cgma
#include <FBRetriangulate.hpp>
Public Member Functions | |
| FBRetriangulate (std::vector< FB_Coord * > &my_verts, std::vector< FB_Triangle * > &my_tris, std::vector< int > &my_newfacets, std::vector< int > &my_newfacetsindex) | |
| FBRetriangulate (std::vector< FB_Coord * > &my_verts, std::vector< FB_Triangle * > &my_tris, std::vector< int > &my_newfacets) | |
| ~FBRetriangulate () | |
| CubitStatus | retriangulate_this_tri (int sequence, std::vector< FB_Edge * > &orphaned_edges) |
Private Types | |
| enum | WindingType { CCW = 0, CW = 1 } |
Private Member Functions | |
| void | make_vert_list () |
| CubitStatus | add_bdry_edges (std::vector< FB_Edge * > &orphaned_edges) |
| double | get_dist (double x0, double y0, double z0, double x1, double y1, double z1) |
| CubitStatus | remove_min_max () |
| void | add_edge_up (int v0, int seq) |
| void | add_edge_down (int v0, int seq) |
| bool | test_for_crossing (int v0, int v1, int v2, int v3) |
| void | add_tri_edge (int v0, int v1, int v0_type, int v1_type) |
| bool | get_a_chain (std::vector< int > *chainlist) |
| void | sort_vertstufflist_edges () |
| void | get_next_vert_in_chain (int &vthis, int &vprev, int direction) |
| void | add_this_bdry_edge (int v0, int v1, int v0_type, int v1_type) |
| void | classify_edges () |
| void | get_edge_indices (int v0, int v1, int v2, int parent, int &e0index, int &e1index, int &e2index) |
Private Attributes | |
| std::vector< FB_Coord * > | verts |
| std::vector< FB_Triangle * > * | tris |
| std::vector< int > * | newfacets |
| std::vector< int > * | newfacetsindex |
| int | p_dir |
| int | s_dir |
| WindingType | winding |
| FB_Triangle * | my_tri |
| std::vector< VertexStuff * > | vertstufflist |
Definition at line 35 of file FBRetriangulate.hpp.
enum FBRetriangulate::WindingType [private] |
| FBRetriangulate::FBRetriangulate | ( | std::vector< FB_Coord * > & | my_verts, |
| std::vector< FB_Triangle * > & | my_tris, | ||
| std::vector< int > & | my_newfacets, | ||
| std::vector< int > & | my_newfacetsindex | ||
Definition at line 45 of file FBRetriangulate.cpp.
| std::vector< int > & | my_newfacets | ||
Definition at line 58 of file FBRetriangulate.cpp.
Definition at line 70 of file FBRetriangulate.cpp.
| CubitStatus FBRetriangulate::add_bdry_edges | ( | std::vector< FB_Edge * > & | orphaned_edges | ) | [private] |
Definition at line 276 of file FBRetriangulate.cpp.
// For each triangle edge, make a list of pairs of edge points and
// vertex numbers that touch the edge. Then sort the list by distance
// from the start of the edge. (This was what we really put in the
// pair, not the point itself.) Finally, go through this sorted list
// and add edges to the edge_list. If the edge_list is empty, we
// still must add in the triangle edge itself.
