cgma
00001 //------------------------------------------------------------------------- 00002 //------------------------------------------------------------------------- 00003 00004 // Filename : FacetModifyEngine.cpp 00005 // 00006 // Purpose : ModifyEngine for faceted geometry 00007 // 00008 // Special Notes : Modeled after GeometryModifyEngine and OCCModifyEngine. 00009 // 00010 // Creator : John Fowler 00011 // 00012 // Creation Date : 6/02 00013 // 00014 // Owner : John Fowler 00015 //------------------------------------------------------------------------- 00016 00017 #include "FacetModifyEngine.hpp" 00018 #include "FacetQueryEngine.hpp" 00019 #include "SettingHandler.hpp" 00020 00021 #include "CubitMessage.hpp" 00022 #include "CubitDefines.h" 00023 00024 #include "CubitUtil.hpp" 00025 #include "CubitPoint.hpp" 00026 #include "CubitPointData.hpp" 00027 #include "CubitFacet.hpp" 00028 #include "CubitQuadFacet.hpp" 00029 #include "CubitFacetData.hpp" 00030 #include "CubitFacetEdge.hpp" 00031 #include "CubitFacetEdgeData.hpp" 00032 #include "GeometryQueryTool.hpp" 00033 #include "GeometryModifyTool.hpp" 00034 #include "ChollaSurface.hpp" 00035 #include "ChollaCurve.hpp" 00036 #include "ChollaPoint.hpp" 00037 #include "FacetPoint.hpp" 00038 #include "FacetCurve.hpp" 00039 #include "CurveFacetEvalTool.hpp" 00040 #include "FacetEvalTool.hpp" 00041 #include "FacetCoEdge.hpp" 00042 #include "FacetLoop.hpp" 00043 #include "FacetSurface.hpp" 00044 #include "FacetShell.hpp" 00045 #include "FacetLump.hpp" 00046 #include "FacetBody.hpp" 00047 #include "ChollaEngine.hpp" 00048 #include "TDGeomFacet.hpp" 00049 #include "CubitFileIOWrapper.hpp" 00050 #include "TDFacetBoundaryPoint.hpp" 00051 #include "Cholla.h" 00052 #include "Body.hpp" 00053 #include "GfxDebug.hpp" 00054 #include "RefFace.hpp" 00055 #include "FacetDataUtil.hpp" 00056 #include "FBDataUtil.hpp" 00057 #include "FBIntersect.hpp" 00058 #include "IntegerHash.hpp" 00059 #include "FacetboolInterface.hpp" 00060 #include "CpuTimer.hpp" 00061 #include "ProgressTool.hpp" 00062 #include "AppUtil.hpp" 00063 #include "SphereEvaluator.hpp" 00064 #include "CylinderEvaluator.hpp" 00065 #include "CubitLoops.hpp" 00066 #include "FacetProjectTool.hpp" 00067 00068 #include <algorithm> 00069 00070 FacetModifyEngine* FacetModifyEngine::instance_ = 0; 00071 CubitBoolean FacetModifyEngine::modifyEnabled = CUBIT_FALSE; 00072 00073 //The do... while(0) trick is to get the trailing semicolon to 00074 // do nothing in some very rare cases. From Steven Engelhardt's Weblog. 00075 00076 #define MODIFY_CHECK_RETURN_NULL \ 00077 do {if(!modifyEnabled){ \ 00078 PRINT_INFO("Facet-based geometry modification is a beta capability.\n");\ 00079 PRINT_ERROR("This capability is currently disabled.\n");\ 00080 PRINT_INFO("To enable this capability, issue the command 'set developer commands on'. \n");\ 00081 return NULL;} }while(0) 00082 00083 #define MODIFY_CHECK_RETURN_VOID \ 00084 do {if(!modifyEnabled){ \ 00085 PRINT_INFO("Facet-based geometry modification is a beta capability.\n");\ 00086 PRINT_ERROR("This capability is currently disabled.\n");\ 00087 PRINT_INFO("To enable this capability, issue the command 'set developer commands on'. \n");\ 00088 return;} }while(0) 00089 00090 #define MODIFY_CHECK_RETURN_FAILURE \ 00091 do {if(!modifyEnabled){ \ 00092 PRINT_INFO("Facet-based geometry modification is a beta capability.\n");\ 00093 PRINT_ERROR("This capability is currently disabled.\n");\ 00094 PRINT_INFO("To enable this capability, issue the command 'set developer commands on'. \n");\ 00095 return CUBIT_FAILURE;} }while(0) 00096 //=============================================================================== 00097 // Function : FacetModifyEngine 00098 // Member Type: PUBLIC 00099 // Description: constructor 00100 // Author : John Fowler 00101 // Date : 10/02 00102 //=============================================================================== 00103 FacetModifyEngine::FacetModifyEngine() 00104 { 00105 // assert( !instance_ ); 00106 00107 // add this modify engine to geometrymodifytool 00108 GeometryModifyTool::instance()->add_gme(this); 00109 } 00110 //Initialize all settings in this class 00111 void FacetModifyEngine::initialize_settings() 00112 { 00113 00114 SettingHandler::instance()->add_setting( 00115 "Facet_modify",FacetModifyEngine::set_modify_enabled, 00116 FacetModifyEngine::is_modify_enabled); 00117 00118 } 00119 00120 //=============================================================================== 00121 // Function : ~FacetModifyEngine 00122 // Member Type: PUBLIC 00123 // Description: destructor 00124 // Author : John Fowler 00125 // Date : 10/02 00126 //=============================================================================== 00127 FacetModifyEngine::~FacetModifyEngine() 00128 { 00129 instance_ = 0; 00130 } 00131 00132 //=============================================================================== 00133 // Function : make_Point 00134 // Member Type: PUBLIC 00135 // Description: make a geometric entity point 00136 // Author : John Fowler 00137 // Date : 10/02 00138 //=============================================================================== 00139 TBPoint* FacetModifyEngine::make_Point( CubitVector const& point) const 00140 { 00141 FacetModifyEngine *self = const_cast<FacetModifyEngine *> (this); 00142 TBPoint* new_point = NULL; 00143 self->make_facet_point(point, new_point); 00144 return new_point; 00145 } 00146 00147 //=============================================================================== 00148 // Function : make_Curve 00149 // Member Type: PUBLIC 00150 // Description: make a curve 00151 // Author : John Fowler 00152 // Date : 10/02 00153 //=============================================================================== 00154 Curve* FacetModifyEngine::make_Curve(Curve * /*curve_ptr*/, 00155 std::map<TopologyBridge*, TopologyBridge*> *old_tb_to_new_tb ) const 00156 { 00157 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00158 return (Curve*) NULL; 00159 } 00160 00161 //=============================================================================== 00162 // Function : make_Curve 00163 // Member Type: PUBLIC 00164 // Description: make a curve 00165 // Author : John Fowler 00166 // Date : 10/02 00167 //=============================================================================== 00168 Curve* FacetModifyEngine::make_Curve( TBPoint const* point1_ptr, 00169 TBPoint const* point2_ptr, 00170 Surface* ref_face_ptr, 00171 const CubitVector * third_point) const 00172 { 00173 00174 CubitPoint* p1 = static_cast<const FacetPoint*>(point1_ptr)->get_cubit_point(); 00175 CubitPoint* p2 = static_cast<const FacetPoint*>(point2_ptr)->get_cubit_point(); 00176 00177 // gather data 00178 CubitVector v1 = p1->coordinates(); 00179 CubitVector v2 = p2->coordinates(); 00180 CubitVector v3 = third_point ? *third_point : CubitVector(); 00181 00182 DLIList<CubitVector*> pts; 00183 pts.append(&v1); 00184 if(third_point) 00185 pts.append(&v3); 00186 pts.append(&v2); 00187 00188 FacetSurface* facet_surf = CAST_TO( ref_face_ptr, FacetSurface ); 00189 DLIList<CubitPoint*> surf_pts; 00190 DLIList<CubitFacet*> surf_facets; 00191 facet_surf->get_my_facets(surf_facets, surf_pts); 00192 00193 00194 std::vector<double> facet_pts; 00195 std::vector<int> facet_conn; 00196 00197 for(DLIList<CubitPoint*>::iterator iter = surf_pts.begin(), end = surf_pts.end(); 00198 iter != end; ++iter) 00199 { 00200 (*iter)->marked(-1); 00201 } 00202 for(DLIList<CubitFacet*>::iterator iter = surf_facets.begin(), end = surf_facets.end(); 00203 iter != end; ++iter) 00204 { 00205 CubitPoint* p[3]; 00206 (*iter)->points(p[0], p[1], p[2]); 00207 for(int i=0; i<3; i++) 00208 { 00209 if(p[i]->marked() == -1) 00210 { 00211 p[i]->marked(facet_pts.size()/3); 00212 CubitVector v = p[i]->coordinates(); 00213 facet_pts.push_back(v.x()); 00214 facet_pts.push_back(v.y()); 00215 facet_pts.push_back(v.z()); 00216 } 00217 facet_conn.push_back(p[i]->marked()); 00218 } 00219 } 00220 00221 // project straight line betwee points to surface 00222 std::vector<int> dudded_facets, new_facets, new_facetindex; 00223 std::vector<double> new_pts; 00224 std::vector<int> edges, segmentPts; 00225 00226 FacetProjectTool proj_tool; 00227 CubitStatus stat = proj_tool.project(pts, facet_pts, facet_conn, 00228 dudded_facets, new_facets, new_facetindex, 00229 new_pts, edges, segmentPts); 00230 00231 if(stat != CUBIT_SUCCESS) 00232 { 00233 PRINT_ERROR("Failed to project facet curve to surface.\n"); 00234 return NULL; 00235 } 00236 00237 assert(edges[0] + 2 >= 0); 00238 if((size_t)(edges[0] + 2) != edges.size()) 00239 { 00240 PRINT_ERROR("Facet curve projection produced multiple curves when one was expected.\n"); 00241 return NULL; 00242 } 00243 00244 // lump new points with old points (we don't care about conforming to the surface mesh) 00245 facet_pts.insert(facet_pts.end(), new_pts.begin(), new_pts.end()); 00246 00247 00248 // build the new curve 00249 edges.erase(edges.begin()); 00250 edges.erase(edges.end()-1); 00251 00252 DLIList<CubitPoint*> curve_pts; 00253 DLIList<CubitFacetEdge*> curve_edges; 00254 CubitPoint* prev_point = p1; 00255 for(size_t i=1; i<edges.size()-1; i++) 00256 { 00257 CubitPoint* next_point = new CubitPointData(CubitVector(&facet_pts[3*edges[i]])); 00258 curve_pts.append(next_point); 00259 CubitFacetEdgeData* cfe = new CubitFacetEdgeData(prev_point, next_point); 00260 curve_edges.append(cfe); 00261 prev_point = next_point; 00262 } 00263 00264 CubitFacetEdgeData* cfe = new CubitFacetEdgeData(prev_point, p2); 00265 curve_edges.append(cfe); 00266 curve_pts.append(p2); 00267 00268 Curve* new_curve = NULL; 00269 FacetModifyEngine* self = const_cast<FacetModifyEngine*>(this); 00270 self->make_facet_curve(const_cast<TBPoint*>(point1_ptr), 00271 const_cast<TBPoint*>(point2_ptr), 00272 curve_edges, curve_pts, new_curve, NULL); 00273 00274 return new_curve; 00275 } 00276 00277 //=============================================================================== 00278 // Function : make_Curve 00279 // Member Type: PUBLIC 00280 // Description: make a curve using point_tangents to describe curvature 00281 // Author : John Fowler 00282 // Date : 10/02 00283 //=============================================================================== 00284 Curve* FacetModifyEngine::make_Curve( DLIList<CubitVector*>& point_list, 00285 DLIList<CubitVector*>& point_tangents) const 00286 { 00287 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00288 return (Curve*)NULL; 00289 } 00290 00291 //=============================================================================== 00292 // Function : make_Curve 00293 // Member Type: PUBLIC 00294 // Description: make a curve 00295 // Author : John Fowler 00296 // Date : 10/02 00297 //=============================================================================== 00298 Curve* FacetModifyEngine::make_Curve(GeometryType /*curve_type*/, 00299 TBPoint const* point1_ptr, 00300 TBPoint const* point2_ptr, 00301 DLIList<CubitVector *> &vector_list, 00302 Surface* /*ref_face_ptr*/) const 00303 { 00304 Curve* new_curve = NULL; 00305 00306 DLIList<CubitPoint*> points; 00307 DLIList<CubitFacetEdge*> edges; 00308 00309 CubitPoint* prev_point = static_cast<const FacetPoint*>(point1_ptr)->get_cubit_point(); 00310 points.append(prev_point); 00311 00312 for(int i=0; i<vector_list.size(); i++) 00313 { 00314 CubitPoint* next_point = new CubitPointData(*vector_list[i]); 00315 CubitFacetEdgeData* cfe = new CubitFacetEdgeData(prev_point, next_point); 00316 edges.append(cfe); 00317 prev_point = next_point; 00318 points.append(prev_point); 00319 } 00320 00321 CubitPoint* end_point = static_cast<const FacetPoint*>(point2_ptr)->get_cubit_point(); 00322 00323 CubitFacetEdgeData* cfe = new CubitFacetEdgeData(prev_point, end_point); 00324 edges.append(cfe); 00325 points.append(end_point); 00326 00327 FacetModifyEngine* self = const_cast<FacetModifyEngine*>(this); 00328 self->make_facet_curve(const_cast<TBPoint*>(point1_ptr), 00329 const_cast<TBPoint*>(point2_ptr), 00330 edges, points, new_curve, NULL); 00331 00332 return new_curve; 00333 } 00334 00335 //=============================================================================== 00336 // Function : make_Curve 00337 // Member Type: PUBLIC 00338 // Description: make a curve 00339 // Author : John Fowler 00340 // Date : 10/02 00341 //=============================================================================== 00342 Curve* FacetModifyEngine::make_Curve( GeometryType /*curve_type*/, 00343 TBPoint const* /*point1_ptr*/, 00344 TBPoint const* /*point2_ptr*/, 00345 CubitVector const* /*intermediate_point_ptr*/ ) const 00346 { 00347 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00348 return (Curve*) NULL; 00349 } 00350 00351 //=============================================================================== 00352 // Function : make_Surface 00353 // Member Type: PUBLIC 00354 // Description: make a surface 00355 // Author : John Fowler 00356 // Date : 10/02 00357 //=============================================================================== 00358 Surface* FacetModifyEngine::make_Surface( Surface * /*old_surface_ptr*/, 00359 std::map< TopologyBridge*, TopologyBridge* > * /*old_tb_to_new_tb*/) const 00360 { 00361 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00362 return (Surface*) NULL; 00363 } 00364 00365 //=============================================================================== 00366 // Function : make_extended_sheet 00367 // Member Type: PUBLIC 00368 // Description: make an extended sheet from a set of surfaces 00369 // Author : 00370 // Date : 00371 //=============================================================================== 00372 BodySM* FacetModifyEngine::make_extended_sheet( DLIList<Surface*> & /*surface_list*/, 00373 CubitBox * /*clip_box_ptr*/, 00374 bool /*preview*/ ) const 00375 { 00376 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00377 return (BodySM*) NULL; 00378 } 00379 00380 //=============================================================================== 00381 // Function : make_Surface 00382 // Member Type: PUBLIC 00383 // Description: make a surface 00384 // Author : John Fowler 00385 // Date : 10/02 00386 //=============================================================================== 00387 Surface* FacetModifyEngine::make_Surface( GeometryType /*surface_type*/, 00388 DLIList<Curve*>& /*curve_list*/, 00389 Surface * /*old_surface_ptr*/, 00390 bool /*check_edges*/) const 00391 { 00392 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00393 return (Surface*) NULL; 00394 } 00395 00396 //=============================================================================== 00397 // Function : make_Lump 00398 // Member Type: PUBLIC 00399 // Description: make a lump 00400 // Author : John Fowler 00401 // Date : 10/02 00402 //=============================================================================== 00403 Lump* FacetModifyEngine::make_Lump( DLIList<Surface*>& /*surface_list*/ ) const 00404 { 00405 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 00406 return (Lump*) NULL; 00407 } 00408 00409 //=============================================================================== 00410 // Function : make_BodySM 00411 // Member Type: PUBLIC 00412 // Description: make a BodySM 00413 // Author : John Fowler 00414 // Date : 10/02 00415 //=============================================================================== 00416 BodySM* FacetModifyEngine::make_BodySM( Surface * ) const 00417 {return NULL ;} 00418 00419 //=============================================================================== 00420 // Function : make_BodySM 00421 // Member Type: PUBLIC 00422 // Description: make a BodySM 00423 // Author : John Fowler 00424 // Date : 10/02 00425 //=============================================================================== 00426 BodySM* FacetModifyEngine::make_BodySM( DLIList<Lump*>& /*lump_list*/ ) const 00427 {return NULL ;} 00428 00429 //=============================================================================== 00430 // Function : fillinedge 00431 // Member Type: PRIVATE 00432 // Description: put points on this edge of triangle to be refined 00433 // Author : John Fowler 00434 // Date : 11/02 00435 //=============================================================================== 00436 void FacetModifyEngine::fillinedge( 00437 int *edge, 00438 int numpointsonanedge, 00439 double radius, 00440 std::vector<CubitPoint *>& points) const 00441 { 00442 MODIFY_CHECK_RETURN_VOID; 00443 00444 int numintervals, i; 00445 double xbegin, ybegin, zbegin, xend, yend, zend, xincr, yincr, zincr; 00446 double dist; 00447 CubitPoint *new_point; 00448 00449 numintervals = numpointsonanedge - 1; 00450 if ( numintervals < 1 ) return; 00451 xbegin = points[edge[0]]->x(); 00452 ybegin = points[edge[0]]->y(); 00453 zbegin = points[edge[0]]->z(); 00454 xend = points[edge[numintervals]]->x(); 00455 yend = points[edge[numintervals]]->y(); 00456 zend = points[edge[numintervals]]->z(); 00457 xincr = (xend-xbegin)/(double)(numintervals); 00458 yincr = (yend-ybegin)/(double)(numintervals); 00459 zincr = (zend-zbegin)/(double)(numintervals); 00460 for ( i = 0; i < numintervals - 1; i++ ) { 00461 xbegin += xincr; 00462 ybegin += yincr; 00463 zbegin += zincr; 00464 00465 dist = sqrt(xbegin*xbegin + ybegin*ybegin + zbegin*zbegin); 00466 new_point = (CubitPoint *) new CubitPointData( xbegin*radius/dist, ybegin*radius/dist, 00467 zbegin*radius/dist ); 00468 edge[i+1] = points.size(); // get the point number 00469 points.push_back(new_point); 00470 } 00471 00472 } 00473 00474 //=============================================================================== 00475 // Function : refinetriangle 00476 // Member Type: PRIVATE 00477 // Description: add internal points and make connections for this triangle 00478 // Author : John Fowler 00479 // Date : 11/02 00480 //=============================================================================== 00481 void FacetModifyEngine::refinetriangle( 00482 int level, 00483 int numpointsonanedge, 00484 int *iedge1, 00485 int *iedge2, 00486 int *iedge3, 00487 int isign1, 00488 int isign2, 00489 int isign3, 00490 double radius, 00491 std::vector<CubitPoint *>& points, 00492 DLIList<CubitFacet *>& facet_list) const 00493 { 00494 00495 MODIFY_CHECK_RETURN_VOID; 00496 00497 int i, numintervals, icount, j, jcount; 00498 int ntris; 00499 int iedge1cnt, iedge2cnt, iedge3cnt; 00500 00501 int increment, trissofar, i1s, i2s, i1e; 00502 int nverts1, nverts; 00503 double dlev; 00504 int *vertnumarray, index, iskip; 00505 CubitFacet *facet_ptr; 00506 CubitPoint *new_point; 00507 double x1inc, y1inc, z1inc, x2inc, y2inc, z2inc; 00508 double xstart, ystart, zstart, xend, yend, zend, dist; 00509 double xinternalinc, yinternalinc, zinternalinc; 00510 00511 numintervals = numpointsonanedge - 1; 00512 iedge1cnt = ( isign1 == 1 ) ? 0 : numintervals; 00513 iedge2cnt = ( isign2 == 1 ) ? 0 : numintervals; 00514 iedge3cnt = ( isign3 == 1 ) ? 0 : numintervals; 00515 00516 index = points.size(); 00517 dlev = 1. + (double)level; 00518 nverts1 = (int)(0.5*(dlev+1.)*dlev); 00519 00520 ntris = (level+1)*(level+1); 00521 dlev += 1.; 00522 nverts = (int)(0.5*(dlev+1.)*dlev); 00523 vertnumarray = new int[nverts]; 00524 00525 // Put the point numbers for the interior points into vertnumarray. 00526 if ( numintervals > 2 ) { // numintervals must be at least 3 to make interior points 00527 jcount = 1; 00528 icount = 2; 00529 for ( i = 2; i < numintervals; i++ ) { 00530 icount += 2; 00531 for ( j = 0; j < jcount; j++ ) { 00532 vertnumarray[icount] = index++; 00533 icount += 1; 00534 } 00535 jcount += 1; 00536 } 00537 } 00538 i = 3; 00539 00540 iskip = 2; 00541 vertnumarray[0] = iedge1[iedge1cnt]; iedge1cnt += isign1; 00542 vertnumarray[1] = iedge1[iedge1cnt]; iedge1cnt += isign1; 00543 iedge2cnt += isign2; 00544 vertnumarray[2] = iedge2[iedge2cnt]; iedge2cnt += isign2; 00545 00546 while ( i < nverts1 ) { 00547 vertnumarray[i] = iedge1[iedge1cnt]; iedge1cnt += isign1; 00548 vertnumarray[i+iskip] = iedge2[iedge2cnt]; iedge2cnt += isign2; 00549 i += iskip+1; 00550 iskip += 1; 00551 } 00552 for ( i = nverts1; i < nverts; i++ ) { 00553 vertnumarray[i] = iedge3[iedge3cnt]; iedge3cnt += isign3; 00554 } 00555 00556 00558 00559 if ( numintervals > 2 ) { 00560 int i1first, i1last, i2first, i2last; 00561 if ( isign1 == 1 ) { 00562 i1first = 0; i1last = numintervals; 00563 } else { 00564 i1last = 0; i1first = numintervals; 00565 } 00566 if ( isign2 == 1 ) { 00567 i2first = 0; i2last = numintervals; 00568 } else { 00569 i2last = 0; i2first = numintervals; 00570 } 00571 x1inc = (points[iedge1[i1last]]->x() - points[iedge1[i1first]]->x())/numintervals; 00572 y1inc = (points[iedge1[i1last]]->y() - points[iedge1[i1first]]->y())/numintervals; 00573 z1inc = (points[iedge1[i1last]]->z() - points[iedge1[i1first]]->z())/numintervals; 00574 x2inc = (points[iedge2[i2last]]->x() - points[iedge2[i2first]]->x())/numintervals; 00575 y2inc = (points[iedge2[i2last]]->y() - points[iedge2[i2first]]->y())/numintervals; 00576 z2inc = (points[iedge2[i2last]]->z() - points[iedge2[i2first]]->z())/numintervals; 00577 00578 icount = 2; 00579 jcount = 1; 00580 for ( i = 2; i < numintervals; i++ ) { 00581 xstart = points[iedge1[i1first]]->x() + (double)i*x1inc; 00582 ystart = points[iedge1[i1first]]->y() + (double)i*y1inc; 00583 zstart = points[iedge1[i1first]]->z() + (double)i*z1inc; 00584 xend = points[iedge2[i2first]]->x() + (double)i*x2inc; 00585 yend = points[iedge2[i2first]]->y() + (double)i*y2inc; 00586 zend = points[iedge2[i2first]]->z() + (double)i*z2inc; 00587 xinternalinc = (xend-xstart)/(icount); 00588 yinternalinc = (yend-ystart)/(icount); 00589 zinternalinc = (zend-zstart)/(icount); 00590 for ( j = 0; j < jcount; j++ ) { 00591 xstart += xinternalinc; 00592 ystart += yinternalinc; 00593 zstart += zinternalinc; 00594 00595 dist = sqrt(xstart*xstart + ystart*ystart + zstart*zstart); 00596 new_point = (CubitPoint *) new CubitPointData( xstart*radius/dist, 00597 ystart*radius/dist, 00598 zstart*radius/dist ); 00599 points.push_back(new_point); 00600 } 00601 icount += 1; 00602 jcount += 1; 00603 } 00604 00605 } 00606 00608 increment = trissofar = 0; 00609 i1s = 0; 00610 i2s = 1; 00611 while ( trissofar < ntris ) { 00612 i1e = i1s + increment; 00613 while ( i1s < i1e) { 00614 facet_ptr = new CubitFacetData( points[vertnumarray[i1s]], 00615 points[vertnumarray[i2s]], 00616 points[vertnumarray[i2s+1]] ); 00617 facet_list.append( facet_ptr ); 00618 facet_ptr = new CubitFacetData( points[vertnumarray[i1s]], 00619 points[vertnumarray[i2s+1]], 00620 points[vertnumarray[i1s+1]] ); 00621 facet_list.append( facet_ptr ); 00622 i1s++; 00623 i2s++; 00624 trissofar += 2; 00625 } 00626 facet_ptr = new CubitFacetData( points[vertnumarray[i1s]], 00627 points[vertnumarray[i2s]], 00628 points[vertnumarray[i2s+1]] ); 00629 facet_list.append( facet_ptr ); 00630 increment++; 00631 trissofar++; 00632 i1s++; 00633 i2s += 2; 00634 } 00635 delete [] vertnumarray; 00636 } 00637 00638 //=============================================================================== 00639 // Function : sphere 00640 // Member Type: PUBLIC 00641 // Description: build a sphere with facets 00642 // Author : John Fowler 00643 // Date : 10/02 00644 //=============================================================================== 00645 BodySM* FacetModifyEngine::sphere(double radius) const 00646 { 00647 MODIFY_CHECK_RETURN_NULL; 00648 00649 CubitStatus rv = CUBIT_SUCCESS; 00650 DLIList <CubitFacet *>facet_list; 00651 DLIList <CubitPoint *>point_list; 00652 CubitPoint *new_point; 00653 double feature_angle; 00654 int i, interp_order; 00655 CubitBoolean smooth_non_manifold, split_surfaces; 00656 BodySM *body_ptr = NULL; 00657 std::vector<CubitPoint *> points; 00663 const double xp = 0.525731112119133606*radius, zp = 0.850650808352039932*radius; 00666 int level, numpointsonanedge; 00667 int *edge[30]; 00670 /* 00671 const int basefacets[20][3] = { {0,1,2},{0,2,3},{3,2,4},{2,5,4}, 00672 {2,1,5},{5,1,6},{5,6,7},{4,5,7}, 00673 {4,7,8},{8,7,9},{9,7,6},{9,6,10}, 00674 {9,10,11},{11,10,0},{0,10,1},{10,6,1}, 00675 {3,11,0},{3,8,11},{3,4,8},{9,11,8} }; 00676 */ 00677 const int edgeendverts[30][2] = { {0,1},{0,2},{0,3},{0,11},{0,10},{1,2}, 00678 {1,5},{1,6},{1,10},{2,3},{2,4},{2,5}, 00679 {3,4},{3,8},{3,11},{4,5},{4,7},{4,8}, 00680 {5,6},{5,7},{6,7},{6,9},{6,10},{7,8}, 00681 {7,9},{8,9},{8,11},{9,10},{9,11},{10,11} }; 00686 const int triedges[20][3] = { {1,2,6},{2,3,10},{-10,13,11},{12,11,-16,}, 00687 {-6,12,7,},{-7,19,8,},{19,20,21},{16,17,20}, 00688 {17,18,24,},{-24,26,25},{-25,-22,-21},{-22,28,23}, 00689 {28,29,30},{-30,-4,-5},{5,1,-9},{-23,-9,-8}, 00690 {15,-3,-4},{14,15,27},{13,14,18},{29,-26,-27} }; 00692 const double svert[12][3] = { {-xp,0.,zp}, {xp,0.,zp}, {0.,zp,xp}, {-zp, xp, 0.}, 00693 {0.,zp,-xp}, {zp,xp,0.}, {zp,-xp,0.}, {xp,0.,-zp}, 00694 {-xp,0.,-zp}, {0.,-zp,-xp}, {0.,-zp,xp}, {-zp,-xp,0.} }; 00695 00696 level = 7; // gives a sphere with 642 vertices and 1280 triangles. 00697 // Eventually this should be user-selectable. 