cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CompositeCurve.hpp 00003 // 00004 // Purpose : Geometry defined as the joining of a chain of curves. 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 12/19/01 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef COMPOSITE_CURVE_HPP 00014 #define COMPOSITE_CURVE_HPP 00015 00016 #include "VGDefines.h" 00017 #include "Curve.hpp" 00018 #include "CompositeGeom.hpp" 00019 #include "HiddenEntitySet.hpp" 00020 #include "CompositeCoEdge.hpp" 00021 00022 class CompositeSurface; 00023 class CompositePoint; 00024 class TBPoint; 00025 00026 class CompositeCurve : public Curve, public TBOwner 00027 { 00028 00029 public: 00030 00031 int HadBridgeRemoved; 00032 //CompositeCurve( DLIList<Curve*>& curve_list, bool periodic ); 00033 //CompositeCurve( ); 00034 CompositeCurve( Curve* curve ); 00035 CompositeCurve( CompositeGeom* geometry ); 00036 CompositeCurve( CompositePoint* point ); // create point-curve 00037 00038 virtual ~CompositeCurve(); 00039 00040 inline Curve* get_curve( int index ) const; 00041 inline CubitSense get_sense( int index ) const; 00042 inline int num_curves( ) const; 00043 inline int index_of( Curve* curve_ptr ) const; 00044 inline void update(); 00045 Curve* remove_curve( int index ); 00046 00047 /* 00048 inline CubitStatus append_curve( Curve* curve_ptr ); 00049 inline CubitStatus prepend_curve( Curve* curve_ptr ); 00050 CubitStatus insert_curve( Curve* curve_ptr, int index ); 00051 Curve* remove_curve( Curve* curve_ptr ); 00052 Curve* remove_curve( int index ); 00053 */ 00054 CompositeCurve* split( Curve* curve_ptr ); 00055 CubitStatus combine( CompositeCurve* curve_ptr, bool prepend ); 00056 void reverse(); 00057 00058 CompositeCoEdge* first_coedge() const; 00059 CompositeCoEdge* next_coedge( CompositeCoEdge* after_this ) const; 00060 CubitStatus add( CompositeCoEdge* coedge ); 00061 CubitStatus remove( CompositeCoEdge* coedge ); 00062 00063 CompositePoint* start_point() const; 00064 CompositePoint* end_point() const; 00065 CubitStatus start_point( CompositePoint* pt ); 00066 CubitStatus end_point( CompositePoint* pt ); 00067 CompositePoint* other_point( CompositePoint* pt ); 00068 CompositePoint* common_point( CompositeCurve* curve ); 00069 CompositeCurve* next( const CompositePoint* around_this ); 00070 00071 HiddenEntitySet& hidden_entities(); 00072 void get_hidden_points( DLIList<TBPoint*>& points ); 00073 00074 bool has_parent_composite_surface() const; 00075 00076 /**************** Methods from TopologyBridge *******************/ 00077 00078 void append_simple_attribute_virt( const CubitSimpleAttrib& csa ); 00079 void remove_simple_attribute_virt(const CubitSimpleAttrib& csa ); 00080 void remove_all_simple_attribute_virt(); 00081 CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>& csa_list ); 00082 CubitStatus get_simple_attribute( const CubitString& name, 00083 DLIList<CubitSimpleAttrib>& attrib_list ); 00084 GeometryQueryEngine* get_geometry_query_engine() const; 00085 00086 void get_parents_virt( DLIList<TopologyBridge*>& parents ); 00087 void get_children_virt( DLIList<TopologyBridge*>& children ); 00088 int layer() const { return COMPOSITE_LAYER; } 00089 00090 /******************** Methods from TBOwner **********************/ 00091 00092 CubitStatus remove_bridge( TopologyBridge* bridge ); 00093 CubitStatus swap_bridge( TopologyBridge* old, 00094 TopologyBridge* neww, 00095 bool reversed ); 00096 CubitBoolean contains_bridge( TopologyBridge* bridge ) const; 00097 void notify_reversed( TopologyBridge* bridge ); 00098 void notify_split( TopologyBridge* new_bridge, TopologyBridge* split_from ); 00099 // void notify_joined( TopologyBridge* dead, TopologyBridge* keep ); 00100 00101 /**************** Methods from GeometryEntity *******************/ 00102 00103 CubitBox bounding_box() const; 00104 double measure( ) ; 00105 GeometryType geometry_type(); 00106 00107 00108 /******************** Methods from Curve ***********************/ 00109 00110 CubitBoolean get_param_range( double& lower, double& upper ); 00111 CubitBoolean is_periodic( double& period); 00112 double start_param(); 00113 double end_param(); 00114 00115 CubitStatus position_from_u( double u_value, CubitVector& pos ); 00116 double u_from_position (const CubitVector& input_position); 00117 00118 double length_from_u( double parameter1, double parameter2 ); 00119 double u_from_arc_length ( double root_param, double arc_length ); 00120 00121 CubitStatus closest_point( CubitVector const& location, 00122 CubitVector& closest_location, 00123 CubitVector* tangent_ptr = NULL, 00124 CubitVector* curvature_ptr = NULL, 00125 double *param = NULL); 00126 00127 CubitStatus closest_point_trimmed( CubitVector const& from_pt, 00128 CubitVector& result_pt ); 00129 00130 CubitBoolean is_position_on( const