cgma
Class for bounding boxes (primarily for "tight" bounding boxes). More...
#include <BoundingBoxTool.hpp>
Static Public Member Functions | |
| static CubitStatus | get_tight_bounding_box (DLIList< RefEntity * > &ref_entity_list, CubitVector ¢er, CubitVector axes[3], CubitVector &extension, double ang_facet_tol, double abs_facet_tol) |
| static CubitStatus | get_axis_bounding_box (DLIList< RefEntity * > &ref_entity_list, CubitVector ¢er, CubitVector axes[3], CubitVector &extension) |
| static CubitStatus | get_corner_points (CubitVector ¢er, CubitVector axes[3], CubitVector &extension, CubitVector &p1, CubitVector &p2, CubitVector &p3, CubitVector &p4, CubitVector &p5, CubitVector &p6, CubitVector &p7, CubitVector &p8) |
| Using the center, axes and extension, gets the 8 corners of the box. | |
| static CubitBoolean | get_use_triangles () |
| static void | set_use_triangles (CubitBoolean val) |
| static int | get_use_triangles_setting () |
| static void | set_use_triangles_setting (int val) |
| static CubitBoolean | get_use_curves () |
| static void | set_use_curves (CubitBoolean val) |
| static int | get_use_curves_setting () |
| static void | set_use_curves_setting (int val) |
| static CubitBoolean | get_use_vertices () |
| static void | set_use_vertices (CubitBoolean val) |
| static int | get_use_vertices_setting () |
| static void | set_use_vertices_setting (int val) |
| static void | initialize_settings () |
| Initialize all settings in this class. | |
Protected Member Functions | |
| ~BoundingBoxTool () | |
Static Private Member Functions | |
| static CubitStatus | append_ref_entity_points (DLIList< RefEntity * > &ref_entity_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol) |
| static CubitStatus | append_body_points (DLIList< Body * > &body_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol) |
| static CubitStatus | append_volume_points (DLIList< RefVolume * > &vol_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol) |
| static CubitStatus | append_curve_points (DLIList< RefEdge * > &ref_edge_list, DLIList< CubitVector * > &vec_list) |
| static CubitStatus | append_vertex_points (DLIList< RefVertex * > &ref_vertex_list, DLIList< CubitVector * > &vec_list) |
| static CubitStatus | append_surface_points (DLIList< RefFace * > &ref_face_list, DLIList< CubitVector * > &vec_list, double ang_tol, double abs_tol) |
| static CubitBoolean | expand_groups_in_list (DLIList< RefEntity * > &ref_entity_list) |
Static Private Attributes | |
| static CubitBoolean | useTriangles = CUBIT_TRUE |
| static CubitBoolean | useCurves = CUBIT_FALSE |
| static CubitBoolean | useVertices = CUBIT_FALSE |
Definition at line 25 of file BoundingBoxTool.hpp.
| BoundingBoxTool::~BoundingBoxTool | ( | ) | [protected] |
Definition at line 32 of file BoundingBoxTool.cpp.
| BoundingBoxTool::BoundingBoxTool | ( | ) | [protected] |
Definition at line 28 of file BoundingBoxTool.cpp.
| CubitStatus BoundingBoxTool::append_body_points | ( | DLIList< Body * > & | body_list, |
| DLIList< CubitVector * > & | vec_list, | ||
| double | ang_tol, | ||
| double | abs_tol | ||
| ) | [static, private] |
Definition at line 147 of file BoundingBoxTool.cpp.
int i;
Body *body_ptr;
DLIList<RefFace*> ref_face_list;
body_list.reset();
for( i=0; i<body_list.size(); i++ )
body_ptr = body_list.get_and_step();
DLIList<RefFace*> ref_face_list_tmp;
body_ptr->ref_faces( ref_face_list_tmp );
ref_face_list.merge_unique( ref_face_list_tmp );
append_surface_points( ref_face_list, vec_list, ang_tol, abs_tol);
return CUBIT_SUCCESS;
| CubitStatus BoundingBoxTool::append_curve_points | ( | DLIList< RefEdge * > & | ref_edge_list, |
| DLIList< CubitVector * > & | vec_list | ||
Definition at line 261 of file BoundingBoxTool.cpp.
// First grab all the vertices and append their coordinates to vec_list.
