numTri = numQuad = 0; 02339 CubitStatus stat = CUBIT_SUCCESS; 02340 stat = build_facets(numTri, numQuad, numEdge, numVert, triEdge, quadEdge, 02341 edgeVert, vert, point_array, edge_array, facet_array, 02342 qfacet_array, facet_list); 02343 if (CUBIT_SUCCESS != stat) { 02344 PRINT_ERROR("Failed to build facets.\n"); 02345 return; 02346 } 02347 02348 // set the control points on edges 02349 02350 CubitFacetEdge *edge_ptr; 02351 //CubitVector T0, T1, P0, P1; 02352 //CubitVector Pi[3]; 02353 02354 for (ii=0; ii<numEdge; ii++) 02355 { 02356 edge_ptr = edge_array[ii]; 02357 index = 3 * (ii * NUM_EDGE_CPTS); 02358 edge_ptr->set_control_points( &(edgeCtrlPts[index]) ); 02359 } 02360 02361 // do the projections 02362 int jj, kk, xyzindex, tindex; 02363 index = tindex = 0; 02364 double dsquared, dsquared_test, dderiv, dderiv2, t, t_min = 0.0; 02365 CubitVector xyz_pt;//, second2142_d; 02366 t = 0.0; 02367 dsquared_test = CUBIT_DBL_MAX; 02368 for ( ii = 0; ii < numEdge; ii++ ) { 02369 edge_ptr = edge_array[ii]; 02370 for ( jj = 0; jj < numLocs; jj++ ) { 02371 xyzindex = 3*jj; 02372 xyz_pt.x(xyz[xyzindex]); 02373 xyz_pt.y(xyz[xyzindex+1]); 02374 xyz_pt.z(xyz[xyzindex+2]); 02375 t = -1.0; 02376 dsquared_test = CUBIT_DBL_MAX; 02377 // Get square of distance from xyz to curve at intervals of 0.2 02378 // in the parameter t. Save the closest distance found as a 02379 // starting point for Newton-Raphson iterations. It was found 02380 // that an interval of 0.5 was too coarse and that the N-R 02381 // sometimes converged on a false value. 02382 CubitVector eval_point; 02383 CubitVector *eval_point_ptr = &eval_point; 02384 CubitVector eval_tangent; 02385 CubitVector *eval_tangent_ptr = &eval_tangent; 02386 CubitVector second_d; 02387 CubitVector *second_d_ptr = &second_d; 02388 for ( kk = 0; kk < 11; kk++ ) { 02389 edge_ptr->evaluate_single(t,eval_point_ptr); 02390 dsquared = ( (xyz_pt.x()-eval_point.x())*(xyz_pt.x()-eval_point.x()) + 02391 (xyz_pt.y()-eval_point.y())*(xyz_pt.y()-eval_point.y()) + 02392 (xyz_pt.z()-eval_point.z())*(xyz_pt.z()-eval_point.z()) ); 02393 if ( fabs(dsquared) < fabs(dsquared_test) ) { 02394 t_min = t; 02395 dsquared_test = dsquared; 02396 } 02397 t += 0.2; 02398 } 02399 double dderiva, dderivb; 02400 if ( t_min == -1.00 ) { 02401 // Check whether the slope changed signs between -1.0 and -0.8. 02402 // If so, the min must have occurred in this interval -- set 02403 // t_min to -0.9. 02404 t = -1.0; 02405 edge_ptr->evaluate_single(t,eval_point_ptr); 02406 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02407 dderiva = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02408 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02409 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02410 t = -0.8; 02411 edge_ptr->evaluate_single(t,eval_point_ptr); 02412 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02413 dderivb = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02414 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02415 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02416 if ( dderiva*dderivb < 0.0 ) t_min = -0.9; 02417 02418 } else if ( t_min == 1.00 ) { 02419 // Check the other end of the range, similarly. 02420 t = 1.0; 02421 edge_ptr->evaluate_single(t,eval_point_ptr); 02422 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02423 dderiva = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02424 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02425 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02426 t = 0.8; 02427 edge_ptr->evaluate_single(t,eval_point_ptr); 02428 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02429 dderivb = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02430 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02431 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02432 if ( dderiva*dderivb < 0.0 ) t_min = 0.9; 02433 } 02434 t = t_min; 02435 if ( (t > -1.0) && (t < 1.0) ) { 02436 int mm; 02437 mm = 0; 02438 while ( mm < 10 ) { // to avoid possible infinite loop 02439 mm++; 02440 edge_ptr->evaluate_single(t,eval_point_ptr); 02441 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02442 dderiv = 2.0*( (eval_point.x()-xyz_pt.x())*eval_tangent.x() + 02443 (eval_point.y()-xyz_pt.y())*eval_tangent.y() + 02444 (eval_point.z()-xyz_pt.z())*eval_tangent.z() ); 02445 02446 edge_ptr->evaluate_2nd_derivative(t, second_d_ptr); 02447 02448 dderiv2 = (eval_point.x()-xyz_pt.x())*second_d.x() + 02449 eval_tangent.x()*eval_tangent.x() + 02450 (eval_point.y()-xyz_pt.y())*second_d.y() + 02451 eval_tangent.y()*eval_tangent.y() + 02452 (eval_point.z()-xyz_pt.z())*second_d.z() + 02453 eval_tangent.z()*eval_tangent.z(); 02454 02455 t = t - dderiv/dderiv2; // Newton-Raphson 02456 02457 if ( t < -1.0 ) { 02458 t = -1.0; 02459 edge_ptr->evaluate_single(t,eval_point_ptr); 02460 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02461 break; 02462 } 02463 if ( t > 1.0 ) { 02464 t = 1.0; 02465 edge_ptr->evaluate_single(t,eval_point_ptr); 02466 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02467 break; 02468 } 02469 if ( fabs(dderiv) < 1.e-11 ) break; 02470 } 02471 } else { // At an endpoint of the paramaterization. 