cgma
#include <LocalToleranceTool.hpp>
Public Member Functions | |
| LocalToleranceTool () | |
| ~LocalToleranceTool () | |
| bool | calculate_local_tolerances (DLIList< BodySM * > body_sm_list) |
| bool | print_local_tolerances (DLIList< BodySM * > body_sm_list) |
Static Public Member Functions | |
| static LocalToleranceTool * | instance (void) |
| static void | delete_instance () |
Private Member Functions | |
| bool | calculate_local_tolerances_automatically (DLIList< BodySM * > body_sm_list) |
Static Private Attributes | |
| static LocalToleranceTool * | instance_ = 0 |
Definition at line 21 of file LocalToleranceTool.hpp.
Definition at line 48 of file LocalToleranceTool.cpp.
Definition at line 59 of file LocalToleranceTool.cpp.
| bool LocalToleranceTool::calculate_local_tolerances | ( | DLIList< BodySM * > | body_sm_list | ) |
Definition at line 118 of file LocalToleranceTool.cpp.
bool rv = true;
const double default_vert_local_tol = 0.001;
const double default_edge_local_tol = 0.01;
const double default_face_local_tol = 0.02;
const double default_vol_local_tol = 0.03;
int i;
// get all bodies
DLIList<Body *> bodies;
RefEntityFactory::instance()->bodies( bodies );
// find all ref_vert in the bodies
DLIList<RefVertex *> ref_verts;
GeometryQueryTool::instance()->ref_vertices( ref_verts );
// for now set default value in all ref_vert
RefVertex *ref_vert;
for( i = 0; i < ref_verts.size(); i++ )
ref_vert = ref_verts.get_and_step();
ref_vert->local_tolerance( default_vert_local_tol );
// find all ref_edge in the bodies
DLIList<RefEdge *> ref_edges;
GeometryQueryTool::instance()->ref_edges( ref_edges );
// for now set default value in all ref_edges
RefEdge *ref_edge;
for( i = 0; i < ref_edges.size(); i++ )
ref_edge = ref_edges.get_and_step();
ref_edge->local_tolerance( default_edge_local_tol );
// find all ref_face in the bodies
DLIList<RefFace *> ref_faces;
GeometryQueryTool::instance()->ref_faces( ref_faces );
// for now set default value in all ref_faces
RefFace *ref_face;
for( i = 0; i < ref_faces.size(); i++ )
ref_face = ref_faces.get_and_step();
ref_face->local_tolerance( default_face_local_tol );
// find all ref_vol in the bodies
DLIList<RefVolume *> ref_vols;
GeometryQueryTool::instance()->ref_volumes( ref_vols );
// for now set default value in all ref_vols
RefVolume *ref_vol;
for( i = 0; i < ref_vols.size(); i++ )
ref_vol = ref_vols.get_and_step();
ref_vol->local_tolerance( default_vol_local_tol );
return rv;
| bool LocalToleranceTool::calculate_local_tolerances_automatically | ( | DLIList< BodySM * > | body_sm_list | ) | [private] |
Definition at line 191 of file LocalToleranceTool.cpp.
bool rv = true;
// find mergable surfaces
double geom_factor = GeometryQueryTool::get_geometry_factor();
double merge_tolerance = geom_factor*GEOMETRY_RESABS;
DLIList< DLIList<Surface*>*> lists_of_mergeable_surfaces;
MergeTool::instance()->find_only_mergeable_surfaces ( body_sm_list, lists_of_mergeable_surfaces, merge_tolerance );
/* Pseudocode for future use
// Map holding overlapping surface pairs
overlapping_surfs_map;
// Add all surfs to spatial tree
SpatialTree.add(all_surfs);
// Create array of all surfs sorted by surface area (smallest to largest)
all_surf_array.sort();
// Loop through progressively larger merge tolerances
for(cur_tol=.00001; cur_tol < .1; cur_tol *= 10.0)
// Each time array size may change because surfs have been removed.
int num_surfs = all_surf_array.size(), i;
for(i=0; i<num_surfs; i++)
cur_surf = all_surf_array[i];
// Get surfs that are close to the current surf.
close_surfs = SpatialTree.get_close_surfs(cur_surf);
// Keep a running total of overlap area so we know when current surf
// is overlapping completely with other surfs.
double overlap_area = 0.0;
int j;
// Loop over all of the close surfs and look for overlaps.
for(j=close_surfs.size(); j>0; j--)
cur_close_surf = close_surfs.get_and_step();
// If there is already a map entry between these two surfs don't check them again.
if(!overlapping_surfs_map.entry_exists(cur_surf, cur_close_surf))
// Measure overlap for these two surfs at current tolerance
cur_overlap = measure_overlap(cur_surf, cur_close_surf, cur_tol);
if(cur_overlap > 0.0)
// add entry for these two surfs (at the current tol)
overlapping_surfs_map.add_entry(cur_surf, cur_close_surf, cur_tol);
// Update the overlapping area for cur_surf
overlap_area += cur_overlap;
// If overlapping area for cur_surf is all of cur_surf then we are done processing it.
if(overlap_area == cur_surf.surface_area())
// Remove cur_surf from all_surf_array
// Remove cur_surf from SpatialTree (if this helps with efficiency)
// jump out of processing of cur_surf
j=0;
return rv;
| void LocalToleranceTool::delete_instance | ( | ) | [static] |
Definition at line 100 of file LocalToleranceTool.cpp.
| LocalToleranceTool * LocalToleranceTool::instance | ( | void | ) | [static] |
Definition at line 75 of file LocalToleranceTool.cpp.
// Check to see if we have created an instance of the class
// If not, proceed to create one.
//if (LocalToleranceTool::instance_ == 0)
// LocalToleranceTool::instance_ = new LocalToleranceTool() ;
// Return the a pointer to the instance of the class.
return NULL; //LocalToleranceTool::instance_ ;
| bool LocalToleranceTool::print_local_tolerances | ( | DLIList< BodySM * > | body_sm_list | ) |
Definition at line 264 of file LocalToleranceTool.cpp.
bool rv = true;
int i;
// get all bodies
PRINT_INFO( " vert id %d, local_tol %f \n", ref_vert->id(), ref_vert->local_tolerance() );
RefEdge *ref_edge;
PRINT_INFO( " edge id %d, local_tol %f \n", ref_edge->id(), ref_edge->local_tolerance() );
RefFace *ref_face;
PRINT_INFO( " face id %d, local_tol %f \n", ref_face->id(), ref_face->local_tolerance() );
RefVolume *ref_vol;
PRINT_INFO( " vol id %d, local_tol %f \n", ref_vol->id(), ref_vol->local_tolerance() );
return rv;
LocalToleranceTool * LocalToleranceTool::instance_ = 0 [static, private] |
Definition at line 25 of file LocalToleranceTool.hpp.