CubitStatus status;
FB_Edge *edge;
std::list< std::pair<double,int> > edge0_list, edge1_list, edge2_list;
std::list< std::pair<double,int> >::iterator dp;
std::vector<FB_Edge*>::iterator dpe, dpe_orig;
double vx0, vy0, vz0, vx1, vy1, vz1, vx2, vy2, vz2, dist;
std::pair<double,int> mypair;
status = CUBIT_SUCCESS;
vx0 = verts[my_tri->v0]->coord[0];
vy0 = verts[my_tri->v0]->coord[1];
vz0 = verts[my_tri->v0]->coord[2];
vx1 = verts[my_tri->v1]->coord[0];
vy1 = verts[my_tri->v1]->coord[1];
vz1 = verts[my_tri->v1]->coord[2];
vx2 = verts[my_tri->v2]->coord[0];
vy2 = verts[my_tri->v2]->coord[1];
vz2 = verts[my_tri->v2]->coord[2];
dpe = my_tri->edge_list.begin();
while ( dpe != my_tri->edge_list.end() ) {
edge = *dpe;
dpe++;
if ( (edge->v0_type == INTERIOR_VERT) &&
(edge->v1_type == INTERIOR_VERT) )
continue;
if ( edge->v0_type == EDGE_0 ) {
dist = get_dist(vx0,vy0,vz0,verts[edge->v0]->coord[0],
verts[edge->v0]->coord[1],verts[edge->v0]->coord[2]);
edge0_list.push_back(std::pair<double,int>(dist,edge->v0));
} else if ( edge->v0_type == EDGE_1 ) {
dist = get_dist(vx1,vy1,vz1,verts[edge->v0]->coord[0],
edge1_list.push_back(std::pair<double,int>(dist,edge->v0));
} else if ( edge->v0_type == EDGE_2 ) {
dist = get_dist(vx2,vy2,vz2,verts[edge->v0]->coord[0],
edge2_list.push_back(std::pair<double,int>(dist,edge->v0));
if ( edge->v1_type == EDGE_0 ) {
dist = get_dist(vx0,vy0,vz0,verts[edge->v1]->coord[0],
verts[edge->v1]->coord[1],verts[edge->v1]->coord[2]);
edge0_list.push_back(std::pair<double,int>(dist,edge->v1));
} else if ( edge->v1_type == EDGE_1 ) {
dist = get_dist(vx1,vy1,vz1,verts[edge->v1]->coord[0],
edge1_list.push_back(std::pair<double,int>(dist,edge->v1));
} else if ( edge->v1_type == EDGE_2 ) {
dist = get_dist(vx2,vy2,vz2,verts[edge->v1]->coord[0],
edge2_list.push_back(std::pair<double,int>(dist,edge->v1));
edge0_list.sort();
edge1_list.sort();
edge2_list.sort();
// Now we have to remove all BDRY_EDGEs because they will be made anew
// in what follows. Erasing elements from a vector is inefficient, but
// this shouldn't happen often.
dpe_orig = my_tri->edge_list.end();
while ( dpe != dpe_orig ) {
edge = *dpe;
if ( edge->edge_type == BDRY_EDGE ) {
dpe = my_tri->edge_list.erase(dpe);
orphaned_edges.push_back(edge);
} else {
dpe++;
int newv0, newv1, newv0_type, newv1_type;
newv0_type = newv1_type = EDGE_0;
newv0 = my_tri->v0;
dp = edge0_list.begin();
while ( dp != edge0_list.end() ) {
mypair = *dp;
newv1 = mypair.second;
// It is possible to get the same vert more than once in the list.
// After sorting, they will be adjacent. The following if statement
// causes duplicate verts to be used only once.
if ( newv0 != newv1 ) {
add_this_bdry_edge(newv0,newv1,newv0_type,newv1_type);
newv0 = newv1;
dp++;
newv1 = my_tri->v1;
newv0_type = newv1_type = EDGE_1;
newv0 = my_tri->v1;
dp = edge1_list.begin();
while ( dp != edge1_list.end() ) {
mypair = *dp;
newv0 = newv1;
dp++;
newv1 = my_tri->v2;
newv0_type = newv1_type = EDGE_2;
newv0 = my_tri->v2;
dp = edge2_list.begin();
while ( dp != edge2_list.end() ) {
mypair = *dp;
newv0 = newv1;
dp++;
newv1 = my_tri->v0;
return status;
| void FBRetriangulate::add_edge_down | ( | int | v0, |
| int | seq | ||
| ) | [private] |
Definition at line 543 of file FBRetriangulate.cpp.
