cgma
00001 //- Class: FacetEvalTool 00002 //- Description: The FacetEvalTool is a general purpose tool that uses a set 00003 //- of facets to determine certain geometry computations. This 00004 //- class can be used to define a surface or do fast bounding box 00005 //- calculations, or determine point inside or outside. 00006 //- Assumptions: It is assumed/required that the facets be continuous through 00007 //- the set. In other words they must shared nodes and be conected 00008 //- through each other. The algorithms assume, for efficient searching, 00009 //- that from one facet, you can get to any other facet in the set. 00010 //- Owner: Steven J. Owen 00011 //- Checked by: 00012 00013 #ifndef SMOOTH_FACET_EVAL_TOOL_HPP 00014 #define SMOOTH_FACET_EVAL_TOOL_HPP 00015 00016 #include "DLIList.hpp" 00017 #include "AbstractTree.hpp" 00018 #include "CubitFacet.hpp" //For inline function. 00019 00020 template <class Y> class KDDTree; 00021 00022 namespace FacetEvalToolUtils { 00023 00024 template <typename R> inline R determ3(R p1, R q1, R p2, R q2, R p3, R q3) { 00025 return (q3) * ((p2) - (p1)) + (q2) * ((p1) - (p3)) + (q1) * ((p3) - (p2)); 00026 } 00027 template <typename R> inline R sqr(R a) { return a * a; } 00028 template <typename R> inline R cube(R a) { return sqr(a) * a; } 00029 template <typename R> inline R quart(R a) { return sqr(a) * sqr(a); } 00030 template <typename R> inline R blend(R x) { 00031 return -2.0 * (x) * (x) * (x) + 3.0 * (x) * (x); 00032 } 00033 00034 } // namespace FacetEvalToolUtils 00035 00036 class CubitBox; 00037 class CubitFacet; 00038 class CubitPoint; 00039 class CubitVector; 00040 class CubitTransformMatrix; 00041 00042 class FacetEvalTool 00043 { 00044 private: 00045 static double timeGridSearch; 00046 static double timeFacetProject; 00047 static int numEvals; 00048 00049 int toolID; 00050 int interpOrder; 00051 //- interpolation order 0=linear, 1=gradient, 2=quadratic, 4=quartic Bezier 00052 DLIList<CubitFacet*> myFacetList; 00053 //- Facets that are used for evaluation. 00054 DLIList<CubitFacet*> markedFacetList; 00055 //- Facets that are used for evaluation. 00056 DLIList<CubitPoint*> myPointList; 00057 //- point list 00058 DLIList<CubitFacetEdge*> myEdgeList; 00059 DLIList<DLIList<CubitFacetEdge*>*> myLoopList; 00060 //- edges only used for bezier interp 00061 AbstractTree <CubitFacet*> *aTree; 00062 //- used for surfaces with many facets 00063 CubitBox *myBBox; 00064 //- Bounding box of facets 00065 double myArea; 00066 //- area of the facet surface 00067 double compareTol; 00068 //- for comparing bounding box 00069 CubitFacet *lastFacet; 00070 //- The last facet evaluated 00071 int isFlat; 00072 //- The surface represented by the facets is flat 00073 CubitBoolean isParameterized; 00074 //- Surface contains a parameterization (uv values initialized) 00075 double minDot; 00076 //- computed from feature angle 00077 int output_id; 00078 00079 bool have_data_to_calculate_bbox(void); 00080 00081 void set_up_grid_search(double geom_factor); 00089 void facets_from_search_grid( CubitVector &this_point, 00090 DLIList<CubitFacet *> &facet_list, 00091 double &tol_used ); 00099 void facets_from_search_grid( CubitVector &this_point, 00100 double compare_tol, 00101 DLIList<CubitFacet *> &facet_list ); 00102 //- set up a grid search data structure if we have lots of facets 00103 00104 CubitStatus get_points_from_facets(DLIList<CubitFacet*> &facet_list, 00105 DLIList<CubitPoint*> &point_list ); 00106 //- populates the point_list with points contained by the given facets. 