cgma
#include <CubitQuadFacetData.hpp>
Public Member Functions | |
| CubitQuadFacetData (CubitFacet *tri_facets[2], CubitPoint *points[4]) | |
| CubitQuadFacetData (CubitPoint *points[4]) | |
| CubitQuadFacetData (CubitPoint *point0, CubitPoint *point1, CubitPoint *point2, CubitPoint *point3) | |
| CubitQuadFacetData (CubitFacetEdge *e0, CubitFacetEdge *e1, CubitFacetEdge *e2, CubitFacetEdge *e3) | |
| ~CubitQuadFacetData () | |
| int | tri_to_quad_index (int tri_index, int pt_index) |
| CubitFacet * | get_tri_facet (int index) |
| CubitFacet * | get_tri_facet_at_point (CubitPoint *point_ptr) |
| void | remove_tri_facets () |
| void | points (CubitPoint *points[4]) |
| void | points (DLIList< CubitPoint * > &point_list) |
| CubitPoint * | point (int index) |
| CubitFacetEdge * | edge (int index) |
Private Attributes | |
| CubitFacet * | myTriangleFacets [2] |
| int | triToQuadIndex [2][3] |
Definition at line 9 of file CubitQuadFacetData.hpp.
| CubitQuadFacetData::CubitQuadFacetData | ( | CubitFacet * | tri_facets[2], |
| CubitPoint * | points[4] | ||
Definition at line 23 of file CubitQuadFacetData.cpp.
myTriangleFacets[0] = tri_facets[0];
myTriangleFacets[1] = tri_facets[1];
CubitBoolean found = CUBIT_FALSE;
CubitPoint *pt;
int ii, jj, kk;
for (jj=0; jj<2; jj++)
for (kk=0; kk<3; kk++)
pt = myTriangleFacets[jj]->point(kk);
for (ii=0; ii<4 && !found; ii++)
if (points[ii] == pt)
triToQuadIndex[jj][kk] = ii;
found = CUBIT_TRUE;
// If assertion occurs, the that points passed to the constructor do
// not match the points on the triangle facets
assert(found == CUBIT_TRUE);
| CubitQuadFacetData::CubitQuadFacetData | ( | CubitPoint * | points[4] | ) |
Definition at line 125 of file CubitQuadFacetData.cpp.
// The orientation of the triangles in the quad is arbitrary.
// We may want to split based on some other criteria (ie. angles)
myTriangleFacets[0] = new CubitFacetData( points[0], points[1], points[2] );
myTriangleFacets[1] = new CubitFacetData( points[2], points[3], points[0] );
triToQuadIndex[0][0] = 0;
triToQuadIndex[0][1] = 1;
triToQuadIndex[0][2] = 2;
triToQuadIndex[1][0] = 2;
triToQuadIndex[1][1] = 3;
triToQuadIndex[1][2] = 0;
| CubitQuadFacetData::CubitQuadFacetData | ( | CubitPoint * | point0, |
| CubitPoint * | point1, | ||
| CubitPoint * | point2, | ||
| CubitPoint * | point3 | ||
Definition at line 65 of file CubitQuadFacetData.cpp.
myTriangleFacets[0] = new CubitFacetData( point0, point1, point2 );
myTriangleFacets[1] = new CubitFacetData( point2, point3, point0 );
| CubitQuadFacetData::CubitQuadFacetData | ( | CubitFacetEdge * | e0, |
| CubitFacetEdge * | e1, | ||
| CubitFacetEdge * | e2, | ||
| CubitFacetEdge * | e3 | ||
Definition at line 92 of file CubitQuadFacetData.cpp.
