cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetCurve.hpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Steven J. Owen 00009 // 00010 // Creation Date : 07/14/00 00011 // 00012 // Owner : Steven J. Owen 00013 //------------------------------------------------------------------------- 00014 00015 #ifndef CURVE_FACET_HPP 00016 #define CURVE_FACET_HPP 00017 00018 // ********** BEGIN STANDARD INCLUDES ********** 00019 // ********** END STANDARD INCLUDES ********** 00020 00021 // ********** BEGIN CUBIT INCLUDES ********** 00022 #include "CubitDefines.h" 00023 #include "Curve.hpp" 00024 #include "FacetAttribSet.hpp" 00025 // ********** END CUBIT INCLUDES ********** 00026 00027 // ********** BEGIN FORWARD DECLARATIONS ********** 00028 class TopologyEntity; 00029 class CurveFacetEvalTool; 00030 class FacetEvalTool; 00031 class FacetAttrib; 00032 class CurveFacetEvalTool; 00033 class TBPoint; 00034 class CubitPoint; 00035 class CubitFacetEdge; 00036 class CubitFacetEdge; 00037 00038 class FacetBody; 00039 class FacetLump; 00040 class FacetShell; 00041 class FacetSurface; 00042 class FacetLoop; 00043 class FacetCoEdge; 00044 class FacetPoint; 00045 00046 // ********** END FORWARD DECLARATIONS ********** 00047 00048 class FacetCurve : public Curve 00049 { 00050 public : 00051 00052 FacetCurve( CurveFacetEvalTool *curve_facet_tool, 00053 TBPoint *fp0, TBPoint *fp1, 00054 DLIList<CoEdgeSM*> &coedgelist ); 00055 //I- curve_facet_eval_tool_ptr pointer 00056 //I- A pointer to the set of facet edges that define this curve. 00057 00058 FacetCurve( CurveFacetEvalTool *curve_facet_tool, 00059 TBPoint *fp0, TBPoint *fp1, 00060 CubitSense sense ); 00061 //I- curve_facet_eval_tool_ptr pointer 00062 //I- start and end points 00063 //I- Sense of curve 00064 00065 virtual ~FacetCurve() ; 00066 //- The destructor 00067 00068 00069 virtual void append_simple_attribute_virt(const CubitSimpleAttrib&); 00070 //R void 00071 //I 00072 //I- 00073 //I- that is to be appended to this OSME object. 00074 //- The purpose of this function is to append a 00075 //- attribute to the OSME. The is attached to each of the 00076 //- underlying solid model entities this one points to. 00077 00078 virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&); 00079 //R void 00080 //I CubitSimpleAttrib* 00081 //I- A reference to a CubitSimpleAttrib object which is the object 00082 //I- that is to be removed to this OSME object. 00083 //- The purpose of this function is to remove a simple 00084 //- attribute from the OSME. The attribute is attached to each of the 00085 //- underlying solid model entities this one points to. 00086 00087 virtual void remove_all_simple_attribute_virt(); 00088 //R void 00089 //I- 00090 //- The purpose of this function is to remove all simple 00091 //- attributes from the OSME. 00092 00093 virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&); 00094 virtual CubitStatus get_simple_attribute(const CubitString& name, 00095 DLIList<CubitSimpleAttrib>&); 00096 //R CubitSimpleAttrib* 00097 //R- the returned cubit simple attribute. 00098 //- The purpose of this function is to get the attributes 00099 //- of the geometry entity. The name is attached to the underlying solid 00100 //- model entity(ies) this one points to. 00101 //- MJP Note: 00102 //- This is the code that implements the requirement that names 00103 //- of VGI Entities propagate across solid model boolean 00104 //- operations. The success of this relies, of course, on the underlying 00105 //- solid modeler being able to propagate attributes across 00106 //- such operations on its entities. If it cannot, then "names" 00107 //- of VGI entities will not propagate. 00108 00109 virtual CubitBox bounding_box() const ; 00110 //- see comments in GeometryEntity.hpp 00111 00112 virtual GeometryQueryEngine* 00113 get_geometry_query_engine() const; 00114 //R GeometryQueryEngine* 00115 //R- A pointer to the geometric modeling engine associated with 00116 //R- the object. 00117 //- This function returns a pointer to the geometric modeling engine 00118 //- associated with the object. 