cgma
This is a singleton pattern class for the feature functions. More...
#include <GeometryFeatureTool.hpp>
Public Member Functions | |
| ~GeometryFeatureTool () | |
| destructor | |
| void | add_gfe (GeometryFeatureEngine *gfe_ptr) |
| add a feature engine to the list | |
| GeometryFeatureEngine::FeatureType | feature_type (BasicTopologyEntity *bte) |
| Returns the feature type that created the entity. | |
| CubitStatus | get_related_by_feature (BasicTopologyEntity *bte, DLIList< GeometryEntity * > &return_list) |
| Get all of the entities related to 'entity_in' by the same source feature. | |
| DLIList < GeometryFeatureEngine::FeatureType > | available_feature_types (BasicTopologyEntity *bte) |
| Get the feature types available from this FeatureEngine. | |
Static Public Member Functions | |
| static GeometryFeatureTool * | instance (GeometryFeatureEngine *GFEPtr=NULL) |
| static void | delete_instance () |
Protected Member Functions | |
| GeometryFeatureTool (GeometryFeatureEngine *GFEPtr) | |
| constructor | |
Private Member Functions | |
| GeometryFeatureEngine * | get_engine (TopologyBridge *tb_ptr) const |
| returns the feature engine of an entity | |
| GeometryFeatureEngine * | get_engine (TopologyEntity *te_ptr) const |
| CubitBoolean | same_feature_engine (DLIList< RefEntity * > &ref_entity_list, CubitBoolean check_children) const |
| determines if entities belong to the same engine | |
| CubitBoolean | same_feature_engine (DLIList< TopologyEntity * > &topo_list) const |
Private Attributes | |
| DLIList< GeometryFeatureEngine * > | gfeList |
| list of feature engines | |
Static Private Attributes | |
| static GeometryFeatureTool * | instance_ = 0 |
| singleton pattern class instance interface | |
Definition at line 22 of file GeometryFeatureTool.hpp.
destructor
Definition at line 41 of file GeometryFeatureTool.cpp.
| GeometryFeatureTool::GeometryFeatureTool | ( | GeometryFeatureEngine * | GFEPtr | ) | [protected] |
constructor
Definition at line 202 of file GeometryFeatureTool.cpp.
if (GFEPtr != NULL)
add_gfe(GFEPtr);
| void GeometryFeatureTool::add_gfe | ( | GeometryFeatureEngine * | gfe_ptr | ) |
| DLIList< GeometryFeatureEngine::FeatureType > GeometryFeatureTool::available_feature_types | ( | BasicTopologyEntity * | bte | ) |
Definition at line 183 of file GeometryFeatureTool.cpp.
TopologyEntity* topo_ptr = CAST_TO(bte, TopologyEntity);
DLIList<GeometryFeatureEngine::FeatureType> null_list;
if (!topo_ptr)
return null_list;
GeometryFeatureEngine* gfe = get_engine(topo_ptr);
if(!gfe)
return null_list;
return gfe->available_feature_types(bte->get_geometry_entity_ptr());
| static void GeometryFeatureTool::delete_instance | ( | ) | [inline, static] |
Definition at line 33 of file GeometryFeatureTool.hpp.
Definition at line 140 of file GeometryFeatureTool.cpp.
// first check to see if the feature information is in the tool data
TDSourceFeature *tdss = 0;
tdss = (TDSourceFeature *)bte->
get_TD(&TDSourceFeature::is_source_feature);
if(tdss)
return tdss->source_feature();
// if the feature information is not in the tool data
// then call the engine specific FeatureEngine
if (!topo_ptr)
return GeometryFeatureEngine::FEATURE_UNDEFINED;
if(!gfe)
return gfe->feature_type(bte->get_geometry_entity_ptr());
| GeometryFeatureEngine * GeometryFeatureTool::get_engine | ( | TopologyBridge * | tb_ptr | ) | const [private] |
Definition at line 59 of file GeometryFeatureTool.cpp.