02472 edge_ptr->evaluate_single(t,eval_point_ptr); 02473 edge_ptr->evaluate_single_tangent(t,eval_tangent_ptr); 02474 } 02475 xyzOnEdge[index++] = eval_point.x(); 02476 xyzOnEdge[index++] = eval_point.y(); 02477 xyzOnEdge[index++] = eval_point.z(); 02478 if ( tangent != NULL ) { 02479 eval_tangent.normalize(); 02480 tangent[tindex++] = eval_tangent.x(); 02481 tangent[tindex++] = eval_tangent.y(); 02482 tangent[tindex++] = eval_tangent.z(); 02483 } 02484 } 02485 } 02486 02487 *t_value = t; 02488 02489 // delete the temp arrays 02490 02491 for (ii=0; ii<numEdge; ii++) 02492 delete edge_array[ii]; 02493 for (ii=0; ii<numVert; ii++) 02494 delete point_array[ii]; 02495 delete [] point_array; 02496 delete [] edge_array; 02497 02498 } 02499 02500 //=========================================================================== 02501 // Function: constructQuadNormalsFromFile 02502 // Purpose: Similar to constructQuadNormals, except that instead of 02503 // approximating the surface normals and tangents from the input 02504 // facets, the normals and derivatives are extracted from a file 02505 // that was exported from Cubit along with the exodus file. The 02506 // purpose for this is that Cubit will have the exact surface 02507 // normals and tangents, instead of the approximations from the 02508 // geometry. 02509 // Date: 08/31/2004 02510 // Author: mlstate 02511 //=========================================================================== 02512 CubitStatus constructQuadNormalsFromFile( const char *filename, 02513 int numQuad, 02514 int numEdge, 02515 int* quadEdge, 02516 int* edgeVert, 02517 double* quadVertNorms, 02518 double* edgeVertTang ) 02519 { 02520 CubitStatus status = CUBIT_SUCCESS; 02521 int num_file_quads = 0, 02522 num_file_edges = 0, 02523 *edge_nodes_file = NULL, 02524 *quad_nodes_file = NULL; 02525 double *edge_node_tangs_file = NULL, 02526 *quad_node_norms_file = NULL; 02527 02528 status = readMBGNormalFile( filename, 02529 NULL, 02530 &num_file_quads, 02531 &num_file_edges, 02532 &edge_nodes_file, 02533 &edge_node_tangs_file, 02534 NULL, 02535 NULL, 02536 &quad_nodes_file, 02537 &quad_node_norms_file ); 02538 02539 if ( status == CUBIT_SUCCESS && numEdge > 0 ) 02540 { 02541 status = extractEdgeTangsFromFile( num_file_edges, 02542 edge_nodes_file, 02543 edge_node_tangs_file, 02544 numEdge, 02545 edgeVert, 02546 edgeVertTang ); 02547 } 02548 if ( status == CUBIT_SUCCESS && numQuad > 0 ) 02549 { 02550 status = extractQuadNormalsFromFile( num_file_quads, 02551 quad_nodes_file, 02552 quad_node_norms_file, 02553 numQuad, 02554 edgeVert, 02555 quadEdge, 02556 quadVertNorms ); 02557 } 02558 02559 delete [] edge_nodes_file; 02560 delete [] quad_nodes_file; 02561 delete [] edge_node_tangs_file; 02562 delete [] quad_node_norms_file; 02563 return status; 02564 } 02565 02566 //=========================================================================== 02567 // Function: constructTriNormalsFromFile 02568 // Purpose: Similar to constructTriNormals, except that instead of 02569 // approximating the surface normals and tangents from the input 02570 // facets, the normals and derivatives are extracted from a file 02571 // that was exported from Cubit along with the exodus file. The 02572 // purpose for this is that Cubit will have the exact surface 02573 // normals and tangents, instead of the approximations from the 02574 // geometry. 02575 // Date: 08/31/2004 02576 // Author: mlstate 02577 //=========================================================================== 02578 CubitStatus constructTriNormalsFromFile( const char *filename, 02579 int numTri, 02580 int numEdge, 02581 int* triEdge, 02582 int* edgeVert, 02583 double* triVertNorms, 02584 double* edgeVertTang ) 02585 { 02586 CubitStatus status = CUBIT_SUCCESS; 02587 int num_file_tris = 0, 02588 num_file_edges = 0, 02589 *edge_nodes_file = NULL, 02590 *tri_nodes_file = NULL; 02591 double *edge_node_tangs_file = NULL, 02592 *tri_node_norms_file = NULL; 02593 02594 status = readMBGNormalFile( filename, 02595 &num_file_tris, 02596 NULL, 02597 &num_file_edges, 02598 &edge_nodes_file, 02599 &edge_node_tangs_file, 02600 &tri_nodes_file, 02601 &tri_node_norms_file, 02602 NULL, 02603 NULL ); 02604 02605 if ( status == CUBIT_SUCCESS && numEdge > 0 ) 02606 { 02607 status = extractEdgeTangsFromFile( num_file_edges, 02608 edge_nodes_file, 02609 edge_node_tangs_file, 02610 numEdge, 02611 edgeVert, 02612 edgeVertTang ); 02613 } 02614 if ( status == CUBIT_SUCCESS && numTri > 0 ) 02615 { 02616 status = extractTriNormalsFromFile( num_file_tris, 02617 tri_nodes_file, 02618 tri_node_norms_file, 02619 numTri, 02620 edgeVert, 02621 triEdge, 02622 triVertNorms ); 02623 } 02624 02625 delete [] edge_nodes_file; 02626 delete [] tri_nodes_file; 02627 delete [] edge_node_tangs_file; 02628 delete [] tri_node_norms_file; 02629 return status; 02630 } 02631 02632 //=========================================================================== 02633 // Function: extractEdgeTangsFromFile 02634 // Purpose: extract from the file the edge tangents. 