cgma
#include "iGeom.h"#include <vector>#include <iostream>#include <stdio.h>#include <fstream>#include <assert.h>Go to the source code of this file.
Defines | |
| #define | ASSERT(A) if (!(A)) failed(#A,__FILE__,__LINE__) |
| #define | CHECK(STR) if (err != iBase_SUCCESS) return Print_Error( STR, err, geom, __FILE__, __LINE__ ) |
Functions | |
| int | Tag_Body (iGeom_Instance geom, const iBase_TagHandle tag, const std::string id, const iBase_EntityHandle body) |
| int | Tag_Get (iGeom_Instance geom, const iBase_TagHandle tag, const iBase_EntityHandle body) |
| bool | Print_Error (const char *desc, int err, iGeom_Instance geom, const char *file, int line) |
| int | main () |
Definition at line 9 of file copy_attrib.cpp.
| #define CHECK | ( | STR | ) | if (err != iBase_SUCCESS) return Print_Error( STR, err, geom, __FILE__, __LINE__ ) |
Definition at line 10 of file copy_attrib.cpp.
| int main | ( | ) |
Definition at line 18 of file copy_attrib.cpp.
int err;
iGeom_Instance geom;
double dSide = 10.0, dHeight = 10.0, dRad = 3.0;
iBase_EntityHandle assm = NULL, cyl = NULL, tmp_cyl = NULL, tmp_new = NULL;
std::string geomFile = "test.occ";
iGeom_newGeom( 0, &geom, &err, 0 );
iBase_TagHandle pin_tag = NULL, name_tag = NULL;
char* tag_name_pin = (char*)"PIN";
char* tag_name = (char*)"NAME";
iGeom_getTagHandle(geom, tag_name_pin, &pin_tag, &err, 3);
if(err == iBase_TAG_NOT_FOUND){
iGeom_createTag(geom, tag_name_pin, 1, iBase_INTEGER, &pin_tag, &err, 3);
iGeom_getTagHandle(geom, tag_name, &name_tag, &err, 4);
iGeom_createTag(geom, tag_name, 1, iBase_INTEGER, &name_tag, &err, 4);
// creating prism
std::cout << "\n\n\nCreating Prism\n" << std::endl;
iGeom_createPrism(geom, dHeight, 6,
dSide, dSide,
&assm, &err);
std::string one = "1";
Tag_Body(geom, pin_tag, one, assm);
Tag_Get (geom, pin_tag, assm);
std::cout << "name tag: ";
std::string a = "a";
Tag_Body(geom, name_tag, a, assm);
Tag_Get (geom, name_tag, assm);
std::cout << "\n\n\nCreating Cylinder\n" << std::endl;
// create cylinder
iGeom_createCylinder(geom, dHeight, dRad, dRad, &cyl, &err);
std::string two = "2";
Tag_Body(geom, pin_tag, two, cyl);
Tag_Get(geom, pin_tag, cyl);
std::string b = "b";
Tag_Body(geom, name_tag, b, cyl);
Tag_Get (geom, name_tag, cyl);
// Copy
iGeom_copyEnt(geom, cyl, &tmp_cyl, &err);
std::cout << "\n\n After copy operation\n" << std::endl;
Tag_Get(geom, pin_tag, tmp_cyl);
std::cout << "\ngetting name tag " << std::endl;
Tag_Get(geom, name_tag, tmp_cyl);
// Substract
iGeom_subtractEnts(geom, assm, tmp_cyl, &tmp_new, &err);
std::cout << "\n\n After subtract operation\n" << std::endl;
Tag_Get(geom, pin_tag, tmp_new);
std::cout << "\n getting name tag " << std::endl;
Tag_Get(geom, name_tag, tmp_new);
// save
iGeom_save(geom, geomFile.c_str(), NULL, &err, geomFile.length() , 0);
//check that the two single volume bodys' attributes are exported as SINGLELUMP%
std::string search = "SINGLELUMP%";
std::ifstream Myfile;
Myfile.open (geomFile.c_str());
int found = 0;
std::string line;
size_t offset;
if(Myfile.is_open())
while(!Myfile.eof())
getline(Myfile,line);
if ((offset = line.find(search, 0)) != std::string::npos)
found ++;
Myfile.close();
assert (found == 4);
return 0;
| bool Print_Error | ( | const char * | desc, |
| int | err, | ||
| iGeom_Instance | geom, | ||
| const char * | file, | ||
| int | line | ||
Definition at line 158 of file copy_attrib.cpp.
char buffer[1024];
iGeom_getDescription( geom, buffer, sizeof(buffer) );
buffer[sizeof(buffer)-1] = '\0';
std::cerr << "ERROR: " << desc << std::endl
<< " Error code: " << err << std::endl
<< " Error desc: " << buffer << std::endl
<< " At : " << file << ':' << line << std::endl
return false; // must always return false or CHECK macro will break
| int Tag_Body | ( | iGeom_Instance | geom, |
| const iBase_TagHandle | tag, | ||
| const std::string | id, | ||
| const iBase_EntityHandle | body | ||
Definition at line 111 of file copy_attrib.cpp.
int err = 0;
iGeom_setData(geom, body, tag, id.c_str(), id.size(), &err);
std::cout<<"\nset pin tag - " << id<< " on " << body << std::endl;
return 0;
| int Tag_Get | ( | iGeom_Instance | geom, |
Definition at line 127 of file copy_attrib.cpp.
int err = 0, bytes;
iGeom_getTagSizeBytes( geom, tag, &bytes, &err );
CHECK( "Can't get size" );
std::vector<char> data(bytes);
//just check if pin tag exist, IT'S NOT USED IN THIS FUNCTION
iBase_TagHandle pin1 = NULL;
char* p = (char*)"PIN";
iGeom_getTagHandle(geom, p, &pin1, &err, 3);
CHECK( "PIN tag doesn't exist" );
void* ptr = &data[0];
int junk1 = bytes, junk2;
iGeom_getData( geom, body, tag, (void**)&ptr, &junk1, &junk2, &err );
CHECK( "failed to getData for tag" );
std::cout << "Able to get this tag: "<<*(void**)ptr << " on " << body <<std::endl;
return 0;
