cgma
#include <CurveFacetEvalTool.hpp>
Definition at line 26 of file CurveFacetEvalTool.hpp.
Definition at line 150 of file CurveFacetEvalTool.cpp.
static int counter = 0;
toolID = counter++;
myBBox = NULL;
goodCurveData = CUBIT_TRUE;
Definition at line 164 of file CurveFacetEvalTool.cpp.
if ( myBBox ) delete myBBox;
destroy_facets();
| CubitBox CurveFacetEvalTool::bounding_box | ( | void | ) |
Definition at line 578 of file CurveFacetEvalTool.cpp.
if ( !myBBox )
int ii;
CubitPoint *point_ptr;
double x, y, z;
double x_min = CUBIT_DBL_MAX, x_max = -CUBIT_DBL_MAX;
double y_min = CUBIT_DBL_MAX, y_max = -CUBIT_DBL_MAX;
double z_min = CUBIT_DBL_MAX, z_max = -CUBIT_DBL_MAX;
for ( ii = myPointList.size(); ii > 0; ii-- )
point_ptr = myPointList.get_and_step();
x = point_ptr->x();
y = point_ptr->y();
z = point_ptr->z();
if ( x < x_min )
x_min = x;
if ( y < y_min )
y_min = y;
if ( z < z_min )
z_min = z;
if ( x > x_max )
x_max = x;
if ( y > y_max )
y_max = y;
if ( z > z_max )
z_max = z;
CubitVector min_v(x_min, y_min, z_min );
CubitVector max_v(x_max, y_max, z_max );
myBBox = new CubitBox( min_v, max_v );
return *(myBBox);
| CubitStatus CurveFacetEvalTool::closest_point | ( | CubitVector & | this_point, |
| CubitVector & | closest_point_ptr, | ||
| CubitVector * | normal_ptr = NULL, |
| CubitVector * | curvature_ptr = NULL, |
| double * | param = NULL |
Definition at line 805 of file CurveFacetEvalTool.cpp.
CubitStatus stat = CUBIT_SUCCESS;
// int outside;
int mydebug = 0;
if (mydebug)
draw_location(this_point, CUBIT_RED_INDEX);
if (surfFacetEvalTool == NULL)
stat = project_to_linear_facet_edge( this_point, closest_point,
tangent_ptr, curvature_ptr,
param, &outside );
else
stat = project_to_facet_edge( this_point, closest_point,
tangent_ptr, curvature_ptr, param, &outside );
int i;
CubitVector test_pt_v, closest_pt_v, pt0_v, pt1_v;
double distance2, closest_distance2; // distance squared
CubitFacetEdge *edge, *best_edge = NULL;
myEdgeList.reset();
closest_distance2 = CUBIT_DBL_MAX;
for ( i = myEdgeList.size(); i > 0; i-- ) {
edge = myEdgeList.get_and_step();
pt0_v = edge->point(0)->coordinates();
pt1_v = edge->point(1)->coordinates();
test_pt_v = FacetDataUtil::squared_distance_to_segment(this_point,
pt0_v,pt1_v,distance2);
if ( distance2 < closest_distance2 ) {
closest_distance2 = distance2;
closest_pt_v = test_pt_v;
best_edge = edge;
if ( distance2 < GEOMETRY_RESABS*GEOMETRY_RESABS ) break;
if (mydebug)
myEdgeList.reset();
GfxDebug::draw_point(pt0_v, CUBIT_GREEN_INDEX );
GfxDebug::draw_point(pt1_v, CUBIT_RED_INDEX );
GfxDebug::flush();
if ( interpOrder == 0 ) {
closest_point = closest_pt_v;
if (tangent_ptr) {
CubitVector tangent;
if (best_edge->edge_tangent( closest_point, tangent ) != CUBIT_SUCCESS) {
return CUBIT_FAILURE;
if (curvSense == CUBIT_REVERSED)
tangent = -tangent;
*tangent_ptr = tangent;
// evaluate the curvature if required
if (curvature_ptr)
if( myEdgeList.size() == 1 )
(*curvature_ptr).set( 0, 0, 0);
else
CubitVector curvature;
myEdgeList.move_to( best_edge );
int index = myEdgeList.get_index();
//"best_edge" could be last or first on curve
CubitFacetEdge* prev_edge = NULL;
myEdgeList.back();
if( (index - 1) == myEdgeList.get_index() )
prev_edge = myEdgeList.get();
CubitFacetEdge* next_edge = NULL;
myEdgeList.step(2);
if( (index + 1) == myEdgeList.get_index() )
next_edge = myEdgeList.get();
CubitFacetEdge *closest_edge;
//determine which adjacent edge is closest to "best_point"
if( prev_edge && next_edge )
CubitVector tmp_vec;
double prev_dist, next_dist;
tmp_vec = (prev_edge->point(0)->coordinates() +
prev_edge->point(1)->coordinates() ) / 2;
prev_dist = closest_point.distance_between( tmp_vec );
tmp_vec = (next_edge->point(0)->coordinates() +
next_edge->point(1)->coordinates() ) / 2;
next_dist = closest_point.distance_between( tmp_vec );
if( prev_dist < next_dist )
closest_edge = prev_edge;
else
closest_edge = next_edge;
else if( prev_edge )
else
if (best_edge->edge_curvature( closest_point, curvature, closest_edge ) != CUBIT_SUCCESS) {
curvature = -curvature;
*curvature_ptr = curvature;
} else if ( interpOrder == 4 ) {
double t_value;
double tangent[3];
stat = project_to_bezier_edge(best_edge,this_point,
closest_point,tangent,&t_value);
if(curvSense == CUBIT_REVERSED){
tangent[0]= -tangent[0];
tangent[1]= -tangent[1];
tangent[2]= -tangent[2];
if ( tangent_ptr ) {
tangent_ptr->x(tangent[0]);
tangent_ptr->y(tangent[1]);
tangent_ptr->z(tangent[2]);
if ( curvature_ptr ) {
// The idea here is to get the planes normal to two points on the curve
// on either side of the closest_point, and also to get the plane through
// these three points. The point of intersection of these three planes
// should be a good approximation of the center of curvature, from which
// the curvature vector is readily found.