02635 // Date: 08/31/2004 02636 // Author: mlstate 02637 //=========================================================================== 02638 static CubitStatus extractEdgeTangsFromFile 02639 ( 02640 int num_file_edges, 02641 int *edge_nodes_file, 02642 double *edge_node_tangs_file, 02643 int numEdge, 02644 int *edgeVert, 02645 double *edgeVertTang 02646 ) 02647 { 02648 #define MIN_EDGE_NODE_ID( n1, n2 ) n1 < n2 ? n1 : n2 02649 CubitStatus status = CUBIT_SUCCESS; 02650 DLIList<int *> *edge_hash = new DLIList<int*> [num_file_edges]; 02651 int * edge_data = new int [num_file_edges * 3 ]; 02652 02653 int i; 02654 02655 for ( i = 0; i < num_file_edges; i++ ) 02656 { 02657 int *data = &(edge_data[i*3]); 02658 02659 data[0] = edge_nodes_file[i*2]; 02660 data[1] = edge_nodes_file[i*2 + 1]; 02661 data[2] = i; 02662 02663 int key = MIN_EDGE_NODE_ID( data[0], data[1] ); 02664 key %= num_file_edges; 02665 edge_hash[key].append( data ); 02666 } 02667 02668 for ( i = 0; i < numEdge; i++ ) 02669 { 02670 CubitBoolean found = CUBIT_FALSE; 02671 int *this_edge = &(edgeVert[i*2]); 02672 int key = MIN_EDGE_NODE_ID( this_edge[0], this_edge[1] ); 02673 key %= num_file_edges; 02674 for ( int j = 0; j < edge_hash[key].size(); j++ ) 02675 { 02676 int *data = edge_hash[key].get_and_step(); 02677 if ( data[0] == this_edge[0] && 02678 data[1] == this_edge[1] ) 02679 { 02680 edgeVertTang[ i*2*3 ] = edge_node_tangs_file[ data[2] * 2 * 3 ]; 02681 edgeVertTang[ i*2*3 + 1 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 1 ]; 02682 edgeVertTang[ i*2*3 + 2 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 2 ]; 02683 edgeVertTang[ i*2*3 + 3 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 3 ]; 02684 edgeVertTang[ i*2*3 + 4 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 4 ]; 02685 edgeVertTang[ i*2*3 + 5 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 5 ]; 02686 found = CUBIT_TRUE; 02687 break; 02688 } 02689 else if ( data[0] == this_edge[1] && 02690 data[1] == this_edge[0] ) 02691 { 02692 edgeVertTang[ i*2*3 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 3 ]; 02693 edgeVertTang[ i*2*3 + 1 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 4 ]; 02694 edgeVertTang[ i*2*3 + 2 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 5 ]; 02695 edgeVertTang[ i*2*3 + 3 ] = edge_node_tangs_file[ data[2] * 2 * 3 ]; 02696 edgeVertTang[ i*2*3 + 4 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 1 ]; 02697 edgeVertTang[ i*2*3 + 5 ] = edge_node_tangs_file[ data[2] * 2 * 3 + 2 ]; 02698 found = CUBIT_TRUE; 02699 break; 02700 } 02701 } 02702 if ( found == CUBIT_FALSE ) 02703 { 02704 status = CUBIT_FAILURE; 02705 break; 02706 } 02707 } 02708 delete [] edge_data; 02709 delete [] edge_hash; 02710 02711 return status; 02712 } 02713 02714 //=========================================================================== 02715 // Function: extractTriNormalsFromFile 02716 // Purpose: extract from the file the normals for a block of tri elements. 02717 // Date: 08/31/2004 02718 // Author: mlstate 02719 //=========================================================================== 02720 static CubitStatus extractTriNormalsFromFile 02721 ( 02722 int num_file_tris, 02723 int *tri_nodes_file, 02724 double *tri_node_norms_file, 02725 int numTri, 02726 int *edgeVert, 02727 int *triEdge, 02728 double *triVertNorms 02729 ) 02730 { 02731 #define MIN_TRI_NODE_ID( n1, n2, n3 ) n1 < n2 ? n1 < n3 ? n1 : n3 : n2 < n3 ? n2 : n3 02732 02733 CubitStatus status = CUBIT_SUCCESS; 02734 DLIList< int* > *tri_hash = new DLIList< int*>[num_file_tris]; 02735 int * tri_data = new int [num_file_tris * 4 ]; 02736 02737 int i; 02738 02739 for ( i = 0; i < num_file_tris; i++ ) 02740 { 02741 int *data = &(tri_data[i*4]); 02742 02743 data[0] = tri_nodes_file[i*3]; 02744 data[1] = tri_nodes_file[i*3 + 1]; 02745 data[2] = tri_nodes_file[i*3 + 2]; 02746 data[3] = i; 02747 02748 int key = MIN_TRI_NODE_ID( data[0], data[1], data[2] ); 02749 key %= num_file_tris; 02750 tri_hash[key].append( data ); 02751 } 02752 02753 for ( i = 0; i < numTri; i++ ) 02754 { 02755 CubitBoolean found = CUBIT_FALSE; 02756 int this_tri[3]; 02757 02758 constructTriVerts( &triEdge[i*3], edgeVert, this_tri ); 02759 02760 int key = MIN_TRI_NODE_ID( this_tri[0], this_tri[1], this_tri[2] ); 02761 key %= num_file_tris; 02762 for ( int j = 0; j < tri_hash[key].size(); j++ ) 02763 { 02764 int *data = tri_hash[key].get_and_step(); 02765 02766 if ( this_tri[0] == data[0] && 02767 this_tri[1] == data[1] && 02768 this_tri[2] == data[2] ) 02769 { 02770 triVertNorms[ i*3*3 ] = tri_node_norms_file[ data[3]*3*3 ]; 02771 triVertNorms[ i*3*3 + 1 ] = tri_node_norms_file[ data[3]*3*3 + 1 ]; 02772 triVertNorms[ i*3*3 + 2 ] = tri_node_norms_file[ data[3]*3*3 + 2 ]; 02773 triVertNorms[ i*3*3 + 3 ] = tri_node_norms_file[ data[3]*3*3 + 3 ]; 02774 triVertNorms[ i*3*3 + 4 ] = tri_node_norms_file[ data[3]*3*3 + 4 ]; 02775 triVertNorms[ i*3*3 + 5 ] = tri_node_norms_file[ data[3]*3*3 + 5 ]; 02776 triVertNorms[ i*3*3 + 6 ] = tri_node_norms_file[ data[3]*3*3 + 6 ]; 02777 triVertNorms[ i*3*3 + 7 ] = tri_node_norms_file[ data[3]*3*3 + 7 ]; 02778 triVertNorms[ i*3*3 + 8 ] = tri_node_norms_file[ data[3]*3*3 + 8 ]; 02779 found = CUBIT_TRUE; 02780 break; 02781 } 02782 else if ( this_tri[0] == data[1] && 02783 this_tri[1] == data[2] && 02784 this_tri[2] == data[0] ) 02785 { 02786 triVertNorms[ i*3*3 ] = tri_node_norms_file[ data[3]*3*3 + 3 ]; 02787 triVertNorms[ i*3*3 + 1 ] = tri_node_norms_file[ data[3]*3*3 + 4 ]; 02788 triVertNorms[ i*3*3 + 2 ] = tri_node_norms_file[ data[3]*3*3 + 5 ]; 02789 triVertNorms[ i*3*3 + 3 ] = tri_node_norms_file[ data[3]*3*3 + 6 ]; 02790 triVertNorms[ i*3*3 + 4 ] = tri_node_norms_file[ data[3]*3*3 + 7 ]; 02791 triVertNorms[ i*3*3 + 5 ] = tri_node_norms_file[ data[3]*3*3 + 8 ]; 02792 triVertNorms[ i*3*3 + 6 ] = tri_node_norms_file[ data[3]*3*3 ]; 02793 triVertNorms[ i*3*3 + 7 ] = tri_node_norms_file[ data[3]*3*3 + 1 ]; 02794 triVertNorms[ i*3*3 + 8 ] = tri_node_norms_file[ data[3]*3*3 + 2 ]; 02795 found = CUBIT_TRUE; 02796 break; 02797 } 02798 else if ( this_tri[0] == data[2] && 02799 this_tri[1] == data[0] && 02800 this_tri[2] == data[1] ) 02801 { 02802 triVertNorms[ i*3*3 ] = tri_node_norms_file[ data[3]*3*3 + 6 ]; 02803 triVertNorms[ i*3*3 + 1 ] = tri_node_norms_file[ data[3]*3*3 + 7 ]; 02804 triVertNorms[ i*3*3 + 2 ] = tri_node_norms_file[ data[3]*3*3 + 8 ]; 02805 triVertNorms[ i*3*3 + 3 ] = tri_node_norms_file[ data[3]*3*3 ]; 02806 triVertNorms[ i*3*3 + 4 ] = tri_node_norms_file[ data[3]*3*3 + 1 ]; 02807 triVertNorms[ i*3*3 + 5 ] = tri_node_norms_file[ data[3]*3*3 + 2 ]; 02808 triVertNorms[ i*3*3 + 6 ] = tri_node_norms_file[ data[3]*3*3 + 3 ]; 02809 triVertNorms[ i*3*3 + 7 ] = tri_node_norms_file[ data[3]*3*3 + 4 ]; 02810 triVertNorms[ i*3*3 + 8 ] = tri_node_norms_file[ data[3]*3*3 + 5 ]; 02811 found = CUBIT_TRUE; 02812 break; 02813 } 02814 } 02815 if ( found == CUBIT_FALSE ) 02816 { 02817 status = CUBIT_FAILURE; 02818 break; 02819 } 02820 } 02821 02822 delete [] tri_data; 02823 delete [] tri_hash; 02824 return status; 02825 } 02826 02827 //=========================================================================== 02828 // Function: extractQuadNormalsFromFile 02829 // Purpose: extract from the file the normals for a block of quad elements. 02830 // Date: 08/31/2004 02831 // Author: mlstate 02832 //=========================================================================== 02833 static CubitStatus extractQuadNormalsFromFile 02834 ( 02835 int num_file_quads, 02836 int *quad_nodes_file, 02837 double *quad_node_norms_file, 02838 int numQuad, 02839 int *edgeVert, 02840 int *quadEdge, 02841 double *quadVertNorms 02842 ) 02843 { 02844 #define MIN_QUAD_NODE_ID( n1, n2, n3, n4 ) MIN_EDGE_NODE_ID( (MIN_EDGE_NODE_ID( n1, n2 )), (MIN_EDGE_NODE_ID( n3, n4 )) ) 02845 02846 CubitStatus status = CUBIT_SUCCESS; 02847 DLIList< int* > *quad_hash = new DLIList< int*>[num_file_quads]; 02848 int * quad_data = new int [num_file_quads * 5 ]; 02849 02850 int i; 02851 for ( i = 0; i < num_file_quads; i++ ) 02852 { 02853 int *data = &(quad_data[i*5]); 02854 02855 data[0] = quad_nodes_file[i*4]; 02856 data[1] = quad_nodes_file[i*4 + 1]; 02857 data[2] = quad_nodes_file[i*4 + 2]; 02858 data[3] = quad_nodes_file[i*4 + 3]; 02859 data[4] = i; 02860 02861 int key = MIN_QUAD_NODE_ID( data[0], data[1], data[2], data[3] ); 02862 key %= num_file_quads; 02863 quad_hash[key].append( data ); 02864 } 02865 02866 for ( i = 0; i < numQuad; i++ ) 02867 { 02868 CubitBoolean found = CUBIT_FALSE; 02869 int this_quad[4]; 02870 02871 constructQuadVerts( &quadEdge[i*4], edgeVert, this_quad ); 02872 02873 int key = MIN_QUAD_NODE_ID( this_quad[0], this_quad[1], this_quad[2], this_quad[3] ); 02874 key %= num_file_quads; 02875 for ( int j = 0; j < quad_hash[key].size(); j++ ) 02876 { 02877 int *data = quad_hash[key].get_and_step(); 02878 02879 if ( this_quad[0] == data[0] && 02880 this_quad[1] == data[1] && 02881 this_quad[2] == data[2] && 02882 