cgma
#include "FacetModifyEngine.hpp"#include "FacetQueryEngine.hpp"#include "SettingHandler.hpp"#include "CubitMessage.hpp"#include "CubitDefines.h"#include "CubitUtil.hpp"#include "CubitPoint.hpp"#include "CubitPointData.hpp"#include "CubitFacet.hpp"#include "CubitQuadFacet.hpp"#include "CubitFacetData.hpp"#include "CubitFacetEdge.hpp"#include "CubitFacetEdgeData.hpp"#include "GeometryQueryTool.hpp"#include "GeometryModifyTool.hpp"#include "ChollaSurface.hpp"#include "ChollaCurve.hpp"#include "ChollaPoint.hpp"#include "FacetPoint.hpp"#include "FacetCurve.hpp"#include "CurveFacetEvalTool.hpp"#include "FacetEvalTool.hpp"#include "FacetCoEdge.hpp"#include "FacetLoop.hpp"#include "FacetSurface.hpp"#include "FacetShell.hpp"#include "FacetLump.hpp"#include "FacetBody.hpp"#include "ChollaEngine.hpp"#include "TDGeomFacet.hpp"#include "CubitFileIOWrapper.hpp"#include "TDFacetBoundaryPoint.hpp"#include "Cholla.h"#include "Body.hpp"#include "GfxDebug.hpp"#include "RefFace.hpp"#include "FacetDataUtil.hpp"#include "FBDataUtil.hpp"#include "FBIntersect.hpp"#include "IntegerHash.hpp"#include "FacetboolInterface.hpp"#include "CpuTimer.hpp"#include "ProgressTool.hpp"#include "AppUtil.hpp"#include "SphereEvaluator.hpp"#include "CylinderEvaluator.hpp"#include "CubitLoops.hpp"#include "FacetProjectTool.hpp"#include <algorithm>Go to the source code of this file.
Defines | |
| #define | MODIFY_CHECK_RETURN_NULL |
| #define | MODIFY_CHECK_RETURN_VOID |
| #define | MODIFY_CHECK_RETURN_FAILURE |
| #define MODIFY_CHECK_RETURN_FAILURE |
do {if(!modifyEnabled){ \ PRINT_INFO("Facet-based geometry modification is a beta capability.\n");\ PRINT_ERROR("This capability is currently disabled.\n");\ PRINT_INFO("To enable this capability, issue the command 'set developer commands on'. \n");\ return CUBIT_FAILURE;} }while(0)
Definition at line 90 of file FacetModifyEngine.cpp.
| #define MODIFY_CHECK_RETURN_NULL |
do {if(!modifyEnabled){ \ PRINT_INFO("Facet-based geometry modification is a beta capability.\n");\ PRINT_ERROR("This capability is currently disabled.\n");\ PRINT_INFO("To enable this capability, issue the command 'set developer commands on'. \n");\ return NULL;} }while(0)
Definition at line 76 of file FacetModifyEngine.cpp.
| #define MODIFY_CHECK_RETURN_VOID |
do {if(!modifyEnabled){ \ PRINT_INFO("Facet-based geometry modification is a beta capability.\n");\ PRINT_ERROR("This capability is currently disabled.\n");\ PRINT_INFO("To enable this capability, issue the command 'set developer commands on'. \n");\ return;} }while(0)
Definition at line 83 of file FacetModifyEngine.cpp.
