cgma
#include <CGMReadParallel.hpp>
Public Types | |
| enum | ParallelLoadOption { BCAST, BCAST_AND_DELETE, SCATTER } |
| enum | CGMParallelOpts { POPT_NONE = 0, POPT_READ, POPT_READ_DELETE, POPT_BCAST, POPT_BCAST_DELETE, PORT_SCATTER, PORT_SCATTER_DELETE, POPT_READ_PARALLEL, POPT_FORMAT, POPT_DEFAULT } |
Public Member Functions | |
| CGMReadParallel (GeometryQueryTool *gqt=NULL, CGMParallelComm *pc=NULL) | |
| CubitStatus | load_file (const char *file_names, const char *options, const char *set_tag_name=0, const int *set_tag_values=0, int num_set_tag_values=0) |
| CubitStatus | load_file (const char *file_name, int parallel_mode, std::string &partition_tag_name, std::vector< int > &partition_tag_vals, std::vector< int > &pa_vec, const CGMFileOptions &opts, const char *set_tag_name, const int *set_tag_values, const int num_set_tag_values, const int reader_rank, const bool surf_partition) |
| void | set_reader (unsigned int reader) |
Static Public Attributes | |
| static const char * | CGMparallelOptsNames [] |
| static const char * | CGMpartitionOptsNames [] |
Private Member Functions | |
| CubitStatus | read_entities (const char *file_name) |
| CubitStatus | balance_round_robin () |
| CubitStatus | delete_nonlocal_entities (int reader, std::string &ptag_name, std::vector< int > &ptag_vals) |
| CubitStatus | check_partition_info () |
Private Attributes | |
| GeometryQueryTool * | m_gqt |
| CGMParallelComm * | m_pcomm |
| bool | m_scatter |
| bool | m_reader |
| unsigned int | m_rank |
| unsigned int | m_proc_size |
| BALANCE_METHOD | m_bal_method |
| DLIList< RefEntity * > | m_surf_entity_list |
Definition at line 16 of file CGMReadParallel.hpp.
| POPT_NONE | |
| POPT_READ | |
| POPT_READ_DELETE | |
| POPT_BCAST | |
| POPT_BCAST_DELETE | |
| PORT_SCATTER | |
| PORT_SCATTER_DELETE | |
| POPT_READ_PARALLEL | |
| POPT_FORMAT | |
| POPT_DEFAULT |
Definition at line 47 of file CGMReadParallel.hpp.
Definition at line 22 of file CGMReadParallel.hpp.
{BCAST, BCAST_AND_DELETE, SCATTER};
| CGMReadParallel::CGMReadParallel | ( | GeometryQueryTool * | gqt = NULL, |
| CGMParallelComm * | pc = NULL |
Definition at line 54 of file CGMReadParallel.cpp.
m_gqt(gqt), m_pcomm(pc) {
if (!m_pcomm) {
m_pcomm = new CGMParallelComm();
m_bal_method = ROUND_ROBIN;
m_scatter = false;
m_rank = m_pcomm->proc_config().proc_rank();
m_proc_size = m_pcomm->proc_config().proc_size();
| CubitStatus CGMReadParallel::balance_round_robin | ( | ) | [private] |
Definition at line 384 of file CGMReadParallel.cpp.