CubitVector &test_position ); 00131 CubitPointContainment point_containment( const CubitVector &point ); 00132 00133 CubitStatus get_point_direction( CubitVector& origin, 00134 CubitVector& direction ); 00135 00136 CubitStatus get_interior_extrema( 00137 DLIList<CubitVector*>& interior_points, 00138 CubitSense& return_sense); 00139 00140 CubitStatus get_center_radius( CubitVector& c, double& r ); 00141 00142 CubitBoolean G1_discontinuous( double param, 00143 CubitVector* minus_tangent = NULL, 00144 CubitVector* plus_tangent = NULL ); 00145 00146 00147 void print_debug_info( const char* prefix = 0, bool brief = false ) const; 00148 00149 CubitStatus stitch( CompositeCurve* merge_with ); 00150 void unstitch_all(); 00151 CompositeCurve* primary_stitched_curve(); 00152 bool is_stitched(); 00153 void get_stitched( DLIList<CompositeCurve*>& list ); 00154 00155 CubitStatus curve_param( double u_composite, double& u_curve, int& index ) const; 00156 double composite_param( int index, double param ) const; 00157 00158 //void draw( int color ); 00159 00160 void read_attributes() ; //{ compGeom->read_attributes(); } 00161 void write_attributes() ; //{ compGeom->write_attributes(); } 00162 00163 //R CubitStatus 00164 //O- true or false if spline is rational or not. 00165 //O- the degree of this spline 00166 //O- the control points 00167 //O- If rational, weight for each control point 00168 //O- whether underlying spline is reversed 00169 virtual CubitStatus get_spline_params( bool &rational, 00170 int °ree, 00171 DLIList<CubitVector> &cntrl_pts, 00172 DLIList<double> &cntrl_pt_weights, 00173 DLIList<double> &knots, 00174 bool &spline_is_reversed 00175 ) const; 00176 //R CubitStatus 00177 //O- center - ellipse center point 00178 //O- normal - normal of the plane of the ellipse 00179 //O- major_axis - major axis of the ellipse 00180 //O- radius_ratio - ratio of the length of the major to minor axis. 00181 virtual CubitStatus get_ellipse_params( CubitVector ¢er, 00182 CubitVector &normal, 00183 CubitVector &major_axis, 00184 double &radius_ratio ) const; 00185 00186 protected: 00187 00188 CompositeCurve(); 00189 00190 int closest_curve( CubitVector const& location, 00191 CubitVector *point = NULL ); 00192 //R int 00193 //R- The index of the closest curve 00194 //I location 00195 //I- A position for which the closest curve is desired. 00196 //O point 00197 //O- The closest point on the curve 00198 //- This function finds the closest underlying Curve of this 00199 //- CompositeCurve to a given point 00200 00201 double lengthUntilI( int index ) const; 00202 00203 void fixup_periodic_param( double& u ) const; 00204 00205 CubitStatus set_point( bool set_start_point, CompositePoint* point ); 00206 00207 private: 00208 00209 // these have no implementation, just private delcarations 00210 // to prevent the compiler from generating default implementations 00211 CompositeCurve& operator=(const CompositeCurve&); 00212 CompositeCurve(const CompositeCurve&); 00213 00214 CompositeGeom* compGeom; 00215 00216 HiddenEntitySet* hiddenSet; 00217 00218 CompositeCoEdge* firstCoEdge; 00219 00220 CompositePoint* startPoint; 00221 CompositePoint* endPoint; 00222 00223 CompositeCurve* startNext; 00224 CompositeCurve* endNext; 00225 00226 CompositeCurve* stitchNext; 00227 }; 00228 00229 inline Curve* CompositeCurve::get_curve( int index ) const 00230 { return dynamic_cast<Curve*>(compGeom->entity(index)); } 00231 00232 inline CubitSense CompositeCurve::get_sense( int index ) const 00233 { return compGeom->sense( index ); } 00234 00235 inline int CompositeCurve::num_curves( ) const 00236 { return compGeom->num_entities(); } 00237 00238 inline int CompositeCurve::index_of( Curve* curve ) const 00239 { return compGeom->index_of( curve ); } 00240 00241 inline void CompositeCurve::update() 00242 { compGeom->update_cached_data();} 00243 00244 /* 00245 inline CubitStatus CompositeCurve::prepend_curve( Curve* curve ) 00246 { return insert_curve( curve, 0 ); } 00247 00248 inline CubitStatus CompositeCurve::append_curve( Curve* curve ) 00249 { return insert_curve( curve, num_curves() ); } 00250 */ 00251 inline CompositeCoEdge* CompositeCurve::first_coedge( ) const 00252 { return firstCoEdge; } 00253 00254 inline CompositeCoEdge* CompositeCurve::next_coedge( CompositeCoEdge* coedge ) const 00255 { return !coedge ? firstCoEdge : coedge->myCurve == this ? coedge->nextOnCurve : 0; } 00256 00257 inline CompositePoint* CompositeCurve::start_point() const 00258 { return startPoint; } 00259 00260 inline CompositePoint* CompositeCurve::end_point() const 00261 { return endPoint; } 00262 00263 00264 00265 inline HiddenEntitySet& CompositeCurve::hidden_entities() 00266 { if( !hiddenSet ) 00267 hiddenSet = new HiddenEntitySet(this); 00268 return *hiddenSet; 00269 } 00270 00271 00272 #endif
