cgma
#include <CubitOctreeCell.hpp>
Definition at line 29 of file CubitOctreeCell.hpp.
| CubitOctreeCell::CubitOctreeCell | ( | ) | [inline] |
Definition at line 33 of file CubitOctreeCell.hpp.
| CubitOctreeCell::CubitOctreeCell | ( | CubitVector | center, |
| double | dimension, | ||
| int | level, | ||
| CubitOctreeCell * | parent_cell | ||
Definition at line 24 of file CubitOctreeCell.cpp.
static int counter = 0;
int i, j, k;
leaf = CUBIT_TRUE;
dimension = dim;
mCenter = cen;
depth = level;
num = counter;
counter ++;
parent = parent_cell;
mark = CUBIT_FALSE;
visit = CUBIT_FALSE;
color = CUBIT_WHITE_INDEX;
// CubitOctreeNode = new CubitOctreeNode* [2][2][2];
myFacetList = NULL;
for( i = 0; i < 2; i++ ){
for( j = 0; j < 2; j++ ){
for( k = 0; k < 2; k++ ){
cubitOctreeNode[i][j][k] = NULL;
children[i][j][k] = NULL;
//CubitOctree = NULL;
| CubitOctreeCell::~CubitOctreeCell | ( | ) | [virtual] |
Definition at line 63 of file CubitOctreeCell.cpp.
int i, j, k;
if( children[i][j][k] != NULL ){
delete children[i][j][k];
int num_elm = octreeFacetPointDataList.size();
for( i = 0; i < num_elm; i++ ){
delete octreeFacetPointDataList.pop();
// delete_local_node_matrix();
/*if (myFacetList)
for (i=0; i < myFacetList->size(); ++i)
delete myFacetList->get_and_step();
delete myFacetList;
}*/ //uncomment later
| bool CubitOctreeCell::add_adjacent_unmarked_cells | ( | DLIList< CubitOctreeCell * > & | queue | ) |
Definition at line 404 of file CubitOctreeCell.cpp.
//optimized
static int i, j, k, l, m, n;
static CubitOctreeNode *ptr_grid_node;
static CubitOctreeCell *ptr_cell;
static DLIList<CubitOctreeCell*> temp_list;
for( i = 1; i >= 0; i-- ){
for( j = 1; j >= 0; j-- ){
for( k = 1; k >= 0; k-- ){
ptr_grid_node = cubitOctreeNode[i][j][k];
for( l = 0; l < 2; l++ ){
for( m = 0; m < 2; m++ ){
for( n = 0; n < 2; n++ ){
ptr_cell = ptr_grid_node->get_adj_cell( l, m, n );
if( ptr_cell != NULL )
if( ptr_cell->mark == CUBIT_FALSE )
//queue.append( ptr_cell );
temp_list.append(ptr_cell);
// ptr_cell->set_mark( CUBIT_TRUE );
ptr_cell->mark = CUBIT_TRUE;
queue += temp_list;
temp_list.clean_out();
return CUBIT_TRUE;
| bool CubitOctreeCell::append_list_item | ( | OctreeFacetPointData * | ptr_facet_point_data | ) |
Definition at line 398 of file CubitOctreeCell.cpp.
octreeFacetPointDataList.push( ptr_facet_point_data );
return CUBIT_TRUE;
| void CubitOctreeCell::coloring | ( | DLIList< CubitOctreeCell * > & | black_cell_list | ) |
Definition at line 598 of file CubitOctreeCell.cpp.
int i,j,k;
int grey, black;
grey = FALSE;
black = TRUE;
if( leaf == CUBIT_TRUE ){
if( cubitOctreeNode[i][j][k]->get_color() != CUBIT_BLACK_INDEX )
black = FALSE;
else
grey = TRUE;
if( black == TRUE )
color = CUBIT_BLACK_INDEX;
black_cell_list.append(this);
else
if( grey == TRUE ){
color = CUBIT_GREY_INDEX;
//grey_cell_list.push( this );
else
color = CUBIT_WHITE_INDEX; //constructor
//return CUBIT_TRUE;
else{
children[i][j][k]->coloring( /*grey_cell_list,*/ black_cell_list);
//return CUBIT_FALSE;
| void CubitOctreeCell::display | ( | CubitOctree * | ptr_octree, |
| int | opt | ||
Definition at line 186 of file CubitOctreeCell.cpp.
