cgma
Tool to find surfaces and curves that overlap. More...
#include <SurfaceOverlapTool.hpp>
Public Member Functions | |
| CubitStatus | find_overlapping_surfaces (DLIList< RefFace * > &ref_face_list, DLIList< RefEntity * > &faces_to_draw, bool filter_slivers=false) |
| From the specified surfaces, find surfaces that overlap. | |
| CubitStatus | find_overlapping_surfaces (DLIList< Body * > &body_list, DLIList< RefEntity * > &faces_to_draw, bool filter_slivers=false) |
| From the specified bodies, find surfaces that overlap. | |
| CubitStatus | find_overlapping_surfaces (DLIList< RefFace * > &ref_face_list, DLIList< RefFace * > &ref_face_list1, DLIList< RefFace * > &ref_face_list2, DLIList< RefEntity * > &faces_to_draw, CubitBoolean show_messages=CUBIT_FALSE, bool filter_slivers=false) |
| CubitStatus | find_overlapping_surfaces (DLIList< Body * > &body_list, DLIList< RefFace * > &ref_face_list1, DLIList< RefFace * > &ref_face_list2, DLIList< RefEntity * > &faces_to_draw, CubitBoolean show_messages=CUBIT_FALSE, bool filter_slivers=false) |
| CubitStatus | find_candidate_surfaces_for_imprinting (DLIList< BodySM * > &body_list, DLIList< Surface * > &surface_list1, DLIList< Surface * > &surface_list2, double overlap_tol=-1.0, bool filter_slivers=false) |
| CubitStatus | find_overlapping_curves (DLIList< Surface * > &surf_list, DLIList< DLIList< Curve * > * > &overlapping_curve_lists, std::map< Curve *, DLIList< Curve * > * > &curve_to_list_map, std::multimap< BodySM *, CubitVector > &body_point_imprint_map) |
| From the specified surfaces, find overlapping curves. | |
| CubitStatus | find_overlapping_curves (DLIList< Curve * > &curve_list, DLIList< DLIList< Curve * > * > &overlapping_curve_lists, std::map< Curve *, DLIList< Curve * > * > &curve_to_list_map, std::multimap< BodySM *, CubitVector > &body_point_imprint_map, double overlap_tol=-1.0) |
| From the specified curves, find those that overlap. | |
| CubitStatus | find_overlapping_curves (DLIList< Body * > &bodies, std::multimap< RefEdge *, RefEdge * > &overlapping_edge_map, double maxgap=-1) |
| From the specified bodies, find curves that overlap. | |
| CubitStatus | find_overlapping_curves (DLIList< BodySM * > &bodies, DLIList< DLIList< Curve * > * > &overlapping_curve_lists, std::map< Curve *, DLIList< Curve * > * > &curve_to_list_map, std::multimap< BodySM *, CubitVector > &body_vertex_imprint_map, double overlap_tol) |
| CubitStatus | find_overlapping_curves (DLIList< RefFace * > &faces, std::multimap< RefEdge *, RefEdge * > &overlapping_edge_map, double maxgap=-1) |
| From the specified surfaces, find curves that overlap. | |
| CubitStatus | find_overlapping_curves (DLIList< RefEdge * > &edgelist, std::multimap< RefEdge *, RefEdge * > &overlapping_edge_map, double maxgap=-1) |
| From the specified curves, find curves that overlap. | |
| CubitStatus | find_overlapping_curves (DLIList< RefEdge * > &edges1, DLIList< RefEdge * > &edges2, std::multimap< RefEdge *, RefEdge * > &overlapping_edge_map, double maxgap=-1) |
| CubitBoolean | check_overlap (SurfaceOverlapFacet *facet1, SurfaceOverlapFacet *facet2, const double facet_compare_tol) |
| Checks to if two facets overlap. | |
| CubitBoolean | check_overlap (RefEdge *edge1, RefEdge *edge2, std::map< RefEdge *, DLIList< CurveOverlapFacet * > * > *facet_map, double *overlap_tol=NULL) |
| Checks to see if two curves overlap. Reuses graphic facets. | |
| CubitBoolean | check_overlap (RefFace *ref_face_ptr1, RefFace *ref_face_ptr2, CubitBoolean abort, CubitBoolean draw_overlap=CUBIT_FALSE, double *overlap_area=NULL) |
| Checks to see if two surfaces overlap. | |
| CubitBoolean | check_overlap (Curve *curve1, Curve *curve2, std::map< Curve *, DLIList< CurveOverlapFacet * > * > *facet_map, std::multimap< BodySM *, CubitVector > *body_point_imprint_map=NULL, double overlap_tol=-1.0) |
| CubitBoolean | check_boundary_contact (DLIList< SurfaceOverlapFacet * > *facet_list1, DLIList< SurfaceOverlapFacet * > *facet_list2, AbstractTree< SurfaceOverlapFacet * > *a_tree, const double facet_compare_tol, const double tmp_overlap_tol) |
| Checks for boundary contact between surfaces. | |
| CubitBoolean | check_size_and_swap_surfs (Surface *&tmp_surf1, Surface *&tmp_surf2, const double tolerance, const double facet_tol, DLIList< SurfaceOverlapFacet * > *&facet_list1, DLIList< SurfaceOverlapFacet * > *&facet_list2, std::map< Surface *, AbstractTree< SurfaceOverlapFacet * > * > *&a_tree_map, AbstractTree< SurfaceOverlapFacet * > *&a_tree2) |
| CubitBoolean | extract_surf_facets (Surface *surface1, Surface *surface2, std::map< Surface *, DLIList< SurfaceOverlapFacet * > * > *facet_map, const double tolerance, const double facet_tol, DLIList< SurfaceOverlapFacet * > *&facet_list1, DLIList< SurfaceOverlapFacet * > *&facet_list2) |
| CubitBoolean | calculate_tolerances_for_surf_intersection (Surface *tmp_surf1, Surface *tmp_surf2, DLIList< SurfaceOverlapFacet * > *facet_list1, DLIList< SurfaceOverlapFacet * > *facet_list2, std::map< Surface *, double > *area_map, double &facet_compare_tol, double &overlap_tolerance) |
| Determine tolerance for checking intersection between surfaces. | |
| CubitBoolean | check_overlap (DLIList< SurfaceOverlapFacet * > *facet_list1, DLIList< SurfaceOverlapFacet * > *facet_list2, AbstractTree< SurfaceOverlapFacet * > *a_tree, const double facet_tol, const double tolerance) |
| Checks for overlap betwen facet_lists of two surfaces. | |
| CubitBoolean | check_overlap (DLIList< SurfaceOverlapFacet * > *facet_list1, DLIList< SurfaceOverlapFacet * > *facet_list2, AbstractTree< SurfaceOverlapFacet * > *a_tree, CubitBoolean abort, CubitBoolean draw_overlap, double *overlap_area) |
| Checks to see the two groups of facets overlap. | |
| CubitBoolean | draw_overlapping_surface_pair (RefFace *ref_face_1, RefFace *ref_face_2) |
| Draws the overlapping surface pair. | |
| void | list_settings () |
| List the settings used for surface overlap detection. | |
| unsigned short | get_facet_ang_tol () |
| void | set_facet_ang_tol (unsigned short angle_tol) |
| CubitBoolean | get_skip_facing_surfaces () |
| void | set_skip_facing_surfaces (CubitBoolean setting) |
| ~SurfaceOverlapTool () | |
Static Public Member Functions | |
| static void | initialize_settings () |
| static int | get_facet_ang_tol_setting () |
| static void | set_facet_ang_tol_setting (int angle_tol) |
| static double | get_facet_abs_tol () |
| static void | set_facet_abs_tol (double absolute_tol) |
| static double | get_gap_min () |
| static void | set_gap_min (double val) |
| static double | get_gap_max () |
| static void | set_gap_max (double val) |
| static double | get_angle_min () |
| static void | set_angle_min (double val) |
| static double | get_angle_max () |
| static void | set_angle_max (double val) |
| static double | get_overlap_tolerance () |
| static void | set_overlap_tolerance (double val) |
| static int | get_normal_type () |
| static void | set_normal_type (int type) |
| static CubitString | get_normal_type_setting () |
| static void | set_normal_type_setting (CubitString type) |
| static CubitBoolean | get_group_results () |
| static void | set_group_results (CubitBoolean setting) |
| static CubitBoolean | get_list_pairs () |
| static void | set_list_pairs (CubitBoolean setting) |
| static CubitBoolean | get_display_pairs () |
| static void | set_display_pairs (CubitBoolean setting) |
| static int | get_group_results_setting () |
| static void | set_group_results_setting (int setting) |
| static int | get_list_pairs_setting () |
| static void | set_list_pairs_setting (int setting) |
| static int | get_display_pairs_setting () |
| static void | set_display_pairs_setting (int setting) |
| static CubitBoolean | get_imprint () |
| static void | set_imprint (CubitBoolean setting) |
| static CubitBoolean | get_check_within_bodies () |
| static void | set_check_within_bodies (CubitBoolean setting) |
| static CubitBoolean | get_check_across_bodies () |
| static void | set_check_across_bodies (CubitBoolean setting) |
| static SurfaceOverlapTool * | instance () |
| static void | delete_instance () |
Private Member Functions | |
| CubitStatus | find_overlapping_surfaces (DLIList< RefFace * > &ref_face_list, DLIList< RefFace * > &ref_face_list1, DLIList< RefFace * > &ref_face_list2, DLIList< RefEntity * > &pair_list, CubitBoolean list_pairs, int prog_step, bool filter_slivers=false) |
| double | find_area_overlap (SurfaceOverlapFacet *facet1, SurfaceOverlapFacet *facet2, const double facet_compare_tol) |
| CubitBoolean | check_surfs_for_imprinting (Surface *surface1, Surface *surface2, std::map< Surface *, DLIList< SurfaceOverlapFacet * > * > *facet_map, std::map< Surface *, double > *area_map, std::map< Surface *, AbstractTree< SurfaceOverlapFacet * > * > *a_tree_map, double overlap_tol=-1.0) |
| CubitStatus | imprint (DLIList< RefFace * > &ref_face_list1, DLIList< RefFace * > &ref_face_list2) |
| int | num_descendants (Body *body) |
| CubitStatus | copy_edges_in_list (DLIList< RefEdge * > &old_list, DLIList< RefEdge * > &new_list) |
| CubitStatus | delete_edges_in_list (DLIList< RefEdge * > &edge_list) |
Static Private Attributes | |
| static SurfaceOverlapTool * | instance_ = 0 |
| static unsigned short | facetAngTol = 15 |
| static double | facetAbsTol = 0.0 |
| static double | gapMin = 0.0 |
| static double | gapMax = 0.01 |
| static int | normalType = 1 |
| static CubitBoolean | groupResults = CUBIT_TRUE |
| Controls if surfaces are put in a group or not. | |
| static CubitBoolean | listPairs = CUBIT_TRUE |
| Prints out the lists of overlapping surface pairs. | |
| static CubitBoolean | displayPairs = CUBIT_TRUE |
| Draws the lists of overlapping surface pairs. | |
| static CubitBoolean | imprintResults = CUBIT_FALSE |
| Imprint overlapping surfaces parts onto one another. | |
| static double | overlapTolerance = .001 |
| static CubitBoolean | skipFacingSurfaces = CUBIT_FALSE |
| if the normalType is 2 skip surfaces that face each other | |
| static CubitBoolean | checkWithinBodies = CUBIT_FALSE |
| static CubitBoolean | checkAcrossBodies = CUBIT_TRUE |
| static double | angleMin = 0.0 |
| static double | angleMax = 5.0 |
Definition at line 21 of file SurfaceOverlapTool.hpp.