this_quad[3] == data[3] ) 02883 { 02884 quadVertNorms[ i*4*3 ] = quad_node_norms_file[ data[4]*4*3 ]; 02885 quadVertNorms[ i*4*3 + 1 ] = quad_node_norms_file[ data[4]*4*3 + 1 ]; 02886 quadVertNorms[ i*4*3 + 2 ] = quad_node_norms_file[ data[4]*4*3 + 2 ]; 02887 quadVertNorms[ i*4*3 + 3 ] = quad_node_norms_file[ data[4]*4*3 + 3 ]; 02888 quadVertNorms[ i*4*3 + 4 ] = quad_node_norms_file[ data[4]*4*3 + 4 ]; 02889 quadVertNorms[ i*4*3 + 5 ] = quad_node_norms_file[ data[4]*4*3 + 5 ]; 02890 quadVertNorms[ i*4*3 + 6 ] = quad_node_norms_file[ data[4]*4*3 + 6 ]; 02891 quadVertNorms[ i*4*3 + 7 ] = quad_node_norms_file[ data[4]*4*3 + 7 ]; 02892 quadVertNorms[ i*4*3 + 8 ] = quad_node_norms_file[ data[4]*4*3 + 8 ]; 02893 quadVertNorms[ i*4*3 + 9 ] = quad_node_norms_file[ data[4]*4*3 + 9 ]; 02894 quadVertNorms[ i*4*3 + 10] = quad_node_norms_file[ data[4]*4*3 + 10]; 02895 quadVertNorms[ i*4*3 + 11] = quad_node_norms_file[ data[4]*4*3 + 11]; 02896 found = CUBIT_TRUE; 02897 break; 02898 } 02899 else if ( this_quad[0] == data[1] && 02900 this_quad[1] == data[2] && 02901 this_quad[2] == data[3] && 02902 this_quad[3] == data[0] ) 02903 { 02904 quadVertNorms[ i*4*3 ] = quad_node_norms_file[ data[4]*4*3 + 3 ]; 02905 quadVertNorms[ i*4*3 + 1 ] = quad_node_norms_file[ data[4]*4*3 + 4 ]; 02906 quadVertNorms[ i*4*3 + 2 ] = quad_node_norms_file[ data[4]*4*3 + 5 ]; 02907 quadVertNorms[ i*4*3 + 3 ] = quad_node_norms_file[ data[4]*4*3 + 6 ]; 02908 quadVertNorms[ i*4*3 + 4 ] = quad_node_norms_file[ data[4]*4*3 + 7 ]; 02909 quadVertNorms[ i*4*3 + 5 ] = quad_node_norms_file[ data[4]*4*3 + 8 ]; 02910 quadVertNorms[ i*4*3 + 6 ] = quad_node_norms_file[ data[4]*4*3 + 9 ]; 02911 quadVertNorms[ i*4*3 + 7 ] = quad_node_norms_file[ data[4]*4*3 + 10 ]; 02912 quadVertNorms[ i*4*3 + 8 ] = quad_node_norms_file[ data[4]*4*3 + 11 ]; 02913 quadVertNorms[ i*4*3 + 9 ] = quad_node_norms_file[ data[4]*4*3 + 0 ]; 02914 quadVertNorms[ i*4*3 + 10] = quad_node_norms_file[ data[4]*4*3 + 1 ]; 02915 quadVertNorms[ i*4*3 + 11] = quad_node_norms_file[ data[4]*4*3 + 2 ]; 02916 found = CUBIT_TRUE; 02917 break; 02918 } 02919 else if ( this_quad[0] == data[2] && 02920 this_quad[1] == data[3] && 02921 this_quad[2] == data[0] && 02922 this_quad[3] == data[1] ) 02923 { 02924 quadVertNorms[ i*4*3 ] = quad_node_norms_file[ data[4]*4*3 + 6 ]; 02925 quadVertNorms[ i*4*3 + 1 ] = quad_node_norms_file[ data[4]*4*3 + 7 ]; 02926 quadVertNorms[ i*4*3 + 2 ] = quad_node_norms_file[ data[4]*4*3 + 8 ]; 02927 quadVertNorms[ i*4*3 + 3 ] = quad_node_norms_file[ data[4]*4*3 + 9 ]; 02928 quadVertNorms[ i*4*3 + 4 ] = quad_node_norms_file[ data[4]*4*3 + 10 ]; 02929 quadVertNorms[ i*4*3 + 5 ] = quad_node_norms_file[ data[4]*4*3 + 11 ]; 02930 quadVertNorms[ i*4*3 + 6 ] = quad_node_norms_file[ data[4]*4*3 + 0 ]; 02931 quadVertNorms[ i*4*3 + 7 ] = quad_node_norms_file[ data[4]*4*3 + 1 ]; 02932 quadVertNorms[ i*4*3 + 8 ] = quad_node_norms_file[ data[4]*4*3 + 2 ]; 02933 quadVertNorms[ i*4*3 + 9 ] = quad_node_norms_file[ data[4]*4*3 + 3 ]; 02934 quadVertNorms[ i*4*3 + 10] = quad_node_norms_file[ data[4]*4*3 + 4 ]; 02935 quadVertNorms[ i*4*3 + 11] = quad_node_norms_file[ data[4]*4*3 + 5 ]; 02936 found = CUBIT_TRUE; 02937 break; 02938 } 02939 else if ( this_quad[0] == data[3] && 02940 this_quad[1] == data[0] && 02941 this_quad[2] == data[1] && 02942 this_quad[3] == data[2] ) 02943 { 02944 quadVertNorms[ i*4*3 ] = quad_node_norms_file[ data[4]*4*3 + 9 ]; 02945 quadVertNorms[ i*4*3 + 1 ] = quad_node_norms_file[ data[4]*4*3 + 10 ]; 02946 quadVertNorms[ i*4*3 + 2 ] = quad_node_norms_file[ data[4]*4*3 + 11 ]; 02947 quadVertNorms[ i*4*3 + 3 ] = quad_node_norms_file[ data[4]*4*3 + 0 ]; 02948 quadVertNorms[ i*4*3 + 4 ] = quad_node_norms_file[ data[4]*4*3 + 1 ]; 02949 quadVertNorms[ i*4*3 + 5 ] = quad_node_norms_file[ data[4]*4*3 + 2 ]; 02950 quadVertNorms[ i*4*3 + 6 ] = quad_node_norms_file[ data[4]*4*3 + 3 ]; 02951 quadVertNorms[ i*4*3 + 7 ] = quad_node_norms_file[ data[4]*4*3 + 4 ]; 02952 quadVertNorms[ i*4*3 + 8 ] = quad_node_norms_file[ data[4]*4*3 + 5 ]; 02953 quadVertNorms[ i*4*3 + 9 ] = quad_node_norms_file[ data[4]*4*3 + 6 ]; 02954 quadVertNorms[ i*4*3 + 10] = quad_node_norms_file[ data[4]*4*3 + 7 ]; 02955 quadVertNorms[ i*4*3 + 11] = quad_node_norms_file[ data[4]*4*3 + 8 ]; 02956 found = CUBIT_TRUE; 02957 break; 02958 } 02959 } 02960 if ( found == CUBIT_FALSE ) 02961 { 02962 status = CUBIT_FAILURE; 02963 break; 02964 } 02965 } 02966 02967 delete [] quad_data; 02968 delete [] quad_hash; 02969 return status; 02970 } 02971 02972 //=========================================================================== 02973 // Function: constructTriVerts 02974 // Purpose: Given an array of edge indices for a tri element and an array 02975 // of edge to vertex info, construct an array containing the vertices 02976 // on the