cgma
00001 #include <cstdio> 00002 00003 #include "CubitString.hpp" 00004 #include "CubitMessage.hpp" 00005 #include "DLList.hpp" 00006 #include "RefEntity.hpp" 00007 #include "RefFace.hpp" 00008 #include "RefEdge.hpp" 00009 #include "RefVertex.hpp" 00010 #include "CubitEntity.hpp" 00011 #include "Body.hpp" 00012 #include "CastTo.hpp" 00013 #include "CubitUtil.hpp" 00014 #include "CADefines.hpp" 00015 #include "CABodies.hpp" 00016 #include "TDParallel.hpp" 00017 #include "CAMergePartner.hpp" 00018 #include "TDUniqueId.hpp" 00019 00020 #include "TopologyBridge.hpp" 00021 #include "GeometryQueryTool.hpp" 00022 #include "CGMReadParallel.hpp" 00023 #include "CGMParallelConventions.h" 00024 #include "CGMParallelComm.hpp" 00025 #include "CubitCompat.hpp" 00026 00027 #include <iostream> 00028 00029 const bool CGM_read_parallel_debug = false; 00030 00031 enum CGMParallelActions { 00032 PA_READ = 0, 00033 PA_BROADCAST, 00034 PA_DELETE_NONLOCAL, 00035 PA_SCATTER, 00036 PA_SCATTER_DELETE, 00037 PA_BALANCE 00038 }; 00039 00040 enum CGMPartitionActions { 00041 PT_GEOM_DIM = 0, PT_PAR_PART 00042 }; 00043 00044 const char *CGMParallelActionsNames[] = { "PARALLEL READ", "PARALLEL BROADCAST", 00045 "PARALLEL DELETE NONLOCAL", "PARALLEL SCATTER" }; 00046 00047 const char* CGMReadParallel::CGMparallelOptsNames[] = { "NONE", "READ", 00048 "READ_DELETE", "BCAST", "BCAST_DELETE", "SCATTER", "SCATTER_DELETE", 00049 "READ_PARALLEL", "FORMAT", "", 0 }; 00050 00051 const char* CGMReadParallel::CGMpartitionOptsNames[] = { "NONE", 00052 "GEOM_DIMENSION", "PARARELL_PARTITION", "", 0 }; 00053 00054 CGMReadParallel::CGMReadParallel(GeometryQueryTool* gqt, CGMParallelComm *pc) : 00055 m_gqt(gqt), m_pcomm(pc) { 00056 if (!m_pcomm) { 00057 m_pcomm = new CGMParallelComm(); 00058 } 00059 00060 m_bal_method = ROUND_ROBIN; 00061 m_scatter = false; 00062 m_rank = m_pcomm->proc_config().proc_rank(); 00063 m_proc_size = m_pcomm->proc_config().proc_size(); 00064 } 00065 00066 CubitStatus CGMReadParallel::load_file(const char *file_name, 00067 const char *options, const char* set_tag_name, const int* set_tag_values, 00068 int num_set_tag_values) { 00069 CGMFileOptions opts(options); 00070 00071 // Get parallel settings 00072 int parallel_mode; 00073 CGMFOErrorCode result = opts.match_option("PARALLEL", CGMparallelOptsNames, 00074 parallel_mode); 00075 if (FO_FAILURE == result) { 00076 PRINT_ERROR("Unexpected value for 'PARALLEL' option\n"); 00077 return CUBIT_FAILURE; 00078 } else if (FO_ENTITY_NOT_FOUND == result) { 00079 parallel_mode = 0; 00080 } 00081 00082 bool surf_partition = false; 00083 std::string partition_tag_name; 00084 std::vector<int> partition_tag_vals; 00085 00086 // Get partition tag value(s), if any, and whether they're to be 00087 result = opts.get_ints_option("PARTITION_VAL", partition_tag_vals); 00088 00089 // Get partition setting 00090 result = opts.get_option("PARTITION", partition_tag_name); 00091 00092 if (FO_ENTITY_NOT_FOUND == result || partition_tag_name.empty()) { 00093 partition_tag_name = "GEOM_DIMENSION"; 00094 m_bal_method = ROUND_ROBIN; 00095 } else { 00096 // use geom dimension for partition 00097 if (partition_tag_name == "GEOM_DIMENSION") { 00098 int geom_dim = 0; 00099 for (std::vector<int>::iterator pit = partition_tag_vals.begin(); 00100 pit != partition_tag_vals.end(); pit++) { 00101 geom_dim = *pit; 00102 if (geom_dim == 2) 00103 surf_partition = true; // body & surface partition 00104 else if (geom_dim == 3) 00105 surf_partition = false; // body partition only 00106 else { 00107 PRINT_ERROR("Geometry dimension %d is not supported.\n", geom_dim); 00108 return CUBIT_FAILURE; 00109 } 00110 } 00111 } 00112 // static partition, use chaco 00113 else if (partition_tag_name == "PAR_PARTITION_STATIC") { 00114 m_bal_method = PARTITION_STATIC; 00115 } 00116 // dynamic partition, use zoltan 00117 else if (partition_tag_name == "PAR_PARTITION_DYNAMIC") { 00118 m_bal_method = PARTITION_DYNAMIC; 00119 } 00120 00121 // round-robin 00122 result = opts.get_null_option("PARTITION_DISTRIBUTE"); 00123 if (FO_SUCCESS == result) 00124 m_bal_method = ROUND_ROBIN; 00125 } 00126 00127 // get MPI IO processor rank 00128 int reader_rank; 00129 result = opts.get_int_option("MPI_IO_RANK", reader_rank); 00130 if (FO_ENTITY_NOT_FOUND == result) 00131 reader_rank = 0; 00132 else if (FO_SUCCESS != result) { 00133 PRINT_ERROR("Unexpected value for 'MPI_IO_RANK' option\n"); 00134 return CUBIT_FAILURE; 00135 } 00136 m_pcomm->proc_config().set_master(reader_rank); // set master processor 00137 bool reader = (reader_rank == (int) m_rank); 00138 00139 // now that we've parsed all the parallel options, make an instruction 00140 // queue 00141 std::vector<int> pa_vec; 00142 switch (parallel_mode) { 00143 00144 case POPT_READ: 00145 pa_vec.push_back(PA_READ); 00146 pa_vec.push_back(PA_BALANCE); 00147 break; 00148 00149 case POPT_DEFAULT: 00150 case POPT_READ_DELETE: 00151 pa_vec.push_back(PA_READ); 00152 pa_vec.push_back(PA_BALANCE); 00153 pa_vec.push_back(PA_DELETE_NONLOCAL); 00154 break; 00155 00156 case POPT_BCAST: 00157 if (reader) { 00158 pa_vec.push_back(PA_READ); 00159 pa_vec.push_back(PA_BALANCE); 00160 } 00161 pa_vec.push_back(PA_BROADCAST); 00162 break; 00163 00164 case POPT_BCAST_DELETE: 00165 if (reader) { 00166 pa_vec.push_back(PA_READ); 00167 pa_vec.push_back(PA_BALANCE); 00168 } 00169 pa_vec.push_back(PA_BROADCAST); 00170 pa_vec.push_back(PA_DELETE_NONLOCAL); 00171 break; 00172 00173 case PORT_SCATTER: 00174 if (reader) { 00175 pa_vec.push_back(PA_READ); 00176 pa_vec.push_back(PA_BALANCE); 00177 } 00178 pa_vec.push_back(PA_SCATTER); 00179 m_scatter = true; 00180 break; 00181 00182 case POPT_FORMAT: 00183 PRINT_ERROR("Access to format-specific parallel read not implemented.\n"); 00184 return CUBIT_FAILURE; 00185 00186 case POPT_READ_PARALLEL: 00187 PRINT_ERROR("Partitioning for PARALLEL=READ_PARALLEL not supported yet.