Public Member Functions |
| virtual | ~GeometryHealerEngine () |
| virtual CubitBoolean | is_healer_engine (const TopologyBridge *)=0 |
| virtual CubitBoolean | is_healer_engine (const TopologyEntity *)=0 |
| virtual CubitStatus | auto_heal_bodies (DLIList< Body * > &body_list, DLIList< Body * > &new_body_list, DLIList< TopologyEntity * > &bad_geometry, CubitBoolean rebuild=CUBIT_FALSE, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL)=0 |
| virtual CubitStatus | heal_bodies (DLIList< Body * > &body_list, DLIList< Body * > &new_body_list, DLIList< TopologyEntity * > &bad_geometry, CubitBoolean rebuild=CUBIT_FALSE, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL)=0 |
| virtual CubitStatus | analyze_badgeom (DLIList< Body * > &body_list, DLIList< TopologyEntity * > &bad_geometry, FILE *logfile=NULL)=0 |
| virtual CubitStatus | get_badgeom (DLIList< Body * > &body_list, DLIList< TopologyEntity * > &bad_geometry)=0 |
| virtual CubitStatus | get_tcurves (DLIList< Body * > &body_list, DLIList< RefEdge * > &t_curves)=0 |
| virtual CubitStatus | heal_incremental (DLIList< Body * > &body_list, DLIList< Body * > &new_bodies, DLIList< TopologyEntity * > &bad_geometry, double simplify_tol=CUBIT_DBL_MAX, double stitch_min_tol=CUBIT_DBL_MAX, double stitch_max_tol=CUBIT_DBL_MAX, double geombuild_tol=CUBIT_DBL_MAX, double analytic_tol=CUBIT_DBL_MAX, double isospline_tol=CUBIT_DBL_MAX, double reblend_classify_tol=CUBIT_DBL_MAX, double reblend_tol=CUBIT_DBL_MAX, CubitBoolean keep_old=CUBIT_FALSE, CubitBoolean make_tolerant=CUBIT_FALSE, FILE *logfile_ptr=NULL)=0 |
| virtual void | list_incremental ()=0 |
| virtual void | list_tolerances (DLIList< Body * > &body_list)=0 |
| virtual double | get_default_simplify_tol ()=0 |
| virtual void | set_default_simplify_tol (double tol)=0 |
| virtual double | get_default_stitch_min_tol ()=0 |
| virtual void | set_default_stitch_min_tol (double tol)=0 |
| virtual double | get_default_stitch_max_tol ()=0 |
| virtual void | set_default_stitch_max_tol (double tol)=0 |
| virtual double | get_default_geombuild_tol ()=0 |
| virtual void | set_default_geombuild_tol (double tol)=0 |
| virtual double | get_default_analytic_tol ()=0 |
| virtual void | set_default_analytic_tol (double tol)=0 |
| virtual double | get_default_isospline_tol ()=0 |
| virtual void | set_default_isospline_tol (double tol)=0 |
| virtual double | get_default_reblend_classify_tol ()=0 |
| virtual void | set_default_reblend_classify_tol (double tol)=0 |
| virtual double | get_default_reblend_tol ()=0 |
| virtual void | set_default_reblend_tol (double tol)=0 |
| virtual void | reset_default_tolerances ()=0 |
| virtual void | list_default_tolerances ()=0 |
| virtual void | clean_attributes (DLIList< Body * > &body_list)=0 |
| virtual CubitBoolean | get_cleanatt_flg ()=0 |
| virtual void | set_cleanatt_flg (CubitBoolean flg)=0 |
| virtual int | get_show_method ()=0 |
| virtual void | set_show_method (int method)=0 |
| virtual CubitBoolean | get_show_summary_flg ()=0 |
| virtual void | set_show_summary_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_details_flg ()=0 |
| virtual void | set_show_details_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_on_heal_flg ()=0 |
| virtual void | set_show_on_heal_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_check_vol_on_heal_flg ()=0 |
| virtual void | set_check_vol_on_heal_flg (CubitBoolean flg)=0 |
| virtual double | get_vol_on_heal_limit ()=0 |
| virtual void | set_vol_on_heal_limit (double limit)=0 |
| virtual CubitBoolean | get_check_surf_on_heal_flg ()=0 |
| virtual void | set_check_surf_on_heal_flg (CubitBoolean flg)=0 |
| virtual double | get_surf_on_heal_limit ()=0 |
| virtual void | set_surf_on_heal_limit (double limit)=0 |
| virtual CubitBoolean | get_check_curve_on_heal_flg ()=0 |
| virtual void | set_check_curve_on_heal_flg (CubitBoolean flg)=0 |
| virtual double | get_curve_on_heal_limit ()=0 |
| virtual void | set_curve_on_heal_limit (double limit)=0 |
| virtual CubitBoolean | get_show_bad_vertices_flg ()=0 |
| virtual void | set_show_bad_vertices_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_curves_flg ()=0 |
| virtual void | set_show_bad_curves_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_coedges_flg ()=0 |
| virtual void | set_show_bad_coedges_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_loops_flg ()=0 |
| virtual void | set_show_bad_loops_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_surfaces_flg ()=0 |
| virtual void | set_show_bad_surfaces_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_shells_flg ()=0 |
| virtual void | set_show_bad_shells_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_volumes_flg ()=0 |
| virtual void | set_show_bad_volumes_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_show_bad_bodies_flg ()=0 |
| virtual void | set_show_bad_bodies_flg (CubitBoolean flg)=0 |
| virtual void | list_onshow_flgs ()=0 |
| virtual CubitBoolean | get_inc_preprocess_flg ()=0 |
| virtual void | set_inc_preprocess_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_simplify_flg ()=0 |
| virtual void | set_inc_simplify_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_stitch_flg ()=0 |
| virtual void | set_inc_stitch_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_geombuild_flg ()=0 |
| virtual void | set_inc_geombuild_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_analytic_flg ()=0 |
| virtual void | set_inc_analytic_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_isospline_flg ()=0 |
| virtual void | set_inc_isospline_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_reblend_flg ()=0 |
| virtual void | set_inc_reblend_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_sharpedge_flg ()=0 |
| virtual void | set_inc_sharpedge_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_genericspline_flg ()=0 |
| virtual void | set_inc_genericspline_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_wrapup_flg ()=0 |
| virtual void | set_inc_wrapup_flg (CubitBoolean flg)=0 |
| virtual CubitBoolean | get_inc_postprocess_flg ()=0 |
| virtual void | set_inc_postprocess_flg (CubitBoolean flg)=0 |
| virtual void | measure_filter (DLIList< RefEntity * > &ref_entities, double measure_value, double tolerance)=0 |
| virtual CubitStatus | force_simplify_to_plane (DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0 |
| virtual CubitStatus | force_simplify_to_cylinder (DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0 |
| virtual CubitStatus | force_simplify_to_cone (DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0 |
| virtual CubitStatus | force_simplify_to_sphere (DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0 |
| virtual CubitStatus | force_simplify_to_torus (DLIList< RefFace * > &ref_face_list, DLIList< Body * > &new_body_list, CubitBoolean keep=CUBIT_FALSE)=0 |
Definition at line 39 of file GeometryHealerEngine.hpp.