Definition at line 88 of file SurfaceOverlapTool.cpp.
| SurfaceOverlapTool::SurfaceOverlapTool | ( | ) | [private] |
Definition at line 68 of file SurfaceOverlapTool.cpp.
facetAbsTol = 0.0; // Use default
facetAngTol = 10; // Seems to work pretty good
gapMin = 0.0;
gapMax = 0.01;
angleMin = 0.0;
angleMax = 5.0;
normalType = 1; // 1=any, 2=opposite, 3=same
groupResults = CUBIT_TRUE;
listPairs = CUBIT_TRUE;
displayPairs = CUBIT_TRUE;
overlapTolerance = .001;
imprintResults = CUBIT_FALSE;
checkWithinBodies = CUBIT_FALSE;
checkAcrossBodies = CUBIT_TRUE;
skipFacingSurfaces = CUBIT_FALSE;
| CubitBoolean SurfaceOverlapTool::calculate_tolerances_for_surf_intersection | ( | Surface * | tmp_surf1, |
| Surface * | tmp_surf2, | ||
| DLIList< SurfaceOverlapFacet * > * | facet_list1, | ||
| DLIList< SurfaceOverlapFacet * > * | facet_list2, | ||
| std::map< Surface *, double > * | area_map, | ||
| double & | facet_compare_tol, | ||
| double & | overlap_tolerance | ||
Definition at line 942 of file SurfaceOverlapTool.cpp.
//set ovelap tolerance to one thousandth of the smaller area.
double face1_area, face2_area;
if( area_map )
std::map<Surface*, double>::iterator area_iter;
area_iter = area_map->find( tmp_surf1);
if( area_iter == area_map->end() )
face1_area = tmp_surf1->measure();
area_map->insert( std::map<Surface*, double>::value_type( tmp_surf1, face1_area ) );
else
face1_area = area_iter->second;
area_iter = area_map->find( tmp_surf2);
face2_area = tmp_surf2->measure();
area_map->insert( std::map<Surface*, double>::value_type( tmp_surf2, face2_area ));
else
face2_area = area_iter->second;
else
bool sample_deviation = false;
Surface *larger_surface = NULL;
//if the surfaces are non planar and one is much bigger than the other one...
//adjust the tolerance some
if( (tmp_surf1->geometry_type() != PLANE_SURFACE_TYPE &&
tmp_surf2->geometry_type() != PLANE_SURFACE_TYPE) )
double length1 = tmp_surf1->bounding_box().diagonal().length();
double length2 = tmp_surf2->bounding_box().diagonal().length();
double ratio = 0;
if(length1 > length2)
ratio = length1/length2;
larger_surface = tmp_surf1;
else
ratio = length2/length1;
larger_surface = tmp_surf2;
if( ratio > 50 )
sample_deviation = true;
if( face1_area < face2_area )
overlap_tolerance = face1_area * 0.001;
else
overlap_tolerance = face2_area * 0.001;
//If you're comparing overlap between a large surface and a very small one,
//you might have to adjust tolerances because of the faceting. Here we try
//to determine the deviation of the faceting of the larger surface. I
//take the mid point of the smallest edge on the facet, thinking the smallest
//edge is approximating high curvature so it would deviate the most and thus
//provide the safest tolerance.
int i;
if( sample_deviation )
DLIList<SurfaceOverlapFacet*> *tmp_facet_list = NULL;
if( larger_surface == tmp_surf1 )
tmp_facet_list = facet_list1;
else
tmp_facet_list = facet_list2;
for( i=tmp_facet_list->size(); i--; )
SurfaceOverlapFacet *tmp_facet = tmp_facet_list->get_and_step();
//we used to be lucky, where one seventh of the facets would give us a
//decent tolerance...this doesn't work now....not robust enough
// if( (i%7) == 0) // commenting this out....sometimes you haveto
CubitVector point = tmp_facet->smallest_edge_midpoint();
//determine distance between surface and centroid
CubitVector tmp_point;
larger_surface->closest_point_trimmed( point, tmp_point );
double tmp_distance = point.distance_between( tmp_point );
if( tmp_distance > facet_compare_tol )
facet_compare_tol = tmp_distance;
else
for( i=facet_list1->size(); i--; )
facet_compare_tol += facet_list1->get_and_step()->bounding_box().diagonal().length();
for( i=facet_list2->size(); i--; )
facet_compare_tol += facet_list2->get_and_step()->bounding_box().diagonal().length();
if( facet_list1->size() || facet_list2->size() )
facet_compare_tol /= (facet_list1->size() + facet_list2->size() );
facet_compare_tol *= 0.0025;
//if the merge tolerance is a larger, use it
double tolerance = GeometryQueryTool::get_geometry_factor()*GEOMETRY_RESABS;
if( tolerance > facet_compare_tol )
facet_compare_tol = tolerance;
return CUBIT_TRUE;
| CubitBoolean SurfaceOverlapTool::check_boundary_contact | ( | DLIList< SurfaceOverlapFacet * > * | facet_list1, |
| AbstractTree< SurfaceOverlapFacet * > * | a_tree, | ||
| const double | facet_compare_tol, | ||
| const double | tmp_overlap_tol | ||
Definition at line 1140 of file SurfaceOverlapTool.cpp.
int i, j;
facet_list1->reset();
SurfaceOverlapFacet *facet1 = facet_list1->get_and_step();
CubitBox facet1_bbox = facet1->bounding_box();
DLIList<SurfaceOverlapFacet*> close_facets;
if( a_tree )
a_tree->find( facet1_bbox, close_facets );
facet_list2 = &close_facets;
facet_list2->reset();
for( j=facet_list2->size(); j--; )
SurfaceOverlapFacet *facet2 = facet_list2->get_and_step();
// Check boundary contact
// If triangle bounding boxes don't intersect - no overlap
if( facet1->bbox_overlap( facet_compare_tol, *facet2 ) )
// Check distance between triangles, must be within criteria
double dist = facet1->distance( *facet2 );
if( dist >= gapMin && dist <= facet_compare_tol )
return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean SurfaceOverlapTool::check_overlap | ( | SurfaceOverlapFacet * | facet1, |
| SurfaceOverlapFacet * | facet2, | ||
| const double | facet_compare_tol | ||
| CubitBoolean SurfaceOverlapTool::check_overlap | ( | RefEdge * | edge1, |
| RefEdge * | edge2, | ||
| std::map< RefEdge *, DLIList< CurveOverlapFacet * > * > * | facet_map, | ||
| double * | overlap_tol = NULL |
Definition at line 2489 of file SurfaceOverlapTool.cpp.
//if edges are not splines and are not of the same type,
//they won't overlap
if( (edge1->get_curve_ptr()->geometry_type() != SPLINE_CURVE_TYPE &&
edge2->get_curve_ptr()->geometry_type() != SPLINE_CURVE_TYPE) &&
edge2->get_curve_ptr()->geometry_type() ))
return CUBIT_FALSE;
// we don't want to consider edges from the same body
if (edge1->body() == edge2->body())
return CUBIT_FALSE;
if( overlap_tol )
tolerance = *overlap_tol;
std::map<RefEdge*, DLIList<CurveOverlapFacet*>* >::iterator facet_iterator;
CubitBox edge_box1 = edge1->bounding_box();
CubitBox edge_box2 = edge2->bounding_box();
//do bounding boxes overlap
if( edge_box1.overlap( tolerance, edge_box2 ) )
//curves must overlap at least by 100th of the smaller curve's length
double min_overlap = 0.0;
double edge1_length = edge1->measure();
double edge2_length = edge2->measure();
if( edge1_length < edge2_length )
min_overlap = edge1->measure() * 0.01;
else
min_overlap = edge2->measure() * 0.01;
DLIList<CurveOverlapFacet*> *facet_list1 = NULL;
DLIList<CurveOverlapFacet*> *facet_list2 = NULL;
//see if edge is in map...if not we have to create faceting for it.
if( facet_map )
facet_iterator = facet_map->find( edge1 );
if( facet_map == NULL || facet_iterator == facet_map->end() )
facet_list1 = new DLIList<CurveOverlapFacet*>;
GMem curve_graphics;
edge1->get_graphics( curve_graphics );
GPoint *points = curve_graphics.point_list();
int num_points = curve_graphics.pointListCount;
int kk;
for( kk=0; kk<num_points-1; kk++ )
//create a new CurveOverlapFacets
GPoint gpoints[2];
gpoints[0] = points[kk];
gpoints[1] = points[kk + 1];
CurveOverlapFacet *tmp_facet = new CurveOverlapFacet( gpoints );
facet_list1->append( tmp_facet );
if( facet_map )
facet_map->insert( std::map<RefEdge*,
DLIList<CurveOverlapFacet*>*>::value_type( edge1, facet_list1 ));
else
facet_list1 = (*facet_iterator).second;
//see if edge is in map...if not we have to create facet for it.
if( facet_map )
facet_iterator = facet_map->find( edge2 );
facet_list2 = new DLIList<CurveOverlapFacet*>;
edge2->get_graphics( curve_graphics );
int kk;
GPoint gpoints[2];
facet_list2->append( tmp_facet );
if( facet_map )
DLIList<CurveOverlapFacet*>*>::value_type( edge2, facet_list2 ));
else
facet_list2 = (*facet_iterator).second;
//compare smaller list to larger list...want list1 to be smaller
if( facet_list1->size() > facet_list2->size() )
DLIList<CurveOverlapFacet*> *tmp_list = facet_list1;
facet_list1 = facet_list2;
facet_list2 = tmp_list;
int kk;
double total_overlap = 0.0;
bool overlap = false;
//now determine if enough curve facets overlap
for( kk=facet_list1->size(); kk--; )
CurveOverlapFacet *curr_facet = facet_list1->get_and_step();
//do bounding boxes of facets overlap?
int jj;
for( jj=facet_list2->size(); jj--; )
CurveOverlapFacet *other_facet = facet_list2->get_and_step();
if( curr_facet->bbox_overlap( tolerance, other_facet ) )
if( curr_facet->facet_to_facet_distance( other_facet ) < tolerance )
//are facets parallel within some tolerance angle?
double angle = curr_facet->angle( other_facet );
if( angle < 1 || fabs(180-angle ) < 1 )
double overlap_tolerance =
curr_facet->length() < other_facet->length() ? curr_facet->length():
other_facet->length();
overlap_tolerance *= 0.01;
//how much of the facet overlaps?
