cgma
#include <cstdio>#include <cstdlib>#include <signal.h>#include <unistd.h>#include <termios.h>#include <sys/ioctl.h>#include <ctype.h>#include <time.h>#include "AppUtil.hpp"#include "CubitMessage.hpp"#include "CubitString.hpp"#include "CubitObserver.hpp"#include "SettingHandler.hpp"#include "StubProgressTool.hpp"#include <sys/resource.h>#include <sys/types.h>#include <sys/stat.h>#include <fcntl.h>#include <dlfcn.h>#include "CubitUtil.hpp"Go to the source code of this file.
Defines | |
| #define | PATH_MAX _MAX_PATH |
Functions | |
| void | cubit_update_terminal_size (int) |
| void | sigint_handler (int) |
Variables | |
| static volatile CubitBoolean | cubit_intr = CUBIT_FALSE |
| #define PATH_MAX _MAX_PATH |
Definition at line 67 of file AppUtil.cpp.
| void cubit_update_terminal_size | ( | int | ) |
Definition at line 114 of file AppUtil.cpp.
#if defined(_WIN32)
// http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dllproc/base/getconsolescreenbufferinfo.asp
// http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dllproc/base/scrolling_a_screen_buffer_s_window.asp
HANDLE h_stdout = GetStdHandle(STD_OUTPUT_HANDLE);
CONSOLE_SCREEN_BUFFER_INFO scr_info;
if (GetConsoleScreenBufferInfo(h_stdout, &scr_info))
AppUtil::instance()->set_terminal_size(
// dwSize.Y is will return the height of the scroll-back buffer.
// srWindow contains the position of the visible rect of the
// window in the buffer. That is the height of the window.
scr_info.srWindow.Bottom - scr_info.srWindow.Top,
// use width of scroll buffer rather than size of window
// for number of columns. The window size is useless as
// caller would need to know the offset in the X direction
// to make use of it and we aren't returning that. Besides,
// the user presumably set the scroll buffer to this width
// because that's the line length (s)he wants.
scr_info.dwSize.X
#elif defined(TIOCGWINSZ)
// On UNIX platforms, register this function as a handler for
// SIGWINCH. The system will then call this function any time
// the user changes the size of the terminal window.
#ifdef SIGWINCH
signal( SIGWINCH, &cubit_update_terminal_size );
#endif
const int file = fileno(stdout);
struct winsize size;
if( ioctl( file, TIOCGWINSZ, (char*)&size ) == 0 )
AppUtil::instance()->set_terminal_size( size.ws_row, size.ws_col );
#endif
| void sigint_handler | ( | int | ) |
Definition at line 306 of file AppUtil.cpp.
#ifndef CUBIT_NO_SIGNAL
if( signal( SIGINT, sigint_handler ) == SIG_ERR )
PRINT_ERROR("Cannot continue to catch SIGINT!\n");
cubit_intr = CUBIT_TRUE;
#endif
volatile CubitBoolean cubit_intr = CUBIT_FALSE [static] |
Definition at line 112 of file AppUtil.cpp.