int i, k;
int v1, v0test, v1test, v0type, v1type;
bool foundit, crossed;
FB_Edge *edge;
std::vector<FB_Edge*>::iterator dpe;
v1 = 0; //To keep compiler from warning that v1 might be used uninitialized.
v1type = 0;
v0type = vertstufflist[seq]->v0type;
for ( k = seq-1; k > -1; k-- ) {
foundit = true;
v1 = vertstufflist[k]->v0;
if ( fabs(verts[v1]->coord[p_dir]-verts[v0]->coord[p_dir]) < EPSILON ) continue;
v1type = vertstufflist[k]->v0type;
// v0 to v1 is the putative new edge. Test whether it crosses
// any existing internal edge. Any such internal edge that it
// crosses has to have an endpoint higher than v1. If v1 is the
// next-to-top vertex, use it.
if ( k == 0 ) {
foundit = true;
add_tri_edge(v0,v1,v0type,v1type);
return;
for ( i = k-1; i > 0; i-- ) {
dpe = vertstufflist[i]->edge_list.begin();
while ( dpe != vertstufflist[i]->edge_list.end() ) {
edge = *dpe;
dpe++;
if ( (edge->v0_type != INTERIOR_VERT) &&
(edge->v1_type != INTERIOR_VERT) )
continue;
v0test = edge->v0;
v1test = edge->v1;
if ( (v0test == v1) || (v1test == v1) ) continue;
crossed = test_for_crossing(v0,v1,v0test,v1test);
if ( crossed == true ) {
foundit = false;
break;
if ( foundit == false ) break;
} // end of "for (i ...."
if ( foundit == true ) break;
| void FBRetriangulate::add_edge_up | ( | int | v0, |
| int | seq | ||
| ) | [private] |
Definition at line 492 of file FBRetriangulate.cpp.
unsigned int i, k;
FB_Edge *edge;
v1type = 0;
for ( k = seq+1; k < vertstufflist.size(); k++ ) {
foundit = true;
continue;
// v0 to v1 is the putative new edge. Test whether it crosses any
// existing internal edge. Any such internal edge that it crosses
// has to have an endpoint higher than v1. If v1 is the next-to-top
// vertex, use it.
if ( k == vertstufflist.size() - 1 ) {
foundit = true;
return;
for ( i = k+1; i < vertstufflist.size()-1; i++ ) {
edge = *dpe;
dpe++;
continue;
v0test = edge->v0;
v1test = edge->v1;
foundit = false;
break;
| void FBRetriangulate::add_this_bdry_edge | ( | int | v0, |
| int | v1, | ||
| int | v0_type, | ||
| int | v1_type | ||
| ) | [private] |
Definition at line 416 of file FBRetriangulate.cpp.
// Add an edge if it doesn't already exist.
bool ifoundit;
FB_Edge *edge, *new_edge;
ifoundit = false;
edge = *dpe;
if ( ( ((int)edge->v0 == v0) && ((int)edge->v1 == v1) ) ||
( ((int)edge->v0 == v1) && ((int)edge->v1 == v0) ) ) {
ifoundit = true;
break;
dpe++;
if ( ifoundit == false ) {
new_edge = new FB_Edge(v0,v1,v0_type,v1_type,true);
new_edge->edge_type = BDRY_EDGE;
my_tri->edge_list.push_back(new_edge);
| void FBRetriangulate::add_tri_edge | ( | int | v0, |
| int | v1, | ||
| int | v0_type, | ||
| int | v1_type | ||
| ) | [private] |
Definition at line 625 of file FBRetriangulate.cpp.
