cgma
#include <CurveOverlapFacet.hpp>
Public Member Functions | |
| CurveOverlapFacet (GPoint pnt[2]) | |
| ~CurveOverlapFacet () | |
| double | distance_overlapping (CurveOverlapFacet *other_facet) |
| double | angle (CurveOverlapFacet *other_facet) |
| double | length () |
| bool | bbox_overlap (double tol, CurveOverlapFacet *other_facet) |
| double | facet_to_facet_distance (CurveOverlapFacet *other_facet) |
| void | draw (int color) |
| CubitVector | start_point () |
| CubitVector | end_point () |
Private Attributes | |
| CubitVector | p0 |
| CubitVector | p1 |
| CubitBox | boundingBox |
| double | facetLength |
Friends | |
| class | SurfaceOverlapTool |
Definition at line 16 of file CurveOverlapFacet.hpp.
| CurveOverlapFacet::CurveOverlapFacet | ( | GPoint | pnt[2] | ) |
Definition at line 14 of file CurveOverlapFacet.cpp.
p0.set( p[0].x, p[0].y, p[0].z);
p1.set( p[1].x, p[1].y, p[1].z);
CubitVector min;
min.set( CUBIT_MIN( p[0].x, p[1].x ),
CUBIT_MIN( p[0].y, p[1].y ),
CUBIT_MIN( p[0].z, p[1].z ) );
CubitVector max;
max.set( CUBIT_MAX( p[0].x, p[1].x ),
CUBIT_MAX( p[0].y, p[1].y ),
CUBIT_MAX( p[0].z, p[1].z ) );
boundingBox.reset( min, max );
facetLength = 0.0;
Definition at line 35 of file CurveOverlapFacet.cpp.
| double CurveOverlapFacet::angle | ( | CurveOverlapFacet * | other_facet | ) |
Definition at line 177 of file CurveOverlapFacet.cpp.
CubitVector vec1 = p1 - p0;
CubitVector vec2 = other_facet->p1 - other_facet->p0;
double angle = vec1.interior_angle( vec2 );
return angle;
| bool CurveOverlapFacet::bbox_overlap | ( | double | tol, |
| CurveOverlapFacet * | other_facet | ||
| ) | [inline] |
Definition at line 30 of file CurveOverlapFacet.hpp.
{ return boundingBox.overlap( tol, other_facet->boundingBox ); }
| double CurveOverlapFacet::distance_overlapping | ( | CurveOverlapFacet * | other_facet | ) |
Definition at line 39 of file CurveOverlapFacet.cpp.
//determine which is the smaller facet
CurveOverlapFacet *short_facet, *long_facet;
if( this->length() < other_facet->length() )
short_facet = this;
long_facet = other_facet;
else
short_facet = other_facet;
long_facet = this;
CubitVector long_facet_vector(long_facet->p1 - long_facet->p0);
double long_facet_length = long_facet_vector.length();
long_facet_vector.normalize();
CubitVector l_p0_to_s_p0( short_facet->p0 - long_facet->p0 );
CubitVector l_p0_to_s_p1( short_facet->p1 - long_facet->p0 );
double dot_to_s_p0 = l_p0_to_s_p0 % long_facet_vector;
double dot_to_s_p1 = l_p0_to_s_p1 % long_facet_vector;
//no overlap
if( ( dot_to_s_p0 <= 0.0 && dot_to_s_p1 <= 0.0) ||
( dot_to_s_p0 >= long_facet_length &&
dot_to_s_p1 >= long_facet_length ) )
return 0.0;
//overlap like this:
// o-----------o
// o---------------------o
if( dot_to_s_p0 > 0.0 && dot_to_s_p1 < 0.0 )
return dot_to_s_p0;
if( dot_to_s_p1 > 0.0 && dot_to_s_p0 < 0.0 )
return dot_to_s_p1;
if( dot_to_s_p0 > long_facet_length &&
dot_to_s_p1 < long_facet_length )
return long_facet_length - dot_to_s_p1;
if( dot_to_s_p1 > long_facet_length &&
dot_to_s_p0 < long_facet_length )
return long_facet_length - dot_to_s_p0;
//overlap like this
// o-----------o
// or this:
// o-----------o
// or this:
if( (dot_to_s_p0 <= long_facet_length &&
dot_to_s_p1 < long_facet_length ) ||
(dot_to_s_p1 <= long_facet_length &&
dot_to_s_p0 < long_facet_length ) )
return fabs( dot_to_s_p0 - dot_to_s_p1 );
return 0.0;
//create vectors
CubitVector v0( long_facet->p1 - long_facet->p0 );
CubitVector v1( short_facet->p0 - long_facet->p0 );
CubitVector v2( short_facet->p1 - long_facet->p0 );
CubitVector normalized_v0 = v0;
normalized_v0.normalize();
//project v1 and v2 onto v0
double dot1 = normalized_v0 % v1;
double dot2 = normalized_v0 % v2;
v1 = normalized_v0 * dot1;
v2 = normalized_v0 * dot2;
double length0 = v0.length();
double length1 = v1.length();