\n"); 00188 return CUBIT_FAILURE; 00189 00190 default: 00191 return CUBIT_FAILURE; 00192 } 00193 00194 return load_file(file_name, parallel_mode, partition_tag_name, 00195 partition_tag_vals, pa_vec, opts, set_tag_name, set_tag_values, 00196 num_set_tag_values, reader_rank, surf_partition); 00197 } 00198 00199 CubitStatus CGMReadParallel::load_file(const char *file_name, int parallel_mode, 00200 std::string &partition_tag_name, std::vector<int> &partition_tag_vals, 00201 std::vector<int> &pa_vec, const CGMFileOptions &opts, 00202 const char* set_tag_name, const int* set_tag_values, 00203 const int num_set_tag_values, const int reader_rank, 00204 const bool surf_partition) { 00205 // actuate CA_BODIES and turn on auto flag for other attributes 00206 CGMApp::instance()->attrib_manager()->register_attrib_type(CA_BODIES, 00207 "bodies", "BODIES", &CABodies_creator, CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE, 00208 CUBIT_TRUE, CUBIT_TRUE, CUBIT_FALSE); 00209 CGMApp::instance()->attrib_manager()->auto_flag(CUBIT_TRUE); 00210 00211 if (CGM_read_parallel_debug) { 00212 DEBUG_FLAG(90, CUBIT_TRUE); 00213 DEBUG_FLAG(138, CUBIT_TRUE); 00214 } 00215 00216 // do the work by options 00217 std::vector<int>::iterator vit; 00218 int i; 00219 00220 for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); vit++, i++) { 00221 CubitStatus result = CUBIT_SUCCESS; 00222 switch (*vit) { 00223 //================== 00224 case PA_READ: 00225 double tStart, tEnd; 00226 00227 if (CGM_read_parallel_debug) { 00228 std::cout << "Reading file " << file_name << std::endl; 00229 tStart = MPI_Wtime(); 00230 } 00231 00232 result = read_entities(file_name); 00233 00234 if (CUBIT_SUCCESS != result) { 00235 PRINT_ERROR("Reading file %s failed.\n", file_name); 00236 return CUBIT_FAILURE; 00237 } else if (CGM_read_parallel_debug) { 00238 tEnd = MPI_Wtime(); 00239 PRINT_INFO("Read time in proc %d is %f.\n", m_rank, tEnd - tStart); 00240 PRINT_INFO("Read done.\n"); 00241 } 00242 00243 break; 00244 00245 //================== 00246 case PA_BALANCE: 00247 if (CGM_read_parallel_debug) 00248 std::cout << "Balancing entities." << std::endl; 00249 if (m_bal_method == ROUND_ROBIN) 00250 result = balance_round_robin(); 00251 if (CUBIT_SUCCESS != result) 00252 return result; 00253 00254 if (CGM_read_parallel_debug) 00255 PRINT_INFO("Balancing entities done.\n"); 00256 00257 break; 00258 00259 //================== 00260 case PA_DELETE_NONLOCAL: 00261 if (CGM_read_parallel_debug) { 00262 PRINT_INFO("Deleting nonlocal entities.\n"); 00263 tStart = MPI_Wtime(); 00264 } 00265 00266 result = delete_nonlocal_entities(reader_rank, partition_tag_name, 00267 partition_tag_vals); 00268 00269 if (CUBIT_SUCCESS != result) { 00270 PRINT_ERROR("Delete failed.\n"); 00271 return CUBIT_FAILURE; 00272 } else if (CGM_read_parallel_debug) { 00273 tEnd = MPI_Wtime(); 00274 PRINT_INFO("Delete done.\n"); 00275 PRINT_INFO("Delete time in proc %d is %f.\n", m_rank, tEnd - tStart); 00276 } 00277 break; 00278 00279 //================== 00280 case PA_BROADCAST: 00281 // do the actual broadcast; if single-processor, ignore error 00282 if (m_proc_size > 1) { 00283 if (CGM_read_parallel_debug) { 00284 PRINT_INFO("Broadcasting Body entities.