cgma
00001 00010 #include "GeometryModifyTool.hpp" 00011 #include "GeometryQueryTool.hpp" 00012 #include "OCCQueryEngine.hpp" 00013 #include "Body.hpp" 00014 #include "InitCGMA.hpp" 00015 00016 #include "OCCModifyEngine.hpp" 00017 #include "CubitCompat.hpp" 00018 #include "TestUtilities.hpp" 00019 // main program - initialize, then send to proper function 00020 bool debug = false; 00021 00022 int main (int argc, char **argv) 00023 { 00024 CubitStatus status = InitCGMA::initialize_cgma("OCC"); 00025 if (CUBIT_SUCCESS != status) return 1; 00026 00027 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00028 GeometryModifyTool *gmti = GeometryModifyTool::instance(); 00029 00030 int prob_type =1; // problem type 1 only works, the bounding box computation for sphere, circle surface and cylinder is off - more investigation is needed. The bug is in OCC or OCE not CGM. Tested direct OCE calls and the error persist. 00031 Body* body2 = NULL; 00032 CubitVector plane(1, 0, 0); 00033 if (prob_type == 1) 00034 body2 = gmti->brick(10, 10, 10); 00035 else if (prob_type == 2) 00036 body2 = gmti->sphere(5.0, 0 , 0, 0, 0, false); 00037 else if (prob_type == 3) 00038 body2 = gmti->cylinder(5.0, 5.0, 5.0, 5.0); 00039 else if (prob_type == 4) 00040 body2 = gmti->create_circle_surface(5.0, plane); 00041 00042 // compute bounding box 00043 CubitBox curr_box_before = gti->bounding_box_of_bodies(); 00044 00045 CubitVector scale(2, 2, 2); 00046 CubitVector p1(0, 0, 0); 00047 gmti->scale(body2, p1, scale); 00048 00049 // compute bounding box 00050 CubitBox curr_box_after = gti->bounding_box_of_bodies(); 00051 00052 // check if bounding boxes are identical 00053 double tol = 1.0/100; 00054 int return_val = cubit_box_identical(curr_box_after, 2*curr_box_before, tol, true); 00055 00056 // save file if debug true 00057 00058 if (debug){ 00059 DLIList<RefEntity*> ref_entity_list; 00060 ref_entity_list.push( (RefEntity*) body2); 00061 const CubitString cubit_version="12.2"; 00062 int num_ents_exported=0; 00063 const char *filename = "scale.brep"; 00064 const char *filetype = "OCC"; 00065 CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00066 num_ents_exported, cubit_version); 00067 } 00068 return (return_val-1); 00069 }