int i, j, k;
if( is_leaf() == CUBIT_FALSE ){
//if( children[i][j][k] != NULL ){
children[i][j][k]->display(ptr_octree, opt);
else if (opt == 1)
// draw all cells in black wireframe mode
//double corners[3];
//double half_edge_length = get_dimension()/2.0;
//CubitVector center = get_center();
//center.get_xyz(corners);
//double box[6] = {corners[0]-half_edge_length, corners[1]-half_edge_length, corners[2]-half_edge_length,
//corners[0]+half_edge_length, corners[1]+half_edge_length, corners[2]+half_edge_length};
//SVDrawTool::draw_cube(box, CUBIT_BLACK_INDEX, SVDrawTool::WIRE);
return;
else if (opt == 2)
// draw grey and black cells in black wireframe mode
//(color == CUBIT_GREY_INDEX || color == CUBIT_BLACK_INDEX)
if (color == CUBIT_BLACK_INDEX)
return;
else if (opt == 3)
// draw grey cells in white smoothshade mode
if (color == CUBIT_GREY_INDEX)
//SVDrawTool::draw_cube(box, CUBIT_WHITE_INDEX, SVDrawTool::SHADE);
return;
else if (opt == 4)
if (color != CUBIT_WHITE_INDEX)
return;
else if (opt == 5)
// draw grey and black cells in color wireframe mode
if( color == CUBIT_GREY_INDEX || color == CUBIT_BLACK_INDEX )
display_color_wireframe(ptr_octree);
return;
else
if( /*color == CUBIT_GREY_INDEX ||*/ color == CUBIT_BLACK_INDEX )
return;
| void CubitOctreeCell::display_color_wireframe | ( | CubitOctree * | ptr_octree | ) |
Definition at line 95 of file CubitOctreeCell.cpp.
//glColor3f( (cubitOctreeNode[0][0][0])->GetsizeColor(X), (cubitOctreeNode[0][0][0])->GetsizeColor(Y), (cubitOctreeNode[0][0][0])->GetsizeColor(Z) );
//glColor3f( (cubitOctreeNode[1][0][0])->GetsizeColor(X), (cubitOctreeNode[1][0][0])->GetsizeColor(Y), (cubitOctreeNode[1][0][0])->GetsizeColor(Z) );
// GfxDebug::draw_line( cubitOctreeNode[0][0][0]->x(), cubitOctreeNode[0][0][0]->y(), cubitOctreeNode[0][0][0]->z(), cubitOctreeNode[1][0][0]->x(), cubitOctreeNode[1][0][0]->y(), cubitOctreeNode[1][0][0]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][0][0]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node( cubitOctreeNode[0][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node( cubitOctreeNode[1][0][0]->get_size( OCTREE_SIZE_DEFAULT)) );
//glColor3f( (cubitOctreeNode[0][1][0])->GetsizeColor(X), (cubitOctreeNode[0][1][0])->GetsizeColor(Y), (cubitOctreeNode[0][1][0])->GetsizeColor(Z) );
//glColor3f( (cubitOctreeNode[1][1][0])->GetsizeColor(X), (cubitOctreeNode[1][1][0])->GetsizeColor(Y), (cubitOctreeNode[1][1][0])->GetsizeColor(Z) );
//GfxDebug::draw_line( cubitOctreeNode[0][1][0]->x(), cubitOctreeNode[0][1][0]->y(), cubitOctreeNode[0][1][0]->z(),cubitOctreeNode[1][1][0]->x(), cubitOctreeNode[1][1][0]->y(), cubitOctreeNode[1][1][0]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][1][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][0]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][0]->get_size( OCTREE_SIZE_DEFAULT)) );
//GfxDebug::draw_line( cubitOctreeNode[0][0][0]->x(), cubitOctreeNode[0][0][0]->y(), cubitOctreeNode[0][0][0]->z(), cubitOctreeNode[0][1][0]->x(), cubitOctreeNode[0][1][0]->y(), cubitOctreeNode[0][1][0]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][1][0]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[0][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][0]->get_size( OCTREE_SIZE_DEFAULT)) );
//GfxDebug::draw_line( cubitOctreeNode[1][0][0]->x(), cubitOctreeNode[1][0][0]->y(), cubitOctreeNode[1][0][0]->z(), cubitOctreeNode[1][1][0]->x(), cubitOctreeNode[1][1][0]->y(), cubitOctreeNode[1][1][0]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[1][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][0]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[1][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][0]->get_size( OCTREE_SIZE_DEFAULT)) );
//glColor3f( (cubitOctreeNode[0][0][1])->GetsizeColor(X), (cubitOctreeNode[0][0][1])->GetsizeColor(Y), (cubitOctreeNode[0][0][1])->GetsizeColor(Z) );
//glColor3f( (cubitOctreeNode[1][0][1])->GetsizeColor(X), (cubitOctreeNode[1][0][1])->GetsizeColor(Y), (cubitOctreeNode[1][0][1])->GetsizeColor(Z) );
//GfxDebug::draw_line( cubitOctreeNode[0][0][1]->x(), cubitOctreeNode[0][0][1]->y(), cubitOctreeNode[0][0][1]->z(), cubitOctreeNode[1][0][1]->x(), cubitOctreeNode[1][0][1]->y(), cubitOctreeNode[1][0][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][0][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][0][1]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][0][1]->get_size( OCTREE_SIZE_DEFAULT)) );
//glColor3f( (cubitOctreeNode[0][1][1])->GetsizeColor(X), (cubitOctreeNode[0][1][1])->GetsizeColor(Y), (cubitOctreeNode[0][1][1])->GetsizeColor(Z) );
