cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetQueryEngine.hpp 00003 // 00004 // Purpose : Facet geometry engine. 00005 // 00006 // This class is implemented as a Singleton pattern. Only 00007 // one instance is created and it is accessed through the 00008 // {instance()} static member function. 00009 // 00010 // Special Notes : 00011 // 00012 // Creator : David R. White 00013 // 00014 // Creation Date : 6/29/00 00015 // 00016 //------------------------------------------------------------------------- 00017 00018 #ifndef FACET_GEOMETRY_ENGINE_HPP 00019 #define FACET_GEOMETRY_ENGINE_HPP 00020 00021 // ********** BEGIN STANDARD INCLUDES ********** 00022 00023 #include <typeinfo> 00024 00025 // ********** END STANDARD INCLUDES ********** 00026 00027 // ********** BEGIN CUBIT INCLUDES ********** 00028 00029 #include "CubitFileIOWrapper.hpp" 00030 #include "GeometryQueryEngine.hpp" 00031 00032 // ********** END CUBIT INCLUDES ********** 00033 00034 // ********** BEGIN FORWARD DECLARATIONS 00035 class TopologyEntity; 00036 class TopologyBridge; 00037 class RefEntity; 00038 class Body; 00039 class Shell; 00040 class ShellSM; 00041 class Loop; 00042 class Chain; 00043 class CoEdgeSM; 00044 class LoopSM; 00045 class RefVolume; 00046 class RefFace; 00047 class RefEdge; 00048 class RefVertex; 00049 class TBPoint; 00050 class Curve; 00051 class Surface; 00052 class Lump; 00053 class BodySM; 00054 00055 class GeometryEntity; 00056 class CubitBox; 00057 class CubitString; 00058 00059 class FacetLump; 00060 class FacetShell; 00061 class FacetLoop; 00062 class FacetSurface; 00063 class FacetBody; 00064 class FacetCoEdge; 00065 class FacetCurve; 00066 class FacetPoint; 00067 00068 class CubitFacet; 00069 class CubitQuadFacet; 00070 class CubitFacetEdge; 00071 class CubitPoint; 00072 class FacetEntity; 00073 class CurveFacetEvalTool; 00074 class FacetEvalTool; 00075 00076 // ********** END FORWARD DECLARATIONS ********** 00077 00078 // ********** BEGIN MACRO DEFINITIONS ********** 00079 // ********** END MACRO DEFINITIONS ********** 00080 00081 // ********** BEGIN ENUM DEFINITIONS ********** 00082 typedef enum { 00083 CUBIT_FACET_FILE, 00084 AVS_FILE, 00085 CHOLLA_FILE, 00086 FROM_FACET_LIST, 00087 STL_FILE 00088 } FacetFileFormat; 00089 00090 // ********** END ENUM DEFINITIONS ********** 00091 00092 class FacetQueryEngine : public GeometryQueryEngine 00093 { 00094 public: 00095 // ********** BEGIN FRIEND DECLARATIONS ********** 00096 friend class FacetSurface; 00097 00098 // ********** END FRIEND DECLARATIONS ********** 00099 00100 //HEADER- Constructor and Destructor 00101 00102 static FacetQueryEngine* instance(); 00103 //- Singleton pattern 00104 //- Controlled access and creation of the sole instance of this class. 00105 00106 virtual ~FacetQueryEngine(); 00107 00108 static void delete_instance(); 00109 00110 const char* modeler_type() 00111 { return "facet"; } 00112 00113 int get_major_version(); 00114 00115 int get_minor_version(); 00116 00117 int get_subminor_version(); 00118 00119 CubitString get_engine_version_string(); 00120 00121 //HEADER- RTTI and safe casting functions. 00122 00123 virtual const std::type_info& entity_type_info() const ; 00124 //R- The geometric modeler type 00125 //- This function returns the type of the geometric modeler. 