cgma
#include <CubitSparseMatrix.hpp>
Public Member Functions | |
| CubitSparseMatrix () | |
| CubitSparseMatrix (int numRows, int numCols, std::vector< int > &is, std::vector< int > &js, std::vector< double > &es) | |
| ~CubitSparseMatrix () | |
| void | reset (int numRows, int numCols, std::vector< int > &is, std::vector< int > &js, std::vector< double > &es) |
| void | clear () |
| void | print (char *filename=0) const |
| void | add (int row, int col, double data) |
| int | num_non_zeros (void) const |
| void | num_non_zeros_per_row (double &ave, int &max, int &min) const |
| int | num_rows (void) const |
| int | num_cols (void) const |
| const std::map< int, double > * | get_row (int row) const |
| void | sub_matrix (const std::vector< bool > &rows_to_include, const std::vector< bool > &cols_to_include, CubitSparseMatrix &submatrix) |
| std::vector< double > | operator* (const std::vector< double > &vec) const |
| void | plus_identity () |
Private Member Functions | |
| void | delete_data (void) |
Private Attributes | |
| std::map< int, std::map< int, double > * > | matrixData |
| int | numRows |
| int | numCols |
Definition at line 18 of file CubitSparseMatrix.hpp.
Definition at line 49 of file CubitSparseMatrix.cpp.
| CubitSparseMatrix::CubitSparseMatrix | ( | int | numRows, |
| int | numCols, | ||
| std::vector< int > & | is, | ||
| std::vector< int > & | js, | ||
| std::vector< double > & | es | ||
Definition at line 141 of file CubitSparseMatrix.cpp.
delete_data();
| void CubitSparseMatrix::add | ( | int | row, |
| int | col, | ||
| double | data | ||
Definition at line 107 of file CubitSparseMatrix.cpp.
if ( row+1 > numRows ||
col+1 > numCols )
throw std::invalid_argument( "The dimensions of the 2 matrices must be the same." );
map<int,double> *submap = NULL;
map<int,map<int,double>*>::iterator iter = matrixData.find( row );
if ( iter == matrixData.end() )
submap = new map<int,double>;
matrixData.insert( std::pair<int, map<int,double>*>(row, submap) );
else
submap = iter->second;
map<int,double>::iterator iter2 = submap->find( col );
if ( iter2 != submap->end() )
iter2->second += data;
return;
submap->insert( std::pair<int, double>( col, data ) );
| void CubitSparseMatrix::clear | ( | ) |
Definition at line 94 of file CubitSparseMatrix.cpp.
numRows = 0;
numCols = 0;
delete_data();
| void CubitSparseMatrix::delete_data | ( | void | ) | [private] |
Definition at line 152 of file CubitSparseMatrix.cpp.
while ( !matrixData.empty() )
map<int,double> *submap = matrixData.begin()->second;
matrixData.begin()->second = NULL;
matrixData.erase( matrixData.begin() );
delete submap;
| const map< int, double > * CubitSparseMatrix::get_row | ( | int | row | ) | const |
Definition at line 300 of file CubitSparseMatrix.cpp.
if ( row < 0 || row >= numRows )
throw std::invalid_argument( "The row index must be greater than or equal to 0, and less than the number of rows in the matrix." );
map<int, map<int,double>*>::const_iterator iter = matrixData.find( row );
return NULL;
return iter->second;
| int CubitSparseMatrix::num_cols | ( | void | ) | const [inline] |
Definition at line 47 of file CubitSparseMatrix.hpp.
{ return numCols; };
| int CubitSparseMatrix::num_non_zeros | ( | void | ) | const |
Definition at line 418 of file CubitSparseMatrix.cpp.
int num_nz = 0;
map<int, map<int,double>*>::const_iterator iter1 = matrixData.begin();
while ( iter1 != matrixData.end() )
//iter1->first;
map<int,double>*submap = iter1->second;
if ( submap ) num_nz += submap->size();
iter1++;
return num_nz;
| void CubitSparseMatrix::num_non_zeros_per_row | ( | double & | ave, |
| int & | max, | ||
| int & | min | ||
| ) | const |
Definition at line 370 of file CubitSparseMatrix.cpp.
max = 0;
min = numCols;
ave = 0.0;
//iter1->first;
iter1++;
int nz = submap->size();
ave += nz;
if ( nz > max ) max = nz;
if ( nz < min ) min = nz;
if ( numCols > 0 )
ave /= numCols;
| int CubitSparseMatrix::num_rows | ( | void | ) | const [inline] |
Definition at line 46 of file CubitSparseMatrix.hpp.
