cgma
#include <math.h>#include "GeometryDefines.h"#include "TetFacetorTool.hpp"#include "TDDelaunay.hpp"#include "TDInterpNode.hpp"#include <vector>#include <algorithm>Go to the source code of this file.
Defines | |
| #define | MY_INLINE |
| #define | TET_FACETOR_TOOL template<class TET, class SUBTET, class NODE> MY_INLINE TetFacetorTool<TET, SUBTET, NODE>:: |
| #define | TET_FACETOR_TOOL__I template<class TET, class SUBTET, class NODE> MY_INLINE int TetFacetorTool<TET, SUBTET, NODE>:: |
| #define | TET_FACETOR_TOOL__V template<class TET, class SUBTET, class NODE> MY_INLINE void TetFacetorTool<TET, SUBTET, NODE>:: |
| #define | TET_FACETOR_TOOL__D template<class TET, class SUBTET, class NODE> MY_INLINE double TetFacetorTool<TET, SUBTET, NODE>:: |
| #define | TET_FACETOR_TOOL__B template<class TET, class SUBTET, class NODE> MY_INLINE CubitBoolean TetFacetorTool<TET, SUBTET, NODE>:: |
| #define | TET_FACETOR_TOOL__T template<class TET, class SUBTET, class NODE> MY_INLINE TET *TetFacetorTool<TET, SUBTET, NODE>:: |
| #define | SQR(x) ((x) * (x)) |
Functions | |
| TET_FACETOR_TOOL | TetFacetorTool () |
| TET_FACETOR_TOOL | ~TetFacetorTool () |
| TET_FACETOR_TOOL__I | initialize (CubitBox &bounding_box) |
| TET_FACETOR_TOOL__I | finish () |
| TET_FACETOR_TOOL__I | get_tets (std::vector< TET * > &tet_list) |
| TET_FACETOR_TOOL__T | get_outside_tet () |
| TET_FACETOR_TOOL__I | get_interior_tets (std::vector< TET * > &tet_list) |
| TET_FACETOR_TOOL__I | tesselate (std::vector< NODE * > &node_list, std::vector< TET * > &tet_list) |
| TET_FACETOR_TOOL__I | init_box (std::vector< NODE * > &node_list) |
| TET_FACETOR_TOOL__I | create_bbox_tets () |
| TET_FACETOR_TOOL__I | remove_bbox_tets () |
| TET_FACETOR_TOOL__I | is_bbox (NODE *n) |
| TET_FACETOR_TOOL__I | insert_nodes (std::vector< NODE * > &node_list) |
| TET_FACETOR_TOOL__I | insert_one_node (NODE *node_ptr) |
| TET_FACETOR_TOOL__I | natural_neighbor_tets (CubitVector &xx, std::vector< TET * > &neighbor_tet_list, NODE *&exact_node) |
| TET_FACETOR_TOOL__I | watson_insert (NODE *node_ptr, std::vector< TET * > &neighbor_tet_list) |
| TET_FACETOR_TOOL__I | locate_point (CubitVector &xx, NODE *&exact_node, TET *&containing_tet) |
| TET_FACETOR_TOOL__I | exhaustive_locate_point (CubitVector &xx, NODE *&exact_node, TET *&containing_tet) |
| TET_FACETOR_TOOL__B | point_in_circumsphere (TET *tet_ptr, CubitVector &xx, std::vector< TET * > &neighbor_tet_list) |
| TET_FACETOR_TOOL__I | circumsphere (TET *tet_ptr, CubitVector ¢er, double &radius_squared) |
| TET_FACETOR_TOOL__V | set_tet_visited (TET *tet_ptr, int new_visit_flag) |
| TET_FACETOR_TOOL__I | tet_visited (TET *tet_ptr) |
| TET_FACETOR_TOOL__D | tet_volume (const CubitVector &a, const CubitVector &b, const CubitVector &c, const CubitVector &d) |
| TET_FACETOR_TOOL__I | read_data (const char *filename, std::vector< NODE * > &node_list) |
| #define MY_INLINE |
Definition at line 34 of file TetFacetorTool.cpp.
