cgma
#include <SplitCompositeSurfaceTool.hpp>
Public Member Functions | |
| CubitStatus | split_surface (RefFace *ref_face_ptr, DLIList< CubitVector * > &locations, DLIList< DLIList< CubitVector * > * > &vec_lists, CubitBoolean preview_flg=CUBIT_FALSE, CubitBoolean create_ref_edges_flg=CUBIT_FALSE, CubitBoolean clear_previous_previews=CUBIT_TRUE) |
| CubitStatus | split_surface (DLIList< RefFace * > &ref_face_list, DLIList< CubitVector * > &locations, DLIList< DLIList< DLIList< CubitVector * > * > * > &list_of_vec_lists, CubitBoolean preview_flg=CUBIT_FALSE, CubitBoolean create_ref_edges_flg=CUBIT_FALSE, CubitBoolean clear_previous_previews=CUBIT_TRUE) |
Static Public Member Functions | |
| static SplitCompositeSurfaceTool * | instance () |
| static void | delete_instance () |
Private Member Functions | |
| void | find_faces_for_pos (CubitVector &pos, DLIList< Surface * > surf_list, CubitPointContainment &containment, DLIList< Surface * > &out_list) |
| void | get_additional_split_points (Surface *surf, DLIList< DLIList< CubitVector * > * > &vec_lists) |
| void | find_face_with_non_zero_param_dir (DLIList< Surface * > &surf_list, CubitVector &dir, CubitVector &pos, Surface *&ret_surf, double &du, double &dv, double &step) |
Static Private Attributes | |
| static SplitCompositeSurfaceTool * | instance_ = NULL |
Definition at line 13 of file SplitCompositeSurfaceTool.hpp.
| static void SplitCompositeSurfaceTool::delete_instance | ( | ) | [inline, static] |
Definition at line 17 of file SplitCompositeSurfaceTool.hpp.
| void SplitCompositeSurfaceTool::find_face_with_non_zero_param_dir | ( | DLIList< Surface * > & | surf_list, |
| CubitVector & | dir, | ||
| CubitVector & | pos, | ||
| Surface *& | ret_surf, | ||
| double & | du, | ||
| double & | dv, | ||
| double & | step | ||
| ) | [private] |
Definition at line 189 of file SplitCompositeSurfaceTool.cpp.
int i;
ret_surf = NULL;
for(i=surf_list.size(); i>0 && !ret_surf; i--)
Surface *surf = surf_list.get_and_step();
CubitPointContainment cont = surf->point_containment(pos);
if(cont == CUBIT_PNT_INSIDE)
double ulow, uhigh, vlow, vhigh;
surf->param_dir(dir, pos, du, dv);
surf->get_param_range_U(ulow, uhigh);
surf->get_param_range_V(vlow, vhigh);
double u_len = fabs(ulow-uhigh);
double v_len = fabs(vlow-vhigh);
double par_tol;
if(u_len > v_len)
par_tol = v_len/100.0;
else
par_tol = u_len/100.0;
par_tol *= par_tol;
double len = du*du + dv*dv;
if(len > par_tol)
step = sqrt(u_len*u_len + v_len*v_len)/20.0;
ret_surf = surf;
else if(cont == CUBIT_PNT_BOUNDARY)
double par_tol;
if(u_len > v_len)
else
par_tol *= par_tol;
if(len > par_tol)
double u, v;
surf->u_v_from_position(pos, u, v);
CubitVector new_pos = surf->position_from_u_v(u+du, v+dv);
CubitPointContainment new_cont = surf->point_containment(new_pos);
if(new_cont == CUBIT_PNT_INSIDE)
ret_surf = surf;
| void SplitCompositeSurfaceTool::find_faces_for_pos | ( | CubitVector & | pos, |
| DLIList< Surface * > | surf_list, | ||
| CubitPointContainment & | containment, | ||
| DLIList< Surface * > & | out_list | ||
| ) | [private] |
Definition at line 52 of file SplitCompositeSurfaceTool.cpp.
int j;
for(j=surf_list.size(); j>0; j--)
Surface *surf_ptr = surf_list.get_and_step();
containment = surf_ptr->point_containment(pos);
if(containment == CUBIT_PNT_INSIDE || containment == CUBIT_PNT_BOUNDARY)
out_list.append_unique(surf_ptr);
| void SplitCompositeSurfaceTool::get_additional_split_points | ( | Surface * | surf, |
| DLIList< DLIList< CubitVector * > * > & | vec_lists | ||
| ) | [private] |
Definition at line 67 of file SplitCompositeSurfaceTool.cpp.
int i, j, k, num_surfs;
DLIList<Surface*> surf_list;
CompositeSurface *cs = dynamic_cast<CompositeSurface*>(surf);
if(cs && (num_surfs = cs->num_surfs()) > 1)
for(i=0; i<num_surfs; i++)
Surface *surf = cs->get_surface(i);
if(surf)
surf_list.append(surf);
DLIList<Curve*> hidden_curves;
cs->get_hidden_curves(hidden_curves);
for(i=vec_lists.size(); i--;)
// Remove any hidden curves that already have points on them.