// tan1 and tan2 are the normals to the two planes for the endpoints;
// norm3 is the normal for the plane through the three points.
CubitVector tan1, tan2, point_1, point_2;
CubitVector *tan1_ptr = &tan1;
CubitVector *tan2_ptr = &tan2;
// CubitVector *point_1_ptr = &point_1;
CubitVector *point_2_ptr = &point_2;
t_value -= 0.01;
best_edge->evaluate_single_tangent(t_value,tan1_ptr);
t_value += 0.02;
best_edge->evaluate_single(t_value,tan2_ptr);
best_edge->evaluate_single_tangent(t_value,point_2_ptr);
tan1.normalize();
tan2.normalize();
// Get the plane through the point and normal to the tangent for the two
// points at the end.
// Get the plane for the three points.
CubitVector arm1 = point_1 - closest_point;
CubitVector arm2 = point_2 - closest_point;
CubitVector norm3 = arm1*arm2;
norm3.normalize();
double denominator;
denominator = tan1 % ( tan2 * norm3 );
if ( fabs(denominator) < GEOMETRY_RESABS ) { // planes are parallel;
// curvature is infinite
curvature_ptr->x(CUBIT_DBL_MAX);
curvature_ptr->y(CUBIT_DBL_MAX);
curvature_ptr->z(CUBIT_DBL_MAX);
} else {
CubitVector IntersectionPoint;
IntersectionPoint = ( (point_1%tan1)*(norm3*tan2) +
(closest_point%norm3)*(tan2*tan1) +
(point_2%tan2)*(tan1*norm3) )/denominator;
curvature_ptr->x(closest_point.x() - IntersectionPoint.x());
curvature_ptr->y(closest_point.y() - IntersectionPoint.y());
curvature_ptr->z(closest_point.z() - IntersectionPoint.z());
} else {
PRINT_ERROR("Error: Only curves or order 0 or 4 are supported.\n");
if (param)
*param = u_on_facet_edge( best_edge, closest_point );
if (mydebug)
draw_location(closest_point, CUBIT_GREEN_INDEX);
return stat;
| void CurveFacetEvalTool::debug_draw_facet_edges | ( | int | color = -1 | ) |
Definition at line 2115 of file CurveFacetEvalTool.cpp.
draw_edges(color);
| void CurveFacetEvalTool::destroy_facets | ( | ) | [private] |
Definition at line 1783 of file CurveFacetEvalTool.cpp.
| void CurveFacetEvalTool::draw_edge | ( | CubitFacetEdge * | edge, |
| int | color | ||
| ) | [private] |
Definition at line 1822 of file CurveFacetEvalTool.cpp.
CubitPoint *begin_point = edge->point(0);
CubitPoint *end_point = edge->point(1);
GfxDebug::draw_line(begin_point->x(),
begin_point->y(),
begin_point->z(),
end_point->x(),
end_point->y(),
end_point->z(),
color);
GfxDebug::flush();
| void CurveFacetEvalTool::draw_edges | ( | int | color = -1 | ) | [private] |
Definition at line 1795 of file CurveFacetEvalTool.cpp.
int ii;
if ( color == -1 )
color = CUBIT_BLUE_INDEX;
for ( ii = myEdgeList.size(); ii > 0; ii-- )
CubitFacetEdge *edge = myEdgeList.get_and_step();
begin_point->y(),
begin_point->z(),
end_point->x(),
end_point->y(),
end_point->z(),
color);
GfxDebug::flush();
| void CurveFacetEvalTool::draw_line | ( | CubitVector & | begin, |
| CubitVector & | end, | ||
| int | color = -1 |
| ) | [private] |
Definition at line 1843 of file CurveFacetEvalTool.cpp.