double tmp_overlap = curr_facet->distance_overlapping( other_facet ) ;
if( tmp_overlap > overlap_tolerance )
total_overlap += tmp_overlap;
if( total_overlap > min_overlap )
if( facet_map == NULL )
//clean up facets and list
int i;
delete facet_list1->get_and_step();
delete facet_list2->get_and_step();
delete facet_list1;
delete facet_list2;
overlap = true;
break;
if( overlap == true )
break;
if( overlap == false )
return CUBIT_FALSE;
if( edge1->get_curve_ptr()->geometry_type() == SPLINE_CURVE_TYPE ||
edge2->get_curve_ptr()->geometry_type() == SPLINE_CURVE_TYPE )
//measure between the 2 curves
double dist_between_edges = 0;
CubitVector point_on_edge1, point_on_edge2;
GeometryQueryTool::instance()->entity_entity_distance( edge1, edge2,
point_on_edge1, point_on_edge2, dist_between_edges );
if( dist_between_edges > tolerance )
return CUBIT_FALSE;
//the curvature at the same spot on the curve could be almost the same
//if curvature's at midpoint are not the same, they don't overlap
CubitVector curvature1, curvature2;
CubitVector tangent, closest_location;
edge1->closest_point( point_on_edge1, closest_location, &tangent, &curvature1 );
edge2->closest_point( point_on_edge2, closest_location, &tangent, &curvature2 );
double rad1 = curvature1.length();
double rad2 = curvature2.length();
//if curvatures are more than 10% off
double curvature_diff = fabs( rad1 - rad2 );
if( (rad1 || rad2 ) &&
(rad1 > GEOMETRY_RESABS || //radii must be of significance even look at
rad2 > GEOMETRY_RESABS ))
if( curvature_diff/( (fabs(rad1) + fabs(rad2))/2 ) > 0.1 )
return CUBIT_FALSE;
else
return CUBIT_TRUE;
else
return CUBIT_FALSE;
return CUBIT_TRUE;
| CubitBoolean SurfaceOverlapTool::check_overlap | ( | RefFace * | ref_face_ptr1, |
| RefFace * | ref_face_ptr2, | ||
| CubitBoolean | abort, | ||
| CubitBoolean | draw_overlap = CUBIT_FALSE, |
| double * | overlap_area = NULL |
Definition at line 1292 of file SurfaceOverlapTool.cpp.
if( ref_face_ptr1 == ref_face_ptr2 )
return CUBIT_FALSE;
//if surfaces are not splines and are not of the same type,
I am commenting this out because it filters out some cases we need to find with
this overlap check.
if( (ref_face_ptr1->get_surface_ptr()->geometry_type() != SPLINE_SURFACE_TYPE &&
ref_face_ptr2->get_surface_ptr()->geometry_type() != SPLINE_SURFACE_TYPE) &&
ref_face_ptr2->get_surface_ptr()->geometry_type() ))
return CUBIT_FALSE;
AnalyticGeometryTool::instance();
abort = CUBIT_FALSE;
// Check for overlap between the found surfaces using the facets
TDSurfaceOverlap *tdso_1;
tdso_1 = (TDSurfaceOverlap *)ref_face_ptr1->get_TD(&TDSurfaceOverlap::is_surface_overlap);
if( !tdso_1 )
ref_face_ptr1->add_TD( new TDSurfaceOverlap( ref_face_ptr1, facetAngTol, facetAbsTol,
gapMax ) );
TDSurfaceOverlap *tdso_2;
tdso_2 = (TDSurfaceOverlap *)ref_face_ptr2->get_TD(&TDSurfaceOverlap::is_surface_overlap);
if( !tdso_2 )
ref_face_ptr2->add_TD( new TDSurfaceOverlap( ref_face_ptr2, facetAngTol, facetAbsTol,
gapMax ) );
// Check if within the same body - maybe we don't need to consider this
if( checkWithinBodies == CUBIT_FALSE )
DLIList<Body*> *body_list_ptr1, *body_list_ptr2;
body_list_ptr1 = tdso_1->get_body_list();
body_list_ptr2 = tdso_2->get_body_list();
DLIList<Body*> shared_body_list = *body_list_ptr1;
shared_body_list.intersect( *body_list_ptr2 );
if( shared_body_list.size() )
return CUBIT_FALSE;
// Check if in different bodies - maybe we don't need to consider this
if( checkAcrossBodies == CUBIT_FALSE )
if( shared_body_list.size() == 0 )
return CUBIT_FALSE;
// Compare facets
DLIList<SurfaceOverlapFacet*> *facet_list1 = tdso_1->get_facet_list();
int num_tri1 = 0;
if(facet_list1)
num_tri1 = facet_list1->size();
if( !num_tri1 )
PRINT_WARNING( "Unable to facet surface %d\n", ref_face_ptr1->id() );
return CUBIT_FALSE;
DLIList<SurfaceOverlapFacet*> *facet_list2 = tdso_2->get_facet_list();
int num_tri2 = 0;
if(facet_list2)
num_tri2 = facet_list2->size();
if( !num_tri2 )
PRINT_WARNING( "Unable to facet surface %d\n", ref_face_ptr2->id() );
return CUBIT_FALSE;
PRINT_DEBUG_102( " Comparing %d facets in Surface %d with %d facets in Surface %d...\n",
num_tri1, ref_face_ptr1->id(), num_tri2, ref_face_ptr2->id() );
// Compare least to most - possibly switch the lists
DLIList<SurfaceOverlapFacet*> *temp_list = facet_list1;
facet_list2 = temp_list;
TDSurfaceOverlap *temp_tdso = tdso_1;
tdso_2 = tdso_1;
tdso_1 = temp_tdso;
// Possibly use an AbstractTree for facet_list2
AbstractTree<SurfaceOverlapFacet*> *a_tree = NULL;
if( facet_list2->size() > NO_FACETS_FOR_ABSTRACTTREE )
// If the same size, use the existing AbstractTree if one has
// one and the other doesn't. This probably won't
// save time, but there is a miniscule chance it might.
if( facet_list1->size() == facet_list2->size() )
if( !tdso_2->has_rtree() && tdso_1->has_rtree() )
// Switch them, just to use the existing AbstractTree
tdso_2 = tdso_1;
tdso_1 = temp_tdso;
a_tree = tdso_2->get_facet_rtree();
bool surfs_overlap = check_overlap( facet_list1, facet_list2, a_tree,
abort, draw_overlap, overlap_area );
return surfs_overlap;
| CubitBoolean SurfaceOverlapTool::check_overlap | ( | Curve * | curve1, |
| Curve * | curve2, | ||
| std::map< Curve *, DLIList< CurveOverlapFacet * > * > * | facet_map, | ||
| std::multimap< BodySM *, CubitVector > * | body_point_imprint_map = NULL, |
| double | overlap_tol = -1.0 |
Definition at line 2135 of file SurfaceOverlapTool.cpp.
GeometryType curve1_type = curve1->geometry_type();
GeometryType curve2_type = curve2->geometry_type();
if(overlap_tol > 0.0)
tolerance = overlap_tol;
double facet_tol = tolerance*10;
std::map<Curve*, DLIList<CurveOverlapFacet*>* >::iterator facet_iterator;
CubitBox curve_box1 = curve1->bounding_box();
CubitBox curve_box2 = curve2->bounding_box();
//see if curve is in map...if not we have to create faceting for it.
if( facet_map )
facet_iterator = facet_map->find( curve1 );
curve1->get_geometry_query_engine()->get_graphics( curve1,
&curve_graphics, 0, facet_tol );
int kk;
GPoint gpoints[2];
if( facet_map )
facet_map->insert( std::map<Curve*,
DLIList<CurveOverlapFacet*>*>::value_type( curve1, facet_list1 ));
else
if( facet_map )
facet_iterator = facet_map->find( curve2 );
curve2->get_geometry_query_engine()->get_graphics( curve2,
int kk;
GPoint gpoints[2];
if( facet_map )
DLIList<CurveOverlapFacet*>*>::value_type( curve2, facet_list2 ));
else
int kk;
if(facet_list1->size() > 0 && facet_list2->size() > 0)
Curve *tmp_curve = curve1;
curve1 = curve2;
curve2 = tmp_curve;
CubitVector curv1_start_pt;
CubitVector curv2_start_pt;
CubitVector curv1_end_pt;
CubitVector curv2_end_pt;
//get start/end facet points on curves
if( body_point_imprint_map )
curv1_start_pt = facet_list1->get()->start_point();
curv2_start_pt = facet_list2->get()->start_point();
facet_list1->last();
facet_list2->last();
curv1_end_pt = facet_list1->get()->end_point();
curv2_end_pt = facet_list2->get()->end_point();
int list_size1 = facet_list1->size();
for( kk=list_size1; kk--; )
if( curr_facet->length() < GEOMETRY_RESABS )
continue;
//if 'curr_facet' is the first or last facet in curve1,
//check to see if the start/end point is on curve2, and not coincident
//with the start/end point of curve2. If so, it's a case where you need
//to imprint this start/end point onto the body of curve2.
if( kk == list_size1-1 ) //first facet in curve1
CubitVector closest_point;
curve2->closest_point_trimmed( curr_facet->start_point(), closest_point );
if( curv2_start_pt.distance_between( curr_facet->start_point() ) > tolerance &&
curv2_end_pt.distance_between( curr_facet->start_point() ) > tolerance &&
closest_point.distance_between( curr_facet->start_point() ) < tolerance )
BodySM *tmp_body_sm = curve2->bodysm();
body_point_imprint_map->insert( std::multimap<BodySM*,
CubitVector>::value_type(
tmp_body_sm, closest_point));
if( kk == 0 ) //last facet in curve1
curve2->closest_point_trimmed( curr_facet->end_point(), closest_point );
if( curv2_start_pt.distance_between( curr_facet->end_point() ) > tolerance &&
curv2_end_pt.distance_between( curr_facet->end_point() ) > tolerance &&
closest_point.distance_between( curr_facet->end_point() ) < tolerance )
//insert into vertex-volume imprint map
int jj;
int list_size2 = facet_list2->size();
for( jj=list_size2; jj--; )
double distance_between_facets = curr_facet->facet_to_facet_distance( other_facet );
if( distance_between_facets < tolerance+facet_tol )
if( other_facet->length() < GEOMETRY_RESABS )
continue;
//if 'other_facet' is the first or last facet in curve1,
//check to see if the start/end point is on curve1, and not coincident
//with the start/end point of curve1. If so, it's a case where you need
//to imprint this start/end point onto the body of curve1.
if( jj == list_size2-1 ) //first facet in curve1
curve1->closest_point_trimmed( other_facet->start_point(), closest_point );
if( curv1_start_pt.distance_between( other_facet->start_point() ) > tolerance &&
curv1_end_pt.distance_between( other_facet->start_point() ) > tolerance &&
closest_point.distance_between( other_facet->start_point() ) < tolerance )
BodySM *tmp_body_sm = curve1->bodysm();
tmp_body_sm, closest_point ));
if( jj == 0 ) //last facet in curve1
curve1->closest_point_trimmed( other_facet->end_point(), closest_point );
if( curv1_start_pt.distance_between( other_facet->end_point() ) > tolerance &&
curv1_end_pt.distance_between( other_facet->end_point() ) > tolerance &&
closest_point.distance_between( other_facet->end_point() ) < tolerance )
//get the long and short facet edge
double curr_facet_length = curr_facet->length();
double other_facet_length = other_facet->length();
CurveOverlapFacet *long_facet = ( curr_facet_length > other_facet_length ?