double length2 = v2.length();
//no overlap at all
if( (length1 > long_facet->length() && length2 > long_facet->length() ) ||
(dot1 <= 0 && dot2 <= 0 ) )
return 0.0;
else if( dot1 <= 0 && dot2 > 0 )
return length2;
else if( length2 <= 0 && length1 > 0 )
return length1;
else if( length1 > length0 )
return length0 - length2;
else if( length2 > length0 )
return length0 - length1;
//else
return fabs( length2 - length1 );
CubitVector tmp_vec1( p0.x, p0.y, p0.z);
CubitVector tmp_vec2( p1.x, p1.y, p1.z);
CubitVector tmp_vec3( other_facet->p0.x, other_facet->p0.y, other_facet->p0.z);
CubitVector tmp_vec4( other_facet->p1.x, other_facet->p1.y, other_facet->p1.z);
IntersectionTool int_tool( GEOMETRY_RESABS );
CubitVector closest_point_seg_1;
CubitVector closest_point_seg_2;
double sc, tc;
CubitStatus stat = int_tool.closest_points_on_segments( p0, p1,
other_facet->p0, other_facet->p1,
closest_point_seg_1, closest_point_seg_2,
sc, tc );
//Make sure the closest points aren't the end points. If they are
//and we are within tolerance, it may be that the tolerance is too big
//cause we shouldn't be at a cross if the closest point is an end point...
if ( sc > 0. && sc < 1. && tc > 0. && tc < 1. &&
closest_point_seg_1.within_tolerance(closest_point_seg_2, 0.001) )
return 0.0;
| void CurveOverlapFacet::draw | ( | int | color | ) |
Definition at line 275 of file CurveOverlapFacet.cpp.
GfxPreview::draw_line( p0, p1, color );
return;
Definition at line 286 of file CurveOverlapFacet.cpp.
return p1;
| double CurveOverlapFacet::facet_to_facet_distance | ( | CurveOverlapFacet * | other_facet | ) |
the lines are almost parallel
Definition at line 196 of file CurveOverlapFacet.cpp.
CubitVector u = p1 - p0;
CubitVector v = other_facet->p1 - other_facet->p0;
CubitVector w = p0 - other_facet->p0;
double a = u%u;
double b = u%v;
double c = v%v;
double d = u%w;
double e = v%w;
double D = a*c - b*b;
double sc, sN, sD = D;
double tc, tN, tD = D;
// compute the line parameters of the two closest points
if( D < GEOMETRY_RESABS )
sN = 0.0; // force using point P0 on segment S1
sD = 1.0; // to prevent possible division by 0.0 later
tN = e;
tD = c;
else // get the closest points on the infinite lines
sN = (b*e - c*d);
tN = (a*e - b*d);
if (sN < 0.0)
{ // sc < 0 => the s=0 edge is visible
sN = 0.0;
tN = e;
tD = c;
else if (sN > sD)
{ // sc > 1 => the s=1 edge is visible
sN = sD;
tN = e + b;
tD = c;
if (tN < 0.0)
{ // tc < 0 => the t=0 edge is visible
tN = 0.0;
// recompute sc for this edge
if (-d < 0.0)
sN = 0.0;
else if (-d > a)
sN = sD;
else
sN = -d;
sD = a;
else if (tN > tD)
{ // tc > 1 => the t=1 edge is visible
tN = tD;
if ((-d + b) < 0.0)
sN = 0;
else if ((-d + b) > a)
sN = sD;
else
sN = (-d + b);
sD = a;
// finally do the division to get sc and tc
sc = (fabs(sN) < GEOMETRY_RESABS ? 0.0 : sN / sD);
tc = (fabs(tN) < GEOMETRY_RESABS ? 0.0 : tN / tD);
// get the difference of the two closest points
CubitVector dP = w + (sc * u) - (tc * v); // = S1(sc) - S2(tc)
return dP.length(); // return the closest distance
| double CurveOverlapFacet::length | ( | ) |
Definition at line 186 of file CurveOverlapFacet.cpp.
if( facetLength == 0.0 )
CubitVector tmp_vec = p1 - p0;
facetLength = tmp_vec.length();
return facetLength;
Definition at line 281 of file CurveOverlapFacet.cpp.
return p0;
friend class SurfaceOverlapTool [friend] |
Definition at line 21 of file CurveOverlapFacet.hpp.
CubitBox CurveOverlapFacet::boundingBox [private] |
Definition at line 46 of file CurveOverlapFacet.hpp.
double CurveOverlapFacet::facetLength [private] |
Definition at line 47 of file CurveOverlapFacet.hpp.
CubitVector CurveOverlapFacet::p0 [private] |
Definition at line 44 of file CurveOverlapFacet.hpp.
CubitVector CurveOverlapFacet::p1 [private] |
Definition at line 45 of file CurveOverlapFacet.hpp.