GfxDebug::draw_line(begin.x(), begin.y(), begin.z(),
end.x(), end.y(), end.z(), color);
GfxDebug::flush();
| void CurveFacetEvalTool::draw_location | ( | CubitVector & | loc, |
| int | color = -1 |
| ) | [private] |
Definition at line 1855 of file CurveFacetEvalTool.cpp.
if ( color == -1 )
color = CUBIT_YELLOW_INDEX;
GfxDebug::draw_point(loc, color);
GfxDebug::flush();
| CubitStatus CurveFacetEvalTool::evaluate_bezier_edge | ( | CubitFacetEdge * | edge, |
| int | index0, | ||
| int | index1, | ||
| double | fraction, | ||
| CubitVector & | location_on_curve, | ||
| double * | tangent | ||
| ) | [private] |
Definition at line 708 of file CurveFacetEvalTool.cpp.
CubitStatus status;
int numEdge, numVert, numLocs;
int edgeVert[2];
//int order;
double vert[6], edgeCtrlPts[9], location[3];
CubitVector *edge_ctrl_pts;
double scaled_parameter;
numEdge = 1;
numVert = 2;
numLocs = 1;
edgeVert[0] = 0; edgeVert[1] = 1;
vert[0] = edge->point(index0)->x();
vert[1] = edge->point(index0)->y();
vert[2] = edge->point(index0)->z();
vert[3] = edge->point(index1)->x();
vert[4] = edge->point(index1)->y();
vert[5] = edge->point(index1)->z();
edge_ctrl_pts = edge->control_points();
edgeCtrlPts[0] = edge_ctrl_pts[0].x();
edgeCtrlPts[1] = edge_ctrl_pts[0].y();
edgeCtrlPts[2] = edge_ctrl_pts[0].z();
edgeCtrlPts[3] = edge_ctrl_pts[1].x();
edgeCtrlPts[4] = edge_ctrl_pts[1].y();
edgeCtrlPts[5] = edge_ctrl_pts[1].z();
edgeCtrlPts[6] = edge_ctrl_pts[2].x();
edgeCtrlPts[7] = edge_ctrl_pts[2].y();
edgeCtrlPts[8] = edge_ctrl_pts[2].z();
//evalBezierEdge takes a parameter in the range of -1 to 1.
// evalBezierEdge calls functions which convert back to
// a range of 0 to 1,
// but we must convert to -1 to 1, before sending it.
scaled_parameter = (2.0 * fraction) - 1.0;
// static function in Cholla.cpp
evalBezierEdge(numEdge,numVert,edgeVert,vert,edgeCtrlPts,numLocs,
&scaled_parameter, location,tangent);
location_on_curve.x(location[0]);
location_on_curve.y(location[1]);
location_on_curve.z(location[2]);
status = CUBIT_SUCCESS;
return status;
| CubitSense CurveFacetEvalTool::find_curv_sense | ( | CubitPoint * | start_ptr | ) | [private] |
Definition at line 521 of file CurveFacetEvalTool.cpp.
myEdgeList.reset();
CubitFacetEdge *edge_ptr = myEdgeList.get();
CubitPoint *pt0 = edge_ptr->point(0);
CubitPoint *pt1 = edge_ptr->point(1);
CubitSense sense;
if (start_pt == pt0)
sense = CUBIT_FORWARD;
else if (start_pt == pt1)
sense = CUBIT_REVERSED;
else
sense = CUBIT_UNKNOWN;
return sense;
| CubitSense CurveFacetEvalTool::find_curv_sense | ( | CubitVector & | start | ) | [private] |
Definition at line 553 of file CurveFacetEvalTool.cpp.
myEdgeList.reset();
CubitFacetEdge* temp_edge = myEdgeList.get();
CubitVector temp_vector = temp_edge->point(1)->coordinates() -
temp_edge->point(0)->coordinates();
double tol = temp_vector.length() / 100.0;
//if point(0) of first edge in list == start, it is CUBIT_FORWARD
if(start.within_tolerance(temp_edge->point(0)->coordinates(), tol ) )
return CUBIT_FORWARD;
//if point(1) of first edge in list == start, it is CUBIT_REVERSED
else if(start.within_tolerance(temp_edge->point(1)->coordinates(), tol ) )
return CUBIT_REVERSED;
else
return CUBIT_UNKNOWN;
| CubitStatus CurveFacetEvalTool::fix_point_edge_order | ( | ) | [private] |
Definition at line 2051 of file CurveFacetEvalTool.cpp.