FB_Edge *edge;
unsigned int i;
edge = new FB_Edge(v0,v1,v0_type,v1_type,false);
edge->edge_type = INTERIOR_EDGE;
my_tri->edge_list.push_back(edge);
for ( i = 0; i < vertstufflist.size(); i++ ) {
if ( vertstufflist[i]->v0 == v0 ) {
vertstufflist[i]->edge_list.push_back(edge);
if ( vertstufflist[i]->v0 == v1 ) {
v1_type = vertstufflist[i]->v0type;
| void FBRetriangulate::classify_edges | ( | ) | [private] |
Definition at line 832 of file FBRetriangulate.cpp.
// Flag boundary edges as such.
FB_Edge *edge;
int type;
edge = *dpe;
(edge->v1_type != INTERIOR_VERT) ) {
if ( edge->v0_type == edge->v1_type )
else {
type = UNKNOWN;
switch( edge->v0_type ) {
case VERTEX_0:
if ( edge->v1_type != EDGE_1 ) {
type = BDRY_EDGE;
if ( edge->edge_type == INTERSECTION_EDGE) {
if ( edge->v1_type == VERTEX_1 )
my_tri->cubitedge0index = INTERSECTION_EDGE;
else if ( edge->v1_type == VERTEX_2 )
my_tri->cubitedge2index = INTERSECTION_EDGE;
break;
case VERTEX_1:
if ( edge->v1_type != EDGE_2 ) {
type = BDRY_EDGE;
my_tri->cubitedge1index = INTERSECTION_EDGE;
else if ( edge->v1_type == VERTEX_0 )
break;
case VERTEX_2:
if ( edge->v1_type != EDGE_0 ) {
type = BDRY_EDGE;
break;
case EDGE_0:
if ( (edge->v1_type == VERTEX_0) ||
(edge->v1_type == VERTEX_1) ) {
type = BDRY_EDGE;
break;
case EDGE_1:
if ( (edge->v1_type == VERTEX_1) ||
(edge->v1_type == VERTEX_2) ) {
type = BDRY_EDGE;
break;
case EDGE_2:
if ( (edge->v1_type == VERTEX_2) ||
(edge->v1_type == VERTEX_0) ) {
type = BDRY_EDGE;
break;
if ( type == BDRY_EDGE ) edge->edge_type = BDRY_EDGE;
} // else edge->edge_type = INTERIOR_EDGE;
dpe++;
| bool FBRetriangulate::get_a_chain | ( | std::vector< int > * | chainlist | ) | [private] |
Definition at line 645 of file FBRetriangulate.cpp.
bool status;
int vthis, vprev, vstart;
int direction;
FB_Edge *edge;
status = false;
// to keep compiler from warning that edge might be used uninitialized
edge = 0;
edge = *dpe;
dpe++;
// Skip edges that are not interior edges.
// if ( edge->v0_type == edge->v1_type ) continue;
if ( edge->edge_type == BDRY_EDGE ) continue;
if ( edge->num_times < 2 ) {
if ( (edge->edge_type == BDRY_EDGE) && (edge->num_times == 1) )
continue;
status = true;
edge->num_times++;
break;
if ( status == true ) {
if ( edge->num_times == 1 ) {
vthis = edge->v1;
vprev = edge->v0;
direction = 1;
} else {
vthis = edge->v0;
vprev = edge->v1;
direction = 1;
vstart = vprev;
chainlist->push_back(vthis);
while ( vthis != vstart ) {
get_next_vert_in_chain(vthis,vprev,direction);
if ( status == false ) { // There were no interior edges.
// So just go around the perimeter.
edge = *dpe;
if ( edge->num_times != 0 ) {
status = false;
return status;
edge->num_times = 1;
vthis = edge->v0;
vprev = edge->v1;
direction = 1;
vstart = vprev;
status = true;
return status;
| double FBRetriangulate::get_dist | ( | double | x0, |
| double | y0, | ||
| double | z0, | ||
| double | x1, | ||
| double | y1, | ||
| double | z1 | ||
| ) | [inline, private] |
Definition at line 62 of file FBRetriangulate.hpp.