\n"); 00285 tStart = MPI_Wtime(); 00286 } 00287 00288 result = m_pcomm->broadcast_entities(reader_rank, 00289 m_pcomm->partition_body_list()); 00290 00291 if (CUBIT_SUCCESS != result) { 00292 PRINT_ERROR("Broadcasting Body entities failed.\n"); 00293 return CUBIT_FAILURE; 00294 } else if (CGM_read_parallel_debug) { 00295 tEnd = MPI_Wtime(); 00296 PRINT_INFO("Bcast bodies done.\n"); 00297 PRINT_INFO("Broadcast bodies time in proc %d is %f.\n", m_proc_size, 00298 tEnd - tStart); 00299 } 00300 00301 if (!check_partition_info()) { 00302 PRINT_ERROR("Check partition info failed.\n"); 00303 return CUBIT_FAILURE; 00304 } 00305 } 00306 00307 break; 00308 00309 //================== 00310 case PA_SCATTER: 00311 // do the actual scatter 00312 if (m_proc_size > 1) { 00313 if (CGM_read_parallel_debug) { 00314 PRINT_INFO("Scattering body entities.\n"); 00315 tStart = MPI_Wtime(); 00316 } 00317 result = m_pcomm->scatter_entities(reader_rank, 00318 m_pcomm->partition_body_list()); 00319 00320 if (CUBIT_SUCCESS != result) { 00321 PRINT_ERROR("Scattering body entities failed.\n"); 00322 return CUBIT_FAILURE; 00323 } else if (CGM_read_parallel_debug) { 00324 tEnd = MPI_Wtime(); 00325 PRINT_INFO("Scatter bodies done.\n"); 00326 PRINT_INFO("Scatter bodies time in proc %d is %f.\n", m_proc_size, 00327 tEnd - tStart); 00328 } 00329 00330 if (!check_partition_info()) { 00331 PRINT_ERROR("Check partition info failed.\n"); 00332 return CUBIT_FAILURE; 00333 } 00334 } 00335 if (CGM_read_parallel_debug) 00336 PRINT_INFO("Scatter done.\n"); 00337 00338 break; 00339 00340 //================== 00341 default: 00342 return CUBIT_FAILURE; 00343 } 00344 } 00345 00346 return CUBIT_SUCCESS; 00347 } 00348 00349 CubitStatus CGMReadParallel::read_entities(const char* file_name) { 00350 // check file type 00351 CubitString file_type; 00352 if (strstr(file_name, ".stp")) 00353 file_type = "STEP"; 00354 else if (strstr(file_name, ".igs")) 00355 file_type = "IGES"; 00356 else if (strstr(file_name, ".occ") || strstr(file_name, ".OCC") 00357 || strstr(file_name, ".brep") || strstr(file_name, ".BREP")) 00358 file_type = "OCC"; 00359 else { 00360 PRINT_ERROR("File type not known for file %s; skipping.\n", file_name); 00361 return CUBIT_FAILURE; 00362 } 00363 00364 // import solid model 00365 CubitStatus result = CubitCompat_import_solid_model(file_name, 00366 file_type.c_str()); 00367 if (CUBIT_SUCCESS != result) { 00368 PRINT_ERROR("Reading file %s failed.\n", file_name); 00369 return CUBIT_FAILURE; 00370 } 00371 00372 // get body entities 00373 DLIList<RefEntity*>& body_entity_list = m_pcomm->partition_body_list(); 00374 body_entity_list.clean_out(); 00375 result = m_gqt->ref_entity_list("body", body_entity_list, CUBIT_FALSE); 00376 if (CUBIT_SUCCESS != result) { 00377 PRINT_ERROR("Getting Body entities failed.