cgma
00001 #ifndef CUBITFACETDATA_HPP 00002 #define CUBITFACETDATA_HPP 00003 00004 // Include for CubitBoolean 00005 #include "CubitDefines.h" 00006 #include "MemoryManager.hpp" 00007 #include "CubitPoint.hpp" 00008 #include "DLIList.hpp" 00009 #include "CubitBox.hpp" 00010 #include "CubitFacet.hpp" 00011 class CubitVector; 00012 class CubitBox; 00013 class CubitPlane; 00014 class CubitFacetEdge; 00015 00016 class CubitFacetData : public CubitFacet 00017 { 00018 private: 00019 CubitPoint *pointArray[3]; 00020 CubitFacetEdge *edgeArray[3]; 00021 int edgeUse[3]; 00022 static MemoryManager memoryManager; 00023 //- memory management object 00024 int entityId; 00025 //- for debug tracking... 00026 void allocate_edge(CubitPoint *p1, CubitPoint *p2, int edge_index); 00027 void define_point(CubitFacetEdge *e1, CubitFacetEdge *e2, 00028 int point_index); 00029 void define_bounding_box(); 00030 00031 public: 00032 CubitFacetData( CubitPoint *p1, CubitPoint *p2, 00033 CubitPoint *p3); 00034 CubitFacetData( CubitPoint *p1, CubitPoint *p2, 00035 CubitPoint *p3, int *tool_data); 00036 CubitFacetData( CubitFacetEdge *e1, CubitFacetEdge *e2, 00037 CubitFacetEdge *e3); 00038 ~CubitFacetData(); 00039 00040 void destruct_facet_internals(); 00041 00042 virtual int id(){return entityId;} 00043 virtual void set_id( int ii ) { entityId = ii; } 00044 00045 SetDynamicMemoryAllocation(memoryManager) 00046 //- class specific new and delete operators 00047 CubitStatus closest_point( const CubitVector &point, 00048 CubitVector &closest_point); 00049 //- Sets the closest point on the plane defined by 00050 //- this facet to the point in space. 00051 //- If the normal length to the facet is 0, it will return CUBIT_FAILURE. 00052 00053 CubitPoint* point( int index ); 00054 //Get the point at the specified index. 00055 //asserts that the index is in range, for a 00056 //triangle, 0 <= index <= 2. 00057 00058 00059 void set_point( CubitPoint *the_point, int index ); 00060 //- sets the point into the facet. 00061 00062 CubitFacetEdge *edge( int index ); 00063 void edge( CubitFacetEdge *the_edge, int index ); 00064 //- get and set edge pointers 00065 00066 void edge_use( int direction, int index ); 00067 int edge_use( int index ); 00068 //- get and set the edge uses 00069 int sense(int index); 00070 00071 CubitPoint* split_edge( int edge_index, const CubitVector& position ); 00072 CubitPoint* split_edge( CubitPoint* edge_pt1, CubitPoint* edge_pt2, 00073 const CubitVector& position ); 00074 //R CubitPoint 00075 //R- The new CubitPoint created. 00076 //I edge_pt1, edge_pt2 00077 //I- The end points of an edge of this triangle. 00078 //I position 00079 //I- The position at which to split the edge. 00080 //O new_facet1 00081 //O- The new facet resulting from splitting the edge on 00082 //O- this triangle. 00083 //O new_facet2 00084 //O- The new facet resulting from splitting the same edge 00085 //O- on the ajacent triangle. If there is no other 00086 //O- triangle sharing the edge, NULL will be passed back. 00087 //- Split an edge on this triangle and the other triangle 00088 //- sharing the edge, if it exists. 00089 //- 00090 //- Note: No check is done on the location of the split 00091 //- position. 00092 00093 CubitPoint* insert_point( const CubitVector& position, 00094 CubitFacet*& new_tri1, 00095 CubitFacet*& new_tri2 ); 00096 //R CubitPoint 00097 //R- The new CubitPoint created. 00098 //I position 00099 //I- The position at which to insert a point in the triangle. 