| #define SQR | ( | x | ) | ((x) * (x)) |
Definition at line 65 of file TetFacetorTool.cpp.
| #define TET_FACETOR_TOOL template<class TET, class SUBTET, class NODE> MY_INLINE TetFacetorTool<TET, SUBTET, NODE>:: |
Definition at line 56 of file TetFacetorTool.cpp.
| #define TET_FACETOR_TOOL__B template<class TET, class SUBTET, class NODE> MY_INLINE CubitBoolean TetFacetorTool<TET, SUBTET, NODE>:: |
Definition at line 60 of file TetFacetorTool.cpp.
| #define TET_FACETOR_TOOL__D template<class TET, class SUBTET, class NODE> MY_INLINE double TetFacetorTool<TET, SUBTET, NODE>:: |
Definition at line 59 of file TetFacetorTool.cpp.
| #define TET_FACETOR_TOOL__I template<class TET, class SUBTET, class NODE> MY_INLINE int TetFacetorTool<TET, SUBTET, NODE>:: |
Definition at line 57 of file TetFacetorTool.cpp.
| #define TET_FACETOR_TOOL__T template<class TET, class SUBTET, class NODE> MY_INLINE TET *TetFacetorTool<TET, SUBTET, NODE>:: |
Definition at line 61 of file TetFacetorTool.cpp.
| #define TET_FACETOR_TOOL__V template<class TET, class SUBTET, class NODE> MY_INLINE void TetFacetorTool<TET, SUBTET, NODE>:: |
Definition at line 58 of file TetFacetorTool.cpp.
| TET_FACETOR_TOOL__I circumsphere | ( | TET * | tet_ptr, |
| CubitVector & | center, | ||
| double & | radius_squared | ||
Definition at line 1052 of file TetFacetorTool.cpp.
ToolData *td = tet_ptr->get_TD( TDDelaunay< TET, NODE >::is_delaunay );
TDDelaunay< TET, NODE > *td_del = dynamic_cast<TDDelaunay< TET, NODE >*> (td);
if(td_del == NULL) {
td_del = new TDDelaunay<TET, NODE>();
tet_ptr->add_TD( td_del );
return td_del->circumsphere( tet_ptr, center, radius_squared );
Definition at line 289 of file TetFacetorTool.cpp.
// use the class global bBox as the bounds of the initial tets
CubitVector maxbox, minbox;
maxbox = bBox.maximum();
minbox = bBox.minimum();
// Initialize the class global vars
lastTet = NULL;
tetVisited = CUBIT_INT_MIN;
// For tolerance, find a representative (non-zero) number from
// the nodes to determine relative magnitude of numbers. Take the
// log of this number, subtract 6 from it, then use this number
// as the exponent (likely a negative number) for the tolerance
double tol = CUBIT_MAX(fabs(maxbox.x()),fabs(maxbox.y()));
tol = CUBIT_MAX(tol,fabs(maxbox.z()));
double temp = CUBIT_MAX(fabs(minbox.x()),fabs(minbox.y()));
temp = CUBIT_MAX(temp,fabs(minbox.z()));
tol = CUBIT_MAX(tol,temp);
tol = pow(10.0, (double)(log10(tol) - 6.0));
csTol = tol * tol;
// create the bounding box nodes
CubitVector coor;
int ii;
for (ii=0; ii<8; ii++)
switch (ii) {
case 0: coor.set(minbox.x(), minbox.y(), minbox.z()); break;
case 1: coor.set(maxbox.x(), minbox.y(), minbox.z()); break;
case 2: coor.set(maxbox.x(), maxbox.y(), minbox.z()); break;
case 3: coor.set(minbox.x(), maxbox.y(), minbox.z()); break;
case 4: coor.set(minbox.x(), minbox.y(), maxbox.z()); break;
case 5: coor.set(maxbox.x(), minbox.y(), maxbox.z()); break;
case 6: coor.set(maxbox.x(), maxbox.y(), maxbox.z()); break;
case 7: coor.set(minbox.x(), maxbox.y(), maxbox.z()); break;
boxNodes[ii] = new NODE(coor);
// create 5 tets to fill the box
const int itet_config[5][4] = {{0,1,3,4},{1,2,3,6},{1,5,6,4},
{3,7,4,6},{1,6,3,4}};
NODE *tet_nodes[4];
TET *new_tet;
int jj;
for (ii=0; ii<5; ii++)
for (jj=0; jj<4; jj++)
tet_nodes[jj] = boxNodes[itet_config[ii][jj]];
new_tet = new SUBTET( tet_nodes );
tet_nodes[jj]->add_element(new_tet);
tetList.push_back( new_tet );
return CUBIT_SUCCESS;
| TET_FACETOR_TOOL__I exhaustive_locate_point | ( | CubitVector & | xx, |
| NODE *& | exact_node, | ||
| TET *& | containing_tet | ||
Definition at line 868 of file TetFacetorTool.cpp.