\n"); 00378 return result; 00379 } 00380 00381 return result; 00382 } 00383 00384 CubitStatus CGMReadParallel::balance_round_robin() { 00385 // get bodies 00386 int i, j, k; 00387 DLIList<RefEntity*>& body_entity_list = m_pcomm->partition_body_list(); 00388 int n_proc = m_proc_size; 00389 double* loads = new double[n_proc]; // estimated loads for each processor 00390 double* ve_loads = new double[n_proc]; // estimated loads for each processor 00391 for (i = 0; i < n_proc; i++) { 00392 loads[i] = 0.0; 00393 ve_loads[i] = 0.0; 00394 } 00395 00396 if (m_bal_method == ROUND_ROBIN) { // round-robin case 00397 int n_entity = body_entity_list.size(); 00398 int n_entity_proc = n_entity / n_proc; // # of entities per processor 00399 int i_entity_proc = n_entity_proc; // entity index limit for each processor 00400 int proc = 0; 00401 RefEntity* entity; 00402 00403 // assign processors to bodies 00404 body_entity_list.reset(); 00405 for (i = 0; i < n_entity; i++) { 00406 if (i == i_entity_proc) { 00407 proc++; 00408 if (proc < n_proc) 00409 i_entity_proc += n_entity_proc; 00410 else { 00411 proc %= n_proc; 00412 i_entity_proc++; 00413 } 00414 } 00415 00416 // assign to bodies 00417 entity = body_entity_list.get_and_step(); 00418 DLIList<int> shared_procs; 00419 shared_procs.append(proc); 00420 TDParallel *td_par = (TDParallel *) entity->get_TD( 00421 &TDParallel::is_parallel); 00422 if (td_par == NULL) 00423 td_par = new TDParallel(entity, NULL, &shared_procs); 00424 loads[proc] += entity->measure(); 00425 00426 // assign to volumes, it should be removed in future 00427 DLIList<RefVolume*> volumes; 00428 (dynamic_cast<TopologyEntity*>(entity))->ref_volumes(volumes); 00429 int n_vol = volumes.size(); 00430 volumes.reset(); 00431 for (j = 0; j < n_vol; j++) { 00432 RefEntity *vol = volumes.get_and_step(); 00433 td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel); 00434 if (td_par == NULL) 00435 td_par = new TDParallel(vol, NULL, &shared_procs); 00436 } 00437 00438 // add local surface load 00439 DLIList<RefFace*> faces; 00440 (dynamic_cast<TopologyEntity*>(entity))->ref_faces(faces); 00441 int n_face = faces.size(); 00442 faces.reset(); 00443 for (j = 0; j < n_face; j++) { 00444 RefFace* face = faces.get_and_step(); 00445 TopologyEntity *te = CAST_TO(face, TopologyEntity); 00446 if (te->bridge_manager()->number_of_bridges() < 2) { 00447 loads[proc] = loads[proc] + face->measure(); 00448 } 00449 } 00450 } 00451 00452 // Get all child entities 00453 DLIList<RefEntity*> child_list; 00454 RefEntity::get_all_child_ref_entities(body_entity_list, child_list); 00455 int n_child = child_list.size(); 00456 00457 // assign processors to interface entities 00458 child_list.reset(); 00459 for (i = 0; i < n_child; i++) { 00460 entity = child_list.get_and_step(); 00461 TopologyEntity *te = CAST_TO(entity, TopologyEntity); 00462 00463 if (te->bridge_manager()->number_of_bridges() > 1) { 00464 DLIList<Body*> parent_bodies; 00465 DLIList<int> shared_procs; 00466 (dynamic_cast<TopologyEntity*>(entity))->bodies(parent_bodies); 00467 int n_parent = parent_bodies.size(); 00468 00469 for (j = 0; j < n_parent; j++) { 00470 RefEntity *parent_vol = CAST_TO(parent_bodies.get_and_step(), 00471 RefEntity); 00472 TDParallel *parent_td = (TDParallel *) parent_vol->get_TD( 00473 &TDParallel::is_parallel); 00474 00475 if (parent_td == NULL) { 00476 PRINT_ERROR("parent Volume has to be partitioned."); 00477 return