00107 CubitStatus get_edges_from_facets(DLIList<CubitFacet*> &facet_list, 00108 DLIList<CubitFacetEdge*> &edge_list ); 00109 //- populates the edge_list with edges contained by the given facets 00110 00111 //- populates the loop_list with edges contained by the given edge list 00112 void destroy_facets(); 00113 //- Destroys the facets, and points. 00114 00115 void debug_draw_edges(int color = -1 ); 00116 void debug_draw_edge(CubitFacetEdge *edge, int color = -1 ); 00117 void debug_draw_vec( CubitVector & vec, int color = -1 ); 00118 void debug_draw_facet_normals( int color = -1 ); 00119 void debug_draw_point_normals( int color = -1 ); 00120 void debug_draw_bezier_edges( int color = -1 ); 00121 void debug_draw_bezier_facets( int color = -1 ); 00122 void debug_draw_bezier_facet( CubitFacet *facet, int color = -1 ); 00123 void debug_draw_line( CubitVector &begin, CubitVector &end, int color = -1 ); 00124 void debug_draw_eval_bezier_facet( CubitFacet *facet ); 00125 void debug_draw_location( CubitVector &location, int color = -1 ); 00126 void write_loops(); 00127 //- drawing functions for debugging. 00128 00129 CubitStatus project_to_facets(CubitVector &this_point, 00130 CubitBoolean trim, 00131 CubitBoolean *outside, 00132 CubitVector *closest_point_ptr, 00133 CubitVector *normal_ptr); 00134 00135 CubitStatus init_gradient(); 00136 //- initiaize the gradients (tangent planes at the points) 00137 00138 CubitStatus init_quadrics(); 00139 //- initialize quadric coefficients at the points 00140 00141 CubitStatus eval_quadratic( CubitFacet *facet, 00142 int pt_idx, 00143 CubitVector &eval_pt, 00144 CubitVector &qpoint, 00145 CubitVector &qnorm ); 00146 //- evaluate on facet based on quadratic approximation 00147 00148 void on_circle( CubitVector &ptA, 00149 CubitVector &normA, 00150 CubitVector &ptB, 00151 CubitVector &normB, 00152 CubitVector &eval_pt, 00153 CubitVector &pt_on_circle, 00154 CubitVector &normal ); 00155 //- compute a projection of a point onto a circle. The circle 00156 //- is defined by two points and two normals. Return the 00157 //- projected point and its normal 00158 00159 void eval_quadric( CubitFacet *facet, 00160 int pt_index, 00161 CubitVector &eval_pt, 00162 CubitVector &qpt ); 00163 //- evaluate on facet based on quadratic approximation 00164 00165 CubitStatus get_close_points( CubitPoint *point, 00166 CubitPoint **close_point, 00167 int &num_close, 00168 int max_close, 00169 int min_close ); 00170 //- return an array of points that are close to the given point 00171 00172 static CubitStatus eval_bezier_patch( CubitFacet *facet, CubitVector &areacoord, 00173 CubitVector &pt ); 00174 static CubitStatus eval_bezier_patch_normal( CubitFacet *facet, 00175 CubitVector &areacoord, 00176 CubitVector &normal ); 00177 static CubitStatus hodograph( CubitFacet *facet, 00178 CubitVector &areacoord, 00179 CubitVector Nijk[10] ); 00180 static CubitStatus project_to_patch( CubitFacet *facet, 00181 CubitVector &ac, 00182 const CubitVector &pt, 00183 CubitVector &eval_pt, 00184 CubitVector *eval_norm, 00185 CubitBoolean &outside, 00186 double compare_tol, 00187 int edge_id /* = -1*/); 00188 //- Project a point to a bezier patch. Pass in the area 00189 //- of the point projected to the linear facet. Function 00190 //- assumes that the point is contained within the patch - 00191 //- if not, it will project to one of its edges. 