00119 00120 virtual double measure(); 00121 //R double 00122 //R- The numeric value of the measure (its units depend on the dimension 00123 //R- of the RefEntity being "measured") 00124 //- A generic geometric extent function. 00125 //- Returns volume for Lump, area for Surface, length for Curve and 00126 //- 1.0 for Point 00127 //- 00128 //- If there is an error computing the length a value of -1.0 is 00129 //- returned. 00130 00131 virtual double length_from_u( double parameter1, 00132 double parameter2 ); 00133 //R double 00134 //R- Returned length value 00135 //I parameter1 00136 //I- The first parameter value 00137 //I parameter2 00138 //I- The second parameter value 00139 //- This function returns the arc length along the Curve starting from 00140 //- the point represented by the parameter1 going to the point represented 00141 //- by parameter2. 00142 00143 virtual CubitBoolean is_periodic( double& period); 00144 //R CubitBoolean 00145 //R- CUBIT_TRUE/CUBIT_FALSE 00146 //O period 00147 //O- Returned period value 00148 //- This function determines whether the underlying geometry of the 00149 //- Curve is periodic or not. Returns CUBIT_TRUE if it is and 00150 //- CUBIT_FALSE if it is not. 00151 //- 00152 //- If it is periodic, then it returns the period in the input 00153 //- reference variable, "period". This value is set to 0.0 if 00154 //- the Curve is not periodic. 00155 //- 00156 00157 virtual CubitBoolean get_param_range( double& lower_bound, 00158 double& upper_bound ); 00159 //R CubitBoolean 00160 //R- CUBIT_TRUE/CUBIT_FALSE 00161 //O lower_bound 00162 //O- The lower bound of the parametric range. 00163 //O upper_bound 00164 //O- The upper bound of the parametric range. 00165 //- Returns the lower and upper parametric bounds of the 00166 //- Curve. 00167 //- 00168 //- IMPORTANT NOTE: 00169 //- Note that the lower bound is the parameter value of the start 00170 //- location of the RefEdge that uses this Curve and the upper 00171 //- bound is the parameter value of the end location of the RefEdge 00172 //- that uses this Curve. This takes into account the sense of the 00173 //- RefEdge with respect to the Curve (which could be REVERSED). 00174 //- Hence, the numerical value of the lower parameter bound could be 00175 //- greater than that of the upper parameter bound. 00176 00177 virtual CubitStatus get_interior_extrema(DLIList<CubitVector*>& interior_points, 00178 CubitSense& return_sense); 00179 //- Finds the extrema along this RefEdge. An extremum is defined as 00180 //- a local min or max in the direction of one of the primary axial directions. 00181 //- O-interior_points: list of coordinates where the extrema occur. 00182 //- O-return_sense: Whether the interior extrema are ordered in the 00183 //- FORWARD or REVERSED direction of this RefEdge. 00184 //- 00185 //- ***IMPORTANT!!!*** 00186 //- This function dynamically allocates the CubitVectors appended to 00187 //- interior_points. It is the responsibility of the calling code to 00188 //- delete these CubitVectors (or in the case of RefEdge, to make sure 00189 //- that *it's* calling code knows that it should delete the CubitVectors)! 00190 00191 virtual CubitStatus closest_point( CubitVector const& location, 00192 CubitVector& closest_location, 00193 CubitVector* tangent_ptr = NULL, 00194 CubitVector* curvature_ptr = NULL, 00195 double *param = NULL); 00196 //R void 00197 //I location 00198 //I- The point to which the closest point on the Curve is desired. 00199 //O closest_location 00200 //O- The point on the Curve, closest to the input location which 00201 //O- might not be on the Curve. This is input as a reference 00202 //O- so that the function can modify its contents. 00203 //O tangent_ptr 00204 //O- The tangent to the Curve (output as a unit vector) at the 00205 //O- closest_location. 00206 //O curvature_ptr 00207 //O- The curvature of the Curve at the closest_location. 00208 //- This function computes the point on the Curve closest to the input 00209 //- location. 00210 //- 00211 //- If the tangent and/or curvature is required, then the calling code 00212 //- is responsible for allocating space for the CubitVector(s) and 00213 //- sending in the relevant non-NULL pointers. If either of these 00214 //- pointers is NULL, the related quantity is not computed. 