cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetModifyEngine.hpp 00003 // 00004 // Purpose : ModifyEngine for faceted geometry 00005 // 00006 // Special Notes : Modeled after GeometryModifyEngine and OCCModifyEngine. 00007 // 00008 // Creator : John Fowler 00009 // 00010 // Creation Date : 6/02 00011 // 00012 // Owner : John Fowler 00013 //------------------------------------------------------------------------- 00014 00015 #ifndef FACET_MODIFY_ENGINE_HPP 00016 #define FACET_MODIFY_ENGINE_HPP 00017 00018 #include "GeometryModifyEngine.hpp" 00019 #include <vector> 00020 #include <map> 00021 00022 class TBPoint; 00023 class TopologyBridge; 00024 class TopologyEntity; 00025 class ChollaSurface; 00026 class ChollaCurve; 00027 class ChollaPoint; 00028 class ChollaEngine; 00029 class CurveFacetEvalTool; 00030 class FacetEvalTool; 00031 class CubitPoint; 00032 class CubitFacet; 00033 class CubitFacetEdge; 00034 class CubitQuadFacet; 00035 class TBPoint; 00036 class CoEdgeSM; 00037 class ShellSM; 00038 class FacetBody; 00039 class Body; 00040 class RefFace; 00041 class FacetSurface; 00042 class FacetCurve; 00043 class FacetPoint; 00044 class CubitEvaluatorData; 00045 class SphereEvaluatorData; 00046 class CylinderEvaluatorData; 00047 00048 class FacetModifyEngine : public GeometryModifyEngine 00049 { 00050 00051 public: 00052 00053 //HEADER- Constructor and Destructor 00054 private: 00055 00056 FacetModifyEngine(); 00057 00058 static FacetModifyEngine* instance_; 00059 00060 public: 00061 00062 static inline FacetModifyEngine* instance() 00063 { 00064 if( !instance_ ) 00065 instance_ = new FacetModifyEngine; 00066 return instance_; 00067 } 00068 00069 static void initialize_settings(); 00070 00071 virtual ~FacetModifyEngine(); 00072 //- virtual destructor 00073 00074 virtual bool supports_interoperability() { return false; } 00075 //- Returns whether intermixing of real and virtual geometry operations 00076 //- is supported for the current geometry kernel. 00077 00078 virtual bool supports_facets() { return true; } 00079 00080 virtual TBPoint* make_Point( CubitVector const& point) const ; 00081 00082 virtual Curve* make_Curve(Curve *curve_ptr, 00083 std::map<TopologyBridge*, TopologyBridge*> *old_tb_to_new_tb = NULL) const; 00084 //- creates a curve from an existing curve. This creates totally 00085 //- new topology. This function is useful for constructing geometry 00086 //- from existing geometry. 00087 00088 virtual Curve* make_Curve( TBPoint const* point1_ptr, 00089 TBPoint const* point2_ptr, 00090 Surface* ref_face_ptr, 00091 const CubitVector *third_point = NULL) const; 00092 //- Create a curve exactly on the give ref_face. 00093 //- Make sure the points are on the underlying surface. 00094 00095 virtual Curve* make_Curve( GeometryType curve_type, 00096 TBPoint const* point1_ptr, 00097 TBPoint const* point2_ptr, 00098 DLIList<CubitVector*>& vector_list, 00099 Surface* ref_face_ptr = NULL) const; 00100 00101 virtual Curve* make_Curve( GeometryType curve_type, 00102 TBPoint const* point1_ptr, 00103 TBPoint const* point2_ptr, 00104 CubitVector const* intermediate_point_ptr) const; 00105 00106 virtual Curve* make_Curve( DLIList<CubitVector*>& point_list, 00107 DLIList<CubitVector*>& point_tangents) const; 00108 00109 00110 virtual Surface* make_Surface( Surface *old_surface_ptr, 00111 std::map< TopologyBridge*, TopologyBridge* > *old_tb_to_new_tb = NULL) const; 00112 00113 virtual BodySM* make_extended_sheet( DLIList<Surface*> &surface_list, 00114 CubitBox *clip_box = NULL, 00115 bool preview = false ) const; 00116 00117 #ifdef KCM_MESH_TO_GEOM 00118 virtual CubitStatus mesh2brep(std::vector<double> &xvals, 00119 std::vector<double> &yvals, 00120 std::vector<double> &zvals, 00121 std::vector<unsigned int> &tri_connectivity, 00122 DLIList<BodySM*> &new_body_sms) const; 00123 #endif 00124 00125 virtual Surface* make_Surface( GeometryType surface_type, 00126 DLIList<Curve*>& curve_list, 00127 Surface *old_surface_ptr = NULL, 00128 bool check_edges = true ) const; 00129 00130 virtual Lump* make_Lump( DLIList<Surface*>& surface_list ) const; 00131 00132 //virtual Body *make_Body(Surface *) const; 00133 00134 virtual BodySM* make_BodySM( Surface * ) const; 00135 00136 virtual BodySM* make_BodySM( DLIList<Lump*>& /*lump_list*/ ) const; 00137 00138 //virtual Chain *make_Chain(Curve *) const; 00139 00140 virtual BodySM* sphere(double radius) const ; 00141 00142 virtual BodySM* brick( double wid, double dep, double hi ) const ; 00143 00144 virtual BodySM* brick( const CubitVector ¢er, 00145 const CubitVector axes[3], 00146 const CubitVector &extension) const ; 00147 00148 virtual BodySM* prism( double height, int sides, double major, 00149 double minor) const ; 00150 00151 