input tri. 02977 // Date: 08/31/2004 02978 // Author: mlstate 02979 //=========================================================================== 02980 static void constructTriVerts 02981 ( 02982 int triEdge[3], // <I> Array of edges on this tri. 02983 int *edgeVert, // <I> Array of edge to vertex info. 02984 int triVert[3] // <O> The vertices on the input tri. 02985 ) 02986 { 02987 int *verts_edge1 = &(edgeVert[triEdge[0]*2]); 02988 int *verts_edge2 = &(edgeVert[triEdge[1]*2]); 02989 int *verts_edge3 = &(edgeVert[triEdge[2]*2]); 02990 02991 if ( verts_edge1[0] != verts_edge2[0] && 02992 verts_edge1[0] != verts_edge2[1] ) 02993 { 02994 triVert[0] = verts_edge1[0]; 02995 triVert[1] = verts_edge1[1]; 02996 } 02997 else 02998 { 02999 triVert[0] = verts_edge1[1]; 03000 triVert[1] = verts_edge1[0]; 03001 } 03002 if ( verts_edge3[0] != verts_edge2[0] && 03003 verts_edge3[0] != verts_edge2[1] ) 03004 { 03005 triVert[2] = verts_edge3[1]; 03006 } 03007 else 03008 { 03009 triVert[2] = verts_edge3[0]; 03010 } 03011 } 03012 03013 //=========================================================================== 03014 // Function: constructQuadVerts 03015 // Purpose: Given an array of edge indices for a quad element and an array 03016 // of edge to vertex info, construct an array containing the vertices 03017 // on the input quad. 03018 // Date: 08/31/2004 03019 // Author: mlstate 03020 //=========================================================================== 03021 static void constructQuadVerts 03022 ( 03023 int QuadEdge[4], // <I> Array of edges on this quad. 03024 int *edgeVert, // <I> Array of edge to vertex info. 03025 int QuadVert[4] // <O> The vertices on the input quad. 03026 ) 03027 { 03028 int *verts_edge1 = &(edgeVert[QuadEdge[0]*2]); 03029 int *verts_edge2 = &(edgeVert[QuadEdge[1]*2]); 03030 int *verts_edge3 = &(edgeVert[QuadEdge[2]*2]); 03031 int *verts_edge4 = &(edgeVert[QuadEdge[3]*2]); 03032 03033 if ( verts_edge1[0] != verts_edge2[0] && 03034 verts_edge1[0] != verts_edge2[1] ) 03035 { 03036 QuadVert[0] = verts_edge1[0]; 03037 QuadVert[1] = verts_edge1[1]; 03038 } 03039 else 03040 { 03041 QuadVert[0] = verts_edge1[1]; 03042 QuadVert[1] = verts_edge1[0]; 03043 } 03044 03045 if ( verts_edge3[0] != verts_edge4[0] && 03046 verts_edge3[0] != verts_edge4[1] ) 03047 { 03048 QuadVert[2] = verts_edge3[0]; 03049 QuadVert[3] = verts_edge3[1]; 03050 } 03051 else 03052 { 03053 QuadVert[2] = verts_edge3[1]; 03054 QuadVert[3] = verts_edge3[0]; 03055 } 03056 } 03057 03058 //=========================================================================== 03059 // Function: readMBGNormalFile 03060 // Purpose: Read the raw data out of the Normal/Tangents file. 03061 // Date: 08/31/2004 03062 // Author: mlstate 03063 //=========================================================================== 03064 CubitStatus readMBGNormalFile 03065 ( 03066 const char *filename, 03067 int *num_tris, // <O> 03068 int *num_quads, // <O> 03069 int *num_edges, // <O> 03070 int **edge_nodes, // <OF> len = 2 * num_edges 03071 double **edge_node_tangents, // <OF> len = 3 * 2 * num_edges 03072 int **tri_nodes, // <OF> len = 3 * num_tris 03073 double **tri_node_normals, // <OF> len = 3 * 3 * num_tris 03074 int **quad_nodes, // <OF> len = 4 * num_quads 03075 double **quad_node_normals // <OF> len = 3 * 4 * num_quads 03076 ) 03077 { 03078 #define MAX_FILE_LINE 512 03079 03080 int num_t = 0; 03081 int num_q = 0; 03082 int curr_quad = 0; 03083 int curr_tri = 0; 03084 int num_e = 0; 03085 int n[4]; 03086 03087 if ( num_tris ) *num_tris = 0; 03088 if ( num_quads ) *num_quads = 0; 03089 if ( num_edges ) *num_edges = 0; 03090 if ( edge_nodes ) *edge_nodes = NULL; 03091 if ( edge_node_tangents ) *edge_node_tangents = NULL; 03092 if ( tri_nodes ) *tri_nodes = NULL; 03093 if ( quad_nodes ) *quad_nodes = NULL; 03094 if ( tri_node_normals ) *tri_node_normals = NULL; 03095 if ( quad_node_normals ) *quad_node_normals = NULL; 03096 03097 if ( strlen( filename ) == 0 ) 03098 { 03099 PRINT_ERROR(" No filename specified\n"); 03100 return CUBIT_FAILURE; 03101 } 03102 03103 ifstream geom_file( filename ); 03104 03105 char fileline[MAX_FILE_LINE]; 03106 03107 while ( geom_file.getline( fileline, MAX_FILE_LINE ) ) 03108 { 03109 int block_id, 03110 num_corners, 03111 num_elems; 03112 03113 if ( !strcmp( fileline, END_OF_BLOCKS ) ) break; 03114 if ( 3 != sscanf( fileline, "BLK %d %d %d", 03115 &block_id, &num_corners, &num_elems ) ) 03116 { 03117 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03118 geom_file.close(); 03119 return CUBIT_FAILURE; 03120 } 03121 03122 if ( num_corners == 3 ) 03123 { 03124 checkMemoryAllocations( num_corners, num_elems, &num_t, tri_nodes, 03125 tri_node_normals ); 03126 } 03127 else if ( num_corners == 4 ) 03128 { 03129 checkMemoryAllocations( num_corners, num_elems, &num_q, quad_nodes, 03130 quad_node_normals ); 03131 } 03132 else 03133 { 03134 PRINT_ERROR( "MBG Normal file can only support quads and tris.