curr_facet : other_facet );
CurveOverlapFacet *short_facet = curr_facet;
if( long_facet == curr_facet )
short_facet = other_facet;
//make sure both endpoints or one endpoint and the midpoint
// of the smaller facet edge lie within a radius
//of merge tolerance + facet tolerance to an infinite line defined
// by longer facet edge
CubitVector direction = long_facet->end_point() - long_facet->start_point();
double dist1 = short_facet->start_point().distance_from_infinite_line(
long_facet->start_point(), direction );
double dist2 = short_facet->end_point().distance_from_infinite_line(
if( dist2 > tolerance+facet_tol && dist1 > tolerance+facet_tol )
continue;
CubitVector facet_mid_point = (short_facet->end_point() + short_facet->start_point()) * 0.5;
double dist_to_midpoint = facet_mid_point.distance_from_infinite_line(
if( dist_to_midpoint <= tolerance+facet_tol && (dist2 <= tolerance+facet_tol || dist1 <= tolerance+facet_tol ))
if( total_overlap > tolerance )
overlap = true;
break;
break;
for( kk=facet_list2->size(); kk--; )
delete facet_list1;
delete facet_list2;
return CUBIT_FALSE;
if( curve1_type == SPLINE_CURVE_TYPE ||
curve2_type == SPLINE_CURVE_TYPE )
double dist_between_curves = 0;
CubitVector point_on_curve1, point_on_curve2;
GeometryQueryTool::instance()->entity_entity_distance(curve1, curve2,
point_on_curve1, point_on_curve2, dist_between_curves);
if( dist_between_curves > tolerance )
return CUBIT_FALSE;
//if curvatures at midpoint are not the same, they don't overlap
curve1->closest_point( point_on_curve1, closest_location, &tangent, &curvature1 );
curve2->closest_point( point_on_curve2, closest_location, &tangent, &curvature2 );
if( rad1 > GEOMETRY_RESABS || rad2 > GEOMETRY_RESABS )
return CUBIT_FALSE;
else if( curve1_type == ARC_CURVE_TYPE &&
curve2_type == ARC_CURVE_TYPE )
//if both curves are arcs, make sure radii are almost the same
CubitVector mid_point1, mid_point2;
curve1->mid_point( mid_point1 );
curve2->mid_point( mid_point2 );
CubitVector dummy_vec;
CubitVector curvature1;
CubitVector curvature2;
curve1->closest_point( mid_point1, dummy_vec, NULL, &curvature1 );
curve2->closest_point( mid_point2, dummy_vec, NULL, &curvature2 );
double rad1 = 1/curvature1.length();
double rad2 = 1/curvature2.length();
if( fabs( rad1 - rad2 ) > tolerance )
return CUBIT_FALSE;
else
return CUBIT_TRUE;
return CUBIT_TRUE;
| CubitBoolean SurfaceOverlapTool::check_overlap | ( | DLIList< SurfaceOverlapFacet * > * | facet_list1, |
| const double | facet_tol, | ||
| const double | tolerance | ||
Definition at line 1072 of file SurfaceOverlapTool.cpp.
int i, j;
double area = 0;
double overlap_tol = tolerance * tolerance;
if( a_tree )
double facet1_perimeter = facet1->perimeter();
// Check angle between triangles, must be within criteria
double ang = facet1->angle( *facet2 );
//rough estimate...must be less than half of 45
if( fabs( 180-ang) < 23.5 || ang < 23.5 )
//make sure midpoint and one other point are within facet_tol+tolerance of plane
//defined by larger facet
bool within_parallel_tol = false;
if( facet1_perimeter > facet2->perimeter() )
within_parallel_tol = facet1->facet_points_within_tol( facet2, (facet_tol+tolerance) );
else
within_parallel_tol = facet2->facet_points_within_tol( facet1, (facet_tol+tolerance) );
if( within_parallel_tol )
if( dist <= facet_tol+tolerance )
// Check for projected overlap
// We want sum of area of ALL overlapping facets
area += facet1->projected_overlap( *facet2 );
if( area > overlap_tol )
return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean | draw_overlap, | ||
| double * | overlap_area | ||
Definition at line 1185 of file SurfaceOverlapTool.cpp.
double area = 0;
double opp_low = 180.0 - angleMax;
double opp_high = 180.0 - angleMin;
int num_tri1 = facet_list1->size();
int i,j;
for( i=num_tri1; i--; )
if(i%20 == 0)
// Cancel button pushed or cntrl-C
if (AppUtil::instance()->interrupt())
PRINT_INFO("Find overlap operation aborted.\n");
abort = CUBIT_TRUE;
return CUBIT_FALSE;
if( a_tree )
a_tree->find( facet1->bounding_box(), close_facets );
if(j%20 == 0)
abort = CUBIT_TRUE;
return CUBIT_FALSE;
// Allow overlap for angles close to 180 and 0 degrees
// normalType - 1=any, 2=opposite, 3=same
//ang>=180.0-angt || ang<angt
if( ((normalType==1 && ang>=opp_low && ang<=opp_high) ||
(normalType==1 && ang>=angleMin && ang<=angleMax) ||
(normalType==2 && ang>=opp_low && ang<=opp_high) ||
(normalType==3 && ang>=angleMin && ang<=angleMax) ) &&
(normalType != 2 || !skipFacingSurfaces || !facet1->facing( *facet2 )))// check to make sure the surfaces are not facing )
if( facet1->bbox_overlap( gapMax, *facet2 ) )
if( dist >= gapMin && dist <= gapMax )
area += facet1->projected_overlap( *facet2, draw_overlap );
if( area > overlapTolerance &&
(draw_overlap == CUBIT_FALSE && overlap_area == NULL ) )
return CUBIT_TRUE;
if( draw_overlap == CUBIT_TRUE )
PRINT_INFO("Total overlapping area = %f\n", area );
if( area > 0.0 )
return CUBIT_TRUE;
if( overlap_area )
if( area > 0.0 )
*overlap_area = area;
return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean SurfaceOverlapTool::check_size_and_swap_surfs | ( | Surface *& | tmp_surf1, |
| Surface *& | tmp_surf2, | ||
| const double | tolerance, | ||
| DLIList< SurfaceOverlapFacet * > *& | facet_list1, | ||
| DLIList< SurfaceOverlapFacet * > *& | facet_list2, | ||
| std::map< Surface *, AbstractTree< SurfaceOverlapFacet * > * > *& | a_tree_map, | ||
| AbstractTree< SurfaceOverlapFacet * > *& | a_tree2 | ||
Definition at line 790 of file SurfaceOverlapTool.cpp.
// Compare facets
if( !num_tri1 )
PRINT_WARNING( "Unable to facet surface\n" );
return CUBIT_FALSE;
int num_tri2 = facet_list2->size();
if( !num_tri2 )
return CUBIT_FALSE;
Surface *temp_surf;
temp_surf = tmp_surf1;
tmp_surf1 = tmp_surf2;
tmp_surf2 = temp_surf;
int i;
std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>* >::iterator iter1, iter2;
//see if both are in the a_tree_map
iter1 = a_tree_map->find( tmp_surf1 );
iter2 = a_tree_map->find( tmp_surf2 );
if( !(iter2 != a_tree_map->end()) && (iter1 != a_tree_map->end()) )
Surface *tmp_surf = tmp_surf1;
tmp_surf2 = tmp_surf;
std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>* >::iterator tmp_iter;
tmp_iter = iter1;
iter1 = iter2;
iter2 = tmp_iter;
//populate tree if necessary
if( iter2 == a_tree_map->end() )
//a_tree = new RTree<SurfaceOverlapFacet*>( gapMax );
a_tree2 = new RTree<SurfaceOverlapFacet*>( tolerance+facet_tol );
a_tree2->add( facet_list2->get_and_step() );
a_tree_map->insert( std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>*>::value_type( tmp_surf2, a_tree2 ));
else
a_tree2 = iter2->second;
return CUBIT_TRUE;
| CubitBoolean SurfaceOverlapTool::check_surfs_for_imprinting | ( | Surface * | surface1, |
| Surface * | surface2, | ||
| std::map< Surface *, DLIList< SurfaceOverlapFacet * > * > * | facet_map, | ||
| std::map< Surface *, AbstractTree< SurfaceOverlapFacet * > * > * | a_tree_map, | ||
| ) | [private] |
Definition at line 879 of file SurfaceOverlapTool.cpp.
if( surface1 == surface2 )
return CUBIT_FALSE;
// Initialize toelrances
//double facet_tol = 0.00025;
// Extract graphics facets if not available in map
DLIList<SurfaceOverlapFacet*> *facet_list1 = NULL;
DLIList<SurfaceOverlapFacet*> *facet_list2 = NULL;
extract_surf_facets( surface1, surface2, facet_map, tolerance, facet_tol, facet_list1, facet_list2 );
// Swap first and second surfaces/facets to set smaller surface as first
Surface *tmp_surf1 = surface1;
Surface *tmp_surf2 = surface2;
AbstractTree<SurfaceOverlapFacet*> *a_tree2 = NULL;
if( CUBIT_FALSE == check_size_and_swap_surfs( tmp_surf1, tmp_surf2, tolerance, facet_tol, facet_list1, facet_list2, a_tree_map, a_tree2 ) )
return CUBIT_FALSE;
// Calculate the tolerances for dist and area overlap comparision
double facet_compare_tol = facet_tol+tolerance; // tolerance used in evaluating dist betwen facets
double overlap_tolerance = tolerance * tolerance; // tolerance used in overlaping facets
//calculate_tolerances_for_surf_intersection( tmp_surf1, tmp_surf2, facet_list1, facet_list2, area_map, facet_compare_tol, overlap_tolerance );
// Check 1: check for boundary contact (boundary entities (curves & verts) of one surface touches other surface )
if( check_boundary_contact( facet_list1, facet_list2, a_tree2, facet_compare_tol, overlap_tolerance ) )
return CUBIT_TRUE;
//if surfaces are not splines and are not of the same type, they won't overlap
if( (surface1->geometry_type() != SPLINE_SURFACE_TYPE &&
surface2->geometry_type() != SPLINE_SURFACE_TYPE) &&
(surface1->geometry_type() != surface2->geometry_type() ))
return CUBIT_FALSE;
// Check 2: check for overlap between surfaces
if( check_overlap( facet_list1, facet_list2, a_tree2, facet_compare_tol, overlap_tolerance ) )
return CUBIT_TRUE;
// Check 3: check for interior contact (interior of surface touches interior of other surface )
// Check 4: check for peneration ( one surface penetrates other surface )
return CUBIT_FALSE;
| CubitStatus SurfaceOverlapTool::copy_edges_in_list | ( | DLIList< RefEdge * > & | old_list, |
| DLIList< RefEdge * > & | new_list | ||
| ) | [private] |
Definition at line 1707 of file SurfaceOverlapTool.cpp.
int i;
RefEdge *curr_edge, *new_edge;
RefEntity *curr_entity, *new_entity;
for ( i = old_list.size(); i > 0; i-- )
curr_edge = old_list.get_and_step();
curr_entity = CAST_TO(curr_edge, RefEntity);
assert(curr_entity != NULL );
new_entity = GeometryModifyTool::instance()->copy_refentity(curr_entity);
new_edge = CAST_TO(new_entity, RefEdge);
if ( new_edge == NULL )
PRINT_ERROR("Problems copying edges for imprinting overlap.\n");
assert(new_edge != NULL );
return CUBIT_FAILURE;
new_list.append(new_edge);
return CUBIT_SUCCESS;
| CubitStatus SurfaceOverlapTool::delete_edges_in_list | ( | DLIList< RefEdge * > & | edge_list | ) | [private] |
Definition at line 1788 of file SurfaceOverlapTool.cpp.
int i;
RefEdge *curr_edge;
RefEntity *curr_entity;
for ( i = edge_list.size(); i > 0; i-- )
curr_edge = edge_list.remove();
CubitStatus stat = GeometryQueryTool::instance()->delete_RefEntity(curr_entity);
if ( stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems deleting edges after imprinting overlaps\n");
assert(0);
| static void SurfaceOverlapTool::delete_instance | ( | ) | [inline, static] |
Definition at line 262 of file SurfaceOverlapTool.hpp.
| CubitBoolean SurfaceOverlapTool::draw_overlapping_surface_pair | ( | RefFace * | ref_face_1, |
| RefFace * | ref_face_2 | ||
Definition at line 92 of file SurfaceOverlapTool.cpp.