00192 00193 static void ac_at_edge( CubitVector &fac, 00194 CubitVector &eac, 00195 int edge_id ); 00196 //- determine the area coordinate of the facet at the edge 00197 00198 static CubitBoolean is_at_vertex( CubitFacet *facet, 00199 const CubitVector &pt, 00200 CubitVector &ac, 00201 double compare_tol, 00202 CubitVector &eval_pt, 00203 CubitVector *eval_norm_ptr ); 00204 00205 static CubitBoolean move_ac_inside( CubitVector &ac, double tol ); 00206 //- find the closest area coordinate to the boundary of the 00207 //- patch if any of its components are < 0 00208 //- Return if the ac was modified. 00209 00210 void check_faceting(); 00211 00212 00213 // For a given point, find which pairs of edges 00214 // should be C1 across that point. 00215 CubitStatus mark_edge_pairs(CubitPoint* point); 00216 00217 //loop over the points and call the above function 00218 CubitStatus pair_edges(); 00219 00220 public: 00221 00222 FacetEvalTool(); 00223 //constructor 00224 ~FacetEvalTool(); 00225 //destructor 00226 00227 CubitStatus initialize( DLIList<CubitFacet*> &facet_list, DLIList<CubitPoint*> &point_list, 00228 int interp_order/* = -1*/, double min_dot/* = 0.707106781185*/ ); 00229 00230 int tool_id() 00231 { return toolID; }; 00232 00233 CubitStatus reverse_facets(); 00234 static CubitStatus reverse_facets(DLIList<CubitFacet *> &facets); 00235 00236 int get_output_id() { return output_id; } 00237 void set_output_id( int id ) { output_id = id; } 00238 00239 CubitStatus save( FILE *fp ); 00240 // save to a cubit file 00241 CubitStatus restore( FILE *fp, unsigned int endian, 00242 int num_facets, int num_edges, 00243 int num_points, CubitFacet **facets, 00244 CubitFacetEdge **edges, CubitPoint **points ); 00245 00246 //- get and set the interpolation order 00247 CubitBox bounding_box(); 00248 void set_bounding_box( CubitBox &box ) { *myBBox = box; } 00249 void reset_bounding_box(); 00250 //- Returns the bounding box for the set of facets (based on the points 00251 //- used in the faceted set. 00252 00253 double area(); 00254 //- return the surface area of the facets 00255 00256 void calculate_area(); 00257 //- (re) calcualte area to make sure it is up to date. 00258 00259 double get_min_dot() {return minDot;}; 00260 //- return the mindot (feature angle) 00261 00262 CubitStatus closest_point(CubitVector &this_point, 00263 CubitVector *closest_point_ptr, 00264 CubitVector *normal_ptr = NULL); 00265 //- Finds the closest point from the vector (this_point) to the 00266 //- set of facets that lies on the set of facets. If the point 00267 //- lies outside this set, the closest point will be on the plane 00268 //- of the closest facet. The closest_point is set to be that point. 00269 00270 CubitStatus closest_point_trimmed( CubitVector &this_point, 00271 CubitVector *closest_point_ptr, 00272 CubitBoolean &lies_outside, 00273 CubitVector *normal_ptr = NULL); 00274 //- Finds the closest point from the vector (this_point) to the 00275 //- set of facets that lies on the set of facets. If the point 00276 //- lies outside this set, the closest point will be on the edge 00277 //- of the closest facet. 00278 //- This function also determines if the point is outside or 00279 //- inside the current set of facets. You should call 00280 //- a bounding box test first before this... 00281 00282 CubitFacet* closest_facet( const CubitVector& point ); 00283 00284 int is_flat(); 00285 //- Determine if the set of facets are flat (all in the same plane) 00286 00287 static CubitStatus eval_facet( CubitFacet *facet, 00288 CubitVector &areacoord, 00289 CubitVector *eval_point, 00290 CubitVector *eval_normal ); 00291 //- evaluate the facet at the areacoords 00292 00293 CubitStatus eval_facet( CubitFacet *facet, 00294 CubitVector &pt, 00295 CubitVector &areacoord, 00296 CubitVector &close_point, 00297 CubitBoolean &outside_facet ); 00298 //- evaluate a location and normal on (or near) a facet based on the 00299 //- the facet area coordinates 00300 00301 static CubitStatus project_to_facet( CubitFacet *facet, 00302 const CubitVector &pt, 00303 CubitVector &areacoord, 00304 CubitVector &close_point, 00305 CubitBoolean &outside, 00306 double compare_tol); 00307 //- project a point to the given facet (assumes that it contains 00308 //- the point) areacoord is an initial guess - may be changed. 