cgma
00001 //- Class: TDGeomFacet 00002 //- Owner: Steve Owen 00003 //- Description: Data for reading in a mesh and creating a geometry. 00004 //- This is assumed to be stored on a facet entity. 00005 //- Checked By: 00006 //- Version: 00007 00008 #ifndef TD_GEOM_MESH_HPP 00009 00010 00011 #define TD_GEOM_MESH_HPP 00012 00013 #include "CubitDefines.h" 00014 #include "DLIList.hpp" 00015 #include "ToolData.hpp" 00016 #include "CubitPoint.hpp" 00017 class FacetEntity; 00018 class ChollaEntity; 00019 class ChollaVolume; 00020 class ChollaSurface; 00021 class ChollaCurve; 00022 class ChollaPoint; 00023 class CubitFacet; 00024 class CubitFacetEdge; 00025 00026 00027 class TDGeomFacet : public ToolData 00028 { 00029 private: 00030 00031 static MemoryManager memoryManager; 00032 //- memory management object 00033 00034 int blockId; 00035 00036 int hitFlag; 00037 //- Used for looping. 00038 00039 DLIList<ChollaSurface*> ChollaSurfaceList; 00040 //- list of surfaces this element is on. 00041 00042 DLIList<ChollaCurve*> ChollaCurveList; 00043 //- list of curves this element (edge) is on 00044 00045 DLIList<ChollaPoint*> ChollaPointList; 00046 //- list chollapoints this element (point) is on 00047 00048 DLIList<CubitPoint*> myPoints; 00049 //- list of associated points for this entity (could be one). 00050 00051 CubitVector normal; 00052 //- normal or tangent vector of a facet or facet edge 00053 00054 DLIList<CubitFacetEdge *> *partnerEdgeList; 00055 //- other edges that share the same geometry 00056 00057 DLIList<CubitPoint *> *partnerPointList; 00058 //- other points that share the same geometry 00059 00060 public: 00061 00062 TDGeomFacet(); 00063 //- constructor 00064 00065 ~TDGeomFacet(); 00066 00067 static int is_geom_facet(const ToolData* td); 00068 00069 int get_block_id() 00070 {return blockId;} 00071 00072 void set_block_id(int new_id) 00073 {blockId = new_id;} 00074 00075 int get_hit_flag() 00076 {return hitFlag;} 00077 00078 void set_hit_flag(int flag) 00079 {hitFlag = flag;} 00080 00081 void add_cholla_owner(ChollaEntity *cholla_entity); 00082 00083 void add_cholla_surf(ChollaSurface *f_s_m); 00084 00085 void get_cholla_surfs(DLIList<ChollaSurface*> &surf_list) 00086 {surf_list = ChollaSurfaceList;} 00087 00088 void remove_cholla_surfs() 00089 {ChollaSurfaceList.clean_out();} 00090 00091 void remove_cholla_surf( ChollaSurface *chsurf_ptr ) 00092 {ChollaSurfaceList.remove( chsurf_ptr );} 00093 00094 void add_cholla_curve(ChollaCurve *chcurv_ptr) 00095 {ChollaCurveList.append_unique( chcurv_ptr );} 00096 00097 void get_cholla_curves(DLIList<ChollaCurve*> &curv_list) 00098 {curv_list = ChollaCurveList;} 00099 00100 void remove_cholla_curves() 00101 {ChollaCurveList.clean_out();} 00102 00103 void remove_cholla_curve( ChollaCurve *chcurv_ptr ) 00104 {ChollaCurveList.remove( chcurv_ptr );} 00105 00106 void add_cholla_point(ChollaPoint *chpt_ptr) 00107 {ChollaPointList.append_unique( chpt_ptr );} 00108 00109 void get_cholla_points(DLIList<ChollaPoint*> &point_list) 00110 {point_list = ChollaPointList;} 00111 00112 void remove_cholla_points() 00113 {ChollaPointList.clean_out();} 00114 00115 void remove_cholla_point( ChollaPoint *point_ptr ) 00116 { ChollaPointList.remove( point_ptr ); } 00117 00118 void add_point(CubitPoint *point) 00119 {myPoints.append(point);} 00120 00121 void delete_point(CubitPoint *point) 00122 {myPoints.omit(point);} 00123 00124 void get_points(DLIList<CubitPoint*> &point_list) 00125 {point_list += myPoints;} 00126 00127 CubitPoint* get_first_point() 00128 { 00129 myPoints.reset(); 00130 if ( myPoints.size() ) 00131 return myPoints.get(); 00132 else 00133 return (CubitPoint*) NULL; 00134 } 00135 00136 void add_partner_edge( CubitFacetEdge *partner ) 00137 { if (partnerEdgeList == NULL) 00138 partnerEdgeList = new DLIList<CubitFacetEdge *>; 00139 partnerEdgeList->append( partner ); }; 00140 00141 void get_partner_edges( DLIList <CubitFacetEdge *> &partner_list ) 00142 { if (partnerEdgeList != NULL) partner_list += *partnerEdgeList; }; 00143 00144 int num_partner_edges( ) 00145 { if (partnerEdgeList == NULL) 00146 return 0; 00147 else 00148 return partnerEdgeList->size(); } 00149 00150 void add_partner_point( CubitPoint *partner ) 00151 { if (partnerPointList == NULL) 00152 partnerPointList = new DLIList<CubitPoint *>; 00153 partnerPointList->append( partner ); }; 00154 00155 void get_partner_points( DLIList <CubitPoint *> &partner_list ) 00156 { if (partnerPointList != NULL) partner_list += *partnerPointList; }; 00157 00158 int num_partner_points( ) 00159 { if (partnerPointList == NULL) 00160 return 0; 00161 else 00162 return partnerPointList->size(); } 00163 00164 CubitBoolean is_in_volume( ChollaVolume *chvol_ptr ); 00165 00166 SetDynamicMemoryAllocation(memoryManager) 00167 //- class specific new and delete operators 00168 00169 static void set_memory_allocation_increment(int increment = 0) 00170 {memoryManager.set_memory_allocation_increment(increment);} 00171 //- set block memory size increment 00172 00173 static void destroy_memory() 00174 {memoryManager.destroy_memory();} 00175 //- destroy all memory allocted to this object 00176 00177 static CubitStatus add_geom_facet(FacetEntity *facet_entity, int block_id); 00178 static CubitStatus add_geom_facet(CubitFacet *facet_ptr, int block_id); 00179 static CubitStatus add_geom_facet(CubitFacetEdge *edge_ptr, int block_id); 00180 static CubitStatus add_geom_facet(CubitPoint *point_ptr, int block_id); 00181 00182 static TDGeomFacet* get_geom_facet(FacetEntity *facet_entity); 00183 static TDGeomFacet* get_geom_facet(CubitFacet *facet_ptr); 00184 static TDGeomFacet* get_geom_facet(CubitFacetEdge *edge_ptr); 00185 static TDGeomFacet* get_geom_facet(CubitPoint *point_ptr); 00186 00187 static int get_block_id(FacetEntity *mesh_entity); 00188 static int get_block_id(CubitFacet *facet_ptr); 00189 static int get_block_id(CubitFacetEdge *edge_ptr); 00190 static int get_block_id(CubitPoint *point_ptr); 00191 00192 static int get_hit_flag(FacetEntity *mesh_entity); 00193 static void set_hit_flag(FacetEntity *mesh_entity, int new_val); 00194 CubitVector get_normal( ) { return normal; } 00195 void set_normal( CubitVector &norm ) { normal = norm; } 00196 00197 CubitBoolean is_partner( CubitFacetEdge *edge_ptr ); 00198 CubitBoolean is_partner( CubitPoint *point_ptr ); 00199 00200 void reset_TD_as_new(); 00201 00202 int geo_type(); 00203 00204 }; 00205 00206 00207 #endif // TD_GEOM_MESH_HPP 00208 00209
