cgma
#include <cassert>#include <cstdio>#include <cstdlib>#include <list>#include <map>#include <string>#include "GeometryModifyTool.hpp"#include "GeometryQueryTool.hpp"#include "GMem.hpp"#include "OCCModifyEngine.hpp"#include "OCCQueryEngine.hpp"#include "RefVertex.hpp"#include "RefEdge.hpp"#include "RefFace.hpp"#include "RefVolume.hpp"#include "InitCGMA.hpp"#include "CubitCompat.hpp"Go to the source code of this file.
Defines | |
| #define | STRINGIFY(S) XSTRINGIFY(S) |
| #define | XSTRINGIFY(S) #S |
| #define | SRCDIR "." |
Functions | |
| int | main (int argc, char **argv) |
| #define SRCDIR "." |
Definition at line 24 of file test_occ.cpp.
| #define STRINGIFY | ( | S | ) | XSTRINGIFY(S) |
Definition at line 21 of file test_occ.cpp.
| #define XSTRINGIFY | ( | S | ) | #S |
Definition at line 22 of file test_occ.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 33 of file test_occ.cpp.
CubitStatus status = InitCGMA::initialize_cgma("OCC");
if (CUBIT_SUCCESS != status) return 1;
GeometryQueryTool *gti = GeometryQueryTool::instance();
// Read in the geometry from files specified on the command line
const char* filename = STRINGIFY(SRCDIR) "/LeverArm.brep";
status = CubitCompat_import_solid_model(filename, "OCC");
if (status != CUBIT_SUCCESS) {
PRINT_ERROR("Problems reading geometry file %s.\n", filename);
return 1;
DLIList<RefEdge*> my_curvs;
DLIList<RefFace*> my_surfs;
gti->ref_edges(my_curvs);
gti->ref_faces(my_surfs);
// ***** Discretize the curves ***** //
map< RefEdge*, list<double> > discrete_curves;
for(int i = 0; i < my_curvs.size(); ++i) {
list<double> sample_params;
RefEdge* this_curv = my_curvs.get_and_step();
//Insert nine arbitrary points on each curves
double delta = this_curv->end_param() - this_curv->start_param();
for(int j = 1; j < 10; ++j)
sample_params.push_back( this_curv->start_param() + (static_cast<double>(j) * delta / 10.) );
discrete_curves.insert( std::make_pair(this_curv, sample_params) );
//Pick one of the surfaces arbitrarily and attempt to find the u-v coordinates
//of the points discretizing the boundary of this surface.
RefFace* this_surf = my_surfs.next(7);
DLIList<RefVertex*> surf_points;
DLIList<RefEdge*> surf_curves;
this_surf->ref_vertices(surf_points);
this_surf->ref_edges(surf_curves);
CubitVector coord0, coord1;
double u, v;
double max_u, min_u, max_v, min_v;
this_surf->get_param_range_U(min_u, max_u);
this_surf->get_param_range_V(min_v, max_v);
//Deals with curve end points.
for(int i = 0; i < surf_points.size(); ++i) {
RefVertex* this_point = surf_points.get_and_step();
u = v = -1.e300;
coord0 = this_point->coordinates();
this_surf->u_v_from_position(coord0, u, v, &coord1);
if( u < min_u || v < min_v ) {
printf("Failed to find a parameter with valid range for an apex point\n");
printf(" point coords: %e %e %e\n", coord0.x(), coord0.y(), coord0.z());
printf(" projected coords: %e %e %e\n", coord1.x(), coord1.y(), coord1.z());
printf(" params returned: %e %e\n\n", u, v);
return 1;
//Deals with discretization points on curves.
for(int i = 0; i < surf_curves.size(); ++i) {
RefEdge* this_curv = surf_curves.get_and_step();
assert(discrete_curves.count(this_curv) == 1);
list<double> curve_params = discrete_curves.find(this_curv)->second;
list<double>::iterator it = curve_params.begin(), it_end = curve_params.end();
for( ; it != it_end; ++it) {
u = v = -1.e300;
this_curv->position_from_u(*it, coord0);
printf("Failed to find a parameter with valid range for a curve point\n");
return 1;
printf("done...\n");
return(0);
