cgma
#include "iGeom.h"#include <iostream>#include <set>#include <algorithm>#include <vector>#include <iomanip>#include <assert.h>#include <string.h>#include <math.h>Go to the source code of this file.
Classes | |
| class | SimpleArray< T > |
Defines | |
| #define | CHECK(STR) if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ ) |
| #define | STRINGIFY(S) XSTRINGIFY(S) |
| #define | XSTRINGIFY(S) #S |
| #define | ARRAY_INOUT(A) A.ptr(), &A.capacity(), &A.size() |
| #define | ARRAY_IN(A) &A[0], A.size() |
Typedefs | |
| typedef iBase_TagHandle | TagHandle |
| typedef iBase_EntityHandle | GentityHandle |
| typedef iBase_EntitySetHandle | GentitysetHandle |
Functions | |
| static bool | print_error (const char *desc, int err, iGeom_Instance geom, const char *file, int line) |
| int | main (int argc, char *argv[]) |
| #define ARRAY_IN | ( | A | ) | &A[0], A.size() |
Definition at line 87 of file mergetest.cc.
| #define ARRAY_INOUT | ( | A | ) | A.ptr(), &A.capacity(), &A.size() |
Definition at line 86 of file mergetest.cc.
| #define CHECK | ( | STR | ) | if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ ) |
Definition at line 18 of file mergetest.cc.
| #define STRINGIFY | ( | S | ) | XSTRINGIFY(S) |
Definition at line 20 of file mergetest.cc.
| #define XSTRINGIFY | ( | S | ) | #S |
Definition at line 21 of file mergetest.cc.
| typedef iBase_EntityHandle GentityHandle |
Definition at line 43 of file mergetest.cc.
Definition at line 44 of file mergetest.cc.
| typedef iBase_TagHandle TagHandle |
Definition at line 42 of file mergetest.cc.
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 89 of file mergetest.cc.
// Check command line arg
#ifdef FORCE_OCC
#ifndef HAVE_OCC
#error "Cannot force use of OCC w/out OCC support"
#endif
std::string filename = STRINGIFY(SRCDIR) "/voltest.stp";
std::string outfile = "merged.occ";
std::string engine_opt = ";engine=OCC";
#elif defined(HAVE_OCC)
#else
std::cerr << "for facet engine merge is not supported\n";
return 1;
#endif
if (argc == 1) {
std::cout << "Using default input file: " << filename << std::endl;
std::cout << "Using default output file: " << outfile << std::endl;
else if (argc >= 3) {
filename = argv[1];
outfile = argv[2];
else {
std::cerr << "Usage: " << argv[0] << " [geom_filename] [out file]" << std::endl;
return 1;
// initialize geom
int err;
iGeom_Instance geom;
iGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() );
// Print out Header information
std::cout << "\n merge utility :\n\n";
iGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
CHECK( "ERROR : can not load a geometry" );
iBase_EntitySetHandle root_set;
iGeom_getRootSet( geom, &root_set, &err );
CHECK( "ERROR : getRootSet failed!" );
// print out the number of entities
std::cout << "Model contents: " << std::endl;
const char *gtype[] = {"vertices: ", "edges: ", "faces: ", "regions: "};
for (int i = 0; i <= 3; ++i) {
int count;
iGeom_getNumOfType( geom, root_set, i, &count, &err );
CHECK( "Error: problem getting entities after gLoad." );
std::cout << gtype[i] << count << std::endl;
// get volumes, and call merge
int count;
iGeom_getNumOfType( geom, root_set, 3, &count, &err );
CHECK( "Error: problem getting volume numbers after gLoad." );
SimpleArray<iBase_EntityHandle> vols;
iGeom_getEntities( geom, root_set, 3, ARRAY_INOUT(vols), &err );
CHECK( "Error: problem getting volumes." );
// now imprint
std::cout << "\n\nImprinting...." << std::endl;
iGeom_imprintEnts(geom, ARRAY_IN(vols),&err);
CHECK( "Error: problem imprinting volumes." );
std::cout << "\n\nMerging...." << std::endl;
double dTol = 1e-4;
iGeom_mergeEnts(geom, ARRAY_IN(vols), dTol, &err);
CHECK( "Error: problem merging volumes." );
iGeom_save(geom, outfile.c_str(), NULL, &err,
strlen(outfile.c_str()), 0);
CHECK( "Error: problem saving." );
return 0;
| static bool print_error | ( | const char * | desc, |
| int | err, | ||
| iGeom_Instance | geom, | ||
| const char * | file, | ||
| int | line | ||
| ) | [static] |
Definition at line 23 of file mergetest.cc.
char buffer[1024];
iGeom_getDescription( geom, buffer, sizeof(buffer) );
buffer[sizeof(buffer)-1] = '\0';
std::cerr << "ERROR: " << desc << std::endl
<< " Error code: " << err << std::endl
<< " Error desc: " << buffer << std::endl
<< " At : " << file << ':' << line << std::endl
return false; // must always return false or CHECK macro will break