CubitFacetEdge* this_edge;
CubitFacetEdge* next_edge;
CubitPoint *this_pt1;
CubitPoint *next_pt0, *next_pt1;
if( myEdgeList.size() == 0 )
this_edge = myEdgeList.get_and_step();
int ii;
for( ii = myEdgeList.size() - 1; ii > 0; ii-- )
if( 0 != this_edge->num_adj_facets() )
continue;
next_edge = myEdgeList.get_and_step();
this_pt1 = this_edge->point( 1 );
next_pt0 = next_edge->point( 0 );
next_pt1 = next_edge->point( 1 );
if( this_pt1 != next_pt0 &&
this_pt1 != next_pt1 )
//Swap direction of edge. (mod. 3-7-06) Now calling flip instead
// of doing the flip manually. The flip function also tracks
// the orientation so that we can remember the original orientation
// of the edge.
this_edge->flip();
this_edge = next_edge;
//Handle last edge
next_edge = myEdgeList.prev(2);
if( 0 == this_edge->num_adj_facets() )
CubitPoint* this_pt0 = this_edge->point( 0 );
if( this_pt0 != next_pt0 &&
this_pt0 != next_pt1 )
//Swap direction of edge.(mod. 3-7-06) Now calling flip instead
// of the edge.
this_edge->flip();
return CUBIT_SUCCESS;
| void CurveFacetEvalTool::get_facets | ( | DLIList< CubitFacetEdge * > & | facet_list | ) | [inline] |
Definition at line 190 of file CurveFacetEvalTool.hpp.
{ facet_list += myEdgeList; }
| int CurveFacetEvalTool::get_output_id | ( | ) | [inline] |
Definition at line 152 of file CurveFacetEvalTool.hpp.
{ return output_id; }
| void CurveFacetEvalTool::get_points | ( | DLIList< CubitPoint * > & | point_list | ) | [inline] |
Definition at line 193 of file CurveFacetEvalTool.hpp.
{ point_list += myPointList; }
| CubitStatus CurveFacetEvalTool::get_segments_from_loops | ( | DLIList< DLIList< CubitFacetEdge * > * > * | facet_loop_list, |
| CubitVector & | start, | ||
| DLIList< CubitFacetEdge * > & | edge_list, | ||
| DLIList< CubitPoint * > & | point_list, | ||
| CubitSense | owrts | ||
| ) | [private] |
Definition at line 181 of file CurveFacetEvalTool.cpp.
int ii, jj;
int mydebug = 0;
CubitBoolean done = CUBIT_FALSE;
DLIList<CubitFacetEdge*> *facet_loop;
CubitFacetEdge *edge, *startedge = NULL;
CubitPoint *pt0, *pt1;
CubitVector loc_pt0, loc_pt1;
double edge_length;
facetLength = 0.0e0;
int tool_id = surfFacetEvalTool->tool_id();
//loop over the "loops"
for (ii=0; ii<facet_loop_list->size() && !done && stat == CUBIT_SUCCESS; ii++) {
//get the next facet loop
facet_loop = facet_loop_list->get_and_step();
// now loop over the edges in that loop
for (jj=0; jj<facet_loop->size() && !done; jj++) {
//get the start edge... we will
//traverse the list forwards, if the surface is oriented forward
//otherwise, traverse it backwards
startedge =
(orientation_wrt_surf == CUBIT_FORWARD) ? facet_loop->get_and_step() :
facet_loop->get_and_back();
if (startedge->get_flag() == 0) {
if (orientation_wrt_surf == CUBIT_FORWARD) {
startedge->boundary_edge_points( pt0, pt1, tool_id );
else {
startedge->boundary_edge_points( pt1, pt0, tool_id );
loc_pt0 = pt0->coordinates();
loc_pt1 = pt1->coordinates();
if (loc_pt0.within_tolerance( start, GEOMETRY_RESABS )) {
startedge->set_flag( 1 );
edge = startedge;
if (mydebug) draw_edge( edge, CUBIT_GREEN_INDEX );
while (!done) {
edge_list.append( edge );
point_list.append( pt0 );
edge_length = loc_pt0.distance_between( loc_pt1 );
facetLength += edge_length;
//if the other end of the edge is at the begginning of the
//loop, then we're done.
if (loc_pt1.within_tolerance( end, GEOMETRY_RESABS )) {
done = CUBIT_TRUE;
point_list.append( pt1 );
else {//otherwise...
edge = facet_loop->get_and_step();
else {
edge = facet_loop->get_and_back();
if (mydebug) draw_edge( edge, CUBIT_BLUE_INDEX );
//if we got back to the startedge without the
// other end of an edge getting to the start vertex,
// we have a problem....
if (edge == startedge)
stat = CUBIT_FAILURE; // this shouldn't happen
done = CUBIT_TRUE;
}//end edge == startedge
}//end else not within tolerance
}//end while not done
}//end if within tolerance
}//end if not marked
}//end loop over edges in facet loop
}//end loop over facet loops
if(done!=CUBIT_TRUE)
PRINT_ERROR("Can't define curve representation in mesh-based geometry\n");
return stat;
| CubitPoint * | start_pt, | ||
| CubitPoint * | end_pt, | ||
| ) | [private] |
Definition at line 285 of file CurveFacetEvalTool.cpp.