virtual BodySM* pyramid( double height, int sides, double major, 00152 double minor, double top=0.0) const ; 00153 00154 virtual BodySM* cylinder( double hi, double r1, double r2, 00155 double r3 ) const ; 00156 00157 virtual BodySM* torus( double r1, double r2 ) const ; 00158 00159 virtual BodySM* planar_sheet ( const CubitVector& p1, 00160 const CubitVector& p2, 00161 const CubitVector& p3, 00162 const CubitVector& p4 ) const; 00163 00164 virtual BodySM* copy_body( BodySM* body_sm, 00165 std::map<TopologyBridge*, TopologyBridge*> *old_tb_to_new_tb = NULL ) const; 00166 /* 00167 virtual CubitStatus stitch_surfs( 00168 DLIList<BodySM*>& surf_bodies, 00169 BodySM*& stitched_body)const; 00170 */ 00171 virtual BodySM* create_body( VolumeFacets& volume, std::map<FacetShapes*, GeometryEntity*>& entity_map, 00172 const FacetPointSet& points, int interp_order) const; 00173 00174 virtual CubitStatus subtract(DLIList<BodySM*> &tool_body_list, 00175 DLIList<BodySM*> &from_bodies, 00176 DLIList<BodySM*> &new_bodies, 00177 bool imprint = false, 00178 bool keep_old = false) const; 00179 00180 virtual CubitStatus imprint(BodySM* BodyPtr1, BodySM* BodyPtr2, 00181 BodySM*& newBody1, BodySM*& newBody2, 00182 bool keep_old) const; 00183 00184 virtual CubitStatus imprint(DLIList<BodySM*> &from_body_list, 00185 DLIList<BodySM*> &new_from_body_list, 00186 bool keep_old, DLIList<TopologyBridge*> *new_tbs = NULL, 00187 DLIList<TopologyBridge*> *att_tbs = NULL) const; 00188 00189 virtual CubitStatus imprint( DLIList<BodySM*> &body_list, 00190 DLIList<Curve*> &ref_edge_list, 00191 DLIList<BodySM*>& new_body_list, 00192 DLIList<TopologyBridge*> &temporary_bridges, 00193 bool keep_old_body, 00194 bool show_messages=CUBIT_TRUE) const; 00195 00196 virtual CubitStatus imprint( DLIList<Surface*> &ref_face_list, 00197 DLIList<Curve*> &ref_edge_list, 00198 DLIList<TopologyBridge*> &temporary_bridges, 00199 DLIList<BodySM*>& new_body_list, 00200 bool keep_old_body ) const; 00201 00202 virtual CubitStatus imprint( DLIList<Surface*> &surface_list, 00203 DLIList<DLIList<Curve*>*> &curve_lists_list, 00204 BodySM*& new_body, 00205 bool keep_old_body, 00206 bool expand = true, 00207 DLIList<TopologyBridge*> *new_tbs = NULL, 00208 DLIList<TopologyBridge*> *att_tbs = NULL ) const; 00209 00210 virtual CubitStatus imprint( DLIList<BodySM*> &body_list, 00211 DLIList<CubitVector> &vector_list, 00212 DLIList<BodySM*>& new_body_list, 00213 bool keep_old_body, 00214 DLIList<TopologyBridge*> *new_tbs = NULL, 00215 DLIList<TopologyBridge*> *att_tbs = NULL, 00216 double *tol_in = NULL, 00217 bool clean_up_slivers = true) const; 00218 00219 virtual CubitStatus imprint_projected_edges( DLIList<Surface*> &ref_face_list, 00220 DLIList<Curve*> &ref_edge_list, 00221 DLIList<BodySM*>& new_body_list, 00222 DLIList<Curve*> &kept_edge_list, 00223 bool keep_old_body, 00224 bool keep_free_edges) const; 00225 00226 virtual CubitStatus imprint_projected_edges(DLIList<Surface*> &ref_face_list, 00227 DLIList<BodySM*> &body_list, 00228 DLIList<Curve*> &ref_edge_list, 00229 DLIList<BodySM*>& new_body_list, 00230 bool keep_old_body, 00231 bool keep_free_edges) const; 00232 00233 virtual CubitStatus project_edges( DLIList<Surface*> &ref_face_list, 00234 DLIList<Curve*> &ref_edge_list_in, 00235 DLIList<Curve*> &ref_edge_list_new, 00236 bool print_error = true ) const; 00237 00238 virtual CubitStatus remove_topology(DLIList<Curve*> &curves_to_remove, 00239 DLIList<Surface*> &surfs_to_remove, 00240 double backoff_distance, 00241 double small_edge_size, 00242 DLIList<BodySM*> &new_bodysm_list, 00243 CubitBoolean preview) const; 00244 00245 virtual CubitStatus curve_surface_intersection( Surface *surface, 00246 Curve* curve, 00247 DLIList<Curve*> &new_curves ) const; 00248 00249 virtual CubitStatus intersect(BodySM* tool_body_ptr, 00250 DLIList<BodySM*> &from_bodies, 00251 DLIList<BodySM*> &new_bodies, 00252 bool keep_old = CUBIT_FALSE, 00253 bool preview = CUBIT_FALSE ) const; 00254 00255 virtual CubitStatus chop(DLIList<BodySM*> &bodies, 00256 DLIList<BodySM*> &intersectBodies, 00257 DLIList<BodySM*> &outsideBody, 00258 BodySM*& leftoversBody, 00259 bool keep_old = CUBIT_FALSE, 00260 bool nonreg = CUBIT_FALSE) const; 00261 00262 virtual CubitStatus unite(DLIList<BodySM*> &bodies, 00263 DLIList<BodySM*> &newBodies, 00264 bool keep_old = CUBIT_FALSE) const; 00265 00266 virtual void get_possible_invalid_tbs(DLIList<TopologyBridge*> &bridges_in, 00267 DLIList<TopologyBridge*> &bridges_out); 00268 00269 virtual CubitStatus thicken(DLIList<BodySM*>& bodies, 00270 DLIList<BodySM*>& new_bodies, 00271 double depth, 00272 bool both = CUBIT_FALSE) const ; 00273 00274 virtual CubitStatus hollow(DLIList<BodySM*>& bodies, 00275 DLIList<Surface*>& surfs_to_remove, 