// Then do the curves, but just put inside points in. This avoids duplicate
// points at the vertices.
int i;
RefEdge *ref_edge_ptr;
DLIList<RefVertex*> ref_vertex_list;
ref_edge_list.reset();
for( i=0; i<ref_edge_list.size(); i++ )
ref_edge_ptr = ref_edge_list.get_and_step();
DLIList<RefVertex*> ref_vertex_list_temp;
ref_edge_ptr->ref_vertices( ref_vertex_list_temp );
ref_vertex_list.merge_unique( ref_vertex_list_temp );
append_vertex_points( ref_vertex_list, vec_list );
// Now add the *inside* curve points
int j, num_pnts;
GMem *g_mem = new GMem;
ref_edge_ptr->get_graphics( *g_mem );
num_pnts = g_mem->pointListCount;
GPoint* point_list = g_mem->point_list();
for( j=1; j<num_pnts-1; j++ )
CubitVector* cubit_vector_ptr = new CubitVector(
point_list[j].x, point_list[j].y, point_list[j].z );
vec_list.append( cubit_vector_ptr );
delete g_mem;
| CubitStatus BoundingBoxTool::append_ref_entity_points | ( | DLIList< RefEntity * > & | ref_entity_list, |
Definition at line 114 of file BoundingBoxTool.cpp.
DLIList<Body*> body_list;
CAST_LIST( ref_entity_list, body_list, Body );
if( body_list.size() )
append_body_points( body_list, vec_list, ang_facet_tol, abs_facet_tol );
DLIList<RefVolume*> vol_list;
CAST_LIST( ref_entity_list, vol_list, RefVolume );
if( vol_list.size() )
append_volume_points( vol_list, vec_list, ang_facet_tol, abs_facet_tol );
DLIList<RefFace*> surface_list;
CAST_LIST( ref_entity_list, surface_list, RefFace );
if( surface_list.size() )
append_surface_points( surface_list, vec_list, ang_facet_tol, abs_facet_tol );
DLIList<RefEdge*> curve_list;
CAST_LIST( ref_entity_list, curve_list, RefEdge );
if( curve_list.size() )
append_curve_points( curve_list, vec_list );
DLIList<RefVertex*> vertex_list;
CAST_LIST( ref_entity_list, vertex_list, RefVertex );
if( vertex_list.size() )
append_vertex_points( vertex_list, vec_list );
| CubitStatus BoundingBoxTool::append_surface_points | ( | DLIList< RefFace * > & | ref_face_list, |
Definition at line 197 of file BoundingBoxTool.cpp.
int i;
RefFace *ref_face_ptr;
DLIList<RefEdge*> ref_edge_list;
ref_face_list.reset();
for( i=0; i<ref_face_list.size(); i++ )
ref_face_ptr = ref_face_list.get_and_step();
if( useTriangles == CUBIT_TRUE )
int num_pnt;
ref_face_ptr->get_graphics( *g_mem, (int)ang_tol, abs_tol );
num_pnt = g_mem->pointListCount;
//int num_pnts = g_mem->point_list_size();
int y;
for( y=0; y<num_pnt; y++ )
point_list[y].x, point_list[y].y, point_list[y].z );
delete g_mem;
if( useCurves == CUBIT_TRUE )
// Grab the curves from the surface
DLIList<RefEdge*> ref_edge_list_tmp;
ref_face_ptr->ref_edges( ref_edge_list_tmp );
ref_edge_list.merge_unique( ref_edge_list_tmp );
// Only need vertices if both surfaces and curves are false
if( useTriangles == CUBIT_FALSE && useCurves == CUBIT_FALSE &&
useVertices == CUBIT_TRUE )
// Grab the vertices from the surface
DLIList<RefVertex*> ref_vertex_list_tmp;
ref_face_ptr->ref_vertices( ref_vertex_list_tmp );
ref_vertex_list.merge_unique( ref_vertex_list_tmp );
append_curve_points( ref_edge_list, vec_list );
| CubitStatus BoundingBoxTool::append_vertex_points | ( | DLIList< RefVertex * > & | ref_vertex_list, |
Definition at line 308 of file BoundingBoxTool.cpp.
int i;
RefVertex *ref_vertex_ptr;
ref_vertex_list.reset();
for( i=0; i<ref_vertex_list.size(); i++ )
ref_vertex_ptr = ref_vertex_list.get_and_step();
CubitVector coords = ref_vertex_ptr->coordinates();
CubitVector* cubit_vector_ptr = new CubitVector( coords );
| CubitStatus BoundingBoxTool::append_volume_points | ( | DLIList< RefVolume * > & | vol_list, |
Definition at line 172 of file BoundingBoxTool.cpp.
int i;
RefVolume *vol_ptr;
vol_list.reset();
for( i=0; i<vol_list.size(); i++ )
vol_ptr = vol_list.get_and_step();
vol_ptr->ref_faces( ref_face_list_tmp );
| CubitBoolean BoundingBoxTool::expand_groups_in_list | ( | DLIList< RefEntity * > & | ref_entity_list | ) | [static, private] |
Definition at line 394 of file BoundingBoxTool.cpp.