CubitBoolean abort = CUBIT_FALSE;
CubitBoolean draw_overlap = CUBIT_TRUE;
CubitBoolean overlap = check_overlap( ref_face_1, ref_face_2,
abort, draw_overlap );
return overlap;
| CubitBoolean SurfaceOverlapTool::extract_surf_facets | ( | Surface * | surface1, |
| DLIList< SurfaceOverlapFacet * > *& | facet_list2 | ||
Definition at line 630 of file SurfaceOverlapTool.cpp.
int i;
std::map<Surface*, DLIList<SurfaceOverlapFacet*>* >::iterator facet_iterator;
//see if surface is in map...if not we have to create faceting for it.
if( facet_map )
facet_iterator = facet_map->find( surface1 );
//for non-planar surfaces, facet wrt the smallest curve of the surface
double min_edge_length = 0.0;
if( surface1->geometry_type() != PLANE_SURFACE_TYPE )
DLIList<Curve*> tmp_curves;
surface1->curves( tmp_curves );
CubitBox surface_box = surface1->bounding_box();
//ignore curves that are really small
double min_length_threshold = (surface_box.diagonal().length())*0.01;
if( tmp_curves.size() )
min_edge_length = CUBIT_DBL_MAX;
double tmp_length;
for( i=tmp_curves.size(); i--; )
tmp_length = tmp_curves.get_and_step()->measure();
if( tmp_length > min_length_threshold && tmp_length < min_edge_length )
min_edge_length = tmp_length;
if( min_edge_length == CUBIT_DBL_MAX )
else
min_edge_length *= 2;
facet_list1 = new DLIList<SurfaceOverlapFacet*>;
GMem surface_graphics;
surface1->get_geometry_query_engine()->get_graphics( surface1, &surface_graphics,
0, facet_tol, 0 );
GPoint* plist = surface_graphics.point_list();
int* facet_list = surface_graphics.facet_list();
GPoint p[3];
for (i = 0; i < surface_graphics.fListCount; )
int sides = facet_list[i++];
if (sides != 3)
PRINT_WARNING("Skipping n-sided polygone in triangle list"
" in TDSurfaceOverlap.\n");
i += sides;
else
p[0] = plist[facet_list[i++]];
p[1] = plist[facet_list[i++]];
p[2] = plist[facet_list[i++]];
SurfaceOverlapFacet *facet = new SurfaceOverlapFacet( p );
facet_list1->append( facet );
if( facet_map )
facet_map->insert( std::map<Surface*,
DLIList<SurfaceOverlapFacet*>*>::value_type( surface1, facet_list1 ));
else
facet_list1 = facet_iterator->second;
if( facet_map )
facet_iterator = facet_map->find( surface2 );
if( surface2->geometry_type() != PLANE_SURFACE_TYPE )
surface2->curves( tmp_curves );
CubitBox surface_box = surface2->bounding_box();
double tmp_length;
else
facet_list2 = new DLIList<SurfaceOverlapFacet*>;
surface2->get_geometry_query_engine()->get_graphics( surface2, &surface_graphics,
0, facet_tol, 0 );
GPoint p[3];
if (sides != 3)
i += sides;
else
facet_list2->append( facet );
if( facet_map )
DLIList<SurfaceOverlapFacet*>*>::value_type( surface2, facet_list2 ));
else
facet_list2 = facet_iterator->second;
return CUBIT_TRUE;
| double SurfaceOverlapTool::find_area_overlap | ( | SurfaceOverlapFacet * | facet1, |
| ) | [private] |
Definition at line 594 of file SurfaceOverlapTool.cpp.
double local_overlap_area = 0.0;
(normalType==3 && ang>=angleMin && ang<=angleMax)) &&
local_overlap_area = facet1->projected_overlap( *facet2 );
return local_overlap_area;
| CubitStatus SurfaceOverlapTool::find_candidate_surfaces_for_imprinting | ( | DLIList< BodySM * > & | body_list, |
| DLIList< Surface * > & | surface_list1, | ||
| DLIList< Surface * > & | surface_list2, | ||
| double | overlap_tol = -1.0, |
| bool | filter_slivers = false |
Definition at line 125 of file SurfaceOverlapTool.cpp.
//collect all the surfaces
DLIList<Surface*> surface_list;
int i;
for( i=body_list.size(); i--; )
BodySM *body_sm = body_list.get_and_step();
DLIList<Surface*> surfs;
body_sm->surfaces_ignore_virtual( surfs, false );
// body_sm->surfaces( surfs );
surface_list.merge_unique( surfs );
// Populate the Surface AbstractTree
AbstractTree<Surface*> *a_tree = new RTree<Surface*>( tolerance );
surface_list.reset();
for( i=surface_list.size(); i--; )
Surface *surface = surface_list.get_and_step();
a_tree->add( surface );
std::map<Surface*, DLIList<SurfaceOverlapFacet*>* > surface_facet_map;
std::map<Surface*, double > surface_to_area_map;
std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>* > a_tree_map;
Surface *surf1 = surface_list.get_and_step();
BodySM *surf1_body = surf1->bodysm();
// Remove this surface from AbstractTree so it is not found and never
// found again
a_tree->remove( surf1 );
// Find RefFaces from AbstractTree that are within range of this surface
CubitBox surf1_box = surf1->bounding_box();
DLIList<Surface*> close_surfaces;
a_tree->find( surf1_box, close_surfaces );
int j;
for( j=close_surfaces.size(); j--; )
Surface *surf2 = close_surfaces.get_and_step();
BodySM *surf2_body = surf2->bodysm();
//don't check for overlapping surfaces within bodies
if( surf1_body == surf2_body )
continue;
// check for overlap, boundary contact, int contact, penetration, etc.
if( check_surfs_for_imprinting( surf1, surf2,
&surface_facet_map,
&surface_to_area_map,
&a_tree_map,
overlap_tol ) == CUBIT_TRUE )
surface_list1.append( surf1 );
surface_list2.append( surf2 );
//clean up maps;
std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>* >::iterator tree_iter;
tree_iter = a_tree_map.begin();
for(; tree_iter != a_tree_map.end(); tree_iter++ )
delete tree_iter->second;
std::map<Surface*, DLIList<SurfaceOverlapFacet*>* >::iterator sof_iter;
sof_iter = surface_facet_map.begin();
for(; sof_iter != surface_facet_map.end(); sof_iter++)
DLIList<SurfaceOverlapFacet*> *tmp_list = sof_iter->second;
//delete contents of list
for( i=tmp_list->size(); i--; )
delete tmp_list->get_and_step();
//delete the list
delete tmp_list;
delete a_tree;
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< Surface * > & | surf_list, |
| DLIList< DLIList< Curve * > * > & | overlapping_curve_lists, | ||
| std::map< Curve *, DLIList< Curve * > * > & | curve_to_list_map, | ||
| std::multimap< BodySM *, CubitVector > & | body_point_imprint_map | ||
Definition at line 1909 of file SurfaceOverlapTool.cpp.
DLIList<Curve*> curve_list;
int i;
for( i=surf_list.size(); i--; )
Surface *surf = surf_list.get_and_step();
DLIList<Curve*> curves;
surf->curves_ignore_virtual(curves, false);
// body_sm->curves( curves);
curve_list.merge_unique( curves );
return find_overlapping_curves(curve_list, overlapping_curve_lists, curve_to_list_map,
body_point_imprint_map);
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< Curve * > & | curve_list, |
| std::multimap< BodySM *, CubitVector > & | body_point_imprint_map, | ||
Definition at line 1810 of file SurfaceOverlapTool.cpp.
int i;
//put all the curves into a tree
AbstractTree<Curve*> *a_tree = new RTree<Curve*>( tolerance );
curve_list.reset();
for( i=curve_list.size(); i--; )
Curve *curve = curve_list.get_and_step();
a_tree->add( curve );
std::map<Curve*, DLIList<CurveOverlapFacet*>* > facet_map;
std::map<Curve*, DLIList<Curve*>* >::iterator list_iter;
curve_list.reset();
Curve *curve1= curve_list.get_and_step();
BodySM *curve1_body = curve1->bodysm();
// found again
a_tree->remove( curve1 );
CubitBox curve1_box = curve1->bounding_box();
DLIList<Curve*> close_curves;
a_tree->find( curve1_box, close_curves );
int j;
for( j=close_curves.size(); j--; )
Curve *curve2 = close_curves.get_and_step();
BodySM *curve2_body = curve2->bodysm();
if( curve2_body == curve1_body )
continue;
std::multimap<BodySM*, CubitVector> tmp_body_point_imprint_map;
if( check_overlap( curve1, curve2, &facet_map, &tmp_body_point_imprint_map, overlap_tol ) )
//check to see if the curve1 is already overlapping with another curve
list_iter = curve_to_list_map.find( curve1 );
if( list_iter != curve_to_list_map.end() )
DLIList<Curve*> *tmp_curve_list = list_iter->second;
tmp_curve_list->append( curve2 );
else
//list for curve 1 does not exist....make a new one
DLIList<Curve*> *tmp_curve_list = new DLIList<Curve*>;
overlapping_curve_lists.append( tmp_curve_list );
tmp_curve_list->append( curve1 );
curve_to_list_map.insert( std::map<Curve*,
DLIList<Curve*>*>::value_type( curve1, tmp_curve_list ));
else
//append what's in body_point_imprint_map to one passed in
body_point_imprint_map.insert( tmp_body_point_imprint_map.begin(),
tmp_body_point_imprint_map.end() );
//clean up facet map
std::map<Curve*, DLIList<CurveOverlapFacet*>* >::iterator facet_iter;
facet_iter=facet_map.begin();
for(; facet_iter != facet_map.end(); facet_iter++ )
DLIList<CurveOverlapFacet*> *co_facet_list = facet_iter->second;
//delete all the facets in the list
for( i=co_facet_list->size(); i--; )
delete co_facet_list->get_and_step();
delete co_facet_list;
delete a_tree;
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< Body * > & | bodies, |
| std::multimap< RefEdge *, RefEdge * > & | overlapping_edge_map, | ||
| double | maxgap = -1 |
Definition at line 1953 of file SurfaceOverlapTool.cpp.
std::map<RefEdge*, DLIList<CurveOverlapFacet*>* >::iterator list_iter;
if (maxgap != -1 && maxgap != 0.0)
tolerance = maxgap;
int i,j;
DLIList<Body*> tmp_body_list = bodies;
for(i=tmp_body_list.size(); i--; )
Body *tmp_body1 = tmp_body_list.pop();
tmp_body_list.reset();
for(j=tmp_body_list.size(); j--; )
Body *tmp_body2 = tmp_body_list.get_and_step();
//determine if bodies are close enough to have overlapping curves
CubitBox body_box1 = tmp_body1->bounding_box();
CubitBox body_box2 = tmp_body2->bounding_box();
if( body_box1.overlap( tolerance, body_box2 ) )
// create list of edges on each body.
