cgma
#include <CompositeSurface.hpp>
Definition at line 35 of file CompositeSurface.hpp.
| CompositeSurface::CompositeSurface | ( | Surface * | surf_ptr | ) |
Definition at line 43 of file CompositeSurface.cpp.
: HadBridgeRemoved(0), stitchPartner(0), firstCoSurf(0), firstLoop(0), hiddenSet(0), facetTool(0) { assert( surface != NULL ); compGeom = new CompositeGeom(1); compGeom->append( surface, CUBIT_FORWARD ); if( surface->owner() ) surface->owner()->swap_bridge( surface, this, false ); surface->owner(this); }
| CompositeSurface::CompositeSurface | ( | CompositeGeom * | geom_ptr | ) |
Definition at line 54 of file CompositeSurface.cpp.
: HadBridgeRemoved(0), compGeom(geometry), stitchPartner(0), firstCoSurf(0), firstLoop(0), hiddenSet(0), facetTool(0) { assert( geometry != NULL ); for( int i = 0; i < compGeom->num_entities(); i++ ) { GeometryEntity* entity = compGeom->entity(i); assert( !entity->owner() ); entity->owner(this); } }
| CompositeSurface::~CompositeSurface | ( | ) | [virtual] |
Definition at line 83 of file CompositeSurface.cpp.
while( firstCoSurf )
CompositeCoSurf* cosurf = firstCoSurf;
remove( cosurf );
if( cosurf->get_shell() )
cosurf->get_shell()->remove( cosurf );
delete cosurf;
while( firstLoop )
remove( firstLoop );
for( int j = 0; j < num_surfs(); j++ )
if( get_surface(j)->owner() == this )
get_surface(j)->owner(0);
if( stitchPartner )
stitchPartner->stitchPartner = 0;
stitchPartner = 0;
delete hiddenSet;
delete compGeom;
delete facetTool;
hiddenSet = (HiddenEntitySet*)0xbdbdbdbd;
compGeom = (CompositeGeom*)0xbdbdbdbd;
| CompositeSurface::CompositeSurface | ( | const CompositeSurface & | ) | [private] |
| CubitStatus CompositeSurface::add | ( | CompositeLoop * | loop | ) |
Definition at line 123 of file CompositeSurface.cpp.
if( loop->mySurface )
assert(0);
return CUBIT_FAILURE;
loop->mySurface = this;
loop->loopNext = firstLoop;
firstLoop = loop;
return CUBIT_SUCCESS;
| CubitStatus CompositeSurface::add | ( | CompositeCoSurf * | cosurf | ) |
Definition at line 185 of file CompositeSurface.cpp.
if( cosurf->mySurface )
cosurf->mySurface = this;
cosurf->surfaceNext = firstCoSurf;
firstCoSurf = cosurf;
| void CompositeSurface::append_simple_attribute_virt | ( | const CubitSimpleAttrib & | simple_attrib_ptr | ) | [virtual] |
Implements TopologyBridge.
Definition at line 398 of file CompositeSurface.cpp.
if(compGeom)
compGeom->add_attribute( simple_attrib_ptr );
| CubitBox CompositeSurface::bounding_box | ( | void | ) | const [virtual] |
Implements GeometryEntity.
Definition at line 346 of file CompositeSurface.cpp.
return compGeom->bounding_box();
| CubitStatus CompositeSurface::closest_point | ( | CubitVector const & | location, |
| CubitVector * | closest_location = NULL, |
| CubitVector * | unit_normal = NULL, |
| CubitVector * | curvature1 = NULL, |
| CubitVector * | curvature2 = NULL |
| ) | [virtual] |
Implements Surface.
Definition at line 895 of file CompositeSurface.cpp.
if ( num_surfs() == 1 )
return get_surface(0)->closest_point( location, closest_location,
unit_normal,
curvature1, curvature2 );
update_facet_tool();
if ( facetTool )
CubitStatus result = CUBIT_SUCCESS;
CubitVector facet_closest;
// look for multiple surfaces if normal is requested
if (unit_normal)
DLIList<int> index_list;
int num_found = facetTool->closest_index( location, index_list,
&facet_closest );
CubitVector normal(0.0, 0.0, 0.0);
int i;
for (i = 0; i < num_found; i++)
int index = index_list[i];
if(index > -1)
Surface* surf = get_surface(index);
result = surf->closest_point( facet_closest, closest_location,
&normal, curvature1, curvature2 );
if (get_sense(index) == CUBIT_REVERSED)
*unit_normal += (-normal);
else
*unit_normal += normal;
unit_normal->normalize();
else
int index = facetTool->closest_index( location, &facet_closest );
if(index > -1)
result = surf->closest_point( location, closest_location,
unit_normal, curvature1, curvature2 );
// if (unit_normal && get_sense(index) == CUBIT_REVERSED)
// *unit_normal = -*unit_normal;
else
result = CUBIT_FAILURE;
return result;
// this code is never accessed
Surface* surf = NULL;
int index = -1;
double u, v;
result = surf->u_v_from_position( facet_closest, u, v );
if (!result) return CUBIT_FAILURE;
CubitVector surf_closest;
result = surf->closest_point_uv_guess( location, u, v, &surf_closest,
unit_normal );
if (curvature1 || curvature2)
result = surf->closest_point( surf_closest, 0, 0,
if(closest_location)
*closest_location = surf_closest;
double shortest_dist_sqr, current_dist_sqr;
CubitVector closest_point, current_point;
int closest_surf, current_surf;
//initialize CompositeEntity data structures
closest_surf = compGeom->closest_box( location );
closest_trimmed( closest_surf, location, closest_point );
shortest_dist_sqr = (location - closest_point).length_squared();
while( (current_surf = compGeom->next_box_within_dist( shortest_dist_sqr ) ) >= 0 )
closest_trimmed( current_surf, location, current_point );
current_dist_sqr = (location - current_point).length_squared();
if( current_dist_sqr < shortest_dist_sqr )
closest_surf = current_surf;
closest_point = current_point;
shortest_dist_sqr = current_dist_sqr;
if( closest_location ) *closest_location = closest_point;
if( unit_normal || curvature1 || curvature2 )
get_surface( closest_surf )->closest_point( closest_point, NULL,
if( unit_normal && compGeom->sense(closest_surf) == CUBIT_REVERSED )
*unit_normal *= -1;
| CubitStatus CompositeSurface::closest_point_along_vector | ( | CubitVector & | from_point, |
| CubitVector & | along_vector, | ||
| CubitVector & | point_on_surface | ||
| ) | [virtual] |
Implements Surface.