00698 numpointsonanedge = 2 + level; 00699 00700 for ( i = 0; i < 30; i++ ) { // make the edges 00701 edge[i] = new int[numpointsonanedge]; 00702 edge[i][0] = edgeendverts[i][0]; 00703 edge[i][numpointsonanedge-1] = edgeendverts[i][1]; 00704 } 00705 00706 for ( i = 0; i < 12; i++ ) { // make the icosahedron vertices 00707 new_point = (CubitPoint *) new CubitPointData( svert[i][0],svert[i][1],svert[i][2] ); 00708 points.push_back(new_point); 00709 } 00710 00711 for ( i = 0; i < 30; i++ ) { // put points on the edges 00712 fillinedge(edge[i], numpointsonanedge, radius, points); 00713 } 00714 00715 int sign1, sign2, sign3, edg1, edg2, edg3; 00716 for ( i = 0; i < 20; i++ ) { // refine the 20 triangles 00717 edg1 = ( triedges[i][0] > 0 ) ? triedges[i][0] - 1 : -triedges[i][0] - 1; 00718 edg2 = ( triedges[i][1] > 0 ) ? triedges[i][1] - 1 : -triedges[i][1] - 1; 00719 edg3 = ( triedges[i][2] > 0 ) ? triedges[i][2] - 1 : -triedges[i][2] - 1; 00721 sign1 = ( triedges[i][0] > 0 ) ? 1 : -1; 00722 sign2 = ( triedges[i][1] > 0 ) ? 1 : -1; 00723 sign3 = ( triedges[i][2] > 0 ) ? 1 : -1; 00724 00725 refinetriangle(level,numpointsonanedge,edge[edg1],edge[edg2],edge[edg3], 00726 sign1,sign2,sign3,radius,points,facet_list); 00727 } 00728 00730 for ( unsigned int z = 0; z < points.size(); z++ ) { 00731 point_list.append(points[z]); 00732 } 00733 00734 points.clear(); 00735 00736 for ( i = 0; i < 30; i++ ) delete[] edge[i]; 00737 feature_angle = -1.0; 00738 interp_order = 0; 00739 smooth_non_manifold = CUBIT_TRUE; 00740 split_surfaces = CUBIT_FALSE; 00741 00742 ChollaEngine *cholla_ptr = NULL; 00743 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 00744 rv = fme->build_cholla_surfaces( facet_list, 00745 point_list, 00746 feature_angle, 00747 interp_order, 00748 smooth_non_manifold, 00749 split_surfaces, 00750 cholla_ptr ); 00751 if ( rv == CUBIT_SUCCESS ) 00752 { 00753 CubitEvaluatorData **sphere_data; 00754 00755 set_sphere_eval_data( cholla_ptr, radius, sphere_data ); 00756 00757 finish_facet_Body( cholla_ptr, 00758 (const CubitEvaluatorData **)sphere_data, 00759 feature_angle, 00760 interp_order, 00761 body_ptr); 00762 00763 if ( cholla_ptr ) 00764 { 00765 cholla_ptr->delete_me(); 00766 delete cholla_ptr; 00767 } 00768 if ( sphere_data[0] ) delete sphere_data[0]; 00769 delete sphere_data; 00770 } 00771 return body_ptr; 00772 } 00773 00774 CubitStatus FacetModifyEngine::remove_topology(DLIList<Curve*> &curves_to_remove, 00775 DLIList<Surface*> &surfs_to_remove, 00776 double backoff_distance, 00777 double small_edge_size, 00778 DLIList<BodySM*> &new_bodysm_list, 00779 CubitBoolean preview) const 00780 { 00781 PRINT_INFO("This functionality is not implemented for faceted geometry.\n"); 00782 return CUBIT_FAILURE; 00783 } 00784 00785 void FacetModifyEngine::set_sphere_eval_data 00786 ( 00787 ChollaEngine *cholla_ptr, 00788 double radius, 00789 CubitEvaluatorData **&eval_data ) const 00790 { 00791 00792 //MODIFY_CHECK_RETURN_VOID; 00793 00794 eval_data = new CubitEvaluatorData*; 00795 00796 SphereEvaluatorData *data = new SphereEvaluatorData; 00797 data->radius = radius; 00798 data->center.set( 0.0, 0.0, 0.0 ); 00799 eval_data[0] = data; 00800 } 00801 00802 //=============================================================================== 00803 // Function : brick 00804 // Member Type: PUBLIC 00805 // Description: build a brick with facets 00806 // Author : John Fowler 00807 // Date : 10/02 00808 //=============================================================================== 00809 BodySM* FacetModifyEngine::brick( double wid, double dep, double hi ) const 00810 { 00811 00812 00813 MODIFY_CHECK_RETURN_NULL; 00814 CubitStatus rv = CUBIT_SUCCESS; 00815 double xmin, xmax, ymin, ymax, zmin, zmax; 00816 DLIList <CubitFacet *>facet_list; 00817 DLIList <CubitPoint *>point_list; 00818 CubitPoint *new_point; 00819 CubitFacet *facet_ptr; 00820 int i, numpoints; 00821 double feature_angle; 00822 int interp_order; 00823 CubitBoolean smooth_non_manifold, split_surfaces; 00824 BodySM *body_ptr = NULL; 00825 std::vector<CubitPoint *> points; 00826 00827 numpoints = 14; 00828 00829 xmin = -0.5*wid; 00830 xmax = 0.5*wid; 00831 ymin = -0.5*dep; 00832 ymax = 0.5*dep; 00833 zmin = -0.5*hi; 00834 zmax = 0.5*hi; 00835 00836 new_point = (CubitPoint *) new CubitPointData( xmin,ymin,zmin ); 00837 points.push_back(new_point); 00838 new_point = (CubitPoint *) new CubitPointData( xmax,ymin,zmin ); 00839 points.push_back(new_point); 00840 new_point = (CubitPoint *) new CubitPointData( xmax,ymin,zmax ); 00841 points.push_back(new_point); 00842 new_point = (CubitPoint *) new CubitPointData( xmin,ymin,zmax ); 00843 points.push_back(new_point); 00844 new_point = (CubitPoint *) new CubitPointData( xmin,ymax,zmin ); 00845 points.push_back(new_point); 00846 new_point = (CubitPoint *) new CubitPointData( xmax,ymax,zmin ); 00847 points.push_back(new_point); 00848 new_point = (CubitPoint *) new CubitPointData( xmax,ymax,zmax ); 00849 points.push_back(new_point); 00850 new_point = (CubitPoint *) new CubitPointData( xmin,ymax,zmax ); 00851 points.push_back(new_point); 00852 new_point = (CubitPoint *) new CubitPointData( 0.5*(xmin+xmax),0.5*(ymin+ymax),zmin ); 00853 points.push_back(new_point); 00854 new_point = (CubitPoint *) new CubitPointData( xmax,0.5*(ymin+ymax),0.5*(zmin+zmax) ); 00855 points.push_back(new_point); 00856 new_point = (CubitPoint *) new CubitPointData( 0.5*(xmin+xmax),0.5*(ymin+ymax),zmax ); 00857 points.push_back(new_point); 00858 new_point = (CubitPoint *) new CubitPointData( xmin,0.5*(ymin+ymax),0.5*(zmin+zmax) ); 00859 points.push_back(new_point); 00860 new_point = (CubitPoint *) new CubitPointData( 0.5*(xmin+xmax),ymin,0.5*(zmin+zmax) ); 00861 points.push_back(new_point); 00862 new_point = (CubitPoint *) new CubitPointData( 0.5*(xmin+xmax),ymax,0.5*(zmin+zmax) ); 00863 points.push_back(new_point); 00864 00865 for ( i = 0; i < numpoints; i++ ) { 00866 point_list.append(points[i]); 00867 } 00868 00869 // bottom face 00870 facet_ptr = new CubitFacetData( points[0],points[1], points[12] ); 00871 facet_list.append( facet_ptr ); 00872 facet_ptr = new CubitFacetData( points[1],points[2], points[12] ); 00873 facet_list.append( facet_ptr ); 00874 facet_ptr = new CubitFacetData( points[2],points[3], points[12] ); 00875 facet_list.append( facet_ptr ); 00876 facet_ptr = new CubitFacetData( points[3],points[0], points[12] ); 00877 // back face 00878 facet_list.append( facet_ptr ); 00879 facet_ptr = new CubitFacetData( points[1],points[0], points[8] ); 00880 facet_list.append( facet_ptr ); 00881 facet_ptr = new CubitFacetData( points[5],points[1], points[8] ); 00882 facet_list.append( facet_ptr ); 00883 facet_ptr = new CubitFacetData( points[4],points[5], points[8] ); 00884 facet_list.append( facet_ptr ); 00885 facet_ptr = new CubitFacetData( points[0],points[4], points[8] ); 00886 facet_list.append( facet_ptr ); 00887 // left face 00888 facet_ptr = new CubitFacetData( points[0],points[3], points[11] ); 00889 facet_list.append( facet_ptr ); 00890 facet_ptr = new CubitFacetData( points[3],points[7], points[11] ); 00891 facet_list.append( facet_ptr ); 00892 facet_ptr = new CubitFacetData( points[7],points[4], points[11] ); 00893 facet_list.append( facet_ptr ); 00894 facet_ptr = new CubitFacetData( points[4],points[0], points[11] ); 00895 facet_list.append( facet_ptr ); 00896 // top face 00897 facet_ptr = new CubitFacetData( points[7],points[6], points[13] ); 00898 facet_list.append( facet_ptr ); 00899 facet_ptr = new CubitFacetData( points[6],points[5], points[13] ); 00900 facet_list.append( facet_ptr ); 00901 facet_ptr = new CubitFacetData( points[5],points[4], points[13] ); 00902 facet_list.append( facet_ptr ); 00903 facet_ptr = new CubitFacetData( points[4],points[7], points[13] ); 00904 facet_list.append( facet_ptr ); 00905 // right face 00906 facet_ptr = new CubitFacetData( points[1],points[5], points[9] ); 00907 facet_list.append( facet_ptr ); 00908 facet_ptr = new CubitFacetData( points[5],points[6], points[9] ); 00909 facet_list.append( facet_ptr ); 00910 facet_ptr = new CubitFacetData( points[6],points[2], points[9] ); 00911 facet_list.append( facet_ptr ); 00912 facet_ptr = new CubitFacetData( points[2],points[1], points[9] ); 00913 facet_list.append( facet_ptr ); 00914 // front face 00915 facet_ptr = new CubitFacetData( points[3],points[2], points[10] ); 00916 facet_list.append( facet_ptr ); 00917 facet_ptr = new CubitFacetData( points[2],points[6], points[10] ); 00918 facet_list.append( facet_ptr ); 00919 facet_ptr = new CubitFacetData( points[6],points[7], points[10] ); 00920 facet_list.append( facet_ptr ); 00921 facet_ptr = new CubitFacetData( points[7],points[3], points[10] ); 00922 facet_list.append( facet_ptr ); 00923 00924 points.clear(); // clear out the points vector since we are through with it. 00925 00926 feature_angle = 100.0; 00927 interp_order = 0; 00928 smooth_non_manifold = CUBIT_TRUE; 00929 split_surfaces = CUBIT_FALSE; 00930 00931 ChollaEngine *cholla_ptr = NULL; 00932 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 00933 rv = fme->build_cholla_surfaces( facet_list, 00934 point_list, 00935 feature_angle, 00936 interp_order, 00937 smooth_non_manifold, 00938 split_surfaces, 00939 cholla_ptr ); 00940 if ( rv == CUBIT_SUCCESS ) 00941 { 00942 finish_facet_Body( cholla_ptr, 00943 NULL, 00944 feature_angle, 00945 interp_order, 00946 body_ptr); 00947 if ( cholla_ptr ) 00948 { 00949 cholla_ptr->delete_me(); 00950 delete cholla_ptr; 00951 } 00952 00953 } 00954 return body_ptr; 00955 } 00956 00957 //=============================================================================== 00958 // Function : finish_facet_Body 00959 // Member Type: PRIVATE 00960 // Description: general function for creating a facet-based Body given a closed 00961 // set of facets 00962 // Author : John Fowler 00963 // Date : 10/02 00964 //=============================================================================== 00965 CubitStatus FacetModifyEngine::finish_facet_Body( ChollaEngine *cholla_ptr, 00966 const CubitEvaluatorData **eval_data, 00967 double feature_angle, 00968 int interp_order, 00969 BodySM *&bodysm_ptr) const 00970 { 00971 00972 MODIFY_CHECK_RETURN_FAILURE; 00973 00974 DLIList<Surface *> surface_list; 00975 ShellSM *shell_ptr; 00976 DLIList<ShellSM*> shell_list; 00977 Lump *lump_ptr; 00978 DLIList<Lump*> lump_list; 00979 CubitStatus rv; 00980 DLIList<ChollaSurface *> cholla_surface_list; 00981 DLIList<ChollaCurve *> cholla_curve_list; 00982 DLIList<ChollaPoint *> cholla_point_list; 00983 00984 cholla_ptr->get_curves( cholla_curve_list ); 00985 cholla_ptr->get_surfaces( cholla_surface_list ); 00986 cholla_ptr->get_points( cholla_point_list ); 00987 00988 CubitBoolean use_feature_angle; 00989 if (feature_angle < 0.0) 00990 use_feature_angle = CUBIT_FALSE; 00991 else 00992 use_feature_angle = CUBIT_TRUE; 00993 00994 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00995 00996 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 00997 00998 rv = fme->build_cholla_geometry( eval_data, 00999 cholla_surface_list, 01000 cholla_curve_list, 01001 cholla_point_list, 01002 use_feature_angle, 01003 feature_angle, 01004 interp_order, surface_list ); 01005 01006 if ( surface_list.size() == 0 || rv != CUBIT_SUCCESS ) 01007 { 01008 PRINT_ERROR("Problems building facet based surfaces.\n"); 01009 rv = CUBIT_FAILURE; 01010 goto end_brick; 01011 } 01012 01013 // make a body out of it 01014 rv = fme->make_facet_shell(surface_list,shell_ptr); 01015 if ( shell_ptr == NULL || rv != CUBIT_SUCCESS ) 01016 { 01017 PRINT_ERROR("Problems building facet based shell entity.\n"); 01018 rv = CUBIT_FAILURE; 01019 goto end_brick; 01020 } 01021 //Set the sense for the surfaces (will be cofaces) on this shell. 01022 //Assumption: The sense is always forward when creating geom from facets. 01023 // (This may not be correct -especially with multiple shells in a body) 01024 int ii; 01025 FacetShell* facet_shell; 01026 facet_shell = CAST_TO( shell_ptr, FacetShell ); 01027 for( ii = surface_list.size(); ii > 0; ii-- ) 01028 { 01029 Surface* surf = surface_list.get_and_step(); 01030 FacetSurface* facet_surf = CAST_TO( surf, FacetSurface ); 01031 facet_surf->set_shell_sense( facet_shell, CUBIT_FORWARD ); 01032 } 01033 01034 shell_list.append(shell_ptr); 01035 rv = fme->make_facet_lump(shell_list,lump_ptr); 01036 if ( lump_ptr == NULL || rv != CUBIT_SUCCESS ) 01037 { 01038 PRINT_ERROR("Problems building facet based lump entity.\n"); 01039 rv = CUBIT_FAILURE; 01040 goto end_brick; 01041 } 01042 lump_list.append(lump_ptr); 01043 rv = fme->make_facet_body(lump_list,bodysm_ptr); 01044 01045 if ( rv != CUBIT_SUCCESS ) 01046 { 01047 PRINT_ERROR("Problems building facet based body entity.\n"); 01048 rv = CUBIT_FAILURE; 01049 goto end_brick; 01050 } 01051 01052 PRINT_INFO("Body successfully created.\n"); 01053 PRINT_INFO(" Number of vertices = %d\n", gti->num_ref_vertices()); 01054 PRINT_INFO(" Number of edges = %d\n", gti->num_ref_edges()); 01055 PRINT_INFO(" Number of faces = %d\n", gti->num_ref_faces()); 01056 PRINT_INFO(" Number of volumes = %d\n", gti->num_ref_volumes()); 01057 PRINT_INFO(" Number of bodies = %d\n", gti->num_bodies()); 01058 01059 return rv; 01060 01061 end_brick: 01062 bodysm_ptr = (BodySM *)NULL; 01063 return rv; 01064 01065 } 01066 01067 CubitStatus FacetModifyEngine::finish_facet_Body( DLIList<Surface*>& surface_list, DLIList<CubitSense>& surface_sense, 01068 BodySM *&bodysm_ptr) const 01069 { 01070 ShellSM *shell_ptr; 01071 DLIList<ShellSM*> shell_list; 01072 Lump *lump_ptr; 01073 DLIList<Lump*> lump_list; 01074 CubitStatus rv; 01075 01076 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 01077 01078 if ( surface_list.size() == 0 ) 01079 { 01080 PRINT_ERROR("Problems building facet based surfaces.\n"); 01081 rv = CUBIT_FAILURE; 01082 goto end_brick; 01083 } 01084 01085 // make a body out of it 01086 rv = fme->make_facet_shell(surface_list,shell_ptr); 01087 if ( shell_ptr == NULL || rv != CUBIT_SUCCESS ) 01088 { 01089 PRINT_ERROR("Problems building facet based shell entity.\n"); 01090 rv = CUBIT_FAILURE; 01091 goto end_brick; 01092 } 01093 01094 int ii; 01095 FacetShell* facet_shell; 01096 facet_shell = CAST_TO( shell_ptr, FacetShell ); 01097 for( ii = 0; ii< surface_list.size(); ii++) 01098 { 01099 Surface* surf = surface_list[ii]; 01100 FacetSurface* facet_surf = CAST_TO( surf, FacetSurface ); 01101 facet_surf->set_shell_sense( facet_shell, surface_sense[ii] ); 01102 } 01103 01104 shell_list.append(shell_ptr); 01105 rv = fme->make_facet_lump(shell_list,lump_ptr); 01106 if ( lump_ptr == NULL || rv != CUBIT_SUCCESS ) 01107 { 01108 PRINT_ERROR("Problems building facet based lump entity.\n"); 01109 rv = CUBIT_FAILURE; 01110 goto end_brick; 01111 } 01112 lump_list.append(lump_ptr); 01113 rv = fme->make_facet_body(lump_list,bodysm_ptr); 01114 01115 if ( rv != CUBIT_SUCCESS ) 01116 { 01117 PRINT_ERROR("Problems building facet based body entity.\n"); 01118 rv = CUBIT_FAILURE; 01119 goto end_brick; 01120 } 01121 01122 return rv; 01123 01124 end_brick: 01125 bodysm_ptr = (BodySM *)NULL; 01126 return rv; 01127 01128 } 01129 01130 //=============================================================================== 01131 // Function : brick 01132 // Member Type: PUBLIC 01133 // Description: create a brick with facets given center axes and extension 01134 // Author : Steve Owen 01135 // Date : 1/09 01136 //=============================================================================== 01137 BodySM* FacetModifyEngine::brick( const CubitVector ¢er, 01138 const CubitVector axes[3], 01139 const CubitVector &extension) const 01140 { 01141 01142 01143 MODIFY_CHECK_RETURN_NULL; 01144 CubitStatus rv = CUBIT_SUCCESS; 01145 CubitVector uvec, vvec, wvec, corner, mid; 01146 DLIList <CubitFacet *>facet_list; 01147 DLIList <CubitPoint *>point_list; 01148 CubitPoint *new_point; 01149 CubitFacet *facet_ptr; 01150 int i, numpoints; 01151 double feature_angle; 01152 int interp_order; 01153 CubitBoolean smooth_non_manifold, split_surfaces; 01154 BodySM *body_ptr = NULL; 01155 std::vector<CubitPoint *> points; 01156 01157 numpoints = 14; 01158 01159 uvec = extension.x() * axes[0]; 01160 vvec = extension.y() * axes[1]; 01161 wvec = extension.z() * axes[2]; 01162 01163 corner = center - uvec - vvec - wvec; 01164 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01165 points.push_back(new_point); 01166 01167 corner = center + uvec - vvec - wvec; 01168 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01169 points.push_back(new_point); 01170 01171 corner = center + uvec - vvec + wvec; 01172 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01173 points.push_back(new_point); 01174 01175 corner = center - uvec - vvec + wvec; 01176 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01177 points.push_back(new_point); 01178 01179 corner = center - uvec + vvec - wvec; 01180 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01181 points.push_back(new_point); 01182 01183 corner = center + uvec + vvec - wvec; 01184 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01185 points.push_back(new_point); 01186 01187 corner = center + uvec + vvec + wvec; 01188 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01189 points.push_back(new_point); 01190 01191 corner = center - uvec + vvec + wvec; 01192 new_point = (CubitPoint *) new CubitPointData( corner.x(),corner.y(),corner.z() ); 01193 points.push_back(new_point); 01194 01195 mid = center - wvec; 01196 new_point = (CubitPoint *) new CubitPointData( mid.x(), mid.y(), mid.z() ); 01197 points.push_back(new_point); 01198 01199 mid = center + uvec; 01200 new_point = (CubitPoint *) new CubitPointData( mid.x(), mid.y(), mid.z() ); 01201 points.push_back(new_point); 01202 01203 mid = center + wvec; 01204 new_point = (CubitPoint *) new CubitPointData( mid.x(), mid.y(), mid.z() ); 01205 points.push_back(new_point); 01206 01207 mid = center - uvec; 01208 new_point = (CubitPoint *) new CubitPointData( mid.x(), mid.y(), mid.z() ); 01209 points.push_back(new_point); 01210 01211 mid = center - vvec; 01212 new_point = (CubitPoint *) new CubitPointData( mid.x(), mid.y(), mid.z() ); 01213 points.push_back(new_point); 01214 01215 mid = center + vvec; 01216 new_point = (CubitPoint *) new CubitPointData( mid.x(), mid.y(), mid.z() ); 01217 points.push_back(new_point); 01218 01219 for ( i = 0; i < numpoints; i++ ) { 01220 point_list.append(points[i]); 01221 } 01222 01223 // bottom face 01224 facet_ptr = new CubitFacetData( points[0],points[1], points[12] ); 01225 facet_list.append( facet_ptr ); 01226 facet_ptr = new CubitFacetData( points[1],points[2], points[12] ); 01227 facet_list.append( facet_ptr ); 01228 facet_ptr = new CubitFacetData( points[2],points[3], points[12] ); 01229 facet_list.append( facet_ptr ); 01230 facet_ptr = new CubitFacetData( points[3],points[0], points[12] ); 01231 // back face 01232 facet_list.append( facet_ptr ); 01233 facet_ptr = new CubitFacetData( points[1],points[0], points[8] ); 01234 facet_list.append( facet_ptr ); 01235 facet_ptr = new CubitFacetData( points[5],points[1], points[8] ); 01236 facet_list.append( facet_ptr ); 01237 facet_ptr = new CubitFacetData( points[4],points[5], points[8] ); 01238 facet_list.append( facet_ptr ); 01239 facet_ptr = new CubitFacetData( points[0],points[4], points[8] ); 01240 facet_list.append( facet_ptr ); 01241 // left face 01242 facet_ptr = new CubitFacetData( points[0],points[3], points[11] ); 01243 facet_list.append( facet_ptr ); 01244 facet_ptr = new CubitFacetData( points[3],points[7], points[11] ); 01245 facet_list.append( facet_ptr ); 01246 facet_ptr = new CubitFacetData( points[7],points[4], points[11] ); 01247 facet_list.append( facet_ptr ); 01248 facet_ptr = new CubitFacetData( points[4],points[0], points[11] ); 01249 facet_list.append( facet_ptr ); 01250 // top face 01251 facet_ptr = new CubitFacetData( points[7],points[6], points[13] ); 01252 facet_list.append( facet_ptr ); 01253 facet_ptr = new CubitFacetData( points[6],points[5], points[13] ); 01254 facet_list.append( facet_ptr ); 01255 facet_ptr = new CubitFacetData( points[5],points[4], points[13] ); 01256 facet_list.append( facet_ptr ); 01257 facet_ptr = new CubitFacetData( points[4],points[7], points[13] ); 01258 facet_list.append( facet_ptr ); 01259 // right face 01260 facet_ptr = new CubitFacetData( points[1],points[5], points[9] ); 01261 facet_list.append( facet_ptr ); 01262 facet_ptr = new CubitFacetData( points[5],points[6], points[9] ); 01263 facet_list.append( facet_ptr ); 01264 facet_ptr = new CubitFacetData( points[6],points[2], points[9] ); 01265 facet_list.append( facet_ptr ); 01266 facet_ptr = new CubitFacetData( points[2],points[1], points[9] ); 01267 facet_list.append( facet_ptr ); 01268 // front face 01269 facet_ptr = new CubitFacetData( points[3],points[2], points[10] ); 01270 facet_list.append( facet_ptr ); 01271 facet_ptr = new CubitFacetData( points[2],points[6], points[10] ); 01272 facet_list.append( facet_ptr ); 01273 facet_ptr = new CubitFacetData( points[6],points[7], points[10] ); 01274 facet_list.append( facet_ptr ); 01275 facet_ptr = new CubitFacetData( points[7],points[3], points[10] ); 01276 facet_list.append( facet_ptr ); 01277 01278 points.clear(); // clear out the points vector since we are through with it. 01279 01280 feature_angle = 100.0; 01281 interp_order = 0; 01282 smooth_non_manifold = CUBIT_TRUE; 01283 split_surfaces = CUBIT_FALSE; 01284 01285 ChollaEngine *cholla_ptr = NULL; 01286 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 01287 rv = fme->build_cholla_surfaces( facet_list, 01288 point_list, 01289 feature_angle, 01290 interp_order, 01291 smooth_non_manifold, 01292 split_surfaces, 01293 cholla_ptr ); 01294 if ( rv == CUBIT_SUCCESS ) 01295 { 01296 finish_facet_Body( cholla_ptr, 01297 NULL, 01298 feature_angle, 01299 interp_order, 01300 body_ptr); 01301 if ( cholla_ptr ) 01302 { 01303 cholla_ptr->delete_me(); 01304 delete cholla_ptr; 01305 } 01306 01307 } 01308 return body_ptr; 01309 } 01310 01311 //=============================================================================== 01312 // Function : prism 01313 // Member Type: PUBLIC 01314 // Description: create a prism with facets 01315 // Author : John Fowler 01316 // Date : 10/02 01317 //=============================================================================== 01318 BodySM* FacetModifyEngine::prism( double /*height*/, int /*sides*/, double /*major*/, 01319 double /*minor*/) const 01320 { 01321 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01322 return (BodySM*) NULL; 01323 } 01324 01325 //=============================================================================== 01326 // Function : pyramid 01327 // Member Type: PUBLIC 01328 // Description: create a pyramid with facets 01329 // Author : John Fowler 01330 // Date : 10/02 01331 //=============================================================================== 01332 BodySM* FacetModifyEngine::pyramid( double /*height*/, int /*sides*/, double /*major*/, 01333 double /*minor*/, double /*top*/) const 01334 { 01335 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01336 return (BodySM*) NULL; 01337 } 01338 01339 //=============================================================================== 01340 // Function : cylinder 01341 // Member Type: PUBLIC 01342 // Description: create a cylinder with facets 01343 // Author : John Fowler 01344 // Date : 10/02 01345 //=============================================================================== 01346 BodySM* FacetModifyEngine::cylinder( double hi, double r1, double r2, double r3 ) const 01347 { 01348 MODIFY_CHECK_RETURN_NULL; 01349 01350 CubitStatus rv = CUBIT_SUCCESS; 01351 DLIList <CubitFacet *>facet_list; 01352 DLIList <CubitPoint *>point_list; 01353 CubitPoint *new_point; 01354 CubitFacet *facet_ptr; 01355 int i, j, numpoints; 01356 double feature_angle; 01357 int interp_order; 01358 CubitBoolean smooth_non_manifold, split_surfaces; 01359 BodySM *body_ptr = NULL; 01360 std::vector<CubitPoint *> points; 01361 int reslevel; // relative level of resolution 01362 int nl; // number of axial divisions 01363 int nr; // number of radil divisions 01364 double cfac, rinc, linc; 01365 double x, y, z; 01366 int istart, iend, V3, pend; 01367 double zoffset, lpos, rpos, xrad, yrad; 01368 double rad_ratio = 1.0; 01369 01370 reslevel = 4; 01371 nl = reslevel; 01372 nr = 8*reslevel; 01373 01374 rinc = 360.0/(double)nr; 01375 linc = hi/(double)nl; 01376 cfac = CUBIT_PI/180.; 01377 01378 if ( r3 > 0.0 ) { 01379 // Cylinder: 01380 numpoints = (nl + 1)*nr + 2; 01381 istart = 0; iend = nl+1; 01382 V3 = (nl+1)*nr; 01383 pend = nl; 01384 rad_ratio = r2/r1; 01385 } else { 01386 // Cone: 01387 numpoints = nl*nr + 2; 01388 istart = 0; iend = nl; 01389 V3 = nl*nr; 01390 pend = nl-1; 01391 } 01392 01393 // Make the points. 01394 01395 zoffset = 0.0; 01396 lpos = -0.5*hi; 01397 xrad = r1; 01398 yrad = r2; 01399 for ( i = istart; i < iend; i++ ) { 01400 rpos = 10.0; 01401 xrad = zoffset*r3/hi + (hi - zoffset)*r1/hi; 01402 yrad = zoffset*r3*rad_ratio/hi + (hi - zoffset)*r2/hi; 01403 for ( j = 0; j < nr; j++ ) { 01404 x = xrad*cos(cfac*rpos); 01405 y = yrad*sin(cfac*rpos); 01406 z = lpos; 01407 new_point = (CubitPoint *) new CubitPointData( x,y,z ); 01408 points.push_back(new_point); 01409 rpos += rinc; 01410 } 01411 lpos += linc; 01412 zoffset += linc; 01413 } 01414 // Add the two apoint on the axis at the ends. 01415 new_point = (CubitPoint *) new CubitPointData( 0.,0.,-0.5*hi ); 01416 points.push_back(new_point); 01417 new_point = (CubitPoint *) new CubitPointData( 0.,0.,0.5*hi ); 01418 points.push_back(new_point); 01419 01420 for ( i = 0; i < numpoints; i++ ) { 01421 point_list.append(points[i]); 01422 } 01423 01424 // Make the triangles. 