// Use the last tet to be located as the first try. If there is
// no last tet, then use one tet on the global list
exact_node = NULL;
containing_tet = NULL;
TET *cur_tet;
double tol = GEOMETRY_RESABS;
NODE *na, *nb, *nc, *nd;
CubitVector A, B, C, D;
double volcoord_A, volcoord_B, volcoord_C, volcoord_D, vol;
CubitBoolean found = CUBIT_FALSE;
for (size_t ii=0; ii<tetList.size() && !found; ii++)
cur_tet = tetList[ii];
// Don't chak tets we have already chaked. tetVisited should be
// current (was set in locate_point)
if (tet_visited(cur_tet) == tetVisited)
continue;
set_tet_visited( cur_tet, tetVisited );
// Get the coords of the nodes on the tet and compute the
// barycentric coords (areacoords) of the point with respect
// to the tet. If all area coords are positive, then
// the point is inside the tet. If any are negative
// then choose the next try as the adjacent tet to
// the area coord that was the smallest
cur_tet->tet_nodes( na, nb, nc, nd );
A = na->coordinates();
B = nb->coordinates();
C = nc->coordinates();
D = nd->coordinates();
volcoord_A = tet_volume(B, C, D, xx);
volcoord_B = tet_volume(A, D, C, xx);
volcoord_C = tet_volume(A, B, D, xx);
volcoord_D = tet_volume(A, C, B, xx);
vol = tet_volume(A, C, B, D);
// normalize coords
//vol = volcoord_A + volcoord_B + volcoord_C + volcoord_D;
if (fabs(vol) > CUBIT_RESABS)
volcoord_A /= vol;
volcoord_B /= vol;
volcoord_C /= vol;
volcoord_D /= vol;
else
tol = csTol;
if (volcoord_A > -tol &&
volcoord_B > -tol &&
volcoord_C > -tol &&
volcoord_D > -tol)
found = TRUE;
// if three of the areacoords are +-tol then we are at an existing node
if (volcoord_B < tol && volcoord_C < tol && volcoord_D < tol)
exact_node = na;
else if (volcoord_A < tol && volcoord_C < tol && volcoord_D < tol)
exact_node = nb;
else if (volcoord_A < tol && volcoord_B < tol && volcoord_D < tol)
exact_node = nc;
else if (volcoord_A < tol && volcoord_B < tol && volcoord_C < tol)
exact_node = nd;
// this is the general case where all areacoords are positive.
// we have located the tet xx is contained in
else
containing_tet = cur_tet;
if (!found)
lastTet = NULL;
return CUBIT_FALSE;
lastTet = containing_tet;
Definition at line 125 of file TetFacetorTool.cpp.
return remove_bbox_tets();
| TET_FACETOR_TOOL__I get_interior_tets | ( | std::vector< TET * > & | tet_list | ) |
Definition at line 166 of file TetFacetorTool.cpp.
size_t ii, jj;
TET *tet_ptr;
NODE *nodes[4];
int found = 0;
for (ii=0; ii<tetList.size(); ii++)
tet_ptr = tetList.get_and_step();
tet_ptr->tet_nodes(nodes[0], nodes[1], nodes[2], nodes[3]);
found = 0;
for(jj=0; jj<4 && !found; jj++)
if (is_bbox(nodes[jj]))
found = 1;
if (!found)
tet_list.push_back(tet_ptr);
return tet_list.size();
Definition at line 150 of file TetFacetorTool.cpp.