int ii, jj;
int mydebug = DEBUG_FLAG(181);
double edge_length;
DLIList<CubitFacetEdge*> temp_edge_list;
DLIList<CubitPoint*> temp_point_list;
if (mydebug)
GfxDebug::draw_point( start_pt->x(),
start_pt->y(),
start_pt->z(),
CUBIT_RED_INDEX );
GfxDebug::draw_point( end_pt->x(),
end_pt->y(),
end_pt->z(),
GfxDebug::flush();
//loop over the list of facet loops
//now loop over the edges in that facet loop
startedge =
//if startedge isn't marked
//get the points from the start edge in the appropriate order
else {
//convert to CubitVector
//if the first point on the edge is the start_pt... otherwise step
if (pt0 == start_pt) {
//mark the startedge
CubitFacetEdge* marked_edge = NULL;
edge = startedge;
if (mydebug) draw_edge( edge, CUBIT_GREEN_INDEX );//draw the start edge
//loop until we have reached an end or no more choices
while (!done) {
//if the first point is at the start, we are either
// just starting, or we have looped back onto the
// start point. The latter _may_ be ok. In case
// the latter is the case, clean out the temporary
// lists and (re)initialize the length. Also, unmark
// the edge that we marked the last time we started,
// if we previously marked an edge.
if (pt0 == start_pt){
temp_point_list.clean_out();
temp_edge_list.clean_out();
facetLength = 0.0;
if(marked_edge)
marked_edge->set_flag(0);
marked_edge=edge;
edge->set_flag(1);
//add the current edge to the edge list
temp_edge_list.append( edge );
//add the current start point to the point list
temp_point_list.append( pt0 );
//measure the edge... essentially
//keep a running tally of the curve length
//if the second point is at the end, we're done
if (pt1 == end_pt ) {
done = CUBIT_TRUE;
temp_point_list.append( pt1 );
//otherwise, we need to step forward
else {
else {
//convert point to CubitVector, as above
done = CUBIT_TRUE;
}//end else (ie, if not pt1==end_pt)
}//end while !done
}//end if pt0 == start_pt
}//end if start edge isn't marked
}//end loop over edges in the loop
//now put the temporary list entries onto the end of the list we return.
point_list += temp_point_list;
edge_list += temp_edge_list;
if(done!=CUBIT_TRUE || stat == CUBIT_FAILURE)
PRINT_WARNING("Can't define curve representation in mesh-based geometry\n");
PRINT_INFO(" Hint: Try importing as a free mesh and examining nodes and attached\n");
PRINT_INFO(" elements near the following locations:\n");
PRINT_INFO(" Start curve = %f %f %f\n", start_pt->x(), start_pt->y(), start_pt->z());
PRINT_INFO(" End curve = %f %f %f\n", end_pt->x(), end_pt->y(), end_pt->z());
if (mydebug)
surfFacetEvalTool->debug_draw_facets( CUBIT_YELLOW_INDEX );
int i, j;
for (i=0; i<facet_loop_list->size(); i++)
DLIList<CubitFacetEdge*> *my_facet_loop = facet_loop_list->get_and_step();
for (j=0; j<my_facet_loop->size(); j++)
draw_edge( my_facet_loop->get_and_step(), CUBIT_RED_INDEX );
GfxDebug::mouse_xforms();
return stat;
| CubitStatus CurveFacetEvalTool::get_segments_from_positions | ( | std::vector< CubitVector > & | positions, |
| CubitVector & | start_pt, | ||
| DLIList< CubitPoint * > & | point_list | ||
| ) | [private] |
Definition at line 443 of file CurveFacetEvalTool.cpp.
DLIList<CubitPoint*> surface_pts;
surfFacetEvalTool->get_points( surface_pts );
facetLength = 0;
double smallest_dist = CUBIT_DBL_MAX;
CubitPoint *start_pt = NULL;
//find the closest point to 'start'
for( int k=surface_pts.size(); k--; )
double tmp_dist = surface_pts.get()->coordinates().distance_between_squared( start );
if( tmp_dist < smallest_dist )
smallest_dist = tmp_dist;
start_pt = surface_pts.get();
surface_pts.get_and_step();
myPointList.append( start_pt );
CubitPoint *current_pt = start_pt;
CubitPoint *next_pt = NULL;
for (size_t k = 1; k < positions.size(); k++ )
CubitVector current_pos = positions[k];
//find the CubitPoint attached to this point via an edge
CubitFacetEdge *next_edge;
DLIList<CubitFacetEdge*> adj_edges;
current_pt->edges( adj_edges );
for( int m=adj_edges.size(); m--; )
CubitFacetEdge *tmp_edge = adj_edges.get_and_step();
CubitPoint *other_pt = tmp_edge->other_point( current_pt );
double tmp_dist = current_pos.distance_between_squared( other_pt->coordinates() );
next_pt = other_pt;
next_edge = tmp_edge;
current_pt = next_pt;
facetLength += next_edge->length();
myEdgeList.append( next_edge );
myPointList.append( current_pt );
if ((size_t)myPointList.size() != positions.size() ||
(size_t)myEdgeList.size() != positions.size() - 1 )
| FacetEvalTool* CurveFacetEvalTool::get_surf_eval_tool | ( | ) | [inline] |
Definition at line 197 of file CurveFacetEvalTool.hpp.