return sqrt( (x1-x0)*(x1-x0) + (y1-y0)*(y1-y0) + (z1-z0)*(z1-z0) );
| void FBRetriangulate::get_edge_indices | ( | int | v0, |
| int | v1, | ||
| int | v2, | ||
| int | parent, | ||
| int & | e0index, | ||
| int & | e1index, | ||
| int & | e2index | ||
| ) | [private] |
Definition at line 916 of file FBRetriangulate.cpp.
std::vector<FB_Edge*>::iterator itt;
std::vector<FB_Triangle*>::iterator itp;
FB_Edge *edge;
int e_v0, e_v1, e_type, e_v0type, e_v1type;
itp = tris->begin();
itp += parent;
itt = (*itp)->edge_list.begin();
while ( itt != (*itp)->edge_list.end() ) {
edge = *itt;
e_v0 = edge->v0;
e_v1 = edge->v1;
e_v0type = edge->v0_type;
e_v1type = edge->v1_type;
e_type = edge->edge_type;
if ( ( (e_v0 == v0) && (e_v1 == v1) ) ||
( (e_v0 == v1) && (e_v1 == v0) ) ) {
if ( e_type == INTERSECTION_EDGE )
else if ( e_type == INTERIOR_EDGE )
e0index = 0;
else if ( (e_v0type == EDGE_0) || (e_v1type == EDGE_0) )
e0index = (*itp)->cubitedge0index;
else if ( (e_v0type == EDGE_1) || (e_v1type == EDGE_1) )
e0index = (*itp)->cubitedge1index;
else if ( (e_v0type == EDGE_2) || (e_v1type == EDGE_2) )
e0index = (*itp)->cubitedge2index;
else if ( ( (e_v0type == VERTEX_0) || (e_v0type == VERTEX_1) ) &
( (e_v1type == VERTEX_0) || (e_v1type == VERTEX_1) ) )
else if ( ( (e_v0type == VERTEX_1) || (e_v0type == VERTEX_2) ) &
( (e_v1type == VERTEX_1) || (e_v1type == VERTEX_2) ) )
e1index = (*itp)->cubitedge1index;
else if ( ( (e_v0type == VERTEX_2) || (e_v0type == VERTEX_0) ) &
( (e_v1type == VERTEX_2) || (e_v1type == VERTEX_0) ) )
e2index = (*itp)->cubitedge2index;
else if ( ( (e_v0 == v1) && (e_v1 == v2) ) ||
( (e_v0 == v2) && (e_v1 == v1) ) ) {
e1index = 0;
e1index = (*itp)->cubitedge0index;
e1index = (*itp)->cubitedge2index;
else if ( ( (e_v0 == v2) && (e_v1 == v0) ) ||
( (e_v0 == v0) && (e_v1 == v2) ) ) {
e2index = 0;
e2index = (*itp)->cubitedge0index;
e2index = (*itp)->cubitedge1index;
itt++;
| void FBRetriangulate::get_next_vert_in_chain | ( | int & | vthis, |
| int & | vprev, | ||
| int | direction | ||
| ) | [private] |
Definition at line 716 of file FBRetriangulate.cpp.
unsigned int i;
FB_Edge *edge;
std::vector<FB_Edge*>::iterator dpe, dpebegin, dpeend;
if ( vertstufflist[i]->v0 == (int)vthis ) break;
dpe = dpebegin = vertstufflist[i]->edge_list.begin();
dpeend = vertstufflist[i]->edge_list.end();
while ( dpe != dpeend ) {
edge = *dpe;
if ( (edge->v0 == vprev) || (edge->v1 == vprev) ) break;
dpe++;
if ( direction == 1 ) {
if ( dpe == dpebegin )
dpe = vertstufflist[i]->edge_list.end();
dpe--;
} else {
dpe++;
if ( dpe == dpeend )
dpe = dpebegin;
edge = *dpe;
vprev = vthis;
if ( vthis == edge->v1 ) {
// Swap the edge verts. We do this so that next time we see this
// edge we will know that it was oriented to point in the direction
// of the previous loop. Thus we will know to proceed in the
// opposite direction next time.