00309 00310 static CubitStatus project_to_facets(DLIList <CubitFacet *> &facet_list, 00311 CubitFacet *&last_facet, 00312 int interp_order, 00313 double compare_tol, 00314 const CubitVector &this_point, 00315 CubitBoolean trim, 00316 CubitBoolean *outside, 00317 CubitVector *closest_point_ptr, 00318 CubitVector *normal_ptr); 00319 //- project a point to the a list of facets using the interpolation 00320 //- order. Option to trim to boundary 00321 00322 static CubitStatus eval_edge( CubitFacet *facet, 00323 int vert0, int vert1, 00324 CubitVector &pt_on_plane, 00325 CubitVector &close_point); 00326 static CubitStatus project_to_facetedge( CubitFacet *facet, 00327 int vert0, int vert1, 00328 const CubitVector &the_point, 00329 CubitVector &pt_on_plane, 00330 CubitVector &close_point, 00331 CubitBoolean &outside_facet, 00332 CubitBoolean must_be_on_edge = CUBIT_FALSE); 00333 //- project a point to the edge of a facet 00334 //- if must_be_on_edge is true, close_point will be on the facet edge 00335 00336 static CubitStatus eval_point( CubitFacet *facet, 00337 int vertex_id, 00338 CubitVector &close_point ); 00339 //- evaluate a location at a vertex of a facet 00340 00341 static CubitStatus eval_facet_normal( CubitFacet *facet, 00342 CubitVector &areacoord, 00343 CubitVector &normal ); 00344 //- evaluate the normal on a facet (use the interpOrder) 00345 00346 static void project_to_facet_plane( CubitFacet *facet, 00347 const CubitVector &pt, 00348 CubitVector &point_on_plane, 00349 double &dist ); 00350 //- project a point to the plane of a facet 00351 00352 static void facet_area_coordinate( CubitFacet *facet, 00353 const CubitVector &pt_on_plane, 00354 CubitVector &areacoord ); 00355 //- define the area coordinates of a point on a plane of the facet 00356 00357 static CubitBoolean is_outside( CubitFacet *facet, 00358 CubitVector &areacoord ); 00359 //- determines if the point at the areacoord is outside 00360 //- the range of facets 00361 00362 DLIList<DLIList<CubitFacetEdge*>*> *loops() { return &myLoopList; }; 00363 //- return the edge loop list 00364 00365 int interp_order() { return interpOrder; }; 00366 //- return the interpolation order of the facet eval tool 00367 00368 void get_facets( DLIList<CubitFacet*> &facet_list ) { facet_list += myFacetList; }; 00369 void get_edges( DLIList<CubitFacetEdge*> &edge_list) { edge_list += myEdgeList; }; 00370 void get_points( DLIList<CubitPoint*> &point_list ) { point_list += myPointList; }; 00371 void remove_facets( DLIList<CubitFacet*>& facet_list ); 00372 //- return the facets and points defining the surface (append to list) 00373 00374 void replace_facets( DLIList<CubitFacet *> &facet_list ); 00375 // replace the facets on this FacetEvalTool 00376 00377 int num_facets() const {return myFacetList.size();}; 00378 //- get the number of facets 00379 00380 int num_points() const {return myPointList.size();}; 00381 //- get the number of points 00382 00383 double compare_tol() { return compareTol; }; 00384 void compare_tol(double tol) { compareTol = tol; }; 00385 //- set/get the comparison tolerance. 