cgma
#include "AppUtil.hpp"#include "CGMApp.hpp"#include "GeometryQueryTool.hpp"#include "FacetModifyEngine.hpp"#include "FacetQueryEngine.hpp"#include "CubitFacetData.hpp"#include "CubitPointData.hpp"#include "CubitQuadFacetData.hpp"#include "DLIList.hpp"#include "Surface.hpp"#include "ShellSM.hpp"#include "Lump.hpp"#include "Body.hpp"#include "BodySM.hpp"#include "RefFace.hpp"#include "RefVertex.hpp"#include <iostream>Go to the source code of this file.
Functions | |
| bool | generateFacetModel (DLIList< TopologyBridge * > &model) |
| int | main (int argc, char *argv[]) |
| bool generateFacetModel | ( | DLIList< TopologyBridge * > & | model | ) |
Definition at line 42 of file multifaceted.cpp.
FacetModifyEngine* fme = FacetModifyEngine::instance();
CubitStatus stat;
int i;
DLIList <CubitPoint*> plist;
double pts[4][3] = {
{ 0., 0., 0. },
{ 1., 0., 0. },
{ 1., 1., 0. },
{ 0., 1., 1. },
for (i = 0; i < (int)(sizeof(pts)/sizeof(pts[0])); ++i)
plist.append(new CubitPointData(pts[i][0], pts[i][1], pts[i][2]));
// Build a tetrahedron, with 1 triangular facet per faceted-surface:
int tconn[4][3] = {
{0, 2, 1},
{0, 3, 2},
{0, 1, 3},
{1, 2, 3}
DLIList<Surface*> all_surfs;
DLIList<CubitFacet*> tflist;
DLIList<CubitQuadFacet*> qflist;
DLIList<CubitPoint*> facet_plist;
for (i = 0; i < (int)(sizeof(tconn)/sizeof(tconn[0])); ++i)
std::cout << "Build faceted surface " << i << "\n";
//DLIList<CubitFacet*> tflist;
//DLIList<CubitQuadFacet*> qflist;
//DLIList<CubitPoint*> facet_plist;
// Fails with or without the next 3 lines:
//facet_plist.append(plist[tconn[i][0]]);
//facet_plist.append(plist[tconn[i][1]]);
//facet_plist.append(plist[tconn[i][2]]);
// Create a single facet for our faceted surface:
tflist.append(
new CubitFacetData(
plist[tconn[i][0]], plist[tconn[i][1]], plist[tconn[i][2]]));
DLIList<Surface*> slist;
// Attempt to build a faceted surface:
stat = fme->build_facet_surface(
qflist, tflist, facet_plist, -1., 0, false, false, slist);
if (slist.size() <= 0 || stat != CUBIT_SUCCESS)
PRINT_ERROR("Make surface failed. \n");
return false;
all_surfs += slist;
ShellSM* shell;
stat = fme->make_facet_shell(all_surfs, shell);
if (!shell || stat != CUBIT_SUCCESS)
PRINT_ERROR("Make shell failed. \n");
return false;
DLIList<ShellSM*> shlist;
shlist.append(shell);
Lump* lump;
stat = fme->make_facet_lump(shlist, lump);
if (!lump || stat != CUBIT_SUCCESS) return false;
DLIList<Lump*> llist;
BodySM* bodySM;
Body* body;
llist.append(lump);
stat = fme->make_facet_body(llist, bodySM);
body = GeometryQueryTool::instance()->make_Body(bodySM);
if (!body || stat != CUBIT_SUCCESS) return false;
model.append(bodySM);
return true;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 23 of file multifaceted.cpp.
// Initialize CGM
FacetQueryEngine* fqe = FacetQueryEngine::instance();
DLIList<TopologyBridge*> model;
const char *arg = "multifaceted.stl";
if (generateFacetModel(model))
ModelExportOptions opts;
fqe->export_solid_model(
model, arg, FACET_TYPE,
CubitString(), opts);
std::cout << "Wrote \"" << arg << "\"\n";
return 0;
