cgma
00001 //- Class: FacetDataUtil 00002 //- Description: static library of general functions for querying and/or modifying 00003 //- facet entities 00004 //- Owner: Steve Owen 00005 //- Checked by: 00006 //- Version: 00007 00008 #ifndef __FACETDATAUTIL__ 00009 #define __FACETDATAUTIL__ 00010 00011 #include "DLIList.hpp" 00012 #include "RTree.hpp" 00013 00014 class CubitPoint; 00015 class CubitFacet; 00016 class CubitFacetEdge; 00017 class CubitQuadFacet; 00018 class FacetEntity; 00019 class CubitVector; 00020 class CubitBox; 00021 00022 class FacetDataUtil 00023 { 00024 public: 00025 // get edges from a facet list that are common to "count" facets 00026 // For example, passing in: 00027 // count = 1 returns the boundary edges of a set of facets 00028 // count = 2 returns the interior, manifold edges of a set of facets 00029 // count = n>2 returns non-manifold edges shared by n facets 00030 // 00031 static void edges_by_count(DLIList<CubitFacet*> &facets, 00032 unsigned int count, 00033 DLIList<CubitFacetEdge*> &edges); 00034 00035 // get an ordered list of points and edges around the boundary of a set of facets 00036 // The output "chain" consists of point - edge - point - edge - ... around the 00037 // boundary of the input facets. Having the ordered points as well as the edges 00038 // helps provides sense information for the bounding edges. 00039 static void ordered_point_edge_bdry(DLIList<CubitFacet*> &facets, 00040 DLIList<FacetEntity*> &point_edge_chain); 00041 00042 // given an ordered point - edge boundary and a start and end point on the boundary, 00043 // return the point - edge chain between the two points, inclusive. 00044 static CubitStatus partial_chain(DLIList<FacetEntity*> &point_edge_chain, 00045 FacetEntity* point1, 00046 FacetEntity* point2, 00047 DLIList<FacetEntity*> &chain_between); 00048 00049 // given a set of facets, get the unique list of points used to define the facets. 00050 static void get_facet_points(DLIList<CubitFacet*> &cubit_facets, 00051 DLIList<CubitPoint*> &facet_points); 00052 00053 // given a set of facets, return an unordered list of points at its boundary 00054 static void get_boundary_points(DLIList<CubitFacet*> &facet_list, 00055 DLIList<CubitPoint*> &point_list); 00056 00057 // return an unordered list of edges at the boundary of a set of facets 00058 static void get_boundary_edges(DLIList<CubitFacet*> &facet_list, 00059 DLIList<CubitFacetEdge*> &edge_list); 00060 00061 // get the unique set of points from a facet list 00062 static void get_points( DLIList<CubitFacet*> &facet_list, 00063 DLIList<CubitPoint*> &point_list); 00064 00065 // make a complete copy of facets and points 00066 static void copy_facets(DLIList<CubitFacet*> &old_facet_list, 00067 DLIList<CubitFacet*> &new_facet_list, 00068 DLIList<CubitPoint*> &new_point_list, 00069 DLIList<CubitFacetEdge*> &new_edge_list ); 00070 00071 // populates the edge list from the list of facets - creates the 00072 // edges if necessary 00073 static void get_edges( DLIList<CubitFacet *> &facet_list, 00074 DLIList<CubitFacetEdge *> &edge_list ); 00075 00076 // compute the quality of a triangle defined by three vertices 00077 static double quality(CubitVector &c1, CubitVector &c2, CubitVector &c3, 00078 CubitVector &surf_normal); 00079 00080 // collapse edges that are shorter than 10% of the average edge length 00081 static CubitStatus collapse_short_edges( DLIList<CubitFacet*> &facet_list, 00082 CubitBoolean non_manifold_only ); 00083 00084 static void check(DLIList<CubitFacetEdge *> &edge_list, 00085 DLIList<CubitFacet *> &facet_list); 00086 00087 static void draw_edge( CubitFacetEdge *edge ); 00088 00089 static int edge_compare(CubitFacetEdge *&ea, CubitFacetEdge *&eb); 00090 00091 // for triangulated, manifold, non-self-intersecting polyhedra 00092 static CubitStatus is_point_in_polyhedron(DLIList<CubitFacet *> &tfacet_list, 00093 CubitVector &point_coords, 00094 CubitPointContainment &is_point_in); 00095 00096 // can return CUBIT_FAILURE if triangles are very thin 00097 // used by is_point_in_polyhedron() 00098 static CubitStatus pt_in_tri_2d(double xpt, double ypt, 00099 double x0, double y0, 00100 double x1, double y1, 00101 double x2, double y2, 00102 CubitPointContainment &is_point_in); 00103 00104 00105 // Returns a normalized ray always pointing in the (+++) direction. 