00386 00387 static double get_grid_search_time() 00388 { return timeGridSearch;} 00389 static double get_facet_project_time() 00390 { return timeFacetProject;} 00391 //- Returns static timing information for the two functions. 00392 00393 void debug_draw_facets(int color = -1 ); 00394 00395 void transform_control_points( CubitTransformMatrix &rotmat ); 00396 // transform all control points on the surface a specified 00397 // transformation matrix 00398 00399 CubitStatus init_bezier_surface( ); 00400 static CubitStatus init_bezier_facet( CubitFacet *facet ); 00401 static CubitStatus init_bezier_edge( CubitFacetEdge *edge, double min_dot ); 00402 static CubitStatus init_boundary_bezier_edge( CubitFacetEdge *edge ); 00403 static CubitStatus init_edge_control_points( CubitVector &P0, 00404 CubitVector &P3, 00405 CubitVector &N0, 00406 CubitVector &N3, 00407 CubitVector &T0, 00408 CubitVector &T3, 00409 CubitVector Pi[3] ); 00410 static CubitStatus init_edge_control_points_single( 00411 CubitVector &P0, 00412 CubitVector &P3, 00413 CubitVector &T0, 00414 CubitVector &T3, 00415 CubitVector Pi[3] ); 00416 static CubitStatus init_facet_control_points( CubitVector N[6], 00417 CubitVector P[3][5], 00418 CubitVector G[6] ); 00419 //- Initialize the bezier control points for 00420 //- G1 bezier patch surface interpolation 00421 00422 CubitStatus parameterize(); 00423 //- define a parameterization 00424 00425 static CubitStatus compute_curve_tangent( CubitFacetEdge *edge, 00426 double min_dot, 00427 CubitVector &T0, 00428 CubitVector &T3 ); 00429 //- compute curve tangent vectors at an aedge on the boundary 00430 static CubitFacetEdge *next_boundary_edge( CubitFacetEdge *this_edge, CubitPoint *p0 ); 00431 //- return the next edge on the boundary 00432 00433 CubitStatus get_intersections(CubitVector point1, 00434 CubitVector point2, 00435 DLIList<CubitVector*>& intersection_list, 00436 bool bounded = CUBIT_FALSE); 00437 00438 00439 // The following copyright applies to the following two functions... 00440 // 00441 // Copyright 2001, softSurfer (www.softsurfer.com) 00442 // 00443 // This code may be freely used and modified for any purpose 00444 // providing that this copyright notice is included with it. 00445 // SoftSurfer makes no warranty for this code, and cannot be held 00446 // liable for any real or imagined damage resulting from its use. 00447 // Users of this code must verify correctness for their application. 00448 00449 static int intersect_ray( CubitVector &origin, CubitVector &direction, CubitFacet* facet, CubitVector* point, double &distance ); 00450 //- Find intersection point of a ray and a facet 00451 // Return: -1 = triangle is degenerate (a segment or point) 00452 // 0 = disjoint (no intersect) 00453 // 1 = intersect at unique point 00454 // 2 = are in the same plane 00455 00456 static int intersect_ray( CubitVector &origin, CubitVector &direction, CubitFacetEdge* facet, CubitVector* point, double &distance ); 00457 //- Find intersection point of a ray and a facet edge 00458 // Return: -1 = edge is degenerate (a point) 00459 // 0 = disjoint (no intersect) 00460 // 1 = intersect at unique point 00461 // 2 = are the same line (infinite points) 00462 00463 00464 CubitStatus get_loops_from_facets(DLIList<CubitFacetEdge*> &all_edge_list, 00465 DLIList<DLIList<CubitFacetEdge*>*> &loop_list ); 00466 00467 00468 static double contained_volume( DLIList<CubitFacet *> &facets ); 00469 //- computed the contained volume of a set of facets 00470 // Return: volume of facets (may be negative based on orientation of facets) 00471 00472 }; 00473 00474 #endif // SMOOTH_FACET_EVAL_TOOL_HPP 00475 00476 00477 00478 00479