GeometryFeatureEngine *gfe;
for (int i = 0; i < gfeList.size(); i++)
gfe = gfeList.next(i);
if (gfe->is_feature_engine(tb_ptr))
return gfe;
return NULL;
| GeometryFeatureEngine * GeometryFeatureTool::get_engine | ( | TopologyEntity * | te_ptr | ) | const [private] |
Definition at line 73 of file GeometryFeatureTool.cpp.
TopologyBridge *tb_ptr = te_ptr->bridge_manager()->topology_bridge();
return gfe;
return NULL;
| CubitStatus GeometryFeatureTool::get_related_by_feature | ( | BasicTopologyEntity * | bte, |
| DLIList< GeometryEntity * > & | return_list | ||
Definition at line 165 of file GeometryFeatureTool.cpp.
if (!topo_ptr)
return CUBIT_FAILURE;
if(!gfe)
return gfe->get_related_by_feature(bte->get_geometry_entity_ptr(),return_list);
| GeometryFeatureTool * GeometryFeatureTool::instance | ( | GeometryFeatureEngine * | GFEPtr = NULL | ) | [static] |
Definition at line 15 of file GeometryFeatureTool.cpp.
// Check to see if we have created an instance of the class;
// if not, proceed to create one.
if (instance_ == 0)
// When creating the instance, we should always have a valid
// gfePtr. If not, complain.
instance_ = new GeometryFeatureTool(GFEPtr);
// Check to make sure there's a ref entity factory extant:
// RefEntityFactory *factory =
RefEntityFactory::instance();
// If there is an existing instance of the class, check if there
// is a request to set the default engine. If so, do so.
else if ( GFEPtr != NULL && !instance_->gfeList.move_to(GFEPtr) )
delete instance_->gfeList.remove();
instance_->gfeList.insert(GFEPtr);
// Return the a pointer to the instance of the class.
return instance_;
| CubitBoolean GeometryFeatureTool::same_feature_engine | ( | DLIList< RefEntity * > & | ref_entity_list, |
| CubitBoolean | check_children | ||
Definition at line 89 of file GeometryFeatureTool.cpp.
DLIList<RefEntity*> complete_entity_list;
//Check the check_children option and check all the children if necessary
if (check_children)
//Make a complete list of all the RefEntities and their children
DLIList<RefEntity*> temp = ref_entity_list;
RefEntity* ref_entity_ptr;
for (int i = 0; i < ref_entity_list.size(); i++)
ref_entity_ptr = ref_entity_list.get_and_step();
complete_entity_list.clean_out();
ref_entity_ptr->get_all_child_ref_entities(complete_entity_list);
temp += complete_entity_list;
complete_entity_list.merge_unique(temp);
//Now make sure all the RefEntities are from the same geometry engine
DLIList<TopologyEntity*> te_list;
CAST_LIST(complete_entity_list, te_list, TopologyEntity);
return same_feature_engine(te_list);
| CubitBoolean GeometryFeatureTool::same_feature_engine | ( | DLIList< TopologyEntity * > & | topo_list | ) | const [private] |
Definition at line 119 of file GeometryFeatureTool.cpp.
GeometryFeatureEngine *gePtr1 = get_engine(topo_list.get_and_step());
GeometryFeatureEngine *gePtr2;
for (int i = 1; i < topo_list.size(); i++)
gePtr2 = get_engine(topo_list.get_and_step());
if (gePtr1 != gePtr2)
return CUBIT_FALSE;
return CUBIT_TRUE;
DLIList<GeometryFeatureEngine*> GeometryFeatureTool::gfeList [private] |
Definition at line 84 of file GeometryFeatureTool.hpp.
GeometryFeatureTool * GeometryFeatureTool::instance_ = 0 [static, private] |
Definition at line 81 of file GeometryFeatureTool.hpp.