00276 DLIList<BodySM*>& new_bodies, 00277 double depth) const ; 00278 00279 virtual CubitStatus flip_normals( DLIList<Surface*>& face_list ) const; 00280 00281 virtual CubitStatus sweep_translational( 00282 DLIList<GeometryEntity*>& ref_ent_list, 00283 DLIList<BodySM*>& result_body_list, 00284 const CubitVector& sweep_vector, 00285 double draft_angle, 00286 int draft_type, 00287 bool switchside, 00288 bool rigid, 00289 bool anchor_entity=CUBIT_FALSE, 00290 bool keep_old=CUBIT_FALSE ) const; 00291 00292 virtual CubitStatus sweep_perpendicular( 00293 DLIList<GeometryEntity*>& ref_ent_list, 00294 DLIList<BodySM*>& result_body_list, 00295 double distance, 00296 double draft_angle, 00297 int draft_type, 00298 bool switchside, 00299 bool rigid, 00300 bool anchor_entity=CUBIT_FALSE, 00301 bool keep_old=CUBIT_FALSE ) const; 00302 00303 virtual CubitStatus sweep_rotational( 00304 DLIList<GeometryEntity*>& ref_ent_list, 00305 DLIList<BodySM*>& result_body_list, 00306 const CubitVector& point, 00307 const CubitVector& direction, 00308 double angle, 00309 int steps = 0, 00310 double draft_angle = 0.0, 00311 int draft_type = 0, 00312 bool switchside = CUBIT_FALSE, 00313 bool make_solid = CUBIT_FALSE, 00314 bool rigid = CUBIT_FALSE, 00315 bool anchor_entity=CUBIT_FALSE, 00316 bool keep_old=CUBIT_FALSE ) const; 00317 00318 virtual CubitStatus sweep_along_curve( 00319 DLIList<GeometryEntity*>& ref_ent_list, 00320 DLIList<BodySM*>& result_body_list, 00321 DLIList<Curve*>& ref_edge_list, 00322 double draft_angle = 0.0, 00323 int draft_type = 0, 00324 bool rigid = CUBIT_FALSE, 00325 bool anchor_entity=CUBIT_FALSE, 00326 bool keep_old=CUBIT_FALSE ) const; 00327 00328 virtual CubitStatus sweep_to_body( 00329 DLIList<Curve*> curve_list, 00330 BodySM *target_body, 00331 CubitVector distance, 00332 DLIList<BodySM*> &new_bodies, 00333 bool unite) const; 00334 00335 virtual CubitStatus sweep_to_body( 00336 Surface *source_surface, 00337 BodySM *target_body, 00338 CubitVector distance, 00339 DLIList<BodySM*> &new_bodies) const; 00340 00341 00342 virtual CubitStatus webcut_with_sweep_surfaces( 00343 DLIList<BodySM*> &blank_bodies, 00344 DLIList<Surface*> &surfaces, 00345 const CubitVector& sweep_vector, 00346 bool sweep_perp, 00347 bool through_all, 00348 bool outward, 00349 bool up_to_next, 00350 Surface *stop_surf, 00351 Curve *curve_to_sweep_along, 00352 DLIList<BodySM*> &neighbor_imprint_list, 00353 DLIList<BodySM*> &results_list, 00354 ImprintType imprint_type = NO_IMPRINT, 00355 CubitBoolean preview = false); 00356 00357 virtual CubitStatus webcut_with_sweep_curves( 00358 DLIList<BodySM*> &blank_bodies, 00359 DLIList<Curve*> &curves, 00360 const CubitVector& sweep_vector, 00361 bool through_all, 00362 Surface *stop_surf, 00363 Curve *curve_to_sweep_along, 00364 DLIList<BodySM*> &neighbor_imprint_list, 00365 DLIList<BodySM*> &results_list, 00366 ImprintType imprint_type = NO_IMPRINT, 00367 CubitBoolean preview = false); 00368 00369 virtual CubitStatus webcut_with_sweep_curves_rotated( 00370 DLIList<BodySM*> &blank_bodies, 00371 DLIList<Curve*> &curves, 00372 const CubitVector &point, 00373 const CubitVector &sweep_axis, 00374 double angle, 00375 Surface *stop_surf, 00376 DLIList<BodySM*> &neighbor_imprint_list, 00377 DLIList<BodySM*> &results_list, 00378 ImprintType imprint_type = NO_IMPRINT, 00379 CubitBoolean preview = false); 00380 00381 virtual CubitStatus webcut_with_sweep_surfaces_rotated( 00382 DLIList<BodySM*> &blank_bodies, 00383 DLIList<Surface*> &surfaces, 00384 const CubitVector &point, 00385 const CubitVector &sweep_axis, 00386 double angle, 00387 Surface *stop_surf, 00388 bool up_to_next, 00389 DLIList<BodySM*> &neighbor_imprint_list, 00390 DLIList<BodySM*> &results_list, 00391 ImprintType imprint_type = NO_IMPRINT, 00392 CubitBoolean preview = false); 00393 00394 //HEADER- Webcut-related functions 00395 virtual CubitStatus webcut(DLIList<BodySM*>& webcut_body_list, 00396 const CubitVector &v1, 00397 const CubitVector &v2, 00398 const CubitVector &v3, 00399 DLIList<BodySM*>& neighbor_imprint_list, 00400 DLIList<BodySM*>& results_list, 00401 ImprintType imprint_type = NO_IMPRINT, 00402 bool preview = false) const; 00403 00404 virtual CubitStatus webcut(DLIList<BodySM*>& webcut_body_list, 00405 BodySM const* tool_body, 00406 DLIList<BodySM*>& neighbor_imprint_list, 00407 DLIList<BodySM*>& results_list, 00408 ImprintType imprint_type = NO_IMPRINT, 00409 bool preview = false) const; 00410 00411 virtual CubitStatus webcut_across_translate( DLIList<BodySM*>& body_list, 00412 Surface* plane_surf1, 00413 Surface* plane_surf2, 00414 DLIList<BodySM*>& neighbor_imprint_list, 00415 DLIList<BodySM*>& results_list, 00416 ImprintType imprint_type = NO_IMPRINT, 00417 bool preview = false) const; 