cgma
#include <TDOctreeRefEdge.hpp>
Public Member Functions | |
| TDOctreeRefEdge () | |
| ~TDOctreeRefEdge () | |
| CubitBoolean | get_visit (void) |
| void | set_visit (CubitBoolean type) |
| void | clean_gpoint_list (void) |
| void | set_mref_edge (RefEdge *ptr_mref_edge) |
| GPoint * | get_head_gpoint () |
| int | get_gpoint_list_length (void) |
| CubitBoolean | generate_gpoint_list (double decimation_ang) |
Static Public Member Functions | |
| static int | is_td_skl_mref_edge (const ToolData *td) |
| static CubitStatus | add_td (RefEdge *mref_edge) |
| static TDOctreeRefEdge * | get_td (RefEdge *mref_edge) |
| static void | decimate_curve_points_for_source_entity (GMem &point_data, double angle_tolerance, GMem &result_point_data) |
| static CubitBoolean | find_curve_curvature_using_three_points (CubitVector point_a, CubitVector point_b, CubitVector point_c, CubitVector &curvature) |
Private Attributes | |
| GMem * | resultPointData |
| RefEdge * | refEdge |
| CubitBoolean | visit |
Definition at line 21 of file TDOctreeRefEdge.hpp.
Definition at line 18 of file TDOctreeRefEdge.cpp.
resultPointData = new GMem;
visit = CUBIT_FALSE;
Definition at line 25 of file TDOctreeRefEdge.cpp.
clean_gpoint_list();
//PRINT_INFO("Inside ~TDOctreeRefEdge\n");
| CubitStatus TDOctreeRefEdge::add_td | ( | RefEdge * | mref_edge | ) | [static] |
Definition at line 43 of file TDOctreeRefEdge.cpp.
ToolData *td;
td = mref_edge->get_TD(&TDOctreeRefEdge::is_td_skl_mref_edge);
if ( td == NULL )
TDOctreeRefEdge *td_gm = new TDOctreeRefEdge;
mref_edge->add_TD( td_gm);
td_gm->set_mref_edge( mref_edge );
else
TDOctreeRefEdge *td_gm = CAST_TO(td, TDOctreeRefEdge);
return CUBIT_SUCCESS;
| void TDOctreeRefEdge::clean_gpoint_list | ( | void | ) |
Definition at line 30 of file TDOctreeRefEdge.cpp.
delete resultPointData;
| void TDOctreeRefEdge::decimate_curve_points_for_source_entity | ( | GMem & | point_data, |
| double | angle_tolerance, | ||
| GMem & | result_point_data | ||
| ) | [static] |
Definition at line 85 of file TDOctreeRefEdge.cpp.
// pointListCount instead of point_data.point_list_size() (they are different)
int num_pre_points = point_data.pointListCount;
// only decimate if we have more than 2 points
if(num_pre_points <= 2)
result_point_data = point_data;
return;
// get threshold value
const double threshold = cos( DEGREES_TO_RADIANS(angle_tolerance) );
// mark array for what to keep and throw
char* mark_array = new char[num_pre_points];
// zero means keep the point, non-zero means remove the point
memset(mark_array, 0, num_pre_points);
int num_points_to_keep = 2; // initialize to keep start and end points
int i;
GPoint* point_data_array = point_data.point_list();
// initialize first point
GPoint* pre_point = &(point_data_array[0]);
// traverse all but start and end points
for(i=1; i<(num_pre_points-1); i++)
// create two vectors
// one from i-1 to i and another from i to i+1
GPoint* point = &(point_data_array[i]);
GPoint* next_point = &(point_data_array[i+1]);
CubitVector v1(CubitVector(pre_point->x, pre_point->y, pre_point->z),
CubitVector(point->x, point->y, point->z));
v1.normalize();
CubitVector v2(CubitVector(point->x, point->y, point->z),
CubitVector(next_point->x, next_point->y, next_point->z));
v2.normalize();
// compute whether to keep the point
double dot_product = v1 % v2;
bool keep = dot_product > threshold ? false : true;
// if keep
if(keep)
num_points_to_keep++;
pre_point = point;
// if not keep
else
mark_array[i] = 1;
// make a new GPoint array
GPoint* new_point_list = new GPoint[num_points_to_keep];
int new_point_list_count = 0;
// copy points to keep into the new array
for(i=0; i<num_pre_points; i++)
if(mark_array[i] == 0)
new_point_list[new_point_list_count] = point_data_array[i];
new_point_list_count++;
delete [] mark_array;
assert(new_point_list_count == num_points_to_keep);
//printf("reduced points from %i to %i\n", num_pre_points, num_points_to_keep);
// put data into the result gmem
result_point_data.replace_point_list(new_point_list, new_point_list_count, new_point_list_count);
result_point_data.points_consolidated(CUBIT_TRUE);
| CubitBoolean TDOctreeRefEdge::find_curve_curvature_using_three_points | ( | CubitVector | point_a, |
| CubitVector | point_b, | ||
| CubitVector | point_c, | ||
| CubitVector & | curvature | ||
| ) | [static] |
Definition at line 189 of file TDOctreeRefEdge.cpp.