//glColor3f( (cubitOctreeNode[1][1][1])->GetsizeColor(X), (cubitOctreeNode[1][1][1])->GetsizeColor(Y), (cubitOctreeNode[1][1][1])->GetsizeColor(Z) );
//GfxDebug::draw_line( cubitOctreeNode[0][1][1]->x(), cubitOctreeNode[0][1][1]->y(), cubitOctreeNode[0][1][1]->z(), cubitOctreeNode[1][1][1]->x(), cubitOctreeNode[1][1][1]->y(), cubitOctreeNode[1][1][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][1][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][1]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
//GfxDebug::draw_line( cubitOctreeNode[0][0][1]->x(), cubitOctreeNode[0][0][1]->y(), cubitOctreeNode[0][0][1]->z(), cubitOctreeNode[0][1][1]->x(), cubitOctreeNode[0][1][1]->y(), cubitOctreeNode[0][1][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][0][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][1][1]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[0][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
//GfxDebug::draw_line( cubitOctreeNode[1][0][1]->x(), cubitOctreeNode[1][0][1]->y(), cubitOctreeNode[1][0][1]->z(), cubitOctreeNode[1][1][1]->x(), cubitOctreeNode[1][1][1]->y(), cubitOctreeNode[1][1][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[1][0][1]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][1]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[1][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][0][1]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
//GfxDebug::draw_line( cubitOctreeNode[0][0][0]->x(), cubitOctreeNode[0][0][0]->y(), cubitOctreeNode[0][0][0]->z(), cubitOctreeNode[0][0][1]->x(), cubitOctreeNode[0][0][1]->y(), cubitOctreeNode[0][0][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][0][1]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[0][0][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[0][0][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[0][0][1]->get_size( OCTREE_SIZE_DEFAULT)) );
//GfxDebug::draw_line( cubitOctreeNode[0][1][0]->x(), cubitOctreeNode[0][1][0]->y(), cubitOctreeNode[0][1][0]->z(), cubitOctreeNode[0][1][1]->x(), cubitOctreeNode[0][1][1]->y(), cubitOctreeNode[0][1][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[0][1][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[0][1][1]->get_color() != CUBIT_GREY_INDEX ){
//GfxDebug::draw_line( cubitOctreeNode[1][0][0]->x(), cubitOctreeNode[1][0][0]->y(), cubitOctreeNode[1][0][0]->z(), cubitOctreeNode[1][0][1]->x(), cubitOctreeNode[1][0][1]->y(), cubitOctreeNode[1][0][1]->z(), CUBIT_BLUE_INDEX );
//SkeletonDebug::draw_line( cubitOctreeNode[1][0][0]->get_coord(), cubitOctreeNode[1][0][0]->get_size( OCTREE_SIZE_DEFAULT), cubitOctreeNode[1][0][1]->get_coord(), cubitOctreeNode[1][0][1]->get_size( OCTREE_SIZE_DEFAULT) );
if( cubitOctreeNode[1][0][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][0][1]->get_color() != CUBIT_GREY_INDEX ){
//GfxDebug::draw_line( cubitOctreeNode[1][1][0]->x(), cubitOctreeNode[1][1][0]->y(), cubitOctreeNode[1][1][0]->z(), cubitOctreeNode[1][1][1]->x(), cubitOctreeNode[1][1][1]->y(), cubitOctreeNode[1][1][1]->z(), CUBIT_BLUE_INDEX );
if( cubitOctreeNode[1][1][0]->get_color() != CUBIT_GREY_INDEX && cubitOctreeNode[1][1][1]->get_color() != CUBIT_GREY_INDEX ){
//SkeletonDebug::draw_line( cubitOctreeNode[1][1][0]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][0]->get_size( OCTREE_SIZE_DEFAULT)), cubitOctreeNode[1][1][1]->get_coord(), ptr_octree->get_scaled_from_wrld_size_grid_node(cubitOctreeNode[1][1][1]->get_size( OCTREE_SIZE_DEFAULT)) );
| void CubitOctreeCell::display_octreefacetpointdata | ( | void | ) |
Definition at line 296 of file CubitOctreeCell.cpp.
int i, j, k;
children[i][j][k]->display_octreefacetpointdata( );
else{
for( i = 0; i < octreeFacetPointDataList.size(); i++ ){
octreeFacetPointDataList.get_and_step()->display();
| void CubitOctreeCell::distribute_facet_points_among_children | ( | void | ) |
Definition at line 360 of file CubitOctreeCell.cpp.
int i;
int l, m, n;
OctreeFacetPointData *ptr_facet_point_data;
octreeFacetPointDataList.reset();
ptr_facet_point_data = octreeFacetPointDataList.get_and_step();
l = m = n = 1;
if( ptr_facet_point_data->x() < mCenter.x() )
l = 0;
if( ptr_facet_point_data->y() < mCenter.y() )
m = 0;
if( ptr_facet_point_data->z() < mCenter.z() )
n = 0;
children[l][m][n]->append_list_item( ptr_facet_point_data );
// Clean the points and face list in the parent cell
octreeFacetPointDataList.clean_out();
Definition at line 979 of file CubitOctreeCell.cpp.