// put the edges in body2 in edges1 so edges1 contains
// the list of curves contained in the body listed first in the list
DLIList<RefEdge*> edges1, edges2;
tmp_body1->ref_edges( edges2 );
tmp_body2->ref_edges( edges1 );
//check individual curves for bounding box interference
if (!find_overlapping_curves(edges1, edges2, overlapping_edge_map, tolerance))
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< BodySM * > & | bodies, |
| std::multimap< BodySM *, CubitVector > & | body_vertex_imprint_map, | ||
| double | overlap_tol | ||
Definition at line 1930 of file SurfaceOverlapTool.cpp.
int i;
body_sm->curves_ignore_virtual(curves, false);
body_point_imprint_map, overlap_tol);
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< RefFace * > & | faces, |
Definition at line 1997 of file SurfaceOverlapTool.cpp.
tolerance = maxgap;
AbstractTree<RefFace*> *a_tree = new RTree<RefFace*>( tolerance );
faces.reset();
int i;
for( i=faces.size(); i--; )
RefFace* face = faces.get_and_step();
a_tree->add( face );
faces.reset();
RefFace* face1 = faces.get_and_step();
Body *face1_body = face1->body();
// Remove this face from AbstractTree so it is not found and never
// found again
a_tree->remove( face1 );
CubitBox face1_box = face1->bounding_box();
DLIList<RefFace*> close_faces;
a_tree->find( face1_box, close_faces );
int j;
for( j=close_faces.size(); j--; )
RefFace *face2 = close_faces.get_and_step();
Body *face2_body = face2->body();
//don't check for overlapping faces within bodies
if( face1_body == face2_body )
continue;
face1->ref_edges( edges1 );
face2->ref_edges( edges2 );
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< RefEdge * > & | edgelist, |
Definition at line 2054 of file SurfaceOverlapTool.cpp.
// for now, check every edge against every other edge
// (the helper function will skip edges if they are in the same body)
DLIList<RefEdge*> edgelist2 = edgelist;
return find_overlapping_curves(edgelist, edgelist2, overlapping_edge_map, maxgap);
| CubitStatus SurfaceOverlapTool::find_overlapping_curves | ( | DLIList< RefEdge * > & | edges1, |
| DLIList< RefEdge * > & | edges2, | ||
Definition at line 2064 of file SurfaceOverlapTool.cpp.
int i;
std::map<RefEdge*, DLIList<CurveOverlapFacet*>* > facet_map;
tolerance = maxgap;
for( i=edges1.size(); i--; )
RefEdge *edge1 = edges1.get_and_step();
int j;
for( j=edges2.size(); j--; )
RefEdge *edge2 = edges2.get_and_step();
if( edge1 == edge2 )
continue;
std::multimap<RefEdge*, RefEdge*>::iterator it;
it = overlapping_edge_map.find( edge2 );
if( it != overlapping_edge_map.end() )
continue;
// check to see if this pair is already in the overlap map.
// If it is, don't need to bother checking it for overlap
std::pair< std::multimap<RefEdge*,RefEdge*>::iterator, std::multimap<RefEdge*,RefEdge*>::iterator > range;
range = overlapping_edge_map.equal_range(edge1);
for (it=range.first; it!=range.second; it++)
if ( (it->second == edge2) && (it->first == edge1) )
pair_already_in_map = true;
if (pair_already_in_map)
continue;
if( check_overlap( edge1, edge2, &facet_map, &tolerance ) )
overlapping_edge_map.insert( std::multimap<RefEdge*, RefEdge*>
::value_type( edge1, edge2));
//PRINT_INFO("Curve %d and %d overlap.\n", edge1->id(), edge2->id());
//PRINT_INFO("Insert Curve %d, Curve %d.\n", edge1->id(), edge2->id());
list_iter=facet_map.begin();
for(; list_iter != facet_map.end(); list_iter++ )
DLIList<CurveOverlapFacet*> *co_facet_list = list_iter->second;
| CubitStatus SurfaceOverlapTool::find_overlapping_surfaces | ( | DLIList< RefFace * > & | ref_face_list, |
| DLIList< RefEntity * > & | faces_to_draw, | ||
Definition at line 104 of file SurfaceOverlapTool.cpp.
DLIList<RefFace*> list1, list2;
return find_overlapping_surfaces( ref_face_list, list1, list2, faces_to_draw, CUBIT_TRUE,
filter_slivers);
| CubitStatus SurfaceOverlapTool::find_overlapping_surfaces | ( | DLIList< Body * > & | body_list, |
Definition at line 114 of file SurfaceOverlapTool.cpp.
return find_overlapping_surfaces( body_list, list1, list2, faces_to_draw, CUBIT_TRUE,
filter_slivers);
| DLIList< RefFace * > & | ref_face_list1, | ||
| DLIList< RefFace * > & | ref_face_list2, | ||
| CubitBoolean | show_messages = CUBIT_FALSE, |
Definition at line 354 of file SurfaceOverlapTool.cpp.
CubitStatus status = CUBIT_SUCCESS;
CubitBoolean group_results = CUBIT_FALSE;
CubitBoolean list_pairs = CUBIT_FALSE;
CubitBoolean imprint_results = CUBIT_FALSE;
if( show_messages == CUBIT_TRUE )
group_results = groupResults;
list_pairs = listPairs;
imprint_results = imprintResults;
int prog_step = 10;
if( show_messages )
PRINT_INFO( "Finding surface overlap...\n" );
if( ref_face_list.size() > prog_step )
char message[128];
sprintf(message, "Finding Surface Overlap On %d Surfaces", ref_face_list.size() );
AppUtil::instance()->progress_tool()->start(0, ref_face_list.size(),
"Progress", message, TRUE, TRUE );
else
prog_step = -1;
status = find_overlapping_surfaces( ref_face_list, ref_face_list1,
ref_face_list2, faces_to_draw, list_pairs, prog_step, filter_slivers );
if( show_messages && ref_face_list.size() > prog_step )
AppUtil::instance()->progress_tool()->end();
if( faces_to_draw.size() )
if( group_results == CUBIT_TRUE )
RefGroup *new_group = RefEntityFactory::instance()->construct_RefGroup( "surf_overlap" );
new_group->add_ref_entity( faces_to_draw );
CubitString name = new_group->entity_name();
PRINT_INFO( "Found %d overlapping surface pairs (added to group '%s')\n",
ref_face_list1.size(), name.c_str() );
else if( show_messages )
PRINT_INFO( "Found %d overlapping surface pairs\n", ref_face_list1.size() );
if ( imprint_results )
CubitStatus stat = imprint(ref_face_list1, ref_face_list2);
PRINT_WARNING("Imprinting overlaps was unsuccessful\n");
else if (show_messages )
PRINT_INFO( "Found 0 overlapping surface pairs\n" );
return status;
Definition at line 226 of file SurfaceOverlapTool.cpp.
// Handle the special case of finding overlapping surfaces within a given
// body - we can do this MUCH faster than the general case (this is a
// rare case in general but at Cat we have an application for this!).
// The usual case
if( checkWithinBodies == CUBIT_FALSE ||
(checkWithinBodies == CUBIT_TRUE && checkAcrossBodies == CUBIT_TRUE) )
// Utilize a straight surface list
DLIList<RefFace*> ref_face_list;
body_list.reset();
int i;
Body* body_ptr = body_list.get_and_step();
DLIList<RefFace*> body_face_list;
body_ptr->ref_faces( body_face_list );
ref_face_list.merge_unique( body_face_list );
int prog_step = 0;
if( show_messages )
prog_step = 10;
char message[128];
// Special case - checking within bodies
else
int prog_step = 5;
if( show_messages )
if( body_list.size() > prog_step )
char message[128];
sprintf(message, "Finding Surface Overlap On %d Bodies", body_list.size() );
AppUtil::instance()->progress_tool()->start(0, body_list.size(),
int i;
body_list.reset();
status = find_overlapping_surfaces( body_face_list, ref_face_list1,
ref_face_list2, faces_to_draw, list_pairs, -1, filter_slivers );
if( show_messages && body_list.size() > prog_step )
AppUtil::instance()->progress_tool()->step();
if( status == CUBIT_FAILURE )
break;
return status;
| DLIList< RefEntity * > & | pair_list, | ||
| CubitBoolean | list_pairs, | ||
| int | prog_step, | ||
| ) | [private] |
Definition at line 425 of file SurfaceOverlapTool.cpp.
int number_pairs = 0;
RefEntity* ref_entity;
// Check each surface with each one later in the list
RefFace *ref_face_ptr1, *ref_face_ptr2;
// Populate the RefFace AbstractTree
AbstractTree<RefFace*> *a_tree = new RTree<RefFace*>( gapMax );
int i;
ref_face_list.reset();
for( i=ref_face_list.size(); i--; )
RefFace *ref_face_ptr = ref_face_list.get_and_step();
a_tree->add( ref_face_ptr );
// Main loop for finding overlapping surfaces
goto done;
ref_face_ptr1 = ref_face_list.get_and_step();
// found again
a_tree->remove( ref_face_ptr1 );
CubitBox ref_face1_box = ref_face_ptr1->bounding_box();
DLIList<RefFace*> close_ref_faces;
a_tree->find( ref_face1_box, close_ref_faces );
int j;
for( j=close_ref_faces.size(); j--; )
goto done;
ref_face_ptr2 = close_ref_faces.get_and_step();
bool overlap = check_overlap( ref_face_ptr1, ref_face_ptr2, abort );
if(overlap == CUBIT_TRUE && filter_slivers)
RefFace *f1, *f2;
DLIList<RefEdge*> f1_edges, f2_edges, *f1_edge_list/* , *f2_edge_list */;
ref_face_ptr1->ref_edges(f1_edges);
ref_face_ptr2->ref_edges(f2_edges);
if(f1_edges.size() > f2_edges.size())
f1 = ref_face_ptr2;
f2 = ref_face_ptr1;
f1_edge_list = &f2_edges;
else
f1 = ref_face_ptr1;
f2 = ref_face_ptr2;
f1_edge_list = &f1_edges;
int b;
for(b=f1_edge_list->size(); b>0 && overlap; b--)
RefEdge *cur_edge = f1_edge_list->get_and_step();
if(cur_edge->is_merged())
DLIList<RefFace*> face_list;
cur_edge->ref_faces(face_list);
if(face_list.is_in_list(f2))
CubitVector mid_pt;
cur_edge->mid_point(mid_pt);
CubitVector f1_norm = f1->normal_at(mid_pt);
CubitVector f2_norm = f2->normal_at(mid_pt);
DLIList<CoEdge*> f1_coedges, f2_coedges;
cur_edge->get_co_edges(f1_coedges, f1);
cur_edge->get_co_edges(f2_coedges, f2);
if(f1_coedges.size() == 1 && f2_coedges.size() == 1)
CoEdge *ce1 = f1_coedges.get();
CoEdge *ce2 = f2_coedges.get();
CubitVector curve_dir;
if( cur_edge->get_curve_ptr()->geometry_type() == STRAIGHT_CURVE_TYPE )
cur_edge->get_point_direction(mid_pt, curve_dir);
else
cur_edge->tangent( mid_pt, curve_dir );
CubitVector ce1_dir, ce2_dir;
if(ce1->get_sense() == CUBIT_REVERSED)
ce1_dir = -curve_dir;
else
ce1_dir = curve_dir;
if(ce2->get_sense() == CUBIT_REVERSED)
ce2_dir = -curve_dir;
else
ce2_dir = curve_dir;
CubitVector in_dir1 = f1_norm * ce1_dir;
CubitVector in_dir2 = f2_norm * ce2_dir;
if(in_dir1 % in_dir2 < 0.0)
overlap = false;
if(overlap)
if( abort == CUBIT_TRUE )
goto done;
if( list_pairs == CUBIT_TRUE )
PRINT_INFO( " Surface %d and %d overlap\n", ref_face_ptr1->id(),
number_pairs++;
ref_entity = CAST_TO(ref_face_ptr1,RefEntity);
pair_list.append_unique( ref_entity );
ref_entity = CAST_TO(ref_face_ptr2,RefEntity);
ref_face_list1.append( ref_face_ptr1 );
ref_face_list2.append( ref_face_ptr2 );
goto done;
// Free memory, since this surface will never be accessed again. This
// helps to reduce memory required.
ref_face_ptr1->delete_TD( &TDSurfaceOverlap::is_surface_overlap );
if( prog_step>0 && ref_face_list.size() > prog_step )
done:
// Make sure all tool datas are deleted
ref_face_list.get_and_step()->delete_TD( &TDSurfaceOverlap::is_surface_overlap );
delete a_tree;
| double SurfaceOverlapTool::get_angle_max | ( | ) | [inline, static] |
Definition at line 423 of file SurfaceOverlapTool.hpp.