// get bodies
int i, j, k;
DLIList<RefEntity*>& body_entity_list = m_pcomm->partition_body_list();
int n_proc = m_proc_size;
double* loads = new double[n_proc]; // estimated loads for each processor
double* ve_loads = new double[n_proc]; // estimated loads for each processor
for (i = 0; i < n_proc; i++) {
loads[i] = 0.0;
ve_loads[i] = 0.0;
if (m_bal_method == ROUND_ROBIN) { // round-robin case
int n_entity = body_entity_list.size();
int n_entity_proc = n_entity / n_proc; // # of entities per processor
int i_entity_proc = n_entity_proc; // entity index limit for each processor
int proc = 0;
RefEntity* entity;
// assign processors to bodies
body_entity_list.reset();
for (i = 0; i < n_entity; i++) {
if (i == i_entity_proc) {
proc++;
if (proc < n_proc)
i_entity_proc += n_entity_proc;
else {
proc %= n_proc;
i_entity_proc++;
// assign to bodies
entity = body_entity_list.get_and_step();
DLIList<int> shared_procs;
shared_procs.append(proc);
TDParallel *td_par = (TDParallel *) entity->get_TD(
&TDParallel::is_parallel);
if (td_par == NULL)
td_par = new TDParallel(entity, NULL, &shared_procs);
loads[proc] += entity->measure();
// assign to volumes, it should be removed in future
DLIList<RefVolume*> volumes;
(dynamic_cast<TopologyEntity*>(entity))->ref_volumes(volumes);
int n_vol = volumes.size();
volumes.reset();
for (j = 0; j < n_vol; j++) {
RefEntity *vol = volumes.get_and_step();
td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel);
if (td_par == NULL)
td_par = new TDParallel(vol, NULL, &shared_procs);
// add local surface load
DLIList<RefFace*> faces;
(dynamic_cast<TopologyEntity*>(entity))->ref_faces(faces);
int n_face = faces.size();
faces.reset();
for (j = 0; j < n_face; j++) {
RefFace* face = faces.get_and_step();
TopologyEntity *te = CAST_TO(face, TopologyEntity);
if (te->bridge_manager()->number_of_bridges() < 2) {
loads[proc] = loads[proc] + face->measure();
// Get all child entities
DLIList<RefEntity*> child_list;
RefEntity::get_all_child_ref_entities(body_entity_list, child_list);
int n_child = child_list.size();
// assign processors to interface entities
child_list.reset();
for (i = 0; i < n_child; i++) {
entity = child_list.get_and_step();
TopologyEntity *te = CAST_TO(entity, TopologyEntity);
if (te->bridge_manager()->number_of_bridges() > 1) {
DLIList<Body*> parent_bodies;
(dynamic_cast<TopologyEntity*>(entity))->bodies(parent_bodies);
int n_parent = parent_bodies.size();
for (j = 0; j < n_parent; j++) {
RefEntity *parent_vol = CAST_TO(parent_bodies.get_and_step(),
RefEntity);
TDParallel *parent_td = (TDParallel *) parent_vol->get_TD(
if (parent_td == NULL) {
PRINT_ERROR("parent Volume has to be partitioned.");
return CUBIT_FAILURE;
shared_procs.append_unique(parent_td->get_charge_proc());
if (shared_procs.size() > 1) { // if it is interface
if (td_par == NULL) {
int merge_id = TDUniqueId::get_unique_id(entity);
if (entity->entity_type_info() == typeid(RefFace)) { // face
if (shared_procs.size() != 2) {
PRINT_ERROR(
"Error: # of shared processors of interface surface should be 2.");
// balance interface surface loads
if (loads[shared_procs[0]] > loads[shared_procs[1]]) {
shared_procs.reverse();
loads[shared_procs[0]] = loads[shared_procs[0]]
+ entity->measure();
td_par = new TDParallel(entity, NULL, &shared_procs, NULL,
merge_id, 1);
} else if (entity->entity_type_info() == typeid(RefEdge)
|| entity->entity_type_info() == typeid(RefVertex)) {
int min_p = shared_procs[0];
int n_shared_proc = shared_procs.size();
for (int i1 = 1; i1 < n_shared_proc; i1++) {
if (ve_loads[shared_procs[i1]] < ve_loads[min_p]) {
min_p = shared_procs[i1];
ve_loads[min_p] = ve_loads[min_p] + entity->measure();
shared_procs.remove(min_p);
shared_procs.insert_first(min_p);
// add ghost geometries to shared processors for edge
if (entity->entity_type_info() == typeid(RefEdge)) {
parent_bodies.reset();
RefEntity);
for (k = 0; k < n_shared_proc; k++) {
parent_td->add_ghost_proc(shared_procs[k]);
merge_id, 1);
} else if (m_bal_method == PARTITION_DYNAMIC) {
return CUBIT_SUCCESS;
| CubitStatus CGMReadParallel::check_partition_info | ( | ) | [private] |
Definition at line 619 of file CGMReadParallel.cpp.