NODE *node = boxNodes[0];
std::vector<TET *> *tet_list_ptr = node->tet_list();
assert(tet_list_ptr != NULL && tet_list_ptr->size() > 0);
tet_list_ptr->reset();
return tet_list_ptr->get();
| TET_FACETOR_TOOL__I get_tets | ( | std::vector< TET * > & | tet_list | ) |
Definition at line 137 of file TetFacetorTool.cpp.
tet_list += tetList;
| TET_FACETOR_TOOL__I init_box | ( | std::vector< NODE * > & | node_list | ) |
Definition at line 241 of file TetFacetorTool.cpp.
CubitVector minbox(CUBIT_DBL_MAX, CUBIT_DBL_MAX, CUBIT_DBL_MAX);
CubitVector maxbox(-CUBIT_DBL_MAX, -CUBIT_DBL_MAX, -CUBIT_DBL_MAX);
// loop through nodes to set bounding box
CubitVector coor;
NODE *node_ptr;
unsigned int ii;
for (ii=0; ii<node_list.size(); ii++)
node_ptr = node_list[ii];
coor = node_ptr->coordinates();
if (coor.x() > maxbox.x()) maxbox.x( coor.x() );
if (coor.x() < minbox.x()) minbox.x( coor.x() );
if (coor.y() > maxbox.y()) maxbox.y( coor.y() );
if (coor.y() < minbox.y()) minbox.y( coor.y() );
if (coor.z() > maxbox.z()) maxbox.z( coor.z() );
if (coor.z() < minbox.z()) minbox.z( coor.z() );
// Expand the bounding box by 20% of the size of the diagonal
double dx = maxbox.x() - minbox.x();
double dy = maxbox.y() - minbox.y();
double dz = maxbox.z() - minbox.z();
double expand = 0.2 * sqrt(SQR(dx) + SQR(dy) + SQR(dz));
minbox.x( minbox.x() - expand );
minbox.y( minbox.y() - expand );
minbox.z( minbox.z() - expand );
maxbox.x( maxbox.x() + expand );
maxbox.y( maxbox.y() + expand );
maxbox.z( maxbox.z() + expand );
bBox.reset( minbox, maxbox );
return create_bbox_tets();
| TET_FACETOR_TOOL__I initialize | ( | CubitBox & | bounding_box | ) |
Definition at line 111 of file TetFacetorTool.cpp.
bBox = bounding_box;
| TET_FACETOR_TOOL__I insert_nodes | ( | std::vector< NODE * > & | node_list | ) |
Definition at line 424 of file TetFacetorTool.cpp.
unsigned int ii;
NODE *node_ptr;
int num_failed = 0;
if(insert_one_node( node_ptr ) == CUBIT_FAILURE)
num_failed++;
// If any failed to insert the first time, then try them again
if (num_failed > 0)
num_failed = 0;
if (node_ptr->number_tets() == 0)
num_failed++;
return num_failed;
| TET_FACETOR_TOOL__I insert_one_node | ( | NODE * | node_ptr | ) |
Definition at line 468 of file TetFacetorTool.cpp.
// Get all tets whose circumsphere contain the point
CubitVector xx = node_ptr->coordinates();
std::vector<TET *> neighbor_tet_list;
NODE *duplicate_node = NULL;
int stat = natural_neighbor_tets( xx, neighbor_tet_list, duplicate_node );
if (stat != CUBIT_SUCCESS)
return stat;
// If this new node fell exactly on top of an existing node, then
// ignore it
if (duplicate_node != NULL)
PRINT_WARNING("Duplicate node detected in Delaunay insertion at (%f %f %f).\n"
" Ignoring node and continuing.\n", xx.x(), xx.y(), xx.z());
// insert the node using the bowyer-watson algorithm
stat = watson_insert( node_ptr, neighbor_tet_list );
return stat;
| TET_FACETOR_TOOL__I is_bbox | ( | NODE * | n | ) |
Definition at line 407 of file TetFacetorTool.cpp.