CUBIT_FAILURE; 00478 } 00479 shared_procs.append_unique(parent_td->get_charge_proc()); 00480 } 00481 00482 if (shared_procs.size() > 1) { // if it is interface 00483 TDParallel *td_par = (TDParallel *) entity->get_TD( 00484 &TDParallel::is_parallel); 00485 if (td_par == NULL) { 00486 int merge_id = TDUniqueId::get_unique_id(entity); 00487 if (entity->entity_type_info() == typeid(RefFace)) { // face 00488 if (shared_procs.size() != 2) { 00489 PRINT_ERROR( 00490 "Error: # of shared processors of interface surface should be 2."); 00491 return CUBIT_FAILURE; 00492 } 00493 00494 // balance interface surface loads 00495 if (loads[shared_procs[0]] > loads[shared_procs[1]]) { 00496 shared_procs.reverse(); 00497 } 00498 loads[shared_procs[0]] = loads[shared_procs[0]] 00499 + entity->measure(); 00500 td_par = new TDParallel(entity, NULL, &shared_procs, NULL, 00501 merge_id, 1); 00502 } else if (entity->entity_type_info() == typeid(RefEdge) 00503 || entity->entity_type_info() == typeid(RefVertex)) { 00504 // balance interface surface loads 00505 int min_p = shared_procs[0]; 00506 int n_shared_proc = shared_procs.size(); 00507 for (int i1 = 1; i1 < n_shared_proc; i1++) { 00508 if (ve_loads[shared_procs[i1]] < ve_loads[min_p]) { 00509 min_p = shared_procs[i1]; 00510 } 00511 } 00512 ve_loads[min_p] = ve_loads[min_p] + entity->measure(); 00513 shared_procs.remove(min_p); 00514 shared_procs.insert_first(min_p); 00515 00516 // add ghost geometries to shared processors for edge 00517 if (entity->entity_type_info() == typeid(RefEdge)) { 00518 parent_bodies.reset(); 00519 for (j = 0; j < n_parent; j++) { 00520 RefEntity *parent_vol = CAST_TO(parent_bodies.get_and_step(), 00521 RefEntity); 00522 TDParallel *parent_td = (TDParallel *) parent_vol->get_TD( 00523 &TDParallel::is_parallel); 00524 for (k = 0; k < n_shared_proc; k++) { 00525 parent_td->add_ghost_proc(shared_procs[k]); 00526 } 00527 } 00528 } 00529 td_par = new TDParallel(entity, NULL, &shared_procs, NULL, 00530 merge_id, 1); 00531 } 00532 } 00533 } 00534 } 00535 } 00536 } else if (m_bal_method == PARTITION_DYNAMIC) { 00537 } 00538 00539 return CUBIT_SUCCESS; 00540 } 00541 00542 CubitStatus CGMReadParallel::delete_nonlocal_entities(int reader, 00543 std::string &ptag_name, std::vector<int> &ptag_vals) { 00544 // find bodies deleted 00545 int i; 00546 DLIList<RefEntity*>& body_entity_list = m_pcomm->partition_body_list(); 00547 DLIList<RefEntity*> partition_list, delete_body_list; 00548 int nEntity = body_entity_list.size(); 00549 body_entity_list.reset(); 00550 00551 for (i = 0; i < nEntity; i++) { 00552 RefEntity* entity = body_entity_list.get_and_step(); 00553 TDParallel *td_par = (TDParallel *) entity->get_TD( 00554 &TDParallel::is_parallel); 00555 if (td_par == NULL) { 00556 PRINT_ERROR("Partitioned Volume should have TDParallel data."); 00557 return CUBIT_FAILURE; 00558 } 00559 00560 if (td_par->get_charge_proc() != m_rank) { // candidate to be deleted 00561 // check child surfaces if surface partitioned 00562 DLIList<RefFace*> face_list; 00563 (dynamic_cast<TopologyEntity*>(entity))->ref_faces(face_list); 00564 bool b_partitioned_surf = false; 00565 int n_face = face_list.size(); 00566 face_list.reset(); 00567 for (int j = 0; j < n_face; j++) { 00568 RefEntity* face = face_list.get_and_step(); 00569 TDParallel *td_par_face = (TDParallel *) face->get_TD( 00570 &TDParallel::is_parallel); 00571 if (td_par_face != NULL) { // if surface is partitioned 00572 DLIList<int>* shared_procs = td_par_face->get_shared_proc_list(); 00573 int n_shared = shared_procs->size(); 00574 shared_procs->reset(); 00575 for (int k = 0; k < n_shared; k++) { 00576 if (shared_procs->get_and_step() == (int) m_rank) { 00577 b_partitioned_surf = true; 00578 break; 00579 } 00580 } 00581 } 00582 } 00583 if (b_partitioned_surf) 00584 partition_list.append(entity); 00585 else 00586 delete_body_list.append(entity); 00587 } else 00588 partition_list.append(entity); 00589 } 00590 00591 // print info 00592 char pre_body[100]; 00593 DLIList<CubitEntity*> tmp_body_list; 00594 if (CGM_read_parallel_debug) { 00595 if ((int) m_rank != reader) { 00596 CAST_LIST_TO_PARENT(delete_body_list, tmp_body_list); 00597 sprintf(pre_body, "Will delete %d Bodies: ", tmp_body_list.size()); 00598 CubitUtil::list_entity_ids(pre_body, tmp_body_list); 00599 } 00600 std::cout << "Partitioned Body list size after delete: " 00601 << partition_list.size() << std::endl; 00602 } 00603 00604 // delete bodies 00605 nEntity = delete_body_list.size(); 00606 delete_body_list.reset(); 00607 for (i = 0; i < nEntity; i++) { 00608 GeometryQueryTool::instance()->delete_RefEntity( 00609 delete_body_list.get_and_step()); 00610 } 00611 00612 // update Body list in ParallelComm 00613 body_entity_list.clean_out(); 00614 body_entity_list += partition_list; 00615 00616 return CUBIT_SUCCESS; 00617 } 00618 00619 CubitStatus CGMReadParallel::check_partition_info() { 00620 int i; 00621 DLIList<RefEntity*>& body_entity_list = m_pcomm->partition_body_list(); 00622 int nEntity = body_entity_list.size(); 00623 body_entity_list.reset(); 00624 00625 for (i = 0; i < nEntity; i++) { 00626 RefEntity* entity = body_entity_list.get_and_step(); 00627 TDParallel *td_par = (TDParallel *) entity->get_TD( 00628 &TDParallel::is_parallel); 00629 if (td_par == NULL) { // if body is not partitioned 00630 DLIList<RefEntity*> volumes; 00631 entity->get_child_ref_entities(volumes); 00632 00633 // check if the first Volume is partitioned here, should be removed in future 00634 volumes.reset(); 00635 RefEntity *vol = volumes.get(); 00636 if (vol == NULL || vol->entity_type_info() != typeid(RefVolume)) { 00637 PRINT_ERROR("Partitioned Body should have at least one Volume."); 00638 return CUBIT_FAILURE; 00639 } 00640 td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel); 00641 00642 if (td_par == NULL) { 00643 PRINT_ERROR("Partitioned Volume should have TDParallel data."); 00644 return CUBIT_FAILURE; 00645 } 00646 00647 DLIList<int> s_procs; 00648 s_procs.append(td_par->get_charge_proc()); 00649 td_par = new TDParallel(entity, NULL, &s_procs); 00650 } 00651 } 00652 00653 return CUBIT_SUCCESS; 00654 }