int i, j, k;
CubitBoolean positive_space = CUBIT_FALSE;
CubitBoolean negative_space = CUBIT_FALSE;
if( cubitOctreeNode[i][j][k]->get_halfspace_direction() == OCTREE_POSITIVE )
positive_space = CUBIT_TRUE;
else
negative_space = CUBIT_TRUE;
if( positive_space == CUBIT_TRUE && negative_space == CUBIT_TRUE ){
return CUBIT_TRUE;
else{
return CUBIT_FALSE;
Definition at line 825 of file CubitOctreeCell.cpp.
int i;
CubitVector v0 = ptr_facet->point(0)->coordinates() - get_center(), v1 = ptr_facet->point(1)->coordinates() - get_center(),
v2 = ptr_facet->point(2)->coordinates() - get_center();
static CubitVector sep_axes[13];
sep_axes[0] = ptr_facet->normal();
sep_axes[1] = CubitVector(1,0,0);// note to self: optimize following trivial cross products
sep_axes[2] = CubitVector(0,1,0);
sep_axes[3] = CubitVector(0,0,1);
sep_axes[4] = sep_axes[1]*(v1-v0);
sep_axes[5] = sep_axes[1]*(v2-v1);
sep_axes[6] = sep_axes[1]*(v0-v2);
sep_axes[7] = sep_axes[2]*(v1-v0);
sep_axes[8] = sep_axes[2]*(v2-v1);
sep_axes[9] = sep_axes[2]*(v0-v2);
sep_axes[10] = sep_axes[3]*(v1-v0);
sep_axes[11] = sep_axes[3]*(v2-v1);
sep_axes[12] = sep_axes[3]*(v0-v2);
sep_axes[4].normalize();
sep_axes[5].normalize();
sep_axes[6].normalize();
sep_axes[7].normalize();
sep_axes[8].normalize();
sep_axes[9].normalize();
sep_axes[10].normalize();
sep_axes[11].normalize();
sep_axes[12].normalize();
double rad_b, dot1, dot2, dot3, min_t, max_t;
for (i=0; i < 13; ++i)
// rad_b is the "radius" of the projection of the cell onto the separating axis, centered about the projection of the cell's center
// min_t and max_t are the extremes of the projection of the triangle onto the separating axis
rad_b = (get_dimension() / 2.0) * (fabs(sep_axes[i].x()) + fabs(sep_axes[i].y()) + fabs(sep_axes[i].z()));
dot1 = v0%sep_axes[i];
dot2 = v1%sep_axes[i];
dot3 = v2%sep_axes[i];
min_t = CUBIT_MIN(CUBIT_MIN(dot1,dot2),dot3);
max_t = CUBIT_MAX(CUBIT_MAX(dot1,dot2),dot3);
// if the triangle's projection is on either side of the CubitOctree cell's projection, i.e. the projections don't overlap, then the two are disjoint
//if ( min_t > rad_b || max_t < -rad_b)
if ( (min_t - rad_b) > 1e-6 || (-rad_b -max_t) > 1e-6)
// found a separating axis so facet and cell do not intersect
return CUBIT_FALSE;
// OctreeIntersectionData code was here
return CUBIT_TRUE;
| CubitStatus CubitOctreeCell::find_indices_in_parent | ( | int * | index | ) |
Definition at line 1165 of file CubitOctreeCell.cpp.
int i, j, k;
if( parent->get_child( i, j, k )->id() == num ){
index[0] = i;
index[1] = j;
index[2] = k;
return CUBIT_SUCCESS;
return CUBIT_FAILURE;
| CubitOctreeCell * CubitOctreeCell::find_leaf_octree_cell | ( | const CubitVector & | point | ) |
Definition at line 333 of file CubitOctreeCell.cpp.
int i, j, k;
if( is_leaf() == CUBIT_TRUE ){
return this;
else{
i = j = k = 1;
if( point.x() < mCenter.x() )
i = 0;
if( point.y() < mCenter.y() )
j = 0;
if( point.z() < mCenter.z() )
k = 0;
if (children[i][j][k] == NULL) {return NULL;}
return children[i][j][k]->find_leaf_octree_cell( point );
| CubitVector CubitOctreeCell::get_center | ( | void | ) | [inline] |
Definition at line 63 of file CubitOctreeCell.hpp.
{ return mCenter; }
| CubitOctreeCell * CubitOctreeCell::get_child | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
Definition at line 327 of file CubitOctreeCell.cpp.
return ( children[i][j][k] );
| int CubitOctreeCell::get_color | ( | ) | [inline] |
Definition at line 168 of file CubitOctreeCell.hpp.
