cgma
facets, a simple facet-based C++ driver for CGM More...
#include <math.h>#include "AppUtil.hpp"#include "CGMApp.hpp"#include "GeometryQueryTool.hpp"#include "FacetModifyEngine.hpp"#include "FacetQueryEngine.hpp"#include "CubitObserver.hpp"#include "CubitPointData.hpp"#include "CubitFacetData.hpp"#include "TopologyBridge.hpp"#include "DLIList.hpp"#include "Surface.hpp"#include "ShellSM.hpp"#include "Lump.hpp"#include "Body.hpp"#include "RefFace.hpp"#include "RefVertex.hpp"Go to the source code of this file.
Functions | |
| void | gl_cleanup () |
| int | main (int argc, char **argv) |
| main program - initialize, then send to proper function | |
Definition in file facets.cpp.
| void gl_cleanup | ( | ) |
Definition at line 31 of file facets.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 35 of file facets.cpp.
if (argc == 1) {
PRINT_INFO("Usage: facets <angle_val>\n"
" where <angle_val> is the facet dihedral angle below which a\n"
" model edge will be constructed.\n");
return 0;
// first argument should be an angle
double angle = atof(argv[1]);
// Initialize the GeometryTool
GeometryQueryTool *gqt = GeometryQueryTool::instance();
FacetModifyEngine *fme = FacetModifyEngine::instance();
DLIList<CubitFacet*> f_list;
DLIList <CubitPoint*> p_list;
// define some really simple facets, corresponding to the
// facets for a brick
typedef CubitPointData CPD; typedef CubitFacetData CFD;
CPD *p1 = new CPD(0, 0, 0); CPD *p2 = new CPD(1, 0, 0);
CPD *p3 = new CPD(1, 1, 0); CPD *p4 = new CPD(0, 1, 0);
CPD *p5 = new CPD(0, 0, 1); CPD *p6 = new CPD(1, 0, 1);
CPD *p7 = new CPD(1, 1, 1); CPD *p8 = new CPD(0, 1, 1);
p_list.append(p1); p_list.append(p2);
p_list.append(p3); p_list.append(p4);
p_list.append(p5); p_list.append(p6);
p_list.append(p7); p_list.append(p8);
CFD *f1 = new CFD(p1,p3,p2); CFD *f2 = new CFD(p1,p4,p3); // xy-
CFD *f3 = new CFD(p5,p6,p8); CFD *f4 = new CFD(p6,p7,p8); // xy+
CFD *f5 = new CFD(p1,p8,p4); CFD *f6 = new CFD(p1,p5,p8); // yz-
CFD *f7 = new CFD(p3,p7,p6); CFD *f8 = new CFD(p3,p6,p2); // yz+
CFD *f9 = new CFD(p1,p6,p5); CFD *f10 = new CFD(p1,p2,p6); // xz-
CFD *f11 = new CFD(p3,p4,p8); CFD *f12 = new CFD(p3,p8,p7); // xz+
f_list.append(f1); f_list.append(f2); f_list.append(f3);
f_list.append(f4); f_list.append(f5); f_list.append(f6);
f_list.append(f7); f_list.append(f8); f_list.append(f9);
f_list.append(f10); f_list.append(f11); f_list.append(f12);
DLIList<LoopSM*> my_loops;
DLIList<Surface*> surf_list;
CubitStatus result;
result = fme->build_facet_surface(NULL, f_list, p_list, angle, 4,
false, false, surf_list);
if ( surf_list.size() == 0 || result != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based surfaces.\n");
return result;
else
PRINT_INFO("Constructed %d surfaces.\n", surf_list.size());
//Now build the shell. If we had it set up right this would be
//in a loop. We need to store list of DLBlockSurfaceLists on each
//blockvolumemesh to store the shell information. But that will
//be saved for later.