// (see edge->num_times test in get_a_chain().)
unsigned int vtemp;
vtemp = edge->v0;
edge->v0 = edge->v1;
edge->v1 = vtemp;
vtemp = edge->v0_type;
edge->v0_type = edge->v1_type;
edge->v1_type = vtemp;
vthis = edge->v1;
edge->num_times++;
| void FBRetriangulate::make_vert_list | ( | ) | [private] |
Definition at line 442 of file FBRetriangulate.cpp.
unsigned int i;
int v0, v1;
FB_Edge *edge;
VertexStuff *vstuff;
bool foundv0, foundv1;
edge = *dpe;
dpe++;
v0 = edge->v0;
v1 = edge->v1;
foundv0 = foundv1 = false;
foundv0 = true;
foundv1 = true;
if ( foundv0 == false ) {
vstuff = new VertexStuff(v0, edge->v0_type,verts[v0]->coord[p_dir],
verts[v0]->coord[s_dir]);
vstuff->edge_list.push_back(edge);
vertstufflist.push_back(vstuff);
if ( foundv1 == false ) {
vstuff = new VertexStuff(v1, edge->v1_type,verts[v1]->coord[p_dir],
verts[v1]->coord[s_dir]);
std::vector<VertexStuff* >::iterator vitbegin, vitend;
vitbegin = vertstufflist.begin();
vitend = vertstufflist.end();
std::sort(vitbegin,vitend,vertstuffcompfn_less());
| CubitStatus FBRetriangulate::remove_min_max | ( | ) | [private] |
Definition at line 225 of file FBRetriangulate.cpp.
CubitStatus status;
FB_Edge *edge;
bool goes_down, goes_up;
unsigned int i;
int this_vert, that_vert;
double this_vert_p_dir_coord, that_vert_p_dir_coord;
vstuff = vertstufflist[i];
if ( vstuff->v0type != INTERIOR_VERT ) continue;
goes_down = goes_up = false;
this_vert = vstuff->v0;
this_vert_p_dir_coord = verts[this_vert]->coord[p_dir];
dpe = vstuff->edge_list.begin();
while ( dpe != vstuff->edge_list.end() ) {
edge = *dpe;
dpe++;
if ( edge->v0 == this_vert ) that_vert = edge->v1;
else that_vert = edge->v0;
that_vert_p_dir_coord = verts[that_vert]->coord[p_dir];
if ( that_vert_p_dir_coord < this_vert_p_dir_coord )
goes_down = true;
else if ( that_vert_p_dir_coord > this_vert_p_dir_coord )
goes_up = true;
else {
double this_vert_s_dir_coord, that_vert_s_dir_coord;
this_vert_s_dir_coord = verts[this_vert]->coord[s_dir];
that_vert_s_dir_coord = verts[that_vert]->coord[s_dir];
if ( this_vert_s_dir_coord < that_vert_s_dir_coord )
goes_up = true;
else goes_down = true;
if ( goes_down == false ) {
add_edge_down(this_vert,i);
} else if ( goes_up == false ) {
add_edge_up(this_vert,i);
return status;
| CubitStatus FBRetriangulate::retriangulate_this_tri | ( | int | sequence, |
| std::vector< FB_Edge * > & | orphaned_edges | ||
Definition at line 75 of file FBRetriangulate.cpp.