{return color;}
| int CubitOctreeCell::get_depth | ( | void | ) | [inline] |
Definition at line 54 of file CubitOctreeCell.hpp.
{ return depth; }
| double CubitOctreeCell::get_dimension | ( | void | ) | [inline] |
Definition at line 57 of file CubitOctreeCell.hpp.
{ return dimension; }
| DLIList<OctreeFacetPointData*>* CubitOctreeCell::get_facet_point_data_list | ( | ) | [inline] |
Definition at line 95 of file CubitOctreeCell.hpp.
return &octreeFacetPointDataList;
| CubitBoolean CubitOctreeCell::get_mark | ( | void | ) | [inline] |
Definition at line 102 of file CubitOctreeCell.hpp.
{ return mark; }
| CubitOctreeNode* CubitOctreeCell::get_octree_grid_node | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
| ) | [inline] |
Definition at line 66 of file CubitOctreeCell.hpp.
{ return cubitOctreeNode[i][j][k]; }
| CubitBoolean CubitOctreeCell::get_visit | ( | void | ) | [inline] |
Definition at line 105 of file CubitOctreeCell.hpp.
{ return visit; }
| int CubitOctreeCell::id | ( | void | ) | [inline] |
Definition at line 69 of file CubitOctreeCell.hpp.
{ return num; }
Definition at line 658 of file CubitOctreeCell.cpp.
float avg_size;
int counter;
int i,j,k;
avg_size = 0;
counter = 0;
//if( cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) != 0 && cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) != CUBIT_DBL_MAX ){
//if( cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) != 0.0 ){
if (cubitOctreeNode[i][j][k]->get_color() == CUBIT_BLACK_INDEX)
avg_size += cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT );
counter++;
if( counter == 0 ){
return CUBIT_FALSE;
avg_size /= counter;
//if( cubitOctreeNode[i][j][k]->get_color() == CUBIT_WHITE_INDEX ){
if( cubitOctreeNode[i][j][k]->get_color() != CUBIT_BLACK_INDEX ){
//if( cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) == 0.0 ){
cubitOctreeNode[i][j][k]->set_size( avg_size, OCTREE_SIZE_DEFAULT );
//else{
// cubitOctreeNode[i][j][k]->set_size( ( avg_size + cubitOctreeNode[i][j][k]->get_size( OCTREE_SIZE_DEFAULT ) ) / 2.0, OCTREE_SIZE_DEFAULT );
return CUBIT_TRUE;
| double CubitOctreeCell::inverse_distance_interpolation | ( | const CubitVector & | point | ) |
Definition at line 1003 of file CubitOctreeCell.cpp.
double size;
long double denominator=0;
long double nominator=0;
double weight;
long double dist_func;
CubitVector node_coord;
double dist;
int i, j, k;
int type = DEFAULT_INVERSE_DISTANCE_SCHEME_INSIDE_CELL;
if( get_octree_grid_node(i, j, k)->get_size(OCTREE_SIZE_DEFAULT) != 0.0 ){
node_coord = get_octree_grid_node(i, j, k)->get_coord();
dist = ( node_coord - point ).length();
if( dist < OCTREE_EPSILON )
dist = OCTREE_EPSILON;
switch( type ){
case INVERSE_LINEAR:
dist_func = dist;
break;
case INVERSE_QUADRATIC:
dist_func = dist * dist;
break;
case INVERSE_CUBIC:
dist_func = dist * dist * dist;
break;
default:
denominator += 1.0 / ( dist_func );
size = 0.0;
for( i = 0; i < 2; i ++ ){
node_coord = get_octree_grid_node(i,j,k)->get_coord();
switch( type ){
dist_func = dist;
break;
break;
case INVERSE_CUBIC:
break;
default:
nominator = 1.0 / ( dist_func );
weight = nominator / denominator ;
size += get_octree_grid_node(i,j,k)->get_size( OCTREE_SIZE_DEFAULT ) * weight;
//PRINT_DEBUG_157(" size at grid node = %f\n",get_octree_grid_node(i,j,k)->get_size( OCTREE_SIZE_DEFAULT ));
return size;
| CubitBoolean CubitOctreeCell::is_facet_point_data_present | ( | const CubitVector & | coord | ) |
Definition at line 565 of file CubitOctreeCell.cpp.
OctreeFacetPointData *facet_point_data;
int i;
if( (facet_point_data->coordinates() - coord ).length() < OCTREE_EPSILON ){
return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean CubitOctreeCell::is_facet_point_data_present | ( | OctreeFacetPointData * | new_facet_point_data | ) |
Definition at line 581 of file CubitOctreeCell.cpp.
int i;
if( facet_point_data->id() ==
new_facet_point_data->id() ){
return CUBIT_TRUE;
return CUBIT_FALSE;
| bool CubitOctreeCell::is_intersects_box | ( | const CubitBox & | box | ) |
Definition at line 447 of file CubitOctreeCell.cpp.