00100 //O new_facet1, new_facet2 00101 //O- The two new facets created. 00102 //- Insert a point in the interior of this triangle. 00103 //- 00104 //- Note: No check is done on the location of the split 00105 //- position. 00106 00107 CubitStatus flip_edge( int edge_index ); 00108 CubitStatus flip_edge( CubitFacetEdge *edge ); 00109 //- Given an edge shared by exactly two facets, 00110 //- flip the edge such that it connects the 00111 //- "other" two facet points instead. 00112 //- 00113 //- *----* *----* 00114 //- |\ | | /| 00115 //- | \ | ==> | / | 00116 //- | \ | | / | 00117 //- | \| |/ | 00118 //- *----* *----* 00119 //- 00120 //- NOTE: If you are trying to reverse the sense of 00121 //- an edge, this is NOT the function you want! 00122 00123 void flip(); 00124 //- reorient the facet 00125 00126 }; 00127 00128 00129 inline CubitPoint* CubitFacetData::point( int index ) 00130 { 00131 assert( (index >= 0) && (index < 3) ); 00132 if (!is_backwards()) 00133 return pointArray[index]; 00134 else 00135 { 00136 switch(index) 00137 { 00138 case 0: return pointArray[0]; 00139 case 1: return pointArray[2]; 00140 case 2: return pointArray[1]; 00141 } 00142 } 00143 return NULL; 00144 } 00145 00146 inline void CubitFacetData::set_point( CubitPoint* the_point, int index ) 00147 { 00148 assert( (index >= 0) && (index < 3) ); 00149 if (!is_backwards()) 00150 pointArray[index] = the_point; 00151 else 00152 { 00153 switch(index) 00154 { 00155 case 0: pointArray[0] = the_point; break; 00156 case 1: pointArray[2] = the_point; break; 00157 case 2: pointArray[1] = the_point; break; 00158 } 00159 } 00160 } 00161 00162 inline CubitFacetEdge* CubitFacetData::edge( int index ) 00163 { 00164 assert( (index >= 0) && (index < 3) ); 00165 if (!is_backwards()) { 00166 return edgeArray[index]; 00167 } 00168 else 00169 { 00170 switch(index) 00171 { 00172 case 0:return edgeArray[0]; 00173 case 1:return edgeArray[2]; 00174 case 2:return edgeArray[1]; 00175 } 00176 } 00177 return NULL; 00178 } 00179 00180 00181 inline void CubitFacetData::edge( CubitFacetEdge *the_edge, int index ) 00182 { 00183 assert( (index >= 0) && (index < 3) ); 00184 if (!is_backwards()) 00185 edgeArray[index] = the_edge; 00186 else 00187 { 00188 switch(index) 00189 { 00190 case 0: edgeArray[0] = the_edge; break; 00191 case 1: edgeArray[2] = the_edge; break; 00192 case 2: edgeArray[1] = the_edge; break; 00193 } 00194 } 00195 } 00196 00197 inline int CubitFacetData::edge_use( int index ) 00198 { 00199 assert( (index >= 0) && (index < 3) ); 00200 if (!is_backwards()) 00201 return edgeUse[index]; 00202 else 00203 { 00204 switch(index) 00205 { 00206 case 0: return -edgeUse[0]; 00207 case 1: return -edgeUse[2]; 00208 case 2: return -edgeUse[1]; 00209 } 00210 } 00211 return 0; 00212 } 00213 00214 //- This function is defined so that Meshing and Geometry Entities 00215 //- return the same values as needed in the FacetorTool 00216 inline int CubitFacetData::sense( int index ) { 00217 if(edge_use(index) == 1) 00218 return CUBIT_FORWARD; 00219 else if(edge_use(index) == -1) 00220 return CUBIT_REVERSED; 00221 else 00222 return CUBIT_UNKNOWN; 00223 } 00224 00225 inline void CubitFacetData::edge_use( int direction, int index ) 00226 { 00227 assert( (index >= 0) && (index < 3) ); 00228 if (!is_backwards()) 00229 edgeUse[index] = direction; 00230 else 00231 { 00232 switch(index) 00233 { 00234 case 0: edgeUse[0] = -direction; break; 00235 case 1: edgeUse[2] = -direction; break; 00236 case 2: edgeUse[1] = -direction; break; 00237 } 00238 } 00239 } 00240 00241 #endif 00242 00243
