cgma
#include <PST_Data.hpp>
Public Member Functions | |
| const CubitPlane & | plane () |
| CubitVector | normal () |
| double | bounding_length () |
| PST_CoEdge * | first_coedge () |
| void | append_points (DLIList< PST_Point * > &result_list) |
| PST_Point * | opposite (PST_Edge *edge) |
| PST_Edge * | opposite (PST_Point *point) |
| bool | two_edges (PST_Point *point, PST_Edge *&edge1, PST_Edge *&edge2) |
| bool | modified () |
| void | modified (bool b) |
| void | debug_draw (int color=1, bool flush=true) |
| int | validate (CubitBoolean print=CUBIT_FALSE) |
| void | print () |
Static Public Member Functions | |
| static void | debug_draw_faces (DLIList< PST_Face * > &list, int color, bool flush=true) |
Public Attributes | |
| int | mark |
| int | sequence |
| int | parent |
Private Member Functions | |
| PST_Face (PST_CoEdge *coedge) | |
| PST_Face (PST_CoEdge *coedge, PST_Face *split_from) | |
| ~PST_Face () | |
| bool | calculate_plane () |
Private Attributes | |
| PST_CoEdge * | coedge_ |
| CubitPlane | plane_ |
| cBit | modified_: 1 |
| cBit | update_plane_: 1 |
| cBit | private_mark_: 1 |
Friends | |
| class | PST_Edge |
| class | PST_Point |
Definition at line 369 of file PST_Data.hpp.
| PST_Face::PST_Face | ( | PST_CoEdge * | coedge | ) | [inline, private] |
Definition at line 425 of file PST_Data.hpp.
: mark(0), sequence(0), parent(0), coedge_(coedge), //boundary_(0), modified_(0), update_plane_(1), private_mark_(false) { }
| PST_Face::PST_Face | ( | PST_CoEdge * | coedge, |
| PST_Face * | split_from | ||
Definition at line 435 of file PST_Data.hpp.
: mark(0), sequence(0), parent(0), coedge_(coedge), //boundary_(split_from->boundary()), modified_(0), update_plane_(1), private_mark_(false) { split_from->modified(true); }
| PST_Face::~PST_Face | ( | ) | [inline, private] |
Definition at line 444 of file PST_Data.hpp.
{ assert( !coedge_ ); }
| void PST_Face::append_points | ( | DLIList< PST_Point * > & | result_list | ) |
Definition at line 88 of file PST_Data.cpp.
PST_CoEdge* ce = coedge_;
#ifndef NDEBUG
int debug = 0;
#endif
do
result_list.append( ce->end_point() );
ce = ce->next();
#ifndef NDEBUG
assert( ++debug < PST_MAX_LIST_LEN );
#endif
} while( ce != coedge_ );
| double PST_Face::bounding_length | ( | ) | [inline] |
Definition at line 574 of file PST_Data.hpp.
// The coedges appear to be stored in a circular list so
// get the length of the first edge and then iterate
PST_CoEdge* coe = this->first_coedge();
CubitVector pos1 = coe->start_coord();
CubitVector pos2 = coe->end_coord();
CubitVector dist = pos1 - pos2;
double length = dist.length_squared();
// start the chain at the next coedge
coe = coe->next();
// walk through the coedges till we get back to the first
// and find the minimum length edge
double l;
for ( ; coe != this->first_coedge(); coe = coe->next() )
dist = pos1 - pos2;
l = dist.length_squared();
if ( l < length)
length = l;
return sqrt(length);
| bool PST_Face::calculate_plane | ( | ) | [private] |
Definition at line 172 of file PST_Data.cpp.
update_plane_ = 0;
// Use Newell's method
CubitVector dif, sum, ref(0.,0.,0.);
CubitVector norm(0.,0.,0.);
// For each coedge...
int count = 0;
do
count++;
const CubitVector& pt1 = ce->start_coord();
const CubitVector& pt2 = ce->end_coord();
dif = pt2 - pt1;
sum = pt2 + pt1;
ref += pt1;
norm += CubitVector( dif.y()*sum.z(), dif.z()*sum.x(), dif.x()*sum.y() );
ce = ce->next();
assert( count < PST_MAX_LIST_LEN );
// Degenerate?
double len = norm.length();
if( len > CUBIT_RESABS )
double d = (ref % norm) / (count * len);
norm /= -len; //reverse and normalize
plane_.normal( norm );
plane_.coefficient( d );
return true;
else
plane_.normal( CubitVector(0.,0.,0.) );
plane_.coefficient( 0. );
return false;
| void PST_Face::debug_draw | ( | int | color = 1, |
| bool | flush = true |
Definition at line 629 of file PST_Data.cpp.
