cgma
scale, scaling and bounding box More...
#include "GeometryModifyTool.hpp"#include "GeometryQueryTool.hpp"#include "OCCQueryEngine.hpp"#include "Body.hpp"#include "InitCGMA.hpp"#include "OCCModifyEngine.hpp"#include "CubitCompat.hpp"#include "TestUtilities.hpp"Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
Variables | |
| bool | debug = false |
This program creates solid geometries - compute bounding box1 then scales again computes bounding box2. For a sphere, cylinder and circle-surface with OCE 0.17 and OCC 7.0, the bounding box is not acceptable.
Definition in file scale.cpp.
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 22 of file scale.cpp.
CubitStatus status = InitCGMA::initialize_cgma("OCC");
if (CUBIT_SUCCESS != status) return 1;
GeometryQueryTool *gti = GeometryQueryTool::instance();
GeometryModifyTool *gmti = GeometryModifyTool::instance();
int prob_type =1; // problem type 1 only works, the bounding box computation for sphere, circle surface and cylinder is off - more investigation is needed. The bug is in OCC or OCE not CGM. Tested direct OCE calls and the error persist.
Body* body2 = NULL;
CubitVector plane(1, 0, 0);
if (prob_type == 1)
body2 = gmti->brick(10, 10, 10);
else if (prob_type == 2)
body2 = gmti->sphere(5.0, 0 , 0, 0, 0, false);
else if (prob_type == 3)
body2 = gmti->cylinder(5.0, 5.0, 5.0, 5.0);
else if (prob_type == 4)
body2 = gmti->create_circle_surface(5.0, plane);
// compute bounding box
CubitBox curr_box_before = gti->bounding_box_of_bodies();
CubitVector scale(2, 2, 2);
CubitVector p1(0, 0, 0);
gmti->scale(body2, p1, scale);
CubitBox curr_box_after = gti->bounding_box_of_bodies();
// check if bounding boxes are identical
double tol = 1.0/100;
int return_val = cubit_box_identical(curr_box_after, 2*curr_box_before, tol, true);
// save file if debug true
if (debug){
DLIList<RefEntity*> ref_entity_list;
ref_entity_list.push( (RefEntity*) body2);
const CubitString cubit_version="12.2";
int num_ents_exported=0;
const char *filename = "scale.brep";
const char *filetype = "OCC";
CubitCompat_export_solid_model(ref_entity_list, filename, filetype,
num_ents_exported, cubit_version);
return (return_val-1);
