cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetBody.hpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : David White 00009 // 00010 // Creation Date : 7/18/00 00011 // 00012 //------------------------------------------------------------------------- 00013 00014 #ifndef FACET_BODY_HPP 00015 #define FACET_BODY_HPP 00016 00017 // ********** BEGIN STANDARD INCLUDES ********** 00018 // ********** END STANDARD INCLUDES ********** 00019 00020 // ********** BEGIN CUBIT INCLUDES ********** 00021 #include "CubitDefines.h" 00022 #include "BodySM.hpp" 00023 #include "CubitTransformMatrix.hpp" 00024 #include "FacetAttribSet.hpp" 00025 // ********** END CUBIT INCLUDES ********** 00026 00027 // ********** BEGIN FORWARD DECLARATIONS ********** 00028 class Body; 00029 class TopologyEntity; 00030 class CubitString; 00031 class FacetAttrib; 00032 00033 class FacetLump; 00034 class FacetShell; 00035 class FacetSurface; 00036 class FacetLoop; 00037 class FacetCoEdge; 00038 class FacetCurve; 00039 class FacetPoint; 00040 00041 // ********** END FORWARD DECLARATIONS ********** 00042 00043 class FacetBody : public BodySM 00044 { 00045 public: 00046 00047 FacetBody(DLIList<Lump*> &myLumps); 00048 //- Constructor with a pointer to a BODY. 00049 virtual ~FacetBody() ; 00050 //- The destructor. 00051 00052 CubitBoolean can_be_deleted( DLIList <Body*> &body_list ); 00053 00054 virtual GeometryQueryEngine* get_geometry_query_engine() const; 00055 //R GeometryQueryEngine* 00056 //R- A pointer to the geometric modeling engine associated with 00057 //R- the object. 00058 //- This function returns a pointer to the geometric modeling engine 00059 //- associated with the object. 00060 00061 virtual void append_simple_attribute_virt(const CubitSimpleAttrib&); 00062 //R void 00063 //I 00064 //I- 00065 //I- that is to be appended to this OSME object. 00066 //- The purpose of this function is to append a 00067 //- attribute to the OSME. The is attached to each of the 00068 //- underlying solid model entities this one points to. 00069 00070 virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&); 00071 //R void 00072 //I CubitSimpleAttrib* 00073 //I- A reference to a CubitSimpleAttrib object which is the object 00074 //I- that is to be removed to this OSME object. 00075 //- The purpose of this function is to remove a simple 00076 //- attribute from the OSME. The attribute is attached to each of the 00077 //- underlying solid model entities this one points to. 00078 00079 virtual void remove_all_simple_attribute_virt(); 00080 //R void 00081 //I- 00082 //- The purpose of this function is to remove all simple 00083 //- attributes from the OSME. 00084 00085 virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&); 00086 virtual CubitStatus get_simple_attribute(const CubitString& name, 00087 DLIList<CubitSimpleAttrib>&); 00088 //R CubitSimpleAttrib* 00089 //R- the returned cubit simple attribute. 00090 //- The purpose of this function is to get the attributes 00091 //- of the geometry entity. The name is attached to the underlying solid 00092 //- model entity(ies) this one points to. 00093 //- MJP Note: 00094 //- This is the code that implements the requirement that names 00095 //- of VGI Entities propagate across solid model boolean 00096 //- operations. The success of this relies, of course, on the underlying 00097 //- solid modeler being able to propagate attributes across 00098 //- such operations on its entities. If it cannot, then "names" 00099 //- of VGI entities will not propagate. 