00215 //- 00216 //- Notes: 00217 //- The tangent direction is always in the positive direction of the 00218 //- *owning RefEdge*, regardless of the positive direction of the 00219 //- underlying solid model entities. 00220 00221 virtual CubitStatus position_from_u (double u_value, 00222 CubitVector& output_position); 00223 //R CubitStatus 00224 //R- CUBIT_SUCCESS/FAILURE 00225 //I u_value 00226 //I- The input u parameter value 00227 //O output_position 00228 //O- The output position 00229 //- This function returns the coordinates of a point in the global 00230 //- (world) space that corresponds to the input parametric position 00231 //- in the local space. 00232 //- 00233 //- If the input parameter value is not defined for the Curve, then 00234 //- the input CubitVector is not modified and CUBIT_FAILURE is 00235 //- returned. Otherwise, position is appropriately modified and 00236 //- CUBIT_SUCCESS is returned. 00237 //- 00238 //- If the curve is periodic, the input u_value is first "normalized" 00239 //- to the fundamental period of the Curve before its position 00240 //- in global space is determined. 00241 00242 double u_from_position (const CubitVector& input_position); 00243 00244 virtual double u_from_arc_length ( double root_param, 00245 double arc_length ); 00246 //R double 00247 //R- Returned parameter value 00248 //I root_param 00249 //I- The parameter value of the "root point" 00250 //I arc_length 00251 //I- A distance along the Curve 00252 //- This function returns the parameter value of the point that is 00253 //- "arc_length" away from the root point in the 00254 //- positive sense direction of the owning RefEdge. 00255 //- 00256 //- If arc_length is negative, the new point (whose parameter value is 00257 //- being computed) is in the negative sense direction (along the 00258 //- RefEdge) from the root point (whose parameter value is root_param). 00259 00260 virtual CubitBoolean is_position_on( const CubitVector &test_position ); 00261 //R CubitBoolean 00262 //R- CUBIT_TRUE/CUBIT_FALSE 00263 //I CubitVector 00264 //I- position, point where we want to test, whether or not it 00265 //- is on the curve. 00266 00267 GeometryType geometry_type(); 00268 //R GeometryType (enum) 00269 //R- The enumerated type of the geometric representation 00270 00271 CubitStatus get_point_direction( CubitVector& origin, CubitVector& direction ); 00272 //- Only valid for straight lines 00273 //- Finds the underlying line's origin and direction unit vector 00274 //- Returns CUBIT_FAILURE if curve is not a line 00275 00276 CubitStatus get_center_radius( CubitVector& center, double& radius ); 00277 //- Only valid for arcs 00278 //- Finds the underlying arc's center point and radius 00279 //- Returns CUBIT_FAILURE if curve is not an arc 00280 00281 virtual double start_param(); 00282 //R double parameter 00283 //R- start parameter of curve with respect to refEdge. 00284 00285 virtual double end_param(); 00286 //R double parameter 00287 //R- start parameter of curve with respect to refEdge. 00288 00289 virtual CubitBoolean G1_discontinuous( double param, 00290 CubitVector* minus_tangent = NULL, 00291 CubitVector* plus_tangent = NULL ); 00292 00293 virtual CubitPointContainment point_containment( const CubitVector &point ); 00294 virtual CubitPointContainment point_containment( double u, double v ); 00295 virtual CubitPointContainment point_containment( CubitVector &point, 00296 double u, double v ); 00297 //R CubitPointContainment - is the point outside, inside or on the boundary? 00298 //R- CUBIT_PNT_OUTSIDE, CUBIT_PNT_INSIDE, CUBIT_PNT_BOUNDARY, 00299 // CUBIT_PNT_UNKNOWN 00300 //I CubitVector 00301 //I- position to check, known to be on the Surface 00302 //I double 00303 //I- u coordinate, if known (significantly faster, if this is known - however 00304 // if not known let the function figure it out) 00305 //I double 00306 //I- v coordinate, if known (significantly faster, if this is known - however 00307 // if not known let the function figure it out) 00308 // NOTE: POINT MUST LIE ON THE SURFACE FOR THIS FUNCTION TO WORK PROPERLY. 