00126 00127 virtual CubitBoolean is_solid_modeler_type() const 00128 {return CUBIT_FALSE;} 00129 //R CubitBoolean 00130 //R- This is not a solid modeling engine. 00131 //HEADER- Functions for importing and exporting solid models. 00132 00133 CubitBoolean can_delete_bodies(DLIList<Body*>body_list); 00134 00135 virtual TBPoint* make_Point( GeometryType point_type, 00136 CubitVector const& point) const ; 00137 virtual Curve* make_Curve(Curve *) const; 00138 virtual Curve* make_Curve( TBPoint const* , 00139 TBPoint const* , 00140 RefFace* , 00141 CubitVector * ) const; 00142 virtual Curve* make_Curve( GeometryType , 00143 TBPoint const* , 00144 TBPoint const* , 00145 DLIList<CubitVector*>& , 00146 RefFace* ) const; 00147 virtual Curve* make_Curve( GeometryType , 00148 TBPoint const* , 00149 TBPoint const* , 00150 CubitVector const* , 00151 CubitSense ) const; 00152 virtual Surface* make_Surface( Surface *, 00153 DLIList<Loop*> &, 00154 CubitBoolean ) const; 00155 00156 00157 virtual Surface* make_Surface( GeometryType , 00158 DLIList<Curve*>& , 00159 DLIList<Loop*> &, 00160 Surface *) const ; 00161 virtual Lump* make_Lump( GeometryType , 00162 DLIList<Surface*>& ) const ; 00163 virtual BodySM* make_BodySM( Surface * ) const; 00164 virtual BodySM* make_BodySM( DLIList<Lump*>& ) const ; 00165 00166 Body* copy_body( Body *body_ptr ); 00167 00168 virtual CubitStatus get_graphics( BodySM *bodysm, GMem* g_mem, 00169 std::vector<Surface*> &surface_to_facets_vector, 00170 std::vector<TopologyBridge*> &vertex_edge_to_point_vector, 00171 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > &facet_edges_on_curves, 00172 unsigned short normal_tolerance, 00173 double distance_tolerance, double max_edge_length ) const; 00174 00175 virtual CubitStatus get_graphics( Surface* surface_ptr, 00176 GMem* gMem, 00177 unsigned short normal_tolerance, 00178 double distance_tolerance, 00179 double max_edge_length ) const; 00180 00181 virtual CubitStatus get_graphics( Curve* curve_ptr, 00182 GMem* gMem, 00183 double angle_tolerance=0, 00184 double distance_tolerance=0, 00185 double max_edge_length=0 ) const; 00186 //R CubitStatus 00187 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00188 //I ref_edge_ptr 00189 //I- The RefEdge for which hoops facetting information will be 00190 //I- gathered. 00191 //O numSteps 00192 //O- The number of points in resulting polyline. 00193 //O gMem 00194 //O- The storage place for edges, involved in facetting. 00195 //I tolerance 00196 //I- The tolerance deviation used when facetting the curve (optional 00197 //I- and currently IGNORED by this engine). 00198 //- This function gathers and outputs edge information for 00199 //- hoops involved in facetting a RefEdge. If all goes well, 00200 //- CUBIT_SUCCESS is returned. Otherwise, CUBIT_FAILURE is 00201 //- returned. 00202 00203 virtual CubitStatus get_isoparametric_points(Surface* , 00204 int &, int &, 00205 GMem*&) const; 00206 00207 virtual CubitStatus get_u_isoparametric_points(Surface* ref_face_ptr, 00208 double v, int &n, 00209 GMem *&gMem) const; 00210 00211 virtual CubitStatus get_v_isoparametric_points(Surface* ref_face_ptr, 00212 double u, int &n, 00213 GMem *&gMem) const; 00214 00215 virtual CubitStatus transform_vec_position( 00216 CubitVector const& , 00217 BodySM *, 00218 CubitVector & ) const; 00219 00220 virtual CubitStatus get_intersections( Curve*, CubitVector& point1, 