\n" ); 03135 geom_file.close(); 03136 return CUBIT_FAILURE; 03137 } 03138 03139 for ( int ielem = 0; ielem < num_elems; ielem++ ) 03140 { 03141 int *this_nodes = NULL; 03142 double *this_norms = NULL; 03143 03144 if ( !geom_file.getline( fileline, MAX_FILE_LINE ) ) 03145 { 03146 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03147 geom_file.close(); 03148 return CUBIT_FAILURE; 03149 } 03150 03151 if ( num_corners == 4 ) 03152 { 03153 if ( quad_nodes ) this_nodes = &((*quad_nodes )[4 * curr_quad]); 03154 if ( quad_node_normals ) this_norms = &((*quad_node_normals)[4 * 3 * curr_quad]); 03155 curr_quad++; 03156 } 03157 else if ( num_corners == 3 ) 03158 { 03159 if ( tri_nodes ) this_nodes = &((*tri_nodes )[3 * curr_tri]); 03160 if ( tri_node_normals ) this_norms = &((*tri_node_normals)[3 * 3 * curr_tri]); 03161 curr_tri++; 03162 } 03163 if ( ( num_corners == 4 && 4 != sscanf( fileline, "%d %d %d %d", 03164 &n[0], &n[1], &n[2], &n[3] ) ) || 03165 ( num_corners == 3 && 3 != sscanf( fileline, "%d %d %d", 03166 &n[0], &n[1], &n[2] ) ) ) 03167 { 03168 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03169 geom_file.close(); 03170 return CUBIT_FAILURE; 03171 } 03172 03173 if ( this_nodes ) 03174 memcpy( this_nodes, n, num_corners * sizeof( int ) ); 03175 03176 // Read in the surface normals at the vertices of this element. 03177 03178 for ( int icorner = 0; icorner < num_corners; icorner++ ) 03179 { 03180 if ( !geom_file.getline( fileline, MAX_FILE_LINE ) ) 03181 { 03182 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03183 geom_file.close(); 03184 return CUBIT_FAILURE; 03185 } 03186 if ( this_norms ) 03187 { 03188 double norm[3]; 03189 03190 if ( 3 != sscanf( fileline, "%lf %lf %lf", &norm[0], &norm[1], &norm[2] ) ) 03191 { 03192 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03193 geom_file.close(); 03194 return CUBIT_FAILURE; 03195 } 03196 memcpy( &(this_norms[icorner * 3]), norm, 3 * sizeof( double ) ); 03197 } 03198 } 03199 } 03200 } 03201 03202 if ( !geom_file.getline( fileline, MAX_FILE_LINE ) ) 03203 { 03204 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03205 geom_file.close(); 03206 return CUBIT_FAILURE; 03207 } 03208 03209 if ( 1 != sscanf( fileline, "%d", &num_e ) ) 03210 { 03211 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03212 geom_file.close(); 03213 return CUBIT_FAILURE; 03214 } 03215 03216 if ( edge_nodes || edge_node_tangents ) 03217 { 03218 if ( edge_nodes ) *edge_nodes = new int [ 2 * num_e ]; 03219 if ( edge_node_tangents ) *edge_node_tangents = new double [3 * 2 * num_e]; 03220 03221 for ( int iedge = 0; iedge < num_e; iedge++ ) 03222 { 03223 if ( !geom_file.getline( fileline, MAX_FILE_LINE ) ) 03224 { 03225 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03226 geom_file.close(); 03227 return CUBIT_FAILURE; 03228 } 03229 if ( 2 != sscanf( fileline, "%d %d", &n[0], &n[1] ) ) 03230 { 03231 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03232 geom_file.close(); 03233 return CUBIT_FAILURE; 03234 } 03235 03236 for ( int iend = 0; iend < 2; iend++ ) 03237 { 03238 double d[3]; 03239 03240 if ( edge_nodes ) 03241 { 03242 (*edge_nodes)[iedge * 2 + iend ] = n[iend]; 03243 } 03244 03245 if ( !geom_file.getline( fileline, MAX_FILE_LINE ) ) 03246 { 03247 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03248 geom_file.close(); 03249 return CUBIT_FAILURE; 03250 } 03251 if ( 3 != sscanf( fileline, "%lf %lf %lf", &d[0], &d[1], &d[2] ) ) 03252 { 03253 PRINT_ERROR( "MBG Normal file has incorrect file format\n" ); 03254 geom_file.close(); 03255 return CUBIT_FAILURE; 03256 } 03257 03258 int index = ((iedge*2) + iend) * 3; 03259 if ( edge_node_tangents ) 03260 { 03261 (*edge_node_tangents)[ index ] = d[0]; 03262 (*edge_node_tangents)[ index + 1 ] = d[1]; 03263 (*edge_node_tangents)[ index + 2 ] = d[2]; 03264 } 03265 } 03266 } 03267 } 03268 03269 if ( num_quads ) *num_quads = num_q; 03270 if ( num_tris ) *num_tris = num_t; 03271 if ( num_edges ) *num_edges = num_e; 03272 03273 geom_file.close(); 03274 return CUBIT_SUCCESS; 03275 } 03276 03277 //=========================================================================== 03278 // Function: checkMemoryAllocations 03279 // Purpose: While reading data out of the Normal/Tangents file, reallocate 03280 // Arrays to ensure that we have enough memory. 