int ii;
for(ii=0; ii<8; ii++)
if(n == boxNodes[ii])
return 1;
return 0;
| TET_FACETOR_TOOL__I locate_point | ( | CubitVector & | xx, |
Definition at line 717 of file TetFacetorTool.cpp.
exact_node = NULL;
TET *cur_tet = lastTet;
if (cur_tet == NULL)
cur_tet = tetList[0];
// keep track of the tets we visit by marking as we go -
// increment the visit flag for this call
tetVisited++;
TET *adj_tet = NULL;
while (!found)
// check for inverted tet
assert (vol > 0.0);
// normalize coords
volcoord_A /= vol;
volcoord_B /= vol;
volcoord_C /= vol;
volcoord_D /= vol;
else
tol = csTol;
volcoord_D > -tol)
found = TRUE;
exact_node = na;
exact_node = nb;
exact_node = nc;
exact_node = nd;
else
// at least one of the areacoords is negative. Advance to the next adjacent
// tet. Choose the adjacent tet based on the sign of the areacoords
else
if (volcoord_A <= volcoord_B &&
volcoord_A <= volcoord_C &&
volcoord_A <= volcoord_D)
adj_tet = (TET *)cur_tet->get_connected_tet( nb, nc, nd );
else if (volcoord_B <= volcoord_A &&
volcoord_B <= volcoord_C &&
volcoord_B <= volcoord_D)
adj_tet = (TET *)cur_tet->get_connected_tet( nd, nc, na );
else if (volcoord_C <= volcoord_A &&
volcoord_C <= volcoord_B &&
volcoord_C <= volcoord_D)
adj_tet = (TET *)cur_tet->get_connected_tet( nd, na, nb );
else
adj_tet = (TET *)cur_tet->get_connected_tet( nc, nb, na );
cur_tet = adj_tet;
// Check if we just left the triangulation or we have already been
// to this tet. If so, use the exhaustive search
if(cur_tet == NULL || tet_visited( cur_tet ) == tetVisited)
return exhaustive_locate_point(xx, exact_node, containing_tet);
| TET_FACETOR_TOOL__I natural_neighbor_tets | ( | CubitVector & | xx, |
| std::vector< TET * > & | neighbor_tet_list, | ||
| NODE *& | exact_node | ||
Definition at line 506 of file TetFacetorTool.cpp.
// Determine the tet where the point is located. If its at a node
// return now with success (trivial interpolation case)
TET *containing_tet;
int stat = locate_point( xx, exact_node, containing_tet );
return stat;
if (exact_node != NULL)
// Put the tet that contains the point as the first one on the list
// and mark it as visited
neighbor_tet_list.push_back( containing_tet );
set_tet_visited( containing_tet, ++tetVisited );
// Recursively search, (starting with the tet the point is in)
// search for all tets whose circumsphere contain the point and place
// on the neighbor_tet_list
int iface;
containing_tet->tet_nodes(na, nb, nc, nd);
for (iface=0; iface<4; iface++)
switch(iface)
case 0: adj_tet = (TET *)containing_tet->get_connected_tet( nb, nc, nd ); break;
case 1: adj_tet = (TET *)containing_tet->get_connected_tet( nd, nc, na ); break;
case 2: adj_tet = (TET *)containing_tet->get_connected_tet( nd, na, nb ); break;
case 3: adj_tet = (TET *)containing_tet->get_connected_tet( nc, nb, na ); break;
if (adj_tet != NULL)
if (tet_visited(adj_tet) != tetVisited)
point_in_circumsphere( adj_tet, xx, neighbor_tet_list );
| TET_FACETOR_TOOL__B point_in_circumsphere | ( | TET * | tet_ptr, |
| CubitVector & | xx, | ||
| std::vector< TET * > & | neighbor_tet_list | ||
Definition at line 981 of file TetFacetorTool.cpp.