01425 int vertnum; 01426 vertnum = 0; 01427 for ( i = 0; i < pend; i++ ) { 01428 for ( j = 0; j < nr-1; j++ ) { 01429 facet_ptr = new CubitFacetData( points[vertnum+j],points[vertnum+j+1], points[vertnum+j+nr] ); 01430 facet_list.append( facet_ptr ); 01431 facet_ptr = new CubitFacetData( points[vertnum+j+1],points[vertnum+j+1+nr], points[vertnum+j+nr] ); 01432 facet_list.append( facet_ptr ); 01433 } 01434 facet_ptr = new CubitFacetData( points[vertnum],points[vertnum+nr], points[vertnum+2*nr-1] ); 01435 facet_list.append( facet_ptr ); 01436 facet_ptr = new CubitFacetData( points[vertnum+nr-1],points[vertnum], points[vertnum+2*nr-1] ); 01437 facet_list.append( facet_ptr ); 01438 vertnum += nr; 01439 } 01440 01441 // Endcap(s) 01442 for ( i = 0; i < nr-1; i++ ) { // top cap 01443 facet_ptr = new CubitFacetData( points[vertnum+i],points[vertnum+i+1], points[V3+1] ); 01444 facet_list.append( facet_ptr ); 01445 } 01446 facet_ptr = new CubitFacetData( points[nr-1+vertnum],points[vertnum], points[V3+1] ); 01447 facet_list.append( facet_ptr ); 01448 01449 for ( i = 0; i < nr-1; i++ ) { // bottom cap 01450 facet_ptr = new CubitFacetData( points[i+1],points[i], points[V3] ); 01451 facet_list.append( facet_ptr ); 01452 } 01453 facet_ptr = new CubitFacetData( points[0],points[nr-1], points[V3] ); 01454 facet_list.append( facet_ptr ); 01455 01456 points.clear(); // clear out the points vector since we are through with it. 01457 01458 feature_angle = 135.0; 01459 interp_order = 0; 01460 smooth_non_manifold = CUBIT_TRUE; 01461 split_surfaces = CUBIT_FALSE; 01462 01463 ChollaEngine *cholla_ptr = NULL; 01464 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 01465 rv = fme->build_cholla_surfaces( facet_list, 01466 point_list, 01467 feature_angle, 01468 interp_order, 01469 smooth_non_manifold, 01470 split_surfaces, 01471 cholla_ptr ); 01472 01473 if ( rv == CUBIT_SUCCESS ) 01474 { 01475 CubitEvaluatorData **cyl_data = NULL; 01476 01477 set_cylinder_eval_data( cholla_ptr, hi, r1, r2, r3, cyl_data ); 01478 finish_facet_Body( cholla_ptr, 01479 (const CubitEvaluatorData**)cyl_data, 01480 feature_angle, 01481 interp_order, 01482 body_ptr); 01483 if ( cholla_ptr ) 01484 { 01485 cholla_ptr->delete_me(); 01486 delete cholla_ptr; 01487 } 01488 if ( cyl_data ) 01489 { 01490 if ( cyl_data[0] ) delete cyl_data[0]; 01491 if ( cyl_data[1] ) delete cyl_data[1]; 01492 if ( cyl_data[2] ) delete cyl_data[2]; 01493 delete []cyl_data; 01494 } 01495 } 01496 return body_ptr; 01497 } 01498 01499 void FacetModifyEngine::set_cylinder_eval_data 01500 ( 01501 ChollaEngine *cholla_ptr, 01502 double height, 01503 double base_radius_xdir, 01504 double base_radius_ydir, 01505 double top_radius, 01506 CubitEvaluatorData **&eval_data ) const 01507 { 01508 01509 // MODIFY_CHECK_RETURN_VOID; 01510 DLIList<ChollaSurface *> cholla_surface_list; 01511 cholla_ptr->get_surfaces( cholla_surface_list ); 01512 cholla_surface_list.reset(); 01513 01514 eval_data = NULL; 01515 01516 if ( cholla_surface_list.size() != 3 ) 01517 { 01518 // This cylinder/cone is shaped quite unusually such that the cholla engine 01519 // found more than 3 faces on it. This is likely because it is quite smashed 01520 // in the minor radius direction. As such, there is not a cylindrical 01521 // surface so exit. 01522 01523 return; 01524 } 01525 01526 eval_data = new CubitEvaluatorData* [3]; 01527 eval_data[0] = 01528 eval_data[1] = 01529 eval_data[2] = NULL; 01530 01531 int isurf; 01532 for ( isurf = 0; isurf < cholla_surface_list.size(); isurf++ ) 01533 { 01534 eval_data[isurf] = NULL; 01535 DLIList<ChollaCurve*> cholla_curve_list; 01536 ChollaSurface *csurf = cholla_surface_list.get_and_step(); 01537 csurf->get_curves( cholla_curve_list ); 01538 if ( cholla_curve_list.size() == 2 ) 01539 { 01540 // this is the cylindrical face around the cylinder. 01541 CylinderEvaluatorData *data = new CylinderEvaluatorData; 01542 data->height = height; 01543 data->height = height; 01544 data->base_radius_x = base_radius_xdir; 01545 data->base_radius_y = base_radius_ydir; 01546 data->top_radius = top_radius; 01547 01548 eval_data[isurf] = data; 01549 } 01550 } 01551 } 01552 01553 //=============================================================================== 01554 // Function : torus 01555 // Member Type: PUBLIC 01556 // Description: create a torus with facets 01557 // Author : John Fowler 01558 // Date : 10/02 01559 //=============================================================================== 01560 BodySM* FacetModifyEngine::torus( double r1, double r2 ) const 01561 { 01562 01563 MODIFY_CHECK_RETURN_NULL; 01564 CubitStatus rv = CUBIT_SUCCESS; 01565 DLIList <CubitFacet *>facet_list; 01566 DLIList <CubitPoint *>point_list; 01567 CubitPoint *new_point; 01568 CubitFacet *facet_ptr; 01569 int numpoints; 01570 double feature_angle; 01571 int interp_order; 01572 CubitBoolean smooth_non_manifold, split_surfaces; 01573 BodySM *body_ptr = NULL; 01574 std::vector<CubitPoint *> points; 01575 int reslevel; // relative level of resolution 01576 double theta, thetainc, phi, phiinc, x, z, xp, yp, zp, rmajor, rminor; 01577 int numtheta, numphi, i, j; 01578 01579 reslevel = 4; 01580 numtheta = 8*reslevel; 01581 numphi = 8*reslevel; 01582 numpoints = numtheta*numphi; 01583 rmajor = r1; 01584 rminor = r2; 01585 thetainc = 2.*CUBIT_PI/(double)numtheta; 01586 phiinc = 2.*CUBIT_PI/(double)numphi; 01587 phi = 0.; 01588 01589 // Make the points in the y=0 plane 01590 for ( j = 0; j < numphi; j++ ) { 01591 theta = 0.; 01592 for ( i = 0; i < numtheta; i++ ) { 01593 x = rmajor + rminor*cos(theta); 01594 z = rminor*sin(theta); 01595 // Rotate around the z axis 01596 xp = x*cos(phi); 01597 zp = z; 01598 yp = x*sin(phi); 01599 new_point = (CubitPoint *) new CubitPointData( xp,yp,zp ); 01600 points.push_back(new_point); 01601 theta += thetainc; 01602 } 01603 phi += phiinc; 01604 } 01605 01606 for ( i = 0; i < numpoints; i++ ) { 01607 point_list.append(points[i]); 01608 } 01609 // Make the triangles 01610 int m, k, m2, numtris; 01611 m = numtheta; 01612 numtris = 0; 01613 for ( j = 0; j < numphi; j++ ) { 01614 if ( j == numphi-1 ) m2 = 0; 01615 else m2 = m; 01616 for ( i = 0; i < numtheta; i++ ) { 01617 k = (i+1)%numtheta; 01618 facet_ptr = new CubitFacetData( points[i+m-numtheta], points[m2+i], points[m2+k] ); 01619 facet_list.append( facet_ptr ); 01620 facet_ptr = new CubitFacetData( points[i+m-numtheta], points[m2+k], points[m-numtheta+k] ); 01621 facet_list.append( facet_ptr ); 01622 numtris += 2; 01623 } 01624 m += numtheta; 01625 } 01626 01627 points.clear(); // clear out the points vector since we are through with it. 01628 01629 feature_angle = 135.0; 01630 interp_order = 0; 01631 smooth_non_manifold = CUBIT_TRUE; 01632 split_surfaces = CUBIT_FALSE; 01633 01634 ChollaEngine *cholla_ptr = NULL; 01635 FacetModifyEngine *fme = const_cast<FacetModifyEngine *> (this); 01636 rv = fme->build_cholla_surfaces( facet_list, 01637 point_list, 01638 feature_angle, 01639 interp_order, 01640 smooth_non_manifold, 01641 split_surfaces, 01642 cholla_ptr ); 01643 01644 01645 if ( rv == CUBIT_SUCCESS ) 01646 { 01647 finish_facet_Body( cholla_ptr, 01648 NULL, 01649 feature_angle, 01650 interp_order, 01651 body_ptr); 01652 if ( cholla_ptr ) 01653 { 01654 cholla_ptr->delete_me(); 01655 delete cholla_ptr; 01656 } 01657 } 01658 return body_ptr; 01659 } 01660 01661 //=============================================================================== 01662 // Function : planar_sheet 01663 // Member Type: PUBLIC 01664 // Description: create a planar_sheet with facets 01665 // Author : John Fowler 01666 // Date : 10/02 01667 //=============================================================================== 01668 BodySM* FacetModifyEngine::planar_sheet ( const CubitVector& /*p1*/, 01669 const CubitVector& /*p2*/, 01670 const CubitVector& /*p3*/, 01671 const CubitVector& /*p4*/ ) const 01672 { 01673 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01674 return (BodySM*) NULL; 01675 } 01676 01677 //=============================================================================== 01678 // Function : copy_body 01679 // Member Type: PUBLIC 01680 // Description: copy a facet-based body 01681 // Author : John Fowler 01682 // Date : 10/02 01683 //=============================================================================== 01684 BodySM* FacetModifyEngine::copy_body( BodySM* /*body_sm*/, 01685 std::map<TopologyBridge*, TopologyBridge*> * /*old_tb_to_new_tb */) const 01686 { 01687 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01688 return (BodySM*) NULL; 01689 } 01690 01691 /* 01692 CubitStatus FacetModifyEngine::stitch_surfs( 01693 DLIList<BodySM*>& surf_bodies, 01694 BodySM*& stitched_body) const 01695 { 01696 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01697 return CUBIT_SUCCESS; 01698 } 01699 */ 01700 //=============================================================================== 01701 // Function : subtract 01702 // Member Type: PUBLIC 01703 // Description: subtract boolean operation on facet-based bodies 01704 // Author : John Fowler 01705 // Date : 10/02 01706 //=============================================================================== 01707 CubitStatus FacetModifyEngine::subtract(DLIList<BodySM*> &tool_body_list, 01708 DLIList<BodySM*> &from_bodies, 01709 DLIList<BodySM*> &new_bodies, 01710 bool /*imprint*/, 01711 bool keep_old) const 01712 { 01713 01714 MODIFY_CHECK_RETURN_FAILURE; 01715 CubitStatus status = CUBIT_FAILURE; 01716 int i; 01717 BodySM *tool_body, *from_body; 01718 FacetboolInterface *fbint; 01719 CubitFacetboolOp op; 01720 01721 bool *to_be_deleted = new bool[from_bodies.size()]; 01722 01723 op = CUBIT_FB_SUBTRACTION; 01724 01725 from_bodies.reset(); 01726 tool_body_list.reset(); 01727 01728 for ( i = 0; i < from_bodies.size(); i++ ) to_be_deleted[i] = false; 01729 01730 for ( i = tool_body_list.size(); i > 0; i-- ) { 01731 tool_body = tool_body_list.get_and_step(); 01732 fbint = new FacetboolInterface; 01733 status = fbint->dofacetboolean_subtract(tool_body,from_bodies,new_bodies, 01734 keep_old,to_be_deleted,op); 01735 delete fbint; 01736 if( keep_old == false ) 01737 FacetQueryEngine::instance()->delete_solid_model_entities(tool_body); 01738 } 01739 01740 for ( i = 0; i < from_bodies.size(); i++ ) { 01741 from_body = from_bodies.get_and_step(); 01742 if ( to_be_deleted[i] == true ) 01743 FacetQueryEngine::instance()->delete_solid_model_entities(from_body); 01744 } 01745 01746 delete [] to_be_deleted; 01747 01748 return status; 01749 01750 } 01751 01752 //=============================================================================== 01753 // Function : imprint 01754 // Member Type: PUBLIC 01755 // Description: imprint boolean operation on facet-based bodies 01756 // Author : John Fowler 01757 // Date : 10/02 01758 //=============================================================================== 01759 CubitStatus FacetModifyEngine::imprint(BodySM* /*BodyPtr1*/, BodySM* /*BodyPtr2*/, 01760 BodySM*& /*newBody1*/, BodySM*& /*newBody2*/, 01761 bool /*keep_old*/) const 01762 { 01763 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01764 return CUBIT_FAILURE; 01765 } 01766 01767 //=============================================================================== 01768 // Function : imprint 01769 // Member Type: PUBLIC 01770 // Description: imprint boolean operation on facet-based bodies 01771 // Author : John Fowler 01772 // Date : 10/02 01773 //=============================================================================== 01774 CubitStatus FacetModifyEngine::imprint(DLIList<BodySM*> &from_body_list , 01775 DLIList<BodySM*> &new_from_body_list, 01776 bool keep_old, 01777 DLIList<TopologyBridge*> *new_tbs, 01778 DLIList<TopologyBridge*> *att_tbs) const 01779 { 01780 MODIFY_CHECK_RETURN_FAILURE; 01781 01782 CubitStatus success = CUBIT_SUCCESS; 01783 01784 // total number of imprints to be done 01785 const int num_bodies = from_body_list.size(); 01786 // int total_imprints = (num_bodies *(num_bodies-1))/2; 01787 int i, j; 01788 CubitBox bbox1, bbox2; 01789 std::vector<BodySM*> bodies_vector; 01790 for ( i = 0; i < from_body_list.size(); i++ ) 01791 bodies_vector.push_back(from_body_list.get_and_step()); 01792 01793 // pass in keep_old to the delete_owner_attrib flag; if we're not keeping 01794 // old bodies, we want to keep the owner attrib, so we can pick up entities 01795 // that didn't change 01796 // bool delete_attribs = 01797 (GeometryModifyTool::instance()->get_new_ids() || keep_old); 01798 01799 from_body_list.reset(); 01800 for (i = 0; success && i < num_bodies - 1; i++) { 01801 for (j = i + 1; j < num_bodies; j++) { 01802 BodySM *Body_Ptr1 = bodies_vector[i]; 01803 success = FacetQueryEngine::instance()->create_facet_bounding_box( 01804 Body_Ptr1, 01805 bbox1); 01806 01807 if (AppUtil::instance()->interrupt()) 01808 { 01809 success = CUBIT_FAILURE; 01810 break; 01811 } 01812 BodySM *Body_Ptr2 = bodies_vector[j]; 01813 success = FacetQueryEngine::instance()->create_facet_bounding_box( 01814 Body_Ptr2, 01815 bbox2); 01816 if (bbox1.overlap(GEOMETRY_RESABS, bbox2)) { 01817 FacetboolInterface *FBInt = new FacetboolInterface; 01818 BodySM *out_Body_Ptr1, *out_Body_Ptr2; 01819 FBInt->dofacetboolean_2bodies_imprint(Body_Ptr1,Body_Ptr2, 01820 out_Body_Ptr1,out_Body_Ptr2, 01821 keep_old); 01822 delete FBInt; 01823 instance()->get_gqe()->delete_solid_model_entities(bodies_vector[i]); 01824 instance()->get_gqe()->delete_solid_model_entities(bodies_vector[j]); 01825 bodies_vector[i] = out_Body_Ptr1; 01826 bodies_vector[j] = out_Body_Ptr2; 01827 } 01828 01829 } 01830 } 01831 01832 from_body_list.reset(); 01833 for ( i = 0; i < from_body_list.size(); i++ ) { 01834 new_from_body_list.append(bodies_vector[i]); 01835 } 01836 01837 return success; 01838 } 01839 01840 //=============================================================================== 01841 // Function : imprint 01842 // Member Type: PUBLIC 01843 // Description: imprint boolean operation on facet-based bodies 01844 // Author : John Fowler 01845 // Date : 10/02 01846 //=============================================================================== 01847 CubitStatus FacetModifyEngine::imprint( DLIList<BodySM*> &body_list, 01848 DLIList<Curve*> &ref_edge_list, 01849 DLIList<BodySM*>& new_body_list, 01850 DLIList<TopologyBridge*> &temporary_bridges, 01851 bool keep_old, 01852 bool show_messages) const 01853 { 01854 MODIFY_CHECK_RETURN_FAILURE; 01855 01856 CubitStatus success = CUBIT_SUCCESS; 01857 // bool delete_attribs = 01858 (GeometryModifyTool::instance()->get_new_ids() || keep_old); 01859 int i; 01860 CubitBox edge_list_bbox, bbox2; 01861 const int num_bodies = body_list.size(); 01862 01863 FacetboolInterface *FBInt = new FacetboolInterface; 01864 01865 FBInt->make_FB_edge_list(ref_edge_list); 01866 FBInt->get_edge_list_bbox(edge_list_bbox); 01867 01868 for (i = 0; success && i < num_bodies; i++) { 01869 BodySM *Body_Ptr = body_list.next(i); 01870 success = FacetQueryEngine::instance()->create_facet_bounding_box( 01871 Body_Ptr, 01872 bbox2); 01873 if (edge_list_bbox.overlap(GEOMETRY_RESABS, bbox2)) { 01874 BodySM *new_body; 01875 FBInt->FB_imprint_with_curves(Body_Ptr,new_body,keep_old); 01876 new_body_list.append(new_body); 01877 } 01878 } 01879 01880 delete FBInt; 01881 01882 body_list.reset(); 01883 for ( i = 0; i < body_list.size(); i++ ) { 01884 instance()->get_gqe()->delete_solid_model_entities(body_list.get_and_step()); 01885 } 01886 01887 return success; 01888 } 01889 01890 //=============================================================================== 01891 // Function : imprint 01892 // Member Type: PUBLIC 01893 // Description: imprint boolean operation on facet-based bodies 01894 // Author : John Fowler 01895 // Date : 10/02 01896 //=============================================================================== 01897 CubitStatus FacetModifyEngine::imprint( DLIList<Surface*> &/*ref_face_list*/, 01898 DLIList<Curve*> &/*ref_edge_list*/, 01899 DLIList<TopologyBridge*> &temporary_bridges, 01900 DLIList<BodySM*>& /*new_body_list*/, 01901 bool /*keep_old_body*/ ) const 01902 { 01903 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01904 return CUBIT_FAILURE; 01905 } 01906 01907 //=============================================================================== 01908 // Function : imprint 01909 // Member Type: PUBLIC 01910 // Description: imprint boolean operation on facet-based bodies 01911 // Author : John Fowler 01912 // Date : 10/02 01913 //=============================================================================== 01914 CubitStatus FacetModifyEngine::imprint( DLIList<Surface*> &/*surface_list*/, 01915 DLIList<DLIList<Curve*>*> &/*curve_lists_list*/, 01916 BodySM*& /*new_body*/, 01917 bool /*keep_old_body*/, 01918 bool /*expand*/, 01919 DLIList<TopologyBridge*> *new_tbs, 01920 DLIList<TopologyBridge*> *att_tbs ) const 01921 { 01922 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01923 return CUBIT_FAILURE; 01924 } 01925 01926 //=============================================================================== 01927 // Function : imprint 01928 // Member Type: PUBLIC 01929 // Description: imprint boolean operation on facet-based bodies 01930 // Author : John Fowler 01931 // Date : 10/02 01932 //=============================================================================== 01933 CubitStatus FacetModifyEngine::imprint(DLIList<BodySM*> &/*body_list*/, 01934 DLIList<CubitVector> &/*vector_list*/, 01935 DLIList<BodySM*>& /*new_body_list*/, 01936 bool keep_old, /* keep old body */ 01937 DLIList<TopologyBridge*> *new_tbs, 01938 DLIList<TopologyBridge*> *att_tbs, 01939 double *tol_in, 01940 bool clean_up_slivers) const 01941 { 01942 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01943 return CUBIT_FAILURE; 01944 } 01945 01946 //=============================================================================== 01947 // Function : imprint_projected_edges 01948 // Member Type: PUBLIC 01949 // Description: 01950 // Author : John Fowler 01951 // Date : 10/02 01952 //=============================================================================== 01953 CubitStatus FacetModifyEngine::imprint_projected_edges( DLIList<Surface*> &/*ref_face_list*/, 01954 DLIList<Curve*> &/*ref_edge_list*/, 01955 DLIList<BodySM*>& /*new_body_list*/, 01956 DLIList<Curve*> & /*kept_curve_list*/, 01957 bool /*keep_old_body*/, 01958 bool /*keep_free_edges*/) const 01959 { 01960 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01961 return CUBIT_FAILURE; 01962 } 01963 01964 //=============================================================================== 01965 // Function : imprint_projected_edges 01966 // Member Type: PUBLIC 01967 // Description: 01968 // Author : John Fowler 01969 // Date : 10/02 01970 //=============================================================================== 01971 CubitStatus FacetModifyEngine::imprint_projected_edges(DLIList<Surface*> &/*ref_face_list*/, 01972 DLIList<BodySM*> &/*body_list*/, 01973 DLIList<Curve*> &/*ref_edge_list*/, 01974 DLIList<BodySM*>& /*new_body_list*/, 01975 bool /*keep_old_body*/, 01976 bool /*keep_free_edges*/) const 01977 { 01978 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01979 return CUBIT_FAILURE; 01980 } 01981 01982 //=============================================================================== 01983 // Function : project_edges 01984 // Member Type: PUBLIC 01985 // Description: 01986 // Author : John Fowler 01987 // Date : 10/02 01988 //=============================================================================== 01989 CubitStatus FacetModifyEngine::project_edges( DLIList<Surface*> &/*ref_face_list*/, 01990 DLIList<Curve*> &/*ref_edge_list_in*/, 01991 DLIList<Curve*> &/*ref_edge_list_new*/, 01992 bool /*print_error*/ ) const 01993 { 01994 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 01995 return CUBIT_FAILURE; 01996 } 01997 01998 //=============================================================================== 01999 // Function : intersect 02000 // Member Type: PUBLIC 02001 // Description: intersect boolean operation between facet-based bodies 02002 // Author : John Fowler 02003 // Date : 10/02 02004 //=============================================================================== 02005 CubitStatus FacetModifyEngine::intersect(BodySM* tool_body_ptr, 02006 DLIList<BodySM*> &from_bodies, 02007 DLIList<BodySM*> &new_bodies, 02008 bool keep_old, 02009 bool preview ) const 02010 { 02011 if (preview) 02012 { 02013 PRINT_ERROR("Intersect preview not implemented for Facet geometry\n"); 02014 return CUBIT_FAILURE; 02015 } 02016 02017 02018 MODIFY_CHECK_RETURN_FAILURE; 02019 02020 CubitStatus status = CUBIT_FAILURE; 02021 int i; 02022 BodySM *from_body, *newBody; 02023 // FacetboolInterface *fbint; 02024 CubitFacetboolOp op; 02025 DLIList<BodySM*> bodies; 02026 02027 op = CUBIT_FB_INTERSECTION; 02028 02029 from_bodies.reset(); 02030 for ( i = from_bodies.size(); i > 0; i-- ) { 02031 bodies.clean_out(); 02032 bodies.append(tool_body_ptr); 02033 from_body = from_bodies.get_and_step(); 02034 bodies.append(from_body); 02035 FacetboolInterface fbint; 02036 status = fbint.dofacetboolean(bodies,newBody,keep_old,op); 02037 if ( status == CUBIT_SUCCESS && newBody) new_bodies.append(newBody); 02038 } 02039 02040 return status; 02041 02042 /* 02043 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02044 return CUBIT_FAILURE; 02045 */ 02046 } 02047 02048 //=============================================================================== 02049 // Function : chop 02050 // Member Type: PUBLIC 02051 // Description: chop boolean operation between facet-based bodies 02052 // Author : John Fowler 02053 // Date : 10/02 02054 //=============================================================================== 02055 CubitStatus FacetModifyEngine::chop(DLIList<BodySM*>& bodies, 02056 DLIList<BodySM*> &intersectBodies, 02057 DLIList<BodySM*> &outsideBodies, 02058 BodySM*& leftoversBody, 02059 bool keep_old , 02060 bool nonreg) const 02061 { 02062 MODIFY_CHECK_RETURN_FAILURE; 02063 02064 //Note: there is never any leftover body. 02065 FacetboolInterface *fbint; 02066 CubitFacetboolOp op; 02067 bool keep_old_this = keep_old; 02068 CubitStatus status; 02069 BodySM *body_1, *body_2; 02070 bool intersection_found; 02071 BodySM* intersectBody = NULL; 02072 BodySM* outsideBody = NULL; 02073 02074 if ( bodies.size() > 2 ) { 02075 PRINT_ERROR("Chop not yet supported for more than two bodies.