cgma
#include <SurfaceOverlapFacet.hpp>
Public Member Functions | |
| SurfaceOverlapFacet (GPoint pnt[3]) | |
| ~SurfaceOverlapFacet () | |
| double | distance (SurfaceOverlapFacet &other_facet) |
| CubitBoolean | facing (SurfaceOverlapFacet &other_facet) |
| double | angle (SurfaceOverlapFacet &other_facet) |
| double | projected_overlap (SurfaceOverlapFacet &other_facet, CubitBoolean draw_overlap=CUBIT_FALSE) |
| double | distance_from_position (CubitVector &position) |
| bool | facet_points_within_tol (SurfaceOverlapFacet *other_face, double tolerance) |
| double | perimeter () |
| bool | bbox_overlap (double tol, SurfaceOverlapFacet &other_facet) |
| CubitBox | bounding_box () |
| void | draw (int color) |
| CubitVector | centroid () |
| CubitVector | smallest_edge_midpoint () |
Private Attributes | |
| Triangle3 | t |
| CubitBox | boundingBox |
Static Private Attributes | |
| static AnalyticGeometryTool * | agt = AnalyticGeometryTool::instance() |
Definition at line 29 of file SurfaceOverlapFacet.hpp.
Definition at line 13 of file SurfaceOverlapFacet.cpp.
t.b.x = p[0].x;
t.b.y = p[0].y;
t.b.z = p[0].z;
t.e0.x = p[1].x - p[0].x;
t.e0.y = p[1].y - p[0].y;
t.e0.z = p[1].z - p[0].z;
t.e1.x = p[2].x - p[0].x;
t.e1.y = p[2].y - p[0].y;
t.e1.z = p[2].z - p[0].z;
CubitVector min;
min.set( CUBIT_MIN_3( p[0].x, p[1].x, p[2].x ),
CUBIT_MIN_3( p[0].y, p[1].y, p[2].y ),
CUBIT_MIN_3( p[0].z, p[1].z, p[2].z ) );
CubitVector max;
max.set( CUBIT_MAX_3( p[0].x, p[1].x, p[2].x ),
CUBIT_MAX_3( p[0].y, p[1].y, p[2].y ),
CUBIT_MAX_3( p[0].z, p[1].z, p[2].z ) );
boundingBox.reset( min, max );
Definition at line 43 of file SurfaceOverlapFacet.cpp.
| double SurfaceOverlapFacet::angle | ( | SurfaceOverlapFacet & | other_facet | ) |
| bool SurfaceOverlapFacet::bbox_overlap | ( | double | tol, |
| SurfaceOverlapFacet & | other_facet | ||
| ) | [inline] |
Definition at line 49 of file SurfaceOverlapFacet.hpp.
{ return boundingBox.overlap( tol, other_facet.boundingBox ); }
| CubitBox SurfaceOverlapFacet::bounding_box | ( | void | ) | [inline] |
Definition at line 52 of file SurfaceOverlapFacet.hpp.
{ return boundingBox; }
Definition at line 175 of file SurfaceOverlapFacet.cpp.
| double SurfaceOverlapFacet::distance | ( | SurfaceOverlapFacet & | other_facet | ) |
Definition at line 47 of file SurfaceOverlapFacet.cpp.
double s, t2, u, v;
return agt->MinTriangleTriangle( t, other_facet.t, s, t2, u, v );
| double SurfaceOverlapFacet::distance_from_position | ( | CubitVector & | position | ) |
| void SurfaceOverlapFacet::draw | ( | int | color | ) |
Definition at line 158 of file SurfaceOverlapFacet.cpp.
CubitVector point1 = CubitVector( t.b.x, t.b.y, t.b.z );
CubitVector point2 = CubitVector( t.e0.x + t.b.x,
t.e0.y + t.b.y,
t.e0.z + t.b.z );
CubitVector point3 = CubitVector( t.e1.x + t.b.x,
t.e1.y + t.b.y,
t.e1.z + t.b.z );
GfxPreview::draw_line( point1, point2, color );
GfxPreview::draw_line( point2, point3, color );
GfxPreview::draw_line( point1, point3, color );
return;
| bool SurfaceOverlapFacet::facet_points_within_tol | ( | SurfaceOverlapFacet * | other_face, |
| double | tolerance | ||
Definition at line 70 of file SurfaceOverlapFacet.cpp.