double x_min, x_max, y_min, y_max, z_min, z_max;
CubitVector box_min, box_max;
int I, II, III, IV;
//GfxDebug::draw_point( center.x(), center.y(), center.z(), CUBIT_RED_INDEX, itoa( num, buffer, 10 ) );
// DEBUG:
// changed from dimension -> dimenstion_2
double dimension_2 = dimension / 2.0;
x_min = mCenter.x() - dimension_2;
x_max = mCenter.x() + dimension_2;
y_min = mCenter.y() - dimension_2;
y_max = mCenter.y() + dimension_2;
z_min = mCenter.z() - dimension_2;
z_max = mCenter.z() + dimension_2;
box_min = box.minimum();
box_max = box.maximum();
//PRINT_DEBUG_157("Testing: Bbox of facet MIN = [ %2.2lf %2.2lf %2.2lf ] MAX = [ %2.2lf %2.2lf %2.2lf ]\n",box_min.x(), box_min.y(), box_min.z(), box_max.x(), box_max.y(), box_max.z() );
//PRINT_DEBUG_157("Testing: Cell MIN = [ %2.2lf %2.2lf %2.2lf ] MAX = [ %2.2lf %2.2lf %2.2lf ]\n",x_min, y_min, z_min, x_max, y_max, z_max );
// A represent min of cell and B represent max of cell
// C represent min of bbox and D represent max of bbox
// A < C => I
// B < C => II
// A < D => III
// B < D => IV
I = II = III = IV = -1;
if( x_max < box_min.x() ){
II = 1;
I = 1;
else{
if( x_min < box_min.x() ){
I = 1;
if( x_max <= box_max.x() ){
III = 1;
IV = 1;
else{
if( x_min <= box_max.x() ){
III = 1;
if( I * II == 1 && III * IV == 1 && I * III == 1 ){
//PRINT_DEBUG_157(" X No Intersection \n");
return CUBIT_FALSE;
if( y_max < box_min.y() ){
II = 1;
I = 1;
else{
if( y_min < box_min.y() ){
I = 1;
if( y_max <= box_max.y() ){
III = 1;
IV = 1;
else{
if( y_min <= box_max.y() ){
III = 1;
//PRINT_DEBUG_157(" Y No Intersection \n");
return CUBIT_FALSE;
if( z_max < box_min.z() ){
II = 1;
I = 1;
else{
if( z_min < box_min.z() ){
I = 1;
if( z_max <= box_max.z() ){
III = 1;
IV = 1;
else{
if( z_min <= box_max.z() ){
III = 1;
//PRINT_DEBUG_157(" Z No Intersection \n");
return CUBIT_FALSE;
//PRINT_DEBUG_157(" *********************** Intersection ************************* \n");
return CUBIT_TRUE;
| bool CubitOctreeCell::is_leaf | ( | void | ) | [inline] |
Definition at line 83 of file CubitOctreeCell.hpp.
{ return leaf; }
| void CubitOctreeCell::mark_color | ( | int | type | ) | [inline] |
Definition at line 162 of file CubitOctreeCell.hpp.
{ color = type; }
| double CubitOctreeCell::min_distance_interpolation | ( | const CubitVector & | point | ) |
Definition at line 1095 of file CubitOctreeCell.cpp.
double size;
double dist;
int i, j, k;
double min_dist = CUBIT_DBL_MAX;
size = 0.0;
if( dist < min_dist )
min_dist = dist;
size = get_octree_grid_node(i,j,k)->get_size( OCTREE_SIZE_DEFAULT );
return size;
| double CubitOctreeCell::min_size_interpolation | ( | const CubitVector & | point | ) |
Definition at line 1133 of file CubitOctreeCell.cpp.
int i, j, k;
double min_size = CUBIT_DBL_MAX;
double size;
if( size < OCTREE_EPSILON )
size = OCTREE_EPSILON;
if( size < min_size )
min_size = size;
return min_size;
| int CubitOctreeCell::num_of_facet_point_data | ( | void | ) | [inline] |
Definition at line 89 of file CubitOctreeCell.hpp.
{ return octreeFacetPointDataList.size(); }
| void CubitOctreeCell::release_octreefacetpointdata | ( | void | ) |
Definition at line 273 of file CubitOctreeCell.cpp.
int i, j, k;
children[i][j][k]->release_octreefacetpointdata( );
else{
| void CubitOctreeCell::set_child | ( | int | i, |
| int | j, | ||
| int | k, | ||
| CubitOctreeCell * | ptr_child_cell | ||
Definition at line 321 of file CubitOctreeCell.cpp.
children[i][j][k] = ptr_child_cell;
| void CubitOctreeCell::set_color_and_intersection_datas | ( | CubitFacet * | ptr_facet, |
| RefFace * | ptr_Ref_face, | ||
| CubitSense | surf_sense = CUBIT_FORWARD |
Definition at line 885 of file CubitOctreeCell.cpp.