PST_CoEdge* coedge = first_coedge();
do
coedge->edge()->debug_draw( color, false );
coedge = coedge->next();
} while( coedge != first_coedge() );
if( flush ) GfxDebug::flush();
| void PST_Face::debug_draw_faces | ( | DLIList< PST_Face * > & | list, |
| int | color, | ||
| ) | [static] |
Definition at line 895 of file PST_Data.cpp.
for( int f = face_list.size(); f--; )
face_list.get_and_step()->debug_draw( color, false );
| PST_CoEdge* PST_Face::first_coedge | ( | ) | [inline] |
Definition at line 389 of file PST_Data.hpp.
{ return coedge_; }
| bool PST_Face::modified | ( | ) | [inline] |
Definition at line 400 of file PST_Data.hpp.
{ return modified_; }
| void PST_Face::modified | ( | bool | b | ) | [inline] |
Definition at line 403 of file PST_Data.hpp.
modified_ = b;
if( b ) update_plane_ = 1;
| CubitVector PST_Face::normal | ( | ) | [inline] |
Definition at line 383 of file PST_Data.hpp.
| PST_Point * PST_Face::opposite | ( | PST_Edge * | edge | ) |
Definition at line 105 of file PST_Data.cpp.
#ifndef NDEBUG
int debug = 0;
#endif
do
if( ce->edge() == edge )
return ce->next()->end_point();
ce = ce->next();
#ifndef NDEBUG
#endif
return 0;
| PST_Edge * PST_Face::opposite | ( | PST_Point * | point | ) |
Definition at line 125 of file PST_Data.cpp.
#ifndef NDEBUG
int debug = 0;
#endif
do
if( ce->start_point() == point )
return ce->next()->edge();
ce = ce->next();
#ifndef NDEBUG
#endif
return 0;
| const CubitPlane& PST_Face::plane | ( | ) | [inline] |
Definition at line 376 of file PST_Data.hpp.
if( update_plane_ )
calculate_plane();
return plane_;
| void PST_Face::print | ( | ) |
Definition at line 1211 of file PST_Data.cpp.
if( ! coedge_ )
PRINT_ERROR("Face %p has null coedge.\n", (void*)this);
return;
PRINT_INFO("Face CoEdge Edge Start Pt End Pt\n"
"---------- ----------- ----------- ----------- -----------\n" );
PST_CoEdge* coe = coedge_;
PRINT_INFO("%10p %10p %10p %10p %10p\n",
(void*)this, (void*)coe, (void*)coe->edge(), (void*)coe->start_point(), (void*)coe->end_point() );
coe = coe->next();
while( coe && coe != coedge_ )
PRINT_INFO(" %10p %10p %10p %10p\n",
coe = coe->next();
| bool PST_Face::two_edges | ( | PST_Point * | point, |
| PST_Edge *& | edge1, | ||
| PST_Edge *& | edge2 | ||
Definition at line 145 of file PST_Data.cpp.
e1 = e2 = 0;
#ifndef NDEBUG
int debug = 0;
#endif
do
if( ce->end_point() == point )
if( e1 || e2 )
return false;
e1 = ce->edge();
e2 = ce->next()->edge();
ce = ce->next();
#ifndef NDEBUG
#endif
return e1 && e2;
| int PST_Face::validate | ( | CubitBoolean | print = CUBIT_FALSE | ) |
Definition at line 1145 of file PST_Data.cpp.
if( !coedge_ )
if(print) PRINT_ERROR("Face %p has null loop.\n", (void*)this);
return 1;
int count = 0;
int result = 0;
do
if( count++ > PST_MAX_LIST_LEN )
if( print ) PRINT_ERROR("Face %p loop is infinite.\n", (void*)this);
result++;
break;
if( coe->face() != this )
if( print )
PRINT_ERROR("Loop for face %p contains face %p on edge %p.\n",
(void*)this, (void*)coe->face(), (void*)coe->edge() );
result++;
if( coe->edge() )
result += coe->edge()->validate( print );
else
if( print )
PRINT_ERROR("Coedge %p in face %p has null edge.\n", (void*)coe, (void*)this);
result++;
if( ! coe->next() )
if( print )
PRINT_ERROR("Null coedge after coedge %p in face %p.\n", (void*)coe, (void*)this );
result++;
break;
coe = coe->next();
} while( coe != coedge_ );
return result;
friend class PST_Edge [friend] |
Definition at line 371 of file PST_Data.hpp.
friend class PST_Point [friend] |
Definition at line 372 of file PST_Data.hpp.
PST_CoEdge* PST_Face::coedge_ [private] |
Definition at line 449 of file PST_Data.hpp.
| int PST_Face::mark |
Definition at line 417 of file PST_Data.hpp.
cBit PST_Face::modified_ [private] |
Definition at line 453 of file PST_Data.hpp.
| int PST_Face::parent |
Definition at line 421 of file PST_Data.hpp.
CubitPlane PST_Face::plane_ [private] |
Definition at line 450 of file PST_Data.hpp.
cBit PST_Face::private_mark_ [private] |
Definition at line 455 of file PST_Data.hpp.
Definition at line 419 of file PST_Data.hpp.
cBit PST_Face::update_plane_ [private] |
Definition at line 454 of file PST_Data.hpp.