\n"); 02076 return CUBIT_FAILURE; 02077 } 02078 body_1 = bodies.get_and_step(); 02079 body_2 = bodies.get(); 02080 op = CUBIT_FB_INTERSECTION; 02081 fbint = new FacetboolInterface; 02082 status = fbint->dofacetboolean_2bodies(body_2,body_1,intersectBody, 02083 keep_old_this,intersection_found,op); 02084 if(!status){ 02085 delete fbint; 02086 return status; 02087 } 02088 02089 02090 delete fbint; 02091 if(intersection_found){ 02092 intersectBodies.append( intersectBody ); 02093 } 02094 else{ 02095 return CUBIT_FAILURE; 02096 } 02097 op = CUBIT_FB_SUBTRACTION; 02098 fbint = new FacetboolInterface; 02099 status = fbint->dofacetboolean_2bodies(body_1,body_2,outsideBody, 02100 keep_old_this,intersection_found,op); 02101 if(!status){ 02102 delete fbint; 02103 return status; 02104 } 02105 delete fbint; 02106 if(intersection_found){ 02107 outsideBodies.append( outsideBody ); 02108 } 02109 else{ 02110 return CUBIT_FAILURE; 02111 } 02112 02113 if ( keep_old == false ) { 02114 FacetQueryEngine::instance()->delete_solid_model_entities(body_1); 02115 FacetQueryEngine::instance()->delete_solid_model_entities(body_2); 02116 } 02117 02118 return status; 02119 02120 } 02121 02122 void FacetModifyEngine::get_possible_invalid_tbs(DLIList<TopologyBridge*> &bridges_in, 02123 DLIList<TopologyBridge*> &bridges_out) 02124 { 02125 } 02126 02127 //=============================================================================== 02128 // Function : unite 02129 // Member Type: PUBLIC 02130 // Description: unite boolean operation between facet-based bodies 02131 // Author : John Fowler 02132 // Date : 10/02 02133 //=============================================================================== 02134 CubitStatus FacetModifyEngine::unite(DLIList<BodySM*> &bodies, 02135 DLIList<BodySM*> &newBodies, 02136 bool keep_old) const 02137 { 02138 MODIFY_CHECK_RETURN_FAILURE; 02139 02140 02141 CubitStatus status; 02142 FacetboolInterface *fbint; 02143 CubitFacetboolOp op; 02144 02145 op = CUBIT_FB_UNION; 02146 fbint = new FacetboolInterface; 02147 02148 BodySM *newBody = NULL; 02149 status = fbint->dofacetboolean(bodies,newBody,keep_old,op); 02150 02151 newBodies.append( newBody ); 02152 delete fbint; 02153 return status; 02154 /* 02155 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02156 return CUBIT_FAILURE; 02157 */ 02158 02159 } 02160 02161 02162 CubitStatus FacetModifyEngine::hollow( DLIList<BodySM*>& /*bodies*/, 02163 DLIList<Surface*> & /*surfs*/, 02164 DLIList<BodySM*>& /*new_bodies*/, 02165 double /*depth*/) const 02166 { 02167 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02168 return CUBIT_FAILURE; 02169 } 02170 02171 //=============================================================================== 02172 // Function : thicken 02173 // Member Type: PUBLIC 02174 // Description: 02175 // Author : John Fowler 02176 // Date : 10/02 02177 //=============================================================================== 02178 CubitStatus FacetModifyEngine::thicken(DLIList<BodySM*>& /*bodies*/, 02179 DLIList<BodySM*>& /*new_bodies*/, 02180 double /*depth*/, 02181 bool /*both*/) const 02182 { 02183 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02184 return CUBIT_FAILURE; 02185 } 02186 02187 02188 //=============================================================================== 02189 // Function : flip_normals 02190 // Member Type: PUBLIC 02191 // Description: 02192 // Author : John Fowler 02193 // Date : 10/02 02194 //=============================================================================== 02195 CubitStatus FacetModifyEngine :: flip_normals( DLIList<Surface*>& face_list ) const 02196 { 02197 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02198 return CUBIT_FAILURE; 02199 } 02200 02201 02202 //=============================================================================== 02203 // Function : sweep_translational 02204 // Member Type: PUBLIC 02205 // Description: 02206 // Author : John Fowler 02207 // Date : 10/02 02208 //=============================================================================== 02209 CubitStatus FacetModifyEngine:: sweep_translational( 02210 DLIList<GeometryEntity*>& /*ref_ent_list*/, 02211 DLIList<BodySM*>& /*result_body_list*/, 02212 const CubitVector& /*sweep_vector*/, 02213 double /*draft_angle*/, 02214 int /*draft_type*/, 02215 bool /*switchside*/, 02216 bool /*rigid*/, 02217 bool /*anchor_entity*/, 02218 bool /*keep_old*/ ) const 02219 { 02220 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02221 return CUBIT_FAILURE; 02222 } 02223 02224 //=============================================================================== 02225 // Function : sweep_perpendicular 02226 // Member Type: PUBLIC 02227 // Description: 02228 // Author : John Fowler 02229 // Date : 10/02 02230 //=============================================================================== 02231 CubitStatus FacetModifyEngine:: sweep_perpendicular( 02232 DLIList<GeometryEntity*>& /*ref_ent_list*/, 02233 DLIList<BodySM*>& /*result_body_list*/, 02234 double /*distance*/, 02235 double /*draft_angle*/, 02236 int /*draft_type*/, 02237 bool /*switchside*/, 02238 bool /*rigid*/, 02239 bool /*anchor_entity*/, 02240 bool /*keep_old*/ ) const 02241 { 02242 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02243 return CUBIT_FAILURE; 02244 } 02245 02246 //=============================================================================== 02247 // Function : sweep_rotational 02248 // Member Type: PUBLIC 02249 // Description: 02250 // Author : John Fowler 02251 // Date : 10/02 02252 //=============================================================================== 02253 CubitStatus FacetModifyEngine:: sweep_rotational( 02254 DLIList<GeometryEntity*>& /*ref_ent_list*/, 02255 DLIList<BodySM*>& /*result_body_list*/, 02256 const CubitVector& /*point*/, 02257 const CubitVector& /*direction*/, 02258 double /*angle*/, 02259 int /*steps*/, 02260 double /*draft_angle*/, 02261 int /*draft_type*/, 02262 bool /*switchside*/, 02263 bool /*make_solid*/, 02264 bool /*rigid*/, 02265 bool /*anchor_entity*/, 02266 bool /*keep_old*/ ) const 02267 { 02268 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02269 return CUBIT_FAILURE; 02270 } 02271 02272 //=============================================================================== 02273 // Function : sweep_along_curve 02274 // Member Type: PUBLIC 02275 // Description: 02276 // Author : John Fowler 02277 // Date : 10/02 02278 //=============================================================================== 02279 CubitStatus FacetModifyEngine::sweep_along_curve( 02280 DLIList<GeometryEntity*>& /*ref_ent_list*/, 02281 DLIList<BodySM*>& /*result_body_list*/, 02282 DLIList<Curve*>& /*ref_edge_list*/, 02283 double /*draft_angle*/, 02284 int /*draft_type*/, 02285 bool /*rigid*/, 02286 bool /*anchor_entity*/, 02287 bool /*keep_old*/ ) const 02288 { 02289 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02290 return CUBIT_FAILURE; 02291 } 02292 02293 CubitStatus FacetModifyEngine::sweep_to_body( DLIList<Curve*> curve_list, 02294 BodySM *target_body, 02295 CubitVector distance, 02296 DLIList<BodySM*> &new_bodies, 02297 bool unite ) const 02298 { 02299 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02300 return CUBIT_FAILURE; 02301 } 02302 02303 CubitStatus FacetModifyEngine::sweep_to_body( Surface *source_surface, 02304 BodySM *target_body, 02305 CubitVector distance, 02306 DLIList<BodySM*> &new_bodies ) const 02307 { 02308 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02309 return CUBIT_FAILURE; 02310 } 02311 02312 //HEADER- Webcut-related functions 02313 02314 //=============================================================================== 02315 // Function : webcut 02316 // Member Type: PUBLIC 02317 // Description: 02318 // Author : John Fowler 02319 // Date : 10/02 02320 //=============================================================================== 02321 CubitStatus FacetModifyEngine::webcut(DLIList<BodySM*>& webcut_body_list, 02322 const CubitVector &v1, 02323 const CubitVector &v2, 02324 const CubitVector &v3, 02325 DLIList<BodySM*>& neighbor_imprint_list, 02326 DLIList<BodySM*>& results_list, 02327 ImprintType imprint_type, 02328 bool /*preview*/) const 02329 { 02330 02331 MODIFY_CHECK_RETURN_FAILURE; 02332 02333 CubitBox super_bbox; 02334 CubitStatus status; 02335 int i; 02336 02337 CubitBoolean delete_bodies = (GeometryModifyTool::instance()->get_new_ids() ? 02338 CUBIT_FALSE : CUBIT_TRUE); 02339 02340 // Find the bounding box of all of the bodies. This will be used to make 02341 // the cutting plane. 02342 02343 02344 status = FacetQueryEngine::instance()->create_super_facet_bounding_box(webcut_body_list, 02345 super_bbox); 02346 02347 // Find the size of the cutting plane (x,y) in terms of super_bbox. 02348 DLIList<CubitVector> intersection_points; 02349 FBDataUtil::intersect_plane_with_boundingbox(super_bbox, 02350 v1,v2,v3,intersection_points); 02351 int numpts = intersection_points.size();; 02352 if ( numpts < 3 ) { 02353 PRINT_INFO("INFO: Cutting Tool overlaps the original volume,\n" 02354 " Or cutting plane does not pass through volume.\n" 02355 " The original volume is unaffected.\n" ); 02356 02357 return CUBIT_FAILURE; 02358 } 02359 double xsize, ysize, xcen, ycen, zcen; 02360 double xmin, ymin, zmin, xmax, ymax, zmax, xx, yy, zz; 02361 xmin = ymin = zmin = CUBIT_DBL_MAX; 02362 xmax = ymax = zmax = -xmin + 1; 02363 xcen = ycen = zcen = 0.0; 02364 for ( i = 0; i < numpts; i++ ) { 02365 xx = intersection_points[i].x(); 02366 yy = intersection_points[i].y(); 02367 zz = intersection_points[i].z(); 02368 02369 xcen += xx; 02370 ycen += yy; 02371 zcen += zz; 02372 02373 xmin = (xmin < xx ) ? xmin : xx; 02374 ymin = (ymin < yy ) ? ymin : yy; 02375 zmin = (zmin < zz ) ? zmin : zz; 02376 xmax = (xmax > xx ) ? xmax : xx; 02377 ymax = (ymax > yy ) ? ymax : yy; 02378 zmax = (zmax > zz ) ? zmax : zz; 02379 } 02380 xcen /= numpts; ycen /= numpts; zcen /= numpts; 02381 02382 // Could do this better by rotating the intersection points into the 02383 // x-y plane and then getting xsize and ysize. Factor of 1.3 is just 02384 // to make sure that the plane extends beyond the bodies. 02385 xsize = ysize = 1.3*sqrt( (xmax-xmin)*(xmax-xmin) + 02386 (ymax-ymin)*(ymax-ymin) + 02387 (zmax-zmin)*(zmax-zmin) ); 02388 std::vector<double> cutter_verts; 02389 std::vector<int> cutter_connections; 02390 int numx, numy; 02391 numx = 20; 02392 numy = 20; 02393 // Make the cutter surface. 02394 status = FBDataUtil::FBmake_xy_plane(cutter_verts, cutter_connections, 02395 xsize, ysize, numx, numy); 02396 CubitVector va, vb; 02397 va = v1 - v2; 02398 vb = v3 - v2; 02399 CubitVector rotate_to; 02400 02401 rotate_to = vb*va; 02402 rotate_to.normalize(); 02403 CubitVector center_pt(xcen,ycen,zcen); 02404 status = FBDataUtil::rotate_FB_object(cutter_verts,rotate_to,center_pt); 02405 FacetboolInterface *fbint; 02406 bool cutter_is_plane = true; 02407 // Now make the facetbool objects for the bodies. 02408 webcut_body_list.reset(); 02409 BodySM *body_sm; 02410 02411 for ( i = webcut_body_list.size(); i > 0; i-- ) { 02412 CubitBoolean intersects; 02413 body_sm = webcut_body_list.get_and_step(); 02414 fbint = new FacetboolInterface; 02415 status = fbint->webcut_FB(body_sm,cutter_verts,cutter_connections, 02416 cutter_is_plane,delete_bodies, 02417 intersects,results_list); 02418 delete fbint; 02419 if ( status == CUBIT_FAILURE ) 02420 { 02421 PRINT_ERROR(" Unable to perform webcut.\n" ); 02422 return CUBIT_FAILURE; 02423 } 02424 02425 if ( status == CUBIT_SUCCESS && intersects ) 02426 { 02427 instance()->get_gqe()->delete_solid_model_entities(body_sm); 02428 } 02429 else 02430 { 02431 PRINT_INFO("INFO: Cutting Tool overlaps the original volume,\n" 02432 " Or cutting plane does not pass through volume.\n" 02433 " The original volume is unaffected.\n" ); 02434 } 02435 } 02436 02437 return status; 02438 02439 } 02440 02441 //=============================================================================== 02442 // Function : webcut 02443 // Member Type: PUBLIC 02444 // Description: 02445 // Author : John Fowler 02446 // Date : 10/02 02447 //=============================================================================== 02448 CubitStatus FacetModifyEngine::webcut(DLIList<BodySM*>& /*webcut_body_list*/, 02449 BodySM const* /*tool_body*/, 02450 DLIList<BodySM*>& /*neighbor_imprint_list*/, 02451 DLIList<BodySM*>& /*results_list*/, 02452 ImprintType imprint_type, 02453 bool /*preview*/) const 02454 { 02455 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02456 return CUBIT_FAILURE; 02457 } 02458 02459 //=============================================================================== 02460 // Function : webcut_across_translate 02461 // Member Type: PUBLIC 02462 // Description: 02463 // Author : John Fowler 02464 // Date : 10/02 02465 //=============================================================================== 02466 CubitStatus FacetModifyEngine::webcut_across_translate( DLIList<BodySM*>& /*body_list*/, 02467 Surface* /*plane_surf1*/, 02468 Surface* /*plane_surf2*/, 02469 DLIList<BodySM*>& /*neighbor_imprint_list*/, 02470 DLIList<BodySM*>& /*results_list*/, 02471 ImprintType imprint_type, 02472 bool /*preview*/) const 02473 { 02474 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02475 return CUBIT_FAILURE; 02476 } 02477 02478 //=============================================================================== 02479 // Function : webcut_with_sheet 02480 // Member Type: PUBLIC 02481 // Description: 02482 // Author : John Fowler 02483 // Date : 10/02 02484 //=============================================================================== 02485 CubitStatus FacetModifyEngine::webcut_with_sheet(DLIList<BodySM*> & /*webcut_body_list*/, 02486 BodySM * /*sheet_body*/, 02487 DLIList<BodySM*>& /*neighbor_imprint_list*/, 02488 DLIList<BodySM*> & /*new_bodies*/, 02489 ImprintType imprint_type, 02490 bool /*preview*/) 02491 { 02492 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02493 return CUBIT_FAILURE; 02494 } 02495 02496 //=============================================================================== 02497 // Function : webcut_with_extended_surf 02498 // Member Type: PUBLIC 02499 // Description: 02500 // Author : John Fowler 02501 // Date : 10/02 02502 //=============================================================================== 02503 CubitStatus FacetModifyEngine::webcut_with_extended_sheet(DLIList<BodySM*> & /*webcut_body_list*/, 02504 DLIList<Surface*> & /*surface_list*/, 02505 DLIList<BodySM*>& /*neighbor_imprint_list*/, 02506 DLIList<BodySM*> & /*new_bodies*/, 02507 int & /*num_cut*/, 02508 ImprintType imprint_type, 02509 bool /*preview*/) 02510 { 02511 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02512 return CUBIT_FAILURE; 02513 } 02514 02515 //=============================================================================== 02516 // Function : webcut_with_cylinder 02517 // Member Type: PUBLIC 02518 // Description: 02519 // Author : John Fowler 02520 // Date : 10/02 02521 //=============================================================================== 02522 CubitStatus FacetModifyEngine::webcut_with_cylinder(DLIList<BodySM*> &webcut_body_list, 02523 double radius, 02524 const CubitVector &axis, 02525 const CubitVector ¢er, 02526 DLIList<BodySM*>& neighbor_imprint_list, 02527 DLIList<BodySM*>& results_list, 02528 ImprintType imprint_type, 02529 bool /*preview*/ ) 02530 { 02531 02532 MODIFY_CHECK_RETURN_FAILURE; 02533 02534 CubitBox super_bbox; 02535 CubitStatus status; 02536 int i; 02537 CubitVector bodies_center, my_center, diagonal, my_axis; 02538 02539 CubitBoolean delete_bodies = (GeometryModifyTool::instance()->get_new_ids() ? 02540 CUBIT_FALSE : CUBIT_TRUE); 02541 02542 status = FacetQueryEngine::instance()->create_super_facet_bounding_box( 02543 webcut_body_list,super_bbox); 02544 std::vector<double> cutter_verts; 02545 std::vector<int> cutter_connections; 02546 int nr, nz; 02547 double length; 02548 02549 diagonal = super_bbox.diagonal(); 02550 // length = 2.3*diagonal.length() + 2.0*center.length(); 02551 bodies_center = super_bbox.center(); 02552 length = 3.*sqrt((bodies_center.x() - center.x())*(bodies_center.x() - center.x()) + 02553 (bodies_center.y() - center.y())*(bodies_center.y() - center.y()) + 02554 (bodies_center.z() - center.z())*(bodies_center.z() - center.z()) ); 02555 length += 3.*diagonal.length(); 02556 //length = sqrt(length*length + radius*radius); 02557 // bodies_center += center; 02558 02559 nr = 30; 02560 nz = 5; 02561 02562 // Make the cutter surface. 02563 status = FBDataUtil::FBmake_cylinder(cutter_verts, cutter_connections, 02564 radius, length, nr, nz); 02565 my_center = center; 02566 my_axis = axis; 02567 status = FBDataUtil::rotate_FB_object(cutter_verts,my_axis,my_center); 02568 02569 FacetboolInterface *fbint; 02570 bool cutter_is_plane = false; 02571 // Now make the facetbool objects for the bodies. 02572 webcut_body_list.reset(); 02573 BodySM* body_sm; 02574 for ( i = webcut_body_list.size(); i > 0; i-- ) { 02575 CubitBoolean intersects; 02576 body_sm = webcut_body_list.get_and_step(); 02577 fbint = new FacetboolInterface; 02578 status = fbint->webcut_FB(body_sm,cutter_verts,cutter_connections, 02579 cutter_is_plane,delete_bodies, 02580 intersects,results_list); 02581 delete fbint; 02582 if ( status == CUBIT_FAILURE ) 02583 { 02584 PRINT_ERROR(" Unable to perform webcut.\n" ); 02585 return CUBIT_FAILURE; 02586 } 02587 02588 if ( status == CUBIT_SUCCESS && intersects ) 02589 { 02590 instance()->get_gqe()->delete_solid_model_entities(body_sm); 02591 } 02592 else 02593 { 02594 PRINT_INFO("INFO: Cutting Tool overlaps the original volume,\n" 02595 " Or cutting plane does not pass through volume.\n" 02596 " The original volume is unaffected.\n" ); 02597 } 02598 } 02599 02600 return status; 02601 02602 } 02603 02604 //=============================================================================== 02605 // Function : webcut_with_brick 02606 // Member Type: PUBLIC 02607 // Description: 02608 // Author : John Fowler 02609 // Date : 10/02 02610 //=============================================================================== 02611 CubitStatus FacetModifyEngine::webcut_with_brick( 02612 DLIList<BodySM*>& /*webcut_body_list*/, 02613 const CubitVector &/*center*/, 02614 const CubitVector* /*axes[3]*/, 02615 const CubitVector &/*extension*/, 02616 DLIList<BodySM*> &/*neighbor_imprint_list*/, 02617 DLIList<BodySM*> &/*results_list*/, 02618 ImprintType imprint_type, 02619 bool /*preview*/) 02620 { 02621 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02622 return CUBIT_FAILURE; 02623 } 02624 02625 //=============================================================================== 02626 // Function : webcut_with_planar_sheet 02627 // Member Type: PUBLIC 02628 // Description: 02629 // Author : John Fowler 02630 // Date : 10/02 02631 //=============================================================================== 02632 CubitStatus FacetModifyEngine::webcut_with_planar_sheet( 02633 DLIList<BodySM*>& /*webcut_body_list*/, 02634 const CubitVector &/*center*/, 02635 const CubitVector* /*axes[2]*/, 02636 double /*width*/, 02637 double /*height*/, 02638 DLIList<BodySM*> &/*neighbor_imprint_list*/, 02639 DLIList<BodySM*> &/*results_list*/, 02640 ImprintType imprint_type, 02641 bool /*preview*/) 02642 { 02643 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02644 return CUBIT_FAILURE; 02645 } 02646 02647 //=============================================================================== 02648 // Function : webcut_with_curve_loop 02649 // Member Type: PUBLIC 02650 // Description: 02651 // Author : John Fowler 02652 // Date : 10/02 02653 //=============================================================================== 02654 CubitStatus FacetModifyEngine::webcut_with_curve_loop( 02655 DLIList<BodySM*> &/*webcut_body_list*/, 02656 DLIList<Curve*> &/*ref_edge_list*/, 02657 DLIList<BodySM*> &/*neighbor_imprint_list*/, 02658 DLIList<BodySM*>& /*results_list*/, 02659 ImprintType imprint_type, 02660 bool /*preview*/) 02661 { 02662 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02663 return CUBIT_FAILURE; 02664 } 02665 02666 //=============================================================================== 02667 // Function : section 02668 // Member Type: PUBLIC 02669 // Description: 02670 // Author : John Fowler 02671 // Date : 10/02 02672 //=============================================================================== 02673 CubitStatus FacetModifyEngine::section( DLIList<BodySM*> &/*section_body_list*/, 02674 const CubitVector &/*point_1*/, 02675 const CubitVector &/*point_2*/, 02676 const CubitVector &/*point_3*/, 02677 DLIList<BodySM*>& /*new_body_list*/, 02678 bool /*keep_normal_side*/, 02679 bool /*keep_old*/, 02680 bool /*keep_both_sides*/) 02681 { 02682 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02683 return CUBIT_FAILURE; 02684 } 02685 02686 //=============================================================================== 02687 // Function : split_body 02688 // Member Type: PUBLIC 02689 // Description: Splits multiple lumps in one body into separate bodies 02690 // Author : Corey Ernst 02691 // Date : 08/04 02692 //=============================================================================== 02693 CubitStatus FacetModifyEngine::split_body( BodySM *body_ptr, 02694 DLIList<BodySM*> &new_bodies ) 02695 { 02696 MODIFY_CHECK_RETURN_FAILURE; 02697 02698 //get the all lumps of input body 02699 DLIList<Lump*> lumps; 02700 body_ptr->lumps( lumps ); 02701 02702 if( lumps.size() == 1 ) 02703 { 02704 new_bodies.append( body_ptr ); 02705 return CUBIT_SUCCESS; 02706 } 02707 02708 //for each lump except one first one, create a new body 02709 DLIList<Lump*> single_lump; 02710 lumps.reset(); 02711 lumps.step(); 02712 int i; 02713 FacetBody *tmp_facet_body = static_cast<FacetBody*>( body_ptr ); 02714 for( i=lumps.size()-1; i--; ) 02715 { 02716 BodySM *bodysm_ptr; 02717 single_lump.clean_out(); 02718 tmp_facet_body->remove_lump( static_cast<FacetLump*>(lumps.get())); 02719 single_lump.append( lumps.get_and_step() ); 02720 make_facet_body(single_lump, bodysm_ptr); 02721 if( bodysm_ptr ) 02722 new_bodies.append(bodysm_ptr); 02723 } 02724 02725 new_bodies.append( body_ptr ); 02726 02727 return CUBIT_SUCCESS; 02728 } 02729 02730 //=============================================================================== 02731 // Function : separate_surfaces 02732 // Member Type: PUBLIC 02733 // Description: Separates surfaces from sheet bodies into separate bodies. 02734 // Connected surfaces will remain connected but be placed in a new 02735 // body. NOT IMPLEMENTED 02736 // Author : 02737 // Date : 02738 //=============================================================================== 02739 CubitStatus FacetModifyEngine::separate_surfaces( DLIList<Surface*> &surf_list, 02740 DLIList<BodySM*> &new_bodies ) 02741 { 02742 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02743 return CUBIT_FAILURE; 02744 } 02745 02746 //=============================================================================== 02747 // Function : reverse_body 02748 // Member Type: PUBLIC 02749 // Description: Turn body inside-out 02750 // Author : Jason Kraftcheck 02751 // Date : 05/25/04 02752 //=============================================================================== 02753 CubitStatus FacetModifyEngine::reverse_body( BodySM* body_ptr ) 02754 { 02755 MODIFY_CHECK_RETURN_FAILURE; 02756 02757 FacetBody* body = dynamic_cast<FacetBody*>(body_ptr); 02758 if (0 == body) 02759 { 02760 PRINT_ERROR("Non-facet body in FME::reverse.\n"); 02761 return CUBIT_FAILURE; 02762 } 02763 02764 // Flip CoFace senses 02765 DLIList<FacetShell*> shells; 02766 body->get_shells( shells ); 02767 while (shells.size()) 02768 shells.pop()->reverse(); 02769 02770 return CUBIT_SUCCESS; 02771 } 02772 02773 02774 02775 //=============================================================================== 02776 // Function : split_periodic 02777 // Member Type: PUBLIC 02778 // Description: 02779 // Author : John Fowler 02780 // Date : 10/02 02781 //=============================================================================== 02782 CubitStatus FacetModifyEngine::split_periodic( BodySM * /*body_ptr*/, 02783 BodySM *& /*new_body*/ ) 02784 { 02785 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02786 return CUBIT_FAILURE; 02787 } 02788 02789 //=============================================================================== 02790 // Function : regularize_body 02791 // Member Type: PUBLIC 02792 // Description: 02793 // Author : John Fowler 02794 // Date : 10/02 02795 //=============================================================================== 02796 CubitStatus FacetModifyEngine::regularize_body( BodySM * /*body_ptr*/, 02797 BodySM *& /*new_body_ptr*/ ) 02798 { 02799 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02800 return CUBIT_FAILURE; 02801 } 02802 02803 //=============================================================================== 02804 // Function : regularize_refentity 02805 // Member Type: PUBLIC 02806 // Description: 02807 // Author : John Fowler 02808 // Date : 10/02 02809 //=============================================================================== 02810 CubitStatus FacetModifyEngine::regularize_entity( GeometryEntity * /*old_entity_ptr*/, 02811 BodySM *& /*new_body_ptr*/) 02812 { 02813 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02814 return CUBIT_FAILURE; 02815 } 02816 02817 CubitStatus FacetModifyEngine::test_regularize_entity( GeometryEntity *) 02818 { 02819 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02820 return CUBIT_FAILURE; 02821 } 02822 02823 //=============================================================================== 02824 // Function : offset_curves 02825 // Member Type: PUBLIC 02826 // Description: 02827 // Author : John Fowler 02828 // Date : 10/02 02829 //=============================================================================== 02830 CubitStatus FacetModifyEngine::offset_curves( DLIList<Curve*>& /*ref_edge_list*/, 02831 DLIList<Curve*>&, 02832 double /*offset_distance*/, 02833 const CubitVector& /*offset_direction*/, 02834 int /*gap_type*/ ) 02835 { 02836 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02837 return CUBIT_FAILURE; 02838 } 02839 02840 //=============================================================================== 02841 // Function : split_curve 02842 // Member Type: PUBLIC 02843 // Description: 02844 // Author : Alex Hays 02845 // Date : 9/08 02846 //=============================================================================== 02847 CubitStatus FacetModifyEngine::split_curve( Curve* curve_to_split, 02848 const CubitVector& split_location, 02849 DLIList<Curve*>& created_curves ) 02850 { 02851 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02852 return CUBIT_FAILURE; 02853 } 02854 02855 //=============================================================================== 02856 // Function : trim_curve 02857 // Member Type: PUBLIC 02858 // Description: 02859 // Author : John Fowler 02860 // Date : 10/02 02861 //=============================================================================== 02862 Curve* FacetModifyEngine::trim_curve( Curve* /*trim_curve*/, 02863 const CubitVector& /*trim_vector*/, 02864 const CubitVector& /*keep_vector*/, 02865 bool ) 02866 { 02867 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 02868 return 0; 02869 } 02870 02871 //=============================================================================== 02872 // Function : create_solid_bodies_from_surfs 02873 // Member Type: PUBLIC 02874 // Description: 02875 // Author : Steve Owen 02876 // Date : 9/11/03 02877 //=============================================================================== 02878 CubitStatus FacetModifyEngine::create_solid_bodies_from_surfs(DLIList<Surface*> & ref_face_list, 02879 DLIList<BodySM*> &new_bodies, 02880 bool keep_old, 02881 bool heal, 02882 bool sheet ) const 02883 { 02884 //MODIFY_CHECK_RETURN_FAILURE; 02885 02886 // get the facets from the faces 02887 02888 int ii; 02889 Surface *surf_ptr; 02890 FacetSurface *fsurf_ptr; 02891 DLIList<CubitFacet *> facet_list; 02892 DLIList<CubitPoint *> point_list; 02893 02894 if (heal) 02895 { 02896 PRINT_WARNING("\"heal\" option for facet-based geometry is not supported.