int i;
int nEntity = body_entity_list.size();
for (i = 0; i < nEntity; i++) {
RefEntity* entity = body_entity_list.get_and_step();
if (td_par == NULL) { // if body is not partitioned
DLIList<RefEntity*> volumes;
entity->get_child_ref_entities(volumes);
// check if the first Volume is partitioned here, should be removed in future
volumes.reset();
RefEntity *vol = volumes.get();
if (vol == NULL || vol->entity_type_info() != typeid(RefVolume)) {
PRINT_ERROR("Partitioned Body should have at least one Volume.");
PRINT_ERROR("Partitioned Volume should have TDParallel data.");
DLIList<int> s_procs;
s_procs.append(td_par->get_charge_proc());
td_par = new TDParallel(entity, NULL, &s_procs);
| CubitStatus CGMReadParallel::delete_nonlocal_entities | ( | int | reader, |
| std::string & | ptag_name, | ||
| std::vector< int > & | ptag_vals | ||
| ) | [private] |
Definition at line 542 of file CGMReadParallel.cpp.
// find bodies deleted
int i;
DLIList<RefEntity*> partition_list, delete_body_list;
if (td_par->get_charge_proc() != m_rank) { // candidate to be deleted
// check child surfaces if surface partitioned
DLIList<RefFace*> face_list;
(dynamic_cast<TopologyEntity*>(entity))->ref_faces(face_list);
bool b_partitioned_surf = false;
int n_face = face_list.size();
face_list.reset();
for (int j = 0; j < n_face; j++) {
RefEntity* face = face_list.get_and_step();
TDParallel *td_par_face = (TDParallel *) face->get_TD(
if (td_par_face != NULL) { // if surface is partitioned
DLIList<int>* shared_procs = td_par_face->get_shared_proc_list();
int n_shared = shared_procs->size();
shared_procs->reset();
for (int k = 0; k < n_shared; k++) {
if (shared_procs->get_and_step() == (int) m_rank) {
b_partitioned_surf = true;
break;
if (b_partitioned_surf)
partition_list.append(entity);
else
delete_body_list.append(entity);
} else
// print info
char pre_body[100];
DLIList<CubitEntity*> tmp_body_list;
if (CGM_read_parallel_debug) {
if ((int) m_rank != reader) {
CAST_LIST_TO_PARENT(delete_body_list, tmp_body_list);
sprintf(pre_body, "Will delete %d Bodies: ", tmp_body_list.size());
CubitUtil::list_entity_ids(pre_body, tmp_body_list);
std::cout << "Partitioned Body list size after delete: "
<< partition_list.size() << std::endl;
// delete bodies
nEntity = delete_body_list.size();
delete_body_list.reset();
GeometryQueryTool::instance()->delete_RefEntity(
delete_body_list.get_and_step());
// update Body list in ParallelComm
body_entity_list.clean_out();
body_entity_list += partition_list;
| CubitStatus CGMReadParallel::load_file | ( | const char * | file_names, |
| const char * | options, | ||
| const char * | set_tag_name = 0, |
| const int * | set_tag_values = 0, |
| int | num_set_tag_values = 0 |
Definition at line 66 of file CGMReadParallel.cpp.