Definition at line 2044 of file CompositeSurface.cpp.
int index = closest_underlying_surface( from_point );
CubitStatus status = get_surface(index)->closest_point_along_vector( from_point, along_vector, point_on_surface );
if( CUBIT_FAILURE == status )
//find the next closest surface and try it
double shortest_dist_sqr = CUBIT_DBL_MAX;
double current_dist_sqr;
CubitVector closest_point;
int closest_surf = 0;
for( int k=0; k<compGeom->num_entities(); k++ )
if( k==index )
continue;
closest_trimmed( k, from_point, closest_point );
current_dist_sqr = (from_point - closest_point).length_squared();
closest_surf = k;
status = get_surface(closest_surf)->closest_point_along_vector( from_point, along_vector, point_on_surface );
return status;
| void CompositeSurface::closest_point_trimmed | ( | CubitVector | from_point, |
| CubitVector & | result | ||
| ) | [virtual] |
Implements Surface.
Definition at line 580 of file CompositeSurface.cpp.
get_surface(index)->closest_point_trimmed( from_point, point_on_surf );
| CubitStatus CompositeSurface::closest_point_uv_guess | ( | CubitVector const & | location, |
| double & | u, | ||
| double & | v, | ||
| CubitVector * | unit_normal = NULL |
| ) | [virtual] |
Implements Surface.
Definition at line 757 of file CompositeSurface.cpp.
if ( num_surfs() == 1)
closest_point_uv_guess(location, u, v, closest_location, unit_normal);
else
return closest_point(location, closest_location, unit_normal);
| CubitStatus CompositeSurface::closest_trimmed | ( | int | underlying_surface, |
| const CubitVector & | position, | ||
| ) | [protected] |
Definition at line 1097 of file CompositeSurface.cpp.
get_surface(index)->closest_point_trimmed( position, result );
total_calls++;
CubitVector close, copy(position);
timer.cpu_secs();
surf->closest_point_trimmed( position, result );
trimmed_time += timer.cpu_secs();
surf->closest_point( position, &close );
closest_time += timer.cpu_secs();
CubitPointContainment contain = surf->point_containment( copy );
contain_time += timer.cpu_secs();
if ( contain == CUBIT_PNT_OUTSIDE )
contain_trim_count++;
else if( (result - close).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS)
error_count++;
// if( use_gme_cpt )
// get_surface( index )->closest_point_trimmed( position, result );
// return CUBIT_SUCCESS;
DLIList<TopologyBridge*> bridge_list;
Surface* surf_ptr = get_surface(index);
CubitVector surf_pt, normal, curve_pt;
if( !surf_ptr->closest_point( position, &surf_pt, &normal ) )
CoEdgeSM *closest_coedge, *other_coedge = 0;
cptInfo.setup(surf_ptr);
cptInfo.closest_coedge( position, closest_coedge, other_coedge, curve_pt );
if ( !closest_coedge )
CubitVector coe_normal, cross, tangent1, tangent2, junk;
bool inside;
if ( !other_coedge )
bridge_list.clean_out();
closest_coedge->get_children_virt( bridge_list );
Curve* curve_ptr = dynamic_cast<Curve*>(bridge_list.get());
assert( !!curve_ptr );
double u = curve_ptr->u_from_position( curve_pt );
if( !curve_ptr->G1_discontinuous( u, &tangent1, &tangent2 ) )
curve_ptr->closest_point( curve_pt, junk, &tangent1 );
bool inside = is_inside( tangent1, curve_pt, surf_pt, normal );
result = inside ? surf_pt : curve_pt;
if( closest_coedge->sense() == CUBIT_REVERSED )
tangent1 = -tangent1;
tangent2 = -tangent2;
else
Curve* curve1 = dynamic_cast<Curve*>(bridge_list.get());
other_coedge->get_children_virt( bridge_list );
Curve* curve2 = dynamic_cast<Curve*>(bridge_list.get());
assert(curve1 && curve2);
curve1->closest_point( curve_pt, junk, &tangent1 );
curve2->closest_point( curve_pt, junk, &tangent2 );
if( closest_coedge->sense() == CUBIT_REVERSED ) tangent1 = -tangent1;
if( other_coedge->sense() == CUBIT_REVERSED ) tangent2 = -tangent2;
surf_ptr->closest_point( curve_pt, 0, &coe_normal );
cross = tangent1 * tangent2;
bool inside1 = is_inside( tangent1, curve_pt, surf_pt, normal );
bool inside2 = is_inside( tangent2, curve_pt, surf_pt, normal );
if ( (cross % coe_normal) > 0.0 )
inside = inside1 && inside2;
else
inside = inside1 || inside2;
| int CompositeSurface::closest_underlying_surface | ( | const CubitVector & | position | ) |
Definition at line 1031 of file CompositeSurface.cpp.
if( num_surfs() == 1 )
return 0;
if( facetTool )
return facetTool->closest_index( pos );
closest_surf = compGeom->closest_box( pos );
closest_trimmed( closest_surf, pos, closest_point );
shortest_dist_sqr = (pos - closest_point).length_squared();
closest_trimmed( current_surf, pos, closest_point );
current_dist_sqr = (pos - closest_point).length_squared();
return closest_surf;
| CubitStatus CompositeSurface::combine | ( | CompositeSurface * | dead_surface | ) |
Definition at line 299 of file CompositeSurface.cpp.
int old_size = compGeom->num_entities();
// Merge the "surfaces_to_ignore" list.
surfacesToIgnore.merge_unique(dead_surf->surfacesToIgnore);
compGeom->merge( *(dead_surf->compGeom) );
if( dead_surf->hiddenSet != 0 )
hidden_entities().merge( dead_surf->hiddenSet );
for( int i = old_size; i < compGeom->num_entities(); i++ )
TopologyBridge* bridge = compGeom->entity(i);
assert( bridge->owner() == dead_surf );
bridge->owner( this );
delete facetTool;
facetTool = 0;
| CubitBoolean CompositeSurface::contains_bridge | ( | TopologyBridge * | bridge | ) | const [virtual] |
Reimplemented from TBOwner.