CubitStatus status;
double xspan, yspan, zspan;
std::vector<FB_Triangle *>::iterator itt;
itt = tris->begin();
itt += sequence;
my_tri = *itt;
// tri = &itt;
xspan = my_tri->boundingbox.xmax - my_tri->boundingbox.xmin;
yspan = my_tri->boundingbox.ymax - my_tri->boundingbox.ymin;
zspan = my_tri->boundingbox.zmax - my_tri->boundingbox.zmin;
if ( ( fabs(my_tri->c) >= fabs(my_tri->a) ) &&
( fabs(my_tri->c) >= fabs(my_tri->b) ) ) {
p_dir = 1;
s_dir = 0;
if ( xspan > yspan ) {
p_dir = 0;
s_dir = 1;
else if ( fabs(my_tri->b) >= fabs(my_tri->a) ) {
p_dir = 2;
s_dir = 0;
if ( xspan > zspan ) {
p_dir = 0;
s_dir = 2;
else {
p_dir = 1;
s_dir = 2;
if ( zspan > yspan ) {
p_dir = 2;
s_dir = 1;
if ( p_dir == 0 ) {
if ( s_dir == 1 ) {
if ( my_tri->c > 0.0 )
winding = CCW;
else
winding = CW;
else if (s_dir == 2 ) {
if ( my_tri->b > 0.0 )
winding = CW;
else
winding = CCW;
else if ( p_dir == 1 ) {
if ( s_dir == 0 ) {
winding = CW;
else
winding = CCW;
if ( my_tri->a > 0.0 )
winding = CW;
else
winding = CCW;
else if ( p_dir == 2 ) {
if ( s_dir == 0 ) {
winding = CCW;
else
winding = CW;
else if (s_dir == 1 ) {
winding = CCW;
else
winding = CW;
else{
PRINT_ERROR("Unexpected result.\n");
return CUBIT_FAILURE;
//if ( winding == CCW ) winding = CW;
//else winding = CCW;
classify_edges();
// Add edges around the perimeter of the triangle to its edge list.
status = add_bdry_edges(orphaned_edges);
make_vert_list();
// Add internal edges where there is a local min or max
status = remove_min_max();
// Get the vertex chains that will be retriangulated.
bool chain_status = true;
sort_vertstufflist_edges();
std::vector<int> *chainlist = new std::vector<int>;
// std::vector<FB_Triangle* > new_tris;
unsigned int i, nfsize;
nfsize = newfacets->size();
while (chain_status == true ) {
chain_status = get_a_chain(chainlist);
if ( chain_status == false ) break;
FBTiler *tiler = new FBTiler(verts,p_dir,s_dir,sequence,
my_tri->a,my_tri->b,my_tri->c,newfacets);
status = tiler->Tile_Poly(chainlist);
delete tiler;
chainlist->clear();
delete chainlist;
unsigned int number_new;
int e0index, e1index, e2index;
number_new = newfacets->size() - nfsize;
if ( number_new > 0 ) {
std::vector<int>::iterator itp;
itp = newfacets->begin();
itp += nfsize;
for ( i = 0; i < number_new; i += 3 ) {
FB_Triangle *new_tri;
e0index = e1index = e2index = 0;
get_edge_indices(*itp,*(itp+1),*(itp+2),sequence,
e0index, e1index, e2index);
new_tri = new FB_Triangle(*itp,*(itp+1),*(itp+2),
sequence,my_tri->cubitsurfaceindex,
tris->push_back(new_tri);
itp += 3;
if ( newfacetsindex ) newfacetsindex->push_back(nfsize);
delete vertstufflist[i];
vertstufflist.clear();
return status;
| void FBRetriangulate::sort_vertstufflist_edges | ( | ) | [private] |
Definition at line 764 of file FBRetriangulate.cpp.