00100 00101 virtual BodySM* copy(); 00102 //R FacetBody* 00103 //R- Pointer to a FacetBody object 00104 //- Copies this FacetBody object (including the BODY that it 00105 //- contains) and returns a pointer to a new FacetBody object. 00106 00107 virtual CubitStatus move(double , double , double ); 00108 //R CubitStatus 00109 //R- CUBIT_SUCCESS/FAILURE 00110 //I dx, dy, dz 00111 //I- Offset values in each of the 3 Cartesian coordinate directions 00112 //- Move the BODY by dx, dy and dz 00113 00114 virtual CubitStatus rotate( double , double , double , 00115 double ); 00116 //R CubitStatus 00117 //R- CUBIT_SUCCESS/FAILURE 00118 //I x, y, z 00119 //I- Axis of rotation 00120 //I angle_in_degrees 00121 //I- Angle of rotation in degrees 00122 //- Rotate the BODY angle degrees about a vector defined by 00123 //- x, y and z 00124 00125 virtual CubitStatus scale(double, double, double); 00126 00127 virtual CubitStatus scale(double); 00128 //R CubitStatus 00129 //R- CUBIT_SUCCESS/FAILURE 00130 //I scaling_factor 00131 //I- Scaling factor 00132 //- Scale the BODY by the factor, scaling_factor 00133 00134 CubitStatus reflect(double,double,double); 00135 //- reflect about an axis 00136 00137 virtual CubitStatus restore(); 00138 //R CubitStatus 00139 //R- CUBIT_SUCCESS/FAILURE 00140 //- Restore the BODY by replacing the transformation matrix 00141 //- associated with it with a unit matrix 00142 00143 CubitStatus get_transforms( CubitTransformMatrix &tfm ); 00144 //R CubitStatus 00145 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00146 //I BODYPtr 00147 //- return the transformation matrix for this body 00148 00149 CubitStatus set_transforms( CubitTransformMatrix tfm ); 00150 //R CubitStatus 00151 //R- CUBIT_SUCCESS/CUBIT_FAILURE that myTransforms was 00152 // set correctly 00153 //I BODYPtr 00154 00155 int validate(const CubitString &, DLIList <TopologyEntity*>&); 00156 //- does an api_entity_check for the body. 00157 00158 CubitStatus save_attribs( FILE* file_ptr ); 00159 // Write FactAttribs out to file 00160 00161 CubitStatus restore_attribs( FILE* file_ptr, unsigned int endian ); 00162 // Read FactAttribs from file 00163 00164 void get_lumps ( DLIList<FacetLump *>& lumps ); 00165 void get_shells ( DLIList<FacetShell *>& shells ); 00166 void get_surfaces( DLIList<FacetSurface*>& surfaces ); 00167 void get_loops ( DLIList<FacetLoop *>& loops ); 00168 void get_coedges ( DLIList<FacetCoEdge *>& coedges ); 00169 void get_curves ( DLIList<FacetCurve *>& curves ); 00170 void get_points ( DLIList<FacetPoint *>& points ); 00171 00172 void get_parents_virt( DLIList<TopologyBridge*>& parents ); 00173 void get_children_virt( DLIList<TopologyBridge*>& children ); 00174 00175 void disconnect_all_lumps(); 00176 void add_lump( FacetLump *lump_to_add ); 00177 void remove_lump( FacetLump *lump_to_remove ); 00178 00179 virtual CubitStatus mass_properties( CubitVector& result, double& volume ); 00180 00181 virtual CubitPointContainment point_containment( const CubitVector& pos, double tolerance ); 00182 00183 protected: 00184 00185 private: 00186 CubitStatus transform( CubitTransformMatrix &tfmat, CubitBoolean is_rotation ); 00187 // main function for applying transforms to facet-based bodies 00188 00189 void init_edge_flags( DLIList<Surface *>&surf_list, int flag ); 00190 // set the flags on the facet edges 00191 00192 CubitTransformMatrix myTransforms; 00193 DLIList<Lump*> myLumps; 00194 //List of the attached lumps for the traversal functions. 00195 FacetAttribSet attribSet; 00196 //List of FacetAttrib*'s instead of CubitSimpleAttribs 00197 }; 00198 00199 00200 00201 #endif 00202