00106 // used by is_point_in_polyhedron() 00107 static void random_positive_ray(CubitVector& ray); 00108 00109 // used by is_point_in_polyhedron() 00110 static bool ray_intersects_boundingbox(CubitVector& point, CubitVector& ray, const CubitBox& bbox); 00111 00112 // write a facet list to a facet file 00113 static CubitStatus write_facets( const char *file_name, 00114 DLIList<CubitFacet *> &facet_list); 00115 00116 // group facets into continuous lists 00117 static CubitStatus split_into_shells( DLIList<CubitFacet *> &tfacet_list, 00118 DLIList<CubitQuadFacet *> &qfacet_list, 00119 DLIList<DLIList<CubitFacet *> *> &shell_list, 00120 CubitBoolean &is_water_tight); 00121 00122 // attempt to stitch up the model to make water-tight 00123 static CubitStatus stitch_facets( DLIList<DLIList<CubitFacet *> *> &shell_list, 00124 double tol, CubitBoolean &is_water_tight, 00125 CubitBoolean write_results = CUBIT_TRUE); 00126 00127 // delete a list of facets and their child facet entities 00128 static void delete_facets(DLIList<DLIList<CubitFacet*>*> &shell_list); 00129 static void delete_facets(DLIList<CubitFacet*> &facet_list); 00130 static void delete_facet(CubitFacet *facet_ptr); 00131 static void destruct_facet_no_delete(CubitFacet *facet_ptr); 00132 00133 00134 // determine intersection of a segment with a facet 00135 // returns CUBIT_PNT_UNKNOWN: if segment is in plane of facet 00136 // CUBIT_PNT_OUTSIDE: if segment does not intersect 00137 // CUBIT_PNT_INSIDE: if segment intersects inside facet 00138 // CUBIT_PNT_BOUNDARY: if segment intersects a vertex or edge 00139 static CubitPointContainment intersect_facet(CubitVector &start, CubitVector &end, 00140 CubitFacet *facet_ptr, 00141 CubitVector &qq, 00142 CubitVector &ac, 00143 CubitBoolean bound = CUBIT_TRUE); 00144 00145 // get axis-aligned bounding box of list of points 00146 static CubitStatus get_bbox_of_points(DLIList<CubitPoint*>& point_list, CubitBox& bbox); 00147 00148 // get square of distance from point to closest point on a line segment; 00149 // returns closest point. 00150 static CubitVector squared_distance_to_segment(CubitVector &p, 00151 CubitVector &p0, 00152 CubitVector &p1, 00153 double &distance2); 00154 00155 // Get the intersection of the line defined by point1 and point2 with 00156 // bbox. Returns 0,1 or 2 for the number of intersections. A line 00157 // in one of the planes of the box will return 0. 00158 static int get_bbox_intersections(CubitVector& point1, 00159 CubitVector& point2, 00160 const CubitBox& bbox, 00161 CubitVector& intersection_1, 00162 CubitVector& intersection_2); 00163 00164 // mark facets and their children 00165 static void mark_facets( DLIList<FacetEntity *> &facet_list, int mark_value ); 00166 00167 // used with stitch_facets to merge points that are coincident 00168 static CubitStatus merge_coincident_vertices( DLIList<DLIList<CubitFacet *> *> &shell_list, 00169 double tol, 00170 int &mpmerge, 00171 int &nemerge, 00172 DLIList<CubitPoint *> &unmerged_points); 00173 00174 static CubitStatus merge_coincident_vertices( DLIList<CubitPoint*> &points ); 00175 00176 // used with stitch_facets to merge two points together that have already been 00177 // determined to be coincident. Also handles their adjacent edges 00178 static CubitStatus merge_points( CubitPoint *pt0, CubitPoint *pt1, int &nemerge, 00179 RTree<CubitFacetEdge*> *r_tree=NULL); 00180 00181 static CubitStatus find_facet( DLIList<CubitFacet *> temp_split_facets, 00182 CubitPoint *pnt0, 00183 CubitPoint *pnt1, 00184 DLIList<CubitFacet *> &select_facets ); 00185 00186 00187 private: 00188 00189 // used with split_into_shells to group facets 00190 static CubitStatus get_adj_facets_on_shell( CubitFacet *start_facet_ptr, 00191 DLIList<CubitFacet *> *shell_ptr, 00192 CubitBoolean &is_water_tight, 00193 int mydebug ); 00194 00195 // used with stitch_facets to merge points that are colinear with edges 00196 static CubitStatus merge_colinear_vertices( DLIList<DLIList<CubitFacet *> *> &shell_list, 00197 double tol, 00198 DLIList<CubitPoint *> &merge_points, 00199 int &mpmerge, 00200 int &nemerge, 00201 int &nnomerge); 00202 00203 00204 }; 00205 00206 #endif 00207