CGMFileOptions opts(options);
// Get parallel settings
int parallel_mode;
CGMFOErrorCode result = opts.match_option("PARALLEL", CGMparallelOptsNames,
parallel_mode);
if (FO_FAILURE == result) {
PRINT_ERROR("Unexpected value for 'PARALLEL' option\n");
} else if (FO_ENTITY_NOT_FOUND == result) {
parallel_mode = 0;
bool surf_partition = false;
std::string partition_tag_name;
std::vector<int> partition_tag_vals;
// Get partition tag value(s), if any, and whether they're to be
result = opts.get_ints_option("PARTITION_VAL", partition_tag_vals);
// Get partition setting
result = opts.get_option("PARTITION", partition_tag_name);
if (FO_ENTITY_NOT_FOUND == result || partition_tag_name.empty()) {
partition_tag_name = "GEOM_DIMENSION";
} else {
// use geom dimension for partition
if (partition_tag_name == "GEOM_DIMENSION") {
int geom_dim = 0;
for (std::vector<int>::iterator pit = partition_tag_vals.begin();
pit != partition_tag_vals.end(); pit++) {
geom_dim = *pit;
if (geom_dim == 2)
surf_partition = true; // body & surface partition
else if (geom_dim == 3)
surf_partition = false; // body partition only
else {
PRINT_ERROR("Geometry dimension %d is not supported.\n", geom_dim);
// static partition, use chaco
else if (partition_tag_name == "PAR_PARTITION_STATIC") {
m_bal_method = PARTITION_STATIC;
// dynamic partition, use zoltan
else if (partition_tag_name == "PAR_PARTITION_DYNAMIC") {
m_bal_method = PARTITION_DYNAMIC;
// round-robin
result = opts.get_null_option("PARTITION_DISTRIBUTE");
if (FO_SUCCESS == result)
// get MPI IO processor rank
int reader_rank;
result = opts.get_int_option("MPI_IO_RANK", reader_rank);
reader_rank = 0;
else if (FO_SUCCESS != result) {
PRINT_ERROR("Unexpected value for 'MPI_IO_RANK' option\n");
m_pcomm->proc_config().set_master(reader_rank); // set master processor
bool reader = (reader_rank == (int) m_rank);
// now that we've parsed all the parallel options, make an instruction
// queue
std::vector<int> pa_vec;
switch (parallel_mode) {
case POPT_READ:
pa_vec.push_back(PA_READ);
pa_vec.push_back(PA_BALANCE);
break;
case POPT_DEFAULT:
case POPT_READ_DELETE:
pa_vec.push_back(PA_DELETE_NONLOCAL);
break;
case POPT_BCAST:
if (reader) {
pa_vec.push_back(PA_BROADCAST);
break;
case POPT_BCAST_DELETE:
if (reader) {
break;
case PORT_SCATTER:
if (reader) {
pa_vec.push_back(PA_SCATTER);
m_scatter = true;
break;
case POPT_FORMAT:
PRINT_ERROR("Access to format-specific parallel read not implemented.\n");
case POPT_READ_PARALLEL:
PRINT_ERROR("Partitioning for PARALLEL=READ_PARALLEL not supported yet.\n");
default:
return load_file(file_name, parallel_mode, partition_tag_name,
partition_tag_vals, pa_vec, opts, set_tag_name, set_tag_values,
num_set_tag_values, reader_rank, surf_partition);
| CubitStatus CGMReadParallel::load_file | ( | const char * | file_name, |
| int | parallel_mode, | ||
| std::string & | partition_tag_name, | ||
| std::vector< int > & | partition_tag_vals, | ||
| std::vector< int > & | pa_vec, | ||
| const CGMFileOptions & | opts, | ||
| const char * | set_tag_name, | ||
| const int * | set_tag_values, | ||
| const int | num_set_tag_values, | ||
| const int | reader_rank, | ||
| const bool | surf_partition | ||
Definition at line 199 of file CGMReadParallel.cpp.