CubitVector tmp_pt( t.b.x, t.b.y, t.b.z );
if( this->distance_from_position( tmp_pt ) > tolerance )
return false;
tmp_pt.set( t.b.x + t.e0.x,
t.b.y + t.e0.y,
t.b.z + t.e0.z );
return false;
tmp_pt.set( t.b.x + t.e1.x,
t.b.y + t.e1.y,
t.b.z + t.e1.z );
return false;
return true;
| CubitBoolean SurfaceOverlapFacet::facing | ( | SurfaceOverlapFacet & | other_facet | ) |
Definition at line 104 of file SurfaceOverlapFacet.cpp.
double norm1[3];
agt->Normal( t, norm1 );
double norm2[3];
agt->Normal( other_facet.t, norm2 );
// move to the origin
double o1[3];
o1[0] = other_facet.t.b.x-t.b.x;
o1[1] = other_facet.t.b.y-t.b.y;
o1[2] = other_facet.t.b.z-t.b.z;
double dot_p = agt->dot_vec(norm1,o1);
return (CubitBoolean)(dot_p >= 0.0);
| double SurfaceOverlapFacet::perimeter | ( | ) |
Definition at line 53 of file SurfaceOverlapFacet.cpp.
CubitVector pt0( t.b.x, t.b.y, t.b.z );
CubitVector pt1( t.b.x + t.e0.x,
t.b.y + t.e0.y,
t.b.z + t.e0.z );
CubitVector pt2( t.b.x + t.e1.x,
t.b.y + t.e1.y,
t.b.z + t.e1.z );
double total_dist = pt0.distance_between(pt1);
total_dist += pt1.distance_between( pt2 );
total_dist += pt2.distance_between( pt0 );
return total_dist;
| double SurfaceOverlapFacet::projected_overlap | ( | SurfaceOverlapFacet & | other_facet, |
| CubitBoolean | draw_overlap = CUBIT_FALSE |
Definition at line 128 of file SurfaceOverlapFacet.cpp.
double tmp_double = agt->ProjectedOverlap( t, other_facet.t, draw_overlap );
if( tmp_double > 0.00 )
CubitVector edge0(t.e0.x, t.e0.y, t.e0.z);
CubitVector edge1(t.e1.x, t.e1.y, t.e1.z);
CubitVector normal = edge0 * edge1;
double area_facet1 = normal.length() / 2;
edge0.set(other_facet.t.e0.x, other_facet.t.e0.y, other_facet.t.e0.z);
edge1.set(other_facet.t.e1.x, other_facet.t.e1.y, other_facet.t.e1.z);
double area_facet2 = normal.length() / 2;
//don't report overlapping area between facets unless it is greater
//than one hundredth of the area of the smaller facet
if( area_facet1 < area_facet2 )
if( tmp_double < (area_facet1*0.01))
tmp_double = 0.0;
else if( tmp_double < (area_facet2*0.01 ))
tmp_double = 0.0;
return tmp_double;
Definition at line 193 of file SurfaceOverlapFacet.cpp.
t.e0.y + t.b.y,
t.e0.z + t.b.z );
t.e1.y + t.b.y,
t.e1.z + t.b.z );
double len_12 = point1.distance_between( point2 );
double len_23 = point2.distance_between( point3 );
double len_13 = point1.distance_between( point3 );
if( (len_12 < len_23) && (len_12 < len_13) )
point1 += point2;
point1 /= 2;
return point1;
else if( len_23 < len_13 )
point2 += point3;
point2 /= 2;
return point2;
else
point1 += point3;
point1 /= 2;
return point1;
AnalyticGeometryTool * SurfaceOverlapFacet::agt = AnalyticGeometryTool::instance() [static, private] |
Definition at line 65 of file SurfaceOverlapFacet.hpp.
CubitBox SurfaceOverlapFacet::boundingBox [private] |
Definition at line 64 of file SurfaceOverlapFacet.hpp.
Triangle3 SurfaceOverlapFacet::t [private] |
Definition at line 63 of file SurfaceOverlapFacet.hpp.