{return angleMax;}
| double SurfaceOverlapTool::get_angle_min | ( | ) | [inline, static] |
Definition at line 416 of file SurfaceOverlapTool.hpp.
{return angleMin;}
| CubitBoolean SurfaceOverlapTool::get_check_across_bodies | ( | ) | [inline, static] |
Definition at line 476 of file SurfaceOverlapTool.hpp.
{return checkAcrossBodies;}
| CubitBoolean SurfaceOverlapTool::get_check_within_bodies | ( | ) | [inline, static] |
Definition at line 470 of file SurfaceOverlapTool.hpp.
{return checkWithinBodies;}
| CubitBoolean SurfaceOverlapTool::get_display_pairs | ( | ) | [inline, static] |
Definition at line 458 of file SurfaceOverlapTool.hpp.
{return displayPairs;}
| int SurfaceOverlapTool::get_display_pairs_setting | ( | ) | [static] |
Definition at line 1502 of file SurfaceOverlapTool.cpp.
| double SurfaceOverlapTool::get_facet_abs_tol | ( | ) | [inline, static] |
Definition at line 395 of file SurfaceOverlapTool.hpp.
{return facetAbsTol;}
| unsigned short SurfaceOverlapTool::get_facet_ang_tol | ( | ) |
| int SurfaceOverlapTool::get_facet_ang_tol_setting | ( | ) | [static] |
Definition at line 1508 of file SurfaceOverlapTool.cpp.
{return facetAngTol;}
| double SurfaceOverlapTool::get_gap_max | ( | ) | [inline, static] |
Definition at line 409 of file SurfaceOverlapTool.hpp.
{return gapMax;}
| double SurfaceOverlapTool::get_gap_min | ( | ) | [inline, static] |
Definition at line 402 of file SurfaceOverlapTool.hpp.
{return gapMin;}
| CubitBoolean SurfaceOverlapTool::get_group_results | ( | ) | [inline, static] |
Definition at line 444 of file SurfaceOverlapTool.hpp.
{return groupResults;}
| int SurfaceOverlapTool::get_group_results_setting | ( | ) | [static] |
Definition at line 1490 of file SurfaceOverlapTool.cpp.
| CubitBoolean SurfaceOverlapTool::get_imprint | ( | ) | [inline, static] |
Definition at line 464 of file SurfaceOverlapTool.hpp.
{return imprintResults;}
| CubitBoolean SurfaceOverlapTool::get_list_pairs | ( | ) | [inline, static] |
Definition at line 451 of file SurfaceOverlapTool.hpp.
{return listPairs;}
| int SurfaceOverlapTool::get_list_pairs_setting | ( | ) | [static] |
Definition at line 1496 of file SurfaceOverlapTool.cpp.
{return listPairs;}
| int SurfaceOverlapTool::get_normal_type | ( | ) | [inline, static] |
Definition at line 437 of file SurfaceOverlapTool.hpp.
{return normalType;}
| CubitString SurfaceOverlapTool::get_normal_type_setting | ( | ) | [static] |
Definition at line 1464 of file SurfaceOverlapTool.cpp.
if (normalType == 2) {
return CubitString("opposite");
else if (normalType == 3) {
return CubitString("same");
else {
return CubitString("any");
| double SurfaceOverlapTool::get_overlap_tolerance | ( | ) | [inline, static] |
Definition at line 430 of file SurfaceOverlapTool.hpp.
{return overlapTolerance;}
| CubitBoolean SurfaceOverlapTool::get_skip_facing_surfaces | ( | ) | [inline] |
Definition at line 482 of file SurfaceOverlapTool.hpp.
{return skipFacingSurfaces;}
| CubitStatus SurfaceOverlapTool::imprint | ( | DLIList< RefFace * > & | ref_face_list1, |
| DLIList< RefFace * > & | ref_face_list2 | ||
| ) | [private] |
Definition at line 1516 of file SurfaceOverlapTool.cpp.
//This is a very tricky goal. The goal is to imprint each pair for the
//two lists. The problem is that we need to imprint the bodies of the
//surfaces not just the surfaces since this isn't as robust. The problem
//is that more than one of these surfaces may reference the same body. So
//in fact as we imprint one of the surfaces, the other ones could get deleted and
//create a memory leak.
//The only thing I can think of is to use the id's of the bodies as the constant.
//On the imprint, the body id should not change. So lets create an array of bodies,
//and update the array as they get changed. The array will allow constant access time.
DLIList <Body*> body_list, temp_bodies;
DLIList <int> body_ids1, body_ids2, modified_list;
DLIList <DLIList<RefEdge*>*> edges_list1, edges_list2;
DLIList <RefEdge*> *ref_edges1, *ref_edges2, tmp_edges;
CubitBoolean print = CUBIT_TRUE;
Body *tmp_body;
int i, max_id = -1;
//first get the max id of the bodies here to help us
//get the size of the array.
for ( i = ref_face_list1.size(); i > 0; i-- )
temp_bodies.clean_out();
RefFace *ref_face1 = ref_face_list1.get_and_step();
if ( ref_face1 == NULL )
PRINT_ERROR("Bad data sent to imprint overlaps.\n");
ref_face1->bodies(temp_bodies);
if ( temp_bodies.size() != 1 )
PRINT_WARNING("Entities must be in one body\n");
PRINT_WARNING("Skipping that entity\n");
ref_face_list2.step();
continue;
tmp_body = temp_bodies.get();
RefFace *ref_face2 = ref_face_list2.get_and_step();
if ( ref_face2 == NULL )
ref_face2->bodies(temp_bodies);
continue;
if ( tmp_body->id() > max_id )
max_id = tmp_body->id();
body_list.append(tmp_body);
body_ids1.append(tmp_body->id());
body_list.append(temp_bodies.get());
body_ids2.append(temp_bodies.get()->id());
if ( temp_bodies.get()->id() > max_id )
max_id = temp_bodies.get()->id();
//Now set up the edge lists.
ref_edges1 = new DLIList<RefEdge*>;
ref_face1->ref_edges(tmp_edges);
CubitStatus stat = copy_edges_in_list(tmp_edges, *ref_edges1);
ref_edges2 = new DLIList<RefEdge*>;
tmp_edges.clean_out();
ref_face2->ref_edges(tmp_edges);
stat = copy_edges_in_list(tmp_edges, *ref_edges2);
edges_list1.append(ref_edges1);
edges_list2.append(ref_edges2);
//Now create an array and store all of the bodies.
Body **body_array = new Body* [2*max_id+1];
//initialize the array to null.
for ( i = 0; i < 2*max_id+1; i++ )
body_array[i] = (Body*)NULL;
//Now put the bodies into the array.
for ( i = body_list.size(); i > 0; i-- )
tmp_body = body_list.get_and_step();
body_array[tmp_body->id()] = tmp_body;
//Now go through and pairwise imprint the bodies.
DLIList <Body*> bodies, tmp_modified_bodies;
for( i = body_ids1.size(); i > 0; i-- )
tmp_modified_bodies.clean_out();
int id1 = body_ids1.get_and_step();
int id2 = body_ids2.get_and_step();
ref_edges1 = edges_list1.get_and_step();
ref_edges2 = edges_list2.get_and_step();
Body *body1 = body_array[id1];
Body *body2 = body_array[id2];
int body1_num = num_descendants(body1);
int body2_num = num_descendants(body2);
bodies.clean_out();
bodies.append(body2);
CubitStatus stat = GeometryModifyTool::instance()->
imprint(bodies, *ref_edges1, tmp_modified_bodies, CUBIT_FALSE, CUBIT_FALSE);
if ( stat == CUBIT_SUCCESS && tmp_modified_bodies.size() == 1 )
body2 = tmp_modified_bodies.get();
bodies.clean_out();
bodies.append(body1);
imprint(bodies, *ref_edges2, tmp_modified_bodies, CUBIT_FALSE, CUBIT_FALSE);
body1 = tmp_modified_bodies.get();
body_array[id1] = body1;
int temp_num = num_descendants(body1);
if ( temp_num != body1_num )
modified_list.append_unique(id1);
body_array[id2] = body2;
temp_num = num_descendants(body2);
if ( temp_num != body2_num )
modified_list.append_unique(id2);
if ( modified_list.size() && print )
if ( modified_list.size() != 1 )
PRINT_INFO("Imprinting Modified Bodies: ");
else
PRINT_INFO("Imprinting Modified Body: ");
for ( i = 0; i < modified_list.size(); i++ )
if ( i != modified_list.size()-1 )
if (i%10 == 0 && i != 0 )
PRINT_INFO("%d,\n", modified_list.get_and_step());
else
PRINT_INFO("%d, ", modified_list.get_and_step());
else
PRINT_INFO("%d.\n", modified_list.get_and_step());
else if ( modified_list.size() == 0 && print )
PRINT_INFO("Imprinting overlaps resulted in no modifications.\n");
//clean up our memory.
for ( i = edges_list1.size(); i > 0; i-- )
ref_edges1 = edges_list1.remove();
ref_edges2 = edges_list2.remove();
delete_edges_in_list(*ref_edges1);
delete_edges_in_list(*ref_edges2);
delete ref_edges1;
delete ref_edges2;
delete [] body_array;
| void SurfaceOverlapTool::initialize_settings | ( | ) | [static] |
Definition at line 1733 of file SurfaceOverlapTool.cpp.
SettingHandler::instance()->add_setting("Overlap Facet BBox Absolute",
SurfaceOverlapTool::set_facet_abs_tol,
SurfaceOverlapTool::get_facet_abs_tol);
SettingHandler::instance()->add_setting("Overlap Facet BBox Angle",
SurfaceOverlapTool::set_facet_ang_tol_setting,
SurfaceOverlapTool::get_facet_ang_tol_setting);
SettingHandler::instance()->add_setting("Overlap Minimum Gap",
SurfaceOverlapTool::set_gap_min,
SurfaceOverlapTool::get_gap_min);
SettingHandler::instance()->add_setting("Overlap Maximum Gap",
SurfaceOverlapTool::set_gap_max,
SurfaceOverlapTool::get_gap_max);
SettingHandler::instance()->add_setting("Overlap Minimum Angle",
SurfaceOverlapTool::set_angle_min,
SurfaceOverlapTool::get_angle_min);
SettingHandler::instance()->add_setting("Overlap Maximum Angle",
SurfaceOverlapTool::set_angle_max,
SurfaceOverlapTool::get_angle_max);
SettingHandler::instance()->add_setting("Overlap Normal",
SurfaceOverlapTool::set_normal_type_setting,
SurfaceOverlapTool::get_normal_type_setting);
SettingHandler::instance()->add_setting("Overlap Tolerance",
SurfaceOverlapTool::set_overlap_tolerance,
SurfaceOverlapTool::get_overlap_tolerance);
SettingHandler::instance()->add_setting("Overlap Group",
SurfaceOverlapTool::set_group_results_setting,
SurfaceOverlapTool::get_group_results_setting);
SettingHandler::instance()->add_setting("Overlap List",
SurfaceOverlapTool::set_list_pairs_setting,
SurfaceOverlapTool::get_list_pairs_setting);
SettingHandler::instance()->add_setting("Overlap Display",
SurfaceOverlapTool::set_display_pairs_setting,
SurfaceOverlapTool::get_display_pairs_setting);
SettingHandler::instance()->add_setting("Overlap Within Bodies",
SurfaceOverlapTool::set_check_within_bodies,
SurfaceOverlapTool::get_check_within_bodies);
SettingHandler::instance()->add_setting("Overlap Across Bodies",
SurfaceOverlapTool::set_check_across_bodies,
SurfaceOverlapTool::get_check_across_bodies);
| SurfaceOverlapTool * SurfaceOverlapTool::instance | ( | void | ) | [static] |
Definition at line 61 of file SurfaceOverlapTool.cpp.
if( instance_ == NULL )
instance_ = new SurfaceOverlapTool;
return instance_;
| void SurfaceOverlapTool::list_settings | ( | ) |
List the settings used for surface overlap detection.
