cgma
00001 //- Class: CurveFacetEvalTool 00002 //- Description: The CurveFacetEvalTool is a general purpose tool that uses a set 00003 //- of facets to determine certain geometry computations. This 00004 //- class can be used to define a curve or do fast bounding box 00005 //- calculations, or determine point inside or outside. 00006 //- Assumptions: It is assumed/required that the facets be continuous through 00007 //- the set. In other words they must shared nodes and be conected 00008 //- through each other. The algorithms assume, for efficient searching, 00009 //- that from one facet, you can get to any other facet in the set. 00010 //- Owner: Steven J. Owen 00011 //- Checked by: 00012 00013 #ifndef CURVE_FACET_EVAL_TOOL_HPP 00014 #define CURVE_FACET_EVAL_TOOL_HPP 00015 00016 #include "DLIList.hpp" 00017 #include <map> 00018 00019 class CubitBox; 00020 class CubitPoint; 00021 class CubitVector; 00022 class FacetEvalTool; 00023 class CubitFacetEdge; 00024 class FacetCurve; 00025 00026 class CurveFacetEvalTool 00027 { 00028 private: 00029 int toolID; 00030 int interpOrder; 00031 //- interpolation order 0=linear, 1=gradient, 2=quadratic, 00032 // 3=least_squares, 4=spline 00033 DLIList<CubitFacetEdge*> myEdgeList; 00034 DLIList<CubitPoint*> myPointList; 00035 CubitBox *myBBox; 00036 FacetEvalTool *surfFacetEvalTool; 00037 double facetLength; 00038 CubitSense curvSense; 00039 CubitBoolean goodCurveData; 00040 int output_id; 00041 00042 void draw_edges(int color = -1); 00043 void draw_edge(CubitFacetEdge *edge, int color); 00044 void draw_line(CubitVector &begin, CubitVector &end, int color = -1); 00045 void draw_location(CubitVector &loc, int color = -1 ); 00046 00047 void destroy_facets(); 00048 //- Destroys the facets, and points. 00049 00050 CubitStatus get_segments_from_loops( 00051 DLIList<DLIList<CubitFacetEdge*>*> *facet_loop_list, 00052 CubitVector &start, CubitVector &end, 00053 DLIList<CubitFacetEdge*> &edge_list, 00054 DLIList<CubitPoint*> &point_list, 00055 CubitSense owrts ); 00056 CubitStatus get_segments_from_loops( 00057 DLIList<DLIList<CubitFacetEdge*>*> *facet_loop_list, 00058 CubitPoint *start_pt, CubitPoint *end_pt, 00059 DLIList<CubitFacetEdge*> &edge_list, 00060 DLIList<CubitPoint*> &point_list, 00061 CubitSense owrts ); 00062 // generate a list of edges and points from the loop list 00063 // for this curve 00064 00065 CubitStatus get_segments_from_positions( 00066 std::vector<CubitVector> &positions, 00067 CubitVector &start_pt, 00068 DLIList<CubitFacetEdge*> &edge_list, 00069 DLIList<CubitPoint*> &point_list ); 00070 // generate a list of edges and points from the loop list 00071 // for this curve 00072 00073 /* 00074 CubitStatus project_to_facet_edge(CubitVector &this_point, 00075 CubitVector &closest_point, 00076 CubitVector *tangent_ptr, 00077 CubitVector *curvature_ptr, 00078 double *param, 00079 int *outside ); 00080 00081 // project to the facet edge 00082 CubitStatus project_to_linear_facet_edge(CubitVector &this_point, 00083 CubitVector &closest_point, 00084 CubitVector *tangent_ptr, 00085 CubitVector *curvature_ptr, 00086 double *param, 00087 int *outside ); 00088 // same as above except assumes linear representation AND 00089 // surfFacetEvalTool does notexist 00090 */ 00091 // evaluates a fractional length onto a Bezier edge 00092 CubitStatus evaluate_bezier_edge(CubitFacetEdge *edge, 00093 int index0, 00094 int index1, 00095 double fraction, 00096 CubitVector &location_on_curve, 00097 double *tangent); 00098 00099 // projects a point onto a Bezier edge 00100 CubitStatus project_to_bezier_edge(CubitFacetEdge *edge, 00101 CubitVector &point, CubitVector &projected_point, 00102 double *tangent, double *tval); 00103 00104 double u_on_facet_edge( CubitFacetEdge *edge_at_pt, 00105 CubitVector pt ); 00106 // return the u param on the facet curve given a point on the 00107 // curve and the facet edge it is