CubitBoolean group_found = CUBIT_FALSE;
// just have to step through original entity_list, not the expanded list
for (int i = ref_entity_list.size(); i>0; i--)
RefEntity *entity = ref_entity_list.get();
RefGroup *group = CAST_TO( entity, RefGroup );
if ( group )
ref_entity_list.remove();
group->expand_group( ref_entity_list );
group_found = CUBIT_TRUE;
else
ref_entity_list.step();
return group_found;
| CubitStatus BoundingBoxTool::get_axis_bounding_box | ( | DLIList< RefEntity * > & | ref_entity_list, |
| CubitVector & | center, | ||
| CubitVector | axes[3], | ||
| CubitVector & | extension | ||
| ) | [static] |
Convenience function to get an axis box in the same output format as a tight box.
Definition at line 68 of file BoundingBoxTool.cpp.
CubitBoolean bounding_box_found = CUBIT_FALSE;
CubitBox bounding_box;
// Expand out groups in the list
DLIList<RefEntity*> ref_entity_list_expanded = ref_entity_list;
expand_groups_in_list( ref_entity_list_expanded );
ref_entity_list_expanded.reset();
for( int i = ref_entity_list_expanded.size(); i>0; i-- )
RefEntity* ref_entity_ptr = ref_entity_list_expanded.get_and_step();
if( bounding_box_found == CUBIT_FALSE )
bounding_box = ref_entity_ptr->bounding_box();
bounding_box_found = CUBIT_TRUE;
else {
bounding_box |= ref_entity_ptr->bounding_box();
axes[0].set( 1.0, 0.0, 0.0 );
axes[1].set( 0.0, 1.0, 0.0 );
axes[2].set( 0.0, 0.0, 1.0 );
if( bounding_box_found )
extension.set( bounding_box.x_range()/2.0, bounding_box.y_range()/2.0,
bounding_box.z_range()/2.0 );
center = bounding_box.center();
else
extension.set( 0.0, 0.0, 0.0 );
center.set( 0.0, 0.0, 0.0 );
| CubitStatus BoundingBoxTool::get_corner_points | ( | CubitVector & | center, |
| CubitVector & | extension, | ||
| CubitVector & | p1, | ||
| CubitVector & | p2, | ||
| CubitVector & | p3, | ||
| CubitVector & | p4, | ||
| CubitVector & | p5, | ||
| CubitVector & | p6, | ||
| CubitVector & | p7, | ||
| CubitVector & | p8 | ||
| ) | [static] |
Definition at line 326 of file BoundingBoxTool.cpp.
double x = extension.x(); double y = extension.y(); double z = extension.z();
// Front, Bottom, Left
center.next_point( -axes[0], x, p1 ); p1.next_point( -axes[1], y, p1 );
p1.next_point( axes[2], z, p1 );
// Front, Top, Left
center.next_point( -axes[0], x, p2 ); p2.next_point( axes[1], y, p2 );
p2.next_point( axes[2], z, p2 );
// Front, Top, Right
center.next_point( axes[0], x, p3 ); p3.next_point( axes[1], y, p3 );
p3.next_point( axes[2], z, p3 );
// Front, Bottom, Right
center.next_point( axes[0], x, p4 ); p4.next_point( -axes[1], y, p4 );
p4.next_point( axes[2], z, p4 );
// Back, Bottom, Left
center.next_point( -axes[0], x, p5 ); p5.next_point( -axes[1], y, p5 );
p5.next_point( -axes[2], z, p5 );
// Back, Top, Left
center.next_point( -axes[0], x, p6 ); p6.next_point( axes[1], y, p6 );
p6.next_point( -axes[2], z, p6 );
// Back, Top, Right
center.next_point( axes[0], x, p7 ); p7.next_point( axes[1], y, p7 );
p7.next_point( -axes[2], z, p7 );
// Back, Bottom, Right
center.next_point( axes[0], x, p8 ); p8.next_point( -axes[1], y, p8 );
p8.next_point( -axes[2], z, p8 );
| CubitStatus BoundingBoxTool::get_tight_bounding_box | ( | DLIList< RefEntity * > & | ref_entity_list, |
| double | ang_facet_tol, | ||
| double | abs_facet_tol | ||
| ) | [static] |
Gets tightest box around the given entity list, using facets. Box is defined as center point, vector axes (unit vectors), and extension in each axis (x extension is 1/2 width of box, for example).
Definition at line 36 of file BoundingBoxTool.cpp.