{ return surfFacetEvalTool; }
| CubitBoolean CurveFacetEvalTool::has_good_curve_data | ( | ) | [inline] |
Definition at line 205 of file CurveFacetEvalTool.hpp.
{return goodCurveData;}
| CubitStatus CurveFacetEvalTool::initialize | ( | DLIList< CubitFacetEdge * > & | edge_list, |
| FacetEvalTool * | surf_eval = NULL |
Definition at line 124 of file CurveFacetEvalTool.cpp.
// static int counter = 0;
output_id = -1;
myBBox = NULL;
curvSense = CUBIT_FORWARD;
surfFacetEvalTool = surf_eval;
myEdgeList = edge_list;
myPointList = point_list;
set_length();
CubitStatus status = fix_point_edge_order();
if( CUBIT_SUCCESS != status )
return status;
interpOrder = 0;
if(surf_eval)
interpOrder = surf_eval->interp_order();
bounding_box();
| CubitStatus CurveFacetEvalTool::initialize | ( | FacetEvalTool * | surf_eval_tool, |
| CubitPoint * | start_point, | ||
| CubitPoint * | end_point, | ||
| CubitSense | orientation | ||
Definition at line 91 of file CurveFacetEvalTool.cpp.
output_id = -1;
myBBox = NULL;
surfFacetEvalTool = surf_eval_tool;
CubitStatus stat = get_segments_from_loops( surfFacetEvalTool->loops(),
start_pt, end_pt,
myEdgeList, myPointList,
orientation_wrt_surf );
goodCurveData = (stat == CUBIT_SUCCESS) ? CUBIT_TRUE : CUBIT_FALSE;
if( !goodCurveData )
PRINT_ERROR( "Unable to initialize Curve Evaluation Tool for Faceted Geometry.\n" );
interpOrder = surfFacetEvalTool->interp_order();
curvSense = find_curv_sense( start_pt );
bounding_box();
Definition at line 32 of file CurveFacetEvalTool.cpp.
output_id = -1;
myBBox = NULL;
CubitStatus stat = get_segments_from_loops( surfFacetEvalTool->loops(), start, end,
myEdgeList, myPointList, orientation_wrt_surface );
curvSense = find_curv_sense( start );
bounding_box();
| std::vector< CubitVector > & | positions | ||
Definition at line 58 of file CurveFacetEvalTool.cpp.
output_id = -1;
myBBox = NULL;
CubitStatus stat = get_segments_from_positions( positions, start,
myEdgeList, myPointList );
bounding_box();
| double CurveFacetEvalTool::length | ( | ) | [inline] |
Definition at line 184 of file CurveFacetEvalTool.hpp.
{ return facetLength; };
| double CurveFacetEvalTool::length_from_u | ( | double | root_param, |
| double | end_param | ||
Definition at line 788 of file CurveFacetEvalTool.cpp.
double length = (end_param - root_param) * facetLength;
return length;
| CubitStatus CurveFacetEvalTool::position_from_fraction | ( | double | fraction, |
| CubitVector & | location_on_curve | ||
Definition at line 621 of file CurveFacetEvalTool.cpp.
CubitStatus status = CUBIT_SUCCESS;
double length, curlength, targetlength, lastlength;
CubitFacetEdge *edge = NULL;
CubitPoint *pt0=NULL, *pt1=NULL;
CubitVector eval_location;
myEdgeList.reset();
myPointList.reset();
pt0 = myPointList.get();
if (fraction <= 0.0) {
location_on_curve = pt0->coordinates();
return status;
curlength = lastlength = 0.0e0;
targetlength = fraction * facetLength;
assert(myEdgeList.size() > 0);
int ii = 0;
for ( ; ii<myEdgeList.size() && !done; ii++) {
loc_pt0 = edge->point( 0 )->coordinates();
loc_pt1 = edge->point( 1 )->coordinates();
curlength += length;
if ( edge->point(0) == pt0 ){
pt1 = edge->point(1);
else{
pt1 = edge->point(0);
if (targetlength <= curlength) {
done = CUBIT_TRUE;
double local_fraction = (targetlength - lastlength) / length;
eval_location = loc_pt0 + local_fraction * (loc_pt1 - loc_pt0);
if (interpOrder == 0 || !surfFacetEvalTool) {
location_on_curve = eval_location;
else {
// evaluate Bezier edge
int index0 = 0;
int index1 = 1;
if ( pt1 == edge->point(0) ) {
//switching the indices causes evaluate_bezier_edge to compute the
//wrong location, so I'm removing the switch (mbrewer)
//index0 = 1;
//index1 = 0;
local_fraction = 1. - local_fraction;
status = evaluate_bezier_edge(edge,index0,index1,local_fraction,
location_on_curve,0);
else {
lastlength = curlength;
pt0 = edge->point(1);
else
pt0 = edge->point(0);
if (!done) {
if(pt1 == NULL){
PRINT_ERROR("Opposite point not found while evaluating a curve.\n");
location_on_curve.set(0.0,0.0,0.0);
location_on_curve = pt1->coordinates();
return status;
| CubitStatus CurveFacetEvalTool::project_to_bezier_edge | ( | CubitFacetEdge * | edge, |
| CubitVector & | point, | ||
| CubitVector & | projected_point, | ||
| double * | tangent, | ||
| double * | tval | ||
| ) | [private] |
Definition at line 1025 of file CurveFacetEvalTool.cpp.
