cgma
00001 //- Class: TDOctreeRefEdge 00002 //- Description: Tool data for storing additional information needed for generating line source entities. 00003 //- Owner: W. R. Quadors 00004 //- Checked by: 00005 //- Version: 00006 #include "TDOctreeRefEdge.hpp" 00007 #include "CubitDefines.h" 00008 #include "ToolData.hpp" 00009 #include "MemoryManager.hpp" 00010 #include "DLIList.hpp" 00011 #include "CastTo.hpp" 00012 #include "RefEdge.hpp" 00013 #include "GMem.hpp" 00014 00015 00016 00017 // Constructor 00018 TDOctreeRefEdge::TDOctreeRefEdge(){ 00019 resultPointData = new GMem; 00020 visit = CUBIT_FALSE; 00021 } 00022 00023 00024 // Distructor 00025 TDOctreeRefEdge::~TDOctreeRefEdge(){ 00026 clean_gpoint_list(); 00027 //PRINT_INFO("Inside ~TDOctreeRefEdge\n"); 00028 } 00029 00030 void TDOctreeRefEdge::clean_gpoint_list(){ 00031 delete resultPointData; 00032 } 00033 00034 //------------------------------------------------------------------------- 00035 // Purpose : To create TDOctreeRefEdge to MRefFace 00036 // 00037 // Special Notes : 00038 // 00039 // Creator : W R Quadros 00040 // 00041 // Creation Date : 07/03 00042 //------------------------------------------------------------------------- 00043 CubitStatus TDOctreeRefEdge::add_td( RefEdge *mref_edge ) 00044 { 00045 ToolData *td; 00046 td = mref_edge->get_TD(&TDOctreeRefEdge::is_td_skl_mref_edge); 00047 if ( td == NULL ) 00048 { 00049 TDOctreeRefEdge *td_gm = new TDOctreeRefEdge; 00050 mref_edge->add_TD( td_gm); 00051 td_gm->set_mref_edge( mref_edge ); 00052 } 00053 else 00054 { 00055 TDOctreeRefEdge *td_gm = CAST_TO(td, TDOctreeRefEdge); 00056 td_gm->set_mref_edge( mref_edge ); 00057 } 00058 return CUBIT_SUCCESS; 00059 } 00060 00061 //------------------------------------------------------------------------- 00062 // Purpose : get the TDOctreeRefEdge for a RefEdge 00063 // 00064 // Special Notes : 00065 // 00066 // Creator : W R Quadros 00067 // 00068 // Creation Date : 07/03 00069 //------------------------------------------------------------------------- 00070 TDOctreeRefEdge* TDOctreeRefEdge::get_td( RefEdge *mref_edge ) 00071 { 00072 ToolData *td; 00073 td = mref_edge->get_TD(&TDOctreeRefEdge::is_td_skl_mref_edge); 00074 if ( td != NULL ) 00075 { 00076 TDOctreeRefEdge *td_gm = CAST_TO(td, TDOctreeRefEdge); 00077 return td_gm; 00078 } 00079 return (TDOctreeRefEdge*) NULL; 00080 } 00081 00082 // curve decimating function 00083 // takes in points to decimate based on an angle_tolerance in degrees 00084 // and puts results into the result point data 00085 void TDOctreeRefEdge::decimate_curve_points_for_source_entity(GMem& point_data, double angle_tolerance, GMem& result_point_data) 00086 { 00087 // pointListCount instead of point_data.point_list_size() (they are different) 00088 int num_pre_points = point_data.pointListCount; 00089 00090 // only decimate if we have more than 2 points 00091 if(num_pre_points <= 2) 00092 { 00093 result_point_data = point_data; 00094 return; 00095 } 00096 00097 // get threshold value 00098 const double threshold = cos( DEGREES_TO_RADIANS(angle_tolerance) ); 00099 00100 // mark array for what to keep and throw 00101 char* mark_array = new char[num_pre_points]; 00102 // zero means keep the point, non-zero means remove the point 00103 memset(mark_array, 0, num_pre_points); 00104 00105 int num_points_to_keep = 2; // initialize to keep start and end points 00106 00107 int i; 00108 GPoint* point_data_array = point_data.point_list(); 00109 // initialize first point 00110 GPoint* pre_point = &(point_data_array[0]); 00111 // traverse