Definition at line 532 of file CompositeSurface.cpp.
return (CubitBoolean)(compGeom->index_of(bridge) >= 0);
| CubitStatus CompositeSurface::evaluate | ( | double | u, |
| double | v, | ||
| CubitVector * | position, | ||
| CubitVector * | normal, | ||
| CubitVector * | curvature1, | ||
| CubitVector * | curvature2 | ||
| ) | [virtual] |
Implements Surface.
Definition at line 770 of file CompositeSurface.cpp.
if( position || normal || (curvature1 && curvature2) )
return get_surface(0)->evaluate(u, v, position, normal, curvature1, curvature2 );
else
else
| CompositeCoSurf * CompositeSurface::find_first | ( | CompositeShell * | shell | ) | const |
Definition at line 236 of file CompositeSurface.cpp.
CompositeCoSurf* cos = firstCoSurf;
while( cos && cos->get_shell() != shell )
cos = cos->next_in_surface();
return cos;
| CompositeCoSurf * CompositeSurface::find_first | ( | CompositeLump * | lump | ) | const |
Definition at line 243 of file CompositeSurface.cpp.
while( cos && (!cos->get_shell() || cos->get_shell()->get_lump() != lump ) )
return cos;
| CompositeCoSurf * CompositeSurface::find_next | ( | CompositeCoSurf * | cosurf | ) | const |
Definition at line 250 of file CompositeSurface.cpp.
CompositeCoSurf* cos = cosurf;
while( cos && cos->get_shell() != cosurf->get_shell() )
return cos;
| CompositeLoop * CompositeSurface::first_loop | ( | ) | const [inline] |
Definition at line 346 of file CompositeSurface.hpp.
{ return firstLoop; }
| GeometryType CompositeSurface::geometry_type | ( | ) | [virtual] |
Reimplemented from Surface.
Definition at line 1563 of file CompositeSurface.cpp.
{ return UNDEFINED_SURFACE_TYPE; }
| void CompositeSurface::get_children_virt | ( | DLIList< TopologyBridge * > & | children | ) | [virtual] |
Definition at line 382 of file CompositeSurface.cpp.
for( CompositeLoop* loop = firstLoop; loop; loop = loop->loopNext )
list.append( loop );
| CubitStatus CompositeSurface::get_cone_params | ( | CubitVector & | center, |
| CubitVector & | normal, | ||
| CubitVector & | major_axis, | ||
| double & | radius_ratio, | ||
| double & | sine_angle, | ||
| double & | cos_angle | ||
Implements Surface.
Definition at line 2001 of file CompositeSurface.cpp.
PRINT_ERROR("Currently, Cubit is unable to determine cone parameters for CompositeSurfaces.\n");
| void CompositeSurface::get_curves | ( | DLIList< CompositeCurve * > & | curves | ) |
Definition at line 1544 of file CompositeSurface.cpp.
CompositeCoEdge* coedge = loop->first_coedge();
while( coedge )
result.append_unique( coedge->get_curve() );
coedge = loop->next_coedge( coedge );
| GeometryQueryEngine * CompositeSurface::get_geometry_query_engine | ( | ) | const [virtual] |
Definition at line 550 of file CompositeSurface.cpp.
return VirtualQueryEngine::instance();
| CubitSense CompositeSurface::get_geometry_sense | ( | ) | [virtual] |
| CubitStatus CompositeSurface::get_graphics | ( | GMem & | gmem | ) |
Definition at line 1948 of file CompositeSurface.cpp.
if (!facetTool)
if (!facetTool)
facetTool->graphics( GEOMETRY_RESABS, gmem);
| void CompositeSurface::get_hidden_curves | ( | DLIList< Curve * > & | curves | ) |
Definition at line 1566 of file CompositeSurface.cpp.
if( hiddenSet )
hiddenSet->hidden_curves( curves );
| void CompositeSurface::get_ignored_surfs | ( | DLIList< Surface * > & | surfs | ) |
Definition at line 322 of file CompositeSurface.cpp.
int i;
if(surfacesToIgnore.size() > 0)
for(i=0; i<num_surfs(); i++)
Surface *srf = get_surface(i);
if(surfacesToIgnore.is_in_list(srf))
surfs.append(srf);
| CubitStatus CompositeSurface::get_nurb_params | ( | bool & | rational, |
| int & | degree_u, | ||
| int & | degree_v, | ||
| int & | num_cntrl_pts_u, | ||
| int & | num_cntrl_pts_v, | ||
| DLIList< CubitVector > & | cntrl_pts, | ||
| DLIList< double > & | weights, | ||
| DLIList< double > & | u_knots, | ||
| DLIList< double > & | v_knots | ||
Implements Surface.
Definition at line 2027 of file CompositeSurface.cpp.
PRINT_ERROR("Currently, Cubit is unable to determine nurbs parameters for CompositeSurface.\n");
| CubitBoolean CompositeSurface::get_param_range_U | ( | double & | lower, |
| double & | upper | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1430 of file CompositeSurface.cpp.
if (num_surfs() == 1)
return get_surface(0)->get_param_range_U(lower, upper);
lower = upper = 0;
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::get_param_range_V | ( | double & | lower, |
| ) | [virtual] |
Implements Surface.