Definition at line 1422 of file SurfaceOverlapTool.cpp.
char on_off[2][4];
strcpy( on_off[0], "Off" );
strcpy( on_off[1], "On" );
PRINT_INFO( "Surface Overlap Algorithm Settings:\n" );
if( facetAbsTol == 0.0 )
PRINT_INFO( " Facetting Absolute Tolerance: 0.0 (using default solid modeler setting)\n" );
else
PRINT_INFO( " Facetting Absolute Tolerance: %f\n", facetAbsTol );
if( facetAngTol == 0 )
PRINT_INFO( " Facetting Angle Tolerance: 0 (using default solid modeler setting)\n" );
else
PRINT_INFO( " Facetting Angle Tolerance: %d\n", facetAngTol );
PRINT_INFO( " Gap Range: %f to %f\n", gapMin, gapMax );
PRINT_INFO( " Angle Range: %.1f to %.1f degrees\n", angleMin, angleMax );
PRINT_INFO( " Overlap Area Tolerance: %f\n", overlapTolerance );
switch( normalType )
case 1:
PRINT_INFO( " Pair Normals Allowed: Any\n" );
break;
case 2:
PRINT_INFO( " Pair Normals Allowed: Opposite\n" );
break;
case 3:
PRINT_INFO( " Pair Normals Allowed: Same\n" );
break;
PRINT_INFO( " Display Pairs: %s\n", on_off[displayPairs] );
PRINT_INFO( " List Pairs: %s\n", on_off[listPairs] );
PRINT_INFO( " Group Results: %s\n", on_off[groupResults] );
PRINT_INFO( " Across Body|Volume: %s\n", on_off[checkAcrossBodies] );
PRINT_INFO( " Within Body|Volume: %s\n", on_off[checkWithinBodies] );
PRINT_INFO( " Imprint: %s\n", on_off[imprintResults] );
| int SurfaceOverlapTool::num_descendants | ( | Body * | body | ) | [private] |
Definition at line 1688 of file SurfaceOverlapTool.cpp.
int counter = 0;
counter += body->num_ref_volumes();
counter += body->num_ref_faces();
counter += body->num_ref_edges();
counter += body->num_ref_vertices();
return counter;
| void SurfaceOverlapTool::set_angle_max | ( | double | val | ) | [inline, static] |
Definition at line 426 of file SurfaceOverlapTool.hpp.
{angleMax=val;}
| void SurfaceOverlapTool::set_angle_min | ( | double | val | ) | [inline, static] |
Definition at line 419 of file SurfaceOverlapTool.hpp.
{angleMin=val;}
| void SurfaceOverlapTool::set_check_across_bodies | ( | CubitBoolean | setting | ) | [inline, static] |
Definition at line 479 of file SurfaceOverlapTool.hpp.
{checkAcrossBodies=setting;}
| void SurfaceOverlapTool::set_check_within_bodies | ( | CubitBoolean | setting | ) | [inline, static] |
Definition at line 473 of file SurfaceOverlapTool.hpp.
{checkWithinBodies=setting;}
| void SurfaceOverlapTool::set_display_pairs | ( | CubitBoolean | setting | ) | [inline, static] |
Definition at line 461 of file SurfaceOverlapTool.hpp.
{displayPairs=setting;}
| void SurfaceOverlapTool::set_display_pairs_setting | ( | int | setting | ) | [static] |
Definition at line 1505 of file SurfaceOverlapTool.cpp.
{displayPairs = (setting) ? CUBIT_TRUE : CUBIT_FALSE;}
| void SurfaceOverlapTool::set_facet_abs_tol | ( | double | absolute_tol | ) | [inline, static] |
Definition at line 398 of file SurfaceOverlapTool.hpp.
{facetAbsTol=val;}
| void SurfaceOverlapTool::set_facet_ang_tol | ( | unsigned short | angle_tol | ) | [inline] |
Definition at line 391 of file SurfaceOverlapTool.hpp.
{facetAngTol=val;}
| void SurfaceOverlapTool::set_facet_ang_tol_setting | ( | int | angle_tol | ) | [static] |
Definition at line 1511 of file SurfaceOverlapTool.cpp.
{facetAngTol=(unsigned short)val;}
| void SurfaceOverlapTool::set_gap_max | ( | double | val | ) | [inline, static] |
Definition at line 412 of file SurfaceOverlapTool.hpp.
{gapMax=val;}
| void SurfaceOverlapTool::set_gap_min | ( | double | val | ) | [inline, static] |
Definition at line 405 of file SurfaceOverlapTool.hpp.
{gapMin=val;}
| void SurfaceOverlapTool::set_group_results | ( | CubitBoolean | setting | ) | [inline, static] |
Definition at line 447 of file SurfaceOverlapTool.hpp.
{groupResults=setting;}
| void SurfaceOverlapTool::set_group_results_setting | ( | int | setting | ) | [static] |
Definition at line 1493 of file SurfaceOverlapTool.cpp.
{groupResults = (setting) ? CUBIT_TRUE : CUBIT_FALSE;}
| void SurfaceOverlapTool::set_imprint | ( | CubitBoolean | setting | ) | [inline, static] |
Definition at line 467 of file SurfaceOverlapTool.hpp.
{imprintResults=setting;}
| void SurfaceOverlapTool::set_list_pairs | ( | CubitBoolean | setting | ) | [inline, static] |
Definition at line 454 of file SurfaceOverlapTool.hpp.
{listPairs=setting;}
| void SurfaceOverlapTool::set_list_pairs_setting | ( | int | setting | ) | [static] |
Definition at line 1499 of file SurfaceOverlapTool.cpp.
{listPairs = (setting) ? CUBIT_TRUE : CUBIT_FALSE;}
| void SurfaceOverlapTool::set_normal_type | ( | int | type | ) | [inline, static] |
Definition at line 440 of file SurfaceOverlapTool.hpp.
{normalType=type;}
| void SurfaceOverlapTool::set_normal_type_setting | ( | CubitString | type | ) | [static] |
Definition at line 1477 of file SurfaceOverlapTool.cpp.
if (CubitUtil::compare(type.c_str(), "opposite")) {
normalType = 2;
else if (CubitUtil::compare(type.c_str(), "same")) {
normalType = 3;
else {
normalType = 1;
| void SurfaceOverlapTool::set_overlap_tolerance | ( | double | val | ) | [inline, static] |
Definition at line 433 of file SurfaceOverlapTool.hpp.
{overlapTolerance=val;}
| void SurfaceOverlapTool::set_skip_facing_surfaces | ( | CubitBoolean | setting | ) | [inline] |
Definition at line 485 of file SurfaceOverlapTool.hpp.
{skipFacingSurfaces=setting;}
double SurfaceOverlapTool::angleMax = 5.0 [static, private] |
Angle comparison for determining if facets are coplanar. If they are within angleMin and angleMax they are considered to be coplanar.
Definition at line 351 of file SurfaceOverlapTool.hpp.
double SurfaceOverlapTool::angleMin = 0.0 [static, private] |
Definition at line 350 of file SurfaceOverlapTool.hpp.
CubitBoolean SurfaceOverlapTool::checkAcrossBodies = CUBIT_TRUE [static, private] |
If true, by default, will try to find surfaces of body A that overlap surfaces of body B. Setting this flag to false will make the tool only check for surfaces that overlap in the same body.
Definition at line 387 of file SurfaceOverlapTool.hpp.
CubitBoolean SurfaceOverlapTool::checkWithinBodies = CUBIT_FALSE [static, private] |
By default this tool will not search for overlapping pairs within bodies - only between different bodies. Turn this setting on to search for pairs within bodies. Note however that this will slow the algorithm down.
Definition at line 381 of file SurfaceOverlapTool.hpp.
CubitBoolean SurfaceOverlapTool::displayPairs = CUBIT_TRUE [static, private] |
Draws the lists of overlapping surface pairs.
Definition at line 365 of file SurfaceOverlapTool.hpp.
double SurfaceOverlapTool::facetAbsTol = 0.0 [static, private] |
The distance tolerance means the maximum actual distance between the generated facets and the surface. This value is by default ignored by the facetter - consider specifying a reasonable value here for more accurate results
Definition at line 339 of file SurfaceOverlapTool.hpp.
unsigned short SurfaceOverlapTool::facetAngTol = 15 [static, private] |
The angular tolerance indicates the maximum angle between normals of adjacent surface facets. The default angular tolerance is 15° - consider using a value of 5° . This will generate a more accurate facetted representation of the geometry for overlap detection.
Definition at line 333 of file SurfaceOverlapTool.hpp.
double SurfaceOverlapTool::gapMax = 0.01 [static, private] |
Definition at line 344 of file SurfaceOverlapTool.hpp.
double SurfaceOverlapTool::gapMin = 0.0 [static, private] |
The overlap algorithm will search for surfaces that are within a distance from the gapMin to gapMax.
Definition at line 343 of file SurfaceOverlapTool.hpp.
CubitBoolean SurfaceOverlapTool::groupResults = CUBIT_TRUE [static, private] |
Controls if surfaces are put in a group or not.
Definition at line 359 of file SurfaceOverlapTool.hpp.
CubitBoolean SurfaceOverlapTool::imprintResults = CUBIT_FALSE [static, private] |
Imprint overlapping surfaces parts onto one another.
Definition at line 368 of file SurfaceOverlapTool.hpp.
SurfaceOverlapTool * SurfaceOverlapTool::instance_ = 0 [static, private] |
Definition at line 322 of file SurfaceOverlapTool.hpp.
CubitBoolean SurfaceOverlapTool::listPairs = CUBIT_TRUE [static, private] |
Prints out the lists of overlapping surface pairs.
Definition at line 362 of file SurfaceOverlapTool.hpp.
int SurfaceOverlapTool::normalType = 1 [static, private] |
Searches for overlapping surface that have surface normals in any, opposite, or the same direction.
Definition at line 356 of file SurfaceOverlapTool.hpp.
double SurfaceOverlapTool::overlapTolerance = .001 [static, private] |
The area threshold that 2 surfaces have to actually overlap. Prevents detection of sliver overlaps.
Definition at line 372 of file SurfaceOverlapTool.hpp.
bool SurfaceOverlapTool::skipFacingSurfaces = CUBIT_FALSE [static, private] |
if the normalType is 2 skip surfaces that face each other
Definition at line 375 of file SurfaceOverlapTool.hpp.