00221 CubitVector&, 00222 DLIList<CubitVector>& , 00223 CubitBoolean, 00224 CubitBoolean ); 00225 00226 virtual CubitStatus get_intersections( Curve* , Curve* , 00227 DLIList<CubitVector>& , 00228 CubitBoolean, 00229 CubitBoolean ); 00230 virtual CubitStatus get_intersections( Curve* ref_edge1, Curve* ref_edge2, 00231 DLIList<CubitVector>& intersection_list, 00232 double offset, 00233 CubitBoolean ext_first = CUBIT_TRUE ); 00234 virtual CubitStatus get_intersections( Curve* ref_edge, Surface* ref_face, 00235 DLIList<CubitVector>& intersection_list, 00236 CubitBoolean bounded = CUBIT_FALSE ); 00237 00238 virtual CubitStatus entity_extrema( DLIList<GeometryEntity*> &entity_list, 00239 const CubitVector *dir1, 00240 const CubitVector *dir2, 00241 const CubitVector *dir3, 00242 CubitVector &extrema, 00243 GeometryEntity *&extrema_entity_ptr ); 00244 //- Gets the extrema position along the first given direction. If there 00245 //- is more than one extrema position, the other directions will be used 00246 //- to determine a unique position. Directions 2 and 3 can be NULL. 00247 //- Entities supported include bodies, volumes, surfaces, curves and 00248 //- vertices. The entity the extrema is found on is also returned. 00249 00250 virtual CubitStatus entity_entity_distance( GeometryEntity *ref_entity_ptr1, 00251 GeometryEntity *ref_entity_ptr2, 00252 CubitVector &pos1, CubitVector &pos2, 00253 double &distance ); 00254 //- Gets the minimum distance between two entities and the closest positions 00255 //- on those entities. Supports vertices, curves, surfaces, volumes and bodies. 00256 00257 virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list, 00258 const char* file_name, 00259 Model_File_Type file_type, 00260 const CubitString &cubit_version, 00261 ModelExportOptions &export_options ); 00262 00263 virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list, 00264 char*& p_buffer, 00265 int& n_buffer_size, 00266 bool b_export_buffer) 00267 {return CUBIT_FAILURE;} 00268 00269 virtual CubitStatus save_temp_geom_file( DLIList<TopologyBridge*>& ref_entity_list, 00270 const char *file_name, 00271 const CubitString &cubit_version, 00272 CubitString &created_file, 00273 CubitString &created_file_type ); 00274 00275 virtual CubitStatus import_solid_model(const char* file_name, 00276 Model_File_Type file_type, 00277 DLIList<TopologyBridge*>& imported_entities, 00278 ModelImportOptions &import_options ); 00279 00280 virtual CubitStatus import_solid_model(DLIList<TopologyBridge*> &imported_entities, 00281 const char* pBuffer, 00282 const int n_buffer_size) 00283 {return CUBIT_FAILURE;} 00284 00285 private: 00286 CubitStatus import_solid_model(FILE *file_ptr, 00287 DLIList<TopologyBridge*> &imported_entities ); 00288 00289 public: 00290 virtual void delete_solid_model_entities(DLIList<BodySM*>& body_list) const; 00291 //- Deletes all solid model entities associated with the Bodies in 00292 //- the input list. 00293 00294 virtual CubitStatus delete_solid_model_entities( BodySM* body_ptr ) const; 00295 virtual CubitStatus delete_solid_model_entities(Surface* surf_ptr ) const; 00296 virtual CubitStatus delete_solid_model_entities( Curve* curve_ptr ) const; 00297 virtual CubitStatus delete_solid_model_entities( TBPoint* point_ptr ) const; 00298 00299 virtual CubitStatus fire_ray( CubitVector &origin, 00300 CubitVector &direction, 00301 DLIList<TopologyBridge*> &at_entity_list, 00302 DLIList<double> &ray_params, 00303 int max_hits, 00304 double ray_radius, 00305 DLIList<TopologyBridge*> *hit_entity_list=0 ) const; 00306 //- Fire a ray at specified entities, returning the parameters (distances) 00307 //- along the ray and optionally the entities hit. Returned lists are 00308 //- appended to. Input entities can be any of bodies, volumes, faces, 00309 //- edges or vertices. Optionally you can specify the maximum number of 00310 //- hits to return (default = 0 = unlimited), and the ray radius to use for 00311 //- intersecting the entities (default = 0.0 = use modeller default). 00312 //- NOTE: returned entities hit might be "hidden" beneath virtual entities. 00313 //- To resolve to visible entities, use "get_visible_ents_for_hits" 00314 //- in GeometryQueryTool. 00315 00316 virtual double get_sme_resabs_tolerance() const; // Gets solid modeler's resolution absolute tolerance 00317 virtual double set_sme_resabs_tolerance( double new_resabs ); 00318 00319 virtual CubitStatus set_int_option( const char* opt_name, int val ); 00320 virtual CubitStatus set_dbl_option( const char* opt_name, double val ); 00321 virtual CubitStatus set_str_option( const char* opt_name, const char* val ); 00322 //- Set solid modeler options 00323 00324 static CubitStatus make_facets( int *conn, int nfacets, 00325 DLIList<CubitQuadFacet *> &facet_list ); 00326 static CubitStatus make_facets( int *conn, int nfacets, 00327 DLIList<CubitFacet *> &facet_list ); 00328 //- create facets from a list of points and connectivity 00329 00330 CubitStatus ensure_is_ascii_stl_file(FILE * fp, CubitBoolean &is_ascii); 00331 //- returns true in is_ascii if fp points to an ascii stl file 00332 00333 CubitStatus read_facets_stl_tolerance( 00334 DLIList<CubitFacet *> &tfacet_list, 00335 DLIList<CubitPoint *> &point_list, 00336 const char * file_name, 00337 int &npoints, 00338 int &ntri, 00339 long& seek_address, 00340 double tolerance); 00341 //- read facets from an stl file and combine vertices within tolerance distance 00342 00343 CubitStatus read_facets_stl( 00344 DLIList<CubitFacet *> &tfacet_list, 00345 DLIList<CubitPoint *> &point_list, 00346 const char * file_name, 00347 int &npoints, 00348 int &ntri, 00349 long& seek_address); 00350 //- read facets from an stl file 00351 00352 CubitStatus import_facets( const char *file_name, 00353 CubitBoolean use_feature_angle, 00354 double feature_angle, 00355 double tolerance, 00356 int interp_order, 00357 CubitBoolean smooth_non_manifold, 00358 CubitBoolean split_surfaces, 00359 CubitBoolean stitch, 00360 CubitBoolean improve, 00361 DLIList <CubitQuadFacet *>&quad_facet_list, 00362 DLIList <CubitFacet *> &tri_facet_list, 00363 DLIList<Surface *> &surface_list, 00364 FacetFileFormat file_format = CUBIT_FACET_FILE ); 00365 //- import facets from a file and create a geometry model 00366 00367 static CubitStatus read_facets( const char * file_name, 00368 int *&conn, 00369 int &npoints, 00370 int &nquad, int &ntri, 00371 FacetFileFormat file_format = CUBIT_FACET_FILE ); 00372 static CubitStatus read_cholla_file( const char *file_name, 00373 double &feature_angle, 00374 DLIList<CubitPoint *> &point_list, 00375 DLIList<CubitFacet *> &facet_list); 00376 //- read points and facets from a file 00377 00378 CubitBoolean is_close(CubitVector &this_point, 00379 DLIList<CubitFacet *>&facet_list, 00380 CubitFacet *&lastFacet, 00381 double tol); 00382 //- determine if one of the facets in the list is within a 00383 //- certain distance of the point. 