cgma
#include "PartitionEngine.hpp"#include "CompositeEngine.hpp"#include "SubCurve.hpp"#include "SubSurface.hpp"#include "SegmentedCurve.hpp"#include "PartitionPoint.hpp"#include "PartitionCoEdge.hpp"#include "PartitionLoop.hpp"#include "PartitionSurface.hpp"#include "PartitionLump.hpp"#include "PartitionBody.hpp"#include "PartPTCurve.hpp"#include "PartitionShell.hpp"#include "BodySM.hpp"#include "GMem.hpp"#include "GeometryQueryEngine.hpp"#include "GeometryModifyEngine.hpp"#include "GeometryModifyTool.hpp"#include "VGLoopTool.hpp"#include "FacetProjectTool.hpp"#include "CubitFacetData.hpp"#include "CubitFacetEdgeData.hpp"#include "CubitPointData.hpp"#include "TDVGFacetOwner.hpp"#include "TDVGFacetSplit.hpp"#include "FacetEvalTool.hpp"#include "FacetDataUtil.hpp"#include "PartSurfFacetTool.hpp"#include "PartitionTool.hpp"#include "CompositeSurface.hpp"#include "CompositePoint.hpp"#include "CompositeCurve.hpp"#include "PartitionLumpImprint.hpp"#include "GfxDebug.hpp"#include "BridgeManager.hpp"#include "CADefines.hpp"#include <set>#include "GeometryQueryTool.hpp"#include "CubitTransformMatrix.hpp"#include "CubitObservable.hpp"#include "AppUtil.hpp"#include "GeometryEvent.hpp"Go to the source code of this file.
Functions | |
| static CubitStatus | get_edge_replacements (std::vector< CubitFacetData * > &facet_list, std::vector< CubitFacetEdgeData * > replacement_edges[3]) |
| static CubitFacetData * | find_facet (CubitFacetEdge *edge, bool sense, PartitionEntity *owner) |
| static CubitFacetData * | find_facet (CubitPoint *pt, PartitionEntity *owner) |
| static CubitFacetData * | other_facet (CubitFacetData *facet, int edge, PartitionEntity *owner) |
Variables | |
| const char *const | PARTITION_GEOM_ATTRIB_NAME = "PARTITION_GEOM" |
| static CubitFacetData* find_facet | ( | CubitFacetEdge * | edge, |
| bool | sense, | ||
| PartitionEntity * | owner | ||
| ) | [static] |
Definition at line 1762 of file PartitionEngine.cpp.
DLIList<CubitFacet*> facets(2);
edge->facets(facets);
facets.reset();
for ( int i = facets.size(); i--; ) {
CubitFacet* facet = facets.get();
int edge_index = facet->edge_index(edge);
assert(edge_index >= 0);
bool forward = edge->point(0) == facet->point((edge_index+1)%3);
if ( forward != sense || TDVGFacetOwner::get(facet) != owner )
facets.extract();
else
facets.step();
return facets.size() == 1 ? dynamic_cast<CubitFacetData*>(facets.get()) : 0;
| static CubitFacetData* find_facet | ( | CubitPoint * | pt, |
| ) | [static] |
Definition at line 1793 of file PartitionEngine.cpp.
DLIList<CubitFacet*> facets;
pt->facets(facets);
facets.reset();
if ( TDVGFacetOwner::get(facets.get()) == owner )
facets.step();
else
facets.extract();
| static CubitStatus get_edge_replacements | ( | std::vector< CubitFacetData * > & | facet_list, |
| std::vector< CubitFacetEdgeData * > | replacement_edges[3] | ||
| ) | [static] |
Definition at line 5875 of file PartitionEngine.cpp.
// first facet is the facet to replace
// make sure more than one facet to replace the first
assert(facet_list.size() > 2);
// make sure the lists of replacement edges are empty
assert(replace_edge_lists[0].size() == 0);
assert(replace_edge_lists[1].size() == 0);
assert(replace_edge_lists[2].size() == 0);
CubitFacetData* p_dead = facet_list[0]; // facet to be replaced
// look for edges on the facet that are owned by curves
int i;
//int replace_edge = 0;
// get the edges
CubitFacetEdgeData *edges[3];
for (i=0; i<3; i++)
edges[i] = CAST_TO(p_dead->edge(i), CubitFacetEdgeData);
assert(edges[i] != NULL);
PartitionEntity *p_owner;
PartitionCurve *p_curve;
// see if any are owned by a curve
CubitBoolean b_boundary = CUBIT_FALSE;
for (i=0; i<3 && !b_boundary; i++)
p_owner = TDVGFacetOwner::get(edges[i]);
p_curve = CAST_TO(p_owner, PartitionCurve);
if (p_curve)
b_boundary = CUBIT_TRUE;
// if the facet has an edge on a curve, replace the edge with the edges of the
// replacement facets and split the facet on the adjacent surface.
if (b_boundary)
// make a list with just the new facets -- skip the first facet
DLIList<CubitFacet*> new_facets(facet_list.size() - 1);
for (unsigned u = 1; u < facet_list.size(); u++)
new_facets.append(facet_list[u]);
// get a point edge chain around the boundary of the replacement facets
DLIList<FacetEntity*> point_edge_chain;
FacetDataUtil::ordered_point_edge_bdry(new_facets, point_edge_chain);
// for each edge on a curve get corresponding points and edges from the
//std::vector<CubitFacetEdgeData*>::iterator eitor;
for (i=0; i<3; i++)
if (p_curve)
// fill the replacement list for this edge
// add the edge to be replaced first
//eitor = replace_edge_lists[i].begin();
// get the points from the edge of the dead facet - in the correct order
CubitPoint* pt1;
CubitPoint* pt2;
p_dead->get_edge_pts(i, pt1, pt2);
// get the corresponding chain of points and edges from the replacement facets
DLIList<FacetEntity*> replacement_chain;
CubitStatus res = FacetDataUtil::partial_chain(point_edge_chain,
pt1, pt2, replacement_chain);
if (CUBIT_FAILURE == res)
return CUBIT_FAILURE;
// there should be an odd number of list entries, since it includes points
// and edges, beginning and ending with a point
assert( (replacement_chain.size() % 2) == 1 );
// if only one replacement edge, it should be the same edge
replacement_chain.reset();
if (replacement_chain.size() == 3)
assert(replacement_chain.next(1) == edges[i]);
else
// add the replacement edges to the list - edge to replace first
//*eitor++ = edges[i];
replace_edge_lists[i].push_back(edges[i]);
int j;
CubitFacetEdgeData* p_edge;
for (j=1; j<replacement_chain.size(); j+=2)
//replacement_chain.step();
p_edge = CAST_TO(replacement_chain.next(j), CubitFacetEdgeData);
assert(p_edge != NULL);
//*eitor++ = p_edge;
replace_edge_lists[i].push_back(p_edge);
return CUBIT_SUCCESS;
| static CubitFacetData* other_facet | ( | CubitFacetData * | facet, |
| int | edge, | ||
| ) | [static] |
Definition at line 1819 of file PartitionEngine.cpp.
facet->shared_facets( facet->point((edge+1)%3),
facet->point((edge+2)%3),
facets );
if( TDVGFacetOwner::get(facet) != owner )
facets.extract();
else
facets.step();
| const char* const PARTITION_GEOM_ATTRIB_NAME = "PARTITION_GEOM" |
Definition at line 65 of file PartitionEngine.cpp.