DLIList<Curve*> hidden_curves_without_pts = hidden_curves;
DLIList<CubitVector*> *vec_list = vec_lists.get_and_step();
for(j=vec_list->size(); j--;)
CubitVector *cur_vec = vec_list->get_and_step();
DLIList<Curve*> crvs_to_remove;
for(k=hidden_curves_without_pts.size(); k>0; k--)
Curve *crv = hidden_curves_without_pts.get_and_step();
CubitVector foot;
crv->closest_point_trimmed(*cur_vec, foot);
if(foot.about_equal(*cur_vec))
crvs_to_remove.append_unique(crv);
hidden_curves_without_pts -= crvs_to_remove;
// Now we should only have hidden curves with no points on them.
if(hidden_curves_without_pts.size() > 0)
vec_list->reset();
CubitVector *cur_vec = vec_list->get();
CubitVector *last_vec = vec_list->prev();
while(cur_vec != last_vec)
vec_list->move_to(cur_vec);
CubitVector *next_vec = vec_list->next();
DLIList<CubitVector*> tmp_list;
DLIList<double> vals;
tmp_list.append(cur_vec);
tmp_list.append(next_vec);
vals.append(0.0);
vals.append(1.0);
Curve *hidden_curve = hidden_curves_without_pts.get();
CompositeCurve *cc = dynamic_cast<CompositeCurve*>(hidden_curve);
if(cc)
hidden_curve = cc->get_curve(0);
GeometryModifyEngine *gme = GeometryModifyTool::instance()->
get_engine(hidden_curve);
TBPoint *pt1 = gme->make_Point(*cur_vec);
TBPoint *pt2 = gme->make_Point(*last_vec);
Curve *tmp_crv = gme->make_Curve(STRAIGHT_CURVE_TYPE, pt1, pt2, NULL);
if(tmp_crv)
double arc_length = tmp_crv->get_arc_length();
for(j=hidden_curves_without_pts.size(); j--;)
CubitVector pos1, pos2;
double dist;
GeometryQueryTool::instance()->entity_entity_distance(crv, tmp_crv, pos1, pos2, dist);
CubitVector v1 = *cur_vec - pos1;
CubitVector v2 = *last_vec - pos1;
v1.normalize();
v2.normalize();
if(v1 % v2 < .3)
CubitVector *new_vec = new CubitVector(pos1);
v1 = (pt1->coordinates() - pos2);
double percent = v1.length()/arc_length;
if(percent > 1.0)
percent = 1.0;
if(percent < 0.0)
percent = 0.0;
tmp_list.reset();
vals.reset();
while(percent > vals.get())
vals.step();
tmp_list.step();
vals.back();
tmp_list.back();
vals.insert(percent);
tmp_list.insert(new_vec);
delete tmp_crv;
delete pt1;
delete pt2;
if(tmp_list.size() > 2)
tmp_list.reset();
tmp_list.step();
for(j=tmp_list.size(); j>2; j--)
vec_list->insert(tmp_list.get());
tmp_list.step();
cur_vec = next_vec;
| SplitCompositeSurfaceTool * SplitCompositeSurfaceTool::instance | ( | void | ) | [static] |
Definition at line 13 of file SplitCompositeSurfaceTool.cpp.
if (instance_ == NULL)
instance_ = new SplitCompositeSurfaceTool();
return instance_;
| CubitStatus SplitCompositeSurfaceTool::split_surface | ( | RefFace * | ref_face_ptr, |
| DLIList< CubitVector * > & | locations, | ||
| DLIList< DLIList< CubitVector * > * > & | vec_lists, | ||
| CubitBoolean | preview_flg = CUBIT_FALSE, |
| CubitBoolean | create_ref_edges_flg = CUBIT_FALSE, |
| CubitBoolean | clear_previous_previews = CUBIT_TRUE |
Definition at line 21 of file SplitCompositeSurfaceTool.cpp.
get_additional_split_points(ref_face_ptr->get_surface_ptr(), vec_lists);
return GeometryModifyTool::instance()->split_surface(ref_face_ptr,
locations, vec_lists, preview_flg, create_ref_edges_flg, clear_previous_previews);
| CubitStatus SplitCompositeSurfaceTool::split_surface | ( | DLIList< RefFace * > & | ref_face_list, |
| DLIList< DLIList< DLIList< CubitVector * > * > * > & | list_of_vec_lists, | ||
Definition at line 34 of file SplitCompositeSurfaceTool.cpp.
for( int jj = ref_face_list.size() ; jj > 0 ; jj--)
DLIList<DLIList<CubitVector*>*> vec_lists = *( list_of_vec_lists.get_and_step() );
get_additional_split_points(ref_face_list.get_and_step()->get_surface_ptr(), vec_lists );
return GeometryModifyTool::instance()->split_surface(ref_face_list,
locations, list_of_vec_lists, preview_flg, create_ref_edges_flg, clear_previous_previews);
SplitCompositeSurfaceTool * SplitCompositeSurfaceTool::instance_ = NULL [static, private] |
Definition at line 44 of file SplitCompositeSurfaceTool.hpp.