00384 00385 static CubitStatus export_facets(DLIList<CubitFacet*> &facet_list, 00386 char *filename); 00387 //- export a list of facets to a facet file for debugging purposes 00388 00389 CubitStatus gather_all_facet_entities( DLIList<FacetBody*> &facet_bodies, 00390 DLIList<FacetLump*> &facet_lumps, 00391 DLIList<FacetShell*> &facet_shells, 00392 DLIList<FacetSurface*> &facet_surfaces, 00393 DLIList<FacetLoop*> &facet_loops, 00394 DLIList<FacetCoEdge*> &facet_coedges, 00395 DLIList<FacetCurve*> &facet_curves, 00396 DLIList<FacetPoint*> &facet_points ); 00397 00398 CubitStatus save_facets( FILE *fp, DLIList<FacetSurface*> facet_surfaces, 00399 DLIList<FacetCurve*> facet_curves, 00400 DLIList<FacetPoint*> facet_points ); 00401 00402 CubitStatus save_eval_tools( FILE *fp, DLIList<FacetSurface*> facet_surfaces, 00403 DLIList<FacetCurve*> facet_curves ); 00404 00405 CubitStatus dump_facets( FILE *fp, 00406 DLIList<CubitFacet *> &facet_list, 00407 DLIList<CubitFacetEdge *> &edge_list, 00408 DLIList<CubitPoint *> &point_list ); 00409 CubitStatus gather_facets( DLIList<FacetSurface *> facet_surfaces, 00410 DLIList<FacetCurve *> facet_curves, 00411 DLIList<FacetPoint *> facet_points, 00412 DLIList<CubitFacet *> &facet_list, 00413 DLIList<CubitFacetEdge *> &edge_list, 00414 DLIList<CubitPoint *> &point_list ); 00415 //- functions for saving the facet geometry representation to a cubit file 00416 00417 CubitStatus restore_eval_tools( FILE *fp, 00418 unsigned int endian, 00419 int num_facets, 00420 int num_edges, 00421 int num_points, 00422 CubitFacet **facets, 00423 CubitFacetEdge **edges, 00424 CubitPoint **points, 00425 int &num_cfet, 00426 int &num_fet, 00427 CurveFacetEvalTool **&cfeval_tools, 00428 FacetEvalTool **&feval_tools ); 00429 //- restore facets from CUB file 00430 00431 CubitStatus create_super_facet_bounding_box( 00432 DLIList<BodySM*>& body_list, 00433 CubitBox& super_box ); 00434 CubitStatus create_facet_bounding_box( 00435 BodySM* bodySM, 00436 CubitBox& bbox ); 00437 00438 CubitStatus restore_transform( BodySM* body ); 00439 00440 CubitStatus translate( BodySM* body, const CubitVector& offset ); 00441 CubitStatus rotate ( BodySM* body, const CubitVector& axis, double angle ); 00442 CubitStatus scale ( BodySM* body, double factor ); 00443 CubitStatus scale ( BodySM* body, const CubitVector& factors ); 00444 CubitStatus reflect ( BodySM* body, const CubitVector& axis ); 00445 00446 CubitStatus translate( GeometryEntity* ent, const CubitVector& offset ); 00447 CubitStatus rotate ( GeometryEntity* ent, const CubitVector& axis, double degrees ); 00448 CubitStatus scale ( GeometryEntity* ent, double factor ); 00449 CubitStatus scale ( GeometryEntity* ent, const CubitVector& factors ); 00450 CubitStatus reflect ( GeometryEntity* ent, const CubitVector& axis ); 00451 00452 CubitStatus get_connected_patch( DLIList<FacetSurface*>& remaining_surfs, 00453 DLIList<FacetSurface*>& output_patch ); 00454 virtual CubitBoolean bodies_overlap (BodySM *body_ptr_1, 00455 BodySM *body_ptr_2 ) const; 00456 virtual CubitBoolean volumes_overlap (Lump *lump_ptr_1, 00457 Lump *lump_ptr_2 ) const; 00458 //R CubitBoolean 00459 //R- CUBIT_TRUE if the two bodies overlap, CUBIT_FALSE if they don't 00460 //R- overlap. If the bodies are touching the function 00461 //R- should return CUBIT_FALSE. 