Definition at line 1439 of file CompositeSurface.cpp.
return get_surface(0)->get_param_range_V(lower, upper);
lower = upper = 0;
return CUBIT_FALSE;
| void CompositeSurface::get_parents_virt | ( | DLIList< TopologyBridge * > & | parents | ) | [virtual] |
Definition at line 360 of file CompositeSurface.cpp.
DLIList<TopologyBridge*> parents, parents2;
for( int i = 0; i < num_surfs(); i++ )
parents.clean_out();
get_surface(i)->get_parents( parents );
parents.reset();
for ( int j = parents.size(); j--; )
TopologyBridge* shell = parents.get_and_step();
shell->get_parents( parents2 );
assert (parents2.size() == 1);
if (0 == dynamic_cast<CompositeLump*>(parents2.pop()->owner()))
list.append_unique( shell );
CompositeCoSurf* cosurf = 0;
while ((cosurf = next_co_surface( cosurf )))
list.append_unique( cosurf->get_shell() );
| CubitStatus CompositeSurface::get_point_normal | ( | CubitVector & | origin, |
| CubitVector & | normal | ||
| ) | [virtual] |
Implements Surface.
Definition at line 589 of file CompositeSurface.cpp.
int count = num_surfs();
CubitVector* vect_list = new CubitVector[count];
double RESABS_SQUARED = CUBIT_RESABS * CUBIT_RESABS;
normal.set(0.0,0.0,0.0);
if (count == 1)
return get_surface(0)->get_point_normal(origin,normal);
for( int i = 0; i < count; i++ )
Surface* surf = get_surface(i);
if( surf->get_point_normal(origin,vect_list[i]) == CUBIT_FAILURE )
delete [] vect_list;
if( compGeom->sense(i) == CUBIT_REVERSED )
vect_list[i] *= -1.0;
normal += vect_list[i];
//If we reach this point, then all of the underlying surfaces are planar.
//Next check if they are coplanar.
if( normal.length_squared() < RESABS_SQUARED )
normal.normalize();
for( int j = 0; j < count; j++ )
if( fabs( 1.0 - (normal % ~vect_list[j]) ) > CUBIT_RESABS )
CubitVector zero( 0.0, 0.0, 0.0 );
closest_point( zero, &origin );
| CubitStatus CompositeSurface::get_projected_distance_on_surface | ( | CubitVector * | pos1, |
| CubitVector * | pos2, | ||
| double & | distance | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1980 of file CompositeSurface.cpp.
return get_surface(0)->get_projected_distance_on_surface( pos1, pos2, distance );
else
| CubitSense CompositeSurface::get_sense | ( | int | index | ) | const [inline] |
Definition at line 335 of file CompositeSurface.hpp.
| CubitSense CompositeSurface::get_shell_sense | ( | ShellSM * | shell_ptr | ) | const [virtual] |
Implements Surface.
Definition at line 1650 of file CompositeSurface.cpp.
CompositeShell* shell = dynamic_cast<CompositeShell*>(shellsm_ptr);
if( shell )
return shell->find_sense(this);
DLIList<TopologyBridge*> parents;
if( parents.is_in_list( shellsm_ptr ) )
CubitSense result = get_surface(i)->get_shell_sense(shellsm_ptr);
if( get_sense(i) == CUBIT_REVERSED )
if( result == CUBIT_FORWARD )
result = CUBIT_REVERSED;
else if( result == CUBIT_REVERSED )
result = CUBIT_FORWARD;
return result;
return CUBIT_UNKNOWN;
| CubitStatus CompositeSurface::get_simple_attribute | ( | DLIList< CubitSimpleAttrib > & | attrib_list | ) | [virtual] |
Definition at line 447 of file CompositeSurface.cpp.
if(!compGeom)
compGeom->get_attributes( attrib_list );
| CubitStatus CompositeSurface::get_simple_attribute | ( | const CubitString & | name, |
| DLIList< CubitSimpleAttrib > & | attrib_list | ||
| ) | [virtual] |
Definition at line 455 of file CompositeSurface.cpp.
if(!compGeom)
compGeom->get_attributes( name.c_str(), attrib_list );
| CubitStatus CompositeSurface::get_sphere_params | ( | CubitVector & | center, |
| double & | radius | ||
Implements Surface.
Definition at line 1991 of file CompositeSurface.cpp.
PRINT_ERROR("Currently, Cubit is unable to determine sphere parameters for CompositeSurfaces.\n");
| CompositeSurface* CompositeSurface::get_stitch_partner | ( | ) | const [inline] |
Definition at line 88 of file CompositeSurface.hpp.
{ return stitchPartner; }
| Surface * CompositeSurface::get_surface | ( | int | index | ) | const [inline] |
Definition at line 332 of file CompositeSurface.hpp.
| CubitStatus CompositeSurface::get_torus_params | ( | CubitVector & | center, |
| double & | major_radius, | ||
| double & | minor_radius | ||
Implements Surface.
Definition at line 2015 of file CompositeSurface.cpp.