// The circumsphere of the face has been previously stored with the
// face. Determine distance squared from center of circle to point
set_tet_visited(tet_ptr, tetVisited);
double radsq;
CubitVector cc;
circumsphere(tet_ptr, cc, radsq);
double dist2 = (SQR(xx.x()-cc.x()) +
SQR(xx.y()-cc.y()) +
SQR(xx.z()-cc.z())) - radsq;
CubitBoolean inside_csph;
if (dist2 > csTol)
inside_csph = CUBIT_FALSE;
else if (dist2 < -csTol)
inside_csph = CUBIT_TRUE;
else
inside_csph = CUBIT_TRUE; // (numerically on the sphere)
if (inside_csph)
// add it to the list and go check its neighbors
neighbor_tet_list.push_back(tet_ptr);
int iface;
tet_ptr->tet_nodes( na, nb, nc, nd );
switch(iface)
case 0: adj_tet = (TET *)tet_ptr->get_connected_tet( nb, nc, nd ); break;
case 1: adj_tet = (TET *)tet_ptr->get_connected_tet( nd, nc, na ); break;
case 2: adj_tet = (TET *)tet_ptr->get_connected_tet( nd, na, nb ); break;
case 3: adj_tet = (TET *)tet_ptr->get_connected_tet( nc, nb, na ); break;
return inside_csph;
| TET_FACETOR_TOOL__I read_data | ( | const char * | filename, |
| std::vector< NODE * > & | node_list | ||
Definition at line 1141 of file TetFacetorTool.cpp.
// open the file
FILE *fp = fopen(filename, "r");
if (fp == NULL)
PRINT_ERROR("Could not open file %s for reading\n", filename);
return CUBIT_FAILURE;
PRINT_INFO("Reading data...\n");
// read the number of nodes
int iline = 1;
char line[128];
if (fgets(line, 128, fp) == NULL)
PRINT_ERROR("Format error in facet file %s on line %d\n", filename, iline);
fclose(fp);
int nnodes = 0;
int n = sscanf(line, "%d", &nnodes);
if (n != 1)
PRINT_ERROR("Format error in data file %s on line %d\n", filename, iline);
fclose(fp);
if (nnodes <= 0)
PRINT_ERROR("Expecting number of nodes in data file %s on line %d\n", filename, iline);
fclose(fp);
// read the nodes
int ii;
double xx, yy, zz, data;
NODE *new_node;
for (ii=0; ii<nnodes; ii++)
iline++;
if (fgets(line, 128, fp)== NULL)
fclose(fp);
n = sscanf(line, "%lf %lf %lf %lf", &xx, &yy, &zz, &data );
if (n < 3 || n > 4)
PRINT_INFO(" Expecting 3 doubles and an optional data value, but instead read %d values\n", n);
fclose(fp);
CubitVector pt( xx, yy, zz );
new_node = (NODE *) new NODE( pt );
node_list.push_back( new_node );
if (n==4)
TDInterpNode *td_interp = new TDInterpNode(data);
new_node->add_TD( td_interp );
fclose(fp);
Definition at line 364 of file TetFacetorTool.cpp.
int stat = CUBIT_SUCCESS;
int found;
TET *tet_ptr;
unsigned int ii, jj, kk;
NODE *nodes[4];
found = 0;
tet_ptr = tetList[ii];
found = 1;
for(kk=0; kk<4; kk++)
nodes[kk]->remove_element(tet_ptr);
tetList[ii] = NULL;
delete tet_ptr;
tet_ptr = NULL;
tetList.erase(std::remove(tetList.begin(), tetList.end(), tet_ptr), tetList.end());
delete boxNodes[ii];
return stat;
| TET_FACETOR_TOOL__V set_tet_visited | ( | TET * | tet_ptr, |
| int | new_visit_flag | ||
Definition at line 1071 of file TetFacetorTool.cpp.
td_del->visit_flag( new_visit_flag );
| TET_FACETOR_TOOL__I tesselate | ( | std::vector< NODE * > & | node_list, |
| std::vector< TET * > & | tet_list | ||
Definition at line 199 of file TetFacetorTool.cpp.
int stat;
// create a set of tets in a bounding box to start
stat = init_box( node_list );
// insert all the nodes
if (stat == CUBIT_SUCCESS)
int num_failed = insert_nodes( node_list );
stat = (num_failed==0) ? CUBIT_SUCCESS : CUBIT_FAILURE;
// remove the nodes at the bounding box.
