cgma
00001 00011 #ifndef CHOLLA____H 00012 #define CHOLLA____H 00013 00014 #define NUM_EDGE_CPTS 3 00015 #define NUM_TRI_CPTS 6 00016 #define NUM_QUAD_CPTS 15 00017 00018 #include "CubitDefines.h" 00044 void constructBezier( double angle, int numTri, int numQuad, int numEdge, 00045 int numVert, int* triEdge, int* quadEdge, 00046 int* edgeVert, double* vert, 00047 double* edgeCtrlPts, double* triCtrlPts, 00048 double* quadCtrlPts ); 00049 00076 void constructTriNormals( double angle, int numTri, int numEdge, 00077 int numVert, int* triEdge, 00078 int* edgeVert, double* vert, 00079 double* triVertNorms, double* edgeVertTang, 00080 int* edgeTypeFlags); 00081 00108 void constructQuadNormals( double angle, int numQuad, int numEdge, 00109 int numVert, int* quadEdge, 00110 int* edgeVert, double* vert, 00111 double* quadVertNorms, double* edgeVertTang, 00112 int* edgeTypeFlags); 00113 00131 CubitStatus constructTriNormalsFromFile( const char *filename, 00132 int numTri, 00133 int numEdge, 00134 int* triEdge, 00135 int* edgeVert, 00136 double* triVertNorms, 00137 double* edgeVertTang ); 00138 00159 CubitStatus constructQuadNormalsFromFile( const char *filename, 00160 int numQuad, 00161 int numEdge, 00162 int* quadEdge, 00163 int* edgeVert, 00164 double* quadVertNorms, 00165 double* edgeVertTang ); 00166 00194 CubitStatus readMBGNormalFile( const char *filename, 00195 int *numTri, 00196 int *numQuad, 00197 int *numEdge, 00198 int **edgeVert, 00199 double **edgeVertTang, 00200 int **triVert, 00201 double **triVertNorms, 00202 int **quadVert, 00203 double **quadVertNorms ); 00204 00253 void evalBezierFace( int numFace, int numEdge, int numVert, int numVertPerFace, 00254 int* faceEdge, int* edgeVert, 00255 double* vert, double* faceCtrlPts, 00256 double* edgeCtrlPts, 00257 int numLocs, double* paramLocation, 00258 double* location, double* normal, double* deriv ); 00259 00276 void evalBezierFaceFromNorms( int numFace, int numEdge, int numVert, 00277 int numVertPerFace, int* faceEdge, int* edgeVert, 00278 double* vert, double* vertNorms, double* edgeVertTang, 00279 int numLocs, double* paramLocation, 00280 double* location, double* normal, double* deriv ); 00281 00332 void projToBezierFace( int numFace, int numEdge, int numVert, int numVertPerFace, 00333 int* faceEdge, int* edgeVert, 00334 double* vert, double* faceCtrlPts, 00335 double* edgeCtrlPts, 00336 int numLocs, double* xyz, 00337 int specify_tol, double converge_tol, 00338 double* xyzOnFace, double* normal, double* deriv ); 00339 00356 void projToBezierFaceFromNorms( int numFace, int numEdge, int numVert, int numVertPerFace, 00357 int* faceEdge, int* edgeVert, 00358 double* vert, double* vertNorms, 00359 double* edgeVertTang, 00360 int numLocs, double* xyz, 00361 int specify_tol, double converge_tol, 00362 double* xyzOnFace, double* normal, double* deriv ); 00363 00387 void evalBezierEdgeFromTans( int numEdge, int numVert, int* edgeVert, 00388 double* vert, double* edgeVertTang, 00389 int numLocs, double* paramLocation, 00390 double* location, double* tangent ); 00417 void evalBezierEdge( int numEdge, int numVert, int* edgeVert, 00418 double* vert, double* edgeCtrlPts, 00419 int numLocs, double* paramLocation, 00420 double* location, double* tangent ); 00421 00446 void projToBezierEdgeFromTans( int numEdge, int numVert, int* edgeVert, 00447 double* vert, double* edgeVertTang, 00448 int numLocs, double* xyz, 00449 double* xyzOnEdge, double* tangent ); 00450 00479 void projToBezierEdge( int numEdge, int numVert, int* edgeVert, 00480 double* vert, double* edgeCtrlPts, 00481 int numLocs, double* xyz, 00482 double* xyzOnEdge, double* tangent, double* t_value ); 00483 00488 /* 00489 * 00490 * 00491 * 00492 * 00493 */ 00494 /* dump the face mesh to a file that can be read by CUBIT 00495 * Use the same definition of parameters as used with resolveFaceVectors 00496 * 00497 * @param fileName - name of file to write to (will be overwritten) 00498 * @param includeResults- if (0) then don't write face/edge vectors to file 00499 */ 00500 void dumpMesh(const char *fileName, int includeResults, double angle, 00501 int numTri, int numQuad, int numEdge, 00502 int numVert, int* triEdge, int* quadEdge, 00503 int* edgeVert, double* vert, 00504 double* edgeCtrlPts, double* triCtrlPts, 00505 double* quadCtrlPts); 00506 00507 /* dump only the results to a file 00508 */ 00509 void dumpResults(const char *fileName, int numEdge, int numTri, int numQuad, 00510 double* edgeCtrlPts, double* triCtrlPts, 00511 double* quadCtrlPts ); 00512 00513 /* import the face mesh from the specified file 00514 * This is used by Cubit for debugging purposes 00515 * 00516 * @param fileName - name of file to read from. 00517 * (file typically written by dumpMesh) 00518 */ 00519 void importMesh(const char *fileName, int *resultsIncluded, 00520 double *angle, int *numTri, int *numQuad, int *numEdge, 00521 int *numVert, int** triEdge, int** quadEdge, 00522 int** edgeVert, double** vert, 00523 double** edgeCtrlPts, double** triCtrlPts, 00524 double** quadCtrlPts); 00525 00526 /* read only the results from a file 00527 */ 00528 void importResults(const char *fileName, int *numEdge, int *numTri, 00529 int *numQuad, double** edgeCtrlPts, double** triCtrlPts, 00530 double** quadCtrlPts ); 00531 00532 00533 #endif