00418 00419 virtual CubitStatus webcut_with_sheet(DLIList<BodySM*> &webcut_body_list, 00420 BodySM *sheet_body, 00421 DLIList<BodySM*>& neighbor_imprint_list, 00422 DLIList<BodySM*> &new_bodies, 00423 ImprintType imprint_type = NO_IMPRINT, 00424 bool preview = false); 00425 00426 virtual CubitStatus webcut_with_extended_sheet(DLIList<BodySM*> &webcut_body_list, 00427 DLIList<Surface*> &surface_list, 00428 DLIList<BodySM*>& neighbor_imprint_list, 00429 DLIList<BodySM*> &new_bodies, 00430 int &num_cut, 00431 ImprintType imprint_type = NO_IMPRINT, 00432 bool preview = false); 00433 00434 virtual CubitStatus webcut_with_cylinder(DLIList<BodySM*> &webcut_body_list, 00435 double radius, 00436 const CubitVector &axis, 00437 const CubitVector ¢er, 00438 DLIList<BodySM*>& neighbor_imprint_list, 00439 DLIList<BodySM*>& results_list, 00440 ImprintType imprint_type = NO_IMPRINT, 00441 bool preview = false); 00442 00443 virtual CubitStatus webcut_with_brick( DLIList<BodySM*>& webcut_body_list, 00444 const CubitVector ¢er, 00445 const CubitVector axes[3], 00446 const CubitVector &extension, 00447 DLIList<BodySM*>& neighbor_imprint_list, 00448 DLIList<BodySM*> &results_list, 00449 ImprintType imprint_type = NO_IMPRINT, 00450 bool preview = false); 00451 00452 virtual CubitStatus webcut_with_planar_sheet( DLIList<BodySM*>& webcut_body_list, 00453 const CubitVector ¢er, 00454 const CubitVector axes[2], 00455 double width, double height, 00456 DLIList<BodySM*>& neighbor_imprint_list, 00457 DLIList<BodySM*> &results_list, 00458 ImprintType imprint_type = NO_IMPRINT, 00459 bool preview = false); 00460 00461 virtual CubitStatus webcut_with_curve_loop(DLIList<BodySM*> &webcut_body_list, 00462 DLIList<Curve*> &ref_edge_list, 00463 DLIList<BodySM*>& results_list, 00464 DLIList<BodySM*>& neighbor_imprint_list, 00465 ImprintType imprint_type = NO_IMPRINT, 00466 bool preview = false); 00467 00468 virtual CubitStatus section( DLIList<BodySM*> §ion_body_list, 00469 const CubitVector &point_1, 00470 const CubitVector &point_2, 00471 const CubitVector &point_3, 00472 DLIList<BodySM*>& new_body_list, 00473 bool keep_normal_side, 00474 bool keep_old = false, 00475 bool keep_both_sides = false); 00476 00477 virtual CubitStatus split_body( BodySM *body_ptr, 00478 DLIList<BodySM*> &new_bodies ); 00479 00480 virtual CubitStatus separate_surfaces( DLIList<Surface*> &surf_list, 00481 DLIList<BodySM*> &new_bodies ); 00482 00483 virtual CubitStatus reverse_body( BodySM *body_to_reverse ); 00484 00485 virtual CubitStatus split_periodic( BodySM *body_ptr, 00486 BodySM *&new_body ); 00487 00488 virtual CubitStatus regularize_body( BodySM *body_ptr, 00489 BodySM *&new_body_ptr ); 00490 00491 virtual CubitStatus regularize_entity(GeometryEntity *old_entity_ptr, 00492 BodySM *&new_body_ptr); 00493 virtual CubitStatus test_regularize_entity( GeometryEntity *old_refentity_ptr); 00494 00495 virtual CubitStatus offset_curves( DLIList<Curve*>& ref_edge_list, 00496 DLIList<Curve*>& result_curve_list, 00497 double offset_distance, 00498 const CubitVector& offset_direction, 00499 int gap_type = 1 ); 00500 00501 virtual CubitStatus scale ( BodySM *&body, const CubitVector& factors ); 00502 00503 virtual CubitStatus split_curve( Curve* curve_to_split, 00504 const CubitVector& split_location, 00505 DLIList<Curve*>& created_curves ); 00506 00507 virtual Curve* trim_curve( Curve* trim_curve, 00508 const CubitVector& trim_vector, 00509 const CubitVector& keep_vector, 00510 bool keep_old = false ); 00511 00512 virtual CubitStatus create_solid_bodies_from_surfs(DLIList<Surface*> &ref_face_list, 00513 DLIList<BodySM*> &new_bodies, 00514 bool keep_old = false, 00515 bool heal = true, 00516 bool sheet = false ) const; 00517 00518 virtual Curve* create_arc(const CubitVector& position, 00519 double radius, 00520 double start_angle, 00521 double end_angle, 00522 CubitVector plane, 00523 bool preview = false ); 00524 00525 virtual Curve* create_arc_radius(const CubitVector ¢er, 00526 TBPoint* ref_vertex_start, 00527 TBPoint* ref_vertex_end, 00528 const CubitVector &normal, 00529 double radius, 00530 bool full = false, 00531 bool preview = false); 00532 00533 00534 virtual Curve* create_arc_three( TBPoint* ref_vertex1, 00535 TBPoint* ref_vertex2, 00536 TBPoint* ref_vertex3, 00537 bool full = false, 00538 bool preview = false ); 00539 00540 virtual Curve* create_arc_three( Curve* ref_edge1, 00541 Curve* ref_edge2, 00542 Curve* ref_edge3, 00543 bool full = false , 00544 bool preview = false ); 00545 00546 virtual Curve* create_arc_center_edge( 00547 TBPoint* ref_vertex1, 00548 TBPoint* ref_vertex2, 00549 TBPoint* ref_vertex3, 00550 const CubitVector &normal, 00551 double radius = CUBIT_DBL_MAX, 00552 bool full = false, 00553 bool preview = false ); 00554 00555 virtual CubitStatus create_curve_combine( DLIList<Curve*>& curve_list, 00556 Curve *&new_curve_ptr ); 00557 //- Uses the solid modeller to create a new RefEdge that is a combination 00558 //- of the input chain of edges. 