CubitVector vec_ba, vec_bc;
vec_ba = point_a - point_b;
vec_bc = point_c - point_b;
// Squares of lengths of the edges incident to `a'.
double ba_length = vec_ba.length_squared();
double bc_length = vec_bc.length_squared();
// Cross product of these edges.
// (Take your chances with floating-point roundoff.)
CubitVector cross = vec_ba * vec_bc;
// Calculate the denominator of the formulae.
double denominator = 0.5 / (cross % cross);
assert(denominator != 0.0);
// Calculate offset (from `a') of circumcenter.
CubitVector circle_center = (ba_length * vec_bc - bc_length * vec_ba) * cross;
circle_center *= denominator;
//store radius
double radius = circle_center.length();
circle_center.normalize();
circle_center /= radius;
curvature = circle_center;
return CUBIT_TRUE;
| CubitBoolean TDOctreeRefEdge::generate_gpoint_list | ( | double | decimation_ang | ) |
Definition at line 169 of file TDOctreeRefEdge.cpp.
// get facets from cgm
GMem point_data;
refEdge->get_graphics( point_data );
// decimate the facets to the resolution we want
TDOctreeRefEdge::decimate_curve_points_for_source_entity( point_data, decimation_ang, *resultPointData);
return CUBIT_TRUE;
| int TDOctreeRefEdge::get_gpoint_list_length | ( | void | ) | [inline] |
Definition at line 51 of file TDOctreeRefEdge.hpp.
{ return resultPointData->pointListCount; }
| GPoint* TDOctreeRefEdge::get_head_gpoint | ( | ) | [inline] |
Definition at line 49 of file TDOctreeRefEdge.hpp.
{ return resultPointData->point_list(); }
| TDOctreeRefEdge * TDOctreeRefEdge::get_td | ( | RefEdge * | mref_edge | ) | [static] |
Definition at line 70 of file TDOctreeRefEdge.cpp.
ToolData *td;
if ( td != NULL )
return td_gm;
return (TDOctreeRefEdge*) NULL;
| CubitBoolean TDOctreeRefEdge::get_visit | ( | void | ) | [inline] |
Definition at line 39 of file TDOctreeRefEdge.hpp.
{ return visit; }
| static int TDOctreeRefEdge::is_td_skl_mref_edge | ( | const ToolData * | td | ) | [inline, static] |
Definition at line 47 of file TDOctreeRefEdge.hpp.
{return (CAST_TO(const_cast<ToolData*>(td), TDOctreeRefEdge) != NULL);}
| void TDOctreeRefEdge::set_mref_edge | ( | RefEdge * | ptr_mref_edge | ) | [inline] |
Definition at line 45 of file TDOctreeRefEdge.hpp.
{ refEdge = ptr_mref_edge; }
| void TDOctreeRefEdge::set_visit | ( | CubitBoolean | type | ) | [inline] |
Definition at line 40 of file TDOctreeRefEdge.hpp.
{ visit = type; }
RefEdge* TDOctreeRefEdge::refEdge [private] |
Definition at line 28 of file TDOctreeRefEdge.hpp.
GMem* TDOctreeRefEdge::resultPointData [private] |
Definition at line 27 of file TDOctreeRefEdge.hpp.
CubitBoolean TDOctreeRefEdge::visit [private] |
Definition at line 29 of file TDOctreeRefEdge.hpp.
