This is the complete list of members for
CGMReadParallel, including all inherited members.
| balance_round_robin() | CGMReadParallel | [private] |
| BCAST enum value | CGMReadParallel | |
| BCAST_AND_DELETE enum value | CGMReadParallel | |
| CGMParallelOpts enum name | CGMReadParallel | |
| CGMparallelOptsNames | CGMReadParallel | [static] |
| CGMpartitionOptsNames | CGMReadParallel | [static] |
| CGMReadParallel(GeometryQueryTool *gqt=NULL, CGMParallelComm *pc=NULL) | CGMReadParallel | |
| check_partition_info() | CGMReadParallel | [private] |
| delete_nonlocal_entities(int reader, std::string &ptag_name, std::vector< int > &ptag_vals) | CGMReadParallel | [private] |
| load_file(const char *file_names, const char *options, const char *set_tag_name=0, const int *set_tag_values=0, int num_set_tag_values=0) | CGMReadParallel | |
| load_file(const char *file_name, int parallel_mode, std::string &partition_tag_name, std::vector< int > &partition_tag_vals, std::vector< int > &pa_vec, const CGMFileOptions &opts, const char *set_tag_name, const int *set_tag_values, const int num_set_tag_values, const int reader_rank, const bool surf_partition) | CGMReadParallel | |
| m_bal_method | CGMReadParallel | [private] |
| m_gqt | CGMReadParallel | [private] |
| m_pcomm | CGMReadParallel | [private] |
| m_proc_size | CGMReadParallel | [private] |
| m_rank | CGMReadParallel | [private] |
| m_reader | CGMReadParallel | [private] |
| m_scatter | CGMReadParallel | [private] |
| m_surf_entity_list | CGMReadParallel | [private] |
| ParallelLoadOption enum name | CGMReadParallel | |
| POPT_BCAST enum value | CGMReadParallel | |
| POPT_BCAST_DELETE enum value | CGMReadParallel | |
| POPT_DEFAULT enum value | CGMReadParallel | |
| POPT_FORMAT enum value | CGMReadParallel | |
| POPT_NONE enum value | CGMReadParallel | |
| POPT_READ enum value | CGMReadParallel | |
| POPT_READ_DELETE enum value | CGMReadParallel | |
| POPT_READ_PARALLEL enum value | CGMReadParallel | |
| PORT_SCATTER enum value | CGMReadParallel | |
| PORT_SCATTER_DELETE enum value | CGMReadParallel | |
| read_entities(const char *file_name) | CGMReadParallel | [private] |
| set_reader(unsigned int reader) | CGMReadParallel | |
