cgma
#include <FaceterFacetData.hpp>
Public Member Functions | |
| FaceterFacetData (CubitPoint *p1, CubitPoint *p2, CubitPoint *p3) | |
| ~FaceterFacetData () | |
| virtual int | id () |
| virtual void | set_id (int ii) |
| void | owner (RefEntity *owner) |
| RefEntity * | owner () |
| SetDynamicMemoryAllocation (memoryManager) CubitStatus closest_point(const CubitVector &point | |
| CubitPoint * | point (int index) |
| void | set_point (CubitPoint *the_point, int index) |
| CubitFacetEdge * | edge (int index) |
| void | edge (CubitFacetEdge *the_edge, int index) |
| void | edge_use (int direction, int index) |
| int | edge_use (int index) |
| CubitPoint * | split_edge (CubitPoint *edge_pt1, CubitPoint *edge_pt2, const CubitVector &position) |
| CubitPoint * | insert_point (const CubitVector &position, CubitFacet *&new_tri1, CubitFacet *&new_tri2) |
| void | flip () |
Public Attributes | |
| CubitVector & | closest_point |
Private Attributes | |
| CubitPoint * | pointArray [3] |
| CubitFacetEdge * | edgeArray [3] |
| int | edgeUse [3] |
| int | entityId |
| RefEntity * | myOwner |
Static Private Attributes | |
| static MemoryManager | memoryManager |
Definition at line 17 of file FaceterFacetData.hpp.
| FaceterFacetData::FaceterFacetData | ( | CubitPoint * | p1, |
| CubitPoint * | p2, | ||
| CubitPoint * | p3 | ||
Definition at line 30 of file FaceterFacetData.cpp.
assert( p1 && p2 && p3 );
assert( p1 != p2 && p1 != p3 && p2 != p3 );
myOwner = NULL;
pointArray[0] = p1;
pointArray[1] = p2;
pointArray[2] = p3;
p1->add_facet(this);
p2->add_facet(this);
p3->add_facet(this);
edgeArray[0] = NULL;
edgeArray[1] = NULL;
edgeArray[2] = NULL;
edgeUse[0] = edgeUse[1] = edgeUse[2] = 0;
patchCtrlPts = NULL;
//CubitVector temp = normal();
//cachedNormal = new CubitVector(temp);
plane();
counter_id++;
entityId = counter_id;
// define the bounding box
CubitVector bbox_min, bbox_max;
bbox_min.x(min3(p1->x(),p2->x(),p3->x()));
bbox_min.y(min3(p1->y(),p2->y(),p3->y()));
bbox_min.z(min3(p1->z(),p2->z(),p3->z()));
bbox_max.x(max3(p1->x(),p2->x(),p3->x()));
bbox_max.y(max3(p1->y(),p2->y(),p3->y()));
bbox_max.z(max3(p1->z(),p2->z(),p3->z()));
bBox.reset(bbox_min,bbox_max);
Definition at line 74 of file FaceterFacetData.cpp.
| CubitFacetEdge * FaceterFacetData::edge | ( | int | index | ) | [inline, virtual] |
Implements CubitFacet.
Definition at line 123 of file FaceterFacetData.hpp.
assert( (index >= 0) && (index < 3) );
if (!is_backwards())
return edgeArray[index];
else
switch(index)
case 0: return edgeArray[0];
case 1: return edgeArray[2];
case 2: return edgeArray[1];
return NULL;
| void FaceterFacetData::edge | ( | CubitFacetEdge * | the_edge, |
| int | index | ||
Definition at line 58 of file FaceterFacetData.hpp.
{ edgeArray[index] = the_edge; };
| void FaceterFacetData::edge_use | ( | int | direction, |
| int | index | ||
Definition at line 62 of file FaceterFacetData.hpp.
{ edgeUse[index] = direction; };
| int FaceterFacetData::edge_use | ( | int | index | ) | [inline, virtual] |
Definition at line 140 of file FaceterFacetData.hpp.
return edgeUse[index];
else
switch(index)
case 0: return -edgeUse[0];
case 1: return -edgeUse[2];
case 2: return -edgeUse[1];
return 0;
| void FaceterFacetData::flip | ( | ) | [virtual] |
Definition at line 239 of file FaceterFacetData.cpp.
CubitPoint *pt_tmp = pointArray[1];
pointArray[1] = pointArray[2];
pointArray[2] = pt_tmp;
CubitFacetEdge *ed_tmp = edgeArray[1];
edgeArray[1] = edgeArray[2];
edgeArray[2] = ed_tmp;
for (int ii=0; ii<3; ii++)
if (edgeUse[ii] == -1)
edgeUse[ii] = 1;
else if(edgeUse[ii] == 1)
edgeUse[ii] = -1;
if (cachedPlane)
CubitVector normal = cachedPlane->normal();
normal = -normal;
cachedPlane->normal( normal );
| virtual int FaceterFacetData::id | ( | void | ) | [inline, virtual] |
| CubitPoint * FaceterFacetData::insert_point | ( | const CubitVector & | position, |
| CubitFacet *& | new_tri1, | ||
| CubitFacet *& | new_tri2 | ||
| ) | [virtual] |
Reimplemented from CubitFacet.
