cgma
#include <IntermediateGeomEngine.hpp>
Definition at line 14 of file IntermediateGeomEngine.hpp.
| virtual void IntermediateGeomEngine::attribute_after_imprinting | ( | DLIList< TopologyBridge * > & | tb_list, |
| DLIList< Body * > & | old_bodies | ||
| ) | [pure virtual] |
Implemented in PartitionEngine, and CompositeEngine.
| virtual void IntermediateGeomEngine::clean_out_deactivated_geometry | ( | ) | [pure virtual] |
| virtual CubitStatus IntermediateGeomEngine::export_geometry | ( | DLIList< TopologyBridge * > & | geometry_list | ) | [pure virtual] |
| virtual void IntermediateGeomEngine::get_tbs_with_bridge_manager_as_owner | ( | TopologyBridge * | source_bridge, |
| DLIList< TopologyBridge * > & | tbs | ||
| virtual CubitStatus IntermediateGeomEngine::import_geometry | ( | DLIList< TopologyBridge * > & | geometry_list | ) | [pure virtual] |
| virtual bool IntermediateGeomEngine::is_composite | ( | TBOwner * | bridge_owner | ) | [pure virtual] |
| virtual bool IntermediateGeomEngine::is_composite | ( | TopologyBridge * | bridge | ) | [pure virtual] |
| virtual bool IntermediateGeomEngine::is_partition | ( | TBOwner * | bridge_owner | ) | [pure virtual] |
| virtual int IntermediateGeomEngine::level | ( | ) | const [pure virtual] |
| virtual CubitStatus IntermediateGeomEngine::notify_transform | ( | TopologyBridge * | entity, |
| const CubitTransformMatrix & | xform | ||
| virtual void IntermediateGeomEngine::push_imprint_attributes_before_modify | ( | DLIList< BodySM * > & | body_sms | ) | [pure virtual] |
| virtual void IntermediateGeomEngine::push_named_attributes_to_curves_and_points | ( | DLIList< TopologyBridge * > & | tb_list, |
| const char * | name_in | ||
| virtual void IntermediateGeomEngine::remove_attributes | ( | DLIList< TopologyBridge * > & | bridge_list | ) | [pure virtual] |
| virtual void IntermediateGeomEngine::remove_attributes_from_unmodifed_virtual | ( | DLIList< TopologyBridge * > & | bridges | ) | [pure virtual] |
| virtual void IntermediateGeomEngine::remove_imprint_attributes_after_modify | ( | DLIList< BodySM * > & | old_sms, |
| DLIList< BodySM * > & | new_sms | ||
| virtual void IntermediateGeomEngine::remove_modified | ( | DLIList< Surface * > & | all_surfs, |
| DLIList< Curve * > & | all_curves, | ||
| DLIList< TBPoint * > & | all_pts | ||