00559 //- 00560 00561 virtual GeometryQueryEngine *get_gqe(); 00562 00563 virtual CubitBoolean is_modify_engine(const TopologyBridge *tb_ptr) const; 00564 00565 virtual CubitStatus get_offset_intersections( 00566 Curve* ref_edge1, 00567 Curve* ref_edge2, 00568 DLIList<CubitVector>& intersection_list, 00569 double offset, 00570 bool ext_first = true ); 00571 00572 virtual CubitStatus get_offset_intersections( 00573 Curve* ref_edge_ptr, 00574 Surface* ref_face_ptr, 00575 DLIList<CubitVector> &intersection_list, 00576 double offset = 0.0, 00577 bool ext_surf = true ); 00578 00579 virtual CubitStatus surface_intersection( Surface *surface1_ptr, 00580 Surface *surface2_ptr, 00581 DLIList<Curve*> &inter_graph, 00582 const double tol) const; 00583 00584 virtual CubitStatus get_mid_plane( const CubitVector &point_1, 00585 const CubitVector &point_2, 00586 const CubitVector &point_3, 00587 BodySM *body_to_trim_to, 00588 BodySM *&midplane_body ) const; 00589 00590 virtual CubitStatus get_spheric_mid_surface( Surface *surface_ptr1, 00591 Surface *surface_ptr2, 00592 BodySM *body_to_trim_to, 00593 BodySM *&midsurface_body ) const; 00594 00595 virtual CubitStatus get_conic_mid_surface( Surface *surface_ptr1, 00596 Surface *surface_ptr2, 00597 BodySM *body_to_trim_to, 00598 BodySM *&midsurface_body ) const; 00599 00600 virtual CubitStatus get_toric_mid_surface( Surface *surface_ptr1, 00601 Surface *surface_ptr2, 00602 BodySM *body_to_trim_to, 00603 BodySM *&midsurface_body ) const; 00604 00605 virtual CubitStatus tweak_bend( DLIList<BodySM*> &bend_bodies, 00606 DLIList<BodySM*> &new_bodysm_list, 00607 CubitVector& neutral_root, 00608 CubitVector& bend_axis, 00609 CubitVector& bend_direction, 00610 double radius, 00611 double angle, 00612 DLIList<CubitVector>& bend_regions, 00613 double width = -1, 00614 CubitBoolean center_bend = CUBIT_FALSE, 00615 int num_points = 0, 00616 CubitBoolean keep_old_body = CUBIT_FALSE, 00617 CubitBoolean preview = CUBIT_FALSE ) const; 00621 virtual CubitStatus tweak_chamfer( DLIList<Curve*> &curve_list, 00622 double left_offset, 00623 DLIList<BodySM*> &new_bodysm_list, 00624 double right_offset = -1.0, 00625 CubitBoolean keep_old_body = CUBIT_FALSE, 00626 CubitBoolean preview = CUBIT_FALSE ) const; 00633 virtual CubitStatus tweak_chamfer( DLIList<TBPoint*> &point_list, 00634 double offset1, 00635 DLIList<BodySM*> &new_bodysm_list, 00636 Curve *edge1 = NULL, 00637 double offset2 = -1.0, 00638 Curve *edge2 = NULL, 00639 double offset3 = -1.0, 00640 Curve *edge3 = NULL, 00641 CubitBoolean keep_old_body = CUBIT_FALSE, 00642 CubitBoolean preview = CUBIT_FALSE ) const; 00649 virtual CubitStatus tweak_fillet( DLIList<Curve*> &curve_list, 00650 double radius, 00651 DLIList<BodySM*> &new_bodysm_list, 00652 CubitBoolean keep_old_body = CUBIT_FALSE, 00653 CubitBoolean preview = CUBIT_FALSE ) const; 00657 virtual CubitStatus tweak_fillet( Curve *curve_ptr, 00658 double start_radius, 00659 double end_radius, 00660 BodySM *&new_body_ptr, 00661 CubitBoolean keep_old_body = CUBIT_FALSE, 00662 CubitBoolean preview = CUBIT_FALSE ) const; 00667 virtual CubitStatus tweak_fillet( DLIList<TBPoint*> &point_list, 00668 double radius, 00669 DLIList<BodySM*> &new_bodysm_list, 00670 CubitBoolean keep_old_body = CUBIT_FALSE, 00671 CubitBoolean preview = CUBIT_FALSE ) const; 00675 virtual CubitStatus tweak_move( DLIList<Surface*> &surface_list, 00676 const CubitVector &delta, 00677 DLIList<BodySM*> &new_bodysm_list, 00678 CubitBoolean keep_old_body = CUBIT_FALSE, 00679 CubitBoolean preview = CUBIT_FALSE ) const; 00683 virtual CubitStatus tweak_move( DLIList<Curve*> &curve_list, 00684 const CubitVector &delta, 00685 DLIList<BodySM*> &new_bodysm_list, 00686 CubitBoolean keep_old_body = CUBIT_FALSE, 00687 CubitBoolean preview = CUBIT_FALSE ) const; 00691 virtual CubitStatus tweak_offset( DLIList<Surface*> &surface_list, 00692 double offset_distance, 00693 DLIList<Surface*> *add_surface_list_ptr, 00694 DLIList<double> *add_offset_list_ptr, 00695 DLIList<BodySM*> &new_bodysm_list, 00696 CubitBoolean keep_old_body = CUBIT_FALSE, 00697 CubitBoolean preview = CUBIT_FALSE ) const; 00702 virtual CubitStatus tweak_offset( DLIList<Curve*> &curve_list, 00703 double offset_distance, 00704 DLIList<Curve*> *add_curve_list_ptr, 00705 DLIList<double> *add_offset_list_ptr, 00706 DLIList<BodySM*> &new_bodysm_list, 00707 CubitBoolean keep_old_body = CUBIT_FALSE, 00708 CubitBoolean preview = CUBIT_FALSE ) const; 00713 virtual CubitStatus