// actuate CA_BODIES and turn on auto flag for other attributes
CGMApp::instance()->attrib_manager()->register_attrib_type(CA_BODIES,
"bodies", "BODIES", &CABodies_creator, CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
CUBIT_TRUE, CUBIT_TRUE, CUBIT_FALSE);
CGMApp::instance()->attrib_manager()->auto_flag(CUBIT_TRUE);
DEBUG_FLAG(90, CUBIT_TRUE);
DEBUG_FLAG(138, CUBIT_TRUE);
// do the work by options
std::vector<int>::iterator vit;
int i;
for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); vit++, i++) {
CubitStatus result = CUBIT_SUCCESS;
switch (*vit) {
case PA_READ:
double tStart, tEnd;
std::cout << "Reading file " << file_name << std::endl;
tStart = MPI_Wtime();
result = read_entities(file_name);
if (CUBIT_SUCCESS != result) {
PRINT_ERROR("Reading file %s failed.\n", file_name);
} else if (CGM_read_parallel_debug) {
tEnd = MPI_Wtime();
PRINT_INFO("Read time in proc %d is %f.\n", m_rank, tEnd - tStart);
PRINT_INFO("Read done.\n");
break;
case PA_BALANCE:
std::cout << "Balancing entities." << std::endl;
result = balance_round_robin();
return result;
PRINT_INFO("Balancing entities done.\n");
break;
case PA_DELETE_NONLOCAL:
PRINT_INFO("Deleting nonlocal entities.\n");
result = delete_nonlocal_entities(reader_rank, partition_tag_name,
PRINT_ERROR("Delete failed.\n");
tEnd = MPI_Wtime();
PRINT_INFO("Delete done.\n");
PRINT_INFO("Delete time in proc %d is %f.\n", m_rank, tEnd - tStart);
break;
case PA_BROADCAST:
// do the actual broadcast; if single-processor, ignore error
if (m_proc_size > 1) {
PRINT_INFO("Broadcasting Body entities.\n");
result = m_pcomm->broadcast_entities(reader_rank,
m_pcomm->partition_body_list());
PRINT_ERROR("Broadcasting Body entities failed.\n");
tEnd = MPI_Wtime();
PRINT_INFO("Bcast bodies done.\n");
PRINT_INFO("Broadcast bodies time in proc %d is %f.\n", m_proc_size,
tEnd - tStart);
if (!check_partition_info()) {
PRINT_ERROR("Check partition info failed.\n");
break;
case PA_SCATTER:
// do the actual scatter
PRINT_INFO("Scattering body entities.\n");
result = m_pcomm->scatter_entities(reader_rank,
PRINT_ERROR("Scattering body entities failed.\n");
tEnd = MPI_Wtime();
PRINT_INFO("Scatter bodies done.\n");
PRINT_INFO("Scatter bodies time in proc %d is %f.\n", m_proc_size,
tEnd - tStart);
PRINT_INFO("Scatter done.\n");
break;
default:
| CubitStatus CGMReadParallel::read_entities | ( | const char * | file_name | ) | [private] |
Definition at line 349 of file CGMReadParallel.cpp.
// check file type
CubitString file_type;
if (strstr(file_name, ".stp"))
file_type = "STEP";
else if (strstr(file_name, ".igs"))
file_type = "IGES";
else if (strstr(file_name, ".occ") || strstr(file_name, ".OCC")
|| strstr(file_name, ".brep") || strstr(file_name, ".BREP"))
file_type = "OCC";
else {
PRINT_ERROR("File type not known for file %s; skipping.\n", file_name);
// import solid model
CubitStatus result = CubitCompat_import_solid_model(file_name,
file_type.c_str());
// get body entities
result = m_gqt->ref_entity_list("body", body_entity_list, CUBIT_FALSE);
PRINT_ERROR("Getting Body entities failed.\n");
return result;
return result;
| void CGMReadParallel::set_reader | ( | unsigned int | reader | ) |
const char * CGMReadParallel::CGMparallelOptsNames [static] |
{ "NONE", "READ",
"READ_DELETE", "BCAST", "BCAST_DELETE", "SCATTER", "SCATTER_DELETE",
"READ_PARALLEL", "FORMAT", "", 0 }
Definition at line 43 of file CGMReadParallel.hpp.
const char * CGMReadParallel::CGMpartitionOptsNames [static] |
{ "NONE",
"GEOM_DIMENSION", "PARARELL_PARTITION", "", 0 }
Definition at line 45 of file CGMReadParallel.hpp.
BALANCE_METHOD CGMReadParallel::m_bal_method [private] |
Definition at line 64 of file CGMReadParallel.hpp.
GeometryQueryTool* CGMReadParallel::m_gqt [private] |
Definition at line 56 of file CGMReadParallel.hpp.
CGMParallelComm* CGMReadParallel::m_pcomm [private] |
Definition at line 58 of file CGMReadParallel.hpp.
unsigned int CGMReadParallel::m_proc_size [private] |
Definition at line 62 of file CGMReadParallel.hpp.
unsigned int CGMReadParallel::m_rank [private] |
bool CGMReadParallel::m_reader [private] |
Definition at line 60 of file CGMReadParallel.hpp.
bool CGMReadParallel::m_scatter [private] |
DLIList<RefEntity*> CGMReadParallel::m_surf_entity_list [private] |
Definition at line 67 of file CGMReadParallel.hpp.