Definition at line 174 of file FaceterFacetData.cpp.
if( DEBUG_FLAG(110 ) )
GfxDebug::draw_facet(this, CUBIT_WHITE_INDEX);
GfxDebug::flush();
CubitPoint* new_point = (CubitPoint *) new CubitPointData( position );
new_tri1 = (CubitFacet *)
new FaceterFacetData( pointArray[1], pointArray[2], new_point );
new_tri2 = (CubitFacet *)
new FaceterFacetData( pointArray[2], pointArray[0], new_point );
pointArray[2]->remove_facet( this );
pointArray[2] = new_point;
new_point->add_facet( this );
if( DEBUG_FLAG(110) )
CubitVector temp_vector = new_point->coordinates();
GfxDebug::draw_facet(this, CUBIT_MAGENTA_INDEX);
GfxDebug::flush();
GfxDebug::draw_facet(new_tri1, CUBIT_MAGENTA_INDEX);
GfxDebug::flush();
GfxDebug::draw_facet(new_tri2, CUBIT_MAGENTA_INDEX);
GfxDebug::flush();
GfxDebug::draw_point(temp_vector, CUBIT_CYAN_INDEX);
GfxDebug::flush();
if( cachedPlane &&
(cachedPlane->distance(position) > CUBIT_RESABS) )
delete cachedPlane;
cachedPlane = 0;
if (isBackwards)
new_tri1->is_backwards( 1 );
new_tri2->is_backwards( 1 );
return new_point;
| void FaceterFacetData::owner | ( | RefEntity * | owner | ) | [inline] |
Definition at line 36 of file FaceterFacetData.hpp.
| RefEntity* FaceterFacetData::owner | ( | ) | [inline] |
Definition at line 38 of file FaceterFacetData.hpp.
{return myOwner;}
| CubitPoint * FaceterFacetData::point | ( | int | index | ) | [inline, virtual] |
Definition at line 106 of file FaceterFacetData.hpp.
return pointArray[index];
else
switch(index)
case 0: return pointArray[0];
case 1: return pointArray[2];
case 2: return pointArray[1];
return NULL;
| virtual void FaceterFacetData::set_id | ( | int | ii | ) | [inline, virtual] |
| void FaceterFacetData::set_point | ( | CubitPoint * | the_point, |
| int | index | ||
| ) | [inline] |
Definition at line 54 of file FaceterFacetData.hpp.
{ pointArray[index] = the_point; }
| CubitPoint * FaceterFacetData::split_edge | ( | CubitPoint * | edge_pt1, |
| CubitPoint * | edge_pt2, | ||
| const CubitVector & | position | ||
| ) | [virtual] |
Definition at line 122 of file FaceterFacetData.cpp.
CubitPointData* new_pt = new CubitPointData(position);
// split triangles
DLIList<CubitFacet*> facets;
edge1_pt->shared_facets( edge2_pt, facets );
facets.reset();
for ( int i = facets.size(); i--; ) {
CubitFacet* facet = facets.get_and_step();
FaceterFacetData* facet_d = dynamic_cast<FaceterFacetData*>(facet);
assert(!!facet_d);
// fix up existing facet
int pt2_index = facet->point_index( edge2_pt );
bool edge_reversed = ( edge1_pt == facet->point( (pt2_index+1) % 3 ) );
int edge_index = (pt2_index + 2 - edge_reversed) % 3;
facet->update_plane();
edge2_pt->remove_facet( facet );
facet_d->set_point( new_pt, pt2_index );
new_pt->add_facet( facet );
// make new facet
CubitPoint* other_pt = facet->point( edge_index );
if ( edge_reversed )
new FaceterFacetData( other_pt, edge2_pt, new_pt );
else
new FaceterFacetData( other_pt, new_pt, edge2_pt );
return new_pt;
Definition at line 43 of file FaceterFacetData.hpp.
CubitFacetEdge* FaceterFacetData::edgeArray[3] [private] |
Definition at line 21 of file FaceterFacetData.hpp.
int FaceterFacetData::edgeUse[3] [private] |
Definition at line 22 of file FaceterFacetData.hpp.
int FaceterFacetData::entityId [private] |
Definition at line 25 of file FaceterFacetData.hpp.
MemoryManager FaceterFacetData::memoryManager [static, private] |
Definition at line 23 of file FaceterFacetData.hpp.
RefEntity* FaceterFacetData::myOwner [private] |
Definition at line 26 of file FaceterFacetData.hpp.
CubitPoint* FaceterFacetData::pointArray[3] [private] |
Definition at line 20 of file FaceterFacetData.hpp.
