cgma
00001 //- Class: ChollaSurface 00002 //- Owner: Steven J. Owen 00003 //- Description: Maintains a list of mesh. This is used to store 00004 //- the exterior skin while creating a geometry from a mesh. 00005 //- Created: 5/25/00 00006 //- Checked By: 00007 //- Version: 00008 00009 #ifndef ChollaSurface_HPP 00010 #define ChollaSurface_HPP 00011 00012 00013 #include "DLIList.hpp" 00014 #include "ChollaEntity.hpp" 00015 00016 class ChollaVolume; 00017 class ChollaCurve; 00018 class ChollaPoint; 00019 class FacetEntity; 00020 class CubitFacet; 00021 class CubitPoint; 00022 class CubitFacetEdge; 00023 class FacetEvalTool; 00024 00025 class ChollaSurface : public ChollaEntity 00026 { 00027 private: 00028 int id; 00029 int blockId; 00030 CubitBoolean myFlag; 00031 00032 DLIList<FacetEntity*> surfaceElemList; 00033 DLIList<ChollaCurve*> curveList; 00034 DLIList<ChollaVolume*> volList; 00035 void *mySurface; 00036 FacetEvalTool *myEvalTool; 00037 ChollaSurface *myMergePartner; 00038 void check_faceting(); 00039 00040 public: 00041 00042 ChollaSurface(int block_id); 00043 ~ChollaSurface(); 00044 00045 void get_facets(DLIList<FacetEntity*> &surface_facets) 00046 {surface_facets += surfaceElemList;} 00047 void get_points( DLIList<CubitPoint *> &point_list ); 00048 00049 void assign_geometric_surface(void *surf) 00050 {mySurface = surf;} 00051 void* get_geometric_surface() 00052 {return mySurface;} 00053 void assign_eval_tool(FacetEvalTool *eval_tool_ptr) 00054 {myEvalTool = eval_tool_ptr;} 00055 FacetEvalTool* get_eval_tool() 00056 {return myEvalTool;} 00057 00058 ChollaSurface *merge_partner(){ return myMergePartner; } 00059 void set_merge_partner( ChollaSurface *merge_partner ) 00060 { myMergePartner = merge_partner;} 00061 00062 CubitBoolean get_flag(){ return myFlag; } 00063 void set_flag( CubitBoolean stat ){ myFlag = stat; } 00064 00065 void add_facet(FacetEntity *exterior_face) 00066 {surfaceElemList.append(exterior_face);} 00067 00068 int add_mesh_unique(FacetEntity *exterior_face) 00069 {return surfaceElemList.append_unique(exterior_face);} 00070 00071 void remove_facet( FacetEntity *facet ) 00072 {surfaceElemList.remove( facet );} 00073 00074 bool is_contain( FacetEntity *facet ); 00075 00076 DLIList<FacetEntity*> &get_facet_list() 00077 {return surfaceElemList;} 00078 DLIList<FacetEntity*> *get_facet_list_ptr() 00079 {return &surfaceElemList;} 00080 void get_vertices( DLIList<ChollaPoint *> &chpt_list ); 00081 void get_curves( DLIList<ChollaCurve*> &bcm_list ) 00082 {bcm_list = curveList; } 00083 void add_curve( ChollaCurve *bcm_ptr ) 00084 {curveList.append(bcm_ptr);} 00085 void add_curve_unique( ChollaCurve *bcm_ptr ) 00086 {curveList.append_unique(bcm_ptr);} 00087 void remove_curve( ChollaCurve *bcm_ptr) 00088 {curveList.remove(bcm_ptr);} 00089 void get_volumes( DLIList<ChollaVolume*> &cholla_vol_list ) 00090 {cholla_vol_list = volList; } 00091 void add_volume( ChollaVolume *cholla_vol_ptr ) 00092 {volList.append(cholla_vol_ptr);} 00093 void add_volume_unique( ChollaVolume *cholla_vol_ptr ) 00094 {volList.append_unique(cholla_vol_ptr);} 00095 void remove_volume( ChollaVolume *cholla_vol_ptr) 00096 {volList.remove(cholla_vol_ptr);} 00097 int num_volumes(){return volList.size();} 00098 CubitBoolean is_in_volume( ChollaVolume *chvol_ptr ); 00099 00100 int get_block_id() 00101 {return blockId;} 00102 void set_block_id(int flag) 00103 { blockId = flag; } 00104 00105 int get_id(){return id;} 00106 00107 CubitStatus get_adj_facets( FacetEntity *start_face_ptr, 00108 DLIList<FacetEntity*> &face_list, 00109 int mydebug = 0, 00110 bool bound_check = false, 00111 bool feature_edge_check = true); 00112 // recursive function that creates a list of all faces connected 00113 // the passed in face that are part of this surface (or shell) 00114 00115 00116 CubitStatus split_surface( DLIList<ChollaSurface*> &block_surface_list ); 00117 // split this surface into multiple ChollaSurface where there are 00118 // discontinuous faces. 00119 00120 CubitStatus feature_angle( double min_dot, 00121 DLIList<CubitFacetEdge *> &feature_edge_list); 00122 // mark all edges that exceed the specified feature angle 00123 // min_dot is the minimum dot product between adjacent face normals 00124 00125 CubitStatus add_preexisting_feature_edges( DLIList<CubitFacetEdge *> &feature_edge_list); 00126 // edges that were marked previously in function ChollaEngine::mark_features 00127 // are added to the feature edge list 00128 00129 CubitStatus non_manifold_edges( DLIList<CubitFacetEdge *> &feature_edge_list ); 00130 // mark all edges that are non-manifold (have more than 2 adj facets 00131 00132 CubitStatus clean_features( ); 00133 // clean up edges that do not form complete loops as a result 00134 // of feature angle 00135 00136 void init_hit_flags(); 00137 // initialize the hit flags to the block surface id - used for 00138 // traversing the faces 00139 00140 CubitStatus update_boundary_tool_data(); 00141 //- update the surface IDs on the boundary facet tooldatas 00142 00143 void reset_facet_flags(); 00144 //- reset the marked flags on the facets 00145 00146 CubitBoolean is_adjacent( ChollaSurface *other_surf ); 00147 //- determine if other_surf is adjacent to this surface 00148 00149 DLIList<DLIList<CubitFacetEdge *>*> *get_loop_edges( ); 00150 // return the ordered list of edges on the boundary of this surface 00151 00152 void flip_facets(); 00153 // invert all the facets on this surface 00154 00155 void debug_draw(); 00156 }; 00157 00158 template <> struct DLIListSorter<ChollaSurface*> 00159 { 00160 bool operator()(ChollaSurface* a, ChollaSurface* b) { return a->get_id() < b->get_id(); } 00161 }; 00162 00163 #endif 00164 00165 00166 00167 00168