03281 // Date: 08/31/2004 03282 // Author: mlstate 03283 //=========================================================================== 03284 static void checkMemoryAllocations 03285 ( 03286 int num_nodes_per_elem, 03287 int additional_num_elems, 03288 int *num_elems, 03289 int **nodes, 03290 double **node_normals 03291 ) 03292 { 03293 int old_num = *num_elems; 03294 03295 *num_elems += additional_num_elems; 03296 if ( node_normals && *node_normals ) 03297 { 03298 double *new_mem = new double [ *num_elems * 3 * num_nodes_per_elem ]; 03299 memcpy( new_mem, *node_normals, old_num * 3 * num_nodes_per_elem * sizeof( double ) ); 03300 delete *node_normals; 03301 *node_normals = new_mem; 03302 } 03303 else if ( node_normals ) 03304 { 03305 *node_normals = new double [ *num_elems * num_nodes_per_elem * 3 ]; 03306 } 03307 03308 if ( nodes && *nodes ) 03309 { 03310 int *new_mem = new int [ *num_elems * num_nodes_per_elem ]; 03311 memcpy( new_mem, *nodes, old_num * num_nodes_per_elem * sizeof( int ) ); 03312 delete *nodes; 03313 *nodes = new_mem; 03314 } 03315 else if ( nodes ) 03316 { 03317 *nodes = new int [ *num_elems * num_nodes_per_elem ]; 03318 } 03319 } 03320 03321 // This code classify the type of edge with respect to convexity, 03322 // C0 or C1 continuity, and topology. The returned int uses the following 03323 // number code: 03324 // -1 = non-convex, manifold edge 03325 // 0 = non-feature, manifold edge (ie, C1 edge) 03326 // 1 = convex, manifold edge 03327 // 2 = non-manifold edge 03328 // Numbers higher than two are error codes 03329 // 3 = edge only attached to a single facet (boundary of 2-d sheet). 03330 static int classify_local_convexity_at_edge(CubitFacetEdge *edge_ptr) 03331 { 03332 //easy check... if not a feature return 0 03333 if(!edge_ptr->is_feature()) 03334 return 0; 03335 03336 //else we know that we are at feature... determine the type 03337 CubitFacet *adj_facet_1 = NULL, *adj_facet_2 = NULL; 03338 CubitPoint *point_1 = NULL, *point_2 = NULL, *point_3 = NULL; 03339 CubitVector v2, v3; 03340 CubitVector v0 = edge_ptr->point(0)->coordinates(); 03341 CubitVector v1 = edge_ptr->point(1)->coordinates(); 03342 DLIList<CubitFacet*> adj_facets; 03343 edge_ptr->facets(adj_facets); 03344 03345 //if non-manifold edge, mark as two 03346 if(adj_facets.size() > 2){ 03347 return 2; 03348 } 03349 //if boundary on 2-d (shouldn't happen) mark as 3 03350 //anything above 2 is essentially an error code... 03351 else if(adj_facets.size() < 2){ 03352 return 3; 03353 } 03354 //otherwise, determine whether it is 1 or -1 03355 //this else should be a separate function: classify_edge_convexity() 03356 adj_facet_1 = adj_facets.get_and_step(); 03357 int edge_index = adj_facet_1->edge_index(edge_ptr); 03358 //order such that *_1 is the facet that uses 03359 // this edge as the forward edge... 03360 if(adj_facet_1->edge_use(edge_index) == 1) 03361 adj_facet_2 = adj_facets.get(); 03362 else{ 03363 adj_facet_1 = adj_facets.get(); 03364 adj_facets.reset(); 03365 adj_facet_2 = adj_facets.get(); 03366 } 03367 // order the points so that the Jacobian of the matrix 03368 // will tell use whether we are convex or not at this edge. 03369 adj_facet_1->points(point_1, point_2, point_3); 03370 if(point_1 == edge_ptr->point(0)){ 03371 v2 = point_3->coordinates(); 03372 } 03373 else if(point_1 == edge_ptr->point(1)){ 03374 v2 = point_2->coordinates(); 03375 } 03376 else{ 03377 v2 = point_1->coordinates(); 03378 } 03379 adj_facet_2->points(point_1, point_2, point_3); 03380 if(point_1 == edge_ptr->point(0)){ 03381 v3 = point_2->coordinates(); 03382 } 03383 else if(point_1 == edge_ptr->point(1)){ 03384 v3 = point_3->coordinates(); 03385 } 03386 else{ 03387 v3 = point_1->coordinates(); 03388 } 03389 03390 v1-=v0; 03391 v2-=v0; 03392 v3-=v0; 03393 //if Jacobian is negative, we are convex here. 03394 if( ( v1 % (v2* v3) ) < 0.0){ 03395 return 1; 03396 } 03397 else{ 03398 return -1; 03399 } 03400 03401 } 03402 /* 03403 int test_edges(int num_edge, int* edge_vert, double* my_vert, CubitFacetEdge** edge_array){ 03404 int ii; 03405 int return_val = 0.0; 03406 CubitFacetEdgeData *cfed_ptr = NULL; 03407 int my_v1, my_v2; 03408 CubitVector vert1, vert2; 03409 CubitPoint *poi1, *poi2; 03410 CubitVector coord1, coord2; 03411 for(ii=0; ii<num_edge; ++ii){ 03412 cfed_ptr = CAST_TO(edge_array[ii], CubitFacetEdgeData); 03413 poi1 = cfed_ptr->start_node(); 03414 poi2 = cfed_ptr->end_node(); 03415 coord1.set(poi1->x(),poi1->y(),poi1->z()); 03416 coord2.set(poi2->x(),poi2->y(),poi2->z()); 03417 my_v1 = edge_vert[ii*2]; 03418 my_v2 = edge_vert[ii*2+1]; 03419 vert1.set(my_vert[my_v1*3],my_vert[my_v1*3+1],my_vert[my_v1*3+2]); 03420 vert2.set(my_vert[my_v2*3],my_vert[my_v2*3+1],my_vert[my_v2*3+2]); 03421 double my_dist = vert1.distance_between(coord1); 03422 if(my_dist > .01){ 03423 PRINT_INFO("Edge (%i)(1), distance (%f)\n",ii,my_dist); 03424 return_val++; 03425 } 03426 my_dist = vert2.distance_between(coord2); 03427 if(my_dist > .01){ 03428 PRINT_INFO("Edge (%i)(2), distance (%f)\n",ii,my_dist); 03429 return_val++; 03430 } 03431 } 03432 return return_val; 03433 } 03434 03435 03436 */