CubitStatus stat;
int numEdge, numVert, edgeVert[2], numLocs;
double vert[6], edgeCtrlPts[9], xyz[3], xyzOnEdge[3];
numEdge = 1;
numVert = 2;
numLocs = 1;
vert[0] = edge->point(0)->x();
vert[1] = edge->point(0)->y();
vert[2] = edge->point(0)->z();
vert[3] = edge->point(1)->x();
vert[4] = edge->point(1)->y();
vert[5] = edge->point(1)->z();
xyz[0] = point.x();
xyz[1] = point.y();
xyz[2] = point.z();
projToBezierEdge( numEdge,numVert,edgeVert,vert,edgeCtrlPts,
numLocs,xyz,xyzOnEdge,tangent,tval );
projected_point.x(xyzOnEdge[0]);
projected_point.y(xyzOnEdge[1]);
projected_point.z(xyzOnEdge[2]);
return stat;
| void CurveFacetEvalTool::remove_facets | ( | DLIList< CubitFacetEdge * > & | facet_edges | ) |
Definition at line 2168 of file CurveFacetEvalTool.cpp.
facet_edges = myEdgeList;
myEdgeList.clean_out();
myPointList.clean_out();
| CubitBoolean CurveFacetEvalTool::replace_facets | ( | DLIList< CubitFacetEdge * > & | curv_edges | ) |
Definition at line 2144 of file CurveFacetEvalTool.cpp.
// replace edges
this->myEdgeList = curv_edges;
// replace points
DLIList<CubitPoint *> point_list;
int i;
// insert start point of every facet_edge
curv_edges.reset();
for( i = 0; i < curv_edges.size(); i++ )
point_list.append( CAST_TO( curv_edges.get_and_step(), CubitFacetEdge )->point(0) );
// insert end point of last facet_edge
curv_edges.step( curv_edges.size() - 1 );
point_list.append( CAST_TO( curv_edges.get(), CubitFacetEdge )->point(1) );
this->myPointList = point_list;
return CUBIT_TRUE;
| CubitBoolean CurveFacetEvalTool::replace_point | ( | CubitPoint * | del_pnt, |
| CubitPoint * | keep_pnt | ||
Definition at line 2120 of file CurveFacetEvalTool.cpp.
int npoints = myPointList.size();
CubitBoolean istat = CUBIT_FALSE;
int i;
for ( i = 0; i < npoints; i++ )
point_ptr = myPointList.get();
if( point_ptr == del_pnt )
myPointList.remove();
myPointList.insert( keep_pnt );
istat = CUBIT_TRUE;
myPointList.step();
return istat;
| CubitStatus CurveFacetEvalTool::restore | ( | FILE * | fp, |
| unsigned int | endian, | ||
| int | num_edges, | ||
| int | num_points, | ||
| CubitFacetEdge ** | edges, | ||
| CubitPoint ** | points, | ||
| int | num_fets, | ||
| FacetEvalTool ** | fet_list | ||
Definition at line 1968 of file CurveFacetEvalTool.cpp.
NCubitFile::CIOWrapper cio(endian, fp);
typedef NCubitFile::UnsignedInt32 int32;
// read stuff about this eval tool
int ii;
int int_data[4];
cio.Read(reinterpret_cast<int32*>(int_data), 4);
interpOrder = int_data[0];
int surf_tool_id = int_data[1];
if (int_data[2] == -1 )
curvSense = CUBIT_UNKNOWN;
else
curvSense= int_data[2] ? CUBIT_REVERSED : CUBIT_FORWARD;
goodCurveData = (int_data[3]==0) ? CUBIT_FALSE : CUBIT_TRUE;
if( surf_tool_id != -1 )
surfFacetEvalTool = fet_array[ surf_tool_id ];
else
surfFacetEvalTool = NULL;
cio.Read(&facetLength, 1);
// read the edges
int nedges;
cio.Read(reinterpret_cast<int32*>(&nedges), 1);
if (nedges > 0)
int32* edge_id = new int32 [nedges];
cio.Read(edge_id, nedges);
int id;
for (ii=0; ii<nedges; ii++)
id = edge_id[ii];
if (id <0 || id >= num_edges)
delete [] edge_id;
myEdgeList.append(edges[id]);
delete [] edge_id;
// read the points
int npoints;
cio.Read(reinterpret_cast<int32*>(&npoints), 1);
int id;
if (npoints > 0)
int32* point_id = new int32 [npoints];
cio.Read(point_id, npoints);
for (ii=0; ii<npoints; ii++)
id = point_id[ii];
if (id <0 || id >= num_points)
delete [] point_id;
myPointList.append(points[id]);
delete [] point_id;
bounding_box();
| CubitStatus CurveFacetEvalTool::save | ( | FILE * | fp | ) |
Definition at line 1893 of file CurveFacetEvalTool.cpp.