DLIList<CubitVector*> vec_list;
// Get the facet points from all the objects in the list
append_ref_entity_points( ref_entity_list_expanded, vec_list, ang_facet_tol, abs_facet_tol );
// Get the smallest box that fits around the points making up the facetted geometry
AnalyticGeometryTool::instance()->get_tight_bounding_box( vec_list, center,
axes, extension );
// Free memory
for( int i=0; i<vec_list.size(); i++ )
vec_list.get_and_step();
delete cubit_vector_ptr;
| CubitBoolean BoundingBoxTool::get_use_curves | ( | ) | [static] |
If curves are used, curve tesselation points will be included in the point list used to calculate the tight bounding box. This includes the vertices on the ends of the curves. One use for this is to find a more accurate tight bounding box, since curve tessellations are typically more fine than surface tessellations. However, in practice, I would generally recommend just using surface tessellations. One special case is if the user sends in a list of curves as the criteria for the tight bounding box, the curve
Definition at line 440 of file BoundingBoxTool.cpp.
{return useCurves;}
| int BoundingBoxTool::get_use_curves_setting | ( | ) | [static] |
Definition at line 421 of file BoundingBoxTool.cpp.
{return useCurves;}
| CubitBoolean BoundingBoxTool::get_use_triangles | ( | ) | [static] |
If triangles are used, surface facet points will be included in the point list used to calculate the tight bounding box. This will include vertices and points on the curves. This is the default implementation.
Definition at line 434 of file BoundingBoxTool.cpp.
{return useTriangles;}
| int BoundingBoxTool::get_use_triangles_setting | ( | ) | [static] |
Definition at line 415 of file BoundingBoxTool.cpp.
| CubitBoolean BoundingBoxTool::get_use_vertices | ( | ) | [static] |
If vertices are used, vertex points will be included in the point list used to calculate the tight bounding box. In extremely large models, it could be advantageous to just use vertices. So the user would turn off both the surface and curve flags. One special case is if the user sends in a list of curves as the criteria for the tight bounding box, the curve tessellations are always used, even if the curve parameter is false and this parameter is true.
Definition at line 446 of file BoundingBoxTool.cpp.
{return useVertices;}
| int BoundingBoxTool::get_use_vertices_setting | ( | ) | [static] |
Definition at line 427 of file BoundingBoxTool.cpp.
| void BoundingBoxTool::initialize_settings | ( | ) | [static] |
Definition at line 373 of file BoundingBoxTool.cpp.
SettingHandler::instance()->add_setting("Tight Surface",
BoundingBoxTool::set_use_triangles_setting,
BoundingBoxTool::get_use_triangles_setting );
SettingHandler::instance()->add_setting("Tight Curve",
BoundingBoxTool::set_use_curves_setting,
BoundingBoxTool::get_use_curves_setting);
SettingHandler::instance()->add_setting("Tight Vertex",
BoundingBoxTool::set_use_vertices_setting,
BoundingBoxTool::get_use_vertices_setting);
| void BoundingBoxTool::set_use_curves | ( | CubitBoolean | val | ) | [static] |
Definition at line 443 of file BoundingBoxTool.cpp.
{useCurves=val;}
| void BoundingBoxTool::set_use_curves_setting | ( | int | val | ) | [static] |
Definition at line 424 of file BoundingBoxTool.cpp.
{useCurves = (val) ? CUBIT_TRUE : CUBIT_FALSE;}
| void BoundingBoxTool::set_use_triangles | ( | CubitBoolean | val | ) | [static] |
Definition at line 437 of file BoundingBoxTool.cpp.
{useTriangles=val;}
| void BoundingBoxTool::set_use_triangles_setting | ( | int | val | ) | [static] |
Definition at line 418 of file BoundingBoxTool.cpp.
{useTriangles = (val) ? CUBIT_TRUE : CUBIT_FALSE;}
| void BoundingBoxTool::set_use_vertices | ( | CubitBoolean | val | ) | [static] |
Definition at line 449 of file BoundingBoxTool.cpp.
{useVertices=val;}
| void BoundingBoxTool::set_use_vertices_setting | ( | int | val | ) | [static] |
Definition at line 430 of file BoundingBoxTool.cpp.
{useVertices = (val) ? CUBIT_TRUE : CUBIT_FALSE;}
CubitBoolean BoundingBoxTool::useCurves = CUBIT_FALSE [static, private] |
Definition at line 131 of file BoundingBoxTool.hpp.
CubitBoolean BoundingBoxTool::useTriangles = CUBIT_TRUE [static, private] |
Definition at line 130 of file BoundingBoxTool.hpp.
CubitBoolean BoundingBoxTool::useVertices = CUBIT_FALSE [static, private] |
Definition at line 132 of file BoundingBoxTool.hpp.