PRINT_ERROR("Currently, Cubit is unable to determine torus parameters for CompositeSurface.\n");
| bool CompositeSurface::has_hidden_entities | ( | ) | const |
Definition at line 1558 of file CompositeSurface.cpp.
| HiddenEntitySet & CompositeSurface::hidden_entities | ( | ) | [inline] |
Definition at line 355 of file CompositeSurface.hpp.
if( !hiddenSet )
hiddenSet = new HiddenEntitySet(this);
return *hiddenSet;
| void CompositeSurface::ignore_surface | ( | int | surface_id | ) |
Definition at line 673 of file CompositeSurface.cpp.
if(facetTool)
int i;
int num_surfs_in_composite = num_surfs();
for (i=0; i<num_surfs_in_composite; i++)
Surface *cur_surf = get_surface(i);
if(cur_surf->get_saved_id() == surface_id)
surfacesToIgnore.append_unique(cur_surf);
i = num_surfs_in_composite;
update_facets_to_ignore();
| void CompositeSurface::ignore_surface | ( | Surface * | surf | ) |
Definition at line 693 of file CompositeSurface.cpp.
if(facetTool)
int i;
if(cur_surf == surf)
| int CompositeSurface::index_of | ( | Surface * | surface | ) | const [inline] |
Definition at line 341 of file CompositeSurface.hpp.
| CubitBoolean CompositeSurface::is_closed_in_U | ( | ) | [virtual] |
Definition at line 1365 of file CompositeSurface.cpp.
return get_surface(0)->is_closed_in_U();
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_closed_in_V | ( | ) | [virtual] |
Definition at line 1372 of file CompositeSurface.cpp.
return get_surface(0)->is_closed_in_V();
return CUBIT_FALSE;
| bool CompositeSurface::is_dead_coedge | ( | CompositeCoEdge * | coedge | ) | [protected] |
Definition at line 1838 of file CompositeSurface.cpp.
if (coedge->num_coedges() > 0)
return false;
CompositeCurve* curve = coedge->get_curve();
if (!curve)
return true;
if (curve->num_curves() == 0) // point-curve
CompositePoint* comp = curve->start_point();
assert(comp == curve->end_point());
return !(comp->get_point());
return false;
| CubitBoolean CompositeSurface::is_parametric | ( | ) | [virtual] |
Implements Surface.
Definition at line 1412 of file CompositeSurface.cpp.
return get_surface(0)->is_parametric();
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_periodic | ( | ) | [virtual] |
Implements Surface.
Definition at line 1296 of file CompositeSurface.cpp.
return get_surface(0)->is_periodic();
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_periodic_in_U | ( | double & | period | ) | [virtual] |
Implements Surface.
Definition at line 1313 of file CompositeSurface.cpp.
return get_surface(0)->is_periodic_in_U(period);
period = 0.0;
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_periodic_in_V | ( | double & | period | ) | [virtual] |
Implements Surface.
Definition at line 1321 of file CompositeSurface.cpp.
return get_surface(0)->is_periodic_in_V(period);
period = 0.0;
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_position_on | ( | CubitVector & | position | ) | [virtual] |
Implements Surface.
Definition at line 1459 of file CompositeSurface.cpp.
if( surf->is_position_on( position ) ) return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_singular_in_U | ( | double | u_value | ) | [virtual] |
Implements Surface.
Definition at line 1340 of file CompositeSurface.cpp.
return get_surface(0)->is_singular_in_U(param);
return CUBIT_FALSE;
| CubitBoolean CompositeSurface::is_singular_in_V | ( | double | v_value | ) | [virtual] |
Implements Surface.
Definition at line 1347 of file CompositeSurface.cpp.
return get_surface(0)->is_singular_in_V(param);
return CUBIT_FALSE;
| int CompositeSurface::layer | ( | ) | const [inline, virtual] |
Reimplemented from TopologyBridge.
Definition at line 125 of file CompositeSurface.hpp.
{ return COMPOSITE_LAYER; }
| double CompositeSurface::measure | ( | ) | [virtual] |
Definition at line 565 of file CompositeSurface.cpp.
| CompositeCoSurf * CompositeSurface::next_co_surface | ( | CompositeCoSurf * | prev = 0 | ) | const [inline] |
Definition at line 352 of file CompositeSurface.hpp.
{ return prev ? prev->surfaceNext : firstCoSurf; }
| CompositeLoop * CompositeSurface::next_loop | ( | CompositeLoop * | after_this = 0 | ) | const [inline] |
Definition at line 349 of file CompositeSurface.hpp.
| void CompositeSurface::notify_reversed | ( | TopologyBridge * | bridge | ) | [virtual] |
Implements TBOwner.
Definition at line 1677 of file CompositeSurface.cpp.
int index = compGeom->index_of(bridge);
if( index >= 0 )
compGeom->reverse_sense(index);
| void CompositeSurface::notify_split | ( | TopologyBridge * | new_bridge, |
| TopologyBridge * | old_bridge | ||
| ) | [virtual] |
Definition at line 1814 of file CompositeSurface.cpp.
assert(!new_bridge->owner());
Surface* old_surf = dynamic_cast<Surface*>(old_bridge);
Surface* new_surf = dynamic_cast<Surface*>(new_bridge);
assert( old_surf && new_surf );
int old_surf_index = index_of(old_surf);
assert(old_surf_index >= 0);
compGeom->append(new_surf, compGeom->sense(old_surf_index));
new_surf->owner(this);
DLIList<CompositeCurve*> new_curves;
update_modified();
update_modified( old_surf, new_curves );
update_modified( new_surf, new_curves );
// for( int i = new_curves.size(); i--; )
// if( !CompositeEngine::instance().restore_curve(new_curves.get_and_step()) )
// assert(0);
| void CompositeSurface::notify_topology_modified | ( | TopologyBridge * | bridge | ) | [virtual] |
Definition at line 1714 of file CompositeSurface.cpp.
Surface* surf = dynamic_cast<Surface*>(bridge);
assert( surf && index_of(surf) >= 0 );
update_modified();
update_modified( surf, new_curves );
// assert(0);
| void CompositeSurface::notify_transformed | ( | ) |
Definition at line 1969 of file CompositeSurface.cpp.
| int CompositeSurface::num_surfs | ( | ) | const [inline] |
Definition at line 338 of file CompositeSurface.hpp.
{ return compGeom->num_entities(); }
| CompositeSurface& CompositeSurface::operator= | ( | const CompositeSurface & | ) | [private] |
| CubitPointContainment CompositeSurface::point_containment | ( | const CubitVector & | point | ) | [virtual] |
Implements Surface.