tweak_remove( DLIList<Surface*> &surface_list, 00714 DLIList<BodySM*> &new_bodysm_list, 00715 CubitBoolean extend_adjoining = CUBIT_TRUE, 00716 CubitBoolean keep_old_body = CUBIT_FALSE, 00717 CubitBoolean preview = CUBIT_FALSE ) const; 00722 virtual CubitStatus tweak_remove( DLIList<Curve*> &curve_list, 00723 DLIList<BodySM*> &new_bodysm_list, 00724 CubitBoolean keep_old_body = CUBIT_FALSE, 00725 CubitBoolean preview = CUBIT_FALSE ) const; 00731 virtual CubitStatus tweak_target( DLIList<Surface*> &surface_list, 00732 DLIList<Surface*> &target_surf_list, 00733 DLIList<BodySM*> &new_bodysm_list, 00734 CubitBoolean extend_flg = CUBIT_TRUE, 00735 CubitPlane *limit_plane = NULL, 00736 CubitBoolean reverse_flg = CUBIT_FALSE, 00737 CubitBoolean keep_old_body = CUBIT_FALSE, 00738 CubitBoolean preview = CUBIT_FALSE ) const; 00742 virtual CubitStatus tweak_target( DLIList<Curve*> &curve_list, 00743 DLIList<Surface*> &target_surf_list, 00744 DLIList<BodySM*> &new_bodysm_list, 00745 CubitBoolean extend_flg = CUBIT_TRUE, 00746 CubitPlane *limit_plane = NULL, 00747 CubitBoolean reverse_flg = CUBIT_FALSE, 00748 CubitBoolean keep_old_body = CUBIT_FALSE, 00749 CubitBoolean preview = CUBIT_FALSE, 00750 double surface_area_increase_allowed = 0 ) const; 00756 virtual CubitStatus tweak_target( DLIList<Curve*> &curve_list, 00757 DLIList<Curve*> &target_curve_list, 00758 DLIList<BodySM*> &new_bodysm_list, 00759 CubitBoolean extend_flg = CUBIT_TRUE, 00760 CubitPlane *limit_plane = NULL, 00761 CubitBoolean reverse_flg = CUBIT_FALSE, 00762 CubitBoolean keep_old_body = CUBIT_FALSE, 00763 CubitBoolean preview = CUBIT_FALSE, 00764 double surface_area_increase_allowed = 0 ) const; 00770 virtual CubitStatus tweak_target( TBPoint *point_ptr, 00771 DLIList<Surface*> &modify_surface_list, 00772 CubitVector &target_loc, 00773 BodySM *&new_bodysm_ptr, 00774 CubitBoolean keep_old_body = CUBIT_FALSE, 00775 CubitBoolean preview = CUBIT_FALSE ) const; 00784 virtual CubitStatus remove_curve_slivers( BodySM *body, double lengthlimit ) const; 00785 00786 virtual CubitStatus create_net_surface( DLIList<Surface*>& ref_face_list, BodySM *& new_body, 00787 DLIList<DLIList<CubitVector*>*> &vec_lists_u, 00788 DLIList<DLIList<CubitVector*>*> &vec_lists_v, 00789 double net_tol = 1e-3, 00790 CubitBoolean heal = CUBIT_TRUE ) const; 00791 00792 virtual CubitStatus create_net_surface( DLIList<Curve*>& u_curves, DLIList<Curve*>& v_curves, 00793 BodySM *& new_body, 00794 double net_tol = 1e-3, 00795 CubitBoolean heal = CUBIT_TRUE ) const; 00796 00797 virtual CubitStatus create_offset_surface( Surface* ref_face_ptr, BodySM*& new_body, double offset_distance ) const; 00798 00799 virtual CubitStatus create_offset_sheet( DLIList<Surface*> &surface_list, 00800 double offset_distance, 00801 DLIList<Surface*> *add_surface_list_ptr, 00802 DLIList<double> *add_offset_list_ptr, 00803 DLIList<BodySM*> &new_body_list, 00804 CubitBoolean preview = CUBIT_FALSE ) const; 00813 virtual CubitStatus create_offset_body( BodySM* body_ptr, BodySM*& new_body, double offset_distance ) const; 00814 00815 virtual CubitStatus create_skin_surface( DLIList<Curve*>& curves, BodySM*& new_body, 00816 DLIList<Curve*>& guides) const; 00817 00818 00819 00820 00821 virtual CubitStatus loft_surfaces_to_body( DLIList<Surface*> &surfaces, 00822 DLIList<double> &takeoff_factor_list, 00823 DLIList<Surface*> &takeoff_vector_surface_list, 00824 DLIList<CubitVector> &surface_takeoff_vector_list, 00825 DLIList<Curve*> &takeoff_vector_curve_list, 00826 DLIList<CubitVector> &curve_takeoff_vector_list, 00827 DLIList<Curve*> &guides, 00828 DLIList<TBPoint*> &match_vertices_list, 00829 BodySM*& new_body, 00830 CubitBoolean global_guides, 00831 CubitBoolean closed, 00832 CubitBoolean show_matching_curves, 00833 CubitBoolean preview 00834 ) const ; 00835 00836 virtual CubitStatus create_surface( DLIList<CubitVector*>& vec_list, 00837 BodySM *&new_body, 00838 Surface *ref_face_ptr, 00839 CubitBoolean project_points ) const; 00840 00841 virtual CubitStatus create_surface( DLIList<TBPoint*> &points, 00842 BodySM *&new_body, 00843 Surface *on_surface ) const; 00844 00845 virtual CubitStatus create_weld_surface( CubitVector &root, 00846 Surface *ref_face1, double leg1, Surface *ref_face2, double leg2, 00847 BodySM *&new_body ) const; 00848 00849 virtual CubitStatus stitch( DLIList<BodySM*> &bodies_to_stitch, 00850 DLIList<BodySM*> &new_bodies, 00851 bool tighten_gaps, 00852 double tolerance )const; 00853 00854 00855 //-------------------------------------------------------------- 00856 //- Methods for building specific facet-based geometry entities 00857 //-------------------------------------------------------------- 00858 CubitStatus make_facet_point( CubitPoint *thePoint, 00859 TBPoint *&new_point_ptr ); 00860 CubitStatus make_facet_point( const CubitVector &location, 00861 TBPoint *&new_point_ptr ); 00862 //- create a new facet point 00863 00864 CubitStatus make_facet_curve( TBPoint *start_ptr, 00865 TBPoint *end_ptr, 00866 Curve *&new_curve_ptr, 00867 CurveFacetEvalTool *eval_tool_ptr = NULL); 00868 CubitStatus make_facet_curve( TBPoint *start_ptr, 00869 TBPoint *end_ptr, 00870 DLIList<CubitFacetEdge*> &edge_list, 00871 DLIList<CubitPoint*> &point_list, 00872 Curve *&new_curve_ptr, 00873 CurveFacetEvalTool *eval_tool_ptr = NULL); 00874 //- create a new facet curve 00875 00876 CubitStatus make_facet_coedge( Curve *curv_ptr, 00877 CubitSense sense, 00878 CoEdgeSM *&new_coedge_ptr ); 00879 //- create a new facet coedge 00880 00881 CubitStatus make_facet_loop( DLIList<CoEdgeSM*> &coedge_list, 00882 LoopSM *&new_loop_ptr ); 00883 //- create a new facet loop 00884 00885 CubitStatus make_facet_surface(const CubitEvaluatorData *eval_data, 00886 DLIList<CubitFacet*> &facet_list, 00887 DLIList<CubitPoint*> &point_list, 00888 DLIList<LoopSM*> &my_loops, 00889 int interp_order, 00890 double min_dot, 00891 Surface *&new_surface_ptr, 00892 CubitBoolean use_point_addresses = CUBIT_TRUE, 00893 FacetEvalTool *eval_tool_ptr = NULL, 00894 std::map<FacetCurve*, FacetCurve*> *hard_line_curve_map = NULL ); 00895 //-creates a new FacetSurface given the points and facet list. 00896 00897 CubitStatus make_facet_surface(DLIList<CubitQuadFacet*> &facet_list, 00898 DLIList<CubitPoint*> &point_list, 00899 DLIList<LoopSM*> &my_loops, 00900 int interp_order, 00901 double min_dot, 00902 Surface *&new_surface_ptr); 00903 //-creates a new FacetSurface given the points and quad facet list. 00904 00905 CubitStatus make_facet_shell(DLIList<Surface*> &surface_list, 00906 ShellSM *&new_shell_ptr); 00907 //-creates a new shell, given the list of surfaces. 00908 00909 CubitStatus make_facet_lump(DLIList<ShellSM*> &shell_list, 00910 Lump*& new_lump_ptr); 00911 //-creates a new lump, given the list of shells. 00912 00913 CubitStatus make_facet_body(DLIList<Lump*> &lump_list, 00914 BodySM *&new_body_ptr); 00915 //-creates a new body, given the list of lump. 00916 00917 CubitStatus build_facet_surface( const CubitEvaluatorData **eval_data, 00918 DLIList<CubitFacet *> &facet_list, 00919 DLIList<CubitPoint *> &point_list, 00920 double feature_angle, 00921 int interp_order, 00922 CubitBoolean smooth_non_manifold, 00923 CubitBoolean split_surfaces, 00924 DLIList<Surface *> &surface_list); 00925 CubitStatus build_facet_surface( DLIList<CubitQuadFacet *> &qfacet_list, 00926 DLIList<CubitFacet *> &tfacet_list, 00927 DLIList<CubitPoint *> &point_list, 00928 double feature_angle, 00929 int interp_order, 00930 CubitBoolean smooth_non_manifold, 00931 CubitBoolean split_surfaces, 00932 DLIList<Surface *> &surface_list); 00933 CubitStatus build_facet_surface( DLIList<CubitQuadFacet *> &facet_list, 00934 DLIList<CubitPoint *> &point_list, 00935 double feature_angle, 00936 int interp_order, 00937 CubitBoolean smooth_non_manifold, 00938 CubitBoolean split_surfaces, 00939 DLIList<Surface *> &surface_list); 00940 //- creates one or more new FacetSurfaces with all of its lower 00941 //- order entities. Use an optional feature_angle to break 00942 //- surface 00943 00944 //- Define separate CubitPoint* for the CubitFacet list and CubitQuadFacet 00945 //- list if they are going to create different surfaces. 00946 //- Facets sharing the same CubitPoint* will be created into one surfaces. 00947 //- Separate call of build_facet_surface will try to build different 00948 //- surfaces, and won't be able to use shared CubitPoint* from other 00949 //- build_facet_surface call. 00950 //- As long as facets are defined, the CubitPoint list should be left empty 00951 00952 CubitStatus smooth_facets( RefFace *ref_face_ptr, int niter, CubitBoolean free_laplacian ); 00953 //- attempt to clean up facets by smoothing the points on the surface 00954 CubitStatus create_shell_offset( BodySM *bodysm_ptr, BodySM *&new_bodysm, double offset ); 00955 // create a shell offset from body 00956 CubitStatus improve_facets( RefFace *ref_face_ptr ); 00957 // improve the facets by local swaps 00958 00959 CubitStatus build_cholla_surfaces( DLIList<CubitFacet *> facet_list, 00960 DLIList<CubitPoint *> point_list, 00961 double feature_angle, 00962 int interp_order, 00963 CubitBoolean smooth_non_manifold, 00964 CubitBoolean split_surfaces, 00965 ChollaEngine *&cholla_ptr ); 00966 00967 /* virtual CubitStatus finish_facet_Body( 00968 GeometryType surface_type, 00969 const CubitEvaluatorData *eval_data, 00970 DLIList <CubitFacet *>facet_list, 00971 DLIList <CubitPoint *>point_list, 00972 double feature_angle, 00973 int interp_order, 00974 CubitBoolean smooth_non_manifold, 