\n"); 02897 } 02898 02899 ref_face_list.reset(); 02900 for(ii=0; ii<ref_face_list.size(); ii++) 02901 { 02902 surf_ptr = ref_face_list.get_and_step(); 02903 fsurf_ptr = dynamic_cast<FacetSurface *>(surf_ptr); 02904 assert(fsurf_ptr != NULL); 02905 if (fsurf_ptr == NULL) 02906 return CUBIT_FAILURE; 02907 point_list.clean_out(); 02908 fsurf_ptr->get_my_facets( facet_list, point_list ); 02909 } 02910 02911 // copy the facets 02912 02913 DLIList<CubitFacet *> new_facet_list; 02914 DLIList<CubitPoint *> new_point_list; 02915 DLIList<CubitFacetEdge *> new_edge_list; 02916 FacetDataUtil::copy_facets( facet_list, new_facet_list, new_point_list, new_edge_list ); 02917 02918 // generate new geometry 02919 02920 const char *file_name = NULL; 02921 CubitBoolean use_feature_angle = CUBIT_FALSE; 02922 double feature_angle = 0.0; 02923 int interp_order = 0; 02924 double tol=0.0; 02925 CubitBoolean smooth_non_manifold = CUBIT_FALSE; 02926 CubitBoolean split_surfaces = CUBIT_FALSE; 02927 CubitBoolean stitch = CUBIT_TRUE; 02928 CubitBoolean improve = CUBIT_TRUE; 02929 DLIList <CubitQuadFacet *> quad_facet_list; 02930 DLIList<Surface *> surface_list; 02931 FacetFileFormat file_format = FROM_FACET_LIST; 02932 CubitStatus rv = 02933 FacetQueryEngine::instance()->import_facets( file_name, 02934 use_feature_angle, 02935 feature_angle, 02936 tol, 02937 interp_order, 02938 smooth_non_manifold, 02939 split_surfaces, 02940 stitch, 02941 improve, 02942 quad_facet_list, 02943 new_facet_list, 02944 surface_list, 02945 file_format ); 02946 02947 BodySM *new_body = NULL; 02948 if (rv == CUBIT_SUCCESS) 02949 { 02950 surf_ptr = surface_list.get(); 02951 new_body = surf_ptr->bodysm(); 02952 02953 if( sheet == false ) 02954 { 02955 CubitVector centroid; 02956 double volume = 0.0; 02957 new_body->mass_properties( centroid, volume); 02958 if( volume <= 0.0 ) 02959 { 02960 FacetQueryEngine::instance()->delete_solid_model_entities(new_body); 02961 PRINT_INFO("Failing...Resulting body has no volume.\n"); 02962 return CUBIT_FAILURE; 02963 } 02964 } 02965 02966 // delete the old model 02967 02968 if (!keep_old) 02969 { 02970 DLIList<BodySM*> mybody_list; 02971 DLIList<BodySM*> body_list; 02972 for(ii=0; ii<ref_face_list.size(); ii++) 02973 { 02974 mybody_list.clean_out(); 02975 surf_ptr = ref_face_list.get_and_step(); 02976 surf_ptr->bodysms(mybody_list); 02977 if (mybody_list.size() == 1) 02978 { 02979 body_list.append_unique( mybody_list.get() ); 02980 } 02981 } 02982 if (body_list.size() > 0) 02983 { 02984 FacetQueryEngine::instance()->delete_solid_model_entities(body_list); 02985 //GeometryQueryTool::instance()->delete_Body( body_list ); 02986 } 02987 } 02988 } 02989 else 02990 { 02991 new_body = NULL; 02992 } 02993 02994 if( new_body ) 02995 new_bodies.append( new_body ); 02996 02997 return CUBIT_SUCCESS; 02998 } 02999 03000 03001 //=============================================================================== 03002 // Function : create_circle 03003 // Member Type: PUBLIC 03004 // Description: 03005 // Author : Corey McBride 03006 // Date : 1/11 03007 //=============================================================================== 03008 Curve* FacetModifyEngine::create_arc(const CubitVector& position, 03009 double radius, 03010 double start_angle, 03011 double end_angle, 03012 CubitVector plane, 03013 bool preview ) 03014 { 03015 MODIFY_CHECK_RETURN_NULL; 03016 03017 return NULL; 03018 03019 } 03020 //=============================================================================== 03021 // Function : create_circle 03022 // Member Type: PUBLIC 03023 // Description: 03024 // Author : Corey McBride 03025 // Date : 4/11 03026 //=============================================================================== 03027 Curve* FacetModifyEngine::create_arc_radius(const CubitVector ¢er, 03028 TBPoint* ref_vertex_start, 03029 TBPoint* ref_vertex_end, 03030 const CubitVector &normal, 03031 double radius, 03032 bool full, 03033 bool preview) 03034 { 03035 MODIFY_CHECK_RETURN_NULL; 03036 03037 return NULL; 03038 03039 } 03040 03041 //=============================================================================== 03042 // Function : create_arc_three 03043 // Member Type: PUBLIC 03044 // Description: 03045 // Author : John Fowler 03046 // Date : 10/02 03047 //=============================================================================== 03048 Curve* FacetModifyEngine::create_arc_three( TBPoint* /*ref_vertex1*/, 03049 TBPoint* /*ref_vertex2*/, 03050 TBPoint* /*ref_vertex3*/, 03051 bool /*full*/, 03052 bool /*preview*/ ) 03053 { 03054 MODIFY_CHECK_RETURN_NULL; 03055 03056 return NULL; 03057 03058 } 03059 03060 //=============================================================================== 03061 // Function : create_arc_three 03062 // Member Type: PUBLIC 03063 // Description: 03064 // Author : John Fowler 03065 // Date : 10/02 03066 //=============================================================================== 03067 Curve* FacetModifyEngine::create_arc_three( Curve* /*ref_edge1*/, 03068 Curve* /*ref_edge2*/, 03069 Curve* /*ref_edge3*/, 03070 bool /*full*/, 03071 bool /*preview*/ ) 03072 { 03073 MODIFY_CHECK_RETURN_NULL; 03074 03075 return NULL; 03076 } 03077 03078 //=============================================================================== 03079 // Function : create_arc_center_edge 03080 // Member Type: PUBLIC 03081 // Description: 03082 // Author : John Fowler 03083 // Date : 10/02 03084 //=============================================================================== 03085 Curve* FacetModifyEngine::create_arc_center_edge( TBPoint* /*ref_vertex1*/, 03086 TBPoint* /*ref_vertex2*/, 03087 TBPoint* /*ref_vertex3*/, 03088 const CubitVector& /*normal*/, 03089 double /*radius*/, 03090 bool /*full*/, 03091 bool /*preview*/ ) 03092 { 03093 MODIFY_CHECK_RETURN_NULL; 03094 03095 return NULL; 03096 } 03097 03098 CubitStatus 03099 FacetModifyEngine::create_curve_combine( DLIList<Curve*>& curve_list, 03100 Curve *&new_curve_ptr ) 03101 { 03102 PRINT_ERROR("Curve combine is not implemented for facet based models\n"); 03103 return CUBIT_FAILURE; 03104 } 03105 03106 //=============================================================================== 03107 // Function : get_gqe 03108 // Member Type: PUBLIC 03109 // Description: get the facet geometry query engince instance pointer 03110 // Author : John Fowler 03111 // Date : 10/02 03112 //=============================================================================== 03113 GeometryQueryEngine *FacetModifyEngine::get_gqe() 03114 { 03115 return FacetQueryEngine::instance(); 03116 } 03117 03118 //=============================================================================== 03119 // Function : is_modify_engine 03120 // Member Type: PUBLIC 03121 // Description: return CUBIT_TRUE if the tb_ptr belongs to this modify engine 03122 // Author : John Fowler 03123 // Date : 10/02 03124 //=============================================================================== 03125 CubitBoolean FacetModifyEngine::is_modify_engine(const TopologyBridge *tb_ptr) const 03126 { 03127 return tb_ptr->get_geometry_query_engine() == FacetQueryEngine::instance(); 03128 } 03129 03130 //=============================================================================== 03131 // Function : get_offset_intersections 03132 // Member Type: PUBLIC 03133 // Description: 03134 // Author : John Fowler 03135 // Date : 10/02 03136 //=============================================================================== 03137 CubitStatus FacetModifyEngine::get_offset_intersections( Curve* /*ref_edge1*/, 03138 Curve* /*ref_edge2*/, 03139 DLIList<CubitVector>& /*intersection_list*/, 03140 double /*offset*/, 03141 CubitBoolean /*ext_first*/ ) 03142 { 03143 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03144 return CUBIT_FAILURE; 03145 } 03146 03147 //=============================================================================== 03148 // Function : get_offset_intersections 03149 // Member Type: PUBLIC 03150 // Description: 03151 // Author : John Fowler 03152 // Date : 10/02 03153 //=============================================================================== 03154 CubitStatus FacetModifyEngine::get_offset_intersections( Curve* /*ref_edge_ptr*/, 03155 Surface* /*ref_face_ptr*/, 03156 DLIList<CubitVector> & /*intersection_list*/, 03157 double /*offset*/, 03158 CubitBoolean /*ext_surf*/ ) 03159 { 03160 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03161 return CUBIT_FAILURE; 03162 } 03163 03164 //=============================================================================== 03165 // Function : surface_intersection 03166 // Member Type: PUBLIC 03167 // Description: 03168 // Author : John Fowler 03169 // Date : 10/02 03170 //=============================================================================== 03171 CubitStatus FacetModifyEngine::surface_intersection( Surface * /*surface1_ptr*/, 03172 Surface * /*surface2_ptr*/, 03173 DLIList<Curve*> &/*inter_graph*/, 03174 const double /*tol*/) const 03175 { 03176 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03177 return CUBIT_FAILURE; 03178 } 03179 03180 //=============================================================================== 03181 // Function : get_mid_plane 03182 // Member Type: PUBLIC 03183 // Description: 03184 // Author : John Fowler 03185 // Date : 10/02 03186 //=============================================================================== 03187 CubitStatus FacetModifyEngine::get_mid_plane( const CubitVector & /*point_1*/, 03188 const CubitVector & /*point_2*/, 03189 const CubitVector & /*point_3*/, 03190 BodySM * /*body_to_trim_to*/, 03191 BodySM *& /*midplane_body*/ ) const 03192 { 03193 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03194 return CUBIT_FAILURE; 03195 } 03196 03197 //=============================================================================== 03198 // Function : get_quadric_mid_surface 03199 // Member Type: PUBLIC 03200 // Description: 03201 // Author : Philippe Pebay 03202 // Date : 03/06 03203 //=============================================================================== 03204 CubitStatus FacetModifyEngine::get_spheric_mid_surface( Surface* surface_ptr1, 03205 Surface* surface_ptr2, 03206 BodySM* body_to_trim_to, 03207 BodySM*& midsurface_body ) const 03208 { 03209 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03210 return CUBIT_FAILURE; 03211 } 03212 03213 //=============================================================================== 03214 // Function : get_quadric_mid_surface 03215 // Member Type: PUBLIC 03216 // Description: 03217 // Author : Philippe Pebay 03218 // Date : 03/06 03219 //=============================================================================== 03220 CubitStatus FacetModifyEngine::get_conic_mid_surface( Surface* surface_ptr1, 03221 Surface* surface_ptr2, 03222 BodySM* body_to_trim_to, 03223 BodySM*& midsurface_body ) const 03224 { 03225 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03226 return CUBIT_FAILURE; 03227 } 03228 03229 //=============================================================================== 03230 // Function : get_quadric_mid_surface 03231 // Member Type: PUBLIC 03232 // Description: 03233 // Author : Philippe Pebay 03234 // Date : 03/06 03235 //=============================================================================== 03236 CubitStatus FacetModifyEngine::get_toric_mid_surface( Surface* surface_ptr1, 03237 Surface* surface_ptr2, 03238 BodySM* body_to_trim_to, 03239 BodySM*& midsurface_body ) const 03240 { 03241 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03242 return CUBIT_FAILURE; 03243 } 03244 03245 //============================================================================= 03246 // Function : tweak_bend 03247 // Member Type: PUBLIC 03248 // Description: Bend solid bodies based on a bend radius and angle 03249 // Author : 03250 // Date : 03251 //============================================================================= 03252 CubitStatus FacetModifyEngine::tweak_bend(DLIList<BodySM*>& bend_bodies, 03253 DLIList<BodySM*>& new_bodysm_list, 03254 CubitVector& neutral_root, 03255 CubitVector& bend_axis, 03256 CubitVector& bend_direction, 03257 double radius, 03258 double angle, 03259 DLIList<CubitVector> &bend_regions, 03260 double width, 03261 CubitBoolean center_bend, 03262 int num_points, 03263 CubitBoolean keep_old_body, 03264 CubitBoolean preview ) const 03265 { 03266 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03267 return CUBIT_FAILURE; 03268 } 03269 03270 //============================================================================= 03271 // Function : tweak_chamfer 03272 // Member Type: PUBLIC 03273 // Description: Chamfer curves on solid bodies. The left and right offsets are 03274 // with respect to the curve direction. If the given right offset 03275 // is negative, the left offset is used. Users can preview to 03276 // clarify the meaning of left and right. 03277 // Author : 03278 // Date : 03279 //============================================================================= 03280 CubitStatus FacetModifyEngine::tweak_chamfer( DLIList<Curve*> & /*curve_list*/, 03281 double /*left_offset*/, 03282 DLIList<BodySM*> & /*new_bodysm_list*/, 03283 double /*right_offset*/, 03284 CubitBoolean /*keep_old_body*/, 03285 CubitBoolean /*preview*/ ) const 03286 { 03287 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03288 return CUBIT_FAILURE; 03289 } 03290 03291 //============================================================================= 03292 // Function : tweak_chamfer 03293 // Member Type: PUBLIC 03294 // Description: Chamfer vertices on solid or sheet bodies. On a solid body 03295 // there can be up to 3 offsets; on a sheet body up to 2 offsets. 03296 // The offsets are in the direction of the supplied edges. If 03297 // multiple vertices are supplied, only one offset value is 03298 // allowed and the edges are not used. 03299 // Author : 03300 // Date : 03301 //============================================================================= 03302 CubitStatus 03303 FacetModifyEngine::tweak_chamfer( DLIList<TBPoint*> & /*point_list*/, 03304 double /*offset1*/, 03305 DLIList<BodySM*> & /*new_bodysm_list*/, 03306 Curve * /*edge1*/, 03307 double /*offset2*/, 03308 Curve * /*edge2*/, 03309 double /*offset3*/, 03310 Curve * /*edge3*/, 03311 CubitBoolean /*keep_old_body*/, 03312 CubitBoolean /*preview*/ ) const 03313 { 03314 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03315 return CUBIT_FAILURE; 03316 } 03317 03318 //============================================================================= 03319 // Function : tweak_fillet 03320 // Member Type: PUBLIC 03321 // Description: Create a round fillet (or blend) at the given curves on solid 03322 // bodies. 03323 // Author : 03324 // Date : 03325 //============================================================================= 03326 CubitStatus FacetModifyEngine::tweak_fillet( DLIList<Curve*> & /*curve_list*/, 03327 double /*radius*/, 03328 DLIList<BodySM*> & /*new_bodysm_list*/, 03329 CubitBoolean /*keep_old_body*/, 03330 CubitBoolean /*preview*/ ) const 03331 { 03332 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03333 return CUBIT_FAILURE; 03334 } 03335 03336 //============================================================================= 03337 // Function : tweak_fillet 03338 // Member Type: PUBLIC 03339 // Description: Create a round fillet (or blend) at the given curves on a solid 03340 // body. The fillet has a variable radius from the start to the 03341 // end of the curve. 03342 // Author : 03343 // Date : 03344 //============================================================================= 03345 CubitStatus FacetModifyEngine::tweak_fillet( Curve * /*curve_ptr*/, 03346 double /*start_radius*/, 03347 double /*end_radius*/, 03348 BodySM *& /*new_bodysm_ptr*/, 03349 CubitBoolean /*keep_old_body*/, 03350 CubitBoolean /*preview*/ ) const 03351 { 03352 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03353 return CUBIT_FAILURE; 03354 } 03355 03356 //============================================================================= 03357 // Function : tweak_fillet 03358 // Member Type: PUBLIC 03359 // Description: Create a round fillet (or blend) at the given vertices on sheet 03360 // bodies. 03361 // Author : 03362 // Date : 03363 //============================================================================= 03364 CubitStatus 03365 FacetModifyEngine::tweak_fillet( DLIList<TBPoint*> & /*ref_vertex_list*/, 03366 double /*radius*/, 03367 DLIList<BodySM*> & /*new_bodysm_list*/, 03368 CubitBoolean /*keep_old_body*/, 03369 CubitBoolean /*preview*/ ) const 03370 { 03371 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03372 return CUBIT_FAILURE; 03373 } 03374 03375 //============================================================================= 03376 // Function : tweak_move 03377 // Member Type: PUBLIC 03378 // Description: Tweak specified faces of a volume or volumes along a vector. 03379 // Author : 03380 // Date : 03381 //============================================================================= 03382 CubitStatus FacetModifyEngine::tweak_move( DLIList<Surface*> & /*surface_list*/, 03383 const CubitVector & /*delta*/, 03384 DLIList<BodySM*> & /*new_bodysm_list*/, 03385 CubitBoolean /*keep_old_body*/, 03386 CubitBoolean /*preview*/ ) const 03387 { 03388 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03389 return CUBIT_FAILURE; 03390 } 03391 03392 //============================================================================= 03393 // Function : tweak_move 03394 // Member Type: PUBLIC 03395 // Description: Tweak specified curves of a sheet body along a vector. 03396 // Author : 03397 // Date : 03398 //============================================================================= 03399 CubitStatus FacetModifyEngine::tweak_move( DLIList<Curve*> & /*curve_list*/, 03400 const CubitVector & /*delta*/, 03401 DLIList<BodySM*> & /*new_bodysm_list*/, 03402 CubitBoolean /*keep_old_body*/, 03403 CubitBoolean /*preview*/ ) const 03404 { 03405 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03406 return CUBIT_FAILURE; 03407 } 03408 03409 //============================================================================= 03410 // Function : tweak_offset 03411 // Member Type: PUBLIC 03412 // Description: Tweak specified faces of a volume or volumes by offsetting 03413 // those faces by the offset distance. 03414 // Author : 03415 // Date : 03416 //============================================================================= 03417 CubitStatus FacetModifyEngine::tweak_offset( DLIList<Surface*> & /*surface_list*/, 03418 double /*offset_distance*/, 03419 DLIList<Surface*> * /*add_surface_list_ptr*/, 03420 DLIList<double> * /*add_offset_list_ptr*/, 03421 DLIList<BodySM*> & /*new_bodysm_list*/, 03422 CubitBoolean /*keep_old_body*/, 03423 CubitBoolean /*preview*/ ) const 03424 { 03425 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03426 return CUBIT_FAILURE; 03427 } 03428 03429 //============================================================================= 03430 // Function : tweak_offset 03431 // Member Type: PUBLIC 03432 // Description: Tweak specified curves of a sheet body or bodies by offsetting 03433 // those curves by the offset distance. 03434 // Author : 03435 // Date : 03436 //============================================================================= 03437 CubitStatus FacetModifyEngine::tweak_offset( DLIList<Curve*> & /*curve_list*/, 03438 double /*offset_distance*/, 03439 DLIList<Curve*> * /*add_curve_list_ptr*/, 03440 DLIList<double> * /*add_offset_list_ptr*/, 03441 DLIList<BodySM*> & /*new_bodysm_list*/, 03442 CubitBoolean /*keep_old_body*/, 03443 CubitBoolean /*preview*/ ) const 03444 { 03445 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03446 return CUBIT_FAILURE; 03447 } 03448 03449 //============================================================================= 03450 // Function : tweak_remove 03451 // Member Type: PUBLIC 03452 // Description: Function to remove surfaces from a body and then extend the 03453 // remaining surfaces to fill the gap or hole. 03454 // Author : 03455 // Date : 03456 //============================================================================= 03457 CubitStatus FacetModifyEngine::tweak_remove( DLIList<Surface*> & /*surface_list*/, 03458 DLIList<BodySM*> & /*new_bodysm_list*/, 03459 CubitBoolean /*extend_adjoining*/, 03460 CubitBoolean /*keep_old_body*/, 03461 CubitBoolean /*preview*/ ) const 03462 { 03463 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03464 return CUBIT_FAILURE; 03465 } 03466 03467 //============================================================================= 03468 // Function : tweak_remove 03469 // Member Type: PUBLIC 03470 // Description: Function to remove curves from a sheet body and then extend the 03471 // remaining curves or fill the gap or hole. 03472 // Author : 03473 // Date : 03474 //============================================================================= 03475 CubitStatus FacetModifyEngine::tweak_remove( DLIList<Curve*> & /*curve_list*/, 03476 DLIList<BodySM*> & /*new_bodysm_list*/, 03477 CubitBoolean /*keep_old_body*/, 03478 CubitBoolean /*preview*/ ) const 03479 { 03480 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03481 return CUBIT_FAILURE; 03482 } 03483 03484 //============================================================================= 03485 // Function : tweak_target 03486 // Member Type: PUBLIC 03487 // Description: Tweak specified faces of a volume or volumes up to a set of 03488 // target surfaces. 03489 // Author : 03490 // Date : 03491 //============================================================================= 03492 CubitStatus FacetModifyEngine::tweak_target( DLIList<Surface*> & /*surface_list*/, 03493 DLIList<Surface*> & /*target_surf_list*/, 03494 DLIList<BodySM*> & /*new_bodysm_list*/, 03495 CubitBoolean /*extend_flg*/, 03496 CubitPlane * /*limit_plane*/, 03497 CubitBoolean /*reverse_flg*/, 03498 CubitBoolean /*keep_old_body*/, 03499 CubitBoolean /*preview*/ ) const 03500 { 03501 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03502 return CUBIT_FAILURE; 03503 } 03504 03505 //============================================================================= 03506 // Function : tweak_target 03507 // Member Type: PUBLIC 03508 // Description: Tweak specified edges of a surface or set of surfaces (in sheet 03509 // bodies) up to a set of target surfaces. 03510 // Author : 03511 // Date : 03512 //============================================================================= 03513 CubitStatus FacetModifyEngine::tweak_target( DLIList<Curve*> & /*curve_list*/, 03514 DLIList<Surface*> & /*target_surf_list*/, 03515 DLIList<BodySM*> & /*new_bodysm_list*/, 03516 CubitBoolean /*extend_flg*/, 03517 CubitPlane * /*limit_plane*/, 03518 CubitBoolean /*reverse_flg*/, 03519 CubitBoolean /*keep_old_body*/, 03520 CubitBoolean /*preview*/, 03521 double /*max_area_increase = 0*/ ) const 03522 { 03523 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03524 return CUBIT_FAILURE; 03525 } 03526 03527 //============================================================================= 03528 // Function : tweak_target 03529 // Member Type: PUBLIC 03530 // Description: Tweak specified edges of a sheet body or bodies up to a set of 03531 // target curves that is part of a sheet body. The target is a 03532 // set of surfaces created by thickening the owning surfaces of 03533 // the target curves. 03534 // Author : 03535 // Date : 03536 //============================================================================= 03537 CubitStatus FacetModifyEngine::tweak_target( DLIList<Curve*> & /*curve_list*/, 03538 DLIList<Curve*> & /*target_curve_list*/, 03539 DLIList<BodySM*> & /*new_bodysm_list*/, 03540 CubitBoolean /*extend_flg*/, 03541 CubitPlane * /*limit_plane*/, 03542 CubitBoolean /*reverse_flg*/, 03543 CubitBoolean /*keep_old_body*/, 03544 CubitBoolean /*preview*/, 03545 double /*max_area_increase = 0*/ ) const 03546 { 03547 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03548 return CUBIT_FAILURE; 03549 } 03550 03551 //============================================================================= 03552 // Function : tweak_target 03553 // Member Type: PUBLIC 03554 // Description: Tweak specified point of a sheet body to a given location. The 03555 // given point must be part of a planar surface or surfaces 03556 // attached to linear curves only. The user specified which of 03557 // those surfaces to actually modify. The given location will be 03558 // projected to be on the given planar surface(s) before being 03559 // used - this projected location must be the same on all surfaces. 