Definition at line 1480 of file CompositeSurface.cpp.
bool boundary = false;
CubitPointContainment cpc = get_surface(i)->point_containment( point );
switch( cpc )
case CUBIT_PNT_OUTSIDE:
//case CUBIT_PNT_OFF:
break;
case CUBIT_PNT_INSIDE:
//case CUBIT_PNT_ON:
return cpc;
case CUBIT_PNT_BOUNDARY:
boundary = true;
break;
case CUBIT_PNT_UNKNOWN:
default:
return CUBIT_PNT_UNKNOWN;
if( boundary )
return CUBIT_PNT_BOUNDARY;
else
return CUBIT_PNT_OUTSIDE;
| CubitPointContainment CompositeSurface::point_containment | ( | double | u, |
| double | v | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1516 of file CompositeSurface.cpp.
return get_surface(0)->point_containment(u,v);
// Set this up when uv parameters are defined for composite surfaces.
| CubitVector CompositeSurface::position_from_u_v | ( | double | u, |
| double | v | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1251 of file CompositeSurface.cpp.
return get_surface(0)->position_from_u_v(u,v);
PRINT_ERROR("CompositeSurface::position_from_u_v for non-paramtric surface.\n");
CubitVector nulvect( 0., 0., 0.);
return nulvect;
| CubitStatus CompositeSurface::principal_curvatures | ( | CubitVector const & | location, |
| double & | curvature_1, | ||
| double & | curvature_2, | ||
| CubitVector * | closest_location | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1220 of file CompositeSurface.cpp.
principal_curvatures(location, curvature_1, curvature_2, closest_location);
CubitVector curvature1, curvature2;
CubitStatus s = closest_point( location, closest_location, NULL,
&curvature1, &curvature2 );
if( s == CUBIT_FAILURE ) return CUBIT_FAILURE;
curvature_1 = curvature1.length();
curvature_2 = curvature2.length();
| void CompositeSurface::print_cpt_stats | ( | ) | [static] |
Definition at line 1074 of file CompositeSurface.cpp.
PRINT_INFO("Total Calls %10d\n", total_calls);
PRINT_INFO("ClosestTrimmed %10.0f %10.5f\n", trimmed_time, trimmed_time / total_calls );
PRINT_INFO("Closest %10.0f %10.5f\n", closest_time, closest_time / total_calls );
PRINT_INFO("Containment %10.0f %10.5f\n", contain_time, contain_time / total_calls );
double average_outside = (double)contain_trim_count / total_calls;
PRINT_INFO("Outside Count %10d %10.5f\n", contain_trim_count, average_outside );
double containment = contain_time +
average_outside * trimmed_time +
(1.0-average_outside) * closest_time;
PRINT_INFO("Contain Est. %10.0f %10.5f\n", containment, containment / total_calls );
PRINT_INFO("Error Count %10d %10.5f\n", error_count, (double)error_count / total_calls );
| void CompositeSurface::print_debug_info | ( | const char * | line_prefix = 0, |
| bool | brief = false |
Definition at line 1572 of file CompositeSurface.cpp.
if( line_prefix == 0 ) line_prefix = "";
CompositeLoop* loop = 0;
if( brief )
int count = 0;
while ( (loop = next_loop(loop) ) != NULL )
count++;
#ifdef TOPOLOGY_BRIDGE_IDS
PRINT_INFO("%sCompositeSurface %d : %d loops ", line_prefix, get_id(), count );
PRINT_INFO("%s %d\n", fix_type_name(typeid(*get_surface(0)).name()), get_surface(0)->get_id());
else
PRINT_INFO("%d surfaces.\n", num_surfs());
#else
PRINT_INFO("%sCompositeSurface %p : %d loops ", line_prefix, (void*)this, count );
PRINT_INFO("%s %d\n", fix_type_name(typeid(*get_surface(0)).name()), get_surface(0)->get_saved_id());
// PRINT_INFO("%s %p\n", fix_type_name(typeid(*get_surface(0)).name()), get_surface(0));
else
#endif
return;
char* new_prefix = new char[strlen(line_prefix)+3];
strcpy( new_prefix, line_prefix );
strcat( new_prefix, " " );
PRINT_INFO("%sCompositeSurface %d\n", line_prefix, get_id() );
#else
PRINT_INFO("%sCompositeSurface %d\n", line_prefix, this->get_saved_id() );
// PRINT_INFO("%sCompositeSurface %p\n", line_prefix, this );
#endif
compGeom->print_debug_info( new_prefix );
// Print out info about any surfaces we are ingoring
// during evaluation.
PRINT_INFO("%sSurfaces which are ignored:\n", new_prefix);
for(int k=surfacesToIgnore.size(); k--;)
PRINT_INFO("%sSurface: %d\n",
new_prefix, surfacesToIgnore.get_and_step()->get_saved_id());
if( hiddenSet ) hiddenSet->print_debug_info( new_prefix );
else PRINT_INFO("%s No Hidden Entities.\n", line_prefix );
while( (loop = next_loop(loop) ) != NULL )
loop->print_debug_info( new_prefix );
delete [] new_prefix;
if ( facetTool )
facetTool->debug_draw_facets();
// bool* reversed = new bool[num_surfs()];
// for (int i = 0; i < num_surfs(); i++ )
// reversed[i] = get_sense(i) == CUBIT_REVERSED;
// facetTool->consolidate_points(reversed, GEOMETRY_RESABS);
// delete [] reversed;
| void CompositeSurface::read_attributes | ( | ) | [inline] |
Definition at line 285 of file CompositeSurface.hpp.