ShellSM *shell_ptr;
result = fme->make_facet_shell(surf_list, shell_ptr);
if ( shell_ptr == NULL || result != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based shell entity.\n");
return result;
DLIList<ShellSM*> shell_list;
shell_list.append(shell_ptr);
Lump *lump_ptr;
result = fme->make_facet_lump(shell_list, lump_ptr);
if ( lump_ptr == NULL || result != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based lump entity.\n");
return result;
DLIList<Lump*> lump_list;
lump_list.append(lump_ptr);
BodySM *bodysm_ptr;
Body *body_ptr;
result = fme->make_facet_body(lump_list, bodysm_ptr);
body_ptr = GeometryQueryTool::instance()->make_Body(bodysm_ptr);
if ( body_ptr == NULL || result != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based body entity.\n");
return result;
if (!body_ptr) {
exit(1);
PRINT_INFO("Body successfully created.\n");
PRINT_INFO("Number of vertices = %d\n", gqt->num_ref_vertices());
PRINT_INFO("Number of edges = %d\n", gqt->num_ref_edges());
PRINT_INFO("Number of faces = %d\n", gqt->num_ref_faces());
PRINT_INFO("Number of volumes = %d\n", gqt->num_ref_volumes());
PRINT_INFO("Number of bodies = %d\n", gqt->num_bodies());
// print vertex positions
DLIList<RefVertex*> verts;
gqt->ref_vertices(verts);
int i;
for (i = verts.size(); i > 0; i--) {
CubitVector coords = verts.get_and_step()->coordinates();
PRINT_INFO("Vertex %d: %4.2f, %4.2f, %4.2f.\n",
8-i, coords.x(), coords.y(), coords.z());
RefFace *face = gqt->get_first_ref_face();
// find closest point on each coordinate plane face center
CubitVector test_position, result_position, normal;
test_position.set(.5, .5, 0);
face->find_closest_point_trimmed(test_position, result_position);
normal = face->normal_at(result_position);
PRINT_INFO("Point (%4.2f, %4.2f, %4.2f):\n "
"closest=(%4.2f, %4.2f, %4.2f), normal=(%4.2f, %4.2f, %4.2f).\n",
test_position.x(), test_position.y(), test_position.z(),
result_position.x(), result_position.y(), result_position.z(),
normal.x(), normal.y(), normal.z());
test_position.set(.5, .5, 1);
test_position.set(.5, 0, .5);
test_position.set(.5, 1, .5);
test_position.set(0, .5, .5);
test_position.set(1, .5, .5);
double a = 1.0/3.0;
double b = 1.0/3.0;
double c = 1.0/3.0;
CubitVector temp_point(a,b,c);
CubitVector eval_point;
f1->evaluate( temp_point, &eval_point );
PRINT_INFO("Evaluation of facet 1 at (%4.2f, %4.2f, %4.2f) is "
"(%4.2f, %4.2f, %4.2f).\n",
a, b, c, eval_point.x(), eval_point.y(), eval_point.z() );
a = 0.0; b = 1.0; c = 0.0;
temp_point.set(a,b,c);
f2->evaluate( temp_point, &eval_point );
PRINT_INFO("Evaluation of facet 2 at (%4.2f, %4.2f, %4.2f) is (%4.2f, %4.2f, %4.2f).\n",
a = 0.5; b = 0.5; c = 0.0;
f3->evaluate( temp_point, &eval_point );
PRINT_INFO("Evaluation of facet 3 at (%4.2f, %4.2f, %4.2f) is (%4.2f, %4.2f, %4.2f).\n",
a = 0.0; b = 0.5; c = 0.5;
f4->evaluate( temp_point, &eval_point );
PRINT_INFO("Evaluation of facet 4 at (%4.2f, %4.2f, %4.2f) is (%4.2f, %4.2f, %4.2f).\n",
int ret_val = ( CubitMessage::instance()->error_count() );
FacetQueryEngine * fqe = FacetQueryEngine::instance();
DLIList<TopologyBridge*> model;
model.append( (TopologyBridge*)bodysm_ptr);
ModelExportOptions opts;
const char *arg = "brick.facet";
fqe->export_solid_model(
model, arg, FACET_TYPE,
CubitString(), opts);
PRINT_INFO( "Wrote %s \n", arg);
return ret_val;