// this should give you a convex hull of the points (provided your points
// are dense enough)
stat = remove_bbox_tets();
// copy the local list to the tet_list argument to pass back
for (unsigned int ii=0; ii<tetList.size(); ii++)
tet_list.push_back(tetList[ii]);
return stat;
| TET_FACETOR_TOOL__I tet_visited | ( | TET * | tet_ptr | ) |
Definition at line 1090 of file TetFacetorTool.cpp.
if (td == NULL)
return CUBIT_INT_MIN;
if(td_del == NULL)
return td_del->visit_flag();
| TET_FACETOR_TOOL__D tet_volume | ( | const CubitVector & | a, |
| const CubitVector & | b, | ||
| const CubitVector & | c, | ||
| const CubitVector & | d | ||
Definition at line 1120 of file TetFacetorTool.cpp.
Definition at line 82 of file TetFacetorTool.cpp.
//update private variables
mDebug = 1;
| TET_FACETOR_TOOL__I watson_insert | ( | NODE * | node_ptr, |
Definition at line 562 of file TetFacetorTool.cpp.
TET *tet_ptr;
unsigned int ii,jj;
// mark all the tets in the list
tetVisited++;
for (ii=0; ii<neighbor_tet_list.size(); ii++)
set_tet_visited(neighbor_tet_list[ii], tetVisited);
// Go through the neighbor tets and find the faces that are not
// adjacent to any other tet in the neighbor list. These faces
// will serve as base facets for new tets
std::vector<TET *> new_tet_list;
CubitVector cc;
double radsq;
TET *adj_tet = NULL, *new_tet = NULL;
std::vector<NODE *> cavity_nodes;
NODE *nodes[4];
size_t itet, iface;
size_t ntet = 0;
// form the list of boundary faces of the cavity
for (itet=0; itet<neighbor_tet_list.size(); itet++)
tet_ptr = neighbor_tet_list[itet];
tet_ptr->tet_nodes(na, nb, nc, nd);
switch(iface)
if (adj_tet == NULL || tet_visited(adj_tet) != tetVisited)
switch(iface)
case 0:
cavity_nodes.push_back(nb);
cavity_nodes.push_back(nd);
cavity_nodes.push_back(nc);
break;
case 1:
cavity_nodes.push_back(na);
break;
case 2:
break;
case 3:
break;
ntet++;
for (itet=0; itet<ntet; itet++)
// form a new tet with this face and the node
nodes[0] = cavity_nodes[itet*3];
nodes[1] = cavity_nodes[itet*3+1];
nodes[2] = cavity_nodes[itet*3+2];
nodes[3] = node_ptr;
// check volume of this new tet - if its less than zero then the cavity is
// not strictly star-shaped. fail the insertion, delete any new tets already
// created and return now.
double vol = tet_volume(nodes[0]->coordinates(),
nodes[2]->coordinates(),
nodes[1]->coordinates(),
nodes[3]->coordinates());
if (vol < 0.0)
for (ii=0; ii<new_tet_list.size(); ii++)
tet_ptr = new_tet_list[ii];
for(jj=0; jj<4; jj++)
nodes[jj]->remove_element(tet_ptr);
delete tet_ptr;
new_tet = new SUBTET(nodes);
for (ii=0; ii<4; ii++)
nodes[ii]->add_element(new_tet);
new_tet_list.push_back(new_tet);
// define the circumsphere. If it fails, then fail this
// insertion, delete any tets already created and return now.
if (circumsphere(new_tet, cc, radsq) == CUBIT_FAILURE)
delete tet_ptr;
set_tet_visited(new_tet, tetVisited);
// Set last face for Locate Point
if (new_tet != NULL)
lastTet = new_tet;
// Delete all tets in the neighbor tet list
tetList.erase(std::find(tetList.begin(), tetList.end(), tet_ptr));
delete tet_ptr;
tetList.push_back( new_tet_list[ii] );
Definition at line 97 of file TetFacetorTool.cpp.