on 00108 00109 // CubitStatus project_to_edge_line( CubitFacetEdge *edge, 00110 // CubitVector &this_point, 00111 // CubitVector &pt_on_edge, 00112 // double &dist_to_edge ); 00113 // project to the line defined by the edge 00114 00115 CubitStatus fix_point_edge_order(); 00116 00117 CubitSense find_curv_sense( CubitPoint *start_ptr ); 00118 CubitSense find_curv_sense( CubitVector &start ); 00119 00120 public: 00121 00122 CurveFacetEvalTool(); 00123 ~CurveFacetEvalTool(); 00124 00125 // Called immediately after the constructor to initialize the data. 00126 CubitStatus initialize( DLIList<CubitFacetEdge*> &edge_list, 00127 DLIList<CubitPoint*> &point_list, 00128 FacetEvalTool* surf_eval = NULL); 00129 CubitStatus initialize( FacetEvalTool *surf_eval_tool, 00130 CubitPoint *start_point, 00131 CubitPoint *end_point, 00132 CubitSense orientation ); 00133 CubitStatus initialize( FacetEvalTool *surf_eval_tool, 00134 CubitVector &start, 00135 CubitVector &end, 00136 CubitSense orientation ); 00137 CubitStatus initialize( FacetEvalTool *surf_eval_tool, 00138 CubitVector &start, 00139 std::vector<CubitVector> &positions ); 00140 00141 CubitStatus save(FILE *fp); 00142 // save to a cubit file 00143 CubitStatus restore(FILE *fp, 00144 unsigned int endian, 00145 int num_edges, 00146 int num_points, 00147 CubitFacetEdge **edges, 00148 CubitPoint **points, 00149 int num_fets, 00150 FacetEvalTool **fet_list); 00151 00152 int get_output_id() { return output_id; } 00153 void set_output_id( int id ) { output_id = id; } 00154 00155 CubitBox bounding_box(); 00156 //- Returns the bounding box for the set of facetedges (based on the points 00157 //- used in the faceted set. 00158 00159 CubitStatus closest_point(CubitVector &this_point, 00160 CubitVector &closest_point_ptr, 00161 CubitVector *normal_ptr = NULL, 00162 CubitVector *curvature_ptr = NULL, 00163 double *param = NULL); 00164 //- Finds the closest point from the vector (this_point) to the 00165 //- set of facets that lies on the set of facets. If the point 00166 //- lies outside this set, the closest point will be on the plane 00167 //- of the closest facet. The closest_point is set to be that point. 00168 00169 // replace del_pnt with keep_pnt in point list 00170 CubitBoolean replace_point( CubitPoint *del_pnt, CubitPoint *keep_pnt ); 00171 00172 CubitBoolean replace_facets( DLIList< CubitFacetEdge *> &curv_edges ); 00173 00174 void remove_facets( DLIList<CubitFacetEdge*> &facet_edges); 00175 00176 CubitStatus position_from_fraction( double fraction, // between 0 and 1 00177 CubitVector &location_on_curve ); 00178 //- computes the location on the curve based on a fraction of the 00179 //- distance along the curve and the RefEdge sense 00180 00181 double u_from_arc_length( double root_param, double arc_length ); 00182 double length_from_u ( double root_param, double end_param ); 00183 00184 double length() { return facetLength; }; 00185 //- return the length of the facet edges 00186 00187 CubitSense sense() { return curvSense; }; 00188 //- return the sense of the curve 00189 00190 void get_facets(DLIList<CubitFacetEdge*>& facet_list) 00191 { facet_list += myEdgeList; } 00192 // append the edge facets for this curve onto facet_list 00193 void get_points(DLIList<CubitPoint*>& point_list) 00194 { point_list += myPointList; } 00195 // apend the points for this curve onto point_list 00196 00197 FacetEvalTool *get_surf_eval_tool() { return surfFacetEvalTool; } 00198 void set_facet_eval_tool(FacetEvalTool *surf_eval_tool_ptr) 00199 { surfFacetEvalTool = surf_eval_tool_ptr;} 00200 // get and set the associated surface facet eval tool 00201 00202 void set_length(); 00203 // initialize the curve length 00204 00205 CubitBoolean has_good_curve_data(){return goodCurveData;} 00206 00207 void debug_draw_facet_edges(int color = -1 ); 00208 00209 00210 }; 00211 00212 #endif // CURVE_FACET_EVAL_TOOL_HPP 00213 00214