{ return numRows; };
| vector< double > CubitSparseMatrix::operator* | ( | const std::vector< double > & | vec | ) | const |
Definition at line 259 of file CubitSparseMatrix.cpp.
if ( (int) vec.size() != numCols )
throw std::invalid_argument( "The length of the input vector must be the same as the number of colums in the matrix." );
vector<double> ans( numRows );
int i;
for ( i = 0; i < numRows; i++ )
ans[i] = 0.0;
int row = iter1->first;
iter1++;
map<int,double>::iterator iter2 = submap->begin();
while ( iter2 != submap->end() )
int col = iter2->first;
double data = iter2->second;
iter2++;
ans[row] += data * vec[col];
return ans;
| void CubitSparseMatrix::plus_identity | ( | ) |
Definition at line 403 of file CubitSparseMatrix.cpp.
| void CubitSparseMatrix::print | ( | char * | filename = 0 | ) | const |
Definition at line 319 of file CubitSparseMatrix.cpp.
printf( "CubitSparseMatrix::numRows: %d\n", numRows );
printf( "CubitSparseMatrix::numCols: %d\n", numCols );
int min, max;
double ave;
num_non_zeros_per_row( ave, max, min );
printf( "CubitSparseMatrix::Average # Non Zeros per row: %f\n", ave );
printf( "CubitSparseMatrix::Minimum # Non Zeros per row: %d\n", min );
printf( "CubitSparseMatrix::Maximum # Non Zeros per row: %d\n", max );
CubitFile fp;
if ( filename )
fp.open( filename, "w" );
iter1++;
iter2++;
if ( fp.file() )
fprintf( fp.file(), "%d %d %f\n",
row, col, data );
else
printf( "CubitSparseMatrix::(%d,%d) : %f\n",
row, col, data );
| void CubitSparseMatrix::reset | ( | int | numRows, |
| int | numCols, | ||
Definition at line 61 of file CubitSparseMatrix.cpp.
| void CubitSparseMatrix::sub_matrix | ( | const std::vector< bool > & | rows_to_include, |
| const std::vector< bool > & | cols_to_include, | ||
| CubitSparseMatrix & | submatrix | ||
Definition at line 172 of file CubitSparseMatrix.cpp.
if ( (int) rows_to_include.size() != numRows )
throw std::invalid_argument( "The length of rows_to_include must the the same as the number of rows in the matrix." );
if ( (int) cols_to_include.size() != numCols )
throw std::invalid_argument( "The length of cols_to_include must the the same as the number of colums in the matrix." );
vector<int> is;
vector<int> js;
vector<double> es;
int i;
int *row_indices = new int[numRows];
int *col_indices = new int[numCols];
int num_rows = 0;
int num_cols = 0;
if ( rows_to_include[i] )
row_indices[i] = num_rows;
num_rows++;
else
row_indices[i] = 0;
for ( i = 0; i < numCols; i++ )
if ( cols_to_include[i] )
col_indices[i] = num_cols;
num_cols++;
else
col_indices[i] = 0;
map<int, map<int,double>*>::iterator iter1 = matrixData.begin();
iter1++;
if ( !rows_to_include[row] )
continue;
iter2++;
if ( !cols_to_include[col] )
continue;
is.push_back( row_indices[row] );
js.push_back( col_indices[col] );
es.push_back( data );
delete [] col_indices;
delete [] row_indices;
submatrix.reset( num_rows, num_cols, is, js, es );
std::map< int, std::map< int, double> * > CubitSparseMatrix::matrixData [private] |
Definition at line 67 of file CubitSparseMatrix.hpp.
int CubitSparseMatrix::numCols [private] |
Definition at line 70 of file CubitSparseMatrix.hpp.
int CubitSparseMatrix::numRows [private] |
Definition at line 69 of file CubitSparseMatrix.hpp.