03560 // Author : 03561 // Date : 03562 //============================================================================= 03563 CubitStatus FacetModifyEngine::tweak_target( TBPoint * /*point_ptr*/, 03564 DLIList<Surface*> & /*modify_surface_list*/, 03565 CubitVector & /*target_loc*/, 03566 BodySM *& /*new_bodysm_ptr*/, 03567 CubitBoolean /*keep_old_body*/, 03568 CubitBoolean /*preview*/ ) const 03569 { 03570 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03571 return CUBIT_FAILURE; 03572 } 03573 03574 CubitStatus FacetModifyEngine::remove_curve_slivers( BodySM* /*body*/, 03575 double /*lengthlimit*/ ) const 03576 { 03577 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 03578 return CUBIT_FAILURE; 03579 } 03580 03581 //================================================================================ 03582 // Description: Creates a net surface. 03583 // Author : Tyronne Lim 03584 // Date : 08/18/03 03585 //================================================================================ 03586 CubitStatus FacetModifyEngine::create_net_surface( DLIList<Surface*>& /*ref_face_list*/, 03587 BodySM *& /*new_body*/, 03588 DLIList<DLIList<CubitVector*>*> & /*vec_lists_u*/, 03589 DLIList<DLIList<CubitVector*>*> & /*vec_lists_v*/, 03590 double /*net_tol*/, 03591 CubitBoolean /*heal*/ ) const 03592 { 03593 PRINT_ERROR("Function not implemented in this engine.\n"); 03594 return CUBIT_FAILURE; 03595 } 03596 03597 //================================================================================ 03598 // Description: Creates a net surface. 03599 // Author : Tyronne Lim 03600 // Date : 08/18/03 03601 //================================================================================ 03602 CubitStatus FacetModifyEngine::create_net_surface( DLIList<Curve*>& /*u_curves*/, 03603 DLIList<Curve*>& /*v_curves*/, 03604 BodySM *& /*new_body*/, 03605 double /*net_tol*/, 03606 CubitBoolean /*heal*/ ) const 03607 { 03608 PRINT_ERROR("Function not implemented in this engine.\n"); 03609 return CUBIT_FAILURE; 03610 } 03611 03612 //================================================================================ 03613 // Description: Creates an offset surface. 03614 // Author : Tyronne Lim 03615 // Date : 08/18/03 03616 //================================================================================ 03617 CubitStatus FacetModifyEngine::create_offset_surface( Surface* /*ref_face_ptr*/, 03618 BodySM*& /*new_body*/, 03619 double /*offset_distance*/ ) const 03620 { 03621 PRINT_ERROR("Function not implemented in Facet engine.\n"); 03622 return CUBIT_FAILURE; 03623 } 03624 03625 //================================================================================ 03626 // Description: Creates an offset sheet. 03627 // Author : 03628 // Date : 03629 //================================================================================ 03630 CubitStatus 03631 FacetModifyEngine::create_offset_sheet( DLIList<Surface*> & /*surface_list*/, 03632 double /*offset_distance*/, 03633 DLIList<Surface*> * /*add_surface_list_ptr*/, 03634 DLIList<double> * /*add_offset_list_ptr*/, 03635 DLIList<BodySM*> & /*new_body_list*/, 03636 CubitBoolean /*preview*/ ) const 03637 { 03638 PRINT_ERROR("Function not implemented in Facet engine.\n"); 03639 return CUBIT_FAILURE; 03640 } 03641 03642 //================================================================================ 03643 // Description: Creates an offset body. 03644 // Author : Tyronne Lim 03645 // Date : 08/18/03 03646 //================================================================================ 03647 CubitStatus FacetModifyEngine::create_offset_body( BodySM* body_ptr, 03648 BodySM*& new_bodysm, 03649 double offset_distance ) const 03650 { 03651 return FacetModifyEngine::instance()-> 03652 create_shell_offset( body_ptr, new_bodysm, offset_distance ); 03653 } 03654 03655 //================================================================================ 03656 // Description: Creates a skin surface. 03657 // Author : Tyronne Lim 03658 // Date : 08/18/03 03659 //================================================================================ 03660 CubitStatus FacetModifyEngine::create_skin_surface( DLIList<Curve*>& /*curves*/, 03661 BodySM*& /*new_body*/, 03662 DLIList<Curve*>& /*guides*/) const 03663 { 03664 PRINT_ERROR("Function not implemented in this engine.\n"); 03665 return CUBIT_FAILURE; 03666 } 03667 03668 // 03674 CubitStatus FacetModifyEngine::loft_surfaces_to_body( DLIList<Surface*> &surfaces, 03675 DLIList<double> &takeoff_factor_list, 03676 DLIList<Surface*> &takeoff_vector_surface_list, 03677 DLIList<CubitVector> &surface_takeoff_vector_list, 03678 DLIList<Curve*> &takeoff_vector_curve_list, 03679 DLIList<CubitVector> &curve_takeoff_vector_list, 03680 DLIList<Curve*> &guides, 03681 DLIList<TBPoint*> &match_vertices_list, 03682 BodySM*& new_body, 03683 CubitBoolean global_guides, 03684 CubitBoolean closed, 03685 CubitBoolean show_matching_curves, 03686 CubitBoolean preview 03687 )const 03688 { 03689 PRINT_ERROR("Function not implemented in this engine.\n"); 03690 return CUBIT_FAILURE; 03691 } 03692 03693 03694 //================================================================================ 03695 // Description: Creates a surface. 03696 // Author : Tyronne Lim 03697 // Date : 08/18/03 03698 //================================================================================ 03699 CubitStatus FacetModifyEngine::create_surface( DLIList<CubitVector*>& /*vec_list*/, 03700 BodySM *& /*new_body*/, 03701 Surface * /*ref_face_ptr*/, 03702 CubitBoolean /*project_points*/ ) const 03703 { 03704 PRINT_ERROR("Function not implemented in this engine.\n"); 03705 return CUBIT_FAILURE; 03706 } 03707 03708 CubitStatus FacetModifyEngine::create_surface( DLIList<TBPoint*> & /*points*/, 03709 BodySM *& /*new_body*/, 03710 Surface * /*on_surface*/) const 03711 { 03712 PRINT_ERROR("Function not implemented in this engine.\n"); 03713 return CUBIT_FAILURE; 03714 } 03715 03716 //================================================================================ 03717 // Description: Creates a weld surface. 03718 // Author : Tyronne Lim 03719 // Date : 08/18/03 03720 //================================================================================ 03721 CubitStatus FacetModifyEngine::create_weld_surface( CubitVector & /*root*/, 03722 Surface * /*ref_face1*/, 03723 double /*leg1*/, 03724 Surface * /*ref_face2*/, 03725 double /*leg2*/, 03726 BodySM *& /*new_body*/ ) const 03727 { 03728 PRINT_ERROR("Function not implemented in this engine.\n"); 03729 return CUBIT_FAILURE; 03730 } 03731 03732 03733 CubitStatus FacetModifyEngine::stitch( DLIList<BodySM*> &bodies_to_stitch, 03734 DLIList<BodySM*> &new_bodies, 03735 bool tighten_gaps, 03736 double tolerance )const 03737 { 03738 PRINT_ERROR("Function not implemented in this engine.\n"); 03739 return CUBIT_FAILURE; 03740 } 03741 03742 03743 //================================================================================ 03744 // Facet-based geometry entities 03745 // Methods for building specific facet-based geometry entities 03746 //================================================================================ 03747 03748 //================================================================================ 03749 // Function : make_facet_point 03750 // Member Type: PUBLIC 03751 // Description: create a new facet point given a pointer to the 03752 // associated CubitPoint 03753 // Author : sjowen 03754 // Date : 12/28/00 03755 //================================================================================ 03756 CubitStatus FacetModifyEngine::make_facet_point( CubitPoint *thePoint, 03757 TBPoint *&new_point_ptr ) 03758 { 03759 //MODIFY_CHECK_RETURN_FAILURE; 03760 03761 //We don't know in this function what to attach it to, so do that later. 03762 DLIList<Curve*> curves; 03763 03764 FacetPoint *new_facet_point = new FacetPoint( thePoint, curves ); 03765 03766 new_point_ptr = (TBPoint*) new_facet_point; 03767 03768 return CUBIT_SUCCESS; 03769 } 03770 03771 //================================================================================ 03772 // Function : make_facet_point 03773 // Member Type: PUBLIC 03774 // Description: create a new facet point given its location 03775 // Author : sjowen 03776 // Date : 12/6/00 03777 //================================================================================ 03778 CubitStatus FacetModifyEngine::make_facet_point( const CubitVector &location, 03779 TBPoint *&new_point_ptr ) 03780 { 03781 // MODIFY_CHECK_RETURN_FAILURE; 03782 03783 //We don't know in this function what to attach it to, so do that later. 03784 DLIList<Curve*> curves; 03785 03786 FacetPoint *new_facet_point = new FacetPoint( location, curves ); 03787 03788 new_point_ptr = (TBPoint*) new_facet_point; 03789 03790 return CUBIT_SUCCESS; 03791 } 03792 03793 //================================================================================ 03794 // Function : make_facet_curve 03795 // Member Type: PUBLIC 03796 // Description: create a new facet curve 03797 // (Assumes the curve will have an associated parent surface. 03798 // Evaluations will be done on the surface -- uses the same 03799 // order evaluations as the surface) 03800 // Author : sjowen 03801 // Date : 12/6/00 03802 //================================================================================ 03803 CubitStatus FacetModifyEngine::make_facet_curve( TBPoint *start_ptr, 03804 TBPoint *end_ptr, 03805 Curve *&new_curve_ptr, 03806 CurveFacetEvalTool *eval_tool_ptr) 03807 { 03808 //MODIFY_CHECK_RETURN_FAILURE; 03809 03810 03811 //We don't know in this function what to attach it to, so do that later. 03812 DLIList<CoEdgeSM*> coedgesms; 03813 03814 FacetCurve *new_facet_curv = new FacetCurve( eval_tool_ptr, start_ptr, 03815 end_ptr, coedgesms ); 03816 new_curve_ptr = (Curve*) new_facet_curv; 03817 03818 FacetPoint *facet_start_point = CAST_TO( start_ptr, FacetPoint ); 03819 FacetPoint *facet_end_point = CAST_TO( end_ptr, FacetPoint ); 03820 facet_start_point->add_curve( new_curve_ptr ); 03821 facet_end_point->add_curve( new_curve_ptr ); 03822 03823 return CUBIT_SUCCESS; 03824 } 03825 03826 //================================================================================ 03827 // Function : make_facet_curve 03828 // Member Type: PUBLIC 03829 // Description: create a new facet curve given its edge facets 03830 // (this can be used for generating a facet curve representation 03831 // that does not have a parent surface associated -- currently 03832 // only linear evaluations are possible) 03833 // Author : sjowen 03834 // Date : 2/17/01 03835 //================================================================================ 03836 CubitStatus FacetModifyEngine::make_facet_curve( 03837 TBPoint *start_ptr, // endpoints on the curve 03838 TBPoint *end_ptr, 03839 DLIList<CubitFacetEdge*> &edge_list, // the ordered facet edges on this curve 03840 DLIList<CubitPoint*> &point_list, // the ordered points on this curve 03841 Curve *&new_curve_ptr, // return the new curve pointer 03842 CurveFacetEvalTool *curve_facet_tool ) 03843 { 03844 //MODIFY_CHECK_RETURN_FAILURE; 03845 03846 if ( curve_facet_tool == NULL ) 03847 { 03848 curve_facet_tool = new CurveFacetEvalTool; 03849 CubitStatus status = curve_facet_tool->initialize( edge_list, point_list ); 03850 if ( status != CUBIT_SUCCESS ) 03851 { 03852 return status; 03853 } 03854 } 03855 if (!curve_facet_tool) 03856 return CUBIT_FAILURE; 03857 03858 //We don't know in this function what to attach it to, so do that later. 03859 DLIList<CoEdgeSM*> coedgesms; 03860 03861 FacetCurve *new_facet_curv = new FacetCurve( curve_facet_tool, start_ptr, 03862 end_ptr, coedgesms ); 03863 new_curve_ptr = (Curve*) new_facet_curv; 03864 03865 FacetPoint *facet_start_point = CAST_TO( start_ptr, FacetPoint ); 03866 FacetPoint *facet_end_point = CAST_TO( end_ptr, FacetPoint ); 03867 facet_start_point->add_curve( new_curve_ptr ); 03868 facet_end_point->add_curve( new_curve_ptr ); 03869 03870 return CUBIT_SUCCESS; 03871 } 03872 03873 //================================================================================ 03874 // Function : make_facet_coedge 03875 // Member Type: PUBLIC 03876 // Description: create a new facet coedge 03877 // Author : sjowen 03878 // Date : 12/6/00 03879 //================================================================================ 03880 CubitStatus FacetModifyEngine::make_facet_coedge( Curve *curv_ptr, 03881 CubitSense sense, 03882 CoEdgeSM *&new_coedge_ptr ) 03883 { 03884 // MODIFY_CHECK_RETURN_FAILURE; 03885 03886 //We don't know in this function what to attach it to, so do that later. 03887 LoopSM *loop_ptr = NULL; 03888 03889 //Now create a new loop. 03890 03891 FacetCoEdge *new_facet_coedge = new FacetCoEdge(curv_ptr, loop_ptr, sense); 03892 03893 new_coedge_ptr = (CoEdgeSM*) new_facet_coedge; 03894 03895 FacetCurve *facet_curve = CAST_TO( curv_ptr, FacetCurve ); 03896 facet_curve->add_coedge( new_coedge_ptr ); 03897 03898 return CUBIT_SUCCESS; 03899 } 03900 03901 //================================================================================ 03902 // Function : make_facet_loop 03903 // Member Type: PUBLIC 03904 // Description: create a new facet loop 03905 // Author : sjowen 03906 // Date : 12/6/00 03907 //================================================================================ 03908 CubitStatus FacetModifyEngine::make_facet_loop( DLIList<CoEdgeSM*> &coedge_list, 03909 LoopSM *&new_loop_ptr ) 03910 { 03911 //MODIFY_CHECK_RETURN_FAILURE; 03912 03913 //We don't know in this function what to attach it to, so do that later. 03914 Surface *surf_ptr = NULL; 03915 03916 //Now create a new loop. 03917 03918 FacetLoop *new_facet_loop = new FacetLoop(surf_ptr, coedge_list ); 03919 03920 new_loop_ptr = (LoopSM*) new_facet_loop; 03921 int ii; 03922 for ( ii = coedge_list.size(); ii > 0; ii-- ) 03923 { 03924 CoEdgeSM* coedge_ptr = coedge_list.get_and_step(); 03925 FacetCoEdge *facet_coedge = CAST_TO(coedge_ptr, FacetCoEdge); 03926 facet_coedge->add_loop(new_loop_ptr); 03927 } 03928 return CUBIT_SUCCESS; 03929 } 03930 03931 //================================================================================ 03932 // Function : make_facet_surface 03933 // Member Type: PUBLIC 03934 // Description: create a new facet surface from Quad facets 03935 // Author : sjowen 03936 // Date : 12/6/00 03937 //================================================================================ 03938 CubitStatus FacetModifyEngine::make_facet_surface( 03939 DLIList<CubitQuadFacet*> &quad_facet_list, 03940 DLIList<CubitPoint*> &point_list, 03941 DLIList<LoopSM*> &my_loops, 03942 int interp_order, 03943 double min_dot, 03944 Surface *&new_surface_ptr) 03945 { 03946 // MODIFY_CHECK_RETURN_FAILURE; 03947 03948 CubitQuadFacet *qfacet; 03949 DLIList<CubitFacet*> facet_list; 03950 int ii; 03951 03952 quad_facet_list.reset(); 03953 for (ii=0; ii<quad_facet_list.size(); ii++) 03954 { 03955 qfacet = quad_facet_list.get_and_step(); 03956 facet_list.append( qfacet->get_tri_facet( 0 ) ); 03957 facet_list.append( qfacet->get_tri_facet( 1 ) ); 03958 } 03959 return make_facet_surface( NULL, facet_list, point_list, my_loops, 03960 interp_order, min_dot, new_surface_ptr ); 03961 } 03962 03963 //================================================================================ 03964 // Function : make_facet_surface 03965 // Member Type: PUBLIC 03966 // Description: create a new facet surface 03967 // Author : sjowen 03968 // Date : 12/6/00 03969 //================================================================================ 03970 CubitStatus FacetModifyEngine::make_facet_surface( const CubitEvaluatorData *eval_data, 03971 DLIList<CubitFacet*> &facet_list, 03972 DLIList<CubitPoint*> &point_list, 03973 DLIList<LoopSM*> &my_loops, 03974 int interp_order, 03975 double min_dot, 03976 Surface *&new_surface_ptr, 03977 CubitBoolean use_point_addresses, 03978 FacetEvalTool *facet_eval_tool, 03979 std::map<FacetCurve*, FacetCurve*> *hard_line_curve_map) 03980 { 03981 //MODIFY_CHECK_RETURN_FAILURE; 03982 03983 //Create a new surface given the facets and point list. 03984 if (facet_eval_tool == NULL) 03985 { 03986 facet_eval_tool = new FacetEvalTool(); 03987 if (CUBIT_SUCCESS != facet_eval_tool->initialize(facet_list, point_list, 03988 interp_order, min_dot ) ) 03989 { 03990 return CUBIT_FAILURE; 03991 } 03992 } 03993 03994 //We don't know in this function what to attach it to, so do that later. 03995 DLIList<ShellSM*> shellsms; 03996 FacetSurface *new_facet_surf; 03997 03998 //Now create a new surface. 03999 if ( eval_data && eval_data->ask_type() == SPHERE_SURFACE_TYPE ) 04000 { 04001 new_facet_surf = new FacetSurface( (const SphereEvaluatorData*)eval_data, 04002 facet_eval_tool, 04003 shellsms, 04004 my_loops ); 04005 } 04006 else if ( eval_data && eval_data->ask_type() == CONE_SURFACE_TYPE ) 04007 { 04008 new_facet_surf = new FacetSurface( (const CylinderEvaluatorData*)eval_data, 04009 facet_eval_tool, 04010 shellsms, 04011 my_loops ); 04012 } 04013 else 04014 { 04015 new_facet_surf = new FacetSurface( facet_eval_tool, 04016 shellsms, my_loops ); 04017 } 04018 04019 new_surface_ptr = (Surface*) new_facet_surf; 04020 int ii; 04021 for ( ii = my_loops.size(); ii > 0; ii-- ) 04022 { 04023 LoopSM* loop_ptr = my_loops.get_and_step(); 04024 FacetLoop *facet_loop = CAST_TO(loop_ptr, FacetLoop); 04025 facet_loop->add_surface(new_surface_ptr); 04026 } 04027 04028 // generate the curve facet evaluaion tools for each of the curves on this 04029 // surface - they are based on the surface evaluation tool 04030 04031 DLIList<FacetCoEdge*> coedges; 04032 new_facet_surf->get_coedges( coedges ); 04033 for (ii=0; ii<coedges.size(); ii++) 04034 { 04035 FacetCoEdge *coedgesm_ptr = coedges.get_and_step(); 04036 DLIList<FacetCurve*> curve_list; 04037 coedgesm_ptr->get_curves( curve_list ); 04038 FacetCurve *facet_curve =curve_list.get(); 04039 CurveFacetEvalTool *eval_tool = facet_curve->get_eval_tool(); 04040 if (eval_tool == NULL) 04041 { 04042 TBPoint *start_point = facet_curve->start_point(); 04043 TBPoint *end_point = facet_curve->end_point(); 04044 FacetCoEdge *facet_coedge_ptr = CAST_TO( coedgesm_ptr, FacetCoEdge ); 04045 CubitSense sense = facet_coedge_ptr->get_sense(); 04046 04047 CubitStatus status = CUBIT_SUCCESS; 04048 eval_tool = new CurveFacetEvalTool; 04049 if (!use_point_addresses) 04050 { 04051 CubitVector temp_vec1 = start_point->coordinates(); 04052 CubitVector temp_vec2 = end_point->coordinates(); 04053 04054 std::vector<CubitVector> facet_point_positions; 04055 04056 if( hard_line_curve_map ) 04057 { 04058 std::map<FacetCurve*, FacetCurve*>::iterator map_iter; 04059 map_iter = hard_line_curve_map->find( facet_curve ); 04060 if( map_iter != hard_line_curve_map->end() ) 04061 { 04062 DLIList<CubitPoint*> facet_curve_pts; 04063 map_iter->second->get_points( facet_curve_pts ); 04064 for( int k=facet_curve_pts.size(); k--; ) 04065 facet_point_positions.push_back( facet_curve_pts.get_and_step()->coordinates() ); 04066 } 04067 } 04068 04069 if( facet_point_positions.size() ) 04070 { 04071 CubitVector start = temp_vec1; 04072 if( sense != CUBIT_FORWARD ) 04073 { 04074 std::reverse( facet_point_positions.begin(), facet_point_positions.end() ); 04075 start = temp_vec2; 04076 } 04077 status = eval_tool->initialize( facet_eval_tool, 04078 start, facet_point_positions ); 04079 } 04080 else 04081 status = eval_tool->initialize( facet_eval_tool, 04082 temp_vec1, 04083 temp_vec2, 04084 sense ); 04085 if ( status != CUBIT_SUCCESS ) 04086 { 04087 delete eval_tool; 04088 return status; 04089 } 04090 } 04091 else 04092 { 04093 FacetPoint *start_facet_pt_ptr = CAST_TO( start_point, FacetPoint ); 04094 FacetPoint *end_facet_pt_ptr = CAST_TO( end_point, FacetPoint ); 04095 CubitPoint *start_pt = start_facet_pt_ptr->get_cubit_point(); 04096 CubitPoint *end_pt = end_facet_pt_ptr->get_cubit_point(); 04097 status = eval_tool->initialize( facet_eval_tool, 04098 start_pt, 04099 end_pt, 04100 sense ); 04101 if ( status != CUBIT_SUCCESS ) 04102 { 04103 delete eval_tool; 04104 return status; 04105 } 04106 } 04107 if( !eval_tool->has_good_curve_data() ) 04108 { 04109 if (facet_curve->get_eval_tool() == NULL) 04110 delete eval_tool; 04111 return CUBIT_FAILURE; 04112 } 04113 facet_curve->set_eval_tool( eval_tool ); 04114 } 04115 } 04116 return CUBIT_SUCCESS; 04117 } 04118 04119 //================================================================================ 04120 // Function : make_facet_shell 04121 // Member Type: PUBLIC 04122 // Description: create a new facet shell 04123 // Author : sjowen 04124 // Date : 12/6/00 04125 //================================================================================ 04126 CubitStatus FacetModifyEngine::make_facet_shell(DLIList<Surface*> &surface_list, 04127 ShellSM *&new_shell_ptr) 04128 { 04129 04130 //MODIFY_CHECK_RETURN_FAILURE; 04131 04132 Lump* my_lump = NULL; 04133 FacetShell *new_facet_shell = new FacetShell(my_lump, surface_list); 04134 new_shell_ptr = (ShellSM*) new_facet_shell; 04135 int ii; 04136 for ( ii = surface_list.size(); ii > 0; ii-- ) 04137 { 04138 Surface* surface_ptr = surface_list.get_and_step(); 04139 FacetSurface *facet_surface = CAST_TO(surface_ptr, FacetSurface); 04140 facet_surface->add_shell(new_shell_ptr); 04141 } 04142 return CUBIT_SUCCESS; 04143 } 04144 04145 //================================================================================ 04146 // Function : make_facet_lump 04147 // Member Type: PUBLIC 04148 // Description: create a new facet lump 04149 // Author : sjowen 04150 // Date : 12/6/00 04151 //================================================================================ 04152 CubitStatus FacetModifyEngine::make_facet_lump(DLIList<ShellSM*> &shell_list, 04153 Lump *&new_lump_ptr) 04154 { 04155 //MODIFY_CHECK_RETURN_FAILURE; 04156 04157 04158 FacetLump *new_facet_lump = new FacetLump(shell_list); 04159 new_lump_ptr = (Lump*) new_facet_lump; 04160 int ii; 04161 for ( ii = shell_list.size(); ii > 0; ii-- ) 04162 { 04163 ShellSM* shell_ptr = shell_list.get_and_step(); 04164 FacetShell *facet_shell = CAST_TO(shell_ptr, FacetShell); 04165 facet_shell->add_lump(new_lump_ptr); 04166 } 04167 return CUBIT_SUCCESS; 04168 } 04169 04170 //================================================================================ 04171 // Function : make_facet_body 04172 // Member Type: PUBLIC 04173 // Description: create a new facet body 04174 // Author : sjowen 04175 // Date : 12/6/00 04176 //================================================================================ 04177 CubitStatus FacetModifyEngine::make_facet_body(DLIList<Lump*> &lump_list, 04178 BodySM *&new_body_ptr) 04179 { 04180 04181 // MODIFY_CHECK_RETURN_FAILURE; 04182 04183 FacetBody *new_facet_body = new FacetBody(lump_list); 04184 new_body_ptr = (BodySM*) new_facet_body; 04185 //Now attach the lower entites. 