int i, j, k;
CubitVector facet_normal = ptr_facet->normal();
//SVDrawTool::draw_vector(ptr_facet->center(),ptr_facet->center()+ptr_facet->normal(), CUBIT_MAGENTA_INDEX);
/* if( ptr_facet->is_backwards() ) // Ved: note to self - check this
facet_normal = facet_normal * -1;
// if (!myFacetList) {myFacetList = new DLIList</*CubitFacet*/OctreeIntersectionData*>;} uncomment later
// OctreeIntersectionData(CubitVector normal, int half_space, double len, RefFace *ptr_face, CubitVector closest_point_on_facet, CubitFacet *lp_facet);
/* CubitVector dummy;
OctreeIntersectionData *new_idata = new OctreeIntersectionData(dummy, 1, 0.0, ptr_Ref_face, dummy, ptr_facet);
myFacetList->append(new_idata);*/ // uncomment later
/* if (!myFaceList) {myFaceList = new DLIList<RefFace*>;}
if (!myFaceList->where_is_item(ptr_Ref_face))
myFaceList->append(ptr_Ref_face);
// bool merged = (CAST_TO(ptr_Ref_face, RefFace)->num_parent_ref_entities() == 2);
for (i=0; i < 2; ++i)
for (j=0; j < 2; ++j)
for (k=0; k < 2; ++k)
CubitVector closest_point_on_facet;
double dist_to_facet;
if (defaultDistanceMetric == CAPSULE_DIST) {dist_to_facet = CubitOctree::capsule_distance_to_facet(cubitOctreeNode[i][j][k]->get_coord(), ptr_facet, closest_point_on_facet);}
else if (defaultDistanceMetric == PROJECTED_DIST) {dist_to_facet = CubitOctree::capsule_distance_to_facet(cubitOctreeNode[i][j][k]->get_coord(), ptr_facet, closest_point_on_facet, CUBIT_TRUE);}
/*if (dist_to_facet < 0)
//PRINT_INFO("Invalid distance: %lf !!!!\n", dist_to_facet);
//SVDrawTool::draw_point(cubitOctreeNode[i][j][k]->get_coord(), CUBIT_MAGENTA_INDEX);
//double test_dist = CubitOctree::capsule_distance_to_facet(cubitOctreeNode[i][j][k]->get_coord(), ptr_facet, closest_point_on_facet);
OctreeIntersectionData *idata;
if (/*merged == CUBIT_TRUE*/ surf_sense == CUBIT_UNKNOWN)
CubitVector temp_facet_normal = facet_normal;
if (cubitOctreeNode[i][j][k]->get_halfspace_direction() == OCTREE_NEGATIVE)
temp_facet_normal *= -1.0;
// SVDrawTool::draw_point(cubitOctreeNode[i][j][k]->get_coord(), CUBIT_MAGENTA_INDEX);
idata = new OctreeIntersectionData(temp_facet_normal, OCTREE_NEGATIVE, dist_to_facet, ptr_Ref_face, closest_point_on_facet, ptr_facet);
idata->set_merged(1);
else
CubitBoolean temp_half_space = cubitOctreeNode[i][j][k]->get_halfspace_direction();
if (surf_sense == CUBIT_FORWARD) {temp_facet_normal *= -1.0;}
else if (surf_sense == CUBIT_REVERSED) {temp_half_space = !temp_half_space;}
idata = new OctreeIntersectionData(temp_facet_normal, temp_half_space, dist_to_facet, ptr_Ref_face, closest_point_on_facet, ptr_facet);
// idata->set_facet_ptr(ptr_facet);
// idata->set_int_point(closest_point_on_facet);
cubitOctreeNode[i][j][k]->append_list_item(idata);
#ifdef USE_octree_BGMESH
if (!visit)
greyCellList->append(this); // for background mesh generation
visit = CUBIT_TRUE;
#endif
| void CubitOctreeCell::set_leaf | ( | bool | type | ) | [inline] |
Definition at line 75 of file CubitOctreeCell.hpp.
{ leaf = type; }
| void CubitOctreeCell::set_mark | ( | CubitBoolean | type | ) | [inline] |
Definition at line 101 of file CubitOctreeCell.hpp.
{ mark = type; }
| void CubitOctreeCell::set_oct_grid_node | ( | const int | i, |
| const int | j, | ||
| const int | k, | ||
| CubitOctreeNode * | ptr_node | ||
Definition at line 316 of file CubitOctreeCell.cpp.
cubitOctreeNode[i][j][k] = ptr_node;
| void CubitOctreeCell::set_visit | ( | CubitBoolean | type | ) | [inline] |
Definition at line 104 of file CubitOctreeCell.hpp.