00462 //I body_ptr_1, body_ptr_2 00463 //I- The two body pointers that are being tested for overlap. 00464 //- The function uses the intersect call to test if the bodies 00465 //- are overlaping. The full intersect Boolean is needed to see if 00466 //- the bodies actually overlap and don't just touch. 00467 00468 virtual CubitStatus get_point_containment( DLIList<BodySM*> &bodysm_list, 00469 DLIList<CubitVector> &point_list, 00470 double tolerance, 00471 bool allow_pts_in_multiple_bodies, 00472 std::vector< std::pair<BodySM*, std::vector<int> > > &bodysm_to_pt_indices ); 00473 00474 protected: 00475 00476 FacetQueryEngine(); 00477 00478 private: 00479 00480 CubitStatus write_topology( FILE *file_ptr, 00481 DLIList<FacetBody*> &facet_bodies, 00482 DLIList<FacetLump*> &facet_lumps, 00483 DLIList<FacetShell*> &facet_shells, 00484 DLIList<FacetSurface*> &facet_surfaces, 00485 DLIList<FacetLoop*> &facet_loops, 00486 DLIList<FacetCoEdge*> &facet_coedges, 00487 DLIList<FacetCurve*> &facet_curves, 00488 DLIList<FacetPoint*> &facet_points ); 00489 00490 CubitStatus restore_topology( FILE *file_ptr, 00491 unsigned int endian, 00492 int num_points, 00493 CubitPoint **points_array, 00494 int num_cfet, 00495 CurveFacetEvalTool **cfev_array, 00496 int num_fet, 00497 FacetEvalTool **fev_array, 00498 DLIList<TopologyBridge*> &imported_entities ); 00499 00500 CubitStatus restore_facets( FILE *file_ptr, 00501 unsigned int endian, 00502 int &num_facets, 00503 int &num_edges, 00504 int &num_points, 00505 CubitPoint**&points_array, 00506 int &num_cfet, 00507 int &num_fet, 00508 CurveFacetEvalTool **&cfet_array, 00509 FacetEvalTool **&fet_array); 00510 00511 CubitStatus read_facets( FILE *fp, 00512 unsigned int endian, 00513 int &num_facets, int &num_edges, int &num_points, 00514 CubitFacet **&facets, CubitFacetEdge **&edges, 00515 CubitPoint **&points ); 00516 00517 static FacetQueryEngine* instance_; 00518 //- static pointer to unique instance of this class 00519 00520 static CubitStatus init_hash_points( int num_points ); 00521 static CubitStatus add_hash_point( CubitPoint *point_ptr ); 00522 static CubitPoint *get_hash_point( int id ); 00523 static void delete_hash_points( ); 00524 static int get_hash_key( int id ); 00525 static CubitStatus get_all_hash_points(DLIList<CubitPoint *> &point_list); 00526 static int hashPointSize; 00527 static DLIList<CubitPoint *> *hashPointArray; 00528 //- hash table functions used for reading the facet file 00529 00530 static const int FQE_MAJOR_VERSION; 00531 static const int FQE_MINOR_VERSION; 00532 static const int FQE_SUBMINOR_VERSION; 00533 }; 00534 00535 // ********** BEGIN INLINE FUNCTIONS ********** 00536 // ********** END INLINE FUNCTIONS ********** 00537 00538 // ********** BEGIN FRIEND FUNCTIONS ********** 00539 // ********** END FRIEND FUNCTIONS ********** 00540 00541 // ********** BEGIN EXTERN FUNCTIONS ********** 00542 // ********** END EXTERN FUNCTIONS ********** 00543 00544 // ********** BEGIN HELPER CLASS DECLARATIONS ********** 00545 // ********** END HELPER CLASS DECLARATIONS ********** 00546 00547 #endif