all but start and end points 00112 for(i=1; i<(num_pre_points-1); i++) 00113 { 00114 00115 // create two vectors 00116 // one from i-1 to i and another from i to i+1 00117 GPoint* point = &(point_data_array[i]); 00118 GPoint* next_point = &(point_data_array[i+1]); 00119 00120 CubitVector v1(CubitVector(pre_point->x, pre_point->y, pre_point->z), 00121 CubitVector(point->x, point->y, point->z)); 00122 v1.normalize(); 00123 00124 CubitVector v2(CubitVector(point->x, point->y, point->z), 00125 CubitVector(next_point->x, next_point->y, next_point->z)); 00126 v2.normalize(); 00127 00128 // compute whether to keep the point 00129 double dot_product = v1 % v2; 00130 00131 bool keep = dot_product > threshold ? false : true; 00132 00133 // if keep 00134 if(keep) 00135 { 00136 num_points_to_keep++; 00137 pre_point = point; 00138 } 00139 // if not keep 00140 else 00141 { 00142 mark_array[i] = 1; 00143 } 00144 } 00145 00146 // make a new GPoint array 00147 GPoint* new_point_list = new GPoint[num_points_to_keep]; 00148 int new_point_list_count = 0; 00149 // copy points to keep into the new array 00150 for(i=0; i<num_pre_points; i++) 00151 { 00152 if(mark_array[i] == 0) 00153 { 00154 new_point_list[new_point_list_count] = point_data_array[i]; 00155 new_point_list_count++; 00156 } 00157 } 00158 00159 delete [] mark_array; 00160 00161 assert(new_point_list_count == num_points_to_keep); 00162 //printf("reduced points from %i to %i\n", num_pre_points, num_points_to_keep); 00163 00164 // put data into the result gmem 00165 result_point_data.replace_point_list(new_point_list, new_point_list_count, new_point_list_count); 00166 result_point_data.points_consolidated(CUBIT_TRUE); 00167 } 00168 00169 CubitBoolean TDOctreeRefEdge::generate_gpoint_list( double decimation_ang ) 00170 { 00171 // get facets from cgm 00172 GMem point_data; 00173 refEdge->get_graphics( point_data ); 00174 // decimate the facets to the resolution we want 00175 00176 TDOctreeRefEdge::decimate_curve_points_for_source_entity( point_data, decimation_ang, *resultPointData); 00177 00178 return CUBIT_TRUE; 00179 } 00180 00181 00182 00183 //====================================================================== 00184 // Description: return curvature at a point on the edge 00185 // Author: sjowen 00186 // Modified: W R Quadros 00187 // Date: 01/2005 00188 //====================================================================== 00189 CubitBoolean TDOctreeRefEdge::find_curve_curvature_using_three_points(CubitVector point_a, CubitVector point_b, CubitVector point_c, CubitVector &curvature ){ 00190 00191 00192 CubitVector vec_ba, vec_bc; 00193 00194 vec_ba = point_a - point_b; 00195 vec_bc = point_c - point_b; 00196 00197 // Squares of lengths of the edges incident to `a'. 00198 double ba_length = vec_ba.length_squared(); 00199 double bc_length = vec_bc.length_squared(); 00200 00201 // Cross product of these edges. 00202 // (Take your chances with floating-point roundoff.) 00203 CubitVector cross = vec_ba * vec_bc; 00204 00205 // Calculate the denominator of the formulae. 00206 double denominator = 0.5 / (cross % cross); 00207 assert(denominator != 0.0); 00208 00209 // Calculate offset (from `a') of circumcenter. 00210 CubitVector circle_center = (ba_length * vec_bc - bc_length * vec_ba) * cross; 00211 circle_center *= denominator; 00212 00213 //store radius 00214 double radius = circle_center.length(); 00215 circle_center.normalize(); 00216 circle_center /= radius; 00217 00218 curvature = circle_center; 00219 return CUBIT_TRUE; 00220 } 00221 00222 // EOF 00223 00224 00225