00309 00310 CubitStatus save_attribs( FILE* file_ptr ); 00311 // Write FactAttribs out to file 00312 00313 CubitStatus restore_attribs( FILE* file_ptr, unsigned int endian ); 00314 // Read FactAttribs from file 00315 00316 void get_lumps ( DLIList<FacetLump *>& lumps ); 00317 void get_shells ( DLIList<FacetShell *>& shells ); 00318 void get_surfaces( DLIList<FacetSurface*>& surfaces ); 00319 void get_loops ( DLIList<FacetLoop *>& loops ); 00320 void get_coedges ( DLIList<FacetCoEdge *>& coedges ); 00321 void get_points ( DLIList<FacetPoint *>& points ); 00322 00323 void get_parents_virt( DLIList<TopologyBridge*>& parents ); 00324 void get_children_virt( DLIList<TopologyBridge*>& children ); 00325 00326 void add_coedge( CoEdgeSM *coedge_ptr ) 00327 { myCoEdges.append_unique( coedge_ptr ); } 00328 //- associate this curve with a coedge 00329 00330 void get_facets(DLIList<CubitFacetEdge*>& facet_list); 00331 //- Gets the list of facets describing this curve. 00332 void get_points(DLIList<CubitPoint*>& point_list); 00333 //- Gets the list of points describing this curve. 00334 00335 void reset_length(); 00336 //- update the length of the facet curve 00337 00338 CurveFacetEvalTool *get_eval_tool() 00339 { return curveFacetEvalTool; } 00340 //- return the curve evaluation tool 00341 00342 void set_eval_tool( CurveFacetEvalTool *eval_tool) 00343 { curveFacetEvalTool = eval_tool; } 00344 //- set the curve evaluation tool 00345 00346 TBPoint *start_point() 00347 { return myStartPoint; } 00348 TBPoint *end_point() 00349 { return myEndPoint; } 00350 CubitSense get_sense() { return sense_; } 00351 00352 CubitStatus disconnect_coedge( FacetCoEdge* coedge ); 00353 00354 void remove_start_point() { myStartPoint = 0; } 00355 void remove_end_point() { myEndPoint = 0; } 00356 00357 bool has_parent_coedge() { return myCoEdges.size() > 0; } 00358 00359 //R CubitStatus 00360 //O- true or false if spline is rational or not. 00361 //O- the degree of this spline 00362 //O- the control points 00363 //O- If rational, weight for each control point 00364 //O- the knots 00365 //O- whether underlying spline is reversed 00366 virtual CubitStatus get_spline_params( bool &rational, 00367 int °ree, 00368 DLIList<CubitVector> &cntrl_pts, 00369 DLIList<double> &cntrl_pt_weights, 00370 DLIList<double> &knots, 00371 bool &spline_is_reversed 00372 ) const; 00373 //R CubitStatus 00374 //O- center - ellipse center point 00375 //O- normal - normal of the plane of the ellipse 00376 //O- major_axis - major axis of the ellipse 00377 //O- radius_ratio - ratio of the length of the major to minor axis. 00378 virtual CubitStatus get_ellipse_params( CubitVector ¢er, 00379 CubitVector &normal, 00380 CubitVector &major_axis, 00381 double &radius_ratio ) const; 00382 00383 int id() {return myId;} 00384 00385 protected: 00386 00387 private: 00388 00389 CubitSense get_relative_curve_sense(); 00390 //R CubitSense 00391 //R- Returned sense value 00392 //- Returns the sense of the RefEdge with respect to the underlying 00393 //- facet curve. 00394 00395 void adjust_periodic_parameter(double& param); 00396 00397 CubitSense sense_; 00398 //- The sense of the RefEdge that owns this Curve with respect 00399 //- to the positive sense of the first EDGE in EDGEPtrList_. 00400 //- When a Curve is first constructed, this value is arbitrarily 00401 //- set to CUBIT_FORWARD. 00402 //- MJP NOTE: 00403 //- Not only does the RefEdge have a sense wrt its Curve, but each 00404 //- EDGE has a sense wrt its underlying "curve" object. 00405 00406 FacetAttribSet attribSet; 00407 //List of FacetAttrib*'s instead of CubitSimpleAttribs 00408 00409 friend void run_test_function(); 00410 00411 CurveFacetEvalTool *curveFacetEvalTool; 00412 TBPoint *myStartPoint; 00413 TBPoint *myEndPoint; 00414 DLIList<CoEdgeSM*> myCoEdges; 00415 int myId; 00416 bool periodic; 00417 }; 00418 00419 // ********** BEGIN INLINE FUNCTIONS ********** 00420 // ********** END INLINE FUNCTIONS ********** 00421 00422 // ********** BEGIN FRIEND FUNCTIONS ********** 00423 // ********** END FRIEND FUNCTIONS ********** 00424 00425 // ********** BEGIN EXTERN FUNCTIONS ********** 00426 // ********** END EXTERN FUNCTIONS ********** 00427 00428 #endif 00429