04186 04187 int ii; 04188 for ( ii = lump_list.size(); ii > 0; ii-- ) 04189 { 04190 Lump* lump_ptr = lump_list.get_and_step(); 04191 FacetLump *facet_lump = CAST_TO(lump_ptr, FacetLump); 04192 facet_lump->add_body(new_body_ptr); 04193 } 04194 return CUBIT_SUCCESS; 04195 } 04196 04197 //================================================================================ 04198 // Function : build_facet_surface 04199 // Member Type: PUBLIC 04200 // Description: same as build_facet_surface below, but takes a list of quad facets 04201 // Author : sjowen 04202 // Date : 4/30/01 04203 //================================================================================ 04204 CubitStatus FacetModifyEngine::build_facet_surface( 04205 DLIList<CubitQuadFacet *> &quad_facet_list, 04206 DLIList<CubitPoint *>&point_list, // fills this in if not provided 04207 double feature_angle, 04208 int interp_order, 04209 CubitBoolean smooth_non_manifold, 04210 CubitBoolean split_surfaces, 04211 DLIList<Surface *> &surface_list) 04212 { 04213 //MODIFY_CHECK_RETURN_FAILURE; 04214 04215 CubitQuadFacet *qfacet; 04216 DLIList<CubitFacet*> facet_list; 04217 int ii; 04218 04219 quad_facet_list.reset(); 04220 for (ii=0; ii<quad_facet_list.size(); ii++) 04221 { 04222 qfacet = quad_facet_list.get_and_step(); 04223 facet_list.append( qfacet->get_tri_facet( 0 ) ); 04224 facet_list.append( qfacet->get_tri_facet( 1 ) ); 04225 } 04226 return build_facet_surface( NULL, facet_list, point_list, feature_angle, 04227 interp_order, smooth_non_manifold, 04228 split_surfaces, surface_list ); 04229 } 04230 04231 //================================================================================ 04232 // Function : build_facet_surface 04233 // Member Type: PUBLIC 04234 // Description: same as build_facet_surface below, both quad and triangle facets 04235 // Author : sjowen 04236 // Date : 4/30/01 04237 //================================================================================ 04238 CubitStatus FacetModifyEngine::build_facet_surface( 04239 DLIList<CubitQuadFacet *> &quad_facet_list, 04240 DLIList<CubitFacet *> &tri_facet_list, 04241 DLIList<CubitPoint *>&point_list, // fills this in if not provided 04242 double feature_angle, 04243 int interp_order, 04244 CubitBoolean smooth_non_manifold, 04245 CubitBoolean split_surfaces, 04246 DLIList<Surface *> &surface_list) 04247 { 04248 //MODIFY_CHECK_RETURN_FAILURE; 04249 04250 CubitStatus rv = CUBIT_SUCCESS; 04251 CubitQuadFacet *qfacet; 04252 DLIList<CubitFacet*> facet_list; 04253 int ii; 04254 quad_facet_list.reset(); 04255 for (ii=0; ii<quad_facet_list.size(); ii++) 04256 { 04257 qfacet = quad_facet_list.get_and_step(); 04258 facet_list.append( qfacet->get_tri_facet( 0 ) ); 04259 facet_list.append( qfacet->get_tri_facet( 1 ) ); 04260 } 04261 facet_list += tri_facet_list; 04262 04263 rv = build_facet_surface( NULL, facet_list, point_list, feature_angle, 04264 interp_order, smooth_non_manifold, 04265 split_surfaces, surface_list ); 04266 return rv; 04267 } 04268 04269 //================================================================================ 04270 // Function : build_cholla_surfaces 04271 // Member Type: PUBLIC 04272 // Description: create one or more surfaces from the list of facets. Also creates 04273 // the lower order entities. Generate curves (split surfaces), based 04274 // on feature angle. If feature_angle < 0 then ignore feature_angle 04275 // Note : This function is the main interface for Cubit to the Cholla library 04276 // Author : sjowen 04277 // Date : 4/26/01 04278 //================================================================================ 04279 CubitStatus FacetModifyEngine::build_cholla_surfaces 04280 ( 04281 DLIList<CubitFacet *> facet_list, 04282 DLIList<CubitPoint *> point_list, // fills this in if not provided 04283 double feature_angle, 04284 int interp_order, 04285 CubitBoolean smooth_non_manifold, 04286 CubitBoolean split_surfaces, 04287 ChollaEngine *&cholla_ptr 04288 ) 04289 { 04290 //MODIFY_CHECK_RETURN_FAILURE; 04291 04292 CubitStatus rv = CUBIT_SUCCESS; 04293 04294 // generate the edge and point lists from the facets 04295 04296 DLIList<CubitFacetEdge *> edge_list; 04297 DLIList<FacetEntity*> pe_list; 04298 DLIList<FacetEntity *> pf_list; 04299 FacetDataUtil::get_edges( facet_list, edge_list ); 04300 if (facet_list.size() > 0 && point_list.size() == 0) 04301 FacetDataUtil::get_points( facet_list, point_list ); 04302 04303 CAST_LIST( point_list, pf_list, FacetEntity ); 04304 CAST_LIST( edge_list, pe_list, FacetEntity ); 04305 04306 // create the surfaces 04307 04308 if (rv == CUBIT_SUCCESS) 04309 { 04310 DLIList<FacetEntity*> facet_entity_list; 04311 CAST_LIST( facet_list, facet_entity_list, FacetEntity ); 04312 cholla_ptr = new ChollaEngine( facet_entity_list, 04313 pe_list, pf_list ); 04314 CubitBoolean use_feature_angle; 04315 if (feature_angle < 0.0) 04316 use_feature_angle = CUBIT_FALSE; 04317 else 04318 use_feature_angle = CUBIT_TRUE; 04319 rv = cholla_ptr->create_geometry( use_feature_angle, feature_angle, 04320 interp_order, smooth_non_manifold, 04321 split_surfaces ); 04322 04323 } 04324 return rv; 04325 } 04326 //================================================================================ 04327 // Function : build_facet_surface 04328 // Member Type: PUBLIC 04329 // Description: create one or more surfaces from the list of facets. Also creates 04330 // the lower order entities. Generate curves (split surfaces), based 04331 // on feature angle. If feature_angle < 0 then ignore feature_angle 04332 // Note : This function is the main interface for Cubit to the Cholla library 04333 // Author : sjowen 04334 // Date : 4/26/01 04335 //================================================================================ 04336 CubitStatus FacetModifyEngine::build_facet_surface( 04337 const CubitEvaluatorData **eval_data, 04338 DLIList<CubitFacet *> &facet_list, 04339 DLIList<CubitPoint *> &point_list, // fills this in if not provided 04340 double feature_angle, 04341 int interp_order, 04342 CubitBoolean smooth_non_manifold, 04343 CubitBoolean split_surfaces, 04344 DLIList<Surface *> &surface_list) 04345 { 04346 // MODIFY_CHECK_RETURN_FAILURE; 04347 04348 CubitStatus rv = CUBIT_SUCCESS; 04349 04350 // generate the edge and point lists from the facets 04351 04352 DLIList<CubitFacetEdge *> edge_list; 04353 DLIList<FacetEntity*> pe_list; 04354 DLIList<FacetEntity *> pf_list; 04355 FacetDataUtil::get_edges( facet_list, edge_list ); 04356 if (point_list.size() == 0) 04357 FacetDataUtil::get_points( facet_list, point_list ); 04358 04359 CAST_LIST( point_list, pf_list, FacetEntity ); 04360 CAST_LIST( edge_list, pe_list, FacetEntity ); 04361 04362 // create the surfaces 04363 04364 if (rv == CUBIT_SUCCESS) 04365 { 04366 DLIList<FacetEntity*> facet_entity_list; 04367 CAST_LIST( facet_list, facet_entity_list, FacetEntity ); 04368 ChollaEngine *cholla_ptr = new ChollaEngine( facet_entity_list, 04369 pe_list, pf_list ); 04370 cholla_ptr->set_flip_flag(CUBIT_TRUE); 04371 CubitBoolean use_feature_angle; 04372 if (feature_angle < 0.0) 04373 use_feature_angle = CUBIT_FALSE; 04374 else 04375 use_feature_angle = CUBIT_TRUE; 04376 rv = cholla_ptr->create_geometry( use_feature_angle, feature_angle, 04377 interp_order, smooth_non_manifold, 04378 split_surfaces ); 04379 04380 // make CUBIT geometry out of the Cholla entities 04381 04382 if (rv == CUBIT_SUCCESS) 04383 { 04384 DLIList<ChollaSurface *> cholla_surface_list; 04385 cholla_ptr->get_surfaces( cholla_surface_list ); 04386 DLIList<ChollaCurve *> cholla_curve_list; 04387 cholla_ptr->get_curves( cholla_curve_list ); 04388 DLIList<ChollaPoint *> cholla_point_list; 04389 cholla_ptr->get_points( cholla_point_list ); 04390 rv = build_cholla_geometry(eval_data, cholla_surface_list, cholla_curve_list, 04391 cholla_point_list, use_feature_angle, 04392 feature_angle, interp_order, surface_list); 04393 } 04394 cholla_ptr->delete_me(); 04395 delete cholla_ptr; 04396 } 04397 return rv; 04398 } 04399 04400 //=============================================================================== 04401 // Function : build_cholla_geometry 04402 // Member Type: PRIVATE 04403 // Description: build the CUBIT geometry based on the Facet entity class lists 04404 // Author : sjowen 04405 // Date : 10/02 04406 //=============================================================================== 04407 CubitStatus FacetModifyEngine::build_cholla_geometry( 04408 const CubitEvaluatorData **eval_data, 04409 DLIList<ChollaSurface*> &cholla_surface_list, 04410 DLIList<ChollaCurve*> &cholla_curve_list, 04411 DLIList<ChollaPoint*> &cholla_point_list, 04412 CubitBoolean use_feature_angle, 04413 double feature_angle, 04414 int interp_order, 04415 DLIList<Surface *> &surface_list) 04416 { 04417 // MODIFY_CHECK_RETURN_FAILURE; 04418 04419 CubitStatus stat = CUBIT_SUCCESS; 04420 04421 //- convert feature angle to a dot product 04422 04423 double min_dot = 0.0; 04424 if (use_feature_angle) 04425 { 04426 if (feature_angle > 180.0) feature_angle = 180.0; 04427 if (feature_angle < 0.0) feature_angle = 0.0; 04428 double rad_angle = (180.0 - feature_angle) * CUBIT_PI / 180.0; 04429 min_dot = cos( rad_angle ); 04430 } 04431 04432 // build the CUBIT geometry based on Cholla entities 04433 04434 stat = build_cholla_point_geometry( cholla_point_list ); 04435 04436 if (stat == CUBIT_SUCCESS) 04437 stat = build_cholla_curve_geometry( cholla_curve_list ); 04438 04439 if (stat == CUBIT_SUCCESS) 04440 stat = build_cholla_surface_geometry( eval_data, 04441 cholla_surface_list, 04442 interp_order, min_dot, 04443 surface_list); 04444 04445 return stat; 04446 } 04447 04448 //=============================================================================== 04449 // Function : build_cholla_point_geometry 04450 // Member Type: PRIVATE 04451 // Description: From the cholla point list, create geometric points for each 04452 // Author : sjowen 04453 // Date : 10/02 04454 //=============================================================================== 04455 CubitStatus FacetModifyEngine::build_cholla_point_geometry( 04456 DLIList<ChollaPoint*> &cholla_point_list ) 04457 { 04458 // MODIFY_CHECK_RETURN_FAILURE; 04459 04460 CubitStatus stat = CUBIT_SUCCESS; 04461 int kk; 04462 //int mydebug = 0; 04463 for ( kk = cholla_point_list.size(); kk > 0; kk-- ) 04464 { 04465 ChollaPoint *chpnt_ptr = cholla_point_list.get_and_step(); 04466 TBPoint *point_ptr = (TBPoint *)chpnt_ptr->get_geometric_point(); 04467 if (point_ptr == NULL) 04468 { 04469 FacetEntity *facet_ptr = chpnt_ptr->get_facets(); 04470 CubitPoint *cp_ptr = CAST_TO( facet_ptr, CubitPoint ); 04471 TBPoint *point = NULL; 04472 stat = make_facet_point( cp_ptr, point ); 04473 if ( point == NULL || stat != CUBIT_SUCCESS ) 04474 { 04475 PRINT_ERROR("Problems building mesh based points.\n"); 04476 return stat; 04477 } 04478 point_ptr = (TBPoint *)point; 04479 chpnt_ptr->assign_geometric_point((void *)point_ptr); 04480 } 04481 } 04482 return stat; 04483 } 04484 04485 //=============================================================================== 04486 // Function : build_cholla_curve_geometry 04487 // Member Type: PRIVATE 04488 // Description: From the cholla curve list, create geometric curves for each 04489 // Author : sjowen 04490 // Date : 10/02 04491 //=============================================================================== 04492 CubitStatus FacetModifyEngine::build_cholla_curve_geometry( 04493 DLIList<ChollaCurve*> &cholla_curve_list ) 04494 { 04495 // MODIFY_CHECK_RETURN_FAILURE; 04496 04497 CubitStatus stat = CUBIT_SUCCESS; 04498 int kk; 04499 for ( kk = cholla_curve_list.size(); kk > 0; kk-- ) 04500 { 04501 ChollaCurve *chcurv_ptr = cholla_curve_list.get_and_step(); 04502 Curve *curv_ptr = (Curve *)chcurv_ptr->get_geometric_curve(); 04503 if (curv_ptr == NULL) 04504 { 04505 DLIList<ChollaPoint*> fpoint_list = chcurv_ptr->get_points( ); 04506 ChollaPoint *fpm0_ptr = fpoint_list.get_and_step(); 04507 ChollaPoint *fpm1_ptr = fpoint_list.get_and_step(); 04508 CubitPoint *start_point, *end_point; 04509 chcurv_ptr->get_ends( start_point, end_point ); 04510 assert(start_point != NULL); 04511 assert(end_point != NULL); 04512 if (fpm0_ptr->get_facets() != start_point) 04513 { 04514 ChollaPoint *temp_ptr; 04515 temp_ptr = fpm0_ptr; 04516 fpm0_ptr = fpm1_ptr; 04517 fpm1_ptr = temp_ptr; 04518 } 04519 TBPoint *start_ptr = (TBPoint *) fpm0_ptr->get_geometric_point(); 04520 TBPoint *end_ptr = (TBPoint *) fpm1_ptr->get_geometric_point(); 04521 04522 // if this is a curve without a parent surface then handle it 04523 // differently. (Curves with parents use the surface to evaluate to 04524 // With only a curve, it must evaluate to the curve) 04525 04526 DLIList<ChollaSurface*> fsm_list = chcurv_ptr->get_surfaces(); 04527 if (fsm_list.size() == 0) 04528 { 04529 DLIList<FacetEntity*> facet_list; 04530 DLIList<CubitPoint*> point_list; // needs to be filled in 04531 facet_list = chcurv_ptr->get_facet_list(); 04532 DLIList<CubitFacetEdge*> edge_list; 04533 CAST_LIST( facet_list, edge_list, CubitFacetEdge ); 04534 if (stat != CUBIT_SUCCESS) 04535 return stat; 04536 04537 // the CurveFacetEvalTool was computed in Cholla. Retreive it 04538 // and pass it to make_facet_curve so it can store it with the 04539 // new curve 04540 CurveFacetEvalTool *eval_tool_ptr = chcurv_ptr->get_eval_tool(); 04541 if (eval_tool_ptr == NULL) 04542 return CUBIT_FAILURE; 04543 stat = make_facet_curve( start_ptr, end_ptr, 04544 edge_list, point_list, 04545 curv_ptr, eval_tool_ptr ); 04546 if (stat == CUBIT_SUCCESS) 04547 { 04548 Curve *curvsm_ptr = CAST_TO( curv_ptr, Curve ); 04549 GeometryQueryTool::instance()->make_free_RefEdge( curvsm_ptr ); 04550 } 04551 } 04552 else 04553 { 04554 CurveFacetEvalTool *eval_tool_ptr = chcurv_ptr->get_eval_tool(); 04555 if (eval_tool_ptr == NULL) 04556 return CUBIT_FAILURE; 04557 stat = make_facet_curve( start_ptr, end_ptr, 04558 curv_ptr, eval_tool_ptr ); 04559 if ( curv_ptr == NULL || stat != CUBIT_SUCCESS ) 04560 { 04561 PRINT_ERROR("Problems building mesh based curves.\n"); 04562 return stat; 04563 } 04564 } 04565 chcurv_ptr->assign_geometric_curve((void *)curv_ptr); 04566 } 04567 } 04568 return stat; 04569 } 04570 04571 04572 //=============================================================================== 04573 // Function : build_cholla_loop_geometry 04574 // Member Type: PRIVATE 04575 // Description: From the cholla curve list of a surface, create geometric loops 04576 // Author : sjowen 04577 // Date : 10/02 04578 //=============================================================================== 04579 CubitStatus FacetModifyEngine::build_cholla_loop_geometry( 04580 DLIList<ChollaCurve*> &cholla_curve_list, // curves on a surface 04581 ChollaSurface *chsurf_ptr, // the surface 04582 DLIList<LoopSM*> &loop_list, // append to this loop list 04583 int debug_draw ) 04584 { 04585 //MODIFY_CHECK_RETURN_FAILURE; 04586 04587 CubitStatus stat = CUBIT_SUCCESS; 04588 04589 typedef CubitLoops<CoEdgeSM, CubitPoint>::CoEdge MyCoEdge; 04590 std::vector<MyCoEdge> coedges; 04591 04592 // loop through and build co-edges 04593 for(int i=0; i<cholla_curve_list.size(); i++) 04594 { 04595 ChollaCurve* chcurv_ptr = cholla_curve_list[i]; 04596 04597 CubitSense orientation; 04598 stat = ChollaEngine::determine_curve_orientation( chsurf_ptr, 04599 chcurv_ptr, orientation ); 04600 if(stat == CUBIT_FAILURE) 04601 return CUBIT_FAILURE; 04602 04603 CubitSense this_orientation = orientation == CUBIT_UNKNOWN ? CUBIT_FORWARD : orientation; 04604 04605 CoEdgeSM *coedge_ptr = NULL; 04606 Curve *curv_ptr = (Curve *)chcurv_ptr->get_geometric_curve(); 04607 stat = make_facet_coedge( curv_ptr, this_orientation, coedge_ptr ); 04608 if ( coedge_ptr == NULL || stat != CUBIT_SUCCESS ) 04609 { 04610 PRINT_ERROR("Problems building mesh based coedges.\n"); 04611 return stat; 04612 } 04613 04614 MyCoEdge coedge; 04615 coedge.curve = coedge_ptr; 04616 chcurv_ptr->get_ends( coedge.start, coedge.end ); 04617 coedge.sense = this_orientation; 04618 coedges.push_back(coedge); 04619 04620 if(orientation == CUBIT_UNKNOWN) 04621 { 04622 curv_ptr = (Curve *)chcurv_ptr->get_geometric_curve(); 04623 stat = make_facet_coedge( curv_ptr, CUBIT_REVERSED, coedge_ptr ); 04624 if ( coedge_ptr == NULL || stat != CUBIT_SUCCESS ) 04625 { 04626 PRINT_ERROR("Problems building mesh based coedges.\n"); 04627 return stat; 04628 } 04629 04630 coedge.curve = coedge_ptr; 04631 coedge.sense = CUBIT_REVERSED; 04632 coedges.push_back(coedge); 04633 } 04634 } 04635 04636 // compute loops from co-edges 04637 std::vector<std::vector<MyCoEdge*> > loops; 04638 CubitLoops<CoEdgeSM, CubitPoint>::make_loops(coedges, loops); 04639 04640 // build loops 04641 for(size_t i=0; i<loops.size(); i++) 04642 { 04643 DLIList<CoEdgeSM*> coedge_list; 04644 for(size_t j=0; j<loops[i].size(); j++) 04645 { 04646 coedge_list.append(loops[i][j]->curve); 04647 } 04648 LoopSM *loop_ptr = NULL; 04649 stat = make_facet_loop( coedge_list, loop_ptr ); 04650 if ( loop_ptr == NULL || stat != CUBIT_SUCCESS ) 04651 { 04652 PRINT_ERROR("Problems building mesh based loops.\n"); 04653 return stat; 04654 } 04655 loop_list.append( loop_ptr ); 04656 } 04657 04658 return stat; 04659 } 04660 04661 //=============================================================================== 04662 // Function : build_cholla_surface_geometry (PRIVATE) 04663 // Member Type: PRIVATE 04664 // Description: From the facet surface list, create geometric surface, 04665 // loops and coedges for each surface in the list 04666 // Author : sjowen 04667 // Date : 10/02 04668 //=============================================================================== 04669 CubitStatus FacetModifyEngine::build_cholla_surface_geometry( 04670 const CubitEvaluatorData **eval_data, 04671 DLIList<ChollaSurface*> &cholla_surface_list, 04672 int interp_order, 04673 double min_dot, 04674 DLIList<Surface *> &surface_list) 04675 { 04676 // MODIFY_CHECK_RETURN_FAILURE; 04677 04678 CubitStatus stat = CUBIT_SUCCESS; 04679 int ii, isurface; 04680 04681 // make sure the facet flags have been reset 04682 04683 ChollaCurve *chcurv_ptr; 04684 cholla_surface_list.reset(); 04685 for ( isurface = 0; isurface < cholla_surface_list.size(); isurface++ ) 04686 { 04687 ChollaSurface *chsurf_ptr = cholla_surface_list.get_and_step(); 04688 chsurf_ptr->reset_facet_flags(); 04689 } 04690 04691 // now loop through surfaces and create them 04692 04693 int mydebug = 0; 04694 cholla_surface_list.reset(); 04695 for ( isurface = 0; isurface < cholla_surface_list.size(); isurface++ ) 04696 { 04697 const CubitEvaluatorData *surf_eval_data = eval_data == NULL ? NULL : eval_data[isurface]; 04698 ChollaSurface *chsurf_ptr = cholla_surface_list.get_and_step(); 04699 04700 DLIList<ChollaCurve*> chcurve_list; 04701 chsurf_ptr->get_curves( chcurve_list ); 04702 04703 // init flags for curves on this surface 04704 04705 for (ii=0; ii< chcurve_list.size(); ii++) 04706 { 04707 chcurv_ptr = chcurve_list.get_and_step(); 04708 chcurv_ptr->set_flag(0); 04709 if (mydebug) 04710 { 04711 chcurv_ptr->debug_draw(); 04712 } 04713 } 04714 04715 // generate loops - keep going until we have used all the curves in the list 04716 04717 DLIList<LoopSM*> loop_list; 04718 int debug_draw = 0; 04719 stat = build_cholla_loop_geometry( chcurve_list, chsurf_ptr, 04720 loop_list, debug_draw ); 04721 if (stat != CUBIT_SUCCESS) 04722 { 04723 PRINT_ERROR("Can't build geometric loop from facets\n"); 04724 return stat; 04725 } 04726 04727 // create the surface 04728 04729 Surface *surf_ptr = (Surface *)chsurf_ptr->get_geometric_surface(); 04730 if (surf_ptr == NULL) 04731 { 04732 DLIList<FacetEntity*> facet_entity_list; 04733 DLIList<CubitPoint*> point_list; 04734 chsurf_ptr->get_points(point_list); 04735 chsurf_ptr->get_facets(facet_entity_list); 04736 DLIList<CubitFacet*> facet_list; 04737 CAST_LIST( facet_entity_list, facet_list, CubitFacet ); 04738 FacetEvalTool *eval_tool_ptr = chsurf_ptr->get_eval_tool(); 04739 if (eval_tool_ptr == NULL) 04740 return CUBIT_FAILURE; 04741 stat = make_facet_surface(surf_eval_data, facet_list,point_list,loop_list, 04742 interp_order,min_dot,surf_ptr, CUBIT_TRUE, eval_tool_ptr); 04743 if ( surf_ptr == NULL || stat != CUBIT_SUCCESS ) 04744 { 04745 PRINT_ERROR("Problems building mesh based surfaces.\n"); 04746 return stat; 04747 } 04748 chsurf_ptr->assign_geometric_surface((void *)surf_ptr); 04749 surface_list.append(surf_ptr); 04750 } 04751 } 04752 return stat; 04753 } 04754 04755 //================================================================================ 04756 // Description: improve the facets on a surface 04757 // Author : Steve Owen 04758 // Date : 8/28/2003 04759 //================================================================================ 04760 CubitStatus FacetModifyEngine::improve_facets( RefFace *ref_face_ptr ) 04761 { 04762 //MODIFY_CHECK_RETURN_FAILURE; 04763 04764 //CubitStatus rv = CUBIT_SUCCESS; 04765 04766 // This must be a facet-based surface - return now if it isn't 04767 04768 Surface *surf_ptr = ref_face_ptr->get_surface_ptr(); 04769 FacetSurface *fsurf_ptr = dynamic_cast<FacetSurface *>(surf_ptr); 04770 if (fsurf_ptr == NULL) 04771 { 04772 PRINT_ERROR("Couldn't improve facets on surface %d. It is not a facet-based geometry.\n", 04773 ref_face_ptr->id()); 04774 return CUBIT_FAILURE; 04775 } 04776 04777 CubitPoint *point_ptr; 04778 DLIList<CubitPoint *> point_list; 04779 DLIList<CubitFacet *> facet_list; 04780 DLIList<CubitFacetEdge *> edge_list; 04781 04782 // get the facets from the facet-based surface 04783 04784 fsurf_ptr->get_my_facets(facet_list, point_list); 04785 FacetDataUtil::get_edges(facet_list, edge_list); 04786 04787 // compute normals if necessary 04788 04789 int ii; 04790 for (ii=0; ii<point_list.size(); ii++) 04791 { 04792 point_ptr = point_list.get_and_step(); 04793 point_ptr->normal(); 04794 } 04795 04796 // main clean loop 04797 04798 CubitFacet *facet0, *facet1; 04799 CubitFacetData *cfacet0, *cfacet1; 04800 CubitPoint *pt0, *pt1, *pt2, *pt3; 04801 CubitFacetEdge *edge; 04802 CubitFacetEdgeData *cedge; 04803 int nflip = 0; 04804 CubitVector n0, n1, n2, n3; 04805 CubitVector c0, c1, c2, c3; 04806 double q0, q1, q2, q3; 04807 CubitVector nt0, nt1, nt2, nt3; 04808 DLIList<CubitFacet *>adj_facets; 04809 int nedges = edge_list.size(); 04810 for(ii=0; ii<nedges; ii++) 04811 { 04812 edge = edge_list.get(); 04813 04814 // can't be a feature (edge is on a curve) 04815 if(edge->is_feature()) 04816 { 04817 edge_list.step(); 04818 continue; 04819 } 04820 04821 pt0 = edge->point(0); 04822 pt1 = edge->point(1); 04823 adj_facets.clean_out(); 04824 edge->facets( adj_facets ); 04825 04826 // must be 2 adjacent facets. 04827 if (adj_facets.size() != 2) 04828 { 04829 edge_list.step(); 04830 continue; 04831 } 04832 facet0 = adj_facets.get_and_step(); 04833 facet1 = adj_facets.get(); 04834 04835 // get the adjacent vertices, make sure we are oriented correctly 04836 // - swap pt0 and pt1 if necessary 04837 pt2 = facet0->next_node(pt1); 04838 if(pt2 == pt0) 04839 { 04840 pt2 = pt0; 04841 pt0 = pt1; 04842 pt1 = pt2; 04843 pt2 = facet0->next_node(pt1); 04844 } 04845 pt3 = facet1->next_node(pt0); 04846 04847 // get the normals from the vertices 04848 n0 = pt0->normal( facet0 ); 04849 n1 = pt1->normal( facet0 ); 04850 n2 = pt2->normal( facet0 ); 04851 n3 = pt3->normal( facet1 ); 04852 c0 = pt0->coordinates(); 04853 c1 = pt1->coordinates(); 04854 c2 = pt2->coordinates(); 04855 c3 = pt3->coordinates(); 04856 04857 // compute triangle normals by averaging vertices 04858 nt0 = n0 + n1 + n2; 04859 nt0.normalize(); 04860 nt1 = n0 + n1 + n3; 04861 nt1.normalize(); 04862 nt2 = n0 + n2 + n3; 04863 nt2.normalize(); 04864 nt3 = n1 + n2 + n3; 04865 nt3.normalize(); 04866 04867 // compute quality for each of the four tris... 2 existing tris 04868 // and the two potential tris if we flip 04869 q0 = FacetDataUtil::quality(c0, c1, c2, nt0); 04870 q1 = FacetDataUtil::quality(c1, c0, c3, nt1); 04871 q2 = FacetDataUtil::quality(c0, c3, c2, nt2); 04872 q3 = FacetDataUtil::quality(c1, c2, c3, nt3); 04873 q0 = CUBIT_MIN( q0, q1 ); 04874 q2 = CUBIT_MIN( q2, q3 ); 04875 if (q2 > q0) 04876 { 04877 // flip 04878 04879 facet_list.remove( facet0 ); // these take too long - find another way to remove them 04880 facet_list.remove( facet1 ); 04881 edge_list.change_to(NULL); 04882 04883 cfacet0 = dynamic_cast<CubitFacetData *>( facet0 ); 04884 cfacet1 = dynamic_cast<CubitFacetData *>( facet1 ); 04885 cedge = dynamic_cast<CubitFacetEdgeData *>( edge ); 04886 04887 delete cfacet0; 04888 delete cfacet1; 04889 delete cedge; 04890 04891 // get edges 04892 04893 CubitFacetEdge *e[4]; 04894 e[0] = pt2->get_edge( pt0 ); 04895 e[1] = pt0->get_edge( pt3 ); 04896 e[2] = pt3->get_edge( pt1 ); 04897 e[3] = pt1->get_edge( pt2 ); 04898 cedge = new CubitFacetEdgeData( pt2, pt3 ); 04899 edge = dynamic_cast<CubitFacetEdge *>( cedge ); 04900 04901 cfacet0 = new CubitFacetData( edge, e[0], e[1] ); 04902 cfacet1 = new CubitFacetData( edge, e[2], e[3] ); 04903 facet0 = dynamic_cast<CubitFacet *>( cfacet0 ); 04904 facet1 = dynamic_cast<CubitFacet *>( cfacet1 ); 04905 04906 edge_list.append( edge ); 04907 facet_list.append( facet0 ); 04908 facet_list.append( facet1 ); 04909 04910 nflip++; 04911 } 04912 edge_list.step(); 04913 } 04914 edge_list.remove_all_with_value(NULL); 04915 assert(edge_list.size() == nedges); 04916 if (nflip > 0) 04917 { 04918 fsurf_ptr->get_eval_tool()->replace_facets(facet_list); 04919 } 04920 return CUBIT_SUCCESS; 04921 } 04922 04923 04924 //================================================================================ 04925 // Description: smooth the facets on a surface 04926 // Author : Steve Owen 04927 // Date : 8/28/2003 04928 // Note: free_laplacian = TRUE will not project the node back to a tangent plane 04929 // free_laplacian = FALSE will project to local tangent plane 04930 //================================================================================ 04931 CubitStatus FacetModifyEngine::smooth_facets( RefFace *ref_face_ptr, int niter, 04932 CubitBoolean free_laplacian ) 04933 { 04934 //MODIFY_CHECK_RETURN_FAILURE; 04935 04936 CubitStatus rv = CUBIT_SUCCESS; 04937 04938 // This must be a facet-based surface - return now if it isn't 04939 04940 Surface *surf_ptr = ref_face_ptr->get_surface_ptr(); 04941 FacetSurface *fsurf_ptr = dynamic_cast<FacetSurface *>(surf_ptr); 04942 if (fsurf_ptr == NULL) 04943 { 04944 PRINT_ERROR("Couldn't smooth facets on surface %d. It is not a facet-based geometry.\n", 04945 ref_face_ptr->id()); 04946 return CUBIT_FAILURE; 04947 } 04948 04949 CubitPoint *point_ptr; 04950 DLIList<CubitPoint *>point_list; 04951 04952 // get the points from the facet-basec surface 04953 04954 fsurf_ptr->get_my_points(point_list); 04955 04956 // compute normals if necessary 04957 04958 int ii, jj; 04959 for (ii=0; ii<point_list.size(); ii++) 04960 { 04961 point_ptr = point_list.get_and_step(); 04962 point_ptr->normal(); 04963 point_ptr->marked(0); 04964 } 04965 04966 // get the points on the facet curves associated with this surface 04967 04968 DLIList<CubitPoint *>cpoint_list; 04969 FacetCurve *fcurv_ptr; 04970 Curve *curv_ptr; 04971 04972 int idx; 04973 DLIList<Curve *> curves; 04974 fsurf_ptr->curves(curves); 04975 FacetCurve **fcurve_array = new FacetCurve * [curves.size()]; 04976 for (ii=0; ii<curves.size(); ii++) 04977 { 04978 idx = ii+1; 04979 curv_ptr = curves.get_and_step(); 04980 fcurv_ptr = dynamic_cast<FacetCurve *>(curv_ptr); 04981 if (!fcurv_ptr) 04982 { 04983 PRINT_ERROR("Couldn't smooth facets on surface %d. At least one of it curves is not a facet-based geometry.