{ compGeom->read_attributes(); }
| CubitStatus CompositeSurface::remove | ( | CompositeLoop * | loop | ) |
Definition at line 147 of file CompositeSurface.cpp.
if( loop->mySurface != this )
if( firstLoop == loop )
firstLoop = loop->loopNext;
else
CompositeLoop *prev = firstLoop,
*next = firstLoop->loopNext;
while( next != loop )
assert( next != NULL );
prev = next;
next = next->loopNext;
prev->loopNext = next->loopNext;
loop->loopNext = 0;
loop->mySurface = 0;
| CubitStatus CompositeSurface::remove | ( | CompositeCoSurf * | cosurf | ) |
Definition at line 205 of file CompositeSurface.cpp.
if( cosurf->mySurface != this )
if( cosurf == firstCoSurf )
firstCoSurf = cosurf->surfaceNext;
else
CompositeCoSurf* prev = firstCoSurf;
while( prev && prev->surfaceNext != cosurf )
prev = prev->surfaceNext;
assert( prev != NULL );
prev->surfaceNext = cosurf->surfaceNext;
cosurf->mySurface = 0;
cosurf->surfaceNext = 0;
| void CompositeSurface::remove_all_simple_attribute_virt | ( | ) | [virtual] |
Definition at line 431 of file CompositeSurface.cpp.
if(compGeom)
compGeom->rem_all_attributes( );
| CubitStatus CompositeSurface::remove_bridge | ( | TopologyBridge * | bridge | ) | [virtual] |
Implements TBOwner.
Definition at line 474 of file CompositeSurface.cpp.
if(!compGeom)
int i = compGeom->index_of(bridge);
if( i < 0 )
delete facetTool;
facetTool = 0;
assert( bridge->owner() == this );
bridge->owner(0);
if (!compGeom->remove(i, true))
if (compGeom->num_entities() == 0)
CompositeEngine::instance().notify_deactivated(this);
HadBridgeRemoved = 1;
| void CompositeSurface::remove_dead_coedge | ( | CompositeCoEdge * | coedge | ) | [protected] |
Definition at line 1905 of file CompositeSurface.cpp.
assert(is_dead_coedge(coedge));
assert(curve->num_curves() == 0);
curve->remove(coedge);
delete coedge;
if (curve->next_coedge(NULL))
return;
CompositePoint* start = curve->start_point();
CompositePoint* end = curve->end_point();
curve->start_point(0);
curve->end_point(0);
delete curve;
if ( start->next_curve(NULL) == NULL )
if ( start->get_point() )
CompositeEngine::instance().restore_point_in_curve(start);
else
delete start;
if ( end != start && end->next_curve(NULL) == NULL )
if ( end->get_point() )
CompositeEngine::instance().restore_point_in_curve(end);
else
delete end;
| void CompositeSurface::remove_simple_attribute_virt | ( | const CubitSimpleAttrib & | simple_attrib_ptr | ) | [virtual] |
Definition at line 414 of file CompositeSurface.cpp.
if(compGeom)
compGeom->rem_attribute( simple_attrib_ptr );
| Surface * CompositeSurface::remove_surface | ( | int | index | ) |
Definition at line 497 of file CompositeSurface.cpp.
Surface* result = get_surface(index);
if ( !result || !compGeom->remove(index,false) )
return 0;
result->owner(0);
return result;
| void CompositeSurface::reset_cpt_stats | ( | ) | [static] |
Definition at line 1090 of file CompositeSurface.cpp.
trimmed_time = contain_time = closest_time = 0.0;
total_calls = contain_trim_count = error_count = 0;
| void CompositeSurface::reverse_sense | ( | ) | [virtual] |
Definition at line 1538 of file CompositeSurface.cpp.
| CompositeSurface * CompositeSurface::split | ( | VGArray< int > & | indices_to_move | ) |
Definition at line 268 of file CompositeSurface.cpp.
int i;
for( i = 0; i < indices_to_move.size(); i++ )
if( indices_to_move[i] < 0 || indices_to_move[i] >= num_surfs() )
return 0;
CompositeGeom* new_geom = compGeom->split( indices_to_move );
if( !new_geom )
return 0;
for( i = 0; i < new_geom->num_entities(); i++ )
new_geom->entity(i)->owner( 0 );
delete facetTool;
facetTool = 0;
return new CompositeSurface( new_geom );
| CubitStatus CompositeSurface::stitch | ( | CompositeSurface * | stitch_partner | ) |
Definition at line 1684 of file CompositeSurface.cpp.
if( this == partner || this->stitchPartner || partner->stitchPartner )
assert(0);
this->stitchPartner = partner;
partner->stitchPartner = this;
| CubitStatus CompositeSurface::swap_bridge | ( | TopologyBridge * | old_tb, |
| TopologyBridge * | new_tb, | ||
| bool | reversed | ||
| ) | [virtual] |
Implements TBOwner.
Definition at line 509 of file CompositeSurface.cpp.
if( n->owner() )
int i = compGeom->index_of(o);
GeometryEntity* ge = dynamic_cast<GeometryEntity*>(n);
if( i >= 0 && ge != 0 )
o->owner(0);
n->owner(this);
if ( !compGeom->swap( i, ge ) )
if (reversed)
compGeom->reverse_sense(i);
else
| CubitStatus CompositeSurface::u_v_from_position | ( | CubitVector const & | position, |
| double & | u, | ||
| double & | v, | ||
| CubitVector * | closest_point | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1272 of file CompositeSurface.cpp.
return get_surface(0)->u_v_from_position(pos, u, v, closest);
PRINT_ERROR("CompositeSurface::u_v_from_position for non-paramtric surface.\n");
u = v = 0.0;
| void CompositeSurface::unignore_surface | ( | int | surface_id | ) |
Definition at line 715 of file CompositeSurface.cpp.
if(facetTool)
int i;
surfacesToIgnore.remove(cur_surf);
Definition at line 1697 of file CompositeSurface.cpp.
CompositeSurface* result = this->stitchPartner;
if( result )
this->stitchPartner = result->stitchPartner = 0;
return result;
| void CompositeSurface::update | ( | ) | [inline] |
Definition at line 344 of file CompositeSurface.hpp.