// create the diagonal edge
CubitPoint *p0 = e3->shared_point(e0);
CubitPoint *p2 = e1->shared_point(e2);
assert(p0 != NULL && p2 != NULL);
CubitFacetEdge *e4 = (CubitFacetEdge *) new CubitFacetEdgeData( p0, p2 );
// create the triangles
myTriangleFacets[0] = new CubitFacetData( e1, e4, e0 );
myTriangleFacets[1] = new CubitFacetData( e3, e4, e2 );
Definition at line 149 of file CubitQuadFacetData.cpp.
if (myTriangleFacets[0] == NULL && myTriangleFacets[1] == NULL)
return;
assert(myTriangleFacets[0] && myTriangleFacets[1]);
// determine the dialogonal edge
CubitPoint *p0 = this->point(0);
CubitPoint *p2 = this->point(2);
CubitFacetEdge *dedge = NULL;
if (p0 != NULL && p2 != NULL)
dedge = p0->shared_edge(p2);
// delete both triangles
delete myTriangleFacets[0];
delete myTriangleFacets[1];
// delete the dialgonal edge
if (dedge != NULL)
delete dedge;
| CubitFacetEdge * CubitQuadFacetData::edge | ( | int | index | ) | [virtual] |
Implements CubitQuadFacet.
Definition at line 235 of file CubitQuadFacetData.cpp.
int ii, jj;
CubitPoint *p0 = NULL;
CubitPoint *p1 = NULL;
int index1 = (index + 1) % 4;
for (ii=0; ii<2; ii++)
for (jj=0; jj<3; jj++)
if (triToQuadIndex[ii][jj] == index)
p0 = myTriangleFacets[ii]->point(jj);
else if ( triToQuadIndex[ii][jj] == index1 )
p1 = myTriangleFacets[ii]->point(jj);
assert(p0 != NULL && p1 != NULL); // index is probably out of range
return p0->shared_edge( p1 );
| CubitFacet* CubitQuadFacetData::get_tri_facet | ( | int | index | ) | [inline, virtual] |
Definition at line 30 of file CubitQuadFacetData.hpp.
{ return myTriangleFacets[ index ]; }
| CubitFacet * CubitQuadFacetData::get_tri_facet_at_point | ( | CubitPoint * | point_ptr | ) | [virtual] |
Definition at line 267 of file CubitQuadFacetData.cpp.
int ii, jj;
if (myTriangleFacets[ii]->point(jj) == point_ptr)
return myTriangleFacets[ii];
assert(0); // point isn't on facet
return NULL;
| CubitPoint * CubitQuadFacetData::point | ( | int | index | ) | [virtual] |
Definition at line 212 of file CubitQuadFacetData.cpp.
int ii, jj;
return myTriangleFacets[ii]->point(jj);
assert(0); // index is probably out of range
return NULL;
| void CubitQuadFacetData::points | ( | CubitPoint * | points[4] | ) | [virtual] |
Definition at line 194 of file CubitQuadFacetData.cpp.
thepoints[triToQuadIndex[0][0]] = myTriangleFacets[0]->point(0);
thepoints[triToQuadIndex[0][1]] = myTriangleFacets[0]->point(1);
thepoints[triToQuadIndex[0][2]] = myTriangleFacets[0]->point(2);
thepoints[triToQuadIndex[1][0]] = myTriangleFacets[1]->point(0);
thepoints[triToQuadIndex[1][1]] = myTriangleFacets[1]->point(1);
thepoints[triToQuadIndex[1][2]] = myTriangleFacets[1]->point(2);
| void CubitQuadFacetData::points | ( | DLIList< CubitPoint * > & | point_list | ) | [inline, virtual] |
Reimplemented from CubitQuadFacet.
Definition at line 42 of file CubitQuadFacetData.hpp.
{CubitQuadFacet::points(point_list);}
| void CubitQuadFacetData::remove_tri_facets | ( | ) | [virtual] |
Definition at line 182 of file CubitQuadFacetData.cpp.
myTriangleFacets[0] = NULL;
myTriangleFacets[1] = NULL;
| int CubitQuadFacetData::tri_to_quad_index | ( | int | tri_index, |
| int | pt_index | ||
Definition at line 25 of file CubitQuadFacetData.hpp.
{ return triToQuadIndex[ tri_index ][ pt_index ]; }
CubitFacet* CubitQuadFacetData::myTriangleFacets[2] [private] |
Definition at line 12 of file CubitQuadFacetData.hpp.
int CubitQuadFacetData::triToQuadIndex[2][3] [private] |
Definition at line 13 of file CubitQuadFacetData.hpp.