\n", 04984 ref_face_ptr->id()); 04985 return CUBIT_FAILURE; 04986 } 04987 04988 // mark the points on the curve with the index of the curve in the array 04989 // this will allow us to project the point back to the owning curve 04990 04991 cpoint_list.clean_out(); 04992 fcurv_ptr->get_points(cpoint_list); 04993 for (jj=0; jj<cpoint_list.size(); jj++) 04994 { 04995 point_ptr = cpoint_list.get_and_step(); 04996 point_ptr->marked( idx ); 04997 } 04998 fcurve_array[idx-1] = fcurv_ptr; 04999 05000 // mark the vertices with a negative value so we don't touch them 05001 05002 DLIList<TBPoint *> verts; 05003 fcurv_ptr->points(verts); 05004 for(jj=0; jj<verts.size(); jj++) 05005 { 05006 TBPoint *vert = verts.get_and_step(); 05007 FacetPoint *fvert = dynamic_cast<FacetPoint *> (vert); 05008 fvert->get_cubit_point()->marked(-1); 05009 } 05010 } 05011 05012 // laplacian smoothing 05013 05014 DLIList<CubitPoint *> adj_points; 05015 int iter, nadj; 05016 CubitPoint *adj_point_ptr; 05017 CubitVector new_location; 05018 05019 for (iter = 0; iter < niter; iter++) 05020 { 05021 for (ii=0; ii<point_list.size(); ii++) 05022 { 05023 point_ptr = point_list.get_and_step(); 05024 05025 // don't smooth points at vertices 05026 05027 if (point_ptr->marked() >= 0) 05028 { 05029 adj_points.clean_out(); 05030 point_ptr->adjacent_points( adj_points ); 05031 new_location.set(0.0, 0.0, 0.0); 05032 nadj=0; 05033 for (jj = 0; jj<adj_points.size(); jj++) 05034 { 05035 adj_point_ptr = adj_points.get_and_step(); 05036 if (point_ptr->marked()) // is on a curve 05037 { 05038 // only use points on the same curve to influence the new location 05039 if (point_ptr->marked() == adj_point_ptr->marked()) 05040 { 05041 new_location += adj_point_ptr->coordinates(); 05042 nadj++; 05043 } 05044 } 05045 05046 // interior nodes use all adjacent points 05047 else 05048 { 05049 new_location += adj_point_ptr->coordinates(); 05050 nadj++; 05051 } 05052 } 05053 new_location /= nadj; 05054 05055 // project it to a tangent plane defined at the point. 05056 // except if we are on a curve or we're using free-laplacian option 05057 if (!free_laplacian && point_ptr->marked() == 0) 05058 new_location = point_ptr->project_to_tangent_plane( new_location ); 05059 05060 // for points on a curve project to the curve definition 05061 if(point_ptr->marked() != 0) 05062 { 05063 const CubitVector temp = new_location; 05064 fcurve_array[point_ptr->marked()-1]->closest_point( temp, 05065 new_location ); 05066 } 05067 05068 if (point_ptr->check_inverted_facets(new_location) == CUBIT_SUCCESS) 05069 { 05070 point_ptr->set(new_location); 05071 } 05072 } 05073 } 05074 05075 // update the normals 05076 05077 for (ii=0; ii<point_list.size(); ii++) 05078 { 05079 point_ptr = point_list.get_and_step(); 05080 point_ptr->compute_avg_normal(); 05081 } 05082 } 05083 05084 return rv; 05085 } 05086 05087 //================================================================================ 05088 // Description: create a shell that is the normal offset of the given shell 05089 // Author : Steve Owen 05090 // Date : 8/28/2003 05091 //================================================================================ 05092 CubitStatus FacetModifyEngine::create_shell_offset( BodySM *bodysm_ptr, 05093 BodySM *&new_bodysm, double offset ) 05094 { 05095 // MODIFY_CHECK_RETURN_FAILURE; 05096 05097 // check that this is a facet body 05098 05099 FacetBody *fbody_ptr = dynamic_cast<FacetBody *>(bodysm_ptr); 05100 if (fbody_ptr == NULL) 05101 { 05102 PRINT_ERROR("Body is not a facet-based geometry. This command is intended for use with facetted models\n"); 05103 return CUBIT_FAILURE; 05104 } 05105 05106 // The facet and point lists 05107 05108 DLIList<CubitPoint *> point_list; 05109 DLIList<CubitFacet *> facet_list; 05110 05111 // get the surfaces. Check that they are also all facet bodies 05112 05113 int ii; 05114 Surface *surf_ptr; 05115 FacetSurface *fsurf_ptr; 05116 DLIList<Surface *> surface_list; 05117 fbody_ptr->surfaces( surface_list ); 05118 for (ii=0; ii<surface_list.size(); ii++) 05119 { 05120 surf_ptr = surface_list.get_and_step(); 05121 fsurf_ptr = dynamic_cast<FacetSurface *>(surf_ptr); 05122 if (fsurf_ptr == NULL) 05123 { 05124 PRINT_ERROR("At least one of the surfaces in Body is not facet-based geometry.\n" 05125 "This command is intended for use with facetted models\n"); 05126 return CUBIT_FAILURE; 05127 } 05128 fsurf_ptr->get_my_facets(facet_list, point_list); 05129 } 05130 05131 // create an array of points so we can reference them quickly when generating new facets 05132 05133 CubitPoint **points = new CubitPoint * [point_list.size()]; 05134 05135 // make a unique set of points 05136 05137 int id = 0; 05138 CubitPoint *point_ptr; 05139 for (ii=0; ii < point_list.size(); ii++) 05140 { 05141 point_list.get_and_step()->marked(1); 05142 } 05143 for (ii=0; ii<point_list.size(); ii++) 05144 { 05145 point_ptr = point_list.get_and_step(); 05146 if (point_ptr->marked() == 1) 05147 { 05148 point_ptr->marked(0); 05149 points[id] = point_ptr; 05150 point_ptr->set_id( id ); 05151 id ++; 05152 } 05153 } 05154 int npoints = id; 05155 05156 // get the curves and mark any point on a curve as non-smoothable. 05157 05158 int jj; 05159 Curve *curv_ptr; 05160 FacetCurve *fcurv_ptr; 05161 DLIList<Curve *> curve_list; 05162 fbody_ptr->curves( curve_list ); 05163 for(ii=0; ii<curve_list.size(); ii++) 05164 { 05165 curv_ptr = curve_list.get_and_step(); 05166 fcurv_ptr = dynamic_cast<FacetCurve *>(curv_ptr); 05167 if (fcurv_ptr == NULL) 05168 { 05169 PRINT_ERROR("At least one of the curves in Body is not a facet-based geometry.\n" 05170 "This command is intended for use with facetted models\n"); 05171 return CUBIT_FAILURE; 05172 } 05173 point_list.clean_out(); 05174 fcurv_ptr->get_points( point_list ); 05175 for(jj=0; jj<point_list.size(); jj++) 05176 { 05177 point_ptr = point_list.get_and_step(); 05178 point_ptr->marked(1); 05179 } 05180 } 05181 05182 // smooth the normals to reduce chance of overlap on concave regions 05183 05184 CubitVector new_normal, normal; 05185 const int niter = 3; 05186 int iter, nadj; 05187 CubitPoint *adj_point_ptr; 05188 DLIList<CubitPoint *> adj_points; 05189 05190 for (iter = 0; iter < niter; iter++) 05191 { 05192 for (ii=0; ii<npoints; ii++) 05193 { 05194 point_ptr = points[ii]; 05195 05196 // don't smooth points on curves 05197 05198 if (point_ptr->marked() != 1) 05199 { 05200 adj_points.clean_out(); 05201 point_ptr->adjacent_points( adj_points ); 05202 new_normal.set(0.0, 0.0, 0.0); 05203 nadj = adj_points.size(); 05204 for (jj = 0; jj<nadj; jj++) 05205 { 05206 adj_point_ptr = adj_points.get_and_step(); 05207 new_normal += adj_point_ptr->normal(); 05208 } 05209 new_normal.normalize(); 05210 point_ptr->normal(new_normal); 05211 } 05212 } 05213 } 05214 05215 // generate a new set of points offset from the original 05216 05217 CubitPointData *new_point; 05218 CubitVector new_location; 05219 CubitPoint **new_points = new CubitPoint * [npoints]; 05220 for (ii=0; ii<npoints; ii++) 05221 { 05222 point_ptr = points[ii]; 05223 new_location = point_ptr->coordinates() + point_ptr->normal() * offset; 05224 new_point = new CubitPointData( new_location ); 05225 new_point->set_id( ii ); 05226 new_points[ii] = (CubitPoint *) new_point; 05227 } 05228 05229 // generate triangles for the new shell 05230 05231 DLIList<CubitFacet *> fix_list; 05232 DLIList<CubitFacet *> orig_list; 05233 double dot; 05234 double mindot = 1.0; 05235 CubitFacet *facet_ptr, *new_facet_ptr; 05236 DLIList<CubitFacet *> new_facet_list; 05237 CubitPoint *p0, *p1, *p2; 05238 CubitPoint *np0, *np1, *np2; 05239 for(ii=0; ii<facet_list.size(); ii++) 05240 { 05241 facet_ptr = facet_list.get_and_step(); 05242 facet_ptr->points( p0, p1, p2 ); 05243 np0 = new_points[p0->id()]; 05244 np1 = new_points[p1->id()]; 05245 np2 = new_points[p2->id()]; 05246 new_facet_ptr = (CubitFacet *) new CubitFacetData( np0, np1, np2 ); 05247 new_facet_list.append( new_facet_ptr ); 05248 05249 // compare normals to see if we inverted anything 05250 05251 normal = facet_ptr->normal(); 05252 new_normal = new_facet_ptr->normal(); 05253 dot = normal % new_normal; 05254 if (dot < mindot) mindot = dot; 05255 if (dot < 0.707) 05256 { 05257 new_facet_ptr->marked(1); 05258 fix_list.append( new_facet_ptr ); 05259 orig_list.append( facet_ptr ); 05260 } 05261 } 05262 05263 // go back and try to uninvert tris if needed 05264 05265 int kk; 05266 DLIList<CubitFacet *> problem_list; 05267 if (fix_list.size() > 0) 05268 { 05269 new_location.set(0.0, 0.0, 0.0); 05270 for (iter = 0; iter < niter; iter++) 05271 { 05272 for (ii=0; ii<fix_list.size(); ii++) 05273 { 05274 facet_ptr = fix_list.get_and_step(); 05275 point_list.clean_out(); 05276 facet_ptr->points( point_list ); 05277 for (jj=0; jj<point_list.size(); jj++) 05278 { 05279 point_ptr = point_list.get_and_step(); 05280 05281 // don't smooth marked points 05282 05283 if (point_ptr->marked() != 1) 05284 { 05285 adj_points.clean_out(); 05286 point_ptr->adjacent_points( adj_points ); 05287 new_location.set(0.0, 0.0, 0.0); 05288 nadj = adj_points.size(); 05289 for (kk = 0; kk<nadj; kk++) 05290 { 05291 adj_point_ptr = adj_points.get_and_step(); 05292 new_location += adj_point_ptr->coordinates(); 05293 } 05294 new_location /= nadj; 05295 point_ptr->set(new_location); 05296 } 05297 } 05298 } 05299 } 05300 05301 // see if it worked 05302 05303 fix_list.reset(); 05304 orig_list.reset(); 05305 for(ii=0; ii<fix_list.size(); ii++) 05306 { 05307 new_facet_ptr = fix_list.get_and_step(); 05308 facet_ptr = orig_list.get_and_step(); 05309 new_facet_ptr->update_plane(); 05310 new_normal = new_facet_ptr->normal(); 05311 normal = facet_ptr->normal(); 05312 dot = normal % new_normal; 05313 if (dot < 0.707) 05314 { 05315 problem_list.append( new_facet_ptr ); 05316 } 05317 } 05318 } 05319 05320 // set the normals back the way they were and clean up 05321 05322 for (ii=0; ii<npoints; ii++) 05323 { 05324 point_ptr = points[ii]; 05325 point_ptr->compute_avg_normal(); 05326 } 05327 delete [] points; 05328 delete [] new_points; 05329 05330 // build the geometry 05331 05332 const char *file_name = NULL; 05333 CubitBoolean use_feature_angle = CUBIT_TRUE; 05334 double feature_angle = 0.0; 05335 int interp_order = 0; 05336 CubitBoolean smooth_non_manifold = CUBIT_TRUE; 05337 CubitBoolean split_surfaces = CUBIT_FALSE; 05338 CubitBoolean stitch = CUBIT_FALSE; 05339 CubitBoolean improve = CUBIT_FALSE; 05340 DLIList<CubitQuadFacet *> quad_facet_list; 05341 DLIList<Surface *> new_surface_list; 05342 FacetFileFormat file_format = FROM_FACET_LIST; 05343 05344 CubitStatus rv = 05345 FacetQueryEngine::instance()->import_facets( file_name, use_feature_angle, feature_angle, 0.0, 05346 interp_order, smooth_non_manifold, 05347 split_surfaces, stitch, improve, quad_facet_list, 05348 new_facet_list, new_surface_list, file_format ); 05349 05350 if(problem_list.size() > 0) 05351 { 05352 PRINT_WARNING("Offset process on facet body, may have resulted in %d overalapping facets.\n" 05353 "Check results carefully. Problem facet(s) are displayed in red.)\n", 05354 problem_list.size()); 05355 for (ii=0; ii<problem_list.size(); ii++) 05356 { 05357 facet_ptr = problem_list.get_and_step(); 05358 GfxDebug::draw_facet(facet_ptr, CUBIT_RED_INDEX); 05359 } 05360 GfxDebug::flush(); 05361 } 05362 05363 if( new_surface_list.size() ) 05364 { 05365 new_bodysm = new_surface_list.get()->bodysm(); 05366 if( !new_bodysm ) 05367 { 05368 PRINT_ERROR("Problem offsetting Body\n"); 05369 return CUBIT_FAILURE; 05370 } 05371 } 05372 else 05373 { 05374 PRINT_ERROR("Problem offsetting Body\n"); 05375 return CUBIT_FAILURE; 05376 } 05377 return rv; 05378 } 05379 05380 CubitStatus FacetModifyEngine::webcut_with_sweep_surfaces( 05381 DLIList<BodySM*> &blank_bodies, 05382 DLIList<Surface*> &surfaces, 05383 const CubitVector& sweep_vector, 05384 bool sweep_perp, 05385 bool through_all, 05386 bool outward, 05387 bool up_to_next, 05388 Surface *stop_surf, 05389 Curve *curve_to_sweep_along, 05390 DLIList<BodySM*> &/*neighbor_imprint_list*/, 05391 DLIList<BodySM*> &results_list, 05392 ImprintType imprint_type, 05393 bool /*preview*/) 05394 { 05395 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05396 return CUBIT_FAILURE; 05397 } 05398 05399 CubitStatus FacetModifyEngine::webcut_with_sweep_curves( 05400 DLIList<BodySM*> &blank_bodies, 05401 DLIList<Curve*> &curves, 05402 const CubitVector& sweep_vector, 05403 bool through_all, 05404 Surface *stop_surf, 05405 Curve *curve_to_sweep_along, 05406 DLIList<BodySM*> &/*neighbor_imprint_list*/, 05407 DLIList<BodySM*> &results_list, 05408 ImprintType imprint_type, 05409 bool /*preview*/) 05410 { 05411 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05412 return CUBIT_FAILURE; 05413 } 05414 05415 CubitStatus FacetModifyEngine::webcut_with_sweep_surfaces_rotated( 05416 DLIList<BodySM*> &blank_bodies, 05417 DLIList<Surface*> &surfaces, 05418 const CubitVector &point, 05419 const CubitVector &sweep_axis, 05420 double angle, 05421 Surface *stop_surf, 05422 bool up_to_next, 05423 DLIList<BodySM*> &/*neighbor_imprint_list*/, 05424 DLIList<BodySM*> &results_list, 05425 ImprintType imprint_type, 05426 bool /*preview*/) 05427 { 05428 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05429 return CUBIT_FAILURE; 05430 } 05431 05432 CubitStatus FacetModifyEngine::webcut_with_sweep_curves_rotated( 05433 DLIList<BodySM*> &blank_bodies, 05434 DLIList<Curve*> &curves, 05435 const CubitVector &point, 05436 const CubitVector &sweep_axis, 05437 double angle, 05438 Surface *stop_surf, 05439 DLIList<BodySM*> &/*neighbor_imprint_list*/, 05440 DLIList<BodySM*> &results_list, 05441 ImprintType imprint_type, 05442 bool /*preview*/) 05443 { 05444 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05445 return CUBIT_FAILURE; 05446 } 05447 05448 CubitStatus FacetModifyEngine::scale( BodySM *&body, const CubitVector& factors ) 05449 { 05450 return FacetQueryEngine::instance()->scale( body, factors ); 05451 } 05452 05453 CubitStatus FacetModifyEngine::tolerant_imprint( DLIList<BodySM*> &bodies_in, 05454 DLIList<BodySM*> &new_bodies, 05455 double overlap_tol, 05456 double imprint_tol, 05457 DLIList<TopologyBridge*> *new_tbs, 05458 DLIList<TopologyBridge*> *att_tbs ) const 05459 { 05460 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05461 return CUBIT_FAILURE; 05462 } 05463 05464 CubitStatus FacetModifyEngine::tolerant_imprint( DLIList<Surface*> &surfs_in, 05465 DLIList<BodySM*> &new_bodysm_list) const 05466 { 05467 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05468 return CUBIT_FAILURE; 05469 } 05470 05471 CubitStatus FacetModifyEngine::tolerant_imprint_surface_with_curves( 05472 Surface * /*surface_to_imprint*/, 05473 DLIList<Curve*> & /*curves*/, 05474 DLIList<TopologyBridge*> &temporary_bridges, 05475 BodySM *& /*new_body*/, 05476 DLIList<TopologyBridge*> *new_tbs, 05477 DLIList<TopologyBridge*> *att_tbs) const 05478 { 05479 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05480 return CUBIT_FAILURE; 05481 } 05482 05483 CubitStatus FacetModifyEngine::curve_surface_intersection( Surface * /*surface*/, 05484 Curve* /*curve*/, 05485 DLIList<Curve*> &/*new_curves*/ ) const 05486 { 05487 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05488 return CUBIT_FAILURE; 05489 } 05490 05491 BodySM* FacetModifyEngine::create_body( VolumeFacets& volume, std::map<FacetShapes*, GeometryEntity*>& entity_map, 05492 const FacetPointSet& points, int interp_order) const 05493 { 05494 FacetModifyEngine* self = const_cast<FacetModifyEngine*>(this); 05495 05496 // loop and make points 05497 size_t num_points = points.size() / 3; 05498 DLIList<CubitPoint*> cubit_points(num_points); 05499 05500 std::map<SurfaceFacets*, DLIList<CubitFacet*> > facet_map; 05501 std::map<CurveFacets*, DLIList<CubitFacetEdge*> > facet_edge_map; 05502 05503 // create facets (all facets must be created first so facet edges between surfaces are set up properly) 05504 self->create_facets(volume.surfaceTopology, points, interp_order, cubit_points, facet_map, facet_edge_map); 05505 05506 // now create the topology on top of the facets that were created 05507 DLIList<Surface*> surface_list; 05508 DLIList<CubitSense> surface_sense_list; 05509 for(size_t i=0; i<volume.surfaceTopology.size(); i++) 05510 { 05511 SurfaceFacets* surf = volume.surfaceTopology[i].first; 05512 CubitSense sense = volume.surfaceTopology[i].second; 05513 if ( CUBIT_SUCCESS != self->process_topology(surf, sense, interp_order, cubit_points, facet_map, facet_edge_map, entity_map) ) 05514 return NULL; 05515 surface_list.append((Surface*)entity_map[surf]); 05516 surface_sense_list.append(sense); 05517 } 05518 05519 // finish creation of body from list of surfaces (shell, lump, etc...) 05520 BodySM *body_ptr = NULL; 05521 finish_facet_Body(surface_list, surface_sense_list, body_ptr); 05522 entity_map[&volume] = body_ptr->lump(); 05523 return body_ptr; 05524 } 05525 05526 #ifdef KCM_MESH_TO_GEOM 05527 CubitStatus FacetModifyEngine::mesh2brep(std::vector<double> &xvals, 05528 std::vector<double> &yvals, 05529 std::vector<double> &zvals, 05530 std::vector<unsigned int> &tri_connectivity, 05531 DLIList<BodySM*> &new_body_sms) const 05532 { 05533 PRINT_ERROR("Option not supported for mesh based geometry.\n"); 05534 return CUBIT_FAILURE; 05535 } 05536 #endif 05537 05538 void FacetModifyEngine::create_facets( 05539 const std::vector<std::pair<SurfaceFacets*, CubitSense> >& surfaceTopology, 05540 const FacetPointSet& points, 05541 int interp_order, 05542 DLIList<CubitPoint*>& cubit_points, 05543 std::map<SurfaceFacets*, DLIList<CubitFacet*> >& facet_map, 05544 std::map<CurveFacets*, DLIList<CubitFacetEdge*> >& facet_edge_map) 05545 { 05546 // loop and make points 05547 size_t num_points = points.size() / 3; 05548 for(size_t i=0; i<num_points; i++) 05549 { 05550 cubit_points.append(new CubitPointData(CubitVector(points[i*3], points[i*3+1], points[i*3+2]))); 05551 } 05552 05553 DLIList<CubitFacet*> all_facets; 05554 05555 // process facets for each surface 05556 for(size_t i=0; i<surfaceTopology.size(); i++) 05557 { 05558 CubitSense coface_sense = surfaceTopology[i].second; 05559 SurfaceFacets* surface = surfaceTopology[i].first; 05560 05561 DLIList<CubitFacet*> surface_facets; 05562 05563 for(size_t j=0; j<surface->facetConnectivity.size(); j+=3) 05564 { 05565 CubitFacetData* cfe; 05566 if(coface_sense == CUBIT_REVERSED) 05567 { 05568 cfe = new CubitFacetData( 05569 cubit_points[surface->facetConnectivity[j]], 05570 cubit_points[surface->facetConnectivity[j+2]], 05571 cubit_points[surface->facetConnectivity[j+1]]); 05572 } 05573 else 05574 { 05575 cfe = new CubitFacetData( 05576 cubit_points[surface->facetConnectivity[j]], 05577 cubit_points[surface->facetConnectivity[j+1]], 05578 cubit_points[surface->facetConnectivity[j+2]]); 05579 } 05580 surface_facets.append(cfe); 05581 } 05582 05583 facet_map.insert(std::make_pair(surface, surface_facets)); 05584 all_facets += surface_facets; 05585 } 05586 05587 // make facet edges for curves 05588 DLIList<CubitFacetEdge*> feature_edges; 05589 std::map<SurfaceFacets*, DLIList<CubitFacet*> >::iterator facet_map_iter; 05590 for(facet_map_iter = facet_map.begin(); facet_map_iter != facet_map.end(); ++facet_map_iter) 05591 { 05592 SurfaceFacets* surface = facet_map_iter->first; 05593 int num_loops = surface->curveTopology.size(); 05594 for(int i=0; i<num_loops; i++) 05595 { 05596 int num_curves = surface->curveTopology[i].size(); 05597 for(int j=0; j<num_curves; j++) 05598 { 05599 CurveFacets* edge_facets = surface->curveTopology[i][j].first; 05600 05601 if(facet_edge_map.find(edge_facets) == facet_edge_map.end()) 05602 { 05603 DLIList<CubitFacetEdge*> curve_facets; 05604 const std::vector<int>& curve_pts = edge_facets->points; 05605 for(size_t k=0; k<curve_pts.size()-1; k++) 05606 { 05607 CubitPoint* p1 = cubit_points[curve_pts[k]]; 05608 CubitPoint* p2 = cubit_points[curve_pts[k+1]]; 05609 CubitFacetEdge* edge = new CubitFacetEdgeData(p1, p2); 05610 feature_edges.append(edge); 05611 curve_facets.append(edge); 05612 edge->set_as_feature(); 05613 } 05614 facet_edge_map.insert(std::make_pair(edge_facets, curve_facets)); 05615 } 05616 } 05617 } 05618 } 05619 05620 // create facet edges for facets 05621 DLIList<CubitFacetEdge*> all_edges; 05622 FacetDataUtil::get_edges(all_facets, all_edges); 05623 05624 // create features edges (this puts multiple normals when necessary on features) 05625 ChollaEngine::make_features( feature_edges, CUBIT_FALSE ); 05626 05627 } 05628 05629 CubitStatus FacetModifyEngine::process_topology(SurfaceFacets* surface, CubitSense& coface_sense, 05630 int interp_order, const DLIList<CubitPoint*>& cubit_points, 05631 std::map<SurfaceFacets*, DLIList<CubitFacet*> >& facet_map, 05632 std::map<CurveFacets*, DLIList<CubitFacetEdge*> >& facet_edge_map, 05633 std::map<FacetShapes*, GeometryEntity*>& entity_map) 05634 { 05635 05636 DLIList<CubitFacet*>& surface_facets = facet_map.find(surface)->second; 05637 DLIList<CubitPoint*> surface_points; 05638 for(int i=0; i<surface_facets.size(); i++) 05639 { 05640 surface_facets[i]->points(surface_points); 05641 } 05642 surface_points.uniquify_unordered(); 05643 FacetEvalTool* surf_eval = new FacetEvalTool(); 05644 if ( CUBIT_SUCCESS != surf_eval->initialize(surface_facets, surface_points, interp_order, -1.0 ) ) 05645 return CUBIT_FAILURE; 05646 05647 int num_loops = surface->curveTopology.size(); 05648 05649 DLIList<LoopSM*> loops; 05650 05651 // loop through curves and construct them 05652 // surfaces that are reversed are flipped so we have outward facing normals (do we really need to do this?) 05653 for(int i=0; i<num_loops; i++) 05654 { 05655 DLIList<CoEdgeSM*> current_loop; 05656 int num_curves = surface->curveTopology[i].size(); 05657 for(int j=0; j<num_curves; j++) 05658 { 05659 CurveFacets* edge_facets = surface->curveTopology[i][j].first; 05660 CubitSense coedge_sense = surface->curveTopology[i][j].second; 05661 if(coface_sense == CUBIT_REVERSED) 05662 { 05663 coedge_sense = coedge_sense == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD; 05664 } 05665 process_topology(edge_facets, cubit_points, surf_eval, coedge_sense, facet_edge_map, entity_map); 05666 05667 CoEdgeSM* tmp_coedge; 05668 make_facet_coedge((Curve*)entity_map[surface->curveTopology[i][j].first], coedge_sense, tmp_coedge); 05669 05670 if(coface_sense == CUBIT_REVERSED) 05671 { 05672 current_loop.insert_first(tmp_coedge); 05673 } 05674 else 05675 { 05676 current_loop.append(tmp_coedge); 05677 } 05678 } 05679 05680 // make loop 05681 LoopSM* tmp_loop; 05682 make_facet_loop(current_loop, tmp_loop); 05683 loops.append(tmp_loop); 05684 } 05685 05686 // we've reversed it, so tell the caller 05687 if(coface_sense == CUBIT_REVERSED) 05688 { 05689 coface_sense = CUBIT_FORWARD; 05690 } 05691 05692 Surface* surf_ptr; 05693 make_facet_surface(NULL, surface_facets, surface_points, loops, interp_order, -1.0, 05694 surf_ptr, CUBIT_TRUE, surf_eval); 05695 entity_map[surface] = surf_ptr; 05696 return CUBIT_SUCCESS; 05697 } 05698 05699 void FacetModifyEngine::process_topology(CurveFacets* curve, 05700 const DLIList<CubitPoint*>& cubit_points, FacetEvalTool* surf_eval, CubitSense sense, 05701 std::map<CurveFacets*, DLIList<CubitFacetEdge*> >& facet_edge_map, 05702 std::map<FacetShapes*, GeometryEntity*>& entity_map) 05703 { 05704 // construct each point for the curves 05705 05706 for(size_t j=0; j<2; j++) 05707 { 05708 VertexFacets* vertex_facets = curve->vertexTopology[j]; 05709 if(entity_map.find(vertex_facets) == entity_map.end()) 05710 { 05711 TBPoint* new_vertex; 05712 make_facet_point(cubit_points[vertex_facets->point], new_vertex); 05713 entity_map.insert(std::make_pair(vertex_facets, new_vertex)); 05714 } 05715 } 05716 05717 // construct the curve 05718 if(entity_map.find(curve) == entity_map.end()) 05719 { 05720 DLIList<CubitFacetEdge*>& edge_list = facet_edge_map[curve]; 05721 DLIList<CubitPoint*> point_list; 05722 05723 for(int k=0; k<edge_list.size(); k++) 05724 { 05725 point_list.append(edge_list[k]->point(0)); 05726 } 05727 point_list.append(edge_list[edge_list.size()-1]->point(1)); 05728 05729 CurveFacetEvalTool* curve_facet_tool = new CurveFacetEvalTool; 05730 CubitStatus status = curve_facet_tool->initialize( edge_list, point_list, surf_eval); 05731 if (CUBIT_SUCCESS != status) { 05732 PRINT_ERROR("Failed to intitialize a CurveFacetEvalTool.\n"); 05733 return; 05734 } 05735 Curve* curve_ptr; 05736 make_facet_curve((TBPoint*)entity_map[curve->vertexTopology[0]], 05737 (TBPoint*)entity_map[curve->vertexTopology[1]], 05738 curve_ptr, curve_facet_tool); 05739 entity_map.insert(std::make_pair(curve, curve_ptr)); 05740 } 05741 } 05742 05743 // EOF