{ compGeom->update_cached_data(); }
| void CompositeSurface::update_facet_tool | ( | ) | [protected] |
Definition at line 735 of file CompositeSurface.cpp.
if( ! facetTool )
std::vector<Surface*> surf_vect(num_surfs());
for ( int i = 0; i < num_surfs(); i++ )
surf_vect[i] = get_surface(i);
facetTool = new CompSurfFacets();
if ( ! facetTool->setup( surf_vect ) )
delete facetTool;
facetTool = 0;
else
// Make sure to update the facetTool to reflect
// any surfaces we think we need to ignore.
| void CompositeSurface::update_facets_to_ignore | ( | ) | [protected] |
Definition at line 644 of file CompositeSurface.cpp.
if(facetTool)
int i;
DLIList<int> surfaces_to_ignore;
surfacesToIgnore.reset();
for(int j=surfacesToIgnore.size(); j--;)
if(cur_surf == surfacesToIgnore.get_and_step())
surfaces_to_ignore.append( i );
j=0;
//do it all at once
facetTool->set_ignore_flag( surfaces_to_ignore, 1 );
| void CompositeSurface::update_modified | ( | Surface * | modified_surface, |
| DLIList< CompositeCurve * > & | new_curves | ||
| ) | [protected] |
Definition at line 1727 of file CompositeSurface.cpp.
int i;
//int i = index_of(surf);
//assert(i >= 0);
//CubitSense rel_sense = get_sense(i);
// find any new coedges in the surface
DLIList<LoopSM*> loops;
DLIList<CoEdgeSM*> coedges;
surf->get_children_virt( bridge_list );
CAST_LIST( bridge_list, loops, LoopSM );
assert( bridge_list.size() == loops.size() );
for( i = loops.size(); i--; )
loops.get_and_step()->get_children_virt( bridge_list );
while( bridge_list.size() )
CoEdgeSM* coedge = dynamic_cast<CoEdgeSM*>(bridge_list.pop());
assert(0 != coedge);
coedges.append(coedge);
for( i = coedges.size(); i--; )
CoEdgeSM* coedge = coedges.get_and_step();
assert( bridge_list.size() == 1 );
Curve* curve = dynamic_cast<Curve*>(bridge_list.get());
assert( 0 != curve );
CompositeCoEdge* ccoedge = dynamic_cast<CompositeCoEdge*>(coedge->owner());
if (ccoedge)
// If replace-curve was already done for the curve
// when processing the other surface, the composite
// coedge will have been created already. Add it to
// the hidden set.
if( !ccoedge->owner() && ccoedge->get_curve()->owner() == &hidden_entities())
hidden_entities().hide( ccoedge );
// If the coedge is a composite, the curve must be one
// already as well. Done with this coedge.
continue;
// Replace curve with composite, and hide composite curve
// and any new child points.
CompositeCurve* ccurve = CompositeEngine::instance().replace_curve(curve);
assert(0 != ccurve);
new_curves.append(ccurve);
hidden_entities().hide( ccurve );
CompositePoint* start = ccurve->start_point();
if( ! start->owner() )
hidden_entities().hide(start);
CompositePoint* end = ccurve->start_point();
if( ! end->owner() )
hidden_entities().hide(end);
// CompositeCoEdge was created by replace_curve(..)
// Add it to the HiddenEntitySet
assert(ccoedge && !ccoedge->owner());
| void CompositeSurface::update_modified | ( | ) | [protected] |
Definition at line 1857 of file CompositeSurface.cpp.
// search for dead CoEdge-Curve pairs
DLIList<CoEdgeSM*> coedge_list;
if ( hiddenSet )
hiddenSet->hidden_coedges( coedge_list );
while (coedge_list.size())
CompositeCoEdge* coedge = dynamic_cast<CompositeCoEdge*>(coedge_list.pop());
if ( is_dead_coedge(coedge) )
remove_dead_coedge(coedge);
CompositeLoop* loop = next_loop();
while (loop)
CompositeLoop* next = next_loop(loop);
while (coedge && is_dead_coedge(coedge))
if (coedge)
coedge = coedge->next();
while ( coedge != loop->first_coedge() )
CompositeCoEdge* next_coe = coedge->next();
if (is_dead_coedge(coedge))
coedge = next_coe;
if (loop->first_coedge() == NULL)
remove(loop);
delete loop;
loop = next;
| CubitStatus CompositeSurface::uv_derivitives | ( | double | u, |
| double | v, | ||
| CubitVector & | du, | ||
| CubitVector & | dv | ||
| ) | [virtual] |
Implements Surface.
Definition at line 1390 of file CompositeSurface.cpp.
return get_surface(0)->uv_derivitives(u, v, du, dv);
PRINT_ERROR("CompositeSurface::uv_derivitives for non-paramtric surface.\n");
| void CompositeSurface::write_attributes | ( | ) | [inline] |
Definition at line 286 of file CompositeSurface.hpp.
{ compGeom->write_attributes(); }
friend class CompositeEngine [friend] |
Definition at line 37 of file CompositeSurface.hpp.
CompositeGeom* CompositeSurface::compGeom [private] |
Definition at line 319 of file CompositeSurface.hpp.
CompSurfFacets* CompositeSurface::facetTool [private] |
Definition at line 328 of file CompositeSurface.hpp.
CompositeCoSurf* CompositeSurface::firstCoSurf [private] |
Definition at line 322 of file CompositeSurface.hpp.
CompositeLoop* CompositeSurface::firstLoop [private] |
Definition at line 324 of file CompositeSurface.hpp.
int CompositeSurface::HadBridgeRemoved [private] |
Definition at line 310 of file CompositeSurface.hpp.
HiddenEntitySet* CompositeSurface::hiddenSet [private] |
Definition at line 326 of file CompositeSurface.hpp.
CompositeSurface* CompositeSurface::stitchPartner [private] |
Definition at line 320 of file CompositeSurface.hpp.
DLIList<Surface*> CompositeSurface::surfacesToIgnore [private] |
Definition at line 312 of file CompositeSurface.hpp.