{ visit = type; }
| void CubitOctreeCell::subdivide_octree_based_on_point | ( | CubitPoint * | ptr_point | ) |
| double CubitOctreeCell::trilinear_interpolation | ( | const CubitVector & | point | ) |
Definition at line 713 of file CubitOctreeCell.cpp.
double size;
int i, j, k;
CubitVector center, min_corner, max_corner;
double dim, dim_2;
double Nx[2], Ny[2], Nz[2];
double size_at_node;
CubitOctreeNode *ptr_node;
// Find Shape functions at eight grid nodes of a cell
dim = get_dimension();
dim_2 = dimension / 2.0;
min_corner.x( center.x() - dim_2 );
min_corner.y( center.y() - dim_2 );
min_corner.z( center.z() - dim_2 );
max_corner.x( center.x() + dim_2 );
max_corner.y( center.y() + dim_2 );
max_corner.z( center.z() + dim_2 );
Nx[0] = ( max_corner.x() - point.x() ) / dim;
Ny[0] = ( max_corner.y() - point.y() ) / dim;
Nz[0] = ( max_corner.z() - point.z() ) / dim;
Nx[1] = ( point.x() - min_corner.x() ) / dim;
Ny[1] = ( point.y() - min_corner.y() ) / dim;
Nz[1] = ( point.z() - min_corner.z() ) / dim;
// Trilinear interpolation
// if number of nodes with zero size exceeds MAX_NUM_ZERO_SIZE_NODES
// then average size is used instead of zero
// Interpolate using non-zero nodes
size = 0.0;
int zero_node_counter = 0;
ptr_node = get_octree_grid_node(i, j, k);
size_at_node = ptr_node->get_size(OCTREE_SIZE_DEFAULT);
if( size_at_node != 0.0 ){
size += size_at_node * Nx[i] * Ny[j] * Nz[k];
else{
if( ptr_node->find_size_using_adj_node() == CUBIT_TRUE ){
size += ptr_node->get_size( OCTREE_SIZE_DEFAULT ) * Nx[i] * Ny[j] * Nz[k];
else{
zero_node_counter ++;
// For interior of volume avg_size will not be calculated
// as no zero size node exist
if( zero_node_counter > MAX_NUM_ZERO_SIZE_NODES ){
// Find Average size
double avg_size = 0.0;
int counter = 0;
size_at_node = get_octree_grid_node(i, j, k)->get_size(OCTREE_SIZE_DEFAULT);
avg_size += size_at_node;
counter ++;
if( counter > 0 ){
// use avg_size instead of zero during tri-linear interpolation
// only at nodes with zero size
if( size_at_node == 0.0 ){
size += avg_size * Nx[i] * Ny[j] * Nz[k];
else{
PRINT_DEBUG_157(" WARNING: Size of all nodes is zero \n" );
//In size at a point default auto size will be used
// autosize could be based on either average medial radius or
// steve's autosize function
return size;
| void CubitOctreeCell::write_octreecell_sizing_info_file | ( | FILE * | pof, |
| DLIList< CubitOctreeCell * > & | stack | ||
Definition at line 1187 of file CubitOctreeCell.cpp.
int index[3];
int i, j, k;
if( parent == NULL ){
fprintf( pof, "C %d -1 0 0 0 %d\n", num, !leaf );
else{
find_indices_in_parent( index );
fprintf( pof, "C %d %d %d %d %d %d \n", num, parent->id(), index[0], index[1], index[2], !leaf );
fprintf( pof, "V");
fprintf( pof," %d ", cubitOctreeNode[i][j][k]->get_num() );
fprintf( pof, "\n");
if( leaf == 0 ){
fprintf( pof, "H");
fprintf( pof," %d ", children[i][j][k]->id() );
stack.append( children[i][j][k] );
fprintf( pof, "E\n");
CubitOctreeCell* CubitOctreeCell::children[2][2][2] [private] |
Definition at line 205 of file CubitOctreeCell.hpp.
int CubitOctreeCell::color [private] |
Definition at line 188 of file CubitOctreeCell.hpp.
CubitOctreeNode* CubitOctreeCell::cubitOctreeNode[2][2][2] [private] |
Definition at line 197 of file CubitOctreeCell.hpp.
int CubitOctreeCell::depth [private] |
Definition at line 179 of file CubitOctreeCell.hpp.
double CubitOctreeCell::dimension [private] |
Definition at line 176 of file CubitOctreeCell.hpp.
CubitBoolean CubitOctreeCell::leaf [private] |
Definition at line 182 of file CubitOctreeCell.hpp.
CubitBoolean CubitOctreeCell::mark [private] |
Definition at line 191 of file CubitOctreeCell.hpp.
CubitVector CubitOctreeCell::mCenter [private] |
Definition at line 173 of file CubitOctreeCell.hpp.
DLIList<OctreeIntersectionData*>* CubitOctreeCell::myFacetList [private] |
Definition at line 211 of file CubitOctreeCell.hpp.
int CubitOctreeCell::num [private] |
Definition at line 185 of file CubitOctreeCell.hpp.
Definition at line 208 of file CubitOctreeCell.hpp.
CubitOctreeCell* CubitOctreeCell::parent [private] |
Definition at line 204 of file CubitOctreeCell.hpp.
CubitBoolean CubitOctreeCell::visit [private] |
Definition at line 194 of file CubitOctreeCell.hpp.