// For each vertex that has more than 2 edges, sort the edges in CCW order.
unsigned int i;
FB_Edge *edge;
double x0, y0, x1, y1, slope;
int v0;
unsigned int quadrant;
quadrant = 0; // Initialize so compiler won't warn.
if ( vertstufflist[i]->edge_list.size() > 2 ) {
v0 = vertstufflist[i]->v0;
x0 = verts[v0]->coord[p_dir];
y0 = verts[v0]->coord[s_dir];
edge = *dpe;
dpe++;
if ( edge->v0 == v0 ) {
x1 = verts[edge->v1]->coord[p_dir];
y1 = verts[edge->v1]->coord[s_dir];
} else {
x1 = verts[edge->v0]->coord[p_dir];
y1 = verts[edge->v0]->coord[s_dir];
if ( fabs(x1-x0) < EPSILON ) {
if ( y1 > y0 ) {
slope = CUBIT_DBL_MAX;
quadrant = 1;
} else {
slope = -CUBIT_DBL_MAX;
quadrant = 4;
} else {
slope = (y1-y0)/(x1-x0);
if ( (x1 >= x0) && (y1 >= y0) ) quadrant = 1;
else if ( (x1 < x0) && (y1 > y0) ) quadrant = 2;
else if ( (x1 <= x0) && (y1 <= y0) ) quadrant = 3;
else if ( (x1 > x0) && (y1 < y0) ) quadrant = 4;
edge->slope = slope;
edge->quadrant = quadrant;
// Now sort the edge list by the value of quadrant or slope.
// vertstufflist[i]->edge_list.sort(edgecompfn_less());
// vertstufflist[i]->edge_list.sort(edgecf_less);
// if ( winding == CW )
std::sort(dpebegin,dpeend,edgecompfn_less());
// else
// std::sort(dpebegin,dpeend,edgecompfn_more());
edge = *dpe;
dpe++;
| bool FBRetriangulate::test_for_crossing | ( | int | v0, |
| int | v1, | ||
| int | v2, | ||
| int | v3 | ||
| ) | [private] |
Definition at line 593 of file FBRetriangulate.cpp.
double x0, y0, x1, y1, x2, y2, x3, y3, dxa, dya, dxb, dyb, p01x, p01y;
double product, dasq, dbsq, prodsq;
double s, t;
x0 = verts[v0]->coord[p_dir]; y0 = verts[v0]->coord[s_dir];
x1 = verts[v1]->coord[p_dir]; y1 = verts[v1]->coord[s_dir];
x2 = verts[v2]->coord[p_dir]; y2 = verts[v2]->coord[s_dir];
x3 = verts[v3]->coord[p_dir]; y3 = verts[v3]->coord[s_dir];
dxa = x1 - x0; dya = y1 - y0;
dxb = x3 - x2; dyb = y3 - y2;
product = dxa*dyb - dya*dxb;
dasq = dxa*dxa + dya*dya;
dbsq = dxb*dxb + dyb*dyb;
prodsq = product*product;
if ( prodsq > EPSILON2*dasq*dbsq ) {
p01x = x2 - x0;
p01y = y2 - y0;
s = (p01x*dyb - p01y*dxb)/product;
if ( (s < 0.0) || (s > 1.0) ) return false;
t = (p01x*dya - p01y*dxa)/product;
if ( (t < 0.0) || (t > 1.0) ) return false;
return true;
FB_Triangle* FBRetriangulate::my_tri [private] |
Definition at line 58 of file FBRetriangulate.hpp.
std::vector<int>* FBRetriangulate::newfacets [private] |
Definition at line 53 of file FBRetriangulate.hpp.
std::vector<int>* FBRetriangulate::newfacetsindex [private] |
Definition at line 54 of file FBRetriangulate.hpp.
int FBRetriangulate::p_dir [private] |
Definition at line 55 of file FBRetriangulate.hpp.
int FBRetriangulate::s_dir [private] |
std::vector<FB_Triangle *>* FBRetriangulate::tris [private] |
Definition at line 52 of file FBRetriangulate.hpp.
std::vector<FB_Coord *> FBRetriangulate::verts [private] |
Definition at line 51 of file FBRetriangulate.hpp.
std::vector<VertexStuff* > FBRetriangulate::vertstufflist [private] |
Definition at line 59 of file FBRetriangulate.hpp.
WindingType FBRetriangulate::winding [private] |
Definition at line 57 of file FBRetriangulate.hpp.