NCubitFile::CIOWrapper cio(fp);
// write out "interpOrder"
cio.Write(reinterpret_cast<int32*>(&interpOrder), 1);
// write the associated facet eval tool id. If there is none then write -1
int surf_tool_id = -1;
if (surfFacetEvalTool != NULL)
surf_tool_id = surfFacetEvalTool->get_output_id();
cio.Write(reinterpret_cast<int32*>(&surf_tool_id), 1);
// convert "curvSense" in an int
int sense;
if( curvSense == CUBIT_UNKNOWN )
sense = -1;
else
sense = (curvSense == CUBIT_REVERSED) ? 1 : 0;
// write "curveSense" and "goodCurveData"
cio.Write(reinterpret_cast<int32*>(&sense), 1);
int32 is_good = goodCurveData ? 1 : 0;
cio.Write(&is_good, 1);
// write "facetLength"
cio.Write( &facetLength, 1 );
// write ids of facet edges in "myEdgeList"
int ii;
CubitFacetEdge *edge_ptr;
int nedges = myEdgeList.size();
myEdgeList.reset();
edge_ptr = myEdgeList.get_and_step();
edge_id[ii] = edge_ptr->id();
cio.Write(reinterpret_cast<int32*>(&nedges), 1);
if (nedges > 0)
cio.Write(edge_id, nedges);
delete [] edge_id;
// write ids of points in "myPointList"
point_id[ii] = point_ptr->id();
cio.Write(reinterpret_cast<int32*>(&npoints), 1);
if (npoints > 0)
cio.Write(point_id, npoints);
delete [] point_id;
| CubitSense CurveFacetEvalTool::sense | ( | ) | [inline] |
Definition at line 187 of file CurveFacetEvalTool.hpp.
{ return curvSense; };
| void CurveFacetEvalTool::set_facet_eval_tool | ( | FacetEvalTool * | surf_eval_tool_ptr | ) | [inline] |
Definition at line 198 of file CurveFacetEvalTool.hpp.
{ surfFacetEvalTool = surf_eval_tool_ptr;}
| void CurveFacetEvalTool::set_length | ( | ) |
Definition at line 1870 of file CurveFacetEvalTool.cpp.
int ii;
CubitFacetEdge *cf_edge;
for (ii=0; ii<myEdgeList.size(); ii++)
cf_edge = myEdgeList.get_and_step();
facetLength += cf_edge->length();
| void CurveFacetEvalTool::set_output_id | ( | int | id | ) | [inline] |
Definition at line 153 of file CurveFacetEvalTool.hpp.
| double CurveFacetEvalTool::u_from_arc_length | ( | double | root_param, |
| double | arc_length | ||
Definition at line 770 of file CurveFacetEvalTool.cpp.
if( facetLength == 0 )
return 0;
double u = root_param + arc_length / facetLength;
return u;
| double CurveFacetEvalTool::u_on_facet_edge | ( | CubitFacetEdge * | edge_at_pt, |
| CubitVector | pt | ||
| ) | [private] |
Definition at line 1741 of file CurveFacetEvalTool.cpp.
int ii;
double cum_len = 0.0;
myEdgeList.reset();
for (ii=0; ii<myEdgeList.size() && !done; ii++) {
if (edge != edge_at_pt)
cum_len += edge->length();
else
CubitVector pt0;
pt0 = edge->point( 1 )->coordinates();
else
cum_len += pt.distance_between( pt0 );
done = CUBIT_TRUE;
if (!done)
PRINT_DEBUG_122( "Error in CurveFacetEvalTool::u_on_facet_edge" );
double u = cum_len / facetLength;
return u;
CubitSense CurveFacetEvalTool::curvSense [private] |
Definition at line 38 of file CurveFacetEvalTool.hpp.
double CurveFacetEvalTool::facetLength [private] |
Definition at line 37 of file CurveFacetEvalTool.hpp.
Definition at line 39 of file CurveFacetEvalTool.hpp.
int CurveFacetEvalTool::interpOrder [private] |
Definition at line 30 of file CurveFacetEvalTool.hpp.
CubitBox* CurveFacetEvalTool::myBBox [private] |
Definition at line 35 of file CurveFacetEvalTool.hpp.
DLIList<CubitFacetEdge*> CurveFacetEvalTool::myEdgeList [private] |
Definition at line 33 of file CurveFacetEvalTool.hpp.
DLIList<CubitPoint*> CurveFacetEvalTool::myPointList [private] |
Definition at line 34 of file CurveFacetEvalTool.hpp.
int CurveFacetEvalTool::output_id [private] |
Definition at line 40 of file CurveFacetEvalTool.hpp.
Definition at line 36 of file CurveFacetEvalTool.hpp.
int CurveFacetEvalTool::toolID [private] |
Definition at line 29 of file CurveFacetEvalTool.hpp.