00975 CubitBoolean split_surfaces, 00976 BodySM *&body_ptr) const; 00977 */ 00978 virtual CubitStatus finish_facet_Body( ChollaEngine *cholla_ptr, 00979 const CubitEvaluatorData **eval_data, 00980 double feature_angle, 00981 int interp_order, 00982 BodySM *&bodysm_ptr) const; 00983 00984 virtual CubitStatus finish_facet_Body( DLIList<Surface*>& surfaces, DLIList<CubitSense>& surface_sense, 00985 BodySM *&bodysm_ptr) const; 00986 00987 void set_sphere_eval_data( ChollaEngine *cholla_ptr, 00988 double radius, 00989 CubitEvaluatorData **&eval_data ) const; 00990 00991 void set_cylinder_eval_data( ChollaEngine *cholla_ptr, 00992 double height, 00993 double base_radius_xdir, 00994 double base_radius_ydir, 00995 double top_radius, 00996 CubitEvaluatorData **&eval_data ) const; 00997 00998 // non-virtual specific functions for building facet-based geometry 00999 // from Cholla geometry 01000 01001 CubitStatus build_cholla_geometry( 01002 const CubitEvaluatorData **eval_data, 01003 DLIList<ChollaSurface*> &cholla_surface_list, 01004 DLIList<ChollaCurve*> &cholla_curve_list, 01005 DLIList<ChollaPoint*> &cholla_point_list, 01006 CubitBoolean use_feature_angle, 01007 double feature_angle, 01008 int interp_order, 01009 DLIList<Surface *> &surface_list); 01010 // build the CUBIT geometry based on the Cholla entity class lists 01011 01012 CubitStatus build_cholla_point_geometry( 01013 DLIList<ChollaPoint*> &cholla_point_list ); 01014 // From the cholla point list, create geometric points for each 01015 01016 CubitStatus build_cholla_curve_geometry( 01017 DLIList<ChollaCurve*> &cholla_curve_list ); 01018 // From the cholla curve list, create geometric curves for each 01019 01020 CubitStatus build_cholla_surface_geometry( 01021 const CubitEvaluatorData **eval_data, 01022 DLIList<ChollaSurface*> &cholla_surface_list, 01023 int interp_order, 01024 double min_dot, 01025 DLIList<Surface *> &surface_list); 01026 // From the facet surface list, create geometric surface, 01027 // loops and coedges for each surface in the list 01028 01029 virtual CubitStatus tolerant_imprint(DLIList<Surface*> &surfs_in, 01030 DLIList<BodySM*> &new_bodysm_list) const; 01031 CubitStatus tolerant_imprint_surface_with_curves( Surface *surface_to_imprint, 01032 DLIList<Curve*> &curves, 01033 DLIList<TopologyBridge*> &temporary_bridges, 01034 BodySM *&new_body, 01035 DLIList<TopologyBridge*> *new_tbs = NULL, 01036 DLIList<TopologyBridge*> *att_tbs = NULL ) const; 01037 01038 CubitStatus tolerant_imprint( DLIList<BodySM*> &bodies_in, 01039 DLIList<BodySM*> &new_bodies, 01040 double overlap_tol, 01041 double imprint_tol, 01042 DLIList<TopologyBridge*> *new_tbs = NULL, 01043 DLIList<TopologyBridge*> *att_tbs = NULL ) const; 01044 01045 static CubitBoolean is_modify_enabled() 01046 {return modifyEnabled;} 01047 01048 static void set_modify_enabled(CubitBoolean my_bool) 01049 {modifyEnabled = my_bool;} 01050 01051 01052 01053 01054 protected: 01055 01056 private: 01057 01058 static CubitBoolean modifyEnabled; 01059 01060 CubitStatus build_cholla_loop_geometry( 01061 DLIList<ChollaCurve*> &cholla_curve_list, 01062 ChollaSurface *chsurf_ptr, 01063 DLIList<LoopSM*> &loop_list, 01064 int debug_draw = 0 ); 01065 // From the cholla curve list of a surface, create geometric loops 01066 01067 void fillinedge( 01068 int *edge, 01069 int numpointsonanedge, 01070 double radius, 01071 std::vector<CubitPoint *>& points) const; 01073 01074 void refinetriangle( 01075 int level, 01076 int numpointsonanedge, 01077 int *iedge1, 01078 int *iedge2, 01079 int *iedge3, 01080 int isign1, 01081 int isign2, 01082 int isign3, 01083 double radius, 01084 std::vector<CubitPoint *>& points, 01085 DLIList<CubitFacet *>& facet_list) const; 01087 01088 void create_facets( 01089 const std::vector<std::pair<SurfaceFacets*, CubitSense> >& surfaceTopology, 01090 const FacetPointSet& points, 01091 int interp_order, 01092 DLIList<CubitPoint*>& c_points, 01093 std::map<SurfaceFacets*, DLIList<CubitFacet*> >& facet_map, 01094 std::map<CurveFacets*, DLIList<CubitFacetEdge*> >& facet_edge_map 01095 ); 01096 01097 CubitStatus process_topology(SurfaceFacets* surface, CubitSense& coface_sense, 01098 int interp_order, const DLIList<CubitPoint*>& c_points, 01099 std::map<SurfaceFacets*, DLIList<CubitFacet*> >& facet_map, 01100 std::map<CurveFacets*, DLIList<CubitFacetEdge*> >& facet_edge_map, 01101 std::map<FacetShapes*, GeometryEntity*>& entity_map 01102 ); 01103 01104 void process_topology(CurveFacets* curve, const DLIList<CubitPoint*>& c_points, 01105 FacetEvalTool* eval, CubitSense sense, 01106 std::map<CurveFacets*, DLIList<CubitFacetEdge*> >& facet_edge_map, 01107 std::map<FacetShapes*, GeometryEntity*>& entity_map